  4. TileBoard für Noobs ?
    2.4k
    4.4k
vishow-totemplate
41 Beiträge 5 Kommentatoren 5.8k Aufrufe 6 Beobachtet
  • CrunkFXC CrunkFX
    @uvillers Kannst du mal den Script hier schicken?
    U Offline
    U Offline
    uvillers
    @CrunkFX gern:
    /* my Config
    Uli am 12.05.2020
    var CONFIG = {
    customTheme: CUSTOM_THEMES.COMPACT,
    transition: TRANSITIONS.ANIMATED_GPU,
    entitySize: ENTITY_SIZES.NORMAL,
    tileSize: 150,
    tileMargin: 6,
    serverUrl: "http://192.168.70.2:8082",
    wsUrl: "ws://192.168.70.2:8082/api/websocket",
    authToken: null,
    timeFormat: 24,
    menuePosition: MENU_POSITIONS.LEFT, //oder BOTTOM
    //groupsAlign
    pages: [
    title: '@home',
    bg: 'images/bg1.jpeg',
    icon: 'mdi-home-outline',
    header: DEFAULT_HEADER,
    groups: [
    title: 'Group title',
    width: 2,
    height: 3,
    groupMarginCss: '20px 40px',
    hidden: Boolean | Function,
    items: [
    //Start Arbeitszimmer
    position: [0, 1],
    type: TYPES.SWITCH,
    title: 'Arbeitszimmer',
    subtitle: 'Schreibtisch',
    states: {
    on: "On",
    off: "Off"
    icons: {
    on: "mdi-lightbulb-on",
    off: "mdi-lightbulb",
    }, //Ende Arbeitszimmer
                   position: [1, 1],
                   subtitle: 'Dimmer',
                   type: TYPES.SLIDER,
                   states: {
                      on: "On",
                      off: "Off"
                   icons: {
                  /*sliders: [
                         position: [1, 2],
                         title: 'Brightness',
                         field: 'brightness',
                            type: TYPES.SLIDER,
                         max: 255,
                         min: 0,
                         step: 5,
                         request: {
                            type: "call_service",
                            domain: "light",
                            service: "turn_on",
                            field: "brightness"
                         title: 'Color temp',
                         field: 'color_temp',
                         max: 588,
                         min: 153,
                         step: 15,
                         request: {
                            domain: "light",
                            service: "turn_on",
                            field: "color_temp"
                   //colorpicker: true
            ], //Ende Items
          }, // Ende Groups
        ], // Ende Groups
    }, //Ende Pages
    ] //Ende Pages
    // ENDE
    CrunkFXC 1 Antwort Letzte Antwort
    • U uvillers
      @CrunkFX gern:
      /* my Config
      Uli am 12.05.2020
      var CONFIG = {
      tileSize: 150,
      tileMargin: 6,
      authToken: null,
      timeFormat: 24,
      //groupsAlign
      pages: [
      title: '@home',
      groups: [
      width: 2,
      height: 3,
      items: [
      position: [0, 1],
      type: TYPES.SWITCH,
      states: {
      on: "On",
      off: "Off"
      icons: {
                     position: [1, 1],
                     subtitle: 'Dimmer',
                     type: TYPES.SLIDER,
                     states: {
                        on: "On",
                        off: "Off"
                     icons: {
                    /*sliders: [
                           position: [1, 2],
                              type: TYPES.SLIDER,
                           max: 255,
                           min: 0,
                           step: 5,
                           request: {
                              domain: "light",
                              service: "turn_on",
                              field: "brightness"
                           max: 588,
                           min: 153,
                           step: 15,
                           request: {
                              domain: "light",
                              service: "turn_on",
                              field: "color_temp"
                     //colorpicker: true
              ], //Ende Items
            }, // Ende Groups
          ], // Ende Groups
      }, //Ende Pages
      ] //Ende Pages
      // ENDE
      CrunkFXC Offline
      CrunkFXC Offline
      CrunkFX
      Forum Testing
      schrieb am zuletzt editiert von CrunkFX
      @uvillers Welchen Status haben denn die Brightness der HUE im Arbeitszimmer und der Switch, on und off oder einen Zahlenwert?
      U 1 Antwort Letzte Antwort
      • CrunkFXC CrunkFX
        U Offline
        U Offline
        uvillers
        @CrunkFX Echt, war es so einfach.. verdammt. Dachte "on" "off" wären feste Paramenter. Das es die Rückgabe Werte des Gerätes sind ist logisch und war mir nicht klar. Nun geht's Danke!!!
        • U uvillers
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          @uvillers Leider nicht, aber da hab ich am Anfang auch mit zu kämpfen gehabt.
          F 1 Antwort Letzte Antwort
          • CrunkFXC CrunkFX
            FuXXz2
            @CrunkFX
            Tileboard scheint nicht besonders aktiv genutzt zu sein, bekommt man es denn derzeit irgendwie zum laufen?
            Wenn ich etwas in der Konfiguration eintrage, dann sieht das nach dem Speichern immer wie folgt aus:
            • F FuXXz2
              @CrunkFX
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              @FuXXz2 Hi, welche Version verwendest denn du?
              • CrunkFXC CrunkFX
                FuXXz2
                @CrunkFX Das ist die Version 0.3.1
                • F FuXXz2
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @FuXXz2 Hast du mal den adapter gelöscht und neu hinzugefügt? Bei mir gehts mit der version ohne probleme
                  • CrunkFXC CrunkFX
                    FuXXz2
                    schrieb am zuletzt editiert von FuXXz2
                    @CrunkFX
                    ja :(
                    Mehrmals, habe auch nen 2. ioBroker hier, der noch ganz frisch ist und nix installiert ist. Dort das gleiche Bild
                    Aber ich versuche gerade mal ein paar andere Browser, vielleicht gehts bei irgendeinen
                    • F FuXXz2
                      @CrunkFX
                      ja :(
                      FuXXz2
                      @FuXXz2
                      Die config Datei sieht genauso Schrott aus
                      Browser habe ich nun IE, Edge, Chrome, Opera, Firefox getestet
                      CrunkFXC 2 Antworten Letzte Antwort
                      • F FuXXz2
                        @FuXXz2
                        CrunkFXC Offline
                        CrunkFXC Offline
                        CrunkFX
                        Forum Testing
                        @FuXXz2 Ok ich teste mal kurz was
                        • F FuXXz2
                          @FuXXz2
                          CrunkFXC Offline
                          CrunkFXC Offline
                          CrunkFX
                          Forum Testing
                          @FuXXz2 281f1ac1-a696-41f5-892a-10e0c3c309fd-image.png Habs geschafft, jetzt muss ich nur noch rausfinden worans liegt
                          F 2 Antworten Letzte Antwort
                          • CrunkFXC CrunkFX
                            FuXXz2
                            @CrunkFX
                            Hauptsache ich bin nicht mehr allein damit :)
                            • CrunkFXC CrunkFX
                              FuXXz2
                              @CrunkFX
                              Hast du schon etwas herausgefunden?
                              • F FuXXz2
                                @CrunkFX
                                CrunkFXC Offline
                                CrunkFXC Offline
                                CrunkFX
                                Forum Testing
                                @FuXXz2 Leider bekomme ich das gar nicht mehr ans rennen auch nicht mit der alten Version. Ich habe dazu auf GitHub ein issue erstellt. Vielleicht tut sich ja was
                                • CrunkFXC CrunkFX
                                  FuXXz2
                                  @CrunkFX So wie es aussieht, wird an dem Adapter eh nichts mehr gemacht, dann streiche ich mein TileBoard von der Liste.
                                  Schade, eine der wenigen optisch wirklich schönen Visualisierungen.
