  5. [gelöst] Skript läuft nicht... Lüften oder nicht...
    5.4k
12 Beiträge 6 Kommentatoren 641 Aufrufe 2 Beobachtet
  • D Dragon
      <block type="on_ext" id="i^/*GvdNk0mjVC?nHDj_" x="-1112" y="-1037">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
        <value name="OID0">
          <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_oid" id="H@um[*/98^;(5cdC(Nrg">
          </shadow>
          <block type="get_value" id="DM_+Qob~+lz,SsHE7!/Z">
            <field name="OID">ble.0.58:2d:34:37:a7:42.humidity</field>
          </block>
        </value>
        <value name="OID1">
          <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_oid" id="OC=n};A3I!OtTIvS.Zk+">
          </shadow>
          <block type="get_value" id="o.f#H[Xc*xH:RQe,q~:(">
            <field name="OID">ble.0.58:2d:34:37:aa:c6.humidity</field>
          </block>
        </value>
        <value name="OID2">
          <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_oid" id=":|Ot$RmGik+Q7No7(FrK">
          </shadow>
          <block type="get_value" id="OB_cbp?1b@bZ_0RY3,Ai">
            <field name="OID">ble.0.58:2d:34:37:ad:0a.humidity</field>
          </block>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="~]iX*L~aT64xbBL$%)Lb">
            <value name="IF0">
              <block type="logic_compare" id="iI8TT~mtMboyq]8Ba?Bh">
                <field name="OP">GT</field>
                <value name="A">
                  <block type="convert_tonumber" id="6U8~T1#?#R^Y-?p=q;%r">
                    <value name="VALUE">
                      <block type="get_value" id="H|/~;kIoj*.z_%ANLCt=">
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="math_arithmetic" id="LY/]yax{?`sH-T#/Lcfo">
                    <value name="A">
                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="bej.:/J-W$*]7sySPM.6">
                        <field name="NUM">1</field>
                      </shadow>
                      <block type="convert_tonumber" id="Dl+!jWA]}6]z._n*mI,s">
                          <block type="get_value" id="O#ToH[%T:i`m^IJbSuZ$">
                            <field name="OID">zigbee.0.00158d00044484a0.humidity</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="j)-H7z#@1U4t;C{W5]21">
                      </shadow>
                      <block type="math_arithmetic" id="zHJlV$jv*AqGi7~V;6}{">
                        <field name="OP">MULTIPLY</field>
                        <value name="A">
                          <shadow type="math_number" id="]aTdVSB4)e`I]%6%kx.n">
                            <field name="NUM">3</field>
                          </shadow>
                        </value>
                        <value name="B">
                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="hPib-s;4tp2SgbmCkG`z">
                          </shadow>
                          <block type="math_arithmetic" id="xUs+NS!H9lw5K3%-DTtk">
                            <value name="A">
                              <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="o*)jq8K@p#@(9Q|A.^0a">
                              </shadow>
                              <block type="convert_tonumber" id="5ois]?L6+Ruk2)/O0i#$">
                                  <block type="get_value" id="40fV_Qe.oZZrV*=$adv]">
                                    <field name="OID">ble.0.58:2d:34:37:a7:42.temperature</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="+(UV(=7#7A,wflVgG`7g">
                              </shadow>
                              <block type="convert_tonumber" id="aYeDZ`c`tB3I(-N](N6i">
                                  <block type="get_value" id=".|_9`[bGNTdC/+,N+,6R">
                                    <field name="OID">zigbee.0.00158d00044484a0.temperature</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="update" id=":Tlh534#e1|Pk~:9JBb]">
                <field name="OID">javascript.0.EigeneDatenpunkte.Lueften_Badezimmer</field>
                  <block type="logic_boolean" id="}2QCO|N(9;g/bSWZ.EQ)">
                  </block>
                </value>
              </block>
            </statement>
            <statement name="ELSE">
              <block type="update" id="wxCDXFKE{3/eK*~J/4M~">
                  <block type="logic_boolean" id="TkK;rYU:Zlan,_a^KyNv">
                  </block>
                </value>
              </block>
            </statement>
            <next>
              <block type="controls_if" id="YpF#Qh(9kE:Ev8r{RLC1">
                <value name="IF0">
                  <block type="logic_compare" id="*i{i*3[k!OMb%bA*M+dT">
                    <value name="A">
                      <block type="convert_tonumber" id="mF,I1%k3}ft(?D?~b!i@">
                          <block type="get_value" id="pe8?(b61hns{CBp=wegP">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_arithmetic" id="XuA9kRw^o.xu}[`I~(Y~">
                        <value name="A">
                          </shadow>
                          <block type="convert_tonumber" id="-`[/f)uN[S6o^+}RC|Ho">
                              <block type="get_value" id=")4#*,=[D@/:m![.OZDMf">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                          <block type="math_arithmetic" id="#,@]be5aM]2/0mw2bp].">
                            <value name="A">
                              <shadow type="math_number" id="TZudxS)A5mPO6Y`l.YX|">
                              </shadow>
                            </value>
                            <value name="B">
                              </shadow>
                              <block type="math_arithmetic" id="iXmW9uwdOTe~U=s^IgB.">
                                <value name="A">
                                  </shadow>
                                  <block type="convert_tonumber" id="3KC1|[Cw@th`A5MS70pj">
                                      <block type="get_value" id="HbNA}OCv]z{ia9DIW3Xr">
                                        <field name="OID">ble.0.58:2d:34:37:aa:c6.temperature</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                  <block type="convert_tonumber" id="1]x)FNGMz70]`v6-^8R+">
                                      <block type="get_value" id="?lf=wZ#o-8q?f/Sh9Oh@">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="update" id=";|g{l24~)!*gP8vyhQmT">
                    <field name="OID">javascript.0.EigeneDatenpunkte.Lueften_Schlafzimmer</field>
                      <block type="logic_boolean" id="A1kwNfc/t`aq$_Z!yrTz">
                      </block>
                    </value>
                  </block>
                </statement>
                  <block type="update" id="QinSFT0`EZEM3zdxtM=;">
                      <block type="logic_boolean" id="AzgymN,m9k!p-d5QV[;j">
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block type="controls_if" id="BkvzP.OOpy5~/}8xrbJ`">
                    <value name="IF0">
                      <block type="logic_compare" id=".)Iw.3}|j}PBV{I7AQ#f">
                        <value name="A">
                          <block type="convert_tonumber" id="WBcxJHxoydUkV!gRNcPp">
                              <block type="get_value" id="4P~[(A3BZYV[Xz/Nd2I4">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="math_arithmetic" id="6`AdL[jh#kFk-ST!=Hgc">
                            <value name="A">
                              </shadow>
                              <block type="convert_tonumber" id="IskrFP7!Miz82~t,:B8#">
                                  <block type="get_value" id="c+}S=AJQANxrbuS8S%td">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              </shadow>
                              <block type="math_arithmetic" id="-NhJ2^1[0wF[IO$|,mvg">
                                <value name="A">
                                  <shadow type="math_number" id="/KK(uwpmN:nQ}:a{_y*C">
                                  </shadow>
                                </value>
                                <value name="B">
                                  </shadow>
                                  <block type="math_arithmetic" id="4kij-JZJt{%RCQH*.0hQ">
                                    <value name="A">
                                      </shadow>
                                      <block type="convert_tonumber" id="^Q-~2*L-Y3IZn4OF]wYk">
                                          <block type="get_value" id="Y#XP*/vE:KQQWO_7I?_,">
                                            <field name="OID">ble.0.58:2d:34:37:ad:0a.temperature</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      </shadow>
                                      <block type="convert_tonumber" id="?~%Rlbe1b5_K,3q3EG2x">
                                          <block type="get_value" id="68a]H+AHe}v*_3TWU={B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="update" id="ZGtOMSUYQ2t)?Ty|QpQs">
                        <field name="OID">javascript.0.EigeneDatenpunkte.Lueften_Wohnzimmer</field>
                          <block type="logic_boolean" id=";/Q8N!YfaWd{tSgV8svu">
                          </block>
                        </value>
                      </block>
                    </statement>
                      <block type="update" id="oYEe?HU%C)acgvd^cO5V">
                          <block type="logic_boolean" id="I+bGqe~`C~~`aOy,Cxb#">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    Das Skript läuft nicht. Ich weiß aber nicht wieso. Es soll eigentlich einen Datenpunkt auf wahr oder falsch setzen. Und mit diesem Dann sagen ja es soll gelüftet werden, oder eben nicht.
    Die Zugrunde liegende Formel ist:
    Außen-Luftfeuchtigkeit - 3 * (Innentemperatur - Außentemperatur) => Zu erwartende Innen-Luftfeuchtigkeit.
    Das Ganze kommt von dieser Seite.
    Ich bin etwas ratlos...
    @David-Froebus sagte:
    Dieser einfache Zusammenhang gilt nur in einem begrenzten Temperaturbereich.
      Dragon
      @paul53 Vielen Dank! Das sieht sehr gut aus!
        Dragon
        // Berechnet Taupunkt, absolute Luftfeuchtigkeit, Enthalpie, Lüftungsempfehlung,
        //gemessene Temperatur & Luftfeuctigkeit inkl. Offset zwecks Kalibrierung
        // von paul53 übernommen und angepasst
        // http://forum.iobroker.net/viewtopic.php?f=20&t=2437&hilit=L%C3%BCftung%2A#p21476
        // und Solear: http://forum.iobroker.net/viewtopic.php?f=21&t=2645&p=23381#p23282
        var nn          = 68;                // eigene Höhe nn (normalnull), z.B. über http://de.mygeoposition.com zu ermitteln
        var pfad        = "Raumklima"   +".";   // Pfad unter dem die Datenpunkte in der Javascript-Instanz angelegt werden
        var controlPfad = "CONTROL"     +".";   // Pfad innerhalb des Raums
        var skriptConf  = true;                 // true: Raumwerte werden über das Skript geändert / false: Raumwerte werden über Objekte (oder VIS) geändert
        var defaultTemp = 21.75;                // Default TEMP_Zielwert, wenn im Raum nicht angegeben
        // Räume mit Sensoren
        var raeume = { // Keine Leerzeichen (Name wird als Datenpunktname verwendet!)
            // Sensoren Aussen
            "Terrasse" : {
                "Sensor_TEMP"           :   "zigbee.0.00158d00044484a0.temperature"/*Temperature*/,
                "Sensor_HUM"            :   "zigbee.0.00158d00044484a0.humidity"/*Humidity*/,
                "Sensor_TEMP_OFFSET"    :   0.0,
                "Sensor_HUM_OFFSET"     :   0,
            // Sensoren Innen
            "Badezimmer" : {
                "Sensor_TEMP"           :   "ble.0.58:2d:34:37:a7:42.temperature"/*Temperature*/,
                "Sensor_HUM"            :   "ble.0.58:2d:34:37:a7:42.humidity"/*Humidity*/,
                "TEMP_Zielwert"         :   21.75,
                "Aussensensor"          :   "Terrasse"
            "Wohnzimmer" : {
                "Sensor_TEMP"           :   "ble.0.58:2d:34:37:ad:0a.temperature"/*Temperature*/,
                "Sensor_HUM"            :   "ble.0.58:2d:34:37:ad:0a.humidity"/*Humidity*/,
            "Schlafzimmer" : {
                "Sensor_TEMP"           :   "ble.0.58:2d:34:37:aa:c6.temperature"/*Temperature*/,
                "Sensor_HUM"            :   "ble.0.58:2d:34:37:aa:c6.humidity"/*Humidity*/,
            "Kueche" : {
                "Sensor_TEMP"           :   "zigbee.0.00158d00044500f2.temperature"/*Temperature*/,
                "Sensor_HUM"            :   "zigbee.0.00158d00044500f2.humidity"/*Humidity*/,
             "Flur" : {
                "Sensor_TEMP"           :   "ble.0.58:2d:34:37:ab:0d.temperature"/*Temperature*/,
                "Sensor_HUM"            :   "ble.0.58:2d:34:37:ab:0d.humidity"/*Humidity*/,
        // Skriptbereich. Ab hier muss nichts mehr eingestellt / verändert werden.
        var raumDatenpunkte = {
            "x" : {
                "DpName" : "Feuchtegehalt_Absolut",
                "init": 0,
                "dp": {
                    "name": 'absoluter Feuchtegehalt',
                    "desc": 'absoluter Feuchtegehalt, errechnet',
                    "type": 'number',
                    "role": 'value',
                    "unit": 'g/kg'
            "rh" : {
                "DpName" : "relative_Luftfeuchtigkeit",
                "init": 0,
                "dp": {
                    "name": 'gemessene relative Luftfeuchtigkeit (inkl. Offset)',
                    "desc": 'relative Luftfeuchtigkeit, vom Sensor + Offset zum Ausgleich von Messungenauigkeiten des Geräts',
                    "type": 'number',
                    "role": 'value',
                    "unit": '%'
            "dp" : {
                "DpName" : "Taupunkt",
                "init": 0,
                "dp": {
                    "name": 'Taupunkt',
                    "desc": 'Taupunkt. Temperatur von Wänden, Fenstern, usw. ab der sich die Feuchtigkeit niederschlägt.',
                    "type": 'number',
                    "role": 'value',
                    "unit": '°C'
            "t" : {
                "DpName" : "Temperatur",
                "init": 0,
                "dp": {
                    "name": 'gemessene Temperatur (inkl. Offset)',
                    "desc": 'gemessene Temperatur vom Sensor zzgl. eines Offsets um Geräteungenauigkeiten auszugleichen',
                    "type": 'number',
                    "role": 'value',
                    "unit": '°C'
            "h" : {
                "DpName" : "Enthalpie",
                "init": 0,
                "dp": {
                    "name": 'Enthalpie',
                    "desc": 'Enthalpie',
                    "type": 'number',
                    "role": 'value',
                    "unit": 'kJ/kg'
            "lüften" : {
                "DpName" : "Lüftungsempfehlung",
                "init": false,
                "dp": {
                    "name": 'Lüftungsempfehlung',
                    "desc": 'Lüftungsempfehlung',
                   // "type"  : 'logic',
                    //"role": 'value'
        var raumControl = {
            "Sensor_TEMP_OFFSET" : {
                "DpName" : "Sensor_TEMP_OFFSET",
                "init": 0,
                "dp": {
                    "name": 'Offset Temperatur zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "desc": 'Offset Temperatur zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "type": 'number',
                    "role": 'control.value',
                    "unit": '°C'
            "Sensor_HUM_OFFSET" : {
                "DpName" : "Sensor_HUM_OFFSET",
                "init": 0,
                "dp": {
                    "name": 'Offset Luftfeuchtigkeit zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "desc": 'Offset Luftfeuchtigkeit zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "type": 'number',
                    "unit": '%'
            "TEMP_Zielwert" : {
                "DpName" : "TEMP_Zielwert",
                "init": 0,
                "dp": {
                    "name": 'Temperatursteuerwert zum lüften',
                    "desc": 'Temperatursteuerwert zum lüften',
                    "type": 'number',
                    "unit": '°C'
            "Aussensensor" : {
                "DpName" : "Aussensensor",
                "init": "",
                "dp": {
                    "name": 'Aussensensor, der zum Vergleich genommen wird',
                    "desc": 'Aussensensor, der zum Vergleich genommen wird',
                    "type": 'string',
        var  DP = require('dewpoint');                      // Das Modul dewpoint einlesen
        var xdp = new DP(nn);
        function createDp() {
            var name;
            var init;
            var forceCreation;
            var common;
            for (var raum in raeume) {
                for (var datenpunktID in raumDatenpunkte) {
                    name = pfad + raum + "." + raumDatenpunkte[datenpunktID].DpName;
                    init = raumDatenpunkte[datenpunktID].init;
                    forceCreation = false; // Init der Datenpunkte wird nur beim ersten Star angelegt. Danach bleiben die Wert auch nach Skritpstart enthalten.
                    common = raumDatenpunkte[datenpunktID].dp;
                    createState(name, init , forceCreation, common);
                    log("neuer Datenpunkt: " + name,"debug");
                for (var control in raumControl) {
                    name = pfad + raum + "." + controlPfad + raumControl[control].DpName;
                    //init = raumControl[control].init;
                    forceCreation = skriptConf;
                    common = raumControl[control].dp;
                    if (typeof raeume[raum][raumControl[control].DpName] !=="undefined") {
                        init = raeume[raum][raumControl[control].DpName];
        function runden(val, digits) {
            return Math.round(val * Math.pow(10, digits)) / Math.pow(10, digits);
        function calc(raum) {                                           // Über Modul Dewpoint absolute Feuchte berechnen
            var t           = getState(raeume[raum].Sensor_TEMP).val;   // Temperatur auslesen
            var rh          = getState(raeume[raum].Sensor_HUM).val;    // Feuchtigkeit relativ auslesen
            var y           = xdp.Calc(t, rh);
            var toffset     = 0.0;                                      // Offset in °C
            var rhoffset    = 0;                                        // Offset in %
            if(typeof raeume[raum].Sensor_TEMP_OFFSET !=="undefined") {
                var idtoffset = pfad + raum + "." + controlPfad + "Sensor_TEMP_OFFSET";
                toffset = getState(idtoffset).val;  // Offset aus den Objekten/Datenpunkt auslesen
            if(typeof raeume[raum].Sensor_HUM_OFFSET !=="undefined") {
                var idrhoffset = pfad + raum + "." + controlPfad + "Sensor_HUM_OFFSET";
                rhoffset = getState(idrhoffset).val;  // Offset aus den Objekten/Datenpunkt auslesen
            t       = t     + toffset;
            rh      = rh    + rhoffset;
            var x   =  y.x;                                 // Zu errechnende Variable für Feuchtegehalt in g/kg
            var dp  = y.dp;                                 // Zu errechnende Variable für Taupunkt in °C
            var h   = 1.00545 * t + (2.500827 + 0.00185894 * t) * x;
            var idx     = pfad + raum + "." + raumDatenpunkte["x"].DpName;
            var iddp    = pfad + raum + "." + raumDatenpunkte["dp"].DpName;
            var idt     = pfad + raum + "." + raumDatenpunkte["t"].DpName;
            var idrh    = pfad + raum + "." + raumDatenpunkte["rh"].DpName;
            var ih      = pfad + raum + "." + raumDatenpunkte["h"].DpName;
            setState(idx    , runden(x,2));     // errechnete absolute Feuchte in Variable schreiben
            setState(iddp   , runden(dp,1));    // errechneter Taupunkt in Variable schreiben
            setState(idt    , t);               // Sensor Temperatur        inkl. Offset
            setState(idrh   , rh);              // Sensor Relative Feuchte  inkl. Offset
            setState(ih     , runden(h,2));     // Enthalpie
            // Lüften
            if(typeof raeume[raum].Aussensensor !=="undefined") {
                var aussen = raeume[raum].Aussensensor;
                var idta = pfad + aussen + "." + raumDatenpunkte["t"].DpName;
                var idxa = pfad + aussen + "." + raumDatenpunkte["rh"].DpName;
            } else {
                return;
            var ti = t;                     // Raumtemperatur in °C
            var xi = rh;                    // Raumfeuchtegehalt in g/kg
            var ta = getState(idta).val;    // Aussentemperatur in °C
            var xa = getState(idxa).val;    // Aussenfeuchtegehalt in g/kg
            if (xa === 0) return;
            var mi = defaultTemp;           // Temperaturmittelwert auf Default
            if(typeof raeume[raum].TEMP_Zielwert !=="undefined") {
                mi = raeume[raum].TEMP_Zielwert;
            var mih = mi + 0.25; // Temperaturmittelwert hoch
            var mit = mi - 0.25; // Temperaturmittelwert tief
            var idLueften = pfad + raum + "." + raumDatenpunkte["lüften"].DpName;
            // Lüftungsempfehlung steuern mit 0,3 g/kg und 0,5 K Hysterese
            if      (xa <= (xi - 0.4) && ta <= (ti - 0.6) && ti >= mih) setState(idLueften, true);
            else if (xa >= (xi - 0.1) || ta >= (ti - 0.1) || ti <= mit) setState(idLueften, false);
            log("Raum: " + raum+", ti:"+ti+", ta: "+ta+", xi:"+xi+", xa: "+xa+", mih:"+mih+", mit:"+mit,"debug");
        function calcAll () {
                calc(raum);
        on({id: idSensorTemperaturBad   ,change:'ne'}, function (obj) {
            calc();
        {1}
        on({id: idSensorLuftfeuchteBad  ,change:'ne'}, function (obj) {
            calc();
        // alle 30 Minuten neu berechnen
        schedule("30 * * * *", function () {
            calcAll();
        function main() {
            calcAll();
            calcAll();
        createDp();                 // Datenpunkte anlegen
        setTimeout(main,    500);   // Zum Skriptstart ausführen
        Folgende Fehlermeldung:
        javascript.0 2020-09-14 18:47:59.084 error (15655) at Script.runInContext (vm.js:130:18)
        javascript.0 2020-09-14 18:47:59.084 error (15655) at script.js.common.Komfort.Lüften:192:11
        javascript.0 2020-09-14 18:47:59.083 error (15655) TypeError: DP is not a constructor
        javascript.0 2020-09-14 18:47:59.083 error (15655) ^
        javascript.0 2020-09-14 18:47:59.083 error (15655) var xdp = new DP(nn);
        javascript.0 2020-09-14 18:47:59.082 error (15655) script.js.common.Komfort.Lüften: script.js.common.Komfort.Lüften:192
        javascript.0 2020-09-14 18:47:59.078 error (15655) at Script.runInContext (vm.js:130:18)
        javascript.0 2020-09-14 18:47:59.077 error (15655) at script.js.common.Komfort.Lüften:191:11
        javascript.0 2020-09-14 18:47:59.077 error (15655) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:390:36)
        javascript.0 2020-09-14 18:47:59.076 error (15655) at require (internal/modules/cjs/helpers.js:72:18)
        javascript.0 2020-09-14 18:47:59.076 error (15655) at Module.require (internal/modules/cjs/loader.js:1025:19)
        javascript.0 2020-09-14 18:47:59.075 error (15655) script.js.common.Komfort.Lüften: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../dewpoint'
          Dragon
          zweites skript. eigentlich selbe funktion:
          // Raumklima - v0.6.5
          // gemessene Temperatur & Luftfeuchtigkeit inkl. Offset zwecks Kalibrierung
          // benötigt in der Javascript das Modul "dewpoint"
          // (in der Javascript-Instanz Einstellungen unter "Zusätzliche NPM-Module")
          // Formeln zur Berechnung der Luftfeuchtigkeit:
          // http://www.nabu-eibelshausen.de/Rechner/feuchte_luft_enthalpie.html
          // Empfehlung Paul53:
          // Kalibrierung der Offsetwerte in einer für den Vergleich relevanten Umgebung
          // z.B. 22°C, 65% Luftfeuchte (nicht im Winter).
          // gute Infos zum Raumklima:
          // https://www.energie-lexikon.info/luftfeuchtigkeit.html
          // http://www.energiebuero-online.de/bauphysik/richtigluften.htm
          // Autoren des Skripts:
          // - Paul53:
          //   Formeln, Idee, Experte im Bereich Raumklima, Korrekturen am gr. Skript
          // - Solear:
          //   Zusammenfassung der Skripte/Formeln von Paul53
          // - ruhr70:
          //   Ein Skript für alle vorhandenen Räume
          // - eric 2905:
          //   Optimierungen, viele neue Ideen, JSON-Ausgabe, globale Datenpunkte
          // - Andy3268:
          //   Hinzufügen der 4.ten Bedingung für Raumfuchte Grenzwerte
          // https://forum.iobroker.net/topic/2313/skript-absolute-feuchte-berechnen/437
          // TODO:
          // - Verzicht auf das node module ""dewpoint"
          // - Einstellungen Hysterese (Expertenmodus)
          // - setState / getState, die es nicht gibt: Fehler abfangen und Warnung ausgeben, damit der Adapter sich nicht beendet
          // - Luftdruck alternativ vom Messgerät und nicht über Skript (ggf. per Raum)
          // - Auswählbar: Datenpunkte ohne Einheit (zusätzlich) erzeugen (z.B. für vis justgage, value & indicator)
          // - Auswählbar:
          //   Zweig Raum:    NICHT anlegen
          //   JSON:          NICHT anlegen
          //   DETAILS:       NICHT anlegen
          //   CONTROL:       NICHT anlegen
          // - JSON wird recht groß: ggf. Datenpunkte für JSON auswählbar machen
          // - ggf. JSON nicht als String zusammenbauen, sondern als json-Objekt (dann JSON.stringify(json))
          // - Zähler einbauen: Anzahl Räume in Hysterese (Grenzbereich)
          // # "Lüftungsengine":
          // - möglichst an die individuellen Situationen und Vorlieben anpassbar
          // - differenziertere Lüftungsempfehlung
          // - CO2, Luftgüte einbeziehen
          // - Experteneinstellungen (welche Werte sind einem wichtig)
          // - Modus mit Werten/Prioritäten (wie dringend muss gelüftet werden)
          // - Kellerentlüftung einbauen (Raum markierbar als Keller)
          // - Sommer / Winter (Heizperiode) berücksichtigen
          // - dringend lüften, ab 70% rel. Luftfeuchtigkeit und geeigneter Außenluft (Vergl. absolute Luftfeuchtigkeit)
          // - Massnahme: zu trockene Luft (rel. Luftfeuchtigkeit < 40%)
          // - Massnahme: Luft rel. Feuch > 60% oder 65% (?)
          // - Feuchtigkeitstrend berücksichtigen. Ist ie Tendenz fallend, Bedingung "Entfeuchten" überstimmen.
          // Ideensammlung Lüftungsengine
          // - zentraler Datenpunkt: Heizperiode
          // - je Raum eine opt. Datenpunkt für eine zugeordnete Heizung (Zieltemperatur und Heizung an/aus)
          // - je Raum die Wunschtemperatur
          // - Prio: schlechte Luftqualität
          // - Prio: kühlen, wenn Temperaturunterschied zu groß
          // - Prio: zu trockene Luft (rel.)
          // - Prio: zu feuchte Luft (rel.)
          // berücksichtigen / Beobachtungen:
          // wenn draussen zu kalt ist, macht das lüften tlw. keinen Sinn mehr
          // wenn die Zimmertemperatur bis zum Minimum abkühlt kann torz Unterschid xi/xa
          // xi und die rel. Luftfeuchte weiter steigen, da die dann kältere Raumluft weniger
          // Luftfeuchtigkeittragen kann.
          // Einstellungen Skriptverhalten, eigene Parameter -  !! bitte anpassen !!
          // Wichtig:                             // betrifft den CONTROL Zweig bei den Raumdatepunkten (Offsets, Raummindestemperatur (Auskühlschutz))
          var skriptConf  = true;                 // Anwender kann sich aussuchen, ob er die Werte im Skript oder über die Objekte pflegen möchte
                                                 // true:  Raumwerte werden über das Skript geändert/überschrieben (var raeume)
                                                 // false: Raumwerte werden über Objekte (z.B. im Admin, Zustände oder VIS) geändert
          var debug = false;                      // true: erweitertes Logging einschalten
          // eigene Parameter:
          var hunn            = 68;           // eigene Höhe über nn (normalnull), z.B. über http://de.mygeoposition.com zu ermitteln
          var defaultTemp     = 18.00;     // Default TEMP_Minimum, wenn im Raum nicht angegeben (Auskühlschutz, tiefer soll eine Raumtemperatur durchs lüften nicht sinken)
          var defaultMinFeu   = 45.00;     // Default Mindest Feuchte wenn nicht angegeben.
          var defaultMaxFeu   = 55.00;     // Default Maximal Feuchte wenn nicht angegeben.
          var cronStr         = "*/30 * * * *";       // Zeit, in der alle Räume aktualisiert werden (da auf Änderung der Sensoren aktualisiert wird, kann die Zeit sehr hoch sein)
          var strDatum        = "DD-MM-JJJJ SS:mm:ss";// Format, in dem das Aktualisierungsdatum für das JSON ausgegeben wird
          // ### Experteneinstellungen ###
          // Lüftungsengine
          var hysMinTemp      = 0.5;              // Default 0.5, Hysterese Mindesttemperatur (Auskühlschutz). Innerhalb dieser Deltatemperatur bleibt die alte Lüftungsempfehlung für den Auskühlschutz bestehen.
          var hysEntfeuchten  = 0.2;              // Default 0.3, Hysterese Entfeuhten: Delta g/kG absolute Luftfeuchte. In dem Delta findet keine Änderung der alten Lüftungsempfehlung statt
          // Skriptverhalten
          var delayRooms      = 500;              // Zeit in ms als Verzögerung, wie die Räume abgearbeitet werden
          // Pfade für die Datenpunkte:
          // Unterpfade unterhalb des Hauptpfads
          var raumPfad    = "Raum"        +".";   // Pfad unterhalb des Hauptpfads für die Räume
          var controlPfad = "CONTROL"     +".";   // Pfad innerhalb des Raums für Kontrollparameter
          var detailPfad  = "DETAILS"     +".";   // Pfad innerhalb des Raums für Detailparameter ("" und ohne ".", wenn kein Detailpfad gewünscht)
          var detailEnginePfad = "DETAILS_Lüftungsempfehlung" + "."; // Pfad innerhalb des Raums für Detailparameter zur Lüftungsengine
          var infoPfad    = "Skriptinfos" +".";   // Pfad für globale Skriptparameter zur Info
          // Räume mit Sensoren, Parametrisierung -           !! bitte anpassen !!
          // jeder Sensor darf nur einmal verwendet werden!
          // wird kein Aussensensor angegeben, wird der Sensor als Aussensensor behandelt!
              // Sensoren Aussen
              "Terrasse" : {
              // Sensoren Innen
              "Badezimmer" : {
                  "TEMP_Minimum"         :   defaultTemp, // oder Zieltemperatur in Form von: 20.00 angeben
              "Wohnzimmer" : {
              "Schlafzimmer" : {
              "Kueche" : {
               "Flur" : {
          var idSkriptinfoBar         = pfad + infoPfad + "Luftdruck";
          var idSkriptinfoHunn        = pfad + infoPfad + "Höhe_über_NN";
          // forceCreation = true, damit bei geändert eigener Höhe im Konfigurationsbereich der Datenpunkt neu geschrieben wird
          createState(idSkriptinfoBar, luftdruck(hunn), true, {
             name: 'mittlerer Luftdruck in bar',
             desc: 'mittlerer Luftdruck in bar, errechnet anhand der eigenen Höhe über NN',
             type: 'number',
             unit: 'bar',
             role: 'info'
          createState(idSkriptinfoHunn, hunn, true, {
             name: 'Eigene Höhe über NN',
             desc: 'Eigene Höhe über NN (Normal Null), als Basis für den mittleren Luftdruck',
             type: 'number',
             unit: 'm',
             role: 'info'
             "x" : {
                 "init": 0,
                 "dp": {
                     "type": 'number',
                     "role": 'value',
                     "unit": 'g/kg'
             "rh" : {
                 "init": 0,
                 "dp": {
                     "type": 'number',
                     "role": 'value',
                     "unit": '%'
             "dp" : {
                 "init": 0,
                 "dp": {
                     "name": 'Taupunkt',
                     "type": 'number',
                     "role": 'value',
                     "unit": '°C'
             "t" : {
                 "init": 0,
                 "dp": {
                     "type": 'number',
                     "role": 'value',
                     "unit": '°C'
             "h" : {
                 "DpName" : detailPfad + "Enthalpie",
                 "init": 0,
                 "dp": {
                     "type": 'number',
                     "role": 'value',
                     "unit": 'kJ/kg'
             "sdd" : {
                 "DpName" : detailPfad +"Sättigungsdampfdruck",
                 "init": 0,
                 "dp": {
                     "name": 'Sättigungsdampfdruck',
                     "desc": 'Sättigungsdampfdruck',
                     "type": 'number',
                     "role": 'value',
                     "unit": 'hPa'
             "dd" : {
                 "DpName" : detailPfad + "Dampfdruck",
                 "init": 0,
                 "dp": {
                     "name": 'Dampfdruck',
                     "desc": 'Dampfdruck',
                     "type": 'number',
                     "role": 'value',
                     "unit": 'hPa'
             "rd" : {
                 "DpName" : "Dampfgewicht",
                 "init": 0,
                 "dp": {
                     "name": 'Dampfgewicht (Wassergehalt)',
                     "desc": 'Dampfgewicht (Wassergehalt)',
                     "type": 'number',
                     "role": 'value',
                     "unit": 'g/m³'
             "maxrd" : {
                 "DpName" : detailPfad + "Dampfgewicht_maximal",
                 "init": 0,
                 "dp": {
                     "name": 'max. Dampfgewicht (Wassergehalt)',
                     "desc": 'max. Dampfgewicht (Wassergehalt) bei aktueller Temperatur',
                     "type": 'number',
                     "role": 'value',
                     "unit": 'g/m³'
             "lüften" : {
                 //"init": false,
                 "dp": {
                     "type": 'boolean',
                     "role": 'value'
             "lüften_b1" : {
                 "DpName" : detailEnginePfad + "Lüften_b1_Entfeuchten",
                 //"init": false,
                 "dp": {
                     "name": 'Lüften Bedingung 1 entfeuchten',
                     "desc": 'Lüften Bedingung 1 entfeuchten erfüllt',
                     "type": 'boolean',
                     "role": 'value'
             "lüften_b2" : {
                 "DpName" : detailEnginePfad + "Lüften_b2_Kühlen",
                 //"init": false,
                 "dp": {
                     "name": 'Lüften Bedingung 2 kühlen',
                     "desc": 'Lüften Bedingung 2 kühlen erfüllt',
                     "type": 'boolean',
                     "role": 'value'
             "lüften_b3" : {
                 "DpName" : detailEnginePfad + "Lüften_b3_Auskühlschutz",
                 //"init": false,
                 "dp": {
                     "name": 'Lüften Bedingung 3 Auskühlschutz',
                     "desc": 'Lüften Bedingung 3 Auskühlschutz erfüllt (Innentemperatur soll nicht unter Minimumteperatur fallen)',
                     "type": 'boolean',
                     "role": 'value'
             "lüften_b4" : {
                 "DpName" : detailEnginePfad + "Lüften_b4_Raumfeuchte",
                 //"init": false,
                 "dp": {
                     "name": 'Lüften Bedingung 4 Raumfeuchte',
                     "desc": 'Lüften Bedingung 4 Raumfeuchte erfüllt',
                     "type": 'boolean',
                     "role": 'value'
             "lüften_Hysterese" : {
                 "DpName" : detailEnginePfad + "Lüften_Hysterese",
                 //"init": false,
                 "dp": {
                     "name": 'Logik im Bereich der Hysterese. Keine Änderung der bestehenden Lüftungsempfehlung.',
                     "desc": 'Logik im Bereich der Hysterese. Keine Änderung der bestehenden Lüftungsempfehlung.',
                     "type": 'boolean',
                     "role": 'value'
             "lüften_Beschreibung" : {
                 "DpName" : detailEnginePfad + "Lüftungsempfehlung_Beschreibung",
                 "init": "",
                 "dp": {
                     "name": 'Lüftungsempfehlung beschreibender Text',
                     "desc": 'Lüftungsempfehlung beschreibender Text',
                     "type": 'string',
                     "role": 'value'
             // #1 - Entfeuchten:    Außenluft ist mind. (hysEntfeuchten + 0,1) trockener als Innen
             // #2 - Kühlen:         Außentemperatur ist mindestens 0,6 Grad kühler als innen TODO: im Winter auch?
             // #3 - Auskühlschutz:  Innentemperatur ist höher als die Mindesttemperatur
          var raumControl = {
                 "init": 0,
                 "dp": {
                     "type": 'number',
                     "unit": '°C'
                 "init": 0,
                 "dp": {
                     "type": 'number',
                     "unit": '%'
             "TEMP_Minimum" : {
                 "DpName" : "TEMP_Minimum",
                 "init": 0,
                 "dp": {
                     "name": 'Auskühlschutz Mindestraumtemperatur',
                     "desc": 'Auskühlschutz Mindestraumtemperatur zum lüften',
                     "type": 'number',
                     "unit": '°C'
             "FEUCH_Minimum" : {
                 "DpName" : "FEUCH_Minimum",
                 "init": 0,
                 "dp": {
                     "name": 'Mindest Rel. Raumfeuchte',
                     "desc": 'Mindest Rel. Raumfeuchte zum lüften',
                     "type": 'number',
                     "unit": '%'
             "FEUCH_Maximum" : {
                 "DpName" : "FEUCH_Maximum",
                 "init": 0,
                 "dp": {
                     "name": 'Maximal Rel. Raumfeuchte ',
                     "desc": 'Maximal Rel. Raumfeuchte zum lüften',
                     "type": 'number',
                     "unit": '%'
             "Aussensensor" : {
                 "init": "",
                 "dp": {
                     "type": 'string',
          // globale Skript-Variablen/Objekte
          var xdp     = new DP(hunn);
          var pbar    = luftdruck(hunn);          // individueller Luftdruck      in bar (eigene Höhe)
          // Funktionen
          function writeJson(json) {
             return JSON.stringify(json);
          // prüft ob setObjects() für die Instanz zur Verfügung steht (true/false)
          function checkEnableSetObject() {
             var enableSetObject = getObject("system.adapter.javascript." + instance).native.enableSetObject;
             return enableSetObject;
          function setChannelName(channelId,channelName){
             if(checkEnableSetObject()) { // wenn setObject nicht in der Instanz freigeschaltet ist, wird der Channel nicht angelegt
             // CHANNEL anlegen
                 setObject("javascript." + instance + "." + channelId, {
                     common: {
                     type: 'channel'
                 }, function(err) {
                     if (err) logs('Cannot write object: ' + err,"error");
          function lueftenDp(datenpunktID) {
             return (datenpunktID == "lüften") || (datenpunktID == "lüften_Beschreibung") || (datenpunktID == "lüften_b1") || (datenpunktID == "lüften_b2") || (datenpunktID == "lüften_b3") || (datenpunktID == "lüften_b4") || (datenpunktID ==  "lüften_Hysterese");
             var name;
             var init;
             var forceCreation;
             var common;
                     name = pfad + raumPfad + raum + "." + raumDatenpunkte[datenpunktID].DpName;
                     if (lueftenDp(datenpunktID)) {
                         if (!raeume[raum].Aussensensor) {
                             if (datenpunktID == "lüften") {
                                 log(raum + ": kein Aussensensor angegeben.  ### Messpunkte werden als Aussensensoren behandelt. ###","info"); // Warnung ist im Log OK, wenn es sich um einen Außensensor handelt.
                                 setChannelName(pfad + raumPfad + raum,"Aussensensor");
                         } else {
                             if (debug) log("neuer Datenpunkt: " + name);
                     } else {
                     name = pfad + raumPfad + raum + "." + controlPfad + raumControl[control].DpName;
                         var channelname = "Nur Info. Werte aus dem Skript zählen. Kann im Skript umgestellt werden.";
                         if (!skriptConf) channelname = "Änderungen hier in den Objekten werden berechnet";
                         setChannelName(pfad + raumPfad + raum + "." + controlPfad.substr(0, controlPfad.length-1),channelname);
             //eric2905 Datenpunkt "Lüften" erzeugen
             createState(pfad + 'Lüften', false, {
              name: 'Muss irgendwo gelüftet werden',
              desc: 'Muss irgendwo gelüftet werden',
              type: 'boolean',
              unit: '',
              role: 'value'
             createState(pfad + 'Lüften_Liste', "[]", {
              name: 'Liste der Räume in denen gelüftet werden muss',
              desc: 'Liste der Räume in denen gelüftet werden muss',
              type: 'string',
              unit: '',
              role: 'value'
             // eric2905 Ende -----------------------------------------------------------
             //eric2905 Datenpunkt "JSON" erzeugen
             createState(pfad + 'JSON', "", {
              name: 'JSON-Ausgabe aller Werte',
              desc: 'JSON-Ausgabe aller Werte',
              type: 'string',
              unit: '',
              role: 'value'
             //eric2905 Datenpunkt "Aktualsierung" erzeugen
             createState(pfad + 'Aktualsierung', "", {
              name: 'Aktualisierungszeitpunkt der JSON-Ausgabe',
              desc: 'Aktualisierungszeitpunkt der JSON-Ausgabe',
              type: 'string',
              unit: '',
              role: 'value'
             //eric2905 Datenpunkt "countLueften" erzeugen
             createState(pfad + 'Lüften_Anzahl', 0, {
              name: 'Anzahl Lüftungsempfehlungen',
              desc: 'Anzahl Lüftungsempfehlungen',
              type: 'number',
              unit: '',
              role: 'value'
             log("Datenpunkte angelegt");
          // rundet einen Float auf eine bestimmte Anzahl Nachkommastellen
          function runden(wert,stellen) {
             return Math.round(wert * Math.pow(10,stellen)) / Math.pow(10,stellen);
          // berechnet den mittleren Luftdruck für eine Höhenangabe in NN
          function luftdruck(hunn) {
             var pnn         = 1013.25;                                  // Mittlerer Luftdruck          in hPa bei NN
             var p           = pnn - (hunn / 8.0);                       // individueller Luftdruck      in hPa (eigenen Höhe)
             return p / 1000;                                            // Luftdruck von hPa in bar umrechnen
          // Color Boolean (farbige Ausgabe Boolean als String, z.B. für das Log)
          function cob(boolean) {
             var cobStr = (boolean) ? '<span style="color:lime;"><b>true</b></span>' : '<span style="color:red;"><b>false</b></span>';
             return cobStr;
          function makeNumber(wert) {
             if(isNaN(wert)) {
                 wert = parseFloat(wert.match(/\d+[.|,]?\d+/g));
             return wert;
          // Berechnungen Luftwerte
          function calcSaettigungsdampfdruck(t) {    // benötigt die aktuelle Temperatur
             // Quelle: http://www.wetterochs.de/wetter/feuchte.html#f1
             var sdd,a,b;
             a = 7.5;
             b = 237.3;
             sdd = 6.1078 * Math.pow(10,((a*t)/(b+t)));
             return sdd; // ssd = Sättigungsdampfdruck in hPa
          function calcDampfdruck(sdd,r) {
             var dd = r/100 *sdd;
             return dd;  // dd = Dampfdruck in hPa
          function calcTemperaturKelvin(t) {
             var tk = t + 273.15;
             return tk;
          function calcDampfgewicht(dd,t) { // Wassergehalt
             // Dampfgewicht rd oder AF(r,TK) = 10^5 * mw/R* * DD(r,T)/TK
             var tk = calcTemperaturKelvin(t);
             var mw = 18.016; // kg/kmol (Molekulargewicht des Wasserdampfes)
             var R  = 8314.3; // J/(kmol*K) (universelle Gaskonstante)
             var rd = Math.pow(10,5) * mw/R * dd/tk;
             return rd; // rd = Dampfgewicht in g/m^3
          function calcMaxDampfgewicht(rd,r) {
             var maxrd = rd / r *100;
             return maxrd;
          // Berechnung: alle Werte je Raum
             t   = makeNumber(t);                                        // Temperatur in Number umwandeln
             rh  = makeNumber(rh);                                       // relative Luftfeuchtigkeit in Number umwandeln
             var toffset     = 0.0;                                      // Default Offset in °C
             var rhoffset    = 0;                                        // Default Offset in %
                 // Temperatur, wenn ein Offset vorhanden ist, diesen auslesen und Default überschreiben
                 var idtoffset = pfad + raumPfad+ raum + "." + controlPfad + "Sensor_TEMP_OFFSET";
                 // Luftfeuchtigkeit, wenn ein Offset vorhanden ist, diesen auslesen und Default überschreiben
                 var idrhoffset = pfad + raumPfad + raum + "." + controlPfad + "Sensor_HUM_OFFSET";
             t       = t     + toffset;      // Messwertanpassung: gemessene Temperatur um den Offset ergänzen
             rh      = rh    + rhoffset;     // Messwertanpassung: gemessene relative Luftfeuchtigkeit um Offset ergänzen
             var h       = 1.00545 * t + (2.500827 + 0.00185894 * t) * x;    // Enthalpie in kJ/kg berechnen
             var sdd     = calcSaettigungsdampfdruck(t);                     // Sättigungsdampfdruck in hPa
             var dd      = calcDampfdruck(sdd,rh);                           // dd = Dampfdruck in hPa
             var rd      = calcDampfgewicht(dd,t);                           // rd = Dampfgewicht/Wassergehalt in g/m^3
             var maxrd   = calcMaxDampfgewicht(rd,rh);                       // maximales Dampfgewicht in g/m^3
             var idx     = pfad + raumPfad + raum + "." + raumDatenpunkte["x"].DpName;   // DP-ID absolute Luftfeuchte in g/kg
             var iddp    = pfad + raumPfad + raum + "." + raumDatenpunkte["dp"].DpName;  // DP-ID Taupunkt in °C
             var idt     = pfad + raumPfad + raum + "." + raumDatenpunkte["t"].DpName;   // DP-ID Temperatur inkl. Offset
             var idrh    = pfad + raumPfad + raum + "." + raumDatenpunkte["rh"].DpName;  // DP-ID relative Luftfeuhtigkeit inkl. Offset
             var ih      = pfad + raumPfad + raum + "." + raumDatenpunkte["h"].DpName;   // DP-ID Enthalpie in kJ/kg
             var isdd    = pfad + raumPfad + raum + "." + raumDatenpunkte["sdd"].DpName;
             var idd     = pfad + raumPfad + raum + "." + raumDatenpunkte["dd"].DpName;
             var ird     = pfad + raumPfad + raum + "." + raumDatenpunkte["rd"].DpName;
             var imaxrd  = pfad + raumPfad + raum + "." + raumDatenpunkte["maxrd"].DpName;
             setState(idx    , runden(x,2));     // errechnete absolute Feuchte in Datenpunkt schreiben
             setState(iddp   , runden(dp,1));    // errechneter Taupunkt in Datenpunkt schreiben
             setState(idt    , parseFloat(t));   // Sensor Temperatur        inkl. Offset
             setState(idrh   , parseFloat(rh));   // Sensor Relative Feuchte  inkl. Offset
             setState(ih     , runden(h,2));     // Enthalpie in kJ/kg
             setState(isdd   , runden(sdd,2));
             setState(idd    , runden(dd,2));
             setState(ird    , runden(rd,2));
             setState(imaxrd , runden(maxrd,2));
             // Logik-Engine: Lüftungsempfehlung berechnen
                 // kein Aussensensor, keine Lüftungsempfehlung
                 if (debug) log("<b>------ " + raum + " ------- Aussen, keine Lüftungsempfehlung -----------</b>");
                 return;
             var aussen;
             var idta, idxa;
                 aussen = raeume[raum].Aussensensor; // aussen = "Raumname" des zugehörigen Aussensensors
                 idta = pfad + raumPfad + aussen + "." + raumDatenpunkte["t"].DpName;    // DP-ID zugehöriger Aussensensor, Temperatur aussen
                 idxa = pfad + raumPfad + aussen + "." + raumDatenpunkte["x"].DpName;    // DP-ID zugehöriger Aussensensor, Luftfeuchtigkeit aussen
             } else {
                 return; // wenn es keinen zugehörigen Aussensensor gibt, Funktion beenden (dann muss kein Vergleich berechnet werden)
             var xi = runden(x,2);           // Raumfeuchtegehalt in g/kg
             if (xa == 0) return;            // TODO: warum? hatte ich leider nciht dokumentiert (ruhr70)
             var mi = defaultTemp;           // Temperaturmindestwert auf Default (Auskühlschutz)
             var xh = defaultMaxFeu;         // Feuchtemaximalwert auf Default
             var xt = defaultMinFeu;         // Feuchteminimalwert auf Default
             //if(typeof raeume[raum].TEMP_Minimum !=="undefined") {
             if(typeof raeume[raum].TEMP_Minimum == "number") {
                 mi = raeume[raum].TEMP_Minimum;
             if(typeof raeume[raum].FEUCH_Maximum == "number") {
                 xh = raeume[raum].FEUCH_Maximum;
             if(typeof raeume[raum].FEUCH_Minimum == "number") {
                 xt = raeume[raum].FEUCH_Minimum;
             // Auskühlschutz,  hysMinTemp (Variable) Grad hysMinTemp Hysterese. Tiefer darf die Innentemperatur nicht sinken
             var mih = mi + hysMinTemp;      // Temperaturmindestwert hoch (Mindesttemperatur plus Hysterese)
             var mit = mi;                   // Temperaturmindestwert tief
             var idLueften       = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften"].DpName;
             var idLueftenText   = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften_Beschreibung"].DpName;
             var idLueftenB1     = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften_b1"].DpName;
             var idLueftenB2     = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften_b2"].DpName;
             var idLueftenB3     = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften_b3"].DpName;
             var idLueftenB4     = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften_b4"].DpName;
             var idLueftenHys    = pfad + raumPfad + raum + "." + raumDatenpunkte["lüften_Hysterese"].DpName;
             var lueftenText     = "";
             // Lüftungslogik
             // Bedigungen fürs lüften
             var b1lp = (xa <= (xi - (hysEntfeuchten + 0.1)))    ? true : false;   // Bedingnung 1 lüften positv (Außenluft ist mind. 0,4 trockener als Innen)
             var b2lp = (ta <= (ti - 0.6))                       ? true : false;   // Bedingnung 2 lüften positv (Außentemperatur ist mindestens 0,6 Grad kühler als innen)
             var b3lp = (ti >= mih)                              ? true : false;   // Bedingnung 3 lüften positv (Innentemperatur ist höher als die Minimumtemperatur + Hysterese)
             var b4lp = (rh >= xh)                               ? true : false;   // Bedingnung 4 lüften positv (Relative Raumfeuchte ist höher als die Maximalfeuchtewert)
             var b1lpText = "Entfeuchten:    Außenluft ist mind. 0,4 trockener als Innen";
             var b2lpText = "Kühlen:         Außentemperatur ist mindestens 0,6 Grad kühler als innen";
             var b3lpText = "Auskühlschutz:  Innentemperatur ist höher als die Mindesttemperatur";
             var b4lpText = "Raumfeuchte:    Raumfeuchte ist höher als der Maximalfeuchte";
             setState(idLueftenB1,b1lp);
             setState(idLueftenB2,b2lp);
             setState(idLueftenB3,b3lp);
             setState(idLueftenB4,b4lp);
             // Bedingungen gegen das Lüften
             var b1ln = (xa >= (xi - 0.1))   ? true : false;   // Bedingnung 1 lüften negativ (Außenluft ist zu feucht)
             var b2ln = (ta >= (ti - 0.1))   ? true : false;   // Bedingnung 2 lüften negativ (Außentemperatur zu warm)
             var b3ln = (ti <= mit)          ? true : false;   // Bedingnung 3 lüften negativ (Innentemperatur niedriger als Mindesttemperatur)
             var b4ln = (rh <= xt)           ? true : false;   // Bedingnung 4 lüften negativ (Relative Raumfeuchte ist niedriger als die Mindestfeuchte)
             var b1lnText = "Entfeuchten:    Außenluft ist zu feucht";
             var b2lnText = "Kühlen:         Außentemperatur zu warm";
             var b3lnText = "Auskühlschutz:  Innentemperatur niedriger als Mindestraumtemperatur";
             var b4lnText = "Raumfeuchte:    Raumfeuchte ist niedriger als der Mindestfeuchte";
             // Logik:
             if (b1lp && b2lp && b3lp && b4lp) {
                 // Lüftungsempfehlung, alle bedingungenen erfüllt
                 lueftenText = "Bedingungen für Entfeuchten, Kühlen und Auskühlschutz erfüllt.";
                 setState(idLueftenHys,false);
                 if (debug) log(raum + ': <span style="color:limegreen;"><b>Lüftungsempfehlung</b></span>');
             } else if (b1ln || b2ln || b3ln || b4ln) {
                 // Fenster zu. Ein Ausschlusskriterium reicht für die Empfehlung "Fenster zu".
                 lueftenText = "Fenster zu:<br>";
                 if (b1ln) lueftenText += b1lnText + "<br>";
                 if (b2ln) lueftenText += b2lnText + "<br>";
                 if (b3ln) lueftenText += b3lnText + "<br>";
          	   if (b4ln) lueftenText += b4lnText + "<br>";
                 if (debug) log(raum + ': <span style="color:red;"><b>Empfehlung Fenster zu</b></span>');
             } else {
                 // Hysterese. Keine Änderung der bisherigen Empfehlung.
                 if (debug) log(raum + ': <span style="color:orange;"><b>im Bereich der Hysterese</b></span> (keine Änderung der Lüftungsempfehlung');
                 if (getState(idLueften).val === null) setState(idLueften,false); // noch keine Empfehlung vorhanden, "Fenster zu" empfehlen
                 lueftenText = "Hysterese, keine Änderung der Lüftungsempfehlung";
                 setState(idLueftenHys,true);
             setState(idLueftenText, lueftenText);
             /* Erklärung Lüftungslogik (von Paul53)
                Ergänzung #4 (von Andy3268)
             Lüften:
             wenn    abs. Aussenfeuchte  <   abs. Innenfeuchte     - Hysterese (Entfeuchten)
             UND     Aussentemperatur    <   Innentemperatur       - Hysterese (Kühlen)
             UND     Innentemperatur     >=  Raumtemperaturminimum + Hysterese (Auskühlschutz)
             UND     Innenfeuchte        >=  Raummaximalfechte
             // lüften (und - Alle Bedingungen müssen erfüllt sein):
             // #4 - Raumfeuchte:    Innenfeuchte ist höher als die Maximalfeuchte
             // nicht lüften (oder):
             // #1 - Außenluft ist zu feucht
             // #2 - Außentemperatur zu warm
             // #3 - Innentemperatur niedriger als Mindestraumtemperatur
             // #4 - Innenfeuchte niedriger als Mindestfeuchte
             if (debug) log(raum + ":" + cob(b4ln) + " Raumluft ist trocken genug (b4ln): ");
             if (debug) log(raum + ":" + cob(b3ln) + " Außenluft ist zu feucht (b3ln): ");
             if (debug) log(raum + ":" + cob(b2ln) + " Außentemperatur zu warm (b2ln): ");
             if (debug) log(raum + ":" + cob(b1ln) + " Außenluft ist zu feucht (b1ln): " + ": xa: " + xa + " >= (xi - 0.1) " + (xi - 0.1));
             if (debug) log(raum + ": Fenster zu (ein true reicht):");
             //if (debug) log(raum + ": b1lp: " + b1lp+ ", b2lp: " + b2lp+ ", b3lp: " + b3lp, b4lp: " + b4lp);
             if (debug) log(raum + ":" + cob(b4lp) + " Raumfeuchte ist niedriger als der Mindstwert (b4lp): ");
             if (debug) log(raum + ":" + cob(b3lp) + " Innentemperatur ist höher als die Mindesttemperatur (b3lp): ");
             if (debug) log(raum + ":" + cob(b2lp) + " Außentemperatur ist mindestens 0,6 Grad kühler als innen (b2lp): ");
             if (debug) log(raum + ":" + cob(b1lp) + " Außenluft ist mind. 0,4° trockener als Innen (b1lp):  xa: " + xa + " <= (xi - 0.4) " + (xi - 0.4));
             if (debug) log(raum + ": Lüftungsempfehlung (alle Bedingungen auf true):");
             if (debug) log(raum + ", ti:"+ti+", ta: "+ta+", xi:"+xi+", xa: "+xa+", mih:"+mih+", mit:"+mit,"info");
             if (debug) log("<b>------ " + raum + " ------- Aussensensor: " + aussen + " -----------</b>");
          //eric2905 Erzeuge JSON und setzen Variablen "anyLueften" und "countLueften"
          function createJSON() {
             // alle Daten im JSON werden als String abgelegt
             if (debug) log("=========================================================");
             if (debug) log("Erzeugung JSON Start");
             var anyLueften          = false;
             var countLueften        = 0;
             var raeumeLueftenListe  = [];
             var temppfad = "";
             var tempraum = "";
             var tempVal = "";
             var strJSONfinal = "[";
             var strJSONtemp = "";
                 strJSONtemp = strJSONtemp + "{";
                 strJSONtemp = strJSONtemp + "\"Raum\":\"" + raum + "\",";
                     // Aussensensor ja oder nein
                     var aussensensor = false;
                             aussensensor = true;
                     temppfad = pfad + raumPfad + raum + "." + raumDatenpunkte[datenpunktID].DpName;
                     tempraum = pfad + raumPfad + raum;
                     tempVal = (!aussensensor ? getState(temppfad).val : "");            // kein Aussensenosr: Lüftungsempfehlung auslesen, Aussensensor: Lüftungsempfehlung freilassen
                     if (tempVal === null) tempVal = "";
                     if(raumDatenpunkte[datenpunktID].DpName != "Lüftungsempfehlung") {
                         tempVal = parseFloat(tempVal);
                         tempVal = tempVal.toFixed(2);
                     } else {
                         if (tempVal === true) {
                             anyLueften = true;
                             countLueften = countLueften + 1;
                             raeumeLueftenListe.push(raum);
                     strJSONtemp = strJSONtemp + "\"" + raumDatenpunkte[datenpunktID].DpName + "\":\"" + tempVal + "\",";
                 strJSONtemp = strJSONtemp.substr(0, strJSONtemp.length - 1);
                 strJSONtemp = strJSONtemp + "},";
             strJSONfinal = strJSONfinal + strJSONtemp + "]";
             if (debug) log("strJSONfinal = " + strJSONfinal);
             if (debug) log("anyLueften = " + anyLueften + ", Anzahl Lüftungsempfehlungen: " + countLueften);
             setState(pfad + 'Lüften'                    , anyLueften);
             setState(pfad + 'Lüften_Liste'              , writeJson(raeumeLueftenListe));
             setState(pfad + 'Lüften_Anzahl'             , countLueften);
             setState(pfad + 'JSON'                      , strJSONfinal);
             setState(pfad + 'Aktualsierung'             , formatDate(new Date(), strDatum));
             if (debug) log("Erzeugung JSON Ende");
          // eric2905 Ende ---------------------------------------------------------------
          function calcDelayed(raum, delay) {
             setTimeout(function () {
                 calc(raum);
             }, delay || 0);
          function creatJSONDelayed() {
                 createJSON();
             }, 4000);
          // Klimadaten in allen Räumen berechnen
          function calcAll() {
                 calcDelayed(raum,delayRooms);       // Räume verzögerd nacheinander abarbeiten
          // finde anhand der Sensor ID einen zugeordneten Raum
          function findRoom(sensor) {
                 if (raeume[raum].Sensor_TEMP == sensor) return raum;
                 if (raeume[raum].Sensor_HUM == sensor) return raum;
             return null;
          // Änderung eines Sensors (Temperatur oder Luftfeuchtigkeit)
          function valChange(obj) {
             var raumname = findRoom(obj.id);
             if (raumname) {
                 if (debug) log('<span style="color:black;"><b>Änderung:' + raumname + ": " + obj.id + ": " + obj.state.val + '</b></span>');
                 calcDelayed(raumname,delayRooms);
             // eric2905 Aufruf eingebaut zum JSON erzeugen und Datenpunkt befüllen
             creatJSONDelayed();
          // Datenpunkte für alle Räume anlegen
          function createOn() {
             var dpId    = "";
             // TODO: Im Modus CONTROL über Objekte: Bei Änderung der OFFSETS, Temperatur_Minimum werden die Änderung erst nach Aktualisierung der Messwerte oder nach Zeit erneuert (auf on() reagieren)
             var i =0;
                 if (raeume[raum].Sensor_TEMP) {
                     dpId = raeume[raum].Sensor_TEMP;
                     i++;
                     on({id: dpId ,change:'ne'}, function (obj) {
                         valChange(obj);
                     if (debug) log("on: " + dpId + " angelegt.");
                 if (raeume[raum].Sensor_HUM) {
                     dpId = raeume[raum].Sensor_HUM;
                     i++;
                         valChange(obj)
             log("Subscriptions angelegt: " + i);
          // Schedule
          // Nach Zeit alle Räume abfragen
          schedule(cronStr, function () {
             calcAll();
             creatJSONDelayed();
          // main()
          function main() {
             calcAll();
             setTimeout(calcAll,2000);
             creatJSONDelayed();
          // Skriptstart
          setTimeout(createOn,2000);  // Subscriptions anlegen
          setTimeout(main,    4000);  // Zum Skriptstart ausführen
          javascript.0	2020-09-14 18:50:12.205	error	(15655) at Script.runInContext (vm.js:130:18)
          javascript.0	2020-09-14 18:50:12.205	error	(15655) at script.js.common.Komfort.Lueften:481:15
          javascript.0	2020-09-14 18:50:12.205	error	(15655) TypeError: DP is not a constructor
          javascript.0	2020-09-14 18:50:12.205	error	(15655) ^
          javascript.0	2020-09-14 18:50:12.205	error	(15655) var xdp = new DP(hunn);
          javascript.0	2020-09-14 18:50:12.204	error	(15655) script.js.common.Komfort.Lueften: script.js.common.Komfort.Lueften:481
          javascript.0	2020-09-14 18:50:12.198	error	(15655) at Script.runInContext (vm.js:130:18)
          javascript.0	2020-09-14 18:50:12.198	error	(15655) at script.js.common.Komfort.Lueften:93:13
          javascript.0	2020-09-14 18:50:12.197	error	(15655) at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:390:36)
          javascript.0	2020-09-14 18:50:12.197	error	(15655) at require (internal/modules/cjs/helpers.js:72:18)
          javascript.0	2020-09-14 18:50:12.197	error	(15655) at Module.require (internal/modules/cjs/loader.js:1025:19)
          javascript.0	2020-09-14 18:50:12.196	error	(15655) script.js.common.Komfort.Lueften: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/lib/../../dewpoint
          sigi234S HomoranH 2 Antworten Letzte Antwort
          • D Dragon
            // - Paul53:
            // - Solear:
            // - ruhr70:
            // - eric 2905:
            // - Andy3268:
            // TODO:
            // - Auswählbar:
            // Lüftungsengine
            // Skriptverhalten
                // Sensoren Aussen
                "Terrasse" : {
                // Sensoren Innen
                "Badezimmer" : {
                "Wohnzimmer" : {
                "Schlafzimmer" : {
                "Kueche" : {
                 "Flur" : {
               type: 'number',
               unit: 'bar',
               role: 'info'
               type: 'number',
               unit: 'm',
               role: 'info'
               "x" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": 'g/kg'
               "rh" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": '%'
               "dp" : {
                   "init": 0,
                   "dp": {
                       "name": 'Taupunkt',
                       "type": 'number',
                       "role": 'value',
                       "unit": '°C'
               "t" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": '°C'
               "h" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": 'kJ/kg'
               "sdd" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": 'hPa'
               "dd" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": 'hPa'
               "rd" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": 'g/m³'
               "maxrd" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "role": 'value',
                       "unit": 'g/m³'
               "lüften" : {
                   //"init": false,
                   "dp": {
                       "type": 'boolean',
                       "role": 'value'
               "lüften_b1" : {
                   //"init": false,
                   "dp": {
                       "type": 'boolean',
                       "role": 'value'
               "lüften_b2" : {
                   //"init": false,
                   "dp": {
                       "type": 'boolean',
                       "role": 'value'
               "lüften_b3" : {
                   //"init": false,
                   "dp": {
                       "type": 'boolean',
                       "role": 'value'
               "lüften_b4" : {
                   //"init": false,
                   "dp": {
                       "type": 'boolean',
                       "role": 'value'
                   //"init": false,
                   "dp": {
                       "type": 'boolean',
                       "role": 'value'
                   "init": "",
                   "dp": {
                       "type": 'string',
                       "role": 'value'
            var raumControl = {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "unit": '°C'
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "unit": '%'
               "TEMP_Minimum" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "unit": '°C'
               "FEUCH_Minimum" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "unit": '%'
               "FEUCH_Maximum" : {
                   "init": 0,
                   "dp": {
                       "type": 'number',
                       "unit": '%'
               "Aussensensor" : {
                   "init": "",
                   "dp": {
                       "type": 'string',
            // Funktionen
               // CHANNEL anlegen
                       common: {
                       type: 'channel'
                   }, function(err) {
               var name;
               var init;
               var forceCreation;
               var common;
                           } else {
                       } else {
                type: 'boolean',
                unit: '',
                role: 'value'
                type: 'string',
                unit: '',
                role: 'value'
                type: 'string',
                unit: '',
                role: 'value'
                type: 'string',
                unit: '',
                role: 'value'
                type: 'number',
                unit: '',
                role: 'value'
               return cobStr;
               if(isNaN(wert)) {
               return wert;
               var sdd,a,b;
               a = 7.5;
               b = 237.3;
               return tk;
               return maxrd;
                   return;
               var aussen;
               var idta, idxa;
               } else {
               // Lüftungslogik
               // Logik:
               } else {
               Lüften:
               var temppfad = "";
               var tempraum = "";
               var tempVal = "";
                       } else {
                               anyLueften = true;
                   calc(raum);
               }, delay || 0);
                   createJSON();
               }, 4000);
               return null;
               if (raumname) {
               creatJSONDelayed();
               var dpId    = "";
               var i =0;
                       i++;
                           valChange(obj);
                       i++;
                           valChange(obj)
            // Schedule
               calcAll();
               creatJSONDelayed();
            // main()
            function main() {
               calcAll();
               creatJSONDelayed();
            // Skriptstart
            sigi234S Online
            sigi234S Online
            @David-Froebus
            dewpoint in JS Adapter als Modul eintragen
            • D Dragon
              // - Paul53:
              // - Solear:
              // - ruhr70:
              // - eric 2905:
              // - Andy3268:
              // TODO:
              // - Auswählbar:
              // Lüftungsengine
              // Skriptverhalten
                  // Sensoren Aussen
                  "Terrasse" : {
                  // Sensoren Innen
                  "Badezimmer" : {
                  "Wohnzimmer" : {
                  "Schlafzimmer" : {
                  "Kueche" : {
                   "Flur" : {
                 type: 'number',
                 unit: 'bar',
                 role: 'info'
                 type: 'number',
                 unit: 'm',
                 role: 'info'
                 "x" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": 'g/kg'
                 "rh" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": '%'
                 "dp" : {
                     "init": 0,
                     "dp": {
                         "name": 'Taupunkt',
                         "type": 'number',
                         "role": 'value',
                         "unit": '°C'
                 "t" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": '°C'
                 "h" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": 'kJ/kg'
                 "sdd" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": 'hPa'
                 "dd" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": 'hPa'
                 "rd" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": 'g/m³'
                 "maxrd" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "role": 'value',
                         "unit": 'g/m³'
                 "lüften" : {
                     //"init": false,
                     "dp": {
                         "type": 'boolean',
                         "role": 'value'
                 "lüften_b1" : {
                     //"init": false,
                     "dp": {
                         "type": 'boolean',
                         "role": 'value'
                 "lüften_b2" : {
                     //"init": false,
                     "dp": {
                         "type": 'boolean',
                         "role": 'value'
                 "lüften_b3" : {
                     //"init": false,
                     "dp": {
                         "type": 'boolean',
                         "role": 'value'
                 "lüften_b4" : {
                     //"init": false,
                     "dp": {
                         "type": 'boolean',
                         "role": 'value'
                     //"init": false,
                     "dp": {
                         "type": 'boolean',
                         "role": 'value'
                     "init": "",
                     "dp": {
                         "type": 'string',
                         "role": 'value'
              var raumControl = {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "unit": '°C'
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "unit": '%'
                 "TEMP_Minimum" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "unit": '°C'
                 "FEUCH_Minimum" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "unit": '%'
                 "FEUCH_Maximum" : {
                     "init": 0,
                     "dp": {
                         "type": 'number',
                         "unit": '%'
                 "Aussensensor" : {
                     "init": "",
                     "dp": {
                         "type": 'string',
              // Funktionen
                 // CHANNEL anlegen
                         common: {
                         type: 'channel'
                     }, function(err) {
                 var name;
                 var init;
                 var forceCreation;
                 var common;
                             } else {
                         } else {
                  type: 'boolean',
                  unit: '',
                  role: 'value'
                  type: 'string',
                  unit: '',
                  role: 'value'
                  type: 'string',
                  unit: '',
                  role: 'value'
                  type: 'string',
                  unit: '',
                  role: 'value'
                  type: 'number',
                  unit: '',
                  role: 'value'
                 return cobStr;
                 if(isNaN(wert)) {
                 return wert;
                 var sdd,a,b;
                 a = 7.5;
                 b = 237.3;
                 return tk;
                 return maxrd;
                     return;
                 var aussen;
                 var idta, idxa;
                 } else {
                 // Lüftungslogik
                 // Logik:
                 } else {
                 Lüften:
                 var temppfad = "";
                 var tempraum = "";
                 var tempVal = "";
                         } else {
                                 anyLueften = true;
                     calc(raum);
                 }, delay || 0);
                     createJSON();
                 }, 4000);
                 return null;
                 if (raumname) {
                 creatJSONDelayed();
                 var dpId    = "";
                 var i =0;
                         i++;
                             valChange(obj);
                         i++;
                             valChange(obj)
              // Schedule
                 calcAll();
                 creatJSONDelayed();
              // main()
              function main() {
                 calcAll();
                 creatJSONDelayed();
              // Skriptstart
              @David-Froebus sagte in Skript läuft nicht... Lüften oder nicht...:
              im zweiten Skript steht es ja drin:
              Master67M 1 Antwort Letzte Antwort
                Dragon
                vielen Dank für die Unterstützung. Zweites Skript läuft! Dann werde ich mal weiterbasteln! Tolle Community hier!
                  Master67M Offline
                  Master67M Offline
                  Master67
                  @Homoran sagte in [gelöst] Skript läuft nicht... Lüften oder nicht...:
                  Ähm..... Hust...... wie bekomme ich denn "dewpoint" genau als Modul eingebunden (naja Linux.. ich.. und Konsolen Befehle wir üben noch...)
                  Gruß Master67
                  • Master67M Master67
                    Adnim
                    @Master67
                    Instanzen->Javaskript->Zusätzliche NPM-Module
                    • A Adnim
                      @Master67
                      Master67M Offline
                      Master67M Offline
                      Master67
                      @Adnim .... Ah... Danke :-)
                      Gruß Master67
