  2. English
  3. ioBroker general
  4. Z-Wave does not work after reboot
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
z wavez-wave
12 Beiträge 5 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    which system .. windows or linux ??
    AlCalzoneA A 2 Antworten Letzte Antwort
    • arteckA arteck
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @arteck Pretty sure /opt/iobroker and /dev/ttyACM0 means Linux ;)
      • AlCalzoneA AlCalzone
        arteckA Offline
        arteckA Offline
        arteck
        @AlCalzone i know but look
        "I also noticed that it does not show COM port that I previously used"
        COM = windows
        the combobox has USB Device Name as title
        but you're right /opt/iobroker/ is for linux
        • arteckA arteck
          ap2017
          @arteck Linux
          • arteckA Offline
            arteckA Offline
            arteck
            more infos plz
            adapter -> debug option -> log ??
              ap2017
              Connecting Z-Wave USB stick to a different USB port solved the problem. System accepted port as /dev/ttyACM0 and I am able to see all my Z-Wave devices. I am afraid to reboot, but eventually will have to do it to troubleshoot another ongoing trouble with ASTRO Blockly function.
                ap2017
                Continue to struggle with same issue - after reboot Z-Wave does not work, see log. I am running 64bit Intel platform with all latest modules (ioBroker, Node, ZWave adapter. Please help
                ZWave 8-17-19.txt
                • A ap2017
                  ZWave 8-17-19.txt
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @ap2017 sagte in Z-Wave does not work after reboot:
                  libopenzwave.so.1.6: cannot open shared object file: No such file or directory
                  Did you follow the instructions under known issues?
                    ap2017
                    @AlCalzone Sorry, forgot about this fix, I though that in new version of Z-Wave adapter 1.5.1 this issue is fixed, but I guess this is not an adapter issue.
                    The "sudo ldconfig /usr/local/lib64" worked and fixed the issue. Thank you!
                    • A ap2017
                      I had fully working Z-Wave adapter on X64 Intel Platform with 12 nodes. After reboot, z-wave adapter is no longer working, continuously trying to start, but having the following ,messages:
                      host.ap-OptiPlex-390	2019-07-27 21:10:47.661	error	instance system.adapter.zwave.0 terminated with code null ()
                      host.ap-OptiPlex-390	2019-07-27 21:10:47.661	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
                      zwave.0	2019-07-27 21:10:22.134	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.16.0
                      host.ap-OptiPlex-390	2019-07-27 21:10:21.849	info	instance system.adapter.zwave.0 started with pid 8008
                      host.ap-OptiPlex-390	2019-07-27 21:09:51.842	info	Restart adapter system.adapter.zwave.0 because enabled
                      host.ap-OptiPlex-390	2019-07-27 21:09:51.842	error	instance system.adapter.zwave.0 terminated with code null ()
                      host.ap-OptiPlex-390	2019-07-27 21:09:51.842	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
                      zwave.0	2019-07-27 21:09:26.319	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.16.0
                      host.ap-OptiPlex-390	2019-07-27 21:09:26.029	info	instance system.adapter.zwave.0 started with pid 6542
                      host.ap-OptiPlex-390	2019-07-27 21:08:56.023	info	Restart adapter system.adapter.zwave.0 because enabled
                      host.ap-OptiPlex-390	2019-07-27 21:08:56.023	error	instance system.adapter.zwave.0 terminated with code null ()
                      host.ap-OptiPlex-390	2019-07-27 21:08:56.023	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
                      zwave.0	2019-07-27 21:08:30.506	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v10.16.0
                      host.ap-OptiPlex-390	2019-07-27 21:08:30.218	info	instance system.adapter.zwave.0 started with pid 5091
                      host.ap-OptiPlex-390	2019-07-27 21:08:00.211	info	Restart adapter system.adapter.zwave.0 because enabled
                      host.ap-OptiPlex-390	2019-07-27 21:08:00.211	error	instance system.adapter.zwave.0 terminated with code null ()
                      host.ap-OptiPlex-390	2019-07-27 21:08:00.211	warn	instance system.adapter.zwave.0 terminated due to SIGSEGV
                      I also noticed that it does not show COM port that I previously used. After some struggle I was able to save COM configuration /dev/ttyACM0 but adapter still does not work
                      I found this discussion, but don't see there a clean solution.
                      https://github.com/ioBroker/ioBroker.zwave/issues/43
                      Anthon1y
                      schrieb am zuletzt editiert von Anthon1y
                      I'm also having the same problem as the others!
                      • A Anthon1y
                        @Anthon1y sagte in Z-Wave does not work after reboot:
                        please specify!
