  4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    6.8k
zigbee
95 Beiträge 5 Kommentatoren 10.9k Aufrufe 3 Beobachtet
    @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
    cd /opt/iobroker
    npm i iobroker.zigbee@1.2.1
    birdyB Offline
    birdyB Offline
    birdy
    @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
    cd /opt/iobroker
    Hab aber vergessen, iobroker zu stoppen... Schlecht?
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concentrate@^0.2.3 (node_modules/unpi/node_modules/concentrate):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for concentrate@0.2.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: concentrate@0.2.3
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})
    npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
    npm ERR! notsup Required: {"node":"~0.10.0"}
    npm ERR! notsup Actual:   {"npm":"6.14.6","node":"12.18.4"}
    npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_27_48_926Z-debug.log
    • birdyB birdy
      cd /opt/iobroker
      @birdy
      Versuch mal dissolve rauszukicken.
      Ein aktuelles zigbee benötigt das nicht mehr.
      npm uninstall dissolve
      birdyB 1 Antwort Letzte Antwort
        @birdy
        birdyB Offline
        birdyB Offline
        birdy
        @birdy
        Ein akutelles zigbee benötigt das nicht mehr.
        vorher iobroker stoppen?
        • birdyB birdy
          @birdy
          @birdy
          Kannst du machen.
          • birdyB birdy
            @birdy
            Wenn das nicht klappt versuch mal mit
            npm uninstall dissolve --save
              @birdy
              Kannst du machen.
              birdyB Offline
              birdyB Offline
              birdy
              @Thomas-Braun
              pi@raspberrypi:/opt/iobroker $ npm uninstall dissolve
              npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
              > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
              > node-pre-gyp install --fallback-to-build
              node-pre-gyp WARN Using request for node-pre-gyp https download
              node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
              node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
              Package cairo was not found in the pkg-config search path.
              Perhaps you should add the directory containing `cairo.pc'
              to the PKG_CONFIG_PATH environment variable
              No package 'cairo' found
              gyp: Call to 'pkg-config cairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
              gyp ERR! configure error
              gyp ERR! stack Error: `gyp` failed with exit code: 1
              gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
              gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              gyp ERR! System Linux 4.19.66-v7+
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
              gyp ERR! cwd /opt/iobroker/node_modules/canvas
              gyp ERR! node -v v12.18.4
              gyp ERR! node-gyp -v v5.1.0
              gyp ERR! not ok
              node-pre-gyp ERR! build error
              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
              node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
              node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
              node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
              node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
              node-pre-gyp ERR! System Linux 4.19.66-v7+
              node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
              node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
              node-pre-gyp ERR! node -v v12.18.4
              node-pre-gyp ERR! node-pre-gyp -v v0.11.0
              node-pre-gyp ERR! not ok
              > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
              > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
              ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
              info sharp Attempting to build from source via node-gyp but this may fail due to the above error
              info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
              make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
                CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                COPY Release/nothing.a
                TOUCH Release/obj.target/libvips-cpp.stamp
                CXX(target) Release/obj.target/sharp/src/common.o
              ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
               #include <vips/vips8>
              compilation terminated.
              sharp.target.mk:138: die Regel für Ziel „Release/obj.target/sharp/src/common.o“ scheiterte
              make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
              make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/sharp
              gyp ERR! not ok
              > iobroker@1.0.8 install /opt/iobroker/node_modules/iobroker
              > node lib/setup.js
              NPM version: 6.14.8
              NPM 5 is currently NOT supported!
              Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
              You need to make sure to downgrade again with the above command after you
              installed an update to nodejs/npm!
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 (node_modules/canvas):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! iobroker@1.0.8 install: `node lib/setup.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the iobroker@1.0.8 install script.
              npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_36_28_808Z-debug.log
                birdyB Offline
                birdyB Offline
                birdy
                @Thomas-Braun
                So nebenbei möchte ich mich mal bei dir für die Zeit, die du in den fall investierst, bedanken!
                • birdyB birdy
                  @Thomas-Braun
                  gyp ERR! not ok
                  gyp ERR! not ok
                  > node lib/setup.js
                  NPM version: 6.14.8
                  npm ERR! errno 1
                  npm ERR!
                  @birdy
                  Wie gesagt: Viele viele Baustellen.
                  Vermutlich geht das schneller, wenn du das System komplett neuinstallierst (Buster) und dann dein Backup in den ioBroker einspielst.
                  birdyB 2 Antworten Letzte Antwort
                    @birdy
                    birdyB Offline
                    birdyB Offline
                    birdy
                    @Thomas-Braun
                    aber jetzt ganz schlimm:
                    pi@raspberrypi:/opt/iobroker $ start iobroker
                    -bash: start: Kommando nicht gefunden.
                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                    • birdyB birdy
                      @Thomas-Braun
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @birdy
                      iobroker start
                      • birdyB birdy
                        @Thomas-Braun
                        @birdy
                        Nö. Das heißt ja auch
                        iobroker start
                          @birdy
                          iobroker start
                          birdyB Offline
                          birdyB Offline
                          birdy
                          @birdy
                          iobroker start
                          Sorry, bin schon etwas durch den Wind...
                          • birdyB birdy
                            @birdy
                            iobroker start
                            @birdy
                            Die Meldung bzgl. cairo dürfest du mit
                            sudo apt install libcairo2-dev
                            schon mal loswerden. Ändert aber nix am Umfang der Großbaustelle.
                              @birdy
                              birdyB Offline
                              birdyB Offline
                              birdy
                              @Thomas-Braun
                              Aber was soll ich jetzt mit dem deistallierten dissolve machen?
                              Nochmal?
                              • birdyB birdy
                                @Thomas-Braun
                                Nochmal?
                                @birdy
                                Probier mal. Ich bin nicht mal sicher das dissolve sich jetzt aufgelöst hat...
                                  @birdy
                                  birdyB Offline
                                  birdyB Offline
                                  birdy
                                  @Thomas-Braun
                                  Scheint nicht so... :(
                                  pi@raspberrypi:/opt/iobroker $ npm i iobroker.zigbee@1.2.1
                                  npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_51_25_317Z-debug.log
                                  • birdyB birdy
                                    @Thomas-Braun
                                    Unsupported engine for concentrate@0.2.3: wanted: "node":"~0.10.0"}
                                    Da hast du übrigens den nächsten alten Hund.
                                    Wer weiß was da noch alles nach oben gespült wird.
                                    Ich würde das Ding plattmachen und ein Backup des ioBrokers einspielen. Backitup hast du ja hoffentlich am Start?
                                      birdyB Offline
                                      birdyB Offline
                                      birdy
                                      @Thomas-Braun
                                      Ja, Backup habe ich, Komplett und Standard... Ist eine Variante zu bevorzugen?
                                      • birdyB birdy
                                        @Thomas-Braun
                                        @birdy
                                        Die Unterscheidung zwischen Komplett und Standard kenne ich nicht. Vermutlich eine alte Einstellung.
                                        Du kannst aber auch mal den hier probieren:
                                        iobroker stop
                                        curl -sL https://iobroker.net/fix.sh | bash -
                                        iobroker start
                                        npm i iobroker.zigbee@1.2.1 --force
                                        kannst du auch nochmal versuchen.
                                          @birdy
                                          iobroker stop
                                          iobroker start
                                          birdyB Offline
                                          birdyB Offline
                                          birdy
                                          @birdy
                                          iobroker stop
                                          iobroker start
                                          Nach dem Fix sieht es aber besser aus:
                                          pi@raspberrypi:~ $ npm i iobroker.zigbee@1.2.1                                  npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                          npm WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                                          npm WARN pi No description
                                          npm WARN pi No repository field.
                                          npm WARN pi No README data
                                          npm WARN pi No license field.
                                          + iobroker.zigbee@1.2.1
                                          updated 1 package and audited 113 packages in 38.913s
                                          38 packages are looking for funding
                                            run `npm fund` for details
                                          found 4 high severity vulnerabilities
                                            run `npm audit fix` to fix them, or `npm audit` for details
