  4. Zigbee 1.2.1 pairing geht nicht mehr
    6.8k
zigbee adapterkein pairing
89 Beiträge 8 Kommentatoren 11.3k Aufrufe 7 Beobachtet
  • V vikk88
    @arteck hi, ich habe heute Mittag noch zwei Steckdosen gepairt und bis jetzt läuft alles. Was merkwürdig ist das er im Log anzeigt, dass er manche Geräte nicht finden kann, sie aber da sind und auch schalten
    zigbee.0	2020-09-16 20:58:18.761	debug	(30302) Non-pingable device 0x00158d000422fd64 lumi.sensor_magnet.aq2 was last seen '486.441' seconds ago.
    zigbee.0	2020-09-16 20:58:18.758	debug	(30302) Non-pingable device 0x00158d0002ec019c lumi.sensor_motion.aq2 was last seen '648.092' seconds ago.
    zigbee.0	2020-09-16 20:58:18.754	debug	(30302) Non-pingable device 0x00158d0002ec7bcd lumi.sensor_motion.aq2 was last seen '536.592' seconds ago.
    zigbee.0	2020-09-16 20:58:18.752	debug	(30302) Non-pingable device 0x00158d0002e34b45 lumi.sensor_motion.aq2 was last seen '943.121' seconds ago.
    zigbee.0	2020-09-16 20:58:18.751	debug	(30302) Non-pingable device 0x00158d000316d4e3 lumi.sensor_magnet.aq2 was last seen '661.32' seconds ago.
    zigbee.0	2020-09-16 20:58:18.749	debug	(30302) Non-pingable device 0x00158d0002ec33ea lumi.sensor_motion.aq2 was last seen '532.057' seconds ago.
    zigbee.0	2020-09-16 20:58:18.746	debug	(30302) Non-pingable device 0x00158d000257a747 lumi.sensor_motion.aq2 was last seen '3275.575' seconds ago.
    zigbee.0	2020-09-16 20:58:18.745	debug	(30302) Non-pingable device 0xbc33acfffe54e5d9 TS0601 was last seen '257.157' seconds ago.
    zigbee.0	2020-09-16 20:58:18.744	debug	(30302) Non-pingable device 0x00158d0002733ec0 lumi.weather was last seen '519.773' seconds ago.
    zigbee.0	2020-09-16 20:58:18.742	debug	(30302) Non-pingable device 0x00158d00025d8cad lumi.weather was last seen '120.98' seconds ago.
    zigbee.0	2020-09-16 20:58:18.741	debug	(30302) Non-pingable device 0x00158d0002733e82 lumi.weather was last seen '167.943' seconds ago.
    zigbee.0	2020-09-16 20:58:18.739	debug	(30302) Non-pingable device 0x00158d00025d8bab lumi.weather was last seen '1.803' seconds ago.
    zigbee.0	2020-09-16 20:58:18.738	debug	(30302) Non-pingable device 0x00158d0002ca0270 lumi.weather was last seen '168.381' seconds ago.
    zigbee.0	2020-09-16 20:58:18.736	debug	(30302) Non-pingable device 0x00158d0002c12721 lumi.weather was last seen '467.728' seconds ago.
    zigbee.0	2020-09-16 20:58:18.735	debug	(30302) Non-pingable device 0x04cf8cdf3c7b5e0b lumi.sen_ill.mgl01 was last seen '623.925' seconds ago.
    Ich werde mal weiter beobachten, spätestens morgen früh müsste ich eigentlich die bekannten Probleme kriegen
    N Offline
    N Offline
    nachon
    @vikk88 Ich klinke mich hier mal mit ein, da ich aktuell ebenfalls ein Problem habe und auch die besagte Smart-Plug-Steckdose nutze. Meine habe ich zwar gepairt gelassen, aber mal vom Netz genommen. Die Osram Plugs sind weiterhin im Netz. Mal sehen, ob es sich damit stabilisert.
    V 1 Antwort Letzte Antwort
    • N nachon
      V Offline
      V Offline
      vikk88
      @nachon Ich habe jetzt noch zwei Stück gepairt und habe jetzt 5 Stück am laufen. Momentan läuft auch alles stabil. Warum das so ist weiß ich aber auch nicht, werde es mal weiter beobachten
      N 1 Antwort Letzte Antwort
      • V vikk88
        N Offline
        N Offline
        nachon
        @vikk88 Moin. Also ich habe den Smart Plug noch immer getrennt, dennoch einige Probleme seit dem Update auf Zigbee Adapter 1.2.1. Anbei habe ich weiter recherchiert und folgenden Thread entdeckt:
        https://github.com/ioBroker/ioBroker.zigbee/issues/731
        Hier wird über ähnliche Probleme berichtet.
        • N nachon
          V Offline
          V Offline
          vikk88
          @nachon Ich habe jetzt das Problem, das mein smart plug und meine Osram Leuchte sich ständig resetten. Sie heißen dann beide so wie am Anfang, die Namen die ich vergeben habe sind dann auch weg. Dies hat zur Folge das sich viel Sensoren trennen und auch nicht wieder verbinden.
          Ich habe das Gefühl das es an der der 1.2.1 liegt. Vorher hatte ich solche Probleme nicht. Nur komme ich nicht zurück auf die 1.1.3.
          Im Log steht auch kein Error:
          zigbee.0	2020-09-27 08:10:18.350	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:10:17.950	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
          zigbee.0	2020-09-27 08:10:17.949	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:10:17.948	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
          zigbee.0	2020-09-27 08:10:17.946	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
          zigbee.0	2020-09-27 08:10:17.944	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:10:17.937	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601187017930,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:10:16.038	debug	(21904) Publish {"power":3,"current":0.01,"voltage":233}
          zigbee.0	2020-09-27 08:10:16.010	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
          zigbee.0	2020-09-27 08:10:16.008	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":3}' from endpoint 1 with groupI
          zigbee.0	2020-09-27 08:10:16.006	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
          zigbee.0	2020-09-27 08:10:08.329	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:10:07.970	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
          zigbee.0	2020-09-27 08:10:07.969	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:10:07.968	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
          zigbee.0	2020-09-27 08:10:07.967	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
          zigbee.0	2020-09-27 08:10:07.963	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:10:07.958	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601187007952,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:10:06.034	debug	(21904) Publish {"power":1,"current":0.01,"voltage":233}
          zigbee.0	2020-09-27 08:10:06.008	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
          zigbee.0	2020-09-27 08:10:06.006	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":1}' from endpoint 1 with groupI
          zigbee.0	2020-09-27 08:10:06.004	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
          zigbee.0	2020-09-27 08:09:58.430	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:09:57.944	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
          zigbee.0	2020-09-27 08:09:57.943	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:09:57.942	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
          zigbee.0	2020-09-27 08:09:57.940	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
          zigbee.0	2020-09-27 08:09:57.939	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:09:57.932	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186997926,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:09:56.038	debug	(21904) Publish {"power":1,"current":0.01,"voltage":233}
          zigbee.0	2020-09-27 08:09:56.014	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
          zigbee.0	2020-09-27 08:09:56.013	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":1}' from endpoint 1 with groupI
          zigbee.0	2020-09-27 08:09:56.011	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
          zigbee.0	2020-09-27 08:09:51.802	debug	(21904) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
          zigbee.0	2020-09-27 08:09:51.802	debug	(21904) getMap result: {"lqis":[{"parent":"0x00124b001936a117","networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","lqi":35,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a1
          zigbee.0	2020-09-27 08:09:51.801	debug	(21904) Get map succeeded [{"parent":"0x00124b001936a117","networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","lqi":35,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a117","
          zigbee.0	2020-09-27 08:09:51.800	debug	(21904) Routing table succeeded for '0x842e14fffe51c5c4'
          zigbee.0	2020-09-27 08:09:51.799	debug	(21904) Routing for '0x842e14fffe51c5c4': {"table":[{"destinationAddress":0,"nextHop":63333},{"destinationAddress":6332,"status":"ACTIVE","nextHop":6332},{"destinationAddress":59922,"status":"ACTIVE",
          zigbee.0	2020-09-27 08:09:51.663	debug	(21904) LQI succeeded for '0x842e14fffe51c5c4'
          zigbee.0	2020-09-27 08:09:51.392	debug	(21904) Routing table succeeded for '0x7cb03eaa0a0261fd'
          zigbee.0	2020-09-27 08:09:51.391	debug	(21904) Routing for '0x7cb03eaa0a0261fd': {"neighbors":[{"linkquality":46,"networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","relationship":2,"depth":1},{"linkquality":50,"networkAddress":8908,"ie
          zigbee.0	2020-09-27 08:09:51.389	debug	(21904) Failed to execute routing table for '0x7cb03eaa0a0261fd'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
          zigbee.0	2020-09-27 08:09:48.265	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:09:47.974	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
          zigbee.0	2020-09-27 08:09:47.973	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:09:47.972	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
          zigbee.0	2020-09-27 08:09:47.971	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
          zigbee.0	2020-09-27 08:09:47.969	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:09:47.961	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186987925,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:09:46.030	debug	(21904) Publish {"power":1,"current":0.01,"voltage":233}
          zigbee.0	2020-09-27 08:09:46.004	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
          zigbee.0	2020-09-27 08:09:46.002	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":1}' from endpoint 1 with groupI
          zigbee.0	2020-09-27 08:09:46.000	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
          zigbee.0	2020-09-27 08:09:41.368	debug	(21904) LQI succeeded for '0x7cb03eaa0a0261fd'
          zigbee.0	2020-09-27 08:09:41.344	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:09:40.986	debug	(21904) Routing table succeeded for '0x7cb03eaa0a04f888'
          zigbee.0	2020-09-27 08:09:40.985	debug	(21904) Routing for '0x7cb03eaa0a04f888': {"neighbors":[{"linkquality":88,"networkAddress":8908,"ieeeAddr":"0x842e14fffe51c5c4","relationship":2,"depth":1},{"linkquality":44,"networkAddress":0,"ieeeAd
          zigbee.0	2020-09-27 08:09:40.983	debug	(21904) Failed to execute routing table for '0x7cb03eaa0a04f888'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
          zigbee.0	2020-09-27 08:09:37.942	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
          zigbee.0	2020-09-27 08:09:37.942	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:09:37.941	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
          zigbee.0	2020-09-27 08:09:37.940	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
          zigbee.0	2020-09-27 08:09:37.939	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:09:37.935	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186977932,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:09:36.059	debug	(21904) Publish {"power":3,"current":0.03,"voltage":232}
          zigbee.0	2020-09-27 08:09:36.032	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
          zigbee.0	2020-09-27 08:09:36.030	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":232,"rmsCurrent":25,"activePower":3}' from endpoint 1 with groupI
          zigbee.0	2020-09-27 08:09:36.028	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
          zigbee.0	2020-09-27 08:09:30.962	debug	(21904) LQI succeeded for '0x7cb03eaa0a04f888'
          zigbee.0	2020-09-27 08:09:30.923	debug	(21904) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
          zigbee.0	2020-09-27 08:09:30.922	debug	(21904) getBinding result: []
          zigbee.0	2020-09-27 08:09:30.718	debug	(21904) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
          zigbee.0	2020-09-27 08:09:30.713	debug	(21904) getDevices result: [{"type":"device","common":{"name":"Bad","type":"WSDCGQ11LM","icon":"img/aqara_temperature_sensor.png"},"native":{"id":"00158d0002ca0270"},"from":"system.adapter.zigbee.0","
          zigbee.0	2020-09-27 08:09:30.664	debug	(21904) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
          zigbee.0	2020-09-27 08:09:30.663	debug	(21904) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"}]
          zigbee.0	2020-09-27 08:09:30.544	debug	(21904) Routing table succeeded for 'Coordinator'
          zigbee.0	2020-09-27 08:09:30.543	debug	(21904) Routing for 'Coordinator': {"table":[{"destinationAddress":36891,"status":"ACTIVE","nextHop":36891},{"destinationAddress":63333,"status":"ACTIVE","nextHop":63333},{"destinationAddress":50048,"
          zigbee.0	2020-09-27 08:09:30.523	debug	(21904) LQI succeeded for 'Coordinator'
          zigbee.0	2020-09-27 08:09:30.501	debug	(21904) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
          zigbee.0	2020-09-27 08:09:30.500	debug	(21904) getGroups result: {}
          zigbee.0	2020-09-27 08:09:30.489	debug	(21904) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
          zigbee.0	2020-09-27 08:09:28.429	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:09:27.937	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
          zigbee.0	2020-09-27 08:09:27.936	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:09:27.935	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
          zigbee.0	2020-09-27 08:09:27.934	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
          zigbee.0	2020-09-27 08:09:27.933	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:09:27.927	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186967922,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:09:26.059	debug	(21904) Publish {"power":1,"current":0.01,"voltage":231}
          zigbee.0	2020-09-27 08:09:26.014	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
          zigbee.0	2020-09-27 08:09:26.012	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":231,"rmsCurrent":12,"activePower":1}' from endpoint 1 with group
          zigbee.0	2020-09-27 08:09:26.010	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
          zigbee.0	2020-09-27 08:09:18.389	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
          zigbee.0	2020-09-27 08:09:17.944	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
          zigbee.0	2020-09-27 08:09:17.943	debug	(21904) convert state, OFF, {"state":"OFF"}
          zigbee.0	2020-09-27 08:09:17.942	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
          zigbee.0	2020-09-27 08:09:17.940	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
          zigbee.0	2020-09-27 08:09:17.938	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
          zigbee.0	2020-09-27 08:09:17.932	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186957925,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
          zigbee.0	2020-09-27 08:09:16.020	debug	(21904) Publish {"power":1,"current":0.01,"voltage":231}
          zigbee.0	2020-09-27 08:09:16.001	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
          zigbee.0	2020-09-27 08:09:15.999	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":231,"rmsCurrent":12,"activePower":1}' from endpoint 1 with group
          zigbee.0	2020-09-27 08:09:15.998	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
          zigbee.0	2020-09-27 08:09:13.106	debug	(21904) Publish {"pressure":969.9}
          zigbee.0	2020-09-27 08:09:13.097	debug	(21904) Publish {"humidity":61.16}
          zigbee.0	2020-09-27 08:09:13.091	debug	(21904) Type attributeReport device {"type":"device","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileI
          zigbee.0	2020-09-27 08:09:13.089	debug	(21904) Received Zigbee message from '0x00158d0002ca0270', type 'attributeReport', cluster 'msPressureMeasurement', data '{"16":9699,"20":-1,"measuredValue":969}' from endpoint 1 with groupID 0
          zigbee.0	2020-09-27 08:09:13.087	debug	(21904) handleMessage. {"type":"attributeReport","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":2
          zigbee.0	2020-09-27 08:09:13.078	debug	(21904) Publish {"temperature":18.94}
          zigbee.0	2020-09-27 08:09:13.070	debug	(21904) Type attributeReport device {"type":"device","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileI
          zigbee.0	2020-09-27 08:09:13.067	debug	(21904) Received Zigbee message from '0x00158d0002ca0270', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":6116}' from endpoint 1 with groupID 0
          zigbee.0	2020-09-27 08:09:13.065	debug	(21904) handleMessage. {"type":"attributeReport","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":2
          • arteckA arteck
            @vikk88 dann lass mal analysieren... zuerst die neuste version aus dem GIT installieren
            machmal im Adapter unter Einstellugen
            die debug info rein ...
            und stell dann den adapter auf debug..
            einmal ne dose pairen..und warten bis es wieder hängt.. es sollte dann was im log stehen-.so hoffe ich
            V Offline
            V Offline
            vikk88
            @arteck kannst du etwas mit dem Log anfangen? Ist da irgendwas ungewöhnlich dran?
            zigbee.0	2020-09-29 16:18:53.616	debug	(12265) Publish {"occupancy":false}
            zigbee.0	2020-09-29 16:18:52.810	debug	(12265) Publish {"occupancy":false}
            zigbee.0	2020-09-29 16:18:50.262	debug	(12265) Publish {"power":0,"current":0,"voltage":234}
            zigbee.0	2020-09-29 16:18:50.243	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:18:50.241	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":234,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:18:50.240	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:18:47.816	debug	(12265) Publish {"occupancy":false}
            zigbee.0	2020-09-29 16:18:43.616	debug	(12265) Publish {"occupancy":true}
            zigbee.0	2020-09-29 16:18:43.608	debug	(12265) Publish {"illuminance":8,"illuminance_lux":8}
            zigbee.0	2020-09-29 16:18:43.602	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec33ea","_networkAddress":7518,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
            zigbee.0	2020-09-29 16:18:43.600	debug	(12265) Received Zigbee message from '0x00158d0002ec33ea', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:43.598	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec33ea","_networkAddress":7518,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
            zigbee.0	2020-09-29 16:18:43.588	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec33ea","_networkAddress":7518,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
            zigbee.0	2020-09-29 16:18:43.586	debug	(12265) Received Zigbee message from '0x00158d0002ec33ea', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":8}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:43.584	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":15,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec33ea","_networkAddress":7518,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
            zigbee.0	2020-09-29 16:18:42.809	debug	(12265) Publish {"occupancy":true}
            zigbee.0	2020-09-29 16:18:42.808	debug	(12265) Publish {"illuminance":0,"illuminance_lux":0}
            zigbee.0	2020-09-29 16:18:42.781	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCl
            zigbee.0	2020-09-29 16:18:42.779	debug	(12265) Received Zigbee message from '0x00158d0002ec7bcd', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:42.778	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCluste
            zigbee.0	2020-09-29 16:18:42.770	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCl
            zigbee.0	2020-09-29 16:18:42.767	debug	(12265) Received Zigbee message from '0x00158d0002ec7bcd', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":0}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:42.765	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCluste
            zigbee.0	2020-09-29 16:18:40.210	debug	(12265) Publish {"power":0,"current":0,"voltage":233}
            zigbee.0	2020-09-29 16:18:40.195	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:18:40.194	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:18:40.193	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:18:37.839	debug	(12265) Publish {"occupancy":false}
            zigbee.0	2020-09-29 16:18:37.816	debug	(12265) Publish {"occupancy":true}
            zigbee.0	2020-09-29 16:18:37.770	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profil
            zigbee.0	2020-09-29 16:18:37.769	debug	(12265) Received Zigbee message from '0x00158d0002ec019c', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:37.768	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID"
            zigbee.0	2020-09-29 16:18:37.759	debug	(12265) Publish {"illuminance":1,"illuminance_lux":1}
            zigbee.0	2020-09-29 16:18:37.752	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profil
            zigbee.0	2020-09-29 16:18:37.751	debug	(12265) Received Zigbee message from '0x00158d0002ec019c', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:37.750	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID"
            zigbee.0	2020-09-29 16:18:37.390	debug	(12265) Publish {"occupancy":true}
            zigbee.0	2020-09-29 16:18:37.386	debug	(12265) Publish {"illuminance":0,"illuminance_lux":0}
            zigbee.0	2020-09-29 16:18:37.378	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCl
            zigbee.0	2020-09-29 16:18:37.376	debug	(12265) Received Zigbee message from '0x00158d0002ec7bcd', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:37.374	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCluste
            zigbee.0	2020-09-29 16:18:37.369	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCl
            zigbee.0	2020-09-29 16:18:37.367	debug	(12265) Received Zigbee message from '0x00158d0002ec7bcd', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":0}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:37.366	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":20,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec7bcd","_networkAddress":4781,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCluste
            zigbee.0	2020-09-29 16:18:36.809	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:36.734	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:36.734	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:36.733	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:36.732	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:36.730	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:36.720	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389116715,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:32.687	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:32.608	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:32.607	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:32.606	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:32.605	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:32.604	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:32.553	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389112548,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:30.637	debug	(12265) Publish {"occupancy":true}
            zigbee.0	2020-09-29 16:18:30.634	debug	(12265) Publish {"illuminance":2,"illuminance_lux":2}
            zigbee.0	2020-09-29 16:18:30.620	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profil
            zigbee.0	2020-09-29 16:18:30.618	debug	(12265) Received Zigbee message from '0x00158d0002ec019c', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:30.616	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID"
            zigbee.0	2020-09-29 16:18:30.609	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profil
            zigbee.0	2020-09-29 16:18:30.608	debug	(12265) Received Zigbee message from '0x00158d0002ec019c', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":2}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:30.606	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":21,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ec019c","_networkAddress":63863,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID"
            zigbee.0	2020-09-29 16:18:30.235	debug	(12265) Publish {"power":0,"current":0,"voltage":233}
            zigbee.0	2020-09-29 16:18:30.214	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:18:30.213	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:18:30.211	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:18:27.839	debug	(12265) Publish {"occupancy":true}
            zigbee.0	2020-09-29 16:18:27.828	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d000257a747","_networkAddress":7734,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
            zigbee.0	2020-09-29 16:18:27.826	debug	(12265) Received Zigbee message from '0x00158d000257a747', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:27.824	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d000257a747","_networkAddress":7734,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
            zigbee.0	2020-09-29 16:18:27.819	debug	(12265) Publish {"illuminance":5,"illuminance_lux":5}
            zigbee.0	2020-09-29 16:18:27.808	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d000257a747","_networkAddress":7734,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profile
            zigbee.0	2020-09-29 16:18:27.807	debug	(12265) Received Zigbee message from '0x00158d000257a747', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":5}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:27.806	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":14,"_type":"EndDevice","_ieeeAddr":"0x00158d000257a747","_networkAddress":7734,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":
            zigbee.0	2020-09-29 16:18:26.805	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:26.718	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:26.717	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:26.717	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:26.716	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:26.715	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:26.712	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389106708,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:22.635	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:22.561	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:22.560	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:22.560	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:22.559	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:22.558	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:22.551	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389102545,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:20.117	debug	(12265) Publish {"power":0,"current":0,"voltage":233}
            zigbee.0	2020-09-29 16:18:20.100	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:18:20.099	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:18:20.098	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:18:16.866	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:16.819	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":
            zigbee.0	2020-09-29 16:18:16.817	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'attributeReport', cluster 'genBasic', data '{"65506":30,"appVersion":64}' from endpoint 1 with groupID 0
            zigbee.0	2020-09-29 16:18:16.816	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,
            zigbee.0	2020-09-29 16:18:16.777	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:16.776	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:16.776	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:16.775	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:16.774	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:16.720	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389096715,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:12.628	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:12.560	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:12.559	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:12.558	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:12.557	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:12.556	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:12.550	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389092543,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:11.669	debug	(12265) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-09-29 16:18:11.668	debug	(12265) getMap result: {"lqis":[{"parent":"0x00124b001936a117","networkAddress":63333,"ieeeAddr":"0x7cb03eaa0a0261fd","lqi":1,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a11
            zigbee.0	2020-09-29 16:18:11.667	debug	(12265) Get map succeeded [{"parent":"0x00124b001936a117","networkAddress":63333,"ieeeAddr":"0x7cb03eaa0a0261fd","lqi":1,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a117","n
            zigbee.0	2020-09-29 16:18:11.666	debug	(12265) Routing table succeeded for '0x842e14fffe51c5c4'
            zigbee.0	2020-09-29 16:18:11.664	debug	(12265) Routing for '0x842e14fffe51c5c4': {"table":[{"destinationAddress":0,"nextHop":36891},{"destinationAddress":6332,"status":"ACTIVE","nextHop":6332},{"destinationAddress":59922,"status":"ACTIVE",
            zigbee.0	2020-09-29 16:18:11.292	debug	(12265) LQI succeeded for '0x842e14fffe51c5c4'
            zigbee.0	2020-09-29 16:18:10.359	debug	(12265) Publish {"power":0,"current":0,"voltage":233}
            zigbee.0	2020-09-29 16:18:10.334	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:18:10.332	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:18:10.331	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:18:10.243	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:10.157	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:18:10.078	debug	(12265) Routing table succeeded for '0x7cb03eaa0a04f888'
            zigbee.0	2020-09-29 16:18:10.077	debug	(12265) Routing for '0x7cb03eaa0a04f888': {"neighbors":[{"linkquality":36,"networkAddress":63333,"ieeeAddr":"0x7cb03eaa0a0261fd","relationship":2,"depth":1},{"linkquality":40,"networkAddress":0,"ieeeA
            zigbee.0	2020-09-29 16:18:10.076	debug	(12265) Failed to execute routing table for '0x7cb03eaa0a04f888'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
            zigbee.0	2020-09-29 16:18:06.728	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:06.727	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:06.727	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:06.725	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:06.724	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:06.718	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389086713,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:02.610	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:18:02.609	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:18:02.608	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:18:02.605	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:18:02.604	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:18:02.553	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389082546,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:18:00.297	debug	(12265) Publish {"power":0,"current":0,"voltage":233}
            zigbee.0	2020-09-29 16:18:00.278	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:18:00.277	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:18:00.275	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:18:00.058	debug	(12265) LQI succeeded for '0x7cb03eaa0a04f888'
            zigbee.0	2020-09-29 16:17:59.972	debug	(12265) Routing table succeeded for '0x7cb03eaa0a0261fd'
            zigbee.0	2020-09-29 16:17:59.972	debug	(12265) Routing for '0x7cb03eaa0a0261fd': {"neighbors":[{"linkquality":34,"networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","relationship":2,"depth":1},{"linkquality":58,"networkAddress":8908,"ie
            zigbee.0	2020-09-29 16:17:59.971	debug	(12265) Failed to execute routing table for '0x7cb03eaa0a0261fd'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
            zigbee.0	2020-09-29 16:17:56.809	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:17:56.728	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:17:56.728	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:17:56.727	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:17:56.726	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:17:56.724	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:17:56.719	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389076712,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:17:52.634	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:17:52.553	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
            zigbee.0	2020-09-29 16:17:52.552	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:17:52.552	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
            zigbee.0	2020-09-29 16:17:52.551	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
            zigbee.0	2020-09-29 16:17:52.550	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:17:52.545	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389072540,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:17:50.161	debug	(12265) Publish {"power":0,"current":0,"voltage":234}
            zigbee.0	2020-09-29 16:17:50.147	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
            zigbee.0	2020-09-29 16:17:50.145	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":234,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
            zigbee.0	2020-09-29 16:17:50.144	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
            zigbee.0	2020-09-29 16:17:50.014	debug	(12265) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-09-29 16:17:50.014	debug	(12265) getBinding result: []
            zigbee.0	2020-09-29 16:17:49.950	debug	(12265) LQI succeeded for '0x7cb03eaa0a0261fd'
            zigbee.0	2020-09-29 16:17:49.808	debug	(12265) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-09-29 16:17:49.804	debug	(12265) getDevices result: [{"type":"device","common":{"name":"Bad","type":"WSDCGQ11LM","icon":"img/aqara_temperature_sensor.png"},"native":{"id":"00158d0002ca0270"},"from":"system.adapter.zigbee.0","
            zigbee.0	2020-09-29 16:17:49.727	debug	(12265) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-09-29 16:17:49.726	debug	(12265) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"}]
            zigbee.0	2020-09-29 16:17:49.638	debug	(12265) Routing table succeeded for 'Coordinator'
            zigbee.0	2020-09-29 16:17:49.637	debug	(12265) Routing for 'Coordinator': {"table":[{"destinationAddress":63333,"status":"ACTIVE","nextHop":63333},{"destinationAddress":36891,"status":"ACTIVE","nextHop":36891},{"destinationAddress":54120,"
            zigbee.0	2020-09-29 16:17:49.614	debug	(12265) LQI succeeded for 'Coordinator'
            zigbee.0	2020-09-29 16:17:49.571	debug	(12265) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-09-29 16:17:49.570	debug	(12265) getGroups result: {}
            zigbee.0	2020-09-29 16:17:49.561	debug	(12265) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
            zigbee.0	2020-09-29 16:17:49.094	debug	(12265) system.adapter.admin.0: logging true
            zigbee.0	2020-09-29 16:17:46.795	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:17:46.717	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
            zigbee.0	2020-09-29 16:17:46.717	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:17:46.717	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
            zigbee.0	2020-09-29 16:17:46.716	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
            zigbee.0	2020-09-29 16:17:46.715	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:17:46.711	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389066708,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:17:42.644	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:17:42.563	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
            zigbee.0	2020-09-29 16:17:42.562	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:17:42.561	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
            zigbee.0	2020-09-29 16:17:42.560	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
            zigbee.0	2020-09-29 16:17:42.558	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:17:42.553	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389062545,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:17:40.227	debug	(12265) Publish {"power":0,"current":0,"voltage":234}
            zigbee.0	2020-09-29 16:17:40.211	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
            zigbee.0	2020-09-29 16:17:40.210	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":234,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupI
            zigbee.0	2020-09-29 16:17:40.208	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
            zigbee.0	2020-09-29 16:17:37.281	debug	(12265) Successfully pinged 0x7cb03eaa0a0261fd Plug 01
            zigbee.0	2020-09-29 16:17:37.279	debug	(12265) Type readResponse device {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a0261fd","_networkAddress":63333,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":
            zigbee.0	2020-09-29 16:17:37.277	debug	(12265) Received Zigbee message from '0x7cb03eaa0a0261fd', type 'readResponse', cluster 'genBasic', data '{"zclVersion":1}' from endpoint 3 with groupID 0
            zigbee.0	2020-09-29 16:17:37.276	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a0261fd","_networkAddress":63333,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":4924
            zigbee.0	2020-09-29 16:17:36.817	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:17:36.727	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
            zigbee.0	2020-09-29 16:17:36.727	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:17:36.726	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
            zigbee.0	2020-09-29 16:17:36.724	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
            zigbee.0	2020-09-29 16:17:36.723	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:17:36.718	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389056711,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:17:32.742	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            zigbee.0	2020-09-29 16:17:32.684	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
            zigbee.0	2020-09-29 16:17:32.684	debug	(12265) convert state, OFF, {"state":"OFF"}
            zigbee.0	2020-09-29 16:17:32.683	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
            zigbee.0	2020-09-29 16:17:32.682	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
            zigbee.0	2020-09-29 16:17:32.681	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
            zigbee.0	2020-09-29 16:17:32.678	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601389052674,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601358165273}
            zigbee.0	2020-09-29 16:17:30.186	debug	(12265) Publish {"power":0,"current":0,"voltage":234}
            zigbee.0	2020-09-29 16:17:30.169	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
            zigbee.0	2020-09-29 16:17:30.167	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":234,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupI
            zigbee.0	2020-09-29 16:17:30.165	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
            zigbee.0	2020-09-29 16:17:26.796	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
            Meine Osram Steckdose und meine Osram Lampe scheinen sich immer selbstständig zu resetten und dann sind viele Sensoren nicht mehr erreichbar. Ich kann die dann alle wieder pairen aber nach 1- 2 Tagen passiert das gleiche nochmal.
            • V vikk88
              arteckA Offline
              arteckA Offline
              arteck
              @vikk88
              nutzt du binding ???
              und was ist ads für ein Gerät
              AsgothianA V 2 Antworten Letzte Antwort
              • V vikk88
                @nachon Ich habe jetzt das Problem, das mein smart plug und meine Osram Leuchte sich ständig resetten. Sie heißen dann beide so wie am Anfang, die Namen die ich vergeben habe sind dann auch weg. Dies hat zur Folge das sich viel Sensoren trennen und auch nicht wieder verbinden.
                Ich habe das Gefühl das es an der der 1.2.1 liegt. Vorher hatte ich solche Probleme nicht. Nur komme ich nicht zurück auf die 1.1.3.
                Im Log steht auch kein Error:
                zigbee.0	2020-09-27 08:10:18.350	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:10:17.950	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                zigbee.0	2020-09-27 08:10:17.949	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:10:17.948	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                zigbee.0	2020-09-27 08:10:17.946	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                zigbee.0	2020-09-27 08:10:17.944	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:10:17.937	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601187017930,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:10:16.038	debug	(21904) Publish {"power":3,"current":0.01,"voltage":233}
                zigbee.0	2020-09-27 08:10:16.010	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                zigbee.0	2020-09-27 08:10:16.008	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":3}' from endpoint 1 with groupI
                zigbee.0	2020-09-27 08:10:16.006	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                zigbee.0	2020-09-27 08:10:08.329	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:10:07.970	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                zigbee.0	2020-09-27 08:10:07.969	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:10:07.968	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                zigbee.0	2020-09-27 08:10:07.967	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                zigbee.0	2020-09-27 08:10:07.963	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:10:07.958	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601187007952,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:10:06.034	debug	(21904) Publish {"power":1,"current":0.01,"voltage":233}
                zigbee.0	2020-09-27 08:10:06.008	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                zigbee.0	2020-09-27 08:10:06.006	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":1}' from endpoint 1 with groupI
                zigbee.0	2020-09-27 08:10:06.004	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                zigbee.0	2020-09-27 08:09:58.430	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:09:57.944	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                zigbee.0	2020-09-27 08:09:57.943	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:09:57.942	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                zigbee.0	2020-09-27 08:09:57.940	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                zigbee.0	2020-09-27 08:09:57.939	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:09:57.932	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186997926,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:09:56.038	debug	(21904) Publish {"power":1,"current":0.01,"voltage":233}
                zigbee.0	2020-09-27 08:09:56.014	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                zigbee.0	2020-09-27 08:09:56.013	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":1}' from endpoint 1 with groupI
                zigbee.0	2020-09-27 08:09:56.011	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                zigbee.0	2020-09-27 08:09:51.802	debug	(21904) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                zigbee.0	2020-09-27 08:09:51.802	debug	(21904) getMap result: {"lqis":[{"parent":"0x00124b001936a117","networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","lqi":35,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a1
                zigbee.0	2020-09-27 08:09:51.801	debug	(21904) Get map succeeded [{"parent":"0x00124b001936a117","networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","lqi":35,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a117","
                zigbee.0	2020-09-27 08:09:51.800	debug	(21904) Routing table succeeded for '0x842e14fffe51c5c4'
                zigbee.0	2020-09-27 08:09:51.799	debug	(21904) Routing for '0x842e14fffe51c5c4': {"table":[{"destinationAddress":0,"nextHop":63333},{"destinationAddress":6332,"status":"ACTIVE","nextHop":6332},{"destinationAddress":59922,"status":"ACTIVE",
                zigbee.0	2020-09-27 08:09:51.663	debug	(21904) LQI succeeded for '0x842e14fffe51c5c4'
                zigbee.0	2020-09-27 08:09:51.392	debug	(21904) Routing table succeeded for '0x7cb03eaa0a0261fd'
                zigbee.0	2020-09-27 08:09:51.391	debug	(21904) Routing for '0x7cb03eaa0a0261fd': {"neighbors":[{"linkquality":46,"networkAddress":36891,"ieeeAddr":"0x7cb03eaa0a04f888","relationship":2,"depth":1},{"linkquality":50,"networkAddress":8908,"ie
                zigbee.0	2020-09-27 08:09:51.389	debug	(21904) Failed to execute routing table for '0x7cb03eaa0a0261fd'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
                zigbee.0	2020-09-27 08:09:48.265	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:09:47.974	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                zigbee.0	2020-09-27 08:09:47.973	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:09:47.972	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                zigbee.0	2020-09-27 08:09:47.971	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                zigbee.0	2020-09-27 08:09:47.969	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:09:47.961	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186987925,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:09:46.030	debug	(21904) Publish {"power":1,"current":0.01,"voltage":233}
                zigbee.0	2020-09-27 08:09:46.004	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                zigbee.0	2020-09-27 08:09:46.002	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":233,"rmsCurrent":12,"activePower":1}' from endpoint 1 with groupI
                zigbee.0	2020-09-27 08:09:46.000	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                zigbee.0	2020-09-27 08:09:41.368	debug	(21904) LQI succeeded for '0x7cb03eaa0a0261fd'
                zigbee.0	2020-09-27 08:09:41.344	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:09:40.986	debug	(21904) Routing table succeeded for '0x7cb03eaa0a04f888'
                zigbee.0	2020-09-27 08:09:40.985	debug	(21904) Routing for '0x7cb03eaa0a04f888': {"neighbors":[{"linkquality":88,"networkAddress":8908,"ieeeAddr":"0x842e14fffe51c5c4","relationship":2,"depth":1},{"linkquality":44,"networkAddress":0,"ieeeAd
                zigbee.0	2020-09-27 08:09:40.983	debug	(21904) Failed to execute routing table for '0x7cb03eaa0a04f888'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
                zigbee.0	2020-09-27 08:09:37.942	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                zigbee.0	2020-09-27 08:09:37.942	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:09:37.941	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                zigbee.0	2020-09-27 08:09:37.940	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                zigbee.0	2020-09-27 08:09:37.939	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:09:37.935	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186977932,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:09:36.059	debug	(21904) Publish {"power":3,"current":0.03,"voltage":232}
                zigbee.0	2020-09-27 08:09:36.032	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                zigbee.0	2020-09-27 08:09:36.030	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":232,"rmsCurrent":25,"activePower":3}' from endpoint 1 with groupI
                zigbee.0	2020-09-27 08:09:36.028	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                zigbee.0	2020-09-27 08:09:30.962	debug	(21904) LQI succeeded for '0x7cb03eaa0a04f888'
                zigbee.0	2020-09-27 08:09:30.923	debug	(21904) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                zigbee.0	2020-09-27 08:09:30.922	debug	(21904) getBinding result: []
                zigbee.0	2020-09-27 08:09:30.718	debug	(21904) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                zigbee.0	2020-09-27 08:09:30.713	debug	(21904) getDevices result: [{"type":"device","common":{"name":"Bad","type":"WSDCGQ11LM","icon":"img/aqara_temperature_sensor.png"},"native":{"id":"00158d0002ca0270"},"from":"system.adapter.zigbee.0","
                zigbee.0	2020-09-27 08:09:30.664	debug	(21904) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                zigbee.0	2020-09-27 08:09:30.663	debug	(21904) List of ports: [{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyUSB0"}]
                zigbee.0	2020-09-27 08:09:30.544	debug	(21904) Routing table succeeded for 'Coordinator'
                zigbee.0	2020-09-27 08:09:30.543	debug	(21904) Routing for 'Coordinator': {"table":[{"destinationAddress":36891,"status":"ACTIVE","nextHop":36891},{"destinationAddress":63333,"status":"ACTIVE","nextHop":63333},{"destinationAddress":50048,"
                zigbee.0	2020-09-27 08:09:30.523	debug	(21904) LQI succeeded for 'Coordinator'
                zigbee.0	2020-09-27 08:09:30.501	debug	(21904) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                zigbee.0	2020-09-27 08:09:30.500	debug	(21904) getGroups result: {}
                zigbee.0	2020-09-27 08:09:30.489	debug	(21904) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
                zigbee.0	2020-09-27 08:09:28.429	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:09:27.937	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
                zigbee.0	2020-09-27 08:09:27.936	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:09:27.935	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
                zigbee.0	2020-09-27 08:09:27.934	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
                zigbee.0	2020-09-27 08:09:27.933	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:09:27.927	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186967922,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:09:26.059	debug	(21904) Publish {"power":1,"current":0.01,"voltage":231}
                zigbee.0	2020-09-27 08:09:26.014	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
                zigbee.0	2020-09-27 08:09:26.012	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":231,"rmsCurrent":12,"activePower":1}' from endpoint 1 with group
                zigbee.0	2020-09-27 08:09:26.010	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
                zigbee.0	2020-09-27 08:09:18.389	debug	(21904) convert result {"state":{"state":"OFF","brightness":0}}
                zigbee.0	2020-09-27 08:09:17.944	debug	(21904) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters
                zigbee.0	2020-09-27 08:09:17.943	debug	(21904) convert state, OFF, {"state":"OFF"}
                zigbee.0	2020-09-27 08:09:17.942	debug	(21904) entity: {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":
                zigbee.0	2020-09-27 08:09:17.940	debug	(21904) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"va
                zigbee.0	2020-09-27 08:09:17.938	debug	(21904) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                zigbee.0	2020-09-27 08:09:17.932	debug	(21904) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601186957925,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601183985008}
                zigbee.0	2020-09-27 08:09:16.020	debug	(21904) Publish {"power":1,"current":0.01,"voltage":231}
                zigbee.0	2020-09-27 08:09:16.001	debug	(21904) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
                zigbee.0	2020-09-27 08:09:15.999	debug	(21904) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":231,"rmsCurrent":12,"activePower":1}' from endpoint 1 with group
                zigbee.0	2020-09-27 08:09:15.998	debug	(21904) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
                zigbee.0	2020-09-27 08:09:13.106	debug	(21904) Publish {"pressure":969.9}
                zigbee.0	2020-09-27 08:09:13.097	debug	(21904) Publish {"humidity":61.16}
                zigbee.0	2020-09-27 08:09:13.091	debug	(21904) Type attributeReport device {"type":"device","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileI
                zigbee.0	2020-09-27 08:09:13.089	debug	(21904) Received Zigbee message from '0x00158d0002ca0270', type 'attributeReport', cluster 'msPressureMeasurement', data '{"16":9699,"20":-1,"measuredValue":969}' from endpoint 1 with groupID 0
                zigbee.0	2020-09-27 08:09:13.087	debug	(21904) handleMessage. {"type":"attributeReport","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":2
                zigbee.0	2020-09-27 08:09:13.078	debug	(21904) Publish {"temperature":18.94}
                zigbee.0	2020-09-27 08:09:13.070	debug	(21904) Type attributeReport device {"type":"device","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileI
                zigbee.0	2020-09-27 08:09:13.067	debug	(21904) Received Zigbee message from '0x00158d0002ca0270', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":6116}' from endpoint 1 with groupID 0
                zigbee.0	2020-09-27 08:09:13.065	debug	(21904) handleMessage. {"type":"attributeReport","device":{"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d0002ca0270","_networkAddress":814,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":2
                arteckA Offline
                arteckA Offline
                arteck
                @vikk88 hier ist letzte 1.1.3
                https://github.com/ioBroker/ioBroker.zigbee/tree/fe066d18e187cde6d0f2a13466ea3a971fc51f0e
                • arteckA arteck
                  @vikk88
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @arteck sagte in Zigbee 1.2.1 pairing geht nicht mehr:
                  • 0x7cb01eaa0a => Osram Gerät, wahrscheinlich Plug
                  • Failed to execute routing table -> Versuch die Map aufzubauen, dafuer wird die Routing Table benötigt.
                  @vikk88: Kannst du prüfen welche Firmware-Version(en) deine Plugs haben ?
                  A.
                  • arteckA arteck
                    @vikk88
                    V Offline
                    V Offline
                    vikk88
                    @arteck nein binding benutze ich nicht. Das gerät ist der Plug von Osram. Mein Plan war jetzt den zu löschen und gegen einen weiteren Tuya auszutauschen und die ganze Sache weiter zu beobachten. Sollte das Problem weiter bestehen würde ich die 1.1.3 aufspielen.
                    @Asgothian ich habe mit dem zigbee Adapter die aktuellste geladen
                    • V vikk88
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @vikk88 ok.. danke. Damit geht diese Überlegung den Bach herunter.
                      A.
                      • V Offline
                        V Offline
                        vikk88
                        @Asgothian so heute hat sich die Osram Led wieder resetet. Im Log steht auch failed to execute routing table. Kann es sein das die 1.2.0 Probleme mit Osram Geräten hat?
                        zigbee.0	2020-10-01 17:15:34.033	debug	(12265) Publish {"power":0,"current":0,"voltage":235}
                        zigbee.0	2020-10-01 17:15:34.012	debug	(12265) Type readResponse device {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x842e14fffe1394fe","_networkAddress":11448,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
                        zigbee.0	2020-10-01 17:15:34.011	debug	(12265) Received Zigbee message from '0x842e14fffe1394fe', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":235,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
                        zigbee.0	2020-10-01 17:15:34.009	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x842e14fffe1394fe","_networkAddress":11448,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
                        zigbee.0	2020-10-01 17:15:30.667	debug	(12265) Publish {"power":0,"current":0,"voltage":226}
                        zigbee.0	2020-10-01 17:15:30.644	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-10-01 17:15:30.643	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":226,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
                        zigbee.0	2020-10-01 17:15:30.641	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-10-01 17:15:29.684	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
                        zigbee.0	2020-10-01 17:15:29.228	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
                        zigbee.0	2020-10-01 17:15:28.985	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                        zigbee.0	2020-10-01 17:15:28.984	debug	(12265) convert state, OFF, {"state":"OFF"}
                        zigbee.0	2020-10-01 17:15:28.984	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                        zigbee.0	2020-10-01 17:15:28.983	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                        zigbee.0	2020-10-01 17:15:28.982	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                        zigbee.0	2020-10-01 17:15:28.974	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601565328967,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601530034448}
                        zigbee.0	2020-10-01 17:15:28.738	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                        zigbee.0	2020-10-01 17:15:28.737	debug	(12265) convert state, OFF, {"state":"OFF"}
                        zigbee.0	2020-10-01 17:15:28.737	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                        zigbee.0	2020-10-01 17:15:28.736	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                        zigbee.0	2020-10-01 17:15:28.735	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                        zigbee.0	2020-10-01 17:15:28.728	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601565328722,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601530034448}
                        zigbee.0	2020-10-01 17:15:24.032	debug	(12265) Publish {"power":0,"current":0,"voltage":238}
                        zigbee.0	2020-10-01 17:15:24.009	debug	(12265) Type readResponse device {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x842e14fffe1394fe","_networkAddress":11448,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":26
                        zigbee.0	2020-10-01 17:15:24.007	debug	(12265) Received Zigbee message from '0x842e14fffe1394fe', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":238,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
                        zigbee.0	2020-10-01 17:15:24.006	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x842e14fffe1394fe","_networkAddress":11448,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"d
                        zigbee.0	2020-10-01 17:15:23.666	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
                        zigbee.0	2020-10-01 17:15:23.277	debug	(12265) convert result {"state":{"state":"OFF","brightness":0}}
                        zigbee.0	2020-10-01 17:15:22.805	debug	(12265) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-10-01 17:15:22.804	debug	(12265) getMap result: {"lqis":[{"parent":"0x00124b001936a117","networkAddress":25087,"ieeeAddr":"0x00158d000422fd64","lqi":29,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a1
                        zigbee.0	2020-10-01 17:15:22.803	debug	(12265) Get map succeeded [{"parent":"0x00124b001936a117","networkAddress":25087,"ieeeAddr":"0x00158d000422fd64","lqi":29,"relationship":1,"depth":1,"status":"online"},{"parent":"0x00124b001936a117","
                        zigbee.0	2020-10-01 17:15:22.802	debug	(12265) Routing table succeeded for '0x7cb03eaa0a04f888'
                        zigbee.0	2020-10-01 17:15:22.802	debug	(12265) Routing for '0x7cb03eaa0a04f888': {"neighbors":[{"linkquality":54,"networkAddress":11448,"ieeeAddr":"0x842e14fffe1394fe","relationship":2,"depth":1},{"linkquality":42,"networkAddress":0,"ieeeA
                        zigbee.0	2020-10-01 17:15:22.801	debug	(12265) Failed to execute routing table for '0x7cb03eaa0a04f888'. "Error: AREQ - ZDO - mgmtRtgRsp after 10000ms\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigb
                        zigbee.0	2020-10-01 17:15:20.671	debug	(12265) Publish {"power":0,"current":0,"voltage":226}
                        zigbee.0	2020-10-01 17:15:20.644	debug	(12265) Type readResponse device {"type":"device","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2020-10-01 17:15:20.642	debug	(12265) Received Zigbee message from '0x842e14fffe51c5c4', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":226,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupID
                        zigbee.0	2020-10-01 17:15:20.641	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":6,"_type":"Router","_ieeeAddr":"0x842e14fffe51c5c4","_networkAddress":8908,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"de
                        zigbee.0	2020-10-01 17:15:18.974	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                        zigbee.0	2020-10-01 17:15:18.974	debug	(12265) convert state, OFF, {"state":"OFF"}
                        zigbee.0	2020-10-01 17:15:18.973	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                        zigbee.0	2020-10-01 17:15:18.971	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                        zigbee.0	2020-10-01 17:15:18.970	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                        zigbee.0	2020-10-01 17:15:18.967	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601565318962,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601530034448}
                        zigbee.0	2020-10-01 17:15:18.727	debug	(12265) target: {"ID":3,"profileID":49246,"deviceID":256,"inputClusters":[4096,0,3,4,5,6,8,64527],"outputClusters":[25],"deviceNetworkAddress":36891,"deviceIeeeAddress":"0x7cb03eaa0a04f888","clusters"
                        zigbee.0	2020-10-01 17:15:18.726	debug	(12265) convert state, OFF, {"state":"OFF"}
                        zigbee.0	2020-10-01 17:15:18.726	debug	(12265) entity: {"type":"device","device":{"ID":3,"_type":"Router","_ieeeAddr":"0x7cb03eaa0a04f888","_networkAddress":36891,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":2
                        zigbee.0	2020-10-01 17:15:18.725	debug	(12265) State changes. dev: 0x7cb03eaa0a04f888 model: AC03641 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"val
                        zigbee.0	2020-10-01 17:15:18.725	debug	(12265) Change state 'state' at device 0x7cb03eaa0a04f888 type 'AC03641'
                        zigbee.0	2020-10-01 17:15:18.713	debug	(12265) User stateChange zigbee.0.7cb03eaa0a04f888.state {"val":false,"ack":false,"ts":1601565318710,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1601530034448}
                        zigbee.0	2020-10-01 17:15:18.698	debug	(12265) Publish {"occupancy":false}
                        zigbee.0	2020-10-01 17:15:14.032	debug	(12265) Publish {"power":0,"current":0,"voltage":238}
                        zigbee.0	2020-10-01 17:15:14.011	debug	(12265) Type readResponse device {"type":"device","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x842e14fffe1394fe","_networkAddress":11448,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":2
                        zigbee.0	2020-10-01 17:15:14.007	debug	(12265) Received Zigbee message from '0x842e14fffe1394fe', type 'readResponse', cluster 'haElectricalMeasurement', data '{"rmsVoltage":238,"rmsCurrent":0,"activePower":0}' from endpoint 1 with groupI
                        zigbee.0	2020-10-01 17:15:14.006	debug	(12265) handleMessage. {"type":"readResponse","device":{"ID":2,"_type":"Router","_ieeeAddr":"0x842e14fffe1394fe","_networkAddress":11448,"_manufacturerID":4098,"_endpoints":[{"ID":1,"profileID":260,"
                        zigbee.0	2020-10-01 17:15:12.783	debug	(12265) LQI succeeded for '0x7cb03eaa0a04f888'
                        zigbee.0	2020-10-01 17:15:12.716	debug	(12265) Publish {"pressure":971.4}
                        zigbee.0	2020-10-01 17:15:12.713	debug	(12265) Publish {"humidity":56.2}
                        zigbee.0	2020-10-01 17:15:12.698	debug	(12265) Publish {"temperature":21.76}
                        zigbee.0	2020-10-01 17:15:12.696	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0002733e82","_networkAddress":35564,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profi
                        zigbee.0	2020-10-01 17:15:12.695	debug	(12265) Received Zigbee message from '0x00158d0002733e82', type 'attributeReport', cluster 'msPressureMeasurement', data '{"16":9714,"20":-1,"measuredValue":971}' from endpoint 1 with groupID 0
                        zigbee.0	2020-10-01 17:15:12.694	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0002733e82","_networkAddress":35564,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profi
                        zigbee.0	2020-10-01 17:15:12.693	debug	(12265) Received Zigbee message from '0x00158d0002733e82', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":5620}' from endpoint 1 with groupID 0
                        zigbee.0	2020-10-01 17:15:12.692	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0002733e82","_networkAddress":35564,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID
                        zigbee.0	2020-10-01 17:15:12.690	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0002733e82","_networkAddress":35564,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID
                        zigbee.0	2020-10-01 17:15:12.687	debug	(12265) Type attributeReport device {"type":"device","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0002733e82","_networkAddress":35564,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profi
                        zigbee.0	2020-10-01 17:15:12.686	debug	(12265) Received Zigbee message from '0x00158d0002733e82', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2176}' from endpoint 1 with groupID 0
                        zigbee.0	2020-10-01 17:15:12.685	debug	(12265) handleMessage. {"type":"attributeReport","device":{"ID":10,"_type":"EndDevice","_ieeeAddr":"0x00158d0002733e82","_networkAddress":35564,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID
                        zigbee.0	2020-10-01 17:15:12.341	debug	(12265) Routing table succeeded for '0x842e14fffe1394fe'
                        zigbee.0	2020-10-01 17:15:12.340	debug	(12265) Routing for '0x842e14fffe1394fe': {"table":[{"destinationAddress":0,"nextHop":0},{"destinationAddress":8908,"status":"ACTIVE","nextHop":8908},{"destinationAddress":50048,"status":"ACTIVE","ne
                        zigbee.0	2020-10-01 17:15:12.261	debug	(12265) LQI succeeded for '0x842e14fffe1394fe'
                        zigbee.0	2020-10-01 17:15:12.097	debug	(12265) Routing table succeeded for '0x842e14fffe51c5c4'
                        zigbee.0	2020-10-01 17:15:12.097	debug	(12265) Routing for '0x842e14fffe51c5c4': {"table":[{"destinationAddress":0,"nextHop":11448},{"destinationAddress":35007,"status":"ACTIVE","nextHop":36891},{"destinationAddress":59922,"status":"ACTIV
                        zigbee.0	2020-10-01 17:15:12.001	debug	(12265) LQI succeeded for '0x842e14fffe51c5c4'
                        zigbee.0	2020-10-01 17:15:11.942	debug	(12265) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0	2020-10-01 17:15:11.942	debug	(12265) getBinding result: []
                        zigbee.0	2020-10-01 17:15:11.797	debug	(12265) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
                        Alle Sensoren die an der Led hingen haben sich auch wieder getrennt
                        Die BM reagieren aber noch und sind auch aviable. Kommen mir aber träger vor, also brauchen länger um zu schalten
                        • V vikk88
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @vikk88 kann sein das die Lampe kaputt ist.. kannst du da zum Tausch was anderes reinhängen.. an die gleiche stelle ??
                          ne tradfri.. oder ne andere osram
                          V 1 Antwort Letzte Antwort
                          • arteckA arteck
                            V Offline
                            V Offline
                            vikk88
                            @arteck den Gedanken hatte ich auch schon, werde mir mal eine tradfri besorgen. Komisch ist nur das ich vor ca. einem halben Jahr an der Stelle eine andere osram hängen hatte. Diese hatte einen Defekt, im log stand auch error und das diese nicht erreichbar war, updaten ging auch nicht. Die aktuelle funktioniert auch noch und wird von den BMs geschaltet.
                            L 1 Antwort Letzte Antwort
                            • V vikk88
                              Laser
                              schrieb am zuletzt editiert von Laser
                              Das Zigbee Problem ist scheinbar wieder da...
                              Mein Adapter wird nach einem Update nur noch gelb. (Funktioniere bisher ohne Probleme.)
                              Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                              Als Schnittstelle: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4604-if00
                              eingetragen.
                              Aber auch /dev/ttyACM0 probiert - erfolglos..
                              Wie ändere ich die Benutzerrechte auf COM SS?
                              Das muß doch über IOBroker funktionieren?
                              • L Laser
                                eingetragen.
                                @laser sagte in Zigbee 1.2.1 pairing geht nicht mehr:
                                Was soll das sein?
                                Und wie sehen die Rechte, die du da jetzt verfummeln willst jetzt aus?
                                  Was soll das sein?
                                  Laser
                                  angeblich kann es sein, daß der Benutzer iobroker nicht auf die Schnittstelle für den USB-Stick zugreifen kann.
                                  Allerdings: "Der Benutzer »iobroker« ist bereits ein Mitglied der Gruppe »dialout«."
                                  pi@iobroker-pi:~ $ ls -l /dev/ttyACM0 crw-rw---- 1 root dialout 166, 0 19. Feb 18:45 /dev/ttyACM0
                                  Verfummeln will ich da nichts, nur verstehen, warum ZIGBEE nicht mehr funktioniert...
                                  • L Laser
                                    angeblich kann es sein, daß der Benutzer iobroker nicht auf die Schnittstelle für den USB-Stck zugreifen kann.
                                    Das ist möglich. Aber das kann man besser sehen, wenn man den Status 'jetzt' kennt.
                                    Die Rechte an den /dev-Files gehen aber eigentlich nicht 'kaputt'.
                                    Da wird noch irgendwas anders auf die Schnittstelle zugreifen.
                                    Schau mit
                                    lsof /pfad/zum/gerät
                                    nach was das sein könnte.
                                      Schau mit
                                      Laser
                                      lsof /dev/ttyACM0
                                      Kommando nicht gefunden
                                      • L Laser
                                        lsof /dev/ttyACM0
                                        @laser
                                        Dann musst du es nachinstallieren.
                                        sudo apt update
                                        sudo apt install lsof
                                          @laser
                                          sudo apt update
                                          Laser
                                          pi@iobroker-pi:~ $ sudo lsof /dev/ttyACM0
                                          COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
                                          io.zigbee 5356 iobroker 26uW CHR 166,0 0t0 386 /dev/ttyACM0
