  4. Bug bei Update usw..
    6.8k
build error
27 Beiträge 3 Kommentatoren 2.8k Aufrufe 2 Beobachtet
    @BLRD
    Was ist denn das da für ein Betriebssystem?
    Was Debian-artiges?
    Versuch mal:
    cd /opt/iobroker
    npm install sharp
    Wenn das klemmt: Prüfe welches glibc installiert ist
    ldd --version
    BLRD
    schrieb am zuletzt editiert von BLRD
    @Thomas-Braun
    Hi siehe dies
    Ich werde dies versuchen und eine Rückmeldung geben.
    Danke.
    BLRD
    so der Nachtrag:
    XXXXX:/opt/iobroker$ npm install sharp
    [sudo] password for XX:
    > sharp@0.25.4 install /opt/iobroker/node_modules/iobroker.iot/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    make: Entering directory '/opt/iobroker/node_modules/iobroker.iot/node_modules/sharp/build'
      CC(target) Release/obj.target/nothing/../../../node-addon-api/nothing.o
      AR(target) Release/obj.target/../../../node-addon-api/nothing.a
      COPY Release/nothing.a
      TOUCH Release/obj.target/libvips-cpp.stamp
      CXX(target) Release/obj.target/sharp/src/common.o
    ../src/common.cc:23:22: fatal error: vips/vips8: No such file or directory
     #include <vips/vips8>
    compilation terminated.
    sharp.target.mk:139: recipe for target 'Release/obj.target/sharp/src/common.o' failed
    make: *** [Release/obj.target/sharp/src/common.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.iot/node_modules/sharp/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.192-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/sharp
    gyp ERR! node -v v12.18.4
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    > sharp@0.26.0 install /opt/iobroker/node_modules/sharp
    > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
    ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.10.0
    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
      CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
      AR(target) Release/obj.target/../node-addon-api/nothing.a
    ../src/common.cc:24:22: fatal error: vips/vips8: No such file or directory
    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.4 (node_modules/iobroker.iot/node_modules/sharp):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.4 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! sharp@0.26.0 install: `(node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the sharp@0.26.0 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2020-09-18T14_25_26_570Z-debug.log
    XXXXXX:/opt/iobroker$ ldd --version
    ldd (Debian GLIBC 2.24-11+deb9u4) 2.24
    Copyright (C) 2016 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Written by Roland McGrath and Ulrich Drepper.
    XXXXXXX:/opt/iobroker$
    • B BLRD
      @Thomas-Braun
      Hi siehe dies
      Danke.
      BLRD
      so der Nachtrag:
      gyp ERR! not ok
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      @BLRD
      Stretch ist ja jetzt nicht ganz aktuell.
      Vermutlich musst du da libvips sowie sharp bauen. Siehe auch hier:
        @BLRD
        BLRD
        @Thomas-Braun
        Und was könnte ich statt Stretch nehmen und wie mache ich dies!?
        Danke.
        • B BLRD
          @Thomas-Braun
          Danke.
          @BLRD
          Ist Armbian, oder?
          https://wiki.pine64.org/index.php/ROCK64_Software_Release#Armbian_Debian_Buster_on_mainline_Kernel_.5BmicroSD_.2F_eMMC_Boot.5D
          Ich würde aber wohl zunächst einfach die beiden Dinger selber bauen. Ist etwas weniger aufwändig.
            @BLRD
            Ist Armbian, oder?
            @Thomas-Braun Dann spiele ich mal mit:
              @Homoran
              Da bist du ja prädestiniert für den weiteren Support. Armbian ist mir nicht so geläufig.
              Fein wäre ja ein Buster in Server-Setup mit Kernel 5.8.x
                @Homoran
                @Thomas-Braun sagte in Bug bei Update usw..:
                eben nicht - sonst wäre das nicht mehr so alt.
                Aber wenn du meinst, dann nehme ich mal die Anleitung von dir für Linux und jage das drüber
                  @Homoran
                  Das wäre mein üblicher Ansatz.
                  Backup
                  palttmachen
                  neu installiern
                  restore
                    Backup
                    palttmachen
                    neu installiern
                    restore
                    @Homoran Och, ich dachte du baust jetzt libvip und sharp zusammen.
                      BLRD
                      @Homoran
                      Oh schön zu hören, dass Profis daran arbeiten.
                      Da kann ich nicht viel dazu beitragen.
                      Danke.
                      BLRD
                      • B BLRD
                        @Homoran
                        Danke.
                        BLRD
                        @BLRD sagte in Bug bei Update usw..:
                        hier arbeitet keiner ;-)
                        wie ich schrieb würde ich ein Backup mit backitup erstellen, die neueste Version downloaden, dann neu installieren und das Backup zurückspielen.
                        @Thomas-Braun kann das sicher auch am lebenden Objekt, und da er Armbian nicht so gut kennt, hätte ich das Versuchskarnickel gespielt.
                        Meine Installation ist nicht lebenswichtig
                          @Homoran @BLRD
                          Ich kann ja mal versuchen euch das in die 'Tastaturen zu flüstern'.
                          Zunächst mal schauen, ob nodejs sauber ist:
                          node -v
                          nodejs -v
                          Sollte beides > 12.0.0 sein und die gleiche Version haben.
                          sudo apt install build-essential pkg-config libglib2.0-dev libexpat1-dev
                          wget https://github.com/libvips/libvips/releases/download/v8.10.1/vips-8.10.1.tar.gz
                          tar xf vips-8.10.1.tar.gz
                          cd vips-8.10.1
                          ./configure
                          Wenn da nix böses um die Ecke kommt, dann
                          make
                          sudo make install
                          sudo ldconfig
                            @Homoran @BLRD
                            node -v
                            nodejs -v
                            cd vips-8.10.1
                            ./configure
                            make
                            sudo make install
                            sudo ldconfig
                            das ist ganz lieb von dir!
                            Ich versuche aber gerade von Stretch auf Buster mit Kernel 5.x zu kommen
                              @Homoran sagte in Bug bei Update usw..:
                              Dann müsste da ein Teil der Kompliererei überflüssig sein. Ggf. kann man sharp dann auch ganz normal über npm installieren.
                                das war mein Ziel!
                                ich finde aber deine Anleitung nicht mehr, bei der du irgendwo in einer Datei Stretch mit Buster ersetzt hattest und dann mit update, upgrade und dist-upgrade Buster aufgesetzt hattest.
                                Habe jetzt eine andere Anleitung im Netz gefunden und danach über sed -i 's/stretch/buster/g' /etc/apt/sources.list angepasst.
                                Ob das bei Armbian der richtige Weg war, weiß ich nicht
                                  das war mein Ziel!
                                  Das war die sources.list
                                  Nur ich mach das immer zu Fuß und nicht über sed.
                                  Ist natürlich eleganter, ich kann mir aber die Syntax von sed nie merken...
                                    @Thomas-Braun Danke!
                                    Also müsste das jetzt auch klappen ;-)
                                      @Thomas-Braun So es hat wahrscheinlich geklappt, obwohl...
                                      Nach der apt update usw-Orgie und erneutem Reboot sah es gut aus:
                                      aber der Kernel ist noch 4.4 :-(
                                      In Armbian-config kann man einen Kernel ändern, aber man droht!
                                      Auch nodejs war natürlich noch 10x.
                                      Nach deiner Anleitung in den sources-list die Daten für 12 und 14 eingetragen und sicherheitshalber die 10er und 14er auskommentiert.
                                      Beim anschließenden Update schleicht sich dann doch noch ein stretch repo rein:
                                      pi@rock64:~$ sudo apt update
                                      Hit:1 http://httpredir.debian.org/debian buster InRelease
                                      Hit:2 http://httpredir.debian.org/debian buster-updates InRelease
                                      Hit:3 http://httpredir.debian.org/debian buster-backports InRelease
                                      Hit:4 http://security.debian.org buster/updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
                                      Hit:6 https://mirrors.netix.net/armbian/apt stretch InRelease
                                      Reading package lists... Done
                                      ich habe nicht gefunden wo das jetzt herkommt :-(
                                      deine which Schlange bringt:
                                      pi@rock64:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                      /usr/bin/nodejs
                                      v12.18.4
                                      /usr/bin/node
                                      v12.18.4
                                      /usr/bin/npm
                                      6.14.6
                                      nodejs:
                                        Installed: 12.18.4-1nodesource1
                                        Candidate: 12.18.4-1nodesource1
                                        Version table:
                                       *** 12.18.4-1nodesource1 500
                                              500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
                                           10.21.0~dfsg-1~deb10u1 500
                                              500 http://httpredir.debian.org/debian buster/main arm64 Packages
                                              500 http://security.debian.org buster/updates/main arm64 Packages
                                      Wat nu?
                                      EDIT:
                                      natürlich klappt der install von sharp auch nicht:
                                      pi@rock64:/opt/iobroker$ npm install sharp
                                      ERR! sharp Use with glibc 2.28 requires manual installation of libvips >= 8.10.0
                                      ../src/common.cc:24:10: fatal error: vips/vips8: No such file or directory
                                      make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Error 1
                                      gyp ERR! System Linux 4.4.182-rockchip64
                                      gyp ERR! not ok
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.3 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                                      npm ERR! errno 1
                                      npm ERR!
                                      npm ERR!     /home/pi/.npm/_logs/2020-09-18T16_44_13_676Z-debug.log
                                      EDIT2
                                      der Build von libvips 8.10.1 lief ohne Probleme durch, der nachfolgende Versuch sharp zu installieren schlug weider fehl
                                      gyp ERR! not ok
                                      npm ERR! errno 1
                                      npm ERR!
                                      npm ERR!     /home/pi/.npm/_logs/2020-09-18T16_54_36_024Z-debug.log
                                        /usr/bin/nodejs
                                        v12.18.4
                                        /usr/bin/node
                                        v12.18.4
                                        /usr/bin/npm
                                        6.14.6
                                        nodejs:
                                          Version table:
                                        Wat nu?
                                        EDIT:
                                        gyp ERR! not ok
                                        npm ERR! errno 1
                                        npm ERR!
                                        EDIT2
                                        gyp ERR! not ok
                                        npm ERR! errno 1
                                        npm ERR!
                                        @Homoran Schau mal in /etc/apt/sources.list.d
                                        ob da eine Datei zu finden ist, die
                                        enthält. Da dann auch stretch durch buster ersetzen.
                                          @Thomas-Braun mach ich morgen.
                                          Danke!
