  4. influxDB mit iobroker problem
    6.8k
influxdbiobroker
22 Beiträge 5 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • C Offline
    cainam
    schrieb am zuletzt editiert von cainam
    Hallo zusammen
    Bis vor kurzen hat mein influxDB super funktioniert mit der Speisung der Daten von ioBroker. Seit gestern kommen aber im Log nur noch errors... auch kann ich mit grafana nicht mehr zugreiffen. influxDb läuft aber.... kann mir da jemand helfen?
    LOG: influxdb.0 2020-09-27 21:19:21.113 warn (32360) Error on writePoint("{"value":135993,"time":"2020-09-27T19:18:44.406Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:19.928 info (32360) Add point that had error for proxmox.0.qemu_ioBroker.mem_lev to buffer again, error-count=9
    influxdb.0 2020-09-27 21:19:19.927 warn (32360) Error on writePoint("{"value":35.56,"time":"2020-09-27T19:18:44.454Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:18.745 info (32360) Add point that had error for proxmox.0.qemu_InfluxDB.cpu to buffer again, error-count=1
    influxdb.0 2020-09-27 21:19:18.744 warn (32360) Error on writePoint("{"value":0,"time":"2020-09-27T19:18:14.589Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:16.014 info (32360) Add point that had error for proxmox.0.qemu_Grafana.mem_lev to buffer again, error-count=6
    influxdb.0 2020-09-27 21:19:16.011 warn (32360) Error on writePoint("{"value":27.73,"time":"2020-09-27T19:18:44.924Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:15.772 info (32360) Add point that had error for proxmox.0.qemu_InfluxDB.mem_lev to buffer again, error-count=7
    influxdb.0 2020-09-27 21:19:15.772 warn (32360) Error on writePoint("{"value":27.15,"time":"2020-09-27T19:18:44.578Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:15.764 info (32360) Add point that had error for proxmox.0.qemu_InfluxDB.netin to buffer again, error-count=8
    influxdb.0 2020-09-27 21:19:15.764 warn (32360) Error on writePoint("{"value":158094,"time":"2020-09-27T19:18:44.578Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:15.744 info (32360) Add point that had error for proxmox.0.qemu_InfluxDB.netout to buffer again, error-count=7
    influxdb.0 2020-09-27 21:19:15.742 warn (32360) Error on writePoint("{"value":11443,"time":"2020-09-27T19:18:44.577Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:15.692 info (32360) Add point that had error for proxmox.0.qemu_InfluxDB.uptime to buffer again, error-count=7
    influxdb.0 2020-09-27 21:19:15.692 warn (32360) Error on writePoint("{"value":62,"time":"2020-09-27T19:18:44.577Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:14.902 info (32360) Discard point that had error for proxmox.0.qemu_InfluxDB.cpu, error-count=10
    influxdb.0 2020-09-27 21:19:14.901 warn (32360) Error on writePoint("{"value":44.79,"time":"2020-09-27T19:18:44.577Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:13.632 info (32360) Add point that had error for proxmox.0.qemu_ioBroker.cpu to buffer again, error-count=7
    influxdb.0 2020-09-27 21:19:13.632 warn (32360) Error on writePoint("{"value":11.84,"time":"2020-09-27T19:18:44.448Z","from":"system.adapter.proxmox.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{"error":"timeout"}\n"
    influxdb.0 2020-09-27 21:19:12.304 info (32360) Add point that had error for proxmox.0.qemu_ioBroker.uptime to buffer again, error-count=7
    influxdb.0 2020-09-27 21:19:12.303 warn (32360) Error on writePoint("{"value":2514349,"time":"2020-09-27T19:18:44.405Z","from":"system.adapter.proxmox.
    GlasfaserG crunchipC 2 Antworten Letzte Antwort
    • C cainam
      Hallo zusammen
      GlasfaserG Offline
      GlasfaserG Offline
      @cainam
      setze den Code bitte in CodeTags </>
      • C cainam
        Hallo zusammen
        crunchipC Abwesend
        crunchipC Abwesend
        @cainam Festplattenspeicher womöglich voll
          cainam
          @crunchip said in influxDB mit iobroker problem:
          nein, habe noch x-gb frei... habe so 60mb von 4gb gebraucht.. habe gerade noch um 1gb zur sicherheit erhöht
          p.s. habe gerade noch festgestellt das zB grafana auch nichts mehr anzeigt
          • C cainam
            crunchipC Abwesend
            crunchipC Abwesend
            @cainam war auch nur eine Idee, weil mir das kürzlich selbst passiert ist und führte zum selbigen log
            Wo läuft bei dir was, auf welchem System
            C 1 Antwort Letzte Antwort
              cainam
              @crunchip
              habe eine NUC am laufen mit je einer virtuellen maschine für
              iobroker ip 192.168.0.30
              influxdb ip 192.168.0.36
              grafana ip 192.168.037
              ist alles tiptop bis vor zwei tagen ca. gelaufen (habe auch nix geändert seit da..)
              evt hilfts:
               curl -o profiles.tar.gz "http://192.168.0.36:8086/debug/pprof/all?cpu=true"
                % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                               Dload  Upload   Total   Spent    Left  Speed
              100    19  100    19    0     0   2375      0 --:--:-- --:--:-- --:--:--  2375
                cainam
                @crunchip oder doch ein speicherplatzproblem?
                root@InfluxDB:~# df -h
                Dateisystem                   Größe Benutzt Verf. Verw% Eingehängt auf
                udev                           982M       0  982M    0% /dev
                tmpfs                          200M     21M  180M   11% /run
                /dev/mapper/InfluxDB--vg-root  1.7G    1.7G     0  100% /
                tmpfs                          998M       0  998M    0% /dev/shm
                tmpfs                          5.0M       0  5.0M    0% /run/lock
                tmpfs                          998M       0  998M    0% /sys/fs/cgroup
                /dev/sda1                      236M     49M  176M   22% /boot
                tmpfs                          200M       0  200M    0% /run/user/0
                • C cainam
                  @cainam Naja, dein root ist vollgelaufen, würde ich mal sagen.
                    cainam
                    @Thomas-Braun wie kann ich das anpassen
                    da hat es ja bei den anderen noch genug
                    • C cainam
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @cainam bisschen knapp bemessen😉 und warum hast du das in ner VM und nicht als LXC
                      hattest du nicht oben geschrieben du hast um 1GB erhöht?
                      • C cainam
                        @cainam sagte in influxDB mit iobroker problem:
                        Keine Ahnung von VM & LCX und Konsorten.
                        • C cainam
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @cainam https://beyond.lol/disk-einer-vm-vergroessern-in-proxmox/
                            cainam
                            @crunchip naja, hab eigentlich keine ahnung von linux... habe gelesen das vm einfacher ist... darum
                            ja habe um 1gb in proxmox erhöht... gehe davon aus das ist nun der udev sepeicher
                            • C cainam
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @cainam ja du musst auf der Proxmox oberfläche deine VM erhöhen(hast du ja bereits), dann das was ich dir als link geschickt habe, zusätzlich ausführen, damit deine "Erweiterung" im System bekannt wird.
                              Für solche Sachen nimmt man keine VM, da reicht ein lächerlicher LXC, da du keine Geräte durchreichen musst.
                              Vortei wäre nun auch gewesen, den LXC hättest du ganz normal auf der Proxmox Oberfläche erweitern können, ohne zusätzlichen Schnickschnck
                                cainam
                                @crunchip wie kann ich einfach das nun einfach auf eine lxc ändern... ohne meine datenbank zu verlieren?
                                • C cainam
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @cainam das ist ein wenig aufwendiger, da du dir die Datenbank sichern müsstest. Einen neuen LXC mit Influx erstellen und anschliessend deine Datenbank wieder rein kopieren. Dein LXC braucht dann auch wieder die gleiche IP oder du musst es dann in IoBroker/Grafana bzw wo du das sonst noch nutz, wieder anpassen
                                  https://docs.influxdata.com/influxdb/v1.7/administration/backup_and_restore/
                                    cainam
                                    Das hat zwar alles funktioniert und es sieht auch richtig aus in dem gp... aber wenn ich danach die maschine neu starte und df -h mache sieht es noch genau gleich aus
                                    • C cainam
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @cainam dann hast du etwas falsch gemacht.
                                      und unabhängig davon, mit ner 1GB erweiterung kommst eh nicht lange klar, Ne Influx Datenbank kann ruhig 20 Gb haben
                                        cainam
                                        @crunchip
                                        in dem programm zeigt es mir es richtig an... zurück im influxsystem ist das aber immer noch gleich
                                        naja, will es eigenlich nur mal vorübergehend erhöhen... (auch das ich ein backup machen kann)!
                                        unter fdisk ist es auch drin...
                                        C JLegJ 2 Antworten Letzte Antwort
                                        • C cainam
                                          @crunchip
                                          cainam
                                          ich verzweifle... ich kann weder ein backup machen noch kann ich eine datenbank löschen da ich 0 speicher zur verfügung habe...
                                          PLEASE HELP
