  4. Zigbee Adapter Problem nach Update
    6.7k
zigbee-adapter
66 Beiträge 6 Kommentatoren 8.5k Aufrufe 5 Beobachtet
    @DocGame sagte in Zigbee Adapter Problem nach Update:
    Ich wollte eine neue Zigbee-Adapter version üner die Katze installieren.
    Über git/"die Katze" updated man auch nicht!
    iobroker update
    iobroker upgrade
    iobroker install zigbee@1.2.1
    DocGame
    @Thomas-Braun
    Über die CL genau das gleiche:
    C:\iobroker_NUC\SHome>iobroker install zigbee@1.2.1
    NPM version: 6.14.6
    npm install iobroker.zigbee@1.2.1 --loglevel error (System call)
    gyp ERR! UNCAUGHT EXCEPTION
    gyp ERR! stack TypeError: tar.extract is not a function
    gyp ERR! stack     at Request.<anonymous> (C:\iobroker_NUC\SHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:199:22)
    gyp ERR! stack     at Request.emit (events.js:327:22)
    gyp ERR! stack     at Request.onRequestResponse (C:\iobroker_NUC\SHome\nodejs\node_modules\npm\node_modules\request\request.js:1066:10)
    gyp ERR! stack     at ClientRequest.emit (events.js:315:20)
    gyp ERR! stack     at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:596:27)
    gyp ERR! stack     at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)
    gyp ERR! stack     at TLSSocket.socketOnData (_http_client.js:469:22)
    gyp ERR! stack     at TLSSocket.emit (events.js:315:20)
    gyp ERR! stack     at addChunk (_stream_readable.js:295:12)
    gyp ERR! stack     at readableAddChunk (_stream_readable.js:271:9)
    gyp ERR! System Windows_NT 10.0.19041
    gyp ERR! command "C:\\iobroker_NUC\\SHome\\nodejs\\node.exe" "C:\\iobroker_NUC\\SHome\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\iobroker_NUC\SHome\node_modules\zigbee-herdsman\node_modules\@serialport\bindings
    gyp ERR! node -v v12.18.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! This is a bug in `node-gyp`.
    gyp ERR! Try to update node-gyp and file an Issue if it does not help:
    gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
    npm ERR! code ELIFECYCLE
    npm ERR! errno 7
    npm ERR! @serialport/bindings@9.0.2 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 7
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@9.0.2 install script.
    npm ERR!     C:\iobroker_NUC\SHome\env\npm-cache\_logs\2020-10-26T15_29_55_202Z-debug.log
    host.DESKTOP-24U17KH(SHome) Cannot install iobroker.zigbee@1.2.1: 7
    • D DocGame
      @Thomas-Braun
      NPM version: 6.14.6
      npm ERR! errno 7
      npm ERR!
      @DocGame
      In das Installationsverzeichnis wechseln (Keine Ahnung von Windows...)
      und den npm cache löschen:
      npm cache clear --force
      D 2 Antworten Letzte Antwort
      • D DocGame
        @Thomas-Braun
        NPM version: 6.14.6
        npm ERR! errno 7
        npm ERR!
        node -v v12.18.3
        Oben schreibst du node 10. Was denn nun?
          @DocGame
          DocGame
          schrieb am zuletzt editiert von DocGame
          @Thomas-Braun
          Die Info oben habe ich korrigiert...
          Leider kommt nach dem "npm cache clear --force" und dem
          "iobroker update
          iobroker upgrade
          iobroker install zigbee@1.2.1"
          genau das selbe.
          Hier der ausführiche log "C:\iobroker_NUC\SHome\env\npm-cache_logs\2020-10-26t15_34_18_692z-debug.log":
          2020-10-26T15_34_18_692Z-debug.log
            @DocGame
            DocGame
            @Thomas-Braun
            Fällt dir auch nichts mehr ein ?
            • D DocGame
              @Thomas-Braun
              DocGame
              Wie bekomme ich denn die alte Instasllation des Adapters komplett weg?
              Unter Adapter steht nicht installiert.
              In den Instanzen habe ich ihn gelöscht.
              Ordner zogbee.0 im iobroker-data verzeichnis gelöscht.
              zigbee.admin in files gelöscht.
              Es klappt trotzdem nicht mit der Adapter Neuinstallation.
              • D DocGame
                @DocGame
                iobroker del zigbee
                Von Hand fummelt man da nicht im Dateisystem herum.
                  @DocGame
                  iobroker del zigbee
                  DocGame
                  @Thomas-Braun sagte in Zigbee Adapter Problem nach Update:
                  iobroker del zigbee
                  ich bin verzweifelt....sonst hätte ich das nicht versucht. Hier hängt wirklich alles dran (Vielleicht auch ein Fehler....)
                  Hier der CL Log:
                  C:\iobroker_NUC\SHome>iobroker del zigbee
                  Delete adapter "zigbee"
                  host.DESKTOP-24U17KH(SHome) Counted 1 instances of zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 1 meta of zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 1 adapter for zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 35 devices of zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 1 channels of zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 365 states of zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 14 states of system.adapter.zigbee
                  host.DESKTOP-24U17KH(SHome) Counted 260 states (io.zigbee.*) from states
                  host.DESKTOP-24U17KH(SHome) Counted 12 states (system.adapter.zigbee.*) from states
                  host.DESKTOP-24U17KH(SHome) file zigbee.admin deleted
                  host.DESKTOP-24U17KH(SHome) object zigbee.admin deleted
                  host.DESKTOP-24U17KH(SHome) Deleting 418 object(s).
                  host.DESKTOP-24U17KH(SHome): Only 400 objects left to be deleted.
                   Cannot write files: C:\iobroker_NUC\SHome\iobroker-data\files\zigbee.admin\_data.json: ENOENT: no such file or directory, open 'C:\iobroker_NUC\SHome\iobroker-data\files\zigbee.admin\_data.json'
                  host.DESKTOP-24U17KH(SHome): Only 200 objects left to be deleted.
                  host.DESKTOP-24U17KH(SHome) Deleting 272 state(s).
                  host.DESKTOP-24U17KH(SHome): Only 200 states left to be deleted.
                  Error deleting adapter zigbee from disk: Error: Cannot find module 'iobroker.zigbee/io-package.json'
                  Require stack:
                  - C:\iobroker_NUC\SHome\node_modules\iobroker.js-controller\lib\setup\setupInstall.js
                  - C:\iobroker_NUC\SHome\node_modules\iobroker.js-controller\lib\setup.js
                  - C:\iobroker_NUC\SHome\node_modules\iobroker.js-controller\iobroker.js
                  You might have to delete it yourself!
                  und hier der neuinstallationsversuch:
                  $ ./iobroker add zigbee  --host DESKTOP-24U17KH(SHome)
                  NPM version: 6.14.6
                  gyp
                   ERR! UNCAUGHT EXCEPTION gyp ERR! stack
                   TypeError: tar.extract is not a functiongyp ERR! stack     at Request.<anonymous> (C:\iobroker_NUC\SHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:199:22)gyp ERR! stack     at Request.emit (events.js:327:22)gyp ERR! stack     at Request.onRequestResponse (C:\iobroker_NUC\SHome\nodejs\node_modules\npm\node_modules\request\request.js:1066:10)gyp ERR! stack     at ClientRequest.emit (events.js:315:20)gyp ERR! stack     at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:596:27)gyp ERR! stack     at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)gyp ERR! stack     at TLSSocket.socketOnData (_http_client.js:469:22)gyp ERR! stack     at TLSSocket.emit (events.js:315:20)gyp ERR! stack     at addChunk (_stream_readable.js:295:12)gyp ERR! stack     at readableAddChunk (_stream_readable.js:271:9)
                  gyp ERR! System Windows_NT 10.0.19041gyp ERR! command "C:\\iobroker_NUC\\SHome\\nodejs\\node.exe" "C:\\iobroker_NUC\\SHome\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\iobroker_NUC\SHome\node_modules\zigbee-herdsman\node_modules\@serialport\bindingsgyp ERR! node -v
                   v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! This is a bug in `node-gyp`.gyp ERR! Try to update node-gyp and file an Issue if it does not help:gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
                  npm
                   ERR! code ELIFECYCLEnpm ERR! errno 7
                  npm
                   ERR! @serialport/bindings@9.0.2 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 7npm ERR! npm ERR! Failed at the @serialport/bindings@9.0.2 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR! A complete log of this run can be found in:npm ERR!     C:\iobroker_NUC\SHome\env\npm-cache\_logs\2020-10-26T17_07_58_405Z-debug.log
                  ERROR: host.DESKTOP-24U17KH(SHome) Cannot install iobroker.zigbee@1.2.1: 7
                  Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                  • D DocGame
                    iobroker del zigbee
                    Hier der CL Log:
                    Require stack:
                    NPM version: 6.14.6
                    gyp
                    npm
                    npm
                    Ich bin raus, Windows ist mir auch zu fremd.
                    Google wirft das raus, ist allerdings Linux-lastig:
                    https://github.com/nodejs/node-gyp/issues/1871
                    I think this is normally a sign of mixed installs - one version is trying to use code from another - or an install that didn't properly overwrite an older install (there was a bug a while back with npm that caused this exact error because upgrading npm didn't wipe out older files and directories, leaving a jumbled mess).
                    Clean out your global npm installs, it's going to be /usr/local/lib/node_modules or /usr/lib/node_modules - npm config get prefix shows you the first part of this and it'll depend on how Node was installed on your machine. Just blow that whole directory away because you're going to reinstall anyway. There may be global commands you installed with npm install -g which will be dangling symlinks to subdirectories of that directory, look in the bin with the same root, so /usr/local/bin/ or /usr/bin and look for symlinks that have node_modules in them and get rid of them. If you care about the things you installed globall, take not of them so you can reinstall later.
                    Remove node, nodejs, npm, node-gyp from your system package manager (apt, dnf, yum, apk, etc.). Full purge, leave nothing, these cause too much chaos with the way npm handles dependencies.
                    Install Node from somewhere other than your package manager, I recommend using the NodeSource distributions: https://github.com/nodesource/distributions for servers but the Snap (maintained by me) https://snapcraft.io/node for development systems (I can't understate how nice it is to have the latest version of my chosen release line without asking for it on my dev machine). You could also take a more manual approach such as https://gist.github.com/rvagg/742f811be491a49ba0b9
                    • D DocGame
                      iobroker del zigbee
                      Hier der CL Log:
                      Require stack:
                      NPM version: 6.14.6
                      gyp
                      npm
                      npm
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @DocGame
                      Verifiziere doch bitte mal das genau eine nodejs und node version auf dem System vorhanden sind. Das gleiche mit npm.
                      Auch die Frage - führst du den Befehl wirklich in dem Verzeichnis aus, in dem sich zum ioBroker auch die node_modules befinden ?
                      A
                      • AsgothianA Asgothian
                        @DocGame
                        A
                        DocGame
                        @Asgothian
                        in meiner panik habe ich über den installer noch eine Instanz installiert wie kann ich die wieder löschen?
                          @DocGame
                          A
                          DocGame
                          @Asgothian
                          Erkennst du hierauf was?
                          In der Info steht folgendes:
                          Plattform: Windows
                          Betriebssystem: win32
                          Die Architektur: x64
                          CPUs: 6
                          Geschwindigkeit: 2208 MHz
                          Modell: Intel(R) Core(TM) i5-9500T CPU @ 2.20GHz
                          RAM: 7.8 GB
                          System-Betriebszeit: 00:00:00
                          Node.js: v12.18.3
                          NPM: 6.14.8
                          Adapter-Anzahl: 308
                          Datenträgergröße: 237.5 GiB
                          Datenträger verfügbar: 155.6 GiB
                          Betriebszeit: 00:07:22
                          Aktive Instanzen: 36
                          Alle Anderen Adapter sind grün.
                          Wo finde ich Infos zu Node?
                          • D DocGame
                            @Asgothian
                            Plattform: Windows
                            CPUs: 6
                            RAM: 7.8 GB
                            Node.js: v12.18.3
                            NPM: 6.14.8
                            Adapter-Anzahl: 308
                            DocGame
                            Wenn ich ein Backup einspiele(Iobroker und Zigbee) ist zwar die Instanz da (rot) aber unter Adapter steht keine installierte Instanz.
                            AsgothianA D 2 Antworten Letzte Antwort
                            • D DocGame
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @DocGame such doch mal nach node.exe. (ich bin kein Windows Experte.. sorry)
                              was genau hast du ein 2. mal installiert ? node oder nen iobroker ?
                              A
                              • D DocGame
                                DocGame
                                den iobroker über den Windowsinstaller. Aber erst vorhin, das wird nichts mit dem Problem zu tun haben. Will die Neue später nur wieder loswerden.
                                Ich habe woanders gelesen, dass ich node-gyp installieren soll.
                                Dann kommt folgende Meldung:
                                C:\iobroker_NUC\SHome>npm install -g node-gyp
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                C:\iobroker_NUC\SHome\env\npm\node-gyp -> C:\iobroker_NUC\SHome\env\npm\node_modules\node-gyp\bin\node-gyp.js
                                + node-gyp@7.1.2
                                added 96 packages from 66 contributors in 6.297s
                                • D DocGame
                                  + node-gyp@7.1.2
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @DocGame hast du ein Backup der Konfiguration und der Skripte ?
                                    DocGame
                                    @Asgothian
                                    Ja sowohl über den Backup-Adapter, als auch das exportieren der Scripts und das sichern des iobroker-data Verzeichnisses
                                    • D DocGame
                                      @Asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @DocGame Windows 10 ? Dann installier dir doch mal nach der Anleitung die hier ist einen Docker container mit iobroker. Der läuft unabhängig von dem was du bei Windows installiert hast.
                                      https://github.com/buanet/docker-iobroker
                                      dann kannst du erst einmal den/die installierten iobroker stoppen, zur Not über den Taskmanager, und schaust ob du das ganze im Docker zum Laufen bekommst. Wenn es läuft kannst du das im Windows installierte loeschen und dann schauen ob du mit dem Docker Zeugs weiter machen willst oder nochmal nativ unter Windows installierst.
                                      A.
                                        A.
                                        DocGame
                                        @Asgothian Oh je... auf die schnelle blick ich das nicht.
                                        Zu allem Unglück ist jetzt gerade meine Frau gekommen und steht schreiend im dunkeln Flur.
                                        Muss mal Kerzen suchen und sie beruhigen. Vielleicht kommt ja noch ein Tip (der entscheidende und hoffentlich einfache) bis ich wieder vor dem PC sitze.
                                        • D DocGame
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          @DocGame ich schau mal ob ich eine step by step Anleitung zur Installation finde. Es gibt eine.
                                          A.
