  4. Fire TV Adapter
Fire TV Adapter
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
181 Beiträge 41 Kommentatoren 68.6k Aufrufe 29 Beobachtet
  • H Offline
    Hardwearhansi
    schrieb am zuletzt editiert von Hardwearhansi
    #121
    So hab mich jetzt duch alle anleitungen durch gewätlzt und es kommt denoch immer diese Fehler meldungen:
    020-06-08 00:26:35.173	error	(22724) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.firetv/node_modules/soef/soef.js:1006:20) at Object.options.ready (/opt/i
    firetv.0	2020-06-08 00:26:35.170	error	(22724) unhandled promise rejection: Cannot read property 'getState' of undefined
    firetv.0	2020-06-08 00:26:35.169	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    firetv.0	2020-06-08 00:26:35.138	info	(22724) starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.firetv, node: v10.16.3, js-controller: 3.1.4
    host.raspberrypi	2020-06-08 00:26:33.101	info	instance system.adapter.firetv.0 started with pid 22724
    host.raspberrypi	2020-06-08 00:26:32.959	info	Restart adapter system.adapter.firetv.0 because enabled
    host.raspberrypi	2020-06-08 00:26:32.959	info	instance system.adapter.firetv.0 terminated with code 0 (NO_ERROR)
    firetv.0	2020-06-08 00:26:32.430	info	(22554) Terminated (NO_ERROR): Without reason
    firetv.0	2020-06-08 00:26:32.428	info	(22554) terminating
    firetv.0	2020-06-08 00:26:32.366	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    firetv.0	2020-06-08 00:26:32.366	error	at promiseReadSecret.then.then (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8147:76)
    firetv.0	2020-06-08 00:26:32.366	error	at Object.options.ready (/opt/iobroker/node_modules/iobroker.firetv/node_modules/soef/soef.js:1131:13)
    firetv.0	2020-06-08 00:26:32.366	error	at checkIfUpdated (/opt/iobroker/node_modules/iobroker.firetv/node_modules/soef/soef.js:1006:20)
    firetv.0	2020-06-08 00:26:32.366	error	(22554) TypeError: Cannot read property 'getState' of undefined
    firetv.0	2020-06-08 00:26:32.363	error	(22554) unhandled promise rejection: Cannot read property 'getState' of undefined
    Unhandled	2020-06-08 00:26:32.362	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    firetv.0	2020-06-08 00:26:32.323	info	(22554) starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.firetv, node: v10.16.3, js-controller: 3.1.4
    Ich hoffe mir kann hier wär helfen verzweilfle hier schon seit 3 Tagen
    • H Hardwearhansi
      #122
      @Hardwearhansi firetv 1.0.0 installieren.
      H 1 Antwort Letzte Antwort
        Hardwearhansi
        #123
        @Thomas-Braun said in Fire TV Adapter:
        firetv 1.0.0
        Danke, siehe da Version 1.0.0 von "https://github.com/iobroker-community-adapters/ioBroker.firetv" instaliert und adapter wird Grün .
        • J Offline
          jwerlsdf
          #124
          ich konnte den Adapter erfolgreich installieren. Jetzt habe ich aber eine prinzipielle Frage: Wie kann ich nun die Befehle benutzen?! Bei mir steht überall false. Wenn ich per Telegram den Befehl auf true ändere, passiert nichts. Kann mir da jemand weiterhelfen, wie ich nun z.B. den FireTV-Stick aus oder an schalte?! Vielen Dank im Voraus.
          Stephan SchleichS ? 2 Antworten Letzte Antwort
          • J jwerlsdf
            Stephan SchleichS Offline
            Stephan Schleich
            #125
            @all hat von euch auch jemand das Problem das sich die ADB Dienste am FireTv Stick nach 1-3 Tagen aufhängen?
            Er verliert die verbundenen devices und ein adb kill-server etc bringt nix, ich kann keine devices mehr connecten muss erst am FireTv Stick die ADB diesnte de- und wieder aktivieren
            • J jwerlsdf
              #126
              @jwerlsdf ist der Stick noch mit adb verbunden?
              • Stephan SchleichS Stephan Schleich
                #127
                @Stephan-Schleich ja, das problem hab ich auch.. obs an den Sticks liegt oder am Adapter.. keine Ahnung..
                Stephan SchleichS 1 Antwort Letzte Antwort
                  Stephan Schleich
                  #128
                  @ilovegym liegt leider am stick und find keine lösung dazu
                    jwerlsdf
                    schrieb am zuletzt editiert von jwerlsdf
                    #129
                    @ilovegym
                    blöde Frage: Wie sehe ich das?
                    Der Adapter ist bei mir aber noch auf grün!
                    Habe mir noch die Einträge angeschaut. Alles steht auf false. Nur bei online steht der Wert auf true.
                    bei error wird folgender Text angezeigt:
                    Failure: 'device unauthorized.This adb server's $ADB_VENDOR_KEYS is not setTry 'adb kill-server' if that seems wrong.Otherwise check for a confirmation dialog on your device.'
                    • J jwerlsdf
                      @ilovegym
                      #130
                      @jwerlsdf in der console mit adb devices oder adb connect ip bekommst du den status.
                      Wenn er nicht autorisiert ist, dann schalte den TV ein, starte den FireTV adapter nochmal, dann sollte vom FireTV eine Anfrage zu sehen sein, die du genehmigen musst ( am besten "immer" anklicken, sonst kommt die Anfrage dauernd).
                        jwerlsdf
                        #131
                        @ilovegym
                        folgendes wird jeweils angezeigt:
                        pi@raspberrypi:~ $ adb devices
                        List of devices attached
                        192.168.178.25:5555 device
                        pi@raspberrypi:~ $ adb connect 192.168.178.25
                        already connected to 192.168.178.25:5555
                        • J jwerlsdf
                          @ilovegym
                          Stephan Schleich
                          schrieb am zuletzt editiert von Stephan Schleich
                          #132
                          @jwerlsdf dann passts, dann kannst du ihn via adb steuern
                            jwerlsdf
                            #133
                            @Stephan-Schleich
                            wie geht das denn genau? Ich dachte, das geht einfach über die entsprechenden Einträge im iobroker bei Objekte durch true/false?!
                            • J jwerlsdf
                              @Stephan-Schleich
                              danny_v1
                              #134
                              Hi hab auch Probleme mit dem Adapter. Adapter ist grün adb connect 192.168.178.xxx sagt connected to ...
                              aber alle Wert in den Objekten stehen auf false und im error DP steht "Failure device: 192.168.178.xxx:5555 not found
                              • J Offline
                                jwerlsdf
                                #135
                                Habe es nun tw. hinbekommen. Durch Neustarts des Adapters/ FireTV-Sticks konnte nun eine Verbindung herstellen.
                                Die keys gehen nun (left, right, etc.) per Telegram mit "steuere mit True". danach sind sie aber bei Objekte mit True rot hinterlegt.
                                Bei folgende Befehle habe ich jedoch keine Ahnung, wie ich das stellen soll: On/ off, Text
                                Weiterhin taucht bei mir folgendes Problem auf: Der Adapter hängt sich auf oder ADB?! Ich muss einen restart des Adapters machen, dann geht dieser wieder
                                Fehler: Failure: 'device unauthorized.This adb server's $ADB_VENDOR_KEYS is not setTry 'adb kill-server' if that seems wrong.Otherwise check for a confirmation dialog on your device.'
                                Beim Stick wurde jedoch die Erlaubnis dauerhaft erteilt.
                                • J jwerlsdf
                                  #136
                                  @jwerlsdf sagte in Fire TV Adapter:
                                  Versuch mal
                                  sudo -u iobroker rm /home/iobroker/.android/adbkey*
                                  Und dann nochmal neu einrichten.
                                    Versuch mal
                                    JoergH
                                    #137
                                    ich habe den Adapter installiert, das adb Paket installiert, adb im FireTV aktiviert, rebootet, den Pfad im Adapter angegeben und der Adapter zeigt auch grün an und das Logfile zeigt auch im Silly Mode keine Fehler an, findet jedoch mein FireTV partout nicht wenn ich auf "Geräte suchen" klicke. Das FireTV kann ich in meiner Fritz!Box allerdings ohne Probleme sehen...?
                                    Hat einer eine Idee?
                                    • J JoergH
                                      #138
                                      @joergh
                                      Log file?
                                        @joergh
                                        Log file?
                                        JoergH
                                        #139
                                        • J JoergH
                                          JoergH
                                          #140
                                          @joergh ...und hier noch der Adapter....
                                          Er findet kein FireTV, obwohl ich zwei Stück im Netz habe.
                                          Manuell lässt sich das adb aber mit dem FireTV verbinden...
