  4. Test Adapter radar2 v1.2.x GitHub
radar2 adapter
244 Beiträge 49 Kommentatoren 54.8k Aufrufe 42 Beobachtet
  • nik82N nik82
    ich würde auch gerne den Radar-Adapter installieren, aber bei jeder Installation zerschießt es mir den kompletten IOBroker,
    bleibt hier hängen und danach geht gar nichts mehr, muss komplett zurücksichern:
    $ ./iobroker add radar2 --host IOBROKER(Iobroker)
    NPM version: 6.11.3
    npm install iobroker.radar2@2.0.1 --loglevel error (System call)
    prebuild-install
    info begin Prebuild-install version 5.3.6
    prebuild-install info looking for cached prebuild @
    C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gzprebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-win32-x64.tar.gz
    prebuild-install
    http 200 https://github.com/tessel/node-usb/releases/download/v1.6.3/usb-v1.6.3-node-v64-win32-x64.tar.gz
    prebuild-install
    info downloading to @ C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gz.3948-d8d137107a5c8.tmp
    prebuild-install info renaming to @ C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gz
    prebuild-install info unpacking @ C:\iobroker\Iobroker\env\npm-cache_prebuilds\b5fa15-usb-v1.6.3-node-v64-win32-x64.tar.gz
    resolved to C:\iobroker\Iobroker\node_modules\usb\build\Release\usb_bindings.node
    required C:\iobroker\Iobroker\node_modules\usb\build\Release\usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
    gyp
    ERR! build error
    gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1gyp ERR!
    stack at ChildProcess.onExit (C:\iobroker\Iobroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:193:23)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp
    ERR! System Windows_NT 10.0.18362gyp
    ERR! command "C:\iobroker\Iobroker\nodejs\node.exe" "C:\iobroker\Iobroker\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "build" "--fallback-to-build" "--module=C:\iobroker\Iobroker\node_modules\@abandonware\bluetooth-hci-socket\lib\binding\bluetooth_hci_socket.node" "--module_name=bluetooth_hci_socket" "--module_path=C:\iobroker\Iobroker\node_modules\@abandonware\bluetooth-hci-socket\lib\binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socket
    gyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3
    gyp ERR! not ok
    node-pre-gyp
    ERR! build error node-pre-gyp ERR! stack
    Error: Failed to execute 'C:\iobroker\Iobroker\nodejs\node.exe C:\iobroker\Iobroker\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socket\lib\binding\bluetooth_hci_socket.node --module_name=bluetooth_hci_socket --module_path=C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socket\lib\binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (C:\iobroker\Iobroker\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp
    ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp
    ERR! System Windows_NT 10.0.18362node-pre-gyp ERR! command "C:\iobroker\Iobroker\nodejs\node.exe" "C:\iobroker\Iobroker\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR!
    cwd C:\iobroker\Iobroker\node_modules@abandonware\bluetooth-hci-socketnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.15.0
    node-pre-gyp ERR! not ok
    host.IOBROKER(Iobroker) install adapter radar2
    ERROR: (node:14884) UnhandledPromiseRejectionWarning: Error: Cannot find module 'mime' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) at Function.Module._load (internal/modules/cjs/loader.js:562:25) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Upload.uploadAdapter (C:\iobroker\Iobroker\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:533:24) at packetManager.install.catch.then (C:\iobroker\Iobroker\node_modules\iobroker.js-controller\lib\setup\setupInstall.js:774:28) at process._tickCallback (internal/process/next_tick.js:68:7)(node:14884) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
    ERROR: (node:14884) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Habe eine Iobroker Windows Installation.
    Jemand eine Idee was ich noch machen kann oder ob evtl. irgend etwas fehlt das ich vorher noch installieren muss?
    Danke im Voraus.
    Als Info noch:
    c4c818e6-b865-440a-96d8-91ff07ad79af-image.png JS-Controller
    EDIT
    Problem erledigt, lag an der Iobroker Installation, nicht am Adapter.
    frankjokeF Offline
    frankjokeF Offline
    frankjoke
    #120
    @nik82
    Ich habe eden Adapter (V2.0.1) auf einem Windows-Testsystem laufen:
    Node.js
    v10.21.0 (There is a newer version: v10.23.0 - Recommended version v12.19.0)
    NPM
    6.14.4
    Wie hast du das Windows-System installiert? Scheinst Probleme mit node-Gyp für Windows zu haben und der normalen Installationsroutine zu haben!
    Kannst es mal mittels admin installieren (nicht auf der Kommandozeile)?
    Übrigens, Radar2 hat nur ca 30% seiner Funktionen unter Windows da er nur normale Netzwerkabfragen machen kann aber momentan leider kein BT mehr funktioniert!
    Ich verwende Windows nur zum Testen und Entwickeln ob sich die Adapter darauf installieren lassen oder nicht, aber nicht für wirkliche Installation da es zu viele Einschränkungen hat.
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    nik82N 1 Antwort Letzte Antwort
    • frankjokeF frankjoke
      @nik82
      Node.js
      NPM
      6.14.4
      nik82N Offline
      nik82N Offline
      nik82
      #121
      @frankjoke
      Danke für deine Hilfe, aber wie oben schon unten als EDIT geschrieben, war meine Installation zerschossen.
      Aber trotzdem danke.
      • Basti97B Offline
        Basti97B Offline
        Basti97
        #122
        Ich habe nun den Adapter Radar2 installiert. Nachdem ich alle zusätzlich benötigten Installation durchgeführt habe. Funktoniert er gleich sofort. Nun habe ich aber trotzdem eine Frage wo kann ich einstellen das der Bluetooth Adapter nicht jedes mal alle Scant und in den Datenpunkt ubts Datenpunkt schreibt. Sondern nur die Zufuhr eingegebeneb bzw bekannten Geräten.
        Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
        frankjokeF 1 Antwort Letzte Antwort
        • Basti97B Basti97
          frankjokeF Offline
          frankjokeF Offline
          frankjoke
          #123
          @Basti97
          Wenn du V2.01 verwendest dann kannst das einzelne Abspeichern in der Konfig (Speichern Sie unbekannte BT-Daten) verhindern. Die eine Variable wo alle unknown macs gelistet werden wird trotzdem generiert damit der Adapter weiß welche er schon gesehen hat!
          Frank,
          Basti97B 1 Antwort Letzte Antwort
            @Basti97
            Basti97B Offline
            Basti97B Offline
            Basti97
            schrieb am zuletzt editiert von Basti97
            #124
            @frankjoke Ok Danke ja ich habe den neuesten. Ich gucke mal und probiere es mal aus. 😁😁 Aso und die unbekannten Macs die nicht gespeichert werden sollen werden dann nicht mehr aktualisiert oder?
            • J Offline
              Jan1
              #125
              Wie bekomme ich das eigentlich weg?
              radar2.0	2020-12-05 14:17:13.657	warn	(360746) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
              • J Jan1
                DiginixD Offline
                DiginixD Offline
                Diginix
                #126
                @Jan1 Alle setcap Befehle wie in Post #2 beschrieben ausgeführt?
                ..:: So long! Tom ::..
                • DiginixD Diginix
                  Jan1
                  #127
                  @Diginix
                  Das da:
                  sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
                  sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
                  Oder noch was anderes?
                  • J Jan1
                    @Diginix
                    Das da:
                    #128
                    @Jan1
                    sudo -u iobroker groups
                      @Jan1
                      Jan1
                      #129
                      @Thomas-Braun
                      jan@Beelink:~$ sudo -u iobroker groups
                      iobroker tty dialout audio video bluetooth
                      • J Jan1
                        @Thomas-Braun
                        #130
                        @Jan1 Füg den User mal der Gruppe sudo hinzu.
                        Ist zwar eigentlich nicht Sinn der Sache, aber kannst ja mal schauen ob es damit funktioniert.
                          Jan1
                          #131
                          @Thomas-Braun
                          welchen, iobroker oder jan?
                          • J Jan1
                            @Thomas-Braun
                            #132
                            @Jan1 Den jan haben wir nicht angeschaut.
                            Aber wenn der auch fehlt, dann beide.
                              Jan1
                              #133
                              @Thomas-Braun
                              stimmt, ging ja um iobroker :)
                              Also dann mal:
                              sudo adduser iobroker sudo
                              und
                              sudo adduser jan sudo
                              • J Jan1
                                @Thomas-Braun
                                Also dann mal:
                                und
                                #134
                                @Jan1 Nein...
                                sudo usermod -aG sudo iobroker
                                  @Jan1 Nein...
                                  Jan1
                                  #135
                                  @Thomas-Braun
                                  ausgeführt
                                  wie überprüfe ich das nun noch?
                                  • J Jan1
                                    @Thomas-Braun
                                    ausgeführt
                                    #136
                                    @Jan1
                                    Den Befehl von vorhin nochmal ausführen?
                                    Kann aber sein, dass der User iobroker erst einmal ausgeloggt werden muss. Starte am besten mal neu.
                                    J 2 Antworten Letzte Antwort
                                      @Jan1
                                      Jan1
                                      #137
                                      @Thomas-Braun
                                      jou is drin
                                      iobroker tty dialout sudo audio video bluetooth
                                      mal schauen ob die Meldung damit erledigt ist.
                                        @Jan1
                                        Jan1
                                        #138
                                        @Thomas-Braun
                                        Das war leider nicht die Lösung, da nach Neustart des Adapter schon wieder diese Meldung drinsteht:
                                        radar2.0	2020-12-06 11:28:47.062	warn	(6069) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                                          a1development
                                          schrieb am zuletzt editiert von a1development
                                          #139
                                          I am using Radar2 very sucessfully for quite some time with Gigaset Keeper Tags,
                                          i recently received the new Samsung SmartTag that they started selling this month.
                                          The awesome news is, this has a massivly increased broadcast range. Radar2 is picking it up where the old tag was long out of range, BUT the Samsung SmartTag has some kind of rolling bt mac address. Its changing all the time. I tried to track all the different BT Adresses it genereates, but i stopped after 20 or so.
                                          @frankjoke is there any additional information from the BT scan ( serial numbers etc ) that could be used to identify the signal source. If so, the new Samsung SmartTags would be a huge upgrade for radar2 users. I am talking about this device https://www.samsung.com/de/mobile-accessories/galaxy-smarttag-black-ei-t5300bbegeu/
