  4. Kann keinen Adapter installieren
    6.8k
adapternodenpmerror
29 Beiträge 7 Kommentatoren 4.8k Aufrufe 5 Beobachtet
  • Gurke258G Gurke258
    @Homoran sagte in Kann keinen Adapter installieren:
    Das von dir installierte Modul
    Blink converts Node.js modules into CSS and provides a CSS Authoring Framework, with BEM support.
    Wie kann ich das wieder deistallieren?
    Edit:
    Wenn ich es Deinstallieren will, kommt folgende Meldung:
    pi@HomePi:~ $ npm uninstall blink
    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    audited 72 packages in 2.931s
    2 packages are looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    @Gurke258
    Du steht im falschen Verzeichnis.
    iobroker del blink
    oder
    cd /opt/iobroker
    npm uninstall blink
    Gurke258G 1 Antwort Letzte Antwort
      @Gurke258
      iobroker del blink
      oder
      cd /opt/iobroker
      npm uninstall blink
      Gurke258G Offline
      Gurke258G Offline
      Gurke258
      @Thomas-Braun sagte in Kann keinen Adapter installieren:
      npm uninstall blink
      Da bekomme ich folgende Fehlermeldung:
      pi@HomePi:/opt/iobroker $ iobroker del blink
      Delete adapter "blink"
      Error deleting adapter blink from disk: Error: Cannot find module 'iobroker.blink/io-package.json'
      Require stack:
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
      You might have to delete it yourself!
      pi@HomePi:/opt/iobroker $ npm uninstall blink
      npm ERR! code ELOOP
      npm ERR! syscall open
      npm ERR! path /opt/iobroker/node_modules/iobroker.daswetter/npm-shrinkwrap.json
      npm ERR! errno -40
      npm ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/iobroker.daswetter/npm-shrinkwrap.json'
      npm ERR!     /home/iobroker/.npm/_logs/2020-10-22T18_25_07_907Z-debug.log
      Ich habe auch schon alle neu initiallisiert mit Tipps aus diesem Thread:
      https://forum.iobroker.net/topic/19897/node-js-update-ohne-adapter-neu-zu-installieren/17
      scheint aber auch nichts gebracht zu haben
        npm uninstall blink
        Require stack:
        npm ERR! code ELOOP
        npm ERR! errno -40
        Gurke258G Offline
        Gurke258G Offline
        Gurke258
        schrieb am zuletzt editiert von Gurke258
        Kann mir denn niemand helfen?
        Habe alles kontrolliert nach diesem thread (https://forum.iobroker.net/topic/33791/kein-update-von-adapter-möglich/3), aber da war alles in Ordnung.
          Jan1
          @Gurke258
          mach mal das:
          nodejs -v && node -v && npm -v
          which nodejs && which node && which npm
          und poste das Ergebnis
          • J Jan1
            @Gurke258
            mach mal das:
            Gurke258G Offline
            Gurke258G Offline
            Gurke258
            @Jan1
            pi@HomePi:/opt/iobroker $ nodejs -v && node -v && npm -v
            v12.19.0
            v12.19.0
            6.14.8
            pi@HomePi:/opt/iobroker $ which nodejs && which node && which npm
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
              @Jan1
              v12.19.0
              v12.19.0
              6.14.8
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              Jan1
              @Gurke258
              Das sieht schon mal sauber aus.
              • J Jan1
                @Gurke258
                Gurke258G Offline
                Gurke258G Offline
                Gurke258
                @Jan1
                Ja deswegen wundert es mich ja das es nicht geht
                • wendy2702W Offline
                  wendy2702W Offline
                  Mal mit Node 10 versucht?
                  • wendy2702W wendy2702
                    Gurke258G Offline
                    Gurke258G Offline
                    Gurke258
                    @wendy2702
                    nee noch nicht, aber das ändert doch nichts daran, das ich das beschriebene Modul (Blink@5.0.1) nicht finde bzw. nicht deinstallieren kann?
                      @wendy2702
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Gurke258
                      lösche mal das Verzeichniss
                      /opt/iobroker/node_modules/iobroker.javascript/node_modules/blink
                      • GlasfaserG Glasfaser
                        @Gurke258
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @Glasfaser Einfach so in node_modules was löschen macht keinen Sinn. Das kommt mit dem nächsten Update wieder.
                        cd /opt/iobroker
                        npm ls blink
                        um herauszufinden, wo es mit drin hängt. Dann kann man gezielt im übergeordneten Verzeichnis npm uninstall blink aufrufen. Oder im Falle des Skript-Adapters, es aus den zusätzlichen Modulen entfernen.
                        HomoranH GlasfaserG Gurke258G 3 Antworten Letzte Antwort
                        • AlCalzoneA AlCalzone
                          cd /opt/iobroker
                          npm ls blink
                          @AlCalzone sagte in Kann keinen Adapter installieren:
                          Das ist wichtig, da wir bis heute nicht wissen wie und wo blink installiert wurde
                            cd /opt/iobroker
                            npm ls blink
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @AlCalzone
                            wurde ja alles schon im Thread gemacht ... gelöscht usw....
                            dann habe ich diesen Vorschlag von Apollon77 gelesen ,
                            https://github.com/ioBroker/ioBroker.javascript/issues/617
                              @AlCalzone
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @Glasfaser sagte in Kann keinen Adapter installieren:
                              Ja ne, eben nicht!
                              Ich sehe
                              • einmal npm uninstall blink im Home-Verzeichnis (wo iobroker sicher keine Module sucht).
                              • einmal iobroker del blink, was den nicht existenten blink-Adapter löschen würde (wenn es ihn denn gäbe)
                              Wie ich in meinem letzten Post geschrieben habe: erst mal herausfinden, wo genau das Modul herkommt. Dann kann man über weitere Schritte wie gezieltes Deinstallieren nachdenken. npm uninstall <paketname> wirkt nämlich immer nur im aktuellen Verzeichnis, nicht in Unterverzeichnissen.
                                cd /opt/iobroker
                                npm ls blink
                                Gurke258G Offline
                                Gurke258G Offline
                                Gurke258
                                @AlCalzone
                                Also mit diesem Befehl bekomme ich folgende Meldung:
                                pi@HomePi:/opt/iobroker $ npm ls blink
                                iobroker.inst@2.0.3 /opt/iobroker
                                └─┬ iobroker.javascript@4.8.4
                                  └── UNMET DEPENDENCY blink@^5.0.1
                                npm ERR! missing: blink@^5.0.1, required by iobroker.javascript@4.8.4
                                @AlCalzone
                                Das hatte ich auch schon gefunden und gemacht.
                                  @AlCalzone
                                  @AlCalzone
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  @Gurke258 Hast du blink in den Adaptereinstellungen des Skript-Adapters eingetragen? 38e2e1a4-3bcc-47e0-af2b-7feafaa2c2b7-grafik.png
                                  Falls ja, entfernen und folgendes ausführen:
                                  cd /opt/iobroker/node_modules/iobroker.javascript
                                  npm uninstall blink
                                  Wenn das nicht hinhaut, hilft ggf. die Holzhammermethode:
                                  /opt/iobroker/node_modules/iobroker.javascript/package.json mit einem Editor öffnen und die Zeile "blink": "^5.0.1", löschen.
                                    npm uninstall blink
                                    Gurke258G Offline
                                    Gurke258G Offline
                                    Gurke258
                                    @AlCalzone
                                    Der Fehler scheint behoben zu sein, es war tatsächlich in in Javascripts eingetragen. Habe es gelöscht.
                                    Allerdings kann ich immer noch keine Adapter installieren:
                                    $ ./iobroker add daswetter  --host HomePi
                                    NPM version: 6.14.8
                                    npm install iobroker.daswetter@3.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
                                    npm
                                     ERR! code ELOOPnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.daswetternpm ERR! errno -40
                                    npm ERR! ELOOP: too many symbolic links encountered, access '/opt/iobroker/node_modules/iobroker.daswetter'
                                    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-10-26T17_42_22_564Z-debug.log
                                    ERROR: host.HomePi Cannot install iobroker.daswetter@3.0.4: 216
                                      @AlCalzone
                                      NPM version: 6.14.8
                                      npm
                                      @Gurke258 sagte in Kann keinen Adapter installieren:
                                      code ELOOP
                                      npm -v
                                      which npm
                                        code ELOOP
                                        npm -v
                                        which npm
                                        Gurke258G Offline
                                        Gurke258G Offline
                                        Gurke258
                                        which npm
                                        pi@HomePi:~ $ npm -v
                                        6.14.8
                                        pi@HomePi:~ $ which npm
                                        /usr/bin/npm
                                          which npm
                                          6.14.8
                                          /usr/bin/npm
                                          @Gurke258
                                          Okay.
                                          Die ganze Nummer bitte:
                                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                          Der Fehler kommt zustande, wenn Pakete/Module in falschen Verzeichnissen installiert werden. Passiert i.d.R. wenn da manuell was gemacht wird. Ich vermute, du hast da irgendwas doppelt installiert. Vielleicht global oder im ~ und im iobroker.
