  4. Nach 2 Jahre Updaten klappt aber nicht
update
46 Beiträge 4 Kommentatoren 6.2k Aufrufe 4 Beobachtet
  • B badplay
    @Thomas-Braun said in Nach 2 Jahre Updaten klappt aber nicht:
    curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash
    scheint geklappt zu haben
    pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash
    ## Installing the NodeSource Node.js 12.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
    Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
    Hit:3 https://deb.nodesource.com/node_10.x stretch InRelease
    Fetched 25.4 kB in 1s (19.6 kB/s)
    Reading package lists... Done
    ## Confirming "stretch" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/stretch/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
    OK
    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
    + echo 'deb https://deb.nodesource.com/node_12.x stretch main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_12.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
    Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
    Get:3 https://deb.nodesource.com/node_12.x stretch InRelease [4,585 B]
    Get:4 https://deb.nodesource.com/node_12.x stretch/main armhf Packages [775 B]
    Fetched 30.7 kB in 2s (14.0 kB/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    bzw muss ich noch
    jetzt ausführen?
    @badplay
    Ich hätte es anders gemacht, aber so geht es auch.
    sudo apt update
    sudo apt upgrade
    should do the trick
    B 2 Antworten Letzte Antwort
      @badplay
      sudo apt update
      sudo apt upgrade
      should do the trick
      badplay
      @Thomas-Braun hab nun mit
      pi@raspberrypi:~ $ node -v
      v12.19.0
      drauf
      sudo apt update
      sudo apt upgrade
      hat immer nur ausgegeben das die neuste version 10x installiert war aber ich konnte nicht auf 12x updaten
        @badplay
        sudo apt update
        sudo apt upgrade
        should do the trick
        badplay
        sudo apt upgrade
        nun geht dein code aber auch:
        pi@raspberrypi:~ $ sudo apt update
        Hit:2 https://deb.nodesource.com/node_12.x stretch InRelease
        Get:3 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
        Fetched 25.4 kB in 1s (15.6 kB/s)
        Building dependency tree
        All packages are up to date.
        pi@raspberrypi:~ $ sudo apt upgrade
        Calculating upgrade... Done
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        • B badplay
          v12.19.0
          drauf
          sudo apt update
          sudo apt upgrade
          @badplay sagte in Nach 2 Jahre Updaten klappt aber nicht:
          Logisch. Das Regal mit der Version 12 stand ja auch gar nicht im Laden. Nur die Version 10.
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            badplay
            schrieb am zuletzt editiert von badplay
            @Thomas-Braun aso weil mir geschrieben wurde auf 12 updaten.
            so aber ich denke jetzt sollte alles wieder aktuell sein
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.19.0
            /usr/bin/node
            v12.19.0
            /usr/bin/npm
            6.14.8
            nodejs:
              Installed: 12.19.0-1nodesource1
              Candidate: 12.19.0-1nodesource1
              Version table:
             *** 12.19.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                 8.11.1~dfsg-2~bpo9+1 500
                    500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                 4.8.2~dfsg-1 500
                    500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
            pi@raspberrypi:~ $
            • B badplay
              /usr/bin/nodejs
              v12.19.0
              /usr/bin/node
              v12.19.0
              /usr/bin/npm
              6.14.8
              nodejs:
                Version table:
                   4.8.2~dfsg-1 500
              pi@raspberrypi:~ $
              @badplay Starte mal durch, die Kiste.
              Und dann
              iobroker version
              Wenn da was von 3.1.6 kommt, dann
              iobroker update
              iobroker upgrade
                Und dann
                iobroker version
                iobroker update
                iobroker upgrade
                badplay
                iobroker upgrade
                pi@raspberrypi:~ $ iobroker version
                3.1.6
                pi@raspberrypi:~ $ 3.1.6
                -bash: 3.1.6: command not found
                pi@raspberrypi:~ $ iobroker update
                Used repository: default
                hash unchanged, use cached sources
                update done
                Adapter    "admin"         : 4.0.10   , installed 4.0.10
                Adapter    "alarm"         : 1.2.4
                Adapter    "alexa2"        : 3.3.1
                Adapter    "alpha2"        : 1.0.0
                Adapter    "amazon-dash"   : 1.1.0
                Adapter    "artnet"        : 1.2.2
                Adapter    "asterisk"      : 1.0.6
                Adapter    "asuswrt"       : 1.0.1    , installed 1.0.1
                Adapter    "b-control-em"  : 0.2.1
                Adapter    "backitup"      : 1.6.7
                Adapter    "beckhoff"      : 1.2.2
                Adapter    "benq"          : 0.2.0
                Adapter    "binance"       : 1.1.3
                Adapter    "ble"           : 0.11.8
                Adapter    "bmw"           : 1.3.3
                Adapter    "bosesoundtouch": 0.2.4
                Adapter    "botvac"        : 1.0.0
                Adapter    "bring"         : 1.7.2
                Adapter    "broadlink2"    : 2.0.3
                Adapter    "bsblan"        : 0.1.5
                Adapter    "bshb"          : 0.1.10
                Adapter    "chromecast"    : 2.3.1
                Adapter    "cloud"         : 3.0.4    , installed 3.0.4
                Adapter    "comfoair"      : 0.3.2
                Adapter    "contactid"     : 1.0.1
                Adapter    "coronavirus-statistics": 0.6.1
                Adapter    "countdown"     : 1.1.0
                Adapter    "cul"           : 1.2.1
                Adapter    "daikin"        : 1.0.5
                Adapter    "daswetter"     : 3.0.4
                Adapter    "deconz"        : 1.3.11
                Adapter    "denon"         : 1.7.7
                Adapter    "devices"       : 0.3.6
                Adapter    "digitalstrom"  : 0.5.5
                Adapter    "discovergy"    : 0.5.0
                Adapter    "discovery"     : 2.3.7    , installed 2.3.7
                Adapter    "doorio"        : 1.1.0
                Adapter    "ds18b20"       : 1.1.4
                Adapter    "dwd"           : 2.4.10
                Adapter    "ebus"          : 2.1.1
                Adapter    "ecovacs-deebot": 1.0.3
                Adapter    "egigeozone"    : 0.1.2
                Adapter    "ekey"          : 1.1.0
                Adapter    "email"         : 1.0.7
                Adapter    "emby"          : 1.0.2
                Adapter    "energymanager" : 1.2.3
                Adapter    "enet"          : 1.0.1
                Adapter    "epson_stylus_px830": 0.2.1
                Adapter    "exchangerates" : 0.0.13
                Adapter    "fakeroku"      : 0.2.1
                Adapter    "fb-checkpresence": 1.0.4
                Adapter    "feiertage"     : 1.0.17
                Adapter    "fhem"          : 1.5.3
                Adapter    "find-my-iphone": 0.2.15
                Adapter    "firetv"        : 0.0.27
                Adapter    "flot"          : 1.9.2
                Adapter    "foobar2000"    : 2.0.3
                Adapter    "fritzbox"      : 0.2.1
                Adapter    "fritzdect"     : 0.2.4
                Adapter    "fronius"       : 1.0.5
                Adapter    "fullcalendar"  : 1.1.0
                Adapter    "fullybrowser"  : 2.0.1
                Adapter    "g-homa"        : 0.5.3
                Adapter    "geofency"      : 0.3.2
                Adapter    "gruenbeck"     : 0.0.18
                Adapter    "habpanel"      : 0.4.3
                Adapter    "haier"         : 1.0.2
                Adapter    "ham"           : 1.1.2
                Adapter    "ham-wemo"      : 1.0.1
                Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                Adapter    "heatingcontrol": 1.0.0
                Adapter    "heytech"       : 1.0.0
                Adapter    "hid"           : 0.1.17
                Adapter    "history"       : 1.9.10   , installed 1.9.10
                Adapter    "hm-rega"       : 2.6.21
                Adapter    "hm-rpc"        : 1.14.24
                Adapter    "hmip"          : 1.3.1
                Adapter    "homeconnect"   : 0.0.30
                Adapter    "homee"         : 1.0.7
                Adapter    "homepilot"     : 1.0.3
                Adapter    "hp-ilo"        : 1.0.6
                Adapter    "hs100"         : 2.0.1
                Adapter    "hue"           : 3.3.8
                Adapter    "hue-extended"  : 2.0.0
                Adapter    "ical"          : 1.7.4
                Adapter    "icons-addictive-flavour-png": 0.1.0
                Adapter    "icons-fatcow-hosting": 0.1.0
                Adapter    "icons-icons8"  : 0.0.1
                Adapter    "icons-material-png": 0.1.0
                Adapter    "icons-material-svg": 0.1.0
                Adapter    "icons-mfd-png" : 1.0.2
                Adapter    "icons-mfd-svg" : 1.0.2
                Adapter    "icons-open-icon-library-png": 0.1.2
                Adapter    "icons-ultimate-png": 1.0.1
                Adapter    "influxdb"      : 1.9.1
                Adapter    "info"          : 1.7.2    , installed 1.7.2
                Adapter    "innogy-smarthome": 0.3.6
                Adapter    "iogo"          : 0.5.10
                Adapter    "iot"           : 1.5.3
                Adapter    "iqontrol"      : 1.3.3
                Adapter    "jarvis"        : 1.0.9
                Adapter    "javascript"    : 4.8.4    , installed 4.8.4
                Adapter    "jeelink"       : 0.1.0
                Controller "js-controller" : 3.1.6    , installed 3.1.6
                Adapter    "kecontact"     : 0.1.0
                Adapter    "klf200"        : 1.0.1
                Adapter    "km200"         : 1.1.6
                Adapter    "knmi-weather"  : 1.0.0
                Adapter    "knx"           : 1.0.39
                Adapter    "kodi"          : 2.0.4
                Adapter    "kostal-piko-ba": 1.1.1
                Adapter    "kress"         : 2.5.5
                Adapter    "lametric"      : 0.0.9
                Adapter    "landroid"      : 1.0.3
                Adapter    "lcn"           : 0.3.2
                Adapter    "letrika_comgw" : 0.0.5
                Adapter    "lgtv"          : 1.1.10
                Adapter    "lgtv-rs"       : 0.1.0
                Adapter    "lgtv11"        : 1.0.5
                Adapter    "lifx"          : 0.1.0
                Adapter    "lightify"      : 0.2.16
                Adapter    "link"          : 0.5.9
                Adapter    "linkeddevices" : 1.2.2
                Adapter    "linux-control" : 1.0.0
                Adapter    "logparser"     : 1.1.0
                Adapter    "lovelace"      : 1.0.16
                Adapter    "loxone"        : 2.0.2
                Adapter    "luftdaten"     : 0.0.17
                Adapter    "lupusec"       : 1.2.9
                Adapter    "luxtronik1"    : 0.2.2
                Adapter    "material"      : 0.13.9
                Adapter    "maxcube"       : 0.1.2
                Adapter    "maxcul"        : 1.3.0
                Adapter    "mbus"          : 2.3.0
                Adapter    "mclighting"    : 0.1.1
                Adapter    "megad"         : 1.2.1
                Adapter    "megadd"        : 0.2.0
                Adapter    "megaesp"       : 0.1.0
                Adapter    "melcloud"      : 1.0.6
                Adapter    "mercedesme"    : 0.0.21
                Adapter    "mercury"       : 0.1.1
                Adapter    "meross"        : 1.5.0
                Adapter    "meteoalarm"    : 1.0.9
                Adapter    "midea"         : 0.0.6
                Adapter    "miele"         : 0.1.5
                Adapter    "mielecloudservice": 2.0.0
                Adapter    "mihome"        : 1.3.0    , installed 1.3.0
                Adapter    "mihome-lamp"   : 1.1.0
                Adapter    "mihome-plug"   : 0.2.0
                Adapter    "mihome-vacuum" : 2.0.7
                Adapter    "mikrotik"      : 1.0.11
                Adapter    "milight"       : 0.3.6
                Adapter    "milight-smart-light": 0.2.7
                Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                Adapter    "modbus"        : 3.1.6
                Adapter    "moma"          : 1.2.6
                Adapter    "mpd"           : 1.0.5
                Adapter    "mqtt"          : 2.1.9
                Adapter    "mqtt-client"   : 1.3.1
                Adapter    "musiccast"     : 0.1.3
                Adapter    "mydlink"       : 1.1.7
                Adapter    "mysensors"     : 2.0.1
                Adapter    "nanoleaf-lightpanels": 0.8.1
                Adapter    "nello"         : 2.0.6
                Adapter    "netatmo"       : 1.3.1
                Adapter    "nibeuplink"    : 0.3.0
                Adapter    "nina"          : 0.0.22
                Adapter    "node-red"      : 1.17.2
                Adapter    "nuki"          : 1.3.1
                Adapter    "nuki-extended" : 2.3.0
                Adapter    "nut"           : 1.1.3
                Adapter    "odl"           : 1.0.5
                Adapter    "oilfox"        : 0.0.5
                Adapter    "onkyo"         : 2.0.3
                Adapter    "onvif"         : 0.4.4
                Adapter    "openhab"       : 1.1.0
                Adapter    "openligadb"    : 1.1.0
                Adapter    "openweathermap": 0.1.0
                Adapter    "opi"           : 0.1.1
                Adapter    "oppoplayer"    : 0.2.1
                Adapter    "owfs"          : 0.6.4
                Adapter    "owntracks"     : 0.6.3
                Adapter    "panasonic-viera": 1.0.2
                Adapter    "parser"        : 1.0.7
                Adapter    "paw"           : 0.0.7
                Adapter    "phantomjs"     : 1.0.1
                Adapter    "pi-hole"       : 1.3.1
                Adapter    "piface"        : 1.0.0
                Adapter    "pimatic"       : 0.3.0
                Adapter    "ping"          : 1.4.8    , installed 1.4.8
                Adapter    "places"        : 1.0.0
                Adapter    "plex"          : 0.8.11
                Adapter    "plexconnect"   : 0.0.7
                Adapter    "pollenflug"    : 1.0.6
                Adapter    "proxmox"       : 1.0.1
                Adapter    "proxy"         : 1.1.1
                Adapter    "pushbullet"    : 0.0.11
                Adapter    "pushover"      : 2.0.2
                Adapter    "pushsafer"     : 0.1.8
                Adapter    "radar2"        : 1.0.9
                Adapter    "radiohead"     : 1.0.7
                Adapter    "rflink"        : 2.0.0
                Adapter    "rickshaw"      : 1.0.0
                Adapter    "ring"          : 1.1.3
                Adapter    "robonect"      : 0.1.3
                Adapter    "roomba"        : 1.1.1
                Adapter    "rpi2"          : 1.2.0
                Adapter    "s7"            : 1.1.8
                Adapter    "samsung"       : 0.2.9
                Adapter    "sayit"         : 1.9.8
                Adapter    "sbfspot"       : 4.0.2
                Adapter    "scenes"        : 2.1.7    , installed 2.1.7
                Adapter    "schoolfree"    : 0.6.3
                Adapter    "schwoerer-ventcube": 1.3.0
                Adapter    "shelly"        : 4.0.3
                Adapter    "shuttercontrol": 0.8.6
                Adapter    "sia"           : 1.0.4
                Adapter    "siegenia"      : 1.0.0
                Adapter    "simple-api"    : 2.4.6    , installed 2.4.6
                Adapter    "smappee"       : 0.2.2
                Adapter    "smartgarden"   : 1.0.1
                Adapter    "smartmeter"    : 3.1.5
                Adapter    "snips"         : 1.5.1
                Adapter    "snmp"          : 0.5.0
                Adapter    "socketio"      : 3.0.13   , installed 3.0.13
                Adapter    "solarlog"      : 2.0.0
                Adapter    "solarviewdatareader": 0.2.1
                Adapter    "solarwetter"   : 1.0.0
                Adapter    "sonnen"        : 1.6.0
                Adapter    "sonoff"        : 2.3.3
                Adapter    "sonos"         : 2.1.0
                Adapter    "sony-bravia"   : 1.0.1
                Adapter    "spotify-premium": 1.0.0
                Adapter    "sql"           : 1.15.2
                Adapter    "squeezebox"    : 1.0.0
                Adapter    "squeezeboxrpc" : 1.0.0
                Adapter    "starline"      : 1.0.0
                Adapter    "statistics"    : 0.2.2
                Adapter    "stiebel-isg"   : 1.5.1
                Adapter    "sunnyportal"   : 0.1.5
                Adapter    "swiss-weather-api": 0.3.2
                Adapter    "synology"      : 0.1.18
                Adapter    "systeminfo"    : 0.3.1
                Adapter    "tahoma"        : 0.3.2
                Adapter    "tankerkoenig"  : 2.0.5
                Adapter    "telegram"      : 1.5.9
                Adapter    "terminal"      : 0.1.2
                Adapter    "tesla-motors"  : 0.2.3
                Adapter    "text2command"  : 1.3.0
                Adapter    "tinker"        : 1.1.0
                Adapter    "tr-064"        : 4.0.9
                Adapter    "tradfri"       : 2.6.3
                Adapter    "trashschedule" : 0.0.11
                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                Adapter    "tuya"          : 3.3.15
                Adapter    "tvspielfilm"   : 1.0.4
                Adapter    "unifi"         : 0.5.8
                Adapter    "upnp"          : 1.0.16
                Adapter    "vaillant"      : 0.0.10
                Adapter    "valloxmv"      : 1.1.1
                Adapter    "vcard"         : 0.0.9
                Adapter    "velux"         : 0.0.5
                Adapter    "viessmann"     : 1.3.2
                Adapter    "virtualpowermeter": 1.2.1
                Adapter    "vis"           : 1.2.12   , installed 1.2.12
                Adapter    "vis-bars"      : 0.1.4
                Adapter    "vis-canvas-gauges": 0.1.5
                Adapter    "vis-colorpicker": 1.1.1
                Adapter    "vis-fancyswitch": 1.1.0
                Adapter    "vis-google-fonts": 0.1.0
                Adapter    "vis-history"   : 1.0.0
                Adapter    "vis-hqwidgets" : 1.1.4
                Adapter    "vis-icontwo"   : 0.31.0
                Adapter    "vis-inventwo"  : 1.3.8
                Adapter    "vis-jqui-mfd"  : 1.0.12
                Adapter    "vis-justgage"  : 1.0.2
                Adapter    "vis-keyboard"  : 0.0.2
                Adapter    "vis-lcars"     : 1.0.4
                Adapter    "vis-map"       : 1.0.4
                Adapter    "vis-material-advanced": 1.1.1
                Adapter    "vis-metro"     : 1.1.2
                Adapter    "vis-players"   : 0.1.6
                Adapter    "vis-plumb"     : 1.0.2
                Adapter    "vis-rgraph"    : 0.0.2
                Adapter    "vis-timeandweather": 1.1.7
                Adapter    "vis-weather"   : 2.5.2
                Adapter    "vr200"         : 1.0.0
                Adapter    "vw-connect"    : 0.0.15
                Adapter    "weatherunderground": 3.2.1
                Adapter    "web"           : 3.0.13   , installed 3.0.13
                Adapter    "weishaupt-wem" : 0.0.8
                Adapter    "wiffi-wz"      : 2.2.0
                Adapter    "wifilight"     : 1.1.0
                Adapter    "windows-control": 0.1.5
                Adapter    "wled"          : 0.5.2
                Adapter    "wm-bus"        : 0.1.12
                Adapter    "wolf"          : 0.9.2
                Adapter    "worx"          : 1.2.3
                Adapter    "xbox"          : 0.6.8
                Adapter    "xs1"           : 1.0.2
                Adapter    "yahka"         : 0.11.0
                Adapter    "yamaha"        : 0.3.19
                Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                Adapter    "youtube"       : 0.0.11
                Adapter    "yr"            : 2.0.3
                Adapter    "zigbee"        : 1.2.1
                Adapter    "zont"          : 0.5.3
                Adapter    "zwave"         : 2.0.1
                Adapter    "zwave2"        : 1.7.5
                pi@raspberrypi:~ $ iobroker upgrade
                Adapter "admin"          is up to date.
                Adapter "alarm"          is not installed.
                Adapter "alexa2"         is not installed.
                Adapter "alpha2"         is not installed.
                Adapter "amazon-dash"    is not installed.
                Adapter "artnet"         is not installed.
                Adapter "asterisk"       is not installed.
                Adapter "asuswrt"        is up to date.
                Adapter "b-control-em"   is not installed.
                Adapter "backitup"       is not installed.
                Adapter "beckhoff"       is not installed.
                Adapter "benq"           is not installed.
                Adapter "binance"        is not installed.
                Adapter "ble"            is not installed.
                Adapter "bmw"            is not installed.
                Adapter "bosesoundtouch" is not installed.
                Adapter "botvac"         is not installed.
                Adapter "bring"          is not installed.
                Adapter "broadlink2"     is not installed.
                Adapter "bsblan"         is not installed.
                Adapter "bshb"           is not installed.
                Adapter "chromecast"     is not installed.
                Adapter "cloud"          is up to date.
                Adapter "comfoair"       is not installed.
                Adapter "contactid"      is not installed.
                Adapter "coronavirus-statistics" is not installed.
                Adapter "countdown"      is not installed.
                Adapter "cul"            is not installed.
                Adapter "daikin"         is not installed.
                Adapter "daswetter"      is not installed.
                Adapter "deconz"         is not installed.
                Adapter "denon"          is not installed.
                Adapter "devices"        is not installed.
                Adapter "digitalstrom"   is not installed.
                Adapter "discovergy"     is not installed.
                Adapter "discovery"      is up to date.
                Adapter "doorio"         is not installed.
                Adapter "ds18b20"        is not installed.
                Adapter "dwd"            is not installed.
                Adapter "ebus"           is not installed.
                Adapter "ecovacs-deebot" is not installed.
                Adapter "egigeozone"     is not installed.
                Adapter "ekey"           is not installed.
                Adapter "email"          is not installed.
                Adapter "emby"           is not installed.
                Adapter "energymanager"  is not installed.
                Adapter "enet"           is not installed.
                Adapter "epson_stylus_px830" is not installed.
                Adapter "exchangerates"  is not installed.
                Adapter "fakeroku"       is not installed.
                Adapter "fb-checkpresence" is not installed.
                Adapter "feiertage"      is not installed.
                Adapter "fhem"           is not installed.
                Adapter "find-my-iphone" is not installed.
                Adapter "firetv"         is not installed.
                Adapter "flot"           is not installed.
                Adapter "foobar2000"     is not installed.
                Adapter "fritzbox"       is not installed.
                Adapter "fritzdect"      is not installed.
                Adapter "fronius"        is not installed.
                Adapter "fullcalendar"   is not installed.
                Adapter "fullybrowser"   is not installed.
                Adapter "g-homa"         is not installed.
                Adapter "geofency"       is not installed.
                Adapter "gruenbeck"      is not installed.
                Adapter "habpanel"       is not installed.
                Adapter "haier"          is not installed.
                Adapter "ham"            is not installed.
                Adapter "ham-wemo"       is not installed.
                Adapter "harmony"        is up to date.
                Adapter "heatingcontrol" is not installed.
                Adapter "heytech"        is not installed.
                Adapter "hid"            is not installed.
                Adapter "history"        is up to date.
                Adapter "hm-rega"        is not installed.
                Adapter "hm-rpc"         is not installed.
                Adapter "hmip"           is not installed.
                Adapter "homeconnect"    is not installed.
                Adapter "homee"          is not installed.
                Adapter "homepilot"      is not installed.
                Adapter "hp-ilo"         is not installed.
                Adapter "hs100"          is not installed.
                Adapter "hue"            is not installed.
                Adapter "hue-extended"   is not installed.
                Adapter "ical"           is not installed.
                Adapter "icons-addictive-flavour-png" is not installed.
                Adapter "icons-fatcow-hosting" is not installed.
                Adapter "icons-icons8"   is not installed.
                Adapter "icons-material-png" is not installed.
                Adapter "icons-material-svg" is not installed.
                Adapter "icons-mfd-png"  is not installed.
                Adapter "icons-mfd-svg"  is not installed.
                Adapter "icons-open-icon-library-png" is not installed.
                Adapter "icons-ultimate-png" is not installed.
                Adapter "influxdb"       is not installed.
                Adapter "info"           is up to date.
                Adapter "innogy-smarthome" is not installed.
                Adapter "iogo"           is not installed.
                Adapter "iot"            is not installed.
                Adapter "iqontrol"       is not installed.
                Adapter "jarvis"         is not installed.
                Adapter "javascript"     is up to date.
                Adapter "jeelink"        is not installed.
                Adapter "kecontact"      is not installed.
                Adapter "klf200"         is not installed.
                Adapter "km200"          is not installed.
                Adapter "knmi-weather"   is not installed.
                Adapter "knx"            is not installed.
                Adapter "kodi"           is not installed.
                Adapter "kostal-piko-ba" is not installed.
                Adapter "kress"          is not installed.
                Adapter "lametric"       is not installed.
                Adapter "landroid"       is not installed.
                Adapter "lcn"            is not installed.
                Adapter "letrika_comgw"  is not installed.
                Adapter "lgtv"           is not installed.
                Adapter "lgtv-rs"        is not installed.
                Adapter "lgtv11"         is not installed.
                Adapter "lifx"           is not installed.
                Adapter "lightify"       is not installed.
                Adapter "link"           is not installed.
                Adapter "linkeddevices"  is not installed.
                Adapter "linux-control"  is not installed.
                Adapter "logparser"      is not installed.
                Adapter "lovelace"       is not installed.
                Adapter "loxone"         is not installed.
                Adapter "luftdaten"      is not installed.
                Adapter "lupusec"        is not installed.
                Adapter "luxtronik1"     is not installed.
                Adapter "material"       is not installed.
                Adapter "maxcube"        is not installed.
                Adapter "maxcul"         is not installed.
                Adapter "mbus"           is not installed.
                Adapter "mclighting"     is not installed.
                Adapter "megad"          is not installed.
                Adapter "megadd"         is not installed.
                Adapter "megaesp"        is not installed.
                Adapter "melcloud"       is not installed.
                Adapter "mercedesme"     is not installed.
                Adapter "mercury"        is not installed.
                Adapter "meross"         is not installed.
                Adapter "meteoalarm"     is not installed.
                Adapter "midea"          is not installed.
                Adapter "miele"          is not installed.
                Adapter "mielecloudservice" is not installed.
                Adapter "mihome"         is up to date.
                Adapter "mihome-lamp"    is not installed.
                Adapter "mihome-plug"    is not installed.
                Adapter "mihome-vacuum"  is not installed.
                Adapter "mikrotik"       is not installed.
                Adapter "milight"        is not installed.
                Adapter "milight-smart-light" is not installed.
                Adapter "mobile"         is up to date.
                Adapter "modbus"         is not installed.
                Adapter "moma"           is not installed.
                Adapter "mpd"            is not installed.
                Adapter "mqtt"           is not installed.
                Adapter "mqtt-client"    is not installed.
                Adapter "musiccast"      is not installed.
                Adapter "mydlink"        is not installed.
                Adapter "mysensors"      is not installed.
                Adapter "nanoleaf-lightpanels" is not installed.
                Adapter "nello"          is not installed.
                Adapter "netatmo"        is not installed.
                Adapter "nibeuplink"     is not installed.
                Adapter "nina"           is not installed.
                Adapter "node-red"       is not installed.
                Adapter "nuki"           is not installed.
                Adapter "nuki-extended"  is not installed.
                Adapter "nut"            is not installed.
                Adapter "odl"            is not installed.
                Adapter "oilfox"         is not installed.
                Adapter "onkyo"          is not installed.
                Adapter "onvif"          is not installed.
                Adapter "openhab"        is not installed.
                Adapter "openligadb"     is not installed.
                Adapter "openweathermap" is not installed.
                Adapter "opi"            is not installed.
                Adapter "oppoplayer"     is not installed.
                Adapter "owfs"           is not installed.
                Adapter "owntracks"      is not installed.
                Adapter "panasonic-viera" is not installed.
                Adapter "parser"         is not installed.
                Adapter "paw"            is not installed.
                Adapter "phantomjs"      is not installed.
                Adapter "pi-hole"        is not installed.
                Adapter "piface"         is not installed.
                Adapter "pimatic"        is not installed.
                Adapter "ping"           is up to date.
                Adapter "places"         is not installed.
                Adapter "plex"           is not installed.
                Adapter "plexconnect"    is not installed.
                Adapter "pollenflug"     is not installed.
                Adapter "proxmox"        is not installed.
                Adapter "proxy"          is not installed.
                Adapter "pushbullet"     is not installed.
                Adapter "pushover"       is not installed.
                Adapter "pushsafer"      is not installed.
                Adapter "radar2"         is not installed.
                Adapter "radiohead"      is not installed.
                Adapter "rflink"         is not installed.
                Adapter "rickshaw"       is not installed.
                Adapter "ring"           is not installed.
                Adapter "robonect"       is not installed.
                Adapter "roomba"         is not installed.
                Adapter "rpi2"           is not installed.
                Adapter "s7"             is not installed.
                Adapter "samsung"        is not installed.
                Adapter "sayit"          is not installed.
                Adapter "sbfspot"        is not installed.
                Adapter "scenes"         is up to date.
                Adapter "schoolfree"     is not installed.
                Adapter "schwoerer-ventcube" is not installed.
                Adapter "shelly"         is not installed.
                Adapter "shuttercontrol" is not installed.
                Adapter "sia"            is not installed.
                Adapter "siegenia"       is not installed.
                Adapter "simple-api"     is up to date.
                Adapter "smappee"        is not installed.
                Adapter "smartgarden"    is not installed.
                Adapter "smartmeter"     is not installed.
                Adapter "snips"          is not installed.
                Adapter "snmp"           is not installed.
                Adapter "socketio"       is up to date.
                Adapter "solarlog"       is not installed.
                Adapter "solarviewdatareader" is not installed.
                Adapter "solarwetter"    is not installed.
                Adapter "sonnen"         is not installed.
                Adapter "sonoff"         is not installed.
                Adapter "sonos"          is not installed.
                Adapter "sony-bravia"    is not installed.
                Adapter "spotify-premium" is not installed.
                Adapter "sql"            is not installed.
                Adapter "squeezebox"     is not installed.
                Adapter "squeezeboxrpc"  is not installed.
                Adapter "starline"       is not installed.
                Adapter "statistics"     is not installed.
                Adapter "stiebel-isg"    is not installed.
                Adapter "sunnyportal"    is not installed.
                Adapter "swiss-weather-api" is not installed.
                Adapter "synology"       is not installed.
                Adapter "systeminfo"     is not installed.
                Adapter "tahoma"         is not installed.
                Adapter "tankerkoenig"   is not installed.
                Adapter "telegram"       is not installed.
                Adapter "terminal"       is not installed.
                Adapter "tesla-motors"   is not installed.
                Adapter "text2command"   is not installed.
                Adapter "tinker"         is not installed.
                Adapter "tr-064"         is not installed.
                Adapter "tradfri"        is not installed.
                Adapter "trashschedule"  is not installed.
                Adapter "tunnelbroker-endpoint-updater" is not installed.
                Adapter "tuya"           is not installed.
                Adapter "tvspielfilm"    is not installed.
                Adapter "unifi"          is not installed.
                Adapter "upnp"           is not installed.
                Adapter "vaillant"       is not installed.
                Adapter "valloxmv"       is not installed.
                Adapter "vcard"          is not installed.
                Adapter "velux"          is not installed.
                Adapter "viessmann"      is not installed.
                Adapter "virtualpowermeter" is not installed.
                Adapter "vis"            is up to date.
                Adapter "vis-bars"       is not installed.
                Adapter "vis-canvas-gauges" is not installed.
                Adapter "vis-colorpicker" is not installed.
                Adapter "vis-fancyswitch" is not installed.
                Adapter "vis-google-fonts" is not installed.
                Adapter "vis-history"    is not installed.
                Adapter "vis-hqwidgets"  is not installed.
                Adapter "vis-icontwo"    is not installed.
                Adapter "vis-inventwo"   is not installed.
                Adapter "vis-jqui-mfd"   is not installed.
                Adapter "vis-justgage"   is not installed.
                Adapter "vis-keyboard"   is not installed.
                Adapter "vis-lcars"      is not installed.
                Adapter "vis-map"        is not installed.
                Adapter "vis-material-advanced" is not installed.
                Adapter "vis-metro"      is not installed.
                Adapter "vis-players"    is not installed.
                Adapter "vis-plumb"      is not installed.
                Adapter "vis-rgraph"     is not installed.
                Adapter "vis-timeandweather" is not installed.
                Adapter "vis-weather"    is not installed.
                Adapter "vr200"          is not installed.
                Adapter "vw-connect"     is not installed.
                Adapter "weatherunderground" is not installed.
                Adapter "web"            is up to date.
                Adapter "weishaupt-wem"  is not installed.
                Adapter "wiffi-wz"       is not installed.
                Adapter "wifilight"      is not installed.
                Adapter "windows-control" is not installed.
                Adapter "wled"           is not installed.
                Adapter "wm-bus"         is not installed.
                Adapter "wolf"           is not installed.
                Adapter "worx"           is not installed.
                Adapter "xbox"           is not installed.
                Adapter "xs1"            is not installed.
                Adapter "yahka"          is not installed.
                Adapter "yamaha"         is not installed.
                Adapter "yeelight-2"     is up to date.
                Adapter "youtube"        is not installed.
                Adapter "yr"             is not installed.
                Adapter "zigbee"         is not installed.
                Adapter "zont"           is not installed.
                Adapter "zwave"          is not installed.
                Adapter "zwave2"         is not installed.
                pi@raspberrypi:~ $
                • B badplay
                  iobroker upgrade
                  3.1.6
                  update done
                  pi@raspberrypi:~ $
                  @badplay
                  So, müsste eigentlich laufen.
                  iobroker list adapters
                  iobroker list instances
                    @badplay
                    badplay
                    @Thomas-Braun aber 3.1.6 ist ja dennoch ausgegeben worden
                    pi@raspberrypi:~ $ iobroker list adapters
                    system.adapter.admin                   : admin          - v4.0.10
                    system.adapter.asuswrt                 : asuswrt        - v1.0.1
                    system.adapter.cloud                   : cloud          - v3.0.4
                    system.adapter.discovery               : discovery      - v2.3.7
                    system.adapter.harmony                 : harmony        - v1.2.2
                    system.adapter.history                 : history        - v1.9.10
                    system.adapter.info                    : info           - v1.7.2
                    system.adapter.javascript              : javascript     - v4.8.4
                    system.adapter.mihome                  : mihome         - v1.3.0
                    system.adapter.mobile                  : mobile         - v1.0.1
                    system.adapter.ping                    : ping           - v1.4.8
                    system.adapter.scenes                  : scenes         - v2.1.7
                    system.adapter.simple-api              : simple-api     - v2.4.6
                    system.adapter.socketio                : socketio       - v3.0.13
                    system.adapter.vis                     : vis            - v1.2.12
                    system.adapter.web                     : web            - v3.0.13
                    system.adapter.yeelight-2              : yeelight-2     - v1.0.3
                    pi@raspberrypi:~ $ iobroker list instances
                    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.asuswrt.0               : asuswrt               -  enabled
                    + system.adapter.cloud.0                 : cloud                 -  enabled
                    + system.adapter.discovery.0             : discovery             -  enabled
                    + system.adapter.harmony.0               : harmony               -  enabled
                    + system.adapter.history.0               : history               -  enabled
                    + system.adapter.info.0                  : info                  -  enabled
                    + system.adapter.javascript.0            : javascript            -  enabled
                      system.adapter.mobile.0                : mobile                -  enabled
                    + system.adapter.ping.0                  : ping                  -  enabled
                    + system.adapter.scenes.0                : scenes                -  enabled
                      system.adapter.vis.0                   : vis                   -  enabled
                    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.yeelight-2.0            : yeelight-2            -  enabled
                    + instance is alive
                    pi@raspberrypi:~ $
                    • B badplay
                      + instance is alive
                      pi@raspberrypi:~ $
                      @badplay
                      Alles tutti.
                        @badplay
                        Alles tutti.
                        badplay
                        @Thomas-Braun Dankeschön
                        Danke noch an alle
                        Nun heißt es wie bekomme ich die Sonoff und die anderen Lampen wieder rein, der Alexa Adapter scheint nicht zu funktionieren verbindung fehlt
                        Nun denn ich schau mal
                        • B badplay
                          Danke noch an alle
                          @badplay Andere Frage -> neuer Thread
