[Neuer Adapter] Xiaomi Luftfilter
Ok... nächste Frage.. habe jetzt einfach mal versucht, den Adapter aus GIT zu installieren... Ist auch installiert, sehe aber keine Instanz... Und / oder Objekte... Hat jemand eine Idee ?
Danke und Gruß
hab jetzt noch mal versucht, den Adapter über npm zu installieren und dabei folgende Meldungen erhalten:
:/opt/iobroker# npm install iobroker.mihome-airpurifier npm WARN babel-eslint@10.1.0 requires a peer of eslint@>= 4.12.1 but none is installed. You must install peer dependencies yourself. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) + iobroker.mihome-airpurifier@0.1.8 updated 1 package in 16.065s 99 packages are looking for funding run `npm fund` for detailsMal sehen, was ich da noch so rausfinde. Dacht aber, ich poste das mal, falls jemand einen Tipp hat.
LG
@kamikazemimmi Mit der Version 0.1.4 (also einer etwas älteren) sollte der 2H direkt vom Adapter aus steuerbar sein. Steht zumindest HIER in einem Issue zum 2H.
Auf welcher Hardware/Betriebssystem hast Du iobroker laufen? Die Meldungen sind übrigens unkritisch. Der obere Bereich weisst auf mögliche optionale Abhängigkeiten in Zusammenhang mit dem Zigbee-Adapter hin, brauchst Du aber nicht zwingend. Also nach einem Fehler sieht da nichts aus.
Wenn Du manuell von Guthub installierst, musst Du unter Umständen selbst eine Instanz des Adapters anlegen. In iobroker auf der Seite Adapters ziemlich rechts das +. Vorher solltest Du aber daneben den Pfeil nach oben klicken, um einen Upload zu machen. Ist bei Github-Sachen manchmal nötig. Wenn Du das nicht siehts, musst Du oben in der Leiste den Expterenmodus einschalten.
Wobei ich mich zu erinnern meine, dass bei diesem Adapter keine alte Version zu holen war.
Da der 2H wohl nur bis 0.1.4 ging wirst Du da wenig Glück haben. Umweg über FHEM oder Homebridge ist dann wohl das kleinere Übel, bevor gar nichts geht...Gruss, Jürgen
@Wildbill Danke für die Antwort.
iobroker läuft als VM auf einem Xenserver unter debian stretch. Dann versuch ich mal manuell eine Instanz zu bekommen und suche doch mal, ob die 0.1.4 finde...
Hätte auch gedacht, dass die Meldungen unkritisch sind, aber war mir halt nicht sicher. Und da ich keine Instanz sah, wollt ich der Vollständigkeit halber lieber mal die Spezies fragen😉
Hoffe, ich werde was 🙏😉Danke und Gruß
Melanie -
MelanieMoin,moin !
Also Instanz hab ich hinzugefügt. Als ich den Link von @Wildbill folgte, bin ich darüber gestolpert, dass eine Datei "nur" ergänzt wurde: link text
(Hinweis wurde bei link text gegeben.)
Meine Patch-Zeiten sind schon etwas her, daher hab ich die Zeilen 37+38 (bei mir unter /opt/iobroker/node_modules/miio/lib/models.js) in die models.js eingefügt, Adapter neu gestartet und nun reagiert der Luftfilter erst mal auf an und ausschalten🤗
Ich teste weiter und meld mich, wenn mir noch etwas erwähnenswertes auffällt.LG
Melanie -
Moin,moin !
MelanieAch ich freu mich - scheint zu laufen🤗
Also vielleicht noch mal der Vollständigkeit halber für Interessierte: wir haben ja den 2H.
Token haben wir ausgelesen, wie in @Wildbill Beitrag erwähnt mit mihome-vacuum
dann hier die App installiert,
Instanz hinzugefügt, Daten eingetragen, (bei Version hab ich "2" ausgewählt)
unter /opt/iobroker/node_modules/miio/lib/models.js die beiden erwähnten Zeilen aus link text eingetragen,
Instanz neu gestartet und der 2H kann jetzt gesteuert werdenVielleicht noch der Hinweis, dass bei der Instanz unter "Version" nicht 2H auftaucht. Ich hab "2" gelassen und kann ihn trotzdem steuern.
LG
Melanie -
LG
MelanieHat vielleicht noch jemand einen Tipp, wie ich die Daten vom Objekt unter "Info" aktualisieren kann ? Die ändern sich gar nicht. In der App ändern die sich. Und schalten des Luftfilters 2H unter "control" funktioniert!
Danke und Gruß
Melanie -
Guten abend,
ich hätte auch interesse an einer Version für 3H.
bis denne
Marc -
Hallo zusammen
In den letzten Wochen habe ich mich daran gesetzt den Adapter für meinen 2h anzupassen. Heute kann ich Erfolg vermelden. Weiter unten findet ihr meinen Github Link, über den ihr den Adapter installieren könnt. Bitte löscht vorher den alten Adapter, damit der Adapter frisch installiert wird!!!
Getestet habe ich die Version (0.2.0) nur mit meinem 2h. Ob weiterhin der 2 und 2s funktionieren, ist mir leider nicht bekannt. Wenn jemand einen 2 oder 2s sein eigen nennt und den Adapter kurz testen könnte, wäre ich dankbar und könnte das auf Github vermerken.
Zusätzlich habe ich die Unterstützung für den AirPurifier 3 eingebaut, aber leider kann ich nicht bestätigen, dass dieser einwandfrei funktioniert.
Wenn weitere Geräte integriert werden sollen, so müsste ich den Gerätetyp mitgeteilt bekommen.
Hier Beispiele:
AirPurifier 2 (mini) -> zhimi.airpurifier.m1
AirPurifier 2h -> zhimi.airpurifier.mc2
AirPurifier 2s -> zhimi.airpurifier.mc1
AirPurifier 3 -> zhimi.airpurifier.ma4Und jetzt der GitHub Link:
https://github.com/dontobi/ioBroker.mihome-airpurifierBei Fragen stehe ich gerne zur Verfügung. Ich bitte nur um etwas Geduld, da ich derzeit viel zu tun habe.
Hallo zusammen
Hier Beispiele:
@Fenriswolf said in [Neuer Adapter] Xiaomi Luftfilter:
zhimi.airpurifier.mb3
Teste den Adapter mal und setze den AirPurifier 3. Im miio habe ich den zhimi.airpurifier.mb3 schon eingefügt. Sollte der dann klappen passe ich die Settings vom Adapter an.
@dontobi sagte in [Neuer Adapter] Xiaomi Luftfilter:
Hier das Ergebnis:
host.iobroker-raspi4 2020-11-26 15:34:59.297 error instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker-raspi4 2020-11-26 15:34:59.297 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) host.iobroker-raspi4 2020-11-26 15:34:59.297 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) host.iobroker-raspi4 2020-11-26 15:34:59.296 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/connectToDevice.js:7:16) host.iobroker-raspi4 2020-11-26 15:34:59.296 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18) host.iobroker-raspi4 2020-11-26 15:34:59.296 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) host.iobroker-raspi4 2020-11-26 15:34:59.294 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/models.js:40:27) host.iobroker-raspi4 2020-11-26 15:34:59.294 error Caught by controller[0]: ReferenceError: AirPurifier3 is not defined host.iobroker-raspi4 2020-11-26 15:34:59.294 error Caught by controller[0]: ^ host.iobroker-raspi4 2020-11-26 15:34:59.293 error Caught by controller[0]: 'zhimi.airpurifier.mb3': AirPurifier3, host.iobroker-raspi4 2020-11-26 15:34:59.293 error Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/models.js:40 -
Hier das Ergebnis:
host.iobroker-raspi4 2020-11-26 15:34:59.297 error instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker-raspi4 2020-11-26 15:34:59.297 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) host.iobroker-raspi4 2020-11-26 15:34:59.297 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) host.iobroker-raspi4 2020-11-26 15:34:59.296 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/connectToDevice.js:7:16) host.iobroker-raspi4 2020-11-26 15:34:59.296 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18) host.iobroker-raspi4 2020-11-26 15:34:59.296 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10) host.iobroker-raspi4 2020-11-26 15:34:59.295 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30) host.iobroker-raspi4 2020-11-26 15:34:59.294 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/models.js:40:27) host.iobroker-raspi4 2020-11-26 15:34:59.294 error Caught by controller[0]: ReferenceError: AirPurifier3 is not defined host.iobroker-raspi4 2020-11-26 15:34:59.294 error Caught by controller[0]: ^ host.iobroker-raspi4 2020-11-26 15:34:59.293 error Caught by controller[0]: 'zhimi.airpurifier.mb3': AirPurifier3, host.iobroker-raspi4 2020-11-26 15:34:59.293 error Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/models.js:40@Fenriswolf könntest du den Adapter nicht einmal komplett neu installieren? Ich hatte im miio einen Schreibfehler. Den hab ich eben erst abgeändert. Sollte es dann noch nicht gehen, schaue ich mir das am Wochenende genauer an.
@dontobi ch habe den Adapter eben komplett frisch von Deinem Github-Link geholt und bekomme dieselben Fehler im Log mit meinem 3H:
host.iobroker-vlan100 2020-11-26 17:17:40.010 error instance system.adapter.mihome-airpurifier.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker-vlan100 2020-11-26 17:17:40.010 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10) host.iobroker-vlan100 2020-11-26 17:17:40.010 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30) host.iobroker-vlan100 2020-11-26 17:17:40.010 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/connectToDevice.js:7:16) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/miio/lib/models.js:40:27) host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: ReferenceError: AirPurifier3 is not defined host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: ^ host.iobroker-vlan100 2020-11-26 17:17:40.009 error Caught by controller[0]: 'zhimi.airpurifier.mb3': AirPurifier3, host.iobroker-vlan100 2020-11-26 17:17:40.008 error Caught by controller[0]: /opt/iobroker/node_modules/miio/lib/models.js:40Gruss, Jürgen
Hallo zusammen und einen schönen 1. Advent
Ich habe gestern die Version 0.2.1 vorbereitet und heute morgen selber in meinem ioBroker getestet. Nachdem ich noch ein paar Kleinigkeiten gefixt habe, sollte der 3H eigentlich jetzt funktionieren. Ich bitte darum dies zu testen.
Gruß aus dem Rheinland
Tobi -
Tobi@dontobi
direkt installiert und getestet.
Die Objekte werden angelegt und sehen gut aus, allerdings werden keine Werte übernommen und die Buttons zeigen keinerlei Wirkung.
Logfile:host.iobroker-raspi4 2020-11-29 11:32:47.422 info Restart adapter system.adapter.mihome-airpurifier.0 because enabled host.iobroker-raspi4 2020-11-29 11:32:47.421 info instance system.adapter.mihome-airpurifier.0 terminated with code 0 (NO_ERROR) mihome-airpurifier.0 2020-11-29 11:32:46.859 info (12164) Terminated (NO_ERROR): Without reason mihome-airpurifier.0 2020-11-29 11:32:46.857 info (12164) terminating mihome-airpurifier.0 2020-11-29 11:32:46.842 info (12164) cleaned everything up... mihome-airpurifier.0 2020-11-29 11:32:46.841 error (12164) TypeError: Cannot read property 'toString' of undefined at MiHomeAirPurifier.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-airpurifier/build/main.js:285:37) at Generator.next mihome-airpurifier.0 2020-11-29 11:32:46.840 error (12164) unhandled promise rejection: Cannot read property 'toString' of undefined mihome-airpurifier.0 2020-11-29 11:32:46.839 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). mihome-airpurifier.0 2020-11-29 11:32:46.837 debug (12164) subscribeToValues mihome-airpurifier.0 2020-11-29 11:32:46.836 debug (12164) filterHoursUsed: undefined mihome-airpurifier.0 2020-11-29 11:32:46.835 debug (12164) filterLifeRemaining: undefined mihome-airpurifier.0 2020-11-29 11:32:46.833 debug (12164) led: undefined mihome-airpurifier.0 2020-11-29 11:32:46.832 debug (12164) buzzer: undefined mihome-airpurifier.0 2020-11-29 11:32:46.831 debug (12164) pm25: undefined mihome-airpurifier.0 2020-11-29 11:32:46.830 debug (12164) humidity: undefined mihome-airpurifier.0 2020-11-29 11:32:46.828 debug (12164) manuallevel: NaN mihome-airpurifier.0 2020-11-29 11:32:46.827 debug (12164) mode: undefined mihome-airpurifier.0 2020-11-29 11:32:46.825 debug (12164) power: undefined mihome-airpurifier.0 2020-11-29 11:32:46.824 debug (12164) checkValues mihome-airpurifier.0 2020-11-29 11:32:46.822 info (12164) Connected! mihome-airpurifier.0 2020-11-29 11:32:34.591 debug (12164) Connect to device: 192.168.99.122 mihome-airpurifier.0 2020-11-29 11:32:34.590 info (12164) Connecting... mihome-airpurifier.0 2020-11-29 11:32:34.584 info (12164) Started mihome-airpurifier.0 2020-11-29 11:32:34.552 info (12164) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.mihome-airpurifier, node: v12.20.0, js-controller: 3.1.6 host.iobroker-raspi4 2020-11-29 11:32:32.605 info instance system.adapter.mihome-airpurifier.0 started with pid 12164 host.iobroker-raspi4 2020-11-29 11:32:16.827 info Restart adapter system.adapter.mihome-airpurifier.0 because enabled
bis denne
Danke für die Arbeit !
@dontobi
bis denne
@Fenriswolf Der Token ist auch richtig ausgelesen und eingegeben? Den es kommt keine Meldung bei dir, dass der Adapter sich verbunden hat.
@dontobi
Habe es über die Android-App ausgelesen.[{"did":"335587104","token":"xxxxxx6a82f17f8d13213370dcxxxxxx","longitude":"0.00000000","latitude":"0.00000000","name":"Miefquirl","pid":"0","localip":"192.xxx.xxx.56","mac":"64:90:C1:xx:xx:xx","ssid":"xxxxxxxxxx","bssid":"xxxxxxxxxxxx","parent_id":"","parent_model":"","show_mode":1,"model":"zhimi.airpurifier.mb3","adminFlag":1,"shareFlag":0,"permitLevel":16,"isOnline":true,"desc":"Gerät online ","extra":{"isSetPincode":0,"fw_version":"2.0.8","needVerifyCode":0,"isPasswordEncrypt":0,"mcu_version":"0017"},"uid":6162919983,"pd_id":1182,"password":"","p2p_id":"","rssi":-56,"family_id":0,"reset_flag":0},Im Log steht aber:
mihome-airpurifier.0 2020-11-29 12:23:34.742 info (24519) Connected! mihome-airpurifier.0 2020-11-29 12:23:22.368 debug (24519) Connect to device: 192.168.99.122 mihome-airpurifier.0 2020-11-29 12:23:22.366 info (24519) Connecting... mihome-airpurifier.0 2020-11-29 12:23:22.361 info (24519) StartedÄndert sich der Token beim ändern der IP-Adresse ?
@dontobi
@Fenriswolf Ich denke nicht, dass sich der Token ändert. Ich bin gerade noch etwas am vorbereiten und werde das nachher hochladen.
