  3. Entwicklung
  4. ZigBee neue Version 1.4.0
    6.3k
zigbeeneugitalpha
393 Beiträge 62 Kommentatoren 125.9k Aufrufe 68 Beobachtet
  • E exv2
    Ich hoffe das mir einer helfen kann.
    Ich bekomme meine installierte Version 1.1.0 nicht auf Version 1.4.0 upgedatet.
    Bei der Installation kommt folgene Meldung
    $ ./iobroker upgrade zigbee
    Update zigbee from @1.1.0 to @1.4.0
    host.server Adapter "system.adapter.zigbee.0" is stopped.
    NPM version: 6.14.4
    npm install iobroker.zigbee@1.4.0 --loglevel error (System call)
    gyp
     ERR! find Python gyp ERR! find Python Python is not set from command line or npm configurationgyp ERR! find Python Python is not set from environment variable PYTHONgyp ERR! find Python checking if "python" can be usedgyp ERR! find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR! find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR! find Python gyp ERR! find Python **********************************************************gyp ERR! find Python You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp ERR! find Python - Set the environment variable PYTHONgyp ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"gyp ERR! find Python For more information consult the documentation at:gyp ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR! find Python gyp ERR! configure error gyp ERR! stack Error: Could not find any Python installation to usegyp ERR! stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:310:5)gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:322:5)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:273:12)gyp ERR! stack     at onErrorNT (internal/child_process.js:469:16)gyp ERR! stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)gyp ERR! System Windows_NT 10.0.14393gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\@serialport\bindingsgyp ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm
    ERR!
    code ELIFECYCLEnpm ERR! errno 1npm ERR! @serialport/bindings@9.0.3 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR!
     Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@9.0.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2020-12-07T15_55_37_322Z-debug.log
    ERROR: host.server Cannot install iobroker.zigbee@1.4.0: 1
    ioBroker läuft bauf einen Windows Server.
    Python ist in der Version 3.9 installiert.
    Vielen Dank schon mal für eure Hilfe.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @exv2 Bitte dafür einen neuen Thread aufmachen. Das ist nicht zigbee-adapter spezifisch, sondern es scheint das in deiner node/iobroker installation etwas nicht passt.
    A.
    • H Offline
      hoktar
      schrieb am zuletzt editiert von hoktar
      Ich glaube die RGB-Lampe vom Lidl wird nicht richtig unterstützt. Ich kann sie zwar anlernen, aber außer An/Aus und die RGB Farben kann ich nichts machen. Habe sie heute auch schon umgetauscht , aber auch mit der neuen keine Veränderung. Eigentlich sollte sie doch auch in Weiß leuchten und die Farbtemperatur einstellen können. Dimmen kann ich gar nicht genau sagen ob das funktioniert oder nicht.
      MfG Bastian
      RGB zigbee lampe.JPG RGB zigbee lampe restart.JPG RGB zigbee lampe Lidl.JPG RGB zigbee lampe Geräteinfo.JPG RGB zigbee lampe Bild.JPG
      I S 2 Antworten Letzte Antwort
      • AsgothianA Asgothian
        @JackDaniel
        Ich wollte mir mal ein Bild von dem Fehler machen - irgendwie kommt da immer das raus:
        Im Ernst - ohne weitere Referenzen kann an mit der Fehlermeldung NICHTS getan werden.
        • Node JS Version
        • ioBroker.Zigbee Version
        • HW des Koordinators
        • Kachel des Koordinators im ioBroker.Zigbee (sofern iobroker.Zigbee Version1.4.0)
        • betroffene Geräte (Beschreibung, Kachel, welche DP's hast du versucht zu "binden"
        • ggf. auftretende debug Meldungen beim "bind"
        • ggf. auftretende debug Meldungen beim "unbind"
          (Ja, fuer die beiden letzten Punkte ist es notwendig den Adapter im Debug zu starten und das ganze noch einmal zu probieren)
        Ansonsten: Logs in code Tags, damit es so aussieht - dann kann man das nicht nur lesen sondern sogar auch verstehen:
        Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
        at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28) at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
        at runMicrotasks () at processTicksAndRejections (internal/process/task_queues.js:97:5)
        at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
        A.
        JackDanielJ Offline
        JackDanielJ Offline
        JackDaniel
        Node JS Version - v12.20.0
        ioBroker.Zigbee Version -1.4.0
        HW des Koordinators - dieser hier
        das kommt beim löschversuch
        zigbee.0	2020-12-07 18:07:21.101	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:21.100	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be
        zigbee.0	2020-12-07 18:07:21.099	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55","
        zigbee.0	2020-12-07 18:07:21.098	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:07:21.098	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE","
        zigbee.0	2020-12-07 18:07:21.022	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:07:20.956	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:07:20.955	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE","
        zigbee.0	2020-12-07 18:07:20.874	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:07:20.653	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:07:20.652	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextHo
        zigbee.0	2020-12-07 18:07:20.627	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:20.627	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
        zigbee.0	2020-12-07 18:07:20.591	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:07:20.514	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:20.513	debug	(541206) getDevices result: [{"type":"device","common":{"name":"Rollo Kinderzimmer","type":"E1757","icon":"img/Ikea_fyrtur.png"},"native":{"id":"000d6ffffe2de624"},"from":"system.adapter.zigbee.0","us
        zigbee.0	2020-12-07 18:07:20.454	debug	(541206) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:20.453	debug	(541206) List of ports: [{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/
        zigbee.0	2020-12-07 18:07:20.429	debug	(541206) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:20.429	debug	(541206) getGroups result: {}
        zigbee.0	2020-12-07 18:07:20.402	debug	(541206) Routing table succeeded for 'Coordinator'
        zigbee.0	2020-12-07 18:07:20.402	debug	(541206) Routing for 'Coordinator': {"table":[{"destinationAddress":61554,"status":"ACTIVE","nextHop":13418},{"destinationAddress":45744,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,
        zigbee.0	2020-12-07 18:07:20.399	debug	(541206) LQI succeeded for 'Coordinator'
        zigbee.0	2020-12-07 18:07:20.365	debug	(541206) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:20.364	debug	(541206) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:20.332	debug	(541206) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.0","channel":"26","port":"/dev/ttyACM0","type":"zStack30x","revision":20200211,"version":"2.2.7.2"}
        chromecast.0	2020-12-07 18:07:17.218	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:07:17.170	info	(120990) TV_Wohnzimmer - not enabled
        zigbee.0	2020-12-07 18:07:15.430	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:15.430	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
        zigbee.0	2020-12-07 18:07:15.371	debug	(541206) sendTo "delBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:15.370	error	at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
        zigbee.0	2020-12-07 18:07:15.370	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0	2020-12-07 18:07:15.370	error	at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
        zigbee.0	2020-12-07 18:07:15.370	error	at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28)
        zigbee.0	2020-12-07 18:07:15.370	error	(541206) Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
        zigbee.0	2020-12-07 18:07:15.369	debug	(541206) source: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x086bd7fffe5f8d3f","_networkAddress":2137,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
        zigbee.0	2020-12-07 18:07:15.367	debug	(541206) found state: {"val":"{\"bind_source\":\"zigbee.0.086bd7fffe5f8d3f\",\"bind_source_ep\":\"1\",\"bind_target\":\"1\",\"unbind_from_coordinator\":false}","ack":true,"ts":1600584776907,"q":0,"fr
        zigbee.0	2020-12-07 18:07:15.365	debug	(541206) delBinding message: "bind_086bd7fffe5f8d3f_1_1_undefined"
        chromecast.0	2020-12-07 18:07:10.877	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:07:10.744	info	(120990) TV_Wohnzimmer - not enabled
        zigbee.0	2020-12-07 18:07:08.706	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:08.706	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940b
        zigbee.0	2020-12-07 18:07:08.706	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55",
        zigbee.0	2020-12-07 18:07:08.705	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:07:08.705	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE",
        zigbee.0	2020-12-07 18:07:08.642	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:07:08.578	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:07:08.577	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE",
        zigbee.0	2020-12-07 18:07:08.494	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:07:08.260	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:07:08.259	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
        zigbee.0	2020-12-07 18:07:08.224	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:07:08.223	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextH
        zigbee.0	2020-12-07 18:07:08.162	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:07:08.045	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        und das wenn ich die bindung ändern will
        zigbee.0	2020-12-07 18:09:02.654	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:02.653	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be
        zigbee.0	2020-12-07 18:09:02.652	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55","
        zigbee.0	2020-12-07 18:09:02.651	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:09:02.650	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE","
        zigbee.0	2020-12-07 18:09:02.581	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:09:02.517	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:09:02.516	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE","
        zigbee.0	2020-12-07 18:09:02.437	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:09:02.221	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:09:02.220	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextHo
        zigbee.0	2020-12-07 18:09:02.179	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:02.179	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
        zigbee.0	2020-12-07 18:09:02.160	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:09:02.051	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:02.050	debug	(541206) getDevices result: [{"type":"device","common":{"name":"Rollo Kinderzimmer","type":"E1757","icon":"img/Ikea_fyrtur.png"},"native":{"id":"000d6ffffe2de624"},"from":"system.adapter.zigbee.0","us
        zigbee.0	2020-12-07 18:09:02.027	debug	(541206) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:02.027	debug	(541206) List of ports: [{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/
        zigbee.0	2020-12-07 18:09:01.972	debug	(541206) Routing table succeeded for 'Coordinator'
        zigbee.0	2020-12-07 18:09:01.972	debug	(541206) Routing for 'Coordinator': {"table":[{"destinationAddress":61554,"status":"ACTIVE","nextHop":13418},{"destinationAddress":45744,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,
        zigbee.0	2020-12-07 18:09:01.969	debug	(541206) LQI succeeded for 'Coordinator'
        zigbee.0	2020-12-07 18:09:01.957	debug	(541206) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:01.956	debug	(541206) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:01.956	debug	(541206) getGroups result: {}
        zigbee.0	2020-12-07 18:09:01.955	debug	(541206) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:09:01.955	debug	(541206) getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.4.0","channel":"26","port":"/dev/ttyACM0","type":"zStack30x","revision":20200211,"version":"2.2.7.2"}
        mystrom-wifi-switch.1	2020-12-07 18:09:01.480	info	(533412) result from http://192.168.1.64:{"power":15.14,"Ws":15.25,"relay":true,"temperature":21.31}
        mystrom-wifi-switch.0	2020-12-07 18:08:59.750	info	(533396) result from http://192.168.1.61:{"power":0,"Ws":1.75,"relay":true,"temperature":4.68}
        chromecast.0	2020-12-07 18:08:59.629	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.628	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.617	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.606	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.603	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.332	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.331	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.330	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.302	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:59.298	info	(120990) TV_Wohnzimmer - not enabled
        zigbee.0	2020-12-07 18:08:58.876	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:08:58.875	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
        zigbee.0	2020-12-07 18:08:58.826	debug	(541206) sendTo "editBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:08:58.825	error	at async /opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:255:21
        zigbee.0	2020-12-07 18:08:58.825	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0	2020-12-07 18:08:58.825	error	at runMicrotasks (<anonymous>)
        zigbee.0	2020-12-07 18:08:58.825	error	at Binding.doBindUnbind (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:102:111)
        zigbee.0	2020-12-07 18:08:58.825	error	at Binding.getBindEp (/opt/iobroker/node_modules/iobroker.zigbee/lib/binding.js:89:28)
        zigbee.0	2020-12-07 18:08:58.825	error	(541206) Failed to doBindUnbind TypeError: Cannot read property 'split' of undefined
        zigbee.0	2020-12-07 18:08:58.823	debug	(541206) source: {"type":"device","device":{"ID":5,"_type":"EndDevice","_ieeeAddr":"0x086bd7fffe5f8d3f","_networkAddress":2137,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
        zigbee.0	2020-12-07 18:08:58.821	debug	(541206) found state: {"val":"{\"bind_source\":\"zigbee.0.086bd7fffe5f8d3f\",\"bind_source_ep\":\"1\",\"bind_target\":\"1\",\"unbind_from_coordinator\":false}","ack":true,"ts":1600584776907,"q":0,"fr
        zigbee.0	2020-12-07 18:08:58.819	debug	(541206) delBinding message: "bind_086bd7fffe5f8d3f_1_1_undefined"
        zigbee.0	2020-12-07 18:08:58.818	debug	(541206) editBinding message: {"id":"bind_086bd7fffe5f8d3f_1_1_undefined","bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"zigbee.0.d0cf5efffeea0fc4","bind_target_ep":"1"
        chromecast.0	2020-12-07 18:08:51.236	info	(120990) TV_Wohnzimmer - not enabled
        chromecast.0	2020-12-07 18:08:51.006	info	(120990) TV_Wohnzimmer - not enabled
        unifi.0	2020-12-07 18:08:50.171	info	(530746) Update done
        zigbee.0	2020-12-07 18:08:48.437	debug	(541206) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:08:48.436	debug	(541206) getMap result: {"lqis":[{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940b
        zigbee.0	2020-12-07 18:08:48.435	debug	(541206) Get map succeeded [{"parent":"0x00124b001940be55","networkAddress":2054,"ieeeAddr":"0x000d6ffffe63cff3","lqi":71,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001940be55",
        zigbee.0	2020-12-07 18:08:48.434	debug	(541206) Routing table succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:08:48.433	debug	(541206) Routing for '0x000d6ffffe2fd9f5': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":61554,"status":"ACTIVE","nextHop":47570},{"destinationAddress":27862,"status":"ACTIVE",
        zigbee.0	2020-12-07 18:08:48.370	debug	(541206) LQI succeeded for '0x000d6ffffe2fd9f5'
        zigbee.0	2020-12-07 18:08:48.307	debug	(541206) Routing table succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:08:48.306	debug	(541206) Routing for '0xd0cf5efffeea9a16': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":13418,"status":"ACTIVE","nextHop":13418},{"destinationAddress":52810,"status":"ACTIVE",
        zigbee.0	2020-12-07 18:08:48.237	debug	(541206) LQI succeeded for '0xd0cf5efffeea9a16'
        zigbee.0	2020-12-07 18:08:48.052	debug	(541206) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        zigbee.0	2020-12-07 18:08:48.051	debug	(541206) getBinding result: [{"bind_source":"zigbee.0.086bd7fffe5f8d3f","bind_source_ep":"1","bind_target":"1","unbind_from_coordinator":false,"id":"bind_086bd7fffe5f8d3f_1_1_undefined"}]
        zigbee.0	2020-12-07 18:08:48.018	debug	(541206) Routing table succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:08:48.017	debug	(541206) Routing for '0x000d6ffffebe5831': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":0,"status":"INACTIVE","nextHop":0},{"destinationAddress":25033,"status":"ACTIVE","nextH
        zigbee.0	2020-12-07 18:08:47.941	debug	(541206) LQI succeeded for '0x000d6ffffebe5831'
        zigbee.0	2020-12-07 18:08:47.833	debug	(541206) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        @Asgothian sagte in ZigBee neue Version 1.4.0:
        @JackDaniel
        • Node JS Version
        A.
        Carpe diem
        AsgothianA JackDanielJ 2 Antworten Letzte Antwort
        • H hoktar
          MfG Bastian
          I Offline
          I Offline
          io_laurent
          @hoktar für weißes Licht mal beim Datenpunkt Color den Wert "FFFFFF" eingeben (=RGB-Wert für weiß). Dimmen über Brightness Datenpunkt eingeben, Wert 0-100. Beim Datenpunkt Colortemp musst du mal ausprobieren, glaube Werte zwischen 250-650, aber wie gesagt, mußt du selbst mal tüfteln. Das sollte eigentlich funktionieren...
          H 1 Antwort Letzte Antwort
          • I io_laurent
            hoktar
            @io_laurent Genau das Habe ich ja versucht. bei #ffffff mischt er nur aus den RGB-Leds weiß zusammen. Ich bekomme aber egal was ich einstelle nicht die weißen LEDs an. Nach dem anlernen haben aber ganz klar die Weißen geleuchtet, also sind auch welche verbaut.
            Habe ja noch welche ohne RGB, bei denen funktioniert es super. Farbtemperatur, dimmen und An/Aus.
            mfg
            edit: auch #000000 und #000000ff gehen nicht darauf reagiert die Lampe gar nicht.
            I L 2 Antworten Letzte Antwort
            • H hoktar
              mfg
              I Offline
              I Offline
              io_laurent
              @hoktar Sorry, dann hab ich keine Ahnung, müssen die Profis ran:) dachte, dir fehlen die richtigen Werte, weil im Screenshot keine eingetragen waren.
              • JackDanielJ JackDaniel
                @JackDaniel
                • Node JS Version
                A.
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @JackDaniel ok, damit kann ich da morgen nachschauen.
                A.
                JackDanielJ 1 Antwort Letzte Antwort
                • I io_laurent
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @io_laurent sind sie schon. Die Lampen sind
                  • noch neu
                  • Tuya inside, also hochgradig nicht Standard.
                  Wenn ich das richtig verstand en habe sollte im zigbee2mqtt bereits ein PR zu dem Problem existieren.
                  A.
                  F 1 Antwort Letzte Antwort
                    A.
                    JackDanielJ Offline
                    JackDanielJ Offline
                    JackDaniel
                    @Asgothian
                    danke im voraus 👍
                    Carpe diem
                      • noch neu
                      A.
                      Frank579
                      @Asgothian
                      Danke für die tolle Arbeit 👍👍👍
                      Hallo ich nutze den Adapter mit einem conbee II (ich weiß ist noch experimentell ) ich habe das Problem das ein Ikea Taster, über den Ikea Router , zwar funktioniert aber sei dem er über den Router läuft den Batterie Zustand nicht mehr aktualisiert.. ist da etwas bekannt ?
                      • F Frank579
                        @Asgothian
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @Frank579 welcher Router ??
                        • arteckA arteck
                          Frank579
                          @arteck
                          @arteck sagte in ZigBee neue Version 1.4.0:
                          der Ikea Tradfri repeater, sorry hätte ich erwähnen sollen ....
                          • arteckA arteck
                            first big THX to Ilya and @Asgothian
                            zuerst die Probleme :
                            icons in Objekten sind nicht da wenn diese direkt aus dem z2m projekt kommen
                            ab und an ist in Objekten ein Datenpunkt der nicht zugeordnet ist
                            was ist neu :
                            die Geräte die schon im zigbee2mqtt Projekt dabei sind werden von uns AUTOMATISCH unterstützt
                            ergo wir benötigen keine nachpflege....
                            die Karte sieht ein wenig anders aus.
                            mal schauen ob diese diesmal funktioniert.. Die Geräte die sich bis zur Kartenaufruf nicht gemeldet haben bleiben als nicht verbuden (es sind meistens bateriebetriebene Geräte die melden sich nicht so oft)
                            die Möglichkeit den Stick über TCP anzusprechen
                            mit dem Programmen ser2net oder usbip kann man den Stick auslagern .. es ist kein Multihost mehr nötig.
                            meine empfehlung ser2net. einfacher einzurichten und man braucht es nur auf dem Rechner wo der Stick dran hängt. ich habe es seid ca.4 Monaten am laufen am Rock64 LAN angebunden.
                            mit WLAN geht es auch, währe ich aber vorsichtig.. wenn das WLAN Signal weg ist merkt es der Adapter nicht
                            Info zum Gerät als Link hinzugefügt
                            der Coordinator hat eine eigene Kachel mit ALLEN Informationen die WIR benötigen zwecks Bug Analyse
                            nach Adapter start werden weitere Informationen angezeigt sehr wichtig hier
                            Installed Version :
                            dieser zeigt einen link den man kopiert und im Browser einfügt.
                            Dieser zeigt DIREKT die JETZT installierte Version.
                            icon1 Blau = OTA .. man kann einige Geräte (hue, Osram,tradfri.....) mit neuer Version falls diese existiert aktualisieren
                            die Funktion ist ein wenig buggy und schmeisst evtl. paar Fehler im LOG
                            icon2 mitte = hiermit kan man Osram bzw. tradfri geräte automatusch zurücksetzten und neu anlernen. Das Gerät muss aber sehr nah an den Stick dran
                            icon 3 rechts = damit wird wie immer ein Gerät angelernt.
                            el_malto
                            Sehr cooles Update und Neuerungen. Vielen Dank dafür.
                            Hat das schon jemand mit einen Windows Rechner probiert bzw. erfolgreich eingebunden?
                            Ich habe auf meinen Server Windows Server 2016 drauf und ioBroker läuft in einer Hyper-V VM mit Debian 10 Buster. Meinen CC2531 habe ich mit "VirtualHere" zur VM durchgereicht. Das funktioniert auch ohne Probleme. Ich muss nur die Clienten Software auf der VM nach neustart immer per Hand starten (geht mit der Free Version nicht automatisch). Mit der Free Version kann man ein USB Gerät durchreichen, was mir auch reicht, da ich nur den CC2531 durchreichen will.
                            Habe in der Doku von VirtualHere gelesen das der Port :7575 genutzt wird. Wenn ich IP:Port im Adapter eintrage, kann der Adapter leider keine Verbindung zum Stick herstellen. Auf dem Server kommen folgende Fehlermeldungen im Log von VirtualHere:
                            2020-12-07 21:31:40 INFO :192.168.0.108 connected as connection 3
                            2020-12-07 21:31:47 ERROR :Error received message is too big (comp=553713391, uncomp=16654337)
                            2020-12-07 21:31:50 INFO :Connection 3 successfully removed (reason:timeout)
                            2020-12-07 21:32:03 INFO :192.168.0.108 connected as connection 4
                            2020-12-07 21:32:10 ERROR :Error received message is too big (comp=553713391, uncomp=16654337)
                            2020-12-07 21:32:14 INFO :Connection 4 successfully removed (reason:timeout)
                            usw...
                            Irgendwelche Anfragen kommen wohl beim Server an.
                            Hat das schon jemand ans laufen bekommen oder kann eine andere kostenlose Software für Windows empfehlen die mit dem Adapter kompatible ist? Würde gern nur eine Server Software (Windows) laufen lassen müssen und nicht noch eine auf dem Clienten (VM) wenn der Adapter das nun unterstützt.
                            • H hoktar
                              mfg
                              leon
                              @hoktar
                              Genau das gleiche Problem habe ich bei der Lidl Strip. Asgothian ist da wohl schon dran.
                              • SlowmanS Offline
                                SlowmanS Offline
                                Slowman
                                Bekomme zur Zeit bei den Stick folgende Fehlermeldung:
                                zigbee.0	2020-12-08 11:15:24.843	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:24:58)
                                zigbee.0	2020-12-08 11:15:24.843	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-12-08 11:15:24.843	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:339:27)
                                zigbee.0	2020-12-08 11:15:24.843	error	(7768) Error on send command to 0x7cb03eaa0a0082cd. Error: Error: Command 0x7cb03eaa0a0082cd/3 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultRespons
                                host.iobroker	2020-12-08 11:15:15.646	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                Kann damit gar nichts anfangen
                                • SlowmanS Slowman
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @Slowman
                                  Die Meldung Ist abgehackt. Das wichtige (das Ende) fehlt. Bitte das log herunter laden, die zeile(n) finden, dann neu posten.
                                  A.
                                  M SlowmanS 2 Antworten Letzte Antwort
                                    @Slowman
                                    A.
                                    Mr.X
                                    ich war jetzt ein halbes Jahr glücklich, weil der Zigbee Kram endlich mal lief.
                                    Dann habe ich jetzt upgedatet, um den Lidl Kram zu integrieren, und nun ist der Adappter wieder ständig offline :-(
                                    Würde mich über eine Hilfestellung freuen.
                                    Folgendes steht im Log:
                                    <zigbee.0 2020-12-08 16:49:01.564 error at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
                                    zigbee.0 2020-12-08 16:49:01.564 error at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
                                    zigbee.0 2020-12-08 16:49:01.564 error at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                    zigbee.0 2020-12-08 16:49:01.564 error at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                    zigbee.0 2020-12-08 16:49:01.564 error at new Promise (<anonymous>)
                                    zigbee.0 2020-12-08 16:49:01.564 error at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                    zigbee.0 2020-12-08 16:49:01.564 error at Generator.next (<anonymous>)
                                    zigbee.0 2020-12-08 16:49:01.564 error at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                    zigbee.0 2020-12-08 16:49:01.564 error (12100) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                    zigbee.0 2020-12-08 16:49:01.563 error (12100) Failed to start Zigbee
                                    zigbee.0 2020-12-08 16:48:56.338 info (12100) Installed Version: iobroker.zigbee@1.4.0
                                    zigbee.0 2020-12-08 16:48:56.323 info (12100) Starting Zigbee npm ...
                                    zigbee.0 2020-12-08 16:48:56.321 info (12100) Try to reconnect. 1 attempts left>
                                    • M Mr.X
                                      @Mr-X sagte in ZigBee neue Version 1.4.0:
                                      Da scheint noch was anderes auf den Port zuzugreifen.
                                      Adapter wurde wie installiert? Aus dem Verwahrort oder aus git?
                                      Node Installation korrekt?
                                      Und bitte Text auch in CodeTags einbetten, das liest sich dann besser.
                                        Mr.X
                                        @Thomas-Braun Sorry, habe das eigentlich in die <> Coder-Klammer gesetzt.
                                        Also ich habe von 1.3 (oder so) auf latest 1.4 update gemacht, davor lief alles sauber.
                                        am Rpi 4 stecken keine anderen USB devices, nur der CC2531.
                                        Denke, dass mit Node alles OK ist, wenn es davor Monate lang ohne probs lief.
                                        • M Mr.X
                                          Wie upgedated?
                                          Zu node:
                                          Ausführen, Rückmeldung komplett hier wieder rein:
                                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                          Zu den CodeTags: Nicht in Spitzklammern setzen, sondern den Text markieren und dann das Icon </> anklicken.
