  5. [gelöst] Kodi: Enduhrzeit berechnen
    5.3k
44 Beiträge 5 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • K Kuddel
    @dos1973 habe die Restzeit auch noch eingebaut:
    Das Skript läuft jetzt sekündlich, so lange kodi.0.state nicht gleich stop
    <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="q-.)uV_$xX9EqI#0)1V{" x="-37" y="-270">
     <value name="OID0">
       <shadow type="field_oid" id="3Y]sGqJzX97#Y#bnc%2B">
         <field name="oid">kodi.0.state</field>
       </shadow>
     </value>
     <statement name="STATEMENT">
       <block type="controls_if" id="#KCO]0`h|hPacKdL)=A2">
         <value name="IF0">
           <block type="logic_operation" id="Fk*MZyx-?jaWVfOUD74{" inline="false">
             <field name="OP">AND</field>
             <value name="A">
               <block type="logic_compare" id="f;Y93jeAj5hLE=HpAXci">
                 <field name="OP">NEQ</field>
                 <value name="A">
                   <block type="get_value" id="+oIYTrzhXShgXD?-dx?!">
                     <field name="OID">kodi.0.state</field>
                   </block>
                 </value>
                 <value name="B">
                   <block type="text" id="L7`/vLtiabj}GQ5_)n?I">
                     <field name="TEXT">stop</field>
                   </block>
                 </value>
               </block>
             </value>
             <value name="B">
               <block type="logic_compare" id="S;@tsc#Y9J{l-nz(8#%L">
                 <value name="A">
                   <block type="variables_get" id="_lYj.M;X6{:Ig+t1H-OG">
                     <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field>
                   </block>
                 </value>
                 <value name="B">
                   <block type="logic_boolean" id=":eRp?twu(kMNOV|nraj#">
                   </block>
                 </value>
               </block>
             </value>
           </block>
         </value>
         <statement name="DO0">
           <block type="timeouts_setinterval" id="uGdM,D)hhj,Ipm210S*$">
             <field name="NAME">calc</field>
             <field name="INTERVAL">1000</field>
             <field name="UNIT">ms</field>
               <block type="variables_set" id="0o{kX1g9TrRziofKKE`n">
                 <value name="VALUE">
                   <block type="logic_boolean" id="57_A}S_9aHo-D7/*Q-bz">
                   </block>
                 </value>
                 <next>
                   <block type="variables_set" id="fTK`7dy@}I9{xOUk:fdm">
                     <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field>
                       <block type="lists_split" id="fSNHlFM[e|2s~?~WLoA]">
                         <mutation mode="SPLIT"></mutation>
                         <field name="MODE">SPLIT</field>
                         <value name="INPUT">
                           <block type="get_value" id="%}I/[z=}v|bA_s+cN3T+">
                             <field name="OID">kodi.0.info.playing_time_total</field>
                           </block>
                         </value>
                         <value name="DELIM">
                           <shadow type="text" id="bO/MuTT:URPjI@SOF^wu">
                             <field name="TEXT">:</field>
                           </shadow>
                         </value>
                       </block>
                     </value>
                     <next>
                       <block type="variables_set" id="3L:9B.c/-jdK~YPS;}kk">
                         <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field>
                           <block type="lists_split" id="m0vWY?4A}Fy?zECIMa-g">
                               <block type="get_value" id="cmBA^z.eb9hODfdHQbW8">
                                 <field name="OID">kodi.0.info.playing_time</field>
                               </block>
                             </value>
                               <shadow type="text" id=";o/sw@k#dD0mWkC4+b)M">
                               </shadow>
                             </value>
                           </block>
                         </value>
                         <next>
                           <block type="variables_set" id=";/]R)Ct0Dfu6i-d@fN1=">
                             <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field>
                               <block type="math_number" id="!A%IT%#arX*{$UY8=Kva">
                                 <field name="NUM">0</field>
                               </block>
                             </value>
                             <next>
                               <block type="variables_set" id="%LYJ{05i.|T3]O%OZlti">
                                 <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field>
                                   <block type="math_number" id="-:ZTaSM~NWM#h9LoWuBz">
                                   </block>
                                 </value>
                                 <next>
                                   <block type="controls_for" id="2R-$*vTVI{p#n(T8RV.d">
                                     <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field>
                                     <value name="FROM">
                                       <shadow type="math_number" id="yo3lqjuQw}eovRb+XXQ?">
                                         <field name="NUM">1</field>
                                       </shadow>
                                     </value>
                                     <value name="TO">
                                       <shadow type="math_number">
                                         <field name="NUM">10</field>
                                       </shadow>
                                       <block type="lists_length" id="030ssz#WyY6qdm{Y]+%7">
                                           <block type="variables_get" id="LtjmBy}A-?%QRfowFhZH">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="BY">
                                       <shadow type="math_number" id="W4)e3sbN-C[AtksvJyb0">
                                       </shadow>
                                     </value>
                                     <statement name="DO">
                                       <block type="math_change" id="gZ[fn:P}L%w5Hu*/k[w]">
                                         <value name="DELTA">
                                           </shadow>
                                           <block type="math_arithmetic" id="_nrssb{}I|MM@7r=B2*[" inline="false">
                                             <field name="OP">MULTIPLY</field>
                                             <value name="A">
                                               </shadow>
                                               <block type="math_arithmetic" id="?QRRgY%9F+.UW^4Wl#AO">
                                                 <field name="OP">POWER</field>
                                                 <value name="A">
                                                   <shadow type="math_number" id="`nZhdJ)1xBsAmv:WOH{$">
                                                     <field name="NUM">60</field>
                                                   </shadow>
                                                 </value>
                                                 <value name="B">
                                                   </shadow>
                                                   <block type="math_arithmetic" id="%5v;FD87a~}IdxMU?0vb">
                                                     <value name="A">
                                                       </shadow>
                                                       <block type="variables_get" id="~kv8]AFICio,y}2%8r:A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       <shadow type="math_number" id="By?4fEM=/cIUg=PVf-%.">
                                                       </shadow>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="B">
                                               </shadow>
                                               <block type="convert_tonumber" id="Xjk8qkB+rf0:[Z@JKl{4">
                                                   <block type="lists_getIndex" id="=M7:!eN*k,;Op`ncPBu)">
                                                     <mutation statement="false" at="true"></mutation>
                                                     <field name="MODE">GET</field>
                                                     <field name="WHERE">FROM_END</field>
                                                       <block type="variables_get" id="4n4]sPE}}yOyCqIR6sK$">
                                                       </block>
                                                     </value>
                                                     <value name="AT">
                                                       <block type="variables_get" id="5KN91f+6[?BIQQU^P+T/">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                     <next>
                                       <block type="controls_for" id="/[|3}k{qYeK4wFiN6#lx">
                                         <value name="FROM">
                                           <shadow type="math_number" id="1FErI$q)qi=X^N_:%Js?">
                                           </shadow>
                                         </value>
                                         <value name="TO">
                                           </shadow>
                                           <block type="lists_length" id="yJ$~7a^l4Gd#j:0c3$xr">
                                               <block type="variables_get" id="Lh*:^j)}o|0jC8rH:.-+">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <value name="BY">
                                           <shadow type="math_number" id="T3rAediff*:%E88l7+4%">
                                           </shadow>
                                         </value>
                                           <block type="math_change" id="Bsy0,}!M#a)Xi$$B[t]z">
                                               </shadow>
                                               <block type="math_arithmetic" id="ecXevA40kHBJjiNry:#^" inline="false">
                                                 <value name="A">
                                                   </shadow>
                                                   <block type="math_arithmetic" id="K#Ey7v.v;+lcl{1f@5]H">
                                                     <value name="A">
                                                       <shadow type="math_number" id="a~E=mS#u_.VcC[jX^/;*">
                                                       </shadow>
                                                     </value>
                                                     <value name="B">
                                                       </shadow>
                                                       <block type="math_arithmetic" id="p}_MS2!F;,r~o9#j=$`e">
                                                         <value name="A">
                                                           </shadow>
                                                           <block type="variables_get" id="Wr7+iV$a;ynQ,P%0v/|h">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           <shadow type="math_number" id="7DDk.nAP2`-o[3:5T/`V">
                                                           </shadow>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   </shadow>
                                                   <block type="convert_tonumber" id="95Wkc=Wn9wjOL/~emwC:">
                                                       <block type="lists_getIndex" id="):n}4;0GiBs#gE+_-.uf">
                                                           <block type="variables_get" id="WCs.rt_18?skHj|HC;)H">
                                                           </block>
                                                         </value>
                                                         <value name="AT">
                                                           <block type="variables_get" id="dA]HyO~W)iY5ROXqc$PI">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </statement>
                                         <next>
                                           <block type="variables_set" id="x8t?3^{cNVFaKtPFnFq9">
                                             <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field>
                                               <block type="math_arithmetic" id="2+`tDY!LQG^9AZO8#!ZQ" inline="false">
                                                 <value name="A">
                                                   <shadow type="math_number" id="(_=}+a~Ov.r2s~-^a_*5">
                                                     <field name="NUM">1000</field>
                                                   </shadow>
                                                 </value>
                                                 <value name="B">
                                                   </shadow>
                                                   <block type="math_arithmetic" id="D.`(%|9dOcm*(umN9bT@" inline="false">
                                                     <value name="A">
                                                       </shadow>
                                                       <block type="variables_get" id="u7f(0GaP.#L;(fYVBLIF">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </shadow>
                                                       <block type="variables_get" id="]@3~@l|_;uO[L%2ioP,k">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="control" id="E.QKHpVBex}})iCx|o|3">
                                                 <field name="OID">javascript.0.sonstige.kodi_endzeit</field>
                                                   <block type="text_join" id="r1UQi]J^lm7$v9OOADL%">
                                                     <value name="ADD0">
                                                       <block type="convert_from_date" id="TgQBU@2m$Aam**8naRqf">
                                                         <field name="OPTION">hh:mm</field>
                                                           <block type="math_arithmetic" id="vFX,u4337mHL^[94MZjL">
                                                             <field name="OP">ADD</field>
                                                             <value name="A">
                                                               </shadow>
                                                               <block type="time_get" id="WGy*s;07oKI/J`GDI-x3">
        <field name="OPTION">object</field>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                               <block type="variables_get" id="%/#p`[h/wlvqSaXg{l2J">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="ADD1">
                                                       <block type="text" id="+v9neh|_70u#CP~sT+@%">
                                                         <field name="TEXT"> Uhr</field>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                   <block type="variables_set" id="nhKmUFQhs[6|q%}ff0,i">
                                                     <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field>
                                                       <block type="math_round" id="x}`o/-C2Wlv:@=^_3G[a">
                                                         <field name="OP">ROUNDDOWN</field>
                                                         <value name="NUM">
                                                           <shadow type="math_number" id="Rguwmsm{fn2;p`R/F+a:">
                                                             <field name="NUM">3.1</field>
                                                           </shadow>
                                                           <block type="math_arithmetic" id="+onb0BIs?/9$Yw3z|L~1" inline="false">
                                                             <field name="OP">DIVIDE</field>
                                                             <value name="A">
                                                               <shadow type="math_number" id="1ayYAO}MFY09NC(V(*GM">
                                                               </shadow>
                                                               <block type="math_arithmetic" id="s!0#t?dmhC6%l^`PxZe}" inline="false">
        <value name="A">
        <shadow type="math_number" id="#7%I3W~1uE-TD~wta#+4">
        </shadow>
        <block type="variables_get" id="SgkpuEuN:JsZXnT2uiEq">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="variables_get" id="qn{!2^XJ4`(v,M5e*2D(">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               <shadow type="math_number" id="^L@[tikpu/4]}P`vZMd!">
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="variables_set" id="Ig)k@jiA9xaKTc]*wBI1">
                                                         <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field>
                                                           <block type="math_arithmetic" id="7;16331LR(~*?2+JX6w(" inline="false">
                                                             <value name="A">
                                                               <shadow type="math_number" id="CIIcN4{7e~{BnyvZ*~^6">
                                                               </shadow>
                                                               <block type="math_arithmetic" id=";3*On@WOxyMp^0y1_Z(Y" inline="false">
        <value name="A">
        </shadow>
        <block type="variables_get" id="b%.CyBM,CrX$vS8~1tsR">
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="variables_get" id="G)4-/!z*)m%l/V.ry4?R">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               <shadow type="math_number" id=".+85]3KB6[(gBZ%[,7Y~">
                                                               </shadow>
                                                               <block type="math_arithmetic" id="zmhqTi9sN}dQKx97##xL" inline="false">
        <value name="A">
        <shadow type="math_number" id="lis_nxPR2u]H-3F[$b~S">
        </shadow>
        <block type="variables_get" id="Bt;RhM}rb7h:@KbT}11W">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="LKQ#wr7Q=}y?2oYqM^Z(">
        </shadow>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="controls_if" id="NQRm#kW6C~H}~,#%L^7%">
                                                             <value name="IF0">
                                                               <block type="logic_compare" id="LB3RPmG+6NgIm[`*dHW*">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="x8kn5l:/}[T/I1{38:!m">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="4MfeA;EPvu1_2Q5)5*18">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                               <block type="variables_set" id="S4e+8dy%x$|x`kw^Y1eG">
        <block type="text_join" id="m8@abxaQFWUShO4Yh?^e">
        <value name="ADD0">
        <block type="text" id="CGW`SmYv*y^!z[QWs^o[">
        <field name="TEXT">0</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="jhU!RpxkLcDqpJhV*2c2">
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </statement>
                                                             <next>
                                                               <block type="control" id="Ea:z~+62@$PdX^kjvAcF">
        <field name="OID">javascript.0.sonstige.kodi_restzeit</field>
        <block type="text_join" id="Ha28o];Hw|$Cmy5!r;{L">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="variables_get" id="7OYB3%b#mpP$M/XIeJ%S">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="qD7(2)-oK%;2Rz.5k,:`">
        </block>
        </value>
        <value name="ADD2">
        <block type="variables_get" id="zNo@n~vAZH2|)3f|_NT}">
        </block>
        </value>
        <value name="ADD3">
        <block type="text" id="gMw;QinOi/kC}T?H,Gbn">
        <field name="TEXT"> Min.</field>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </statement>
         <statement name="ELSE">
           <block type="timeouts_clearinterval" id="Jb@;uzYL;m`:c=QqzD4L">
             <next>
               <block type="variables_set" id="iv;KGC[hF6MD=bcKz-}~">
                   <block type="logic_boolean" id="V0z@IGk2vj.t5+#2j3f;">
                   </block>
                 </value>
                 <next>
                   <block type="control" id="VSZMp_fJpd1OzYCY=~xN">
                       <block type="text" id="b8vzkml]yd@f[0(Q`e(2">
                         <field name="TEXT"></field>
                       </block>
                     </value>
                     <next>
                       <block type="control" id="AIf3cY6ex%9}xpyKmOtB">
                           <block type="text" id="nX.)Ffq{`}-Hsq,#!6^6">
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
       </block>
     </statement>
    </block>
    dos1973
    schrieb am zuletzt editiert von dos1973
    @Kuddel
    Wow, ich bin begeistert.
    Beide Werte sind vorhanden. ich habe bei mir den wert auf 5 Sekunden angepasst.
    aber was ist den "calc"
    rein optisch gesehen bei Restzeit 76:22, würde ich folgende Formatierung "01:16:22" ansprechender finden.
    Klasse Ding. Vielen Dank für deine Mühe!
    • D dos1973
      @Kuddel
      Kuddel
      @dos1973 calc ist die Schleife. kannst du ignorieren. habe das Skript schon wieder umgebaut.
      nehme jetzt die Spielzeit als trigger.
      baue seine Vorschlag mit der Formatierung morgen noch ein
      • K Kuddel
        dos1973
        @Kuddel
        playing time, habe ich auch schon dran gedacht - das ist ja auf sekundenbasis.
        Jo, schonmal Danke & bis morgen.
          @dos1973 sagte:
          das geht sozusagen im Sekunden Takt.
          Mit Sekundentakt sollte eine moderne Hardware zurecht kommen.
          Kuddel
          @paul53 kann man die Umrechnung der Restzeit evtl. besser bauen?
          Ich habe das aktuell so umgesetzt:
          Würde auch irgendwie mit Konvertierung gehen ?
          Irgendwie so ?
          • K Kuddel
            Irgendwie so ?
            @Kuddel sagte:
            Ja, man muss die Zeitzone berücksichtigen.
              @Kuddel sagte:
              Kuddel
              @paul53 ah okay.
              habe zu dem Problem mal ein extra Threaad eröffnet:
              https://forum.iobroker.net/topic/38326/sekunden-in-std-min-sek-formatieren/2
              Auf die Zeitzonen wurde da auch schon hingewiesen.
              Weiter bin ich aber dadurch auch nicht ^^
              • K Kuddel
                @paul53 ah okay.
                @Kuddel sagte:
                Die Lösung befindet sich im verlinkten Beitrag.
                  @Kuddel sagte:
                  Kuddel
                  @paul53 super, vielen Dank. Habe es hinbekommen.
                  @dos1973
                  Hier das fertige Skript:
                   <variables>
                     <variable id="z6@)Eo%V776?qOlzgeJq">sekunden_total</variable>
                     <variable id="c70ch.|4qGYP3!UEvS8x">sekunden</variable>
                     <variable id="Gv49fQ40~+/ya6#JMvO}">time_total</variable>
                     <variable id="8?J4Jmf7%_-wS9!yell|">time</variable>
                     <variable id="7gbI~lkqQ~M|C;mJ+cDq">i</variable>
                     <variable id="fB}3.DkAG[Zns[jkc^B)">diff</variable>
                     <variable id="=M^bc[m%CQVRvq!f}vIA">rest_sek_gesamt</variable>
                   </variables>
                   <block type="on_ext" id="mhrPpA^7UN)RTNT]/[[R" x="-12" y="-387">
                     <value name="OID0">
                       <shadow type="field_oid" id="X%v$|Bp`D)/8o$MsBajH">
                         <field name="oid">kodi.0.info.playing_time</field>
                       </shadow>
                     </value>
                       <block type="controls_if" id="DPV3L8uxH[7hV$K{3Okp">
                         <value name="IF0">
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                                   </block>
                                 </value>
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                       </shadow>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                       </block>
                                     </value>
                                     <next>
                                           </block>
                                         </value>
                                         <next>
                                             <value name="FROM">
                                               </shadow>
                                             </value>
                                             <value name="TO">
                                               </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="BY">
                                               </shadow>
                                             </value>
                                                   </shadow>
                                                     <value name="A">
                                                       </shadow>
                                                         <value name="A">
                                                           </shadow>
                                                         </value>
                                                         <value name="B">
                                                           </shadow>
                                                             <value name="A">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </shadow>
                                                               </block>
                                                             </value>
                                                             <value name="AT">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </statement>
                                             <next>
                                                 <value name="FROM">
                                                   </shadow>
                                                 </value>
                                                 <value name="TO">
                                                   </shadow>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="BY">
                                                   </shadow>
                                                 </value>
                                                       </shadow>
                                                         <value name="A">
                                                           </shadow>
                                                             <value name="A">
                                                               </shadow>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </shadow>
        </block>
        </value>
        <value name="AT">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                         <value name="A">
                                                           </shadow>
                                                         </value>
                                                         <value name="B">
                                                           </shadow>
                                                             <value name="A">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="variables_set" id="@IH=J5P5=tnH`9Iu_Px|">
                                                         <field name="VAR" id="=M^bc[m%CQVRvq!f}vIA">rest_sek_gesamt</field>
                                                           <block type="math_arithmetic" id="~E$;9??|fPcDC|HJqW`-" inline="false">
                                                             <value name="A">
                                                               </shadow>
                                                               <block type="variables_get" id="1`UnN?gb.[~)w}d6VRR)">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                               <block type="variables_get" id=")m(;caB*Y|AI7#H$k`-_">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        <value name="ADD0">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
                                                               <block type="comment" id=":K!+{P30dMt;$jGMg6$T">
        <field name="COMMENT">Restzeit in DP schreiben</field>
        <next>
        <block type="controls_if" id="YLU1O|*kP;~~)*%A*c64" collapsed="true">
        <value name="IF0">
        <block type="logic_compare" id="O/cS/vtiw%t25mVoX0E)">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="variables_get" id="Z9ar3}8Z9NYbMmd_Lr{$">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="EQS;F?$mC9ays!GQHelg">
        <field name="NUM">3600</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id=":vGI/P.wI*w^?R3?]A_y">
        <block type="text_join" id="qj]1+vKK[~s9~4E-?Hmt">
        <value name="ADD0">
        <block type="convert_from_date" id="op^3$IrO,sQp3qbNH[yr">
        <field name="OPTION">hh:mm:ss</field>
        <block type="math_arithmetic" id="`@gy7^%rBU*AJl2gq,W^" inline="false">
        <value name="A">
        <shadow type="math_number" id="7DRWC8OQ|/xV,23*f7b.">
        </shadow>
        <block type="math_arithmetic" id="SRr*2A-d~+C3S^ASaz|z" inline="false">
        <value name="A">
        <shadow type="math_number" id="B;w,.X}/n^mV^MqBH1EO">
        </shadow>
        <block type="variables_get" id="Gje!a(?`DOk/EP7U~{+7">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="eh15lqzy94bn2F7r%vLT">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="K2`(*`(@|mb~gR~jDTT.">
        </shadow>
        <block type="convert_from_date" id="D)wHz^=FFv!%zu14#F`9">
        <block type="text" id="l2}(S$*x*xXv8{@KIM.D">
        <field name="TEXT">1970-01-01 00:00</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id=":iAB8qR}G,901EBDh9V@">
        <field name="TEXT"> Std.</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <block type="control" id="1TUgHZS-t^g/r?roa;T:">
        <block type="text_join" id="T7V(Q!yelYlEyv$W7W4_">
        <value name="ADD0">
        <block type="convert_from_date" id="jqWJ%(d*IN6r=2uM2yvn">
        <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
        <field name="OPTION">custom</field>
        <field name="FORMAT">mm:ss</field>
        <block type="math_arithmetic" id="V_}s;3rr[k0N-jfh|V}}" inline="false">
        <value name="A">
        <shadow type="math_number" id=".@}R8NgR0O}W6q=Evlt;">
        </shadow>
        <block type="math_arithmetic" id=")rp!A(b[(?HtEXZ4lGAs" inline="false">
        <value name="A">
        </shadow>
        <block type="variables_get" id="p?7L/:k:KJVYeaAb(Pvk">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="$eyPSY:~L?%j}!8_HgRv">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="convert_from_date" id="y9P,E-JX6-@5QR+90)Ca">
        <block type="text" id="rE/w?T7DF_A_Vh|YK/Rp">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="hNX8Lh|^E|EZ)wM(jO+[">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </statement>
                               </block>
                             </value>
                             <next>
                                   </block>
                                 </value>
                               </block>
                             </next>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                   <block type="math_arithmetic" id="xwnzXAGK!}3ZV`cn+p-J" inline="false" x="318" y="281">
                     <value name="A">
                       </shadow>
                       <block type="variables_get" id="SV_szV+egA]WXMJuUu0A">
                       </block>
                     </value>
                     <value name="B">
                       </shadow>
                       <block type="variables_get" id="s7O)lDYhn!.(UeSGgj(c">
                       </block>
                     </value>
                   </block>
                  </xml>
                  • K Kuddel
                    @dos1973
                     <variables>
                     </variables>
                       <value name="OID0">
                         </shadow>
                       </value>
                           <value name="IF0">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                                     </block>
                                   </value>
                                     </shadow>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                         </block>
                                       </value>
                                         </shadow>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                           <next>
                                               <value name="FROM">
                                                 </shadow>
                                               </value>
                                               <value name="TO">
                                                 </shadow>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <value name="BY">
                                                 </shadow>
                                               </value>
                                                     </shadow>
                                                       <value name="A">
                                                         </shadow>
                                                           <value name="A">
                                                             </shadow>
                                                           </value>
                                                           <value name="B">
                                                             </shadow>
                                                               <value name="A">
        </shadow>
        </block>
                                                               </value>
                                                               <value name="B">
        </shadow>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </shadow>
        </block>
                                                               </value>
                                                               <value name="AT">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                               <next>
                                                   <value name="FROM">
                                                     </shadow>
                                                   </value>
                                                   <value name="TO">
                                                     </shadow>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <value name="BY">
                                                     </shadow>
                                                   </value>
                                                         </shadow>
                                                           <value name="A">
                                                             </shadow>
                                                               <value name="A">
        </shadow>
                                                               </value>
                                                               <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             </shadow>
        </block>
        </value>
        <value name="AT">
        </block>
        </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                           <value name="A">
                                                             </shadow>
                                                           </value>
                                                           <value name="B">
                                                             </shadow>
                                                               <value name="A">
        </shadow>
        </block>
                                                               </value>
                                                               <value name="B">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                               <value name="A">
        </shadow>
        </block>
                                                               </value>
                                                               <value name="B">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        <value name="ADD0">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="ADD0">
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="ADD0">
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                       <value name="A">
                         </shadow>
                         </block>
                       </value>
                       <value name="B">
                         </shadow>
                         </block>
                       </value>
                     </block>
                    </xml>
                    sigi234S Online
                    sigi234S Online
                    @Kuddel
                    Hallo, da ist ein Fehler drinnen, Blöcke nicht verbunden
                    • sigi234S sigi234
                      @Kuddel
                      Kuddel
                      @sigi234 oh danke, die blöcke sind überflüssig
                      • K Kuddel
                        dos1973
                        @Kuddel
                        Danke Dir, schau ich mir morgen an.
                        • D dos1973
                          @Kuddel
                          dos1973
                          @Kuddel 1A. Klappt Super. Thx
                          • D dos1973
                            Kuddel
                            @dos1973 habe noch einen offenen Punkt, nur leider noch keine Idee.
                            Wenn man auf Pausen klickt, wird die Enduhrzeit nicht weiter berechnet
                            • K Kuddel
                              dos1973
                              @Kuddel
                              Stimmt, jetzt wo du e sagst.
                              Idee. Timestamp „pause“ zu Timestamp endzeit addieren
                              Soviel zu Theorie ;-)
                              • D dos1973
                                @Kuddel
                                Kuddel
                                @dos1973 das Problem ist nur, dass das Skript nicht mehr auslöst, wenn Kodi pausiert.
                                weder state noch Spielzeit ändern sich.
                                Hmm mit einer Schleife will ich nur ungern arbeiten
                                • K Kuddel
                                  dos1973
                                  @Kuddel
                                  Wäre state change ein trigger?
                                  Hab jetzt kein kodi vor mir, aber ich meine der state ändert sich.
                                  • D dos1973
                                    @Kuddel
                                    Kuddel
                                    @dos1973 ja der State ändern sich auf Pause.
                                    dann läuft das Skript noch genau einmal.
                                    macht man 5 min Pause, wird die Enduhrzeit für 5min nicht weiter berechnet da sich weder state noch Spielzeit in den 5 min ändern
                                    • K Kuddel
                                      Kuddel
                                      @dos1973 habe mir nochmal gedanken gemacht.
                                      habe das Skript jetzt in drei Falls-Blöcke unterteilt: Play, Pause, Stop
                                      Pause sieht so aus (mit einer Schleife alle 60 Sek.)
                                      Leider funktioniert die Berechnung noch nicht ganz.
                                      @paul53 kannst du helfen ?
                                      • K Kuddel
                                        @Kuddel
                                        Die Restzeit ändert sich in der Pause nicht, sondern nur die aktuelle Zeit.
                                          @Kuddel
                                          Kuddel
                                          @paul53 es geht auch nicht um die Restzeit, sondern um die Enduhrzeit des Films.
                                          Die verändert sich in der Pause ja.
