  4. JavaScript
  5. (gelöst) mehrere DP toggeln
javascript
6 Beiträge 3 Kommentatoren 572 Aufrufe 2 Beobachtet
  • ice987I Offline
    ice987I Offline
    ice987
    schrieb am zuletzt editiert von ice987
    aktuell setzte ich das Widget "materialdesign - Icon List" ein um Farben in einer Tabelle wählen zu können. Jede Farbe darf nur einmal vorkommen, d.h. wenn ein Button gedrückt wird (true) sollen alle anderen Farben (Button) auf "false" springen:
    Widget-Export
    [{"tpl":"tplVis-materialdesign-Icon-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","wrapItems":"true","vibrateOnMobilDevices":"","listLayout":"standard","itemLayout":"vertical","buttonLayout":"full","listItemDataMethod":"inputPerEditor","countListItems":"3","listType0":"buttonToggle","showValueLabel0":false,"listType1":"buttonToggle","showValueLabel1":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"maxItemsperRow":"5","itemGaps":"2","labelFontSize":"10","labelFontFamily":"Arial, Helvetica, sans-serif","labelFontColor":"#ffffff","g_listItemCardBackground":false,"titleLayout":"headline6","g_lock":false,"autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockFilterGrayscale":"30","lockApplyOnlyOnImage":"true","listType2":"text","showValueLabel2":"true","listType3":"text","showValueLabel3":false,"oid0":"0_userdate.0.farbe.gelb","typeButtonToggleValueTrue0":"true","typeButtonToggleValueFalse0":"false","itemBackgroundColor0":"#f59c00","label0":"gelb","listImage0":"check","listImageColor0":"#f59c00","listImageActive0":"check","listImageActiveColor0":"#ff0000","oid1":"0_userdate.0.farbe.orange","typeButtonToggleValueTrue1":"true","typeButtonToggleValueFalse1":"false","label1":"orange","listImage1":"check","listImageActive1":"check","listImageActiveColor1":"#ff0000","listImageActive2":"check","listImageActiveColor2":"#ff0000","typeButtonToggleValueTrue2":"true","typeButtonToggleValueFalse2":"false","label2":"pink","listImageActive3":"check","listImageActiveColor3":"#ff0000","typeButtonToggleValueTrue3":"true","typeButtonToggleValueFalse3":"false","buttonBgColor1":"","listImageColor1":"#ff6600","itemBackgroundColor1":"#ff6600","itemBackgroundColor2":"#e4a7a6","listImageColor2":"#e4a7a6","listImage2":"check","itemBackgroundColor3":"#03933e","label3":"grün","listImage3":"check","listImageColor3":"#03933e","oid2":"0_userdate.0.farbe.pink","oid3":"0_userdate.0.farbe.gruen"},"style":{"left":"52px","top":"341px","width":"275px","height":"55px","z-index":"1"},"widgetSet":"materialdesign"}]
    als JS-Script habe ich das nun bisher sehr umständlich umgesetzt:
    on({id: "0_userdata.0.farbe.gelb", val: true}, function (obj) {
        setState("0_userdata.0.farbe.orange", false);
        setState("0_userdata.0.farbe.pink", false);
        setState("0_userdata.0.farbe.gruen", false);
    on({id: "0_userdata.0.farbe.orange", val: true}, function (obj) {
        setState("0_userdata.0.farbe.gelb", false);
    on({id: "0_userdata.0.farbe.pink", val: true}, function (obj) {
    on({id: "0_userdata.0.farbe.gruen", val: true}, function (obj) {
    welches ist die eleganteste Lösung um dies einfacher zu gestalten? Evtl. hat jemand einen guten Input/Denkanstoss?
    husqvarna-automower, meteoblue, wiserbyfeller, spritmonitor
    • ice987I ice987
      Widget-Export
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @ice987
      Zumindest ein Denkanstoß, mehr ggf. Später, bin gerade unterwegs.
      Ein Array mit allen gewünschten Datenpunkten definieren.
      Ein trigger auf alle dp‘s, mit change:“gt“ um nur den Wechsel false->true zu fangen.
      In der Funktion durch das Array durch gehen. Wenn Eintrag gleich dem Objekt welches den trigger ausgelöst hat nix tun, sonst value auf True setzen.
      • AsgothianA Asgothian
        @ice987
        @Asgothian sagte:
        Etwa so:
        const ids = [
        on({id: ids, change: 'gt'}, function (dp) {
            for(let i = 0; i < ids.length; i++) {
                if(dp.id != ids[i]) setState(ids[i], false, true);
        AsgothianA ice987I 2 Antworten Letzte Antwort
          @Asgothian sagte:
          Etwa so:
          const ids = [
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @paul53 sagte in mehrere DP toggeln:
          Etwa so:
          genau so. Danke @paul53
          A.
            @Asgothian sagte:
            Etwa so:
            const ids = [
            ice987I Offline
            ice987I Offline
            ice987
            @Asgothian
            Vielen Dank für eure Unterstützung!
            zu meinem Verständnis (kopieren kann ja jeder):
            Es wird ein Array generiert mit dem Namen ids, welches alle DP's beinhaltet. Der Inhalt dieses Arrays dient als Wert für den Trigger. Change: 'gt' (gem. Definition: "(greater) New value must be greater than old value (state.val > oldState.val)"): ist somit "true" grösser als "false". Der auslösende DP wird der Funktion mit "dp" übergeben. In der Schlaufe "for" wird bei jedem Element des Arrays geprüft ob der Arrayeintrag dem Auslöser entspricht. Wenn nein dann "setState vom jeweiligen Element auf "false" sonst "true".
            • ice987I ice987
              @Asgothian
              @ice987 sagte:
              Richtig: Wenn nein dann "setState vom jeweiligen Element auf "false", der auslösende Datenpunkt bleibt "true" (wird nicht verändert).
              Ansonsten alles richtig interpretiert.
