  5. Waschmaschine
    5.3k
Waschmaschine
blockly
109 Beiträge 16 Kommentatoren 19.6k Aufrufe 17 Beobachtet
  • SlowmanS Slowman
    Bekomme in den WAMA Script jetzt WARN Meldungen:
    Start
    javascript.0	2020-06-30 15:16:34.958	warn	(2175) at process.topLevelDomainCallback (domain.js:137:15)
    javascript.0	2020-06-30 15:16:34.958	warn	(2175) at processImmediate (internal/timers.js:456:21)
    javascript.0	2020-06-30 15:16:34.958	warn	(2175) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
    javascript.0	2020-06-30 15:16:34.958	warn	(2175) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
    javascript.0	2020-06-30 15:16:34.958	warn	(2175) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
    javascript.0	2020-06-30 15:16:34.958	warn	(2175) at Object.<anonymous> (script.js.Keller.WaMa_fertig:19:5)
    javascript.0	2020-06-30 15:16:34.957	warn	(2175) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    javascript.0	2020-06-30 15:16:34.955	warn	(2175) You are assigning a number to the state "0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Waschstart" which expects a boolean. Please fix your code to use a boolean or change the s
    host.iobroker	2020-06-30 15:15:11.863	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    Ende
    javascript.0	2020-06-30 16:03:57.751	warn	(2175) at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-30 16:03:57.751	warn	(2175) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-06-30 16:03:57.751	warn	(2175) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2039:34)
    javascript.0	2020-06-30 16:03:57.751	warn	(2175) at Object.<anonymous> (script.js.Keller.WaMa_fertig:36:13)
    javascript.0	2020-06-30 16:03:57.751	warn	(2175) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    javascript.0	2020-06-30 16:03:57.750	warn	(2175) You are assigning a number to the state "0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Stromkosten_pro_Waschgang" which expects a boolean. Please fix your code to use a boolean
    javascript.0	2020-06-30 16:03:57.750	warn	(2175) at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-30 16:03:57.750	warn	(2175) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-06-30 16:03:57.750	warn	(2175) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2039:34)
    javascript.0	2020-06-30 16:03:57.750	warn	(2175) at Object.<anonymous> (script.js.Keller.WaMa_fertig:34:13)
    javascript.0	2020-06-30 16:03:57.750	warn	(2175) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    javascript.0	2020-06-30 16:03:57.749	warn	(2175) You are assigning a number to the state "0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Stromverbrauch_pro_Waschgang" which expects a boolean. Please fix your code to use a boole
    javascript.0	2020-06-30 16:03:52.748	warn	(2175) at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-30 16:03:52.748	warn	(2175) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-06-30 16:03:52.748	warn	(2175) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2039:34)
    javascript.0	2020-06-30 16:03:52.748	warn	(2175) at Object.<anonymous> (script.js.Keller.WaMa_fertig:30:9)
    javascript.0	2020-06-30 16:03:52.747	warn	(2175) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
    javascript.0	2020-06-30 16:03:52.743	warn	(2175) You are assigning a number to the state "0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Waschende" which expects a boolean. Please fix your code to use a boolean or change the st
    Ein Datenpunkt:
      "_id": "0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Stromkosten_pro_Waschgang",
      "type": "state",
      "common": {
        "name": "Stromkosten_pro_Waschgang",
        "role": "",
        "type": "boolean",
        "read": true,
        "write": true,
        "desc": "Manuell erzeugt",
        "def": false
      "native": {},
      "user": "system.user.admin",
      "ts": 1592760694828,
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    Oder liegt das Problem woanders.
    Im Forum gefunden bei einen anderen Problem, das man boolean auf string ändern soll?
    F Online
    F Online
    fastfoot
    #83
    @Slowman sagte in Waschmaschine:
    Ändere boolean in number, das ist der typ der Werte, die gesendet werden
    • SlowmanS Offline
      SlowmanS Offline
      Slowman
      #84
      @fastfoot
      Danke, schaue ich mal nach dem nächsten Wäsche, ist jetzt erst mal durch mit Waschen. Muss erst wieder was dreckig machen 😊
      • SlowmanS Offline
        SlowmanS Offline
        Slowman
        #85
        Seit einiger Zeit rechnet meiner irgendwie komisch,bei der Waschmaschine zu wenig und beim Geschirrspüler zu viel 🙄
        Screenshot_2020-08-30 Telegram Web(1).png Screenshot_2020-08-30 Telegram Web.png
        Hier der Blockly vom Geschirrspüler:
        Wie gesagt, ich finde den Fehler nicht, der von der WaMa ist gleich und liefert einen anderen Blödsinn.
        Danke für einen Tipp
        • SlowmanS Slowman
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #86
          Einen direkten Tipp zur Lösung habe ich nicht, aber ein paar Fragen und einen Vorschlag:
          • Nutzen das Waschmaschinenscript und das Spülmaschinenscript unterschiedliche Datenpunkte für Waschstart und Waschende ?
          • Treten die seltsamen Werte nur auf wenn beide Maschinen überlappend laufen, i.e. wenn z.Bsp. die Waschmaschine gestartet wird während die Spülmaschine läuft ?
          Als Vorschlag würde ich die Datenpunkte "WaschStart" und "WaschEnde" durch Variablen ersetzen, so wie es auch bei StartZeit und EndZeit gemacht wurde.
          A.
          SlowmanS 1 Antwort Letzte Antwort
          • AsgothianA Asgothian
            A.
            SlowmanS Offline
            SlowmanS Offline
            Slowman
            schrieb am zuletzt editiert von Slowman
            #87
            @Asgothian
            Haben beide getrennte Datenpunkte.
            Mit den Variablen verstehe ich nicht so ganz, er muss doch irgendwo die letzten Werte sich holen?
            • SlowmanS Slowman
              @Asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #88
              @Slowman
              Wenn du am Anfang des Blocklys 2 Variable definierst, und sie auf 0 setzt (Waschstart, waschende), so wie es mit Startzeit und Startende gemacht wird, dann kannst du statt "steuere " einfach den Baustein "setze" benutzen (wieder - so wie auch mit Startzeit und startende)
              Ansonsten ist der Fehler in deinem Baum schon Sichtbar: Wenn du dir die Zahlen in den Datenpunkten anschaust, dann siehst du das zwischen Waschstart und waschende bei dem Geschirrspüler ca. 4000 liegen, während bei der Waschmaschine dazwischen etwa 0.3 liegen. Es scheint also so zu sein das die beiden Messsteckdosen ihren Energiewert in unterschiedlichen Einheiten ablegen.
              A.
                @Slowman
                A.
                SlowmanS Offline
                SlowmanS Offline
                Slowman
                #89
                @Asgothian
                Danke dir. Verstehe ich das richtig, das er dann sich den Punkt/Zahl merkt und dies dann berechnet?
                Wie schreibe ich denn dann diesen Baustein um?
                • SlowmanS Slowman
                  @Asgothian
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #90
                  @Slowman
                  Ich verstehe die Frage nicht.
                  Bist du im ioBroker ts ?
                    @Slowman
                    SlowmanS Offline
                    SlowmanS Offline
                    Slowman
                    #91
                    @Asgothian
                    Nein, kenne mich mit Teamspeak nicht aus 🙄
                    Aber glaube habe es gefunden.. mom...
                    • SlowmanS Slowman
                      @Asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #92
                      @Slowman
                      dann müsstest du die Frage noch einmal anders stellen, vielleicht kann ich sie dann beantworten :)
                        @Slowman
                        SlowmanS Offline
                        SlowmanS Offline
                        Slowman
                        #93
                        @Asgothian
                        Den Baustein steure mit setze ersetzen, richtig? So, wie jetzt das Beispiel.
                        Richtiger Ansatz?
                        • SlowmanS Slowman
                          @Asgothian
                          Richtiger Ansatz?
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #94
                          @Slowman Exakt
                            @Slowman Exakt
                            SlowmanS Offline
                            SlowmanS Offline
                            Slowman
                            #95
                            @Asgothian
                            So, denke mal das es so passt. Den Wert Stromkosten holt er sich jetzt nur noch aus dem Datenpunkt. Den Rest habe ich umgeändert.
                            Screenshot_2020-08-30 javascript - ioBroker(5).png Screenshot_2020-08-30 javascript - ioBroker(6).png
                              <variables>
                                <variable id="ZM0_}Z7tdRGw|OEboSUb">Geschirrspüler Start</variable>
                                <variable id="eA~.c[yxGq8R8{!f%:h#">Geschirrspüler Ende</variable>
                                <variable id="mB|+S;|3QAoN;5)#v~5u">Startzeit</variable>
                                <variable id="Hhe!Hg(xh7gHuy(6hLlx">Geschirrspueler_EinAus</variable>
                                <variable type="timeout" id="timeout4">timeout4</variable>
                                <variable id="Y6O#H}N0!M,ytg,|2#=p">EndZeit</variable>
                                <variable id="E!Psgr8)b[wT9RI9HC[">Dauer</variable>
                                <variable type="timeout" id="timeout2">timeout2</variable>
                                <variable type="timeout" id="timeout">timeout</variable>
                                <variable id="6zR3cy!$c$@HV6PVyN2!">Stromverbrauch pro Waschgang</variable>
                                <variable id="A/ePxr2pS]eX9Gqw8qOT">Stromkosten pro Waschgang</variable>
                              </variables>
                              <block type="variables_set" id="iv@mYR:]_^Upop_#qFH;" x="838" y="-62">
                                <field name="VAR" id="ZM0_}Z7tdRGw|OEboSUb">Geschirrspüler Start</field>
                                <value name="VALUE">
                                  <block type="math_number" id="8cbWw~V?WpG?Ccg#quGr">
                                    <field name="NUM">0</field>
                                  </block>
                                </value>
                                <next>
                                  <block type="variables_set" id="VK~5i!)A9wx1YlVROhEu">
                                    <field name="VAR" id="eA~.c[yxGq8R8{!f%:h#">Geschirrspüler Ende</field>
                                      <block type="math_number" id="bNEma8]R^c,:H*N9q#W_">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="UgHqqacY6TM}7wOP;wsy">
                                        <field name="VAR" id="mB|+S;|3QAoN;5)#v~5u">Startzeit</field>
                                          <block type="math_number" id=")00MK5w]q^f%?v+:k60k">
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="i@;~wXOo)(5+=$9v:QF">
                                            <field name="VAR" id="Hhe!Hg(xh7gHuy(6hLlx">Geschirrspueler_EinAus</field>
                                              <block type="logic_boolean" id="stD7DD67D[4(YSQ3dCvR">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="on_ext" id="%l??Ns0%ZOhlZQJn)RIY">
                                                <value name="OID0">
                                                  <shadow type="field_oid" id="8p+iN2CjzC1M$2o|Xq=m">
                                                    <field name="oid">shelly.0.SHPLG-S#F8C02D#1.Relay0.Power</field>
                                                  </shadow>
                                                </value>
                                                <statement name="STATEMENT">
                                                  <block type="controls_if" id="-4y,4m5H68[U,UjJH(0">
                                                    <value name="IF0">
                                                      <block type="logic_operation" id="-^U__L=#GGG_LD~6o~hg" inline="false">
                                                        <field name="OP">AND</field>
                                                        <comment pinned="false" h="84" w="432">Falls Maschinengang erkannt (Wattzahl &gt;200) UND Modus ist auf falsch dann starte und schreibe den aktuellen verbrauch in den Datenpunkt</comment>
                                                        <value name="A">
                                                          <block type="logic_compare" id="-%Kg)H+S;{}Yyd@cqe=l">
                                                            <field name="OP">GTE</field>
                                                            <value name="A">
                                                              <block type="on_source" id="QS5)==Ahwtfe.nNTlR@">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="math_number" id="OT1x**T)z3hCtGxhqDDI">
        <field name="NUM">100</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="logic_compare" id=",LW++gUB/lbO[yiNJdv">
                                                            <field name="OP">EQ</field>
                                                            <value name="A">
                                                              <block type="variables_get" id="[$/1md}o9xogfLp!}WA">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="logic_boolean" id="V}KP*,b;J,.3q802Q0l^">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO0">
                                                      <block type="variables_set" id="HHIFm}6:U#VVrIRv7e|">
                                                          <block type="logic_boolean" id="%.!o$LmcZOm0##5WWoJ">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="comment" id="#niZnE_tgmb6Kk@Fr$fl">
                                                            <field name="COMMENT">Falls ein Programm ein paar Stunden vorher gestartet wurde sieht man wenn ob die Maschine Startet</field>
                                                            <next>
                                                              <block type="telegram" id="n~A-iElr}zQGmh%dFiiq">
        <field name="LOG"></field>
        <value name="MESSAGE">
        <shadow type="text" id="Wo1gRgI.3j=lL!S+j/dX">
        <field name="TEXT">Geschirrspüler läuft jetzt</field>
        </shadow>
        </value>
        <value name="USERNAME">
        <block type="text" id="BW6HWl3D$1GxO~]!7=|/">
        <field name="TEXT">Frank</field>
        </block>
        </value>
        <next>
        <block type="variables_set" id=":|$gI;wDf+V^N6RD,#T%">
        <block type="get_value" id="b$lgvB*z^u:a@_hX4hL]">
        <field name="OID">shelly.0.SHPLG-S#F8C02D#1.Relay0.Energy</field>
        </block>
        </value>
        <next>
        <block type="comment" id="~kES-^z;=BjbpxXK9yo}">
        <field name="COMMENT">Startzeit speichern zur Berechnung der gesamt Laufzeit</field>
        <next>
        <block type="variables_set" id="wN^[UA.lTmij81cgn#[@">
        <block type="time_get" id="!~RJI|{hH)+qo._Sk]q;">
        <field name="OPTION">mid</field>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                    <value name="IF1">
                                                      <block type="logic_operation" id="[:7QWv4Op8S6o@lG45(y" inline="false">
                                                        <value name="A">
                                                          <block type="logic_operation" id="Y(DY5TjFzyX=D_%6;##7" inline="false">
                                                            <comment pinned="false" h="49" w="563">Falls der Verbrauch vorher grösser 3 Watt ist dun dann unter 2.9 fällt und der Modus ist Wahr dann beende den Waschmodus.</comment>
                                                            <value name="A">
                                                              <block type="logic_compare" id="ydDpT$dnoB]3iV0{BiSL">
        <value name="A">
        <block type="on_source" id="TI;SFi6{]mr@]Ir[QtYg">
        <field name="ATTR">oldState.val</field>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="wCZMQjlh5X9NCvvT5hm">
        <field name="NUM">4</field>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="logic_compare" id="igy_8vlVI|k$sL-O!Ya">
        <field name="OP">LT</field>
        <value name="A">
        <block type="on_source" id="oKi^o%$Qa%i0^MVE?s)Y">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="bx}yjZ_C7J2#/$NzLoS">
        <field name="NUM">3.9</field>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="logic_compare" id="}A,!m2TVXL.^LQWg%!e|">
                                                            <value name="A">
                                                              <block type="variables_get" id="r/rnzWL?1!/.2!+pr@5(">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="logic_boolean" id="S,c^%FKOd(.(Q(BL!=g">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO1">
                                                      <block type="comment" id="l_UxyF[7l.W[9+KCjUzR">
                                                        <field name="COMMENT">Zusätzliches Timeout "Wenn für 3 Minuten weniger wie 2 Watt verbraucht werden ist die Maschine Fertig</field>
                                                        <next>
                                                          <block type="timeouts_settimeout" id="FT-Aebrk1nQxA(D0}bjX">
                                                            <field name="NAME">timeout4</field>
                                                            <field name="DELAY">58</field>
                                                            <field name="UNIT">min</field>
                                                              <block type="controls_if" id="z#h:Sgr$YhLz;/sJ:;q+">
        <value name="IF0">
        <block type="logic_operation" id="k8k9;Ypy[xEoy_mm2)_">
        <comment pinned="false" h="80" w="160">Falls Verbrauch unter 3 Watt fällt und der Modus ist Wahr dann beende den Waschmodus.</comment>
        <value name="A">
        <block type="logic_compare" id="kgv@}Wxf%H71-6[LoA2">
        <value name="A">
        <block type="get_value" id="p,SxCr5G+PUY,ToS?g64">
        <field name="OID">shelly.0.SHPLG-S#F8C02D#1.Relay0.Power</field>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="OqAYX/y!j21Y]dVWdJ82">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="7k@eXCwx[(!$|iKjlX?">
        <value name="A">
        <block type="variables_get" id="_DQp6uLs##,TQ84hTu,X">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="m[z$R3x+t7q:t3NePYda">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="qp?4+EqX93)A7YpT,6t">
        <field name="VAR" id="Y6O#H}N0!M,ytg,|2#=p">EndZeit</field>
        <block type="time_get" id="GGpCtGnJ^|XKC8!mS_S">
        </block>
        </value>
        <next>
        <block type="variables_set" id="%6t-7+/fnYOGIfAn+5qZ">
        <field name="VAR" id="E!Psgr8)b[wT9RI9HC[">Dauer</field>
        <block type="math_arithmetic" id="weAo4py)IC-58@is52Cg">
        <value name="A">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="i0wQ=PLCNBKJc5hpz7w7">
        <field name="NUM">1</field>
        </shadow>
        <block type="variables_get" id="BzJhg};$iBly2m!o}f">
        </block>
        </value>
        <value name="B">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=":dsZj_obi1eBcP%hJC">
        </shadow>
        <block type="variables_get" id="(j[-tV+kr]?e7G1s}-m4">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="variables_set" id="vj!Vu=sDr5yt.:ZU#OfU">
        <block type="logic_boolean" id="5xCJ(QRB3mIo5.f1Fsg">
        </block>
        </value>
        <next>
        <block type="variables_set" id="w5M[qUK=HD;mzLUoU@hK">
        <block type="get_value" id="}_}=j6pEBm+0afN/394(">
        </block>
        </value>
        <next>
        <block type="controls_if" id="RMHH_kch:3FQxQaWZ]lG">
        <value name="IF0">
        <block type="logic_compare" id="aQAt;O+zWr%|HvV+j=P;">
        <field name="OP">GT</field>
        <value name="A">
        <block type="variables_get" id="Diq%z$U$)7AU#3nVC$@T">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="?yyDu7by5#NGlcmd1pve">
        <field name="NUM">2</field>
        </block>
        </value>
        </block>
        </value>
        <block type="timeouts_settimeout" id=",NjGW@Wtt+n7RKNkcxK!">
        <field name="NAME">timeout2</field>
        <field name="DELAY">5</field>
        <block type="comment" id="P5Kh.,h#^UMV[v9Yzkh">
        <field name="COMMENT">Daten Schreiben für History Verbrauch pro Waschgang</field>
        <next>
        <block type="variables_set" id="SX5GEsOAo0@yW:@TRwa.">
        <field name="VAR" id="6zR3cy!$c$@HV6PVyN2!">Stromverbrauch pro Waschgang</field>
        <block type="math_arithmetic" id="MHdw2]y[BCS~xV|[m3_T">
        <field name="OP">DIVIDE</field>
        <value name="A">
        <shadow type="math_number" id=";x*EJIT-UHcl7Q0j{G#U">
        </shadow>
        <block type="math_rndfixed" id="%DceoHsJ1|2ktnX;ik;Y">
        <field name="n">2</field>
        <value name="x">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="}[m8CJ[~.H(X2Ez)$MNC">
        <field name="NUM">3.1234</field>
        </shadow>
        <block type="math_arithmetic" id="B1^}sQT!K1/]T@W1L[xe" inline="false">
        <value name="A">
        </shadow>
        <block type="get_value_var" id="NE:F^hWocTr{gUS)^@+C">
        <value name="OID">
        <shadow type="text" id="3,LTg[wy.`^G94cq1a9U">
        <field name="TEXT"></field>
        </shadow>
        <block type="variables_get" id="nFN@SA]Ly$)Yxe1!haUM">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=")KC,Lt~MMGdb=v/v*dsR">
        </shadow>
        <block type="get_value_var" id="UjRGZ[Ue75(_M[ns82He">
        <value name="OID">
        <shadow type="text">
        </shadow>
        <block type="variables_get" id="{|N8PR7|_,8J=eXQy:zw">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="HI4EdrTO/8H*p;STQrM">
        <field name="NUM">1000</field>
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="gigTfir/Q3o9S2gzD{90">
        <field name="COMMENT">Ausrechnen der Stromkosten für diesen Waschgang und in den Datenpunkt schreiben</field>
        <next>
        <block type="variables_set" id="O#@cdr5/Wy!Z2G_`7AO7">
        <field name="VAR" id="A/ePxr2pS]eX9Gqw8qOT">Stromkosten pro Waschgang</field>
        <block type="math_rndfixed" id="}:X/;ygx%4P%rz05DOma">
        <field name="n">4</field>
        <value name="x">
        </shadow>
        <block type="math_arithmetic" id="8~CdvibGo?t^vfDF.ry">
        <value name="A">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=";xEJIT-UHcl7Q0j{G#U">
        </shadow>
        <block type="math_arithmetic" id="jk_su~s;-F0M0+89zf6!">
        <field name="OP">MULTIPLY</field>
        <value name="A">
        <shadow type="math_number" id=";xEJIT-UHcl7Q0j{G#U">
        </shadow>
        <block type="get_value_var" id="prkh^UeeTL-n$}%VsXjN">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="9aTw2Fq6Ee*]bt,IM:Mz">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=")KC,Lt~MMGdb=v/vdsR">
        </shadow>
        <block type="get_value" id="C2GwSFjOKe-T0-p9HB0">
        <field name="OID">0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Preis_KW</field>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="k|9t!~JsdR/2hn,.Ta~.">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="comment" id="wF!c?,7;T=c_:f5E$ca%">
        <field name="COMMENT">Alexa Benachrichtung</field>
        <next>
        <block type="control" id="w3DS%f?P5Y+pO7;1V~SB">
        <field name="OID">alexa2.0.Echo-Devices.5f894234bce346edbb4a1adce0045f99.Commands.speak</field>
        <block type="text" id="vtK95A?T0Tj#c5DEZ[5~">
        <field name="TEXT">50;Geschirrspüler ist fertig</field>
        </block>
        </value>
        <next>
        <block type="comment" id="@dC$^axcVYkgm8#naev1">
        <field name="COMMENT">Nachricht über Telegramm</field>
        <next>
        <block type="telegram" id=":)Sqh|eio_J%+h7Q@6nJ">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="zaE.r=+WylppU_4Nmdx~">
        <field name="TEXT">Waschmaschine ist fertig</field>
        </shadow>
        <block type="text_join" id="3,~.TJZeugM.!B%S1^X}">
        <mutation items="13"></mutation>
        <value name="ADD0">
        <block type="text" id="|9?4%icsy2}Q088ry:q">
        <field name="TEXT">😎😎😎 Die Geschirrspüler ist Fertig. 😎😎😎</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="time_get" id="a?D^RPe+s+Si=kkfgj[">
        <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
        <field name="OPTION">custom</field>
        <field name="FORMAT">\n</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="grfj-@D75~7#;4n|Zja">
        <field name="TEXT">Dauer: </field>
        </block>
        </value>
        <value name="ADD3">
        <block type="variables_get" id="n.X3BETU_{qnfXV+E~:">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="hB0LeD{cRvcWSjG+y.+=">
        <field name="TEXT"> Minuten.</field>
        </block>
        </value>
        <value name="ADD5">
        <block type="time_get" id="cA93H,ih=ovnjMRR4?Q6">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="iq5TjK!:5+gf]#fZ42]">
        <field name="TEXT">Verbrauch: </field>
        </block>
        </value>
        <value name="ADD7">
        <shadow type="math_number" id="}[m8CJ[~.H(X2Ez)$MNC">
        </shadow>
        <block type="math_rndfixed" id="F$p9}8[w8:T(m=e~CovU">
        <value name="x">
        <shadow type="math_number" id="RA,BraD%kOetT,YHoI^E">
        </shadow>
        <block type="get_value_var" id="m3kCO;qi/UVymfMc-a^S">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="itHxUmSztiKq#*Ks;J@g">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="Gq}sI5FR]paEBl+;3+e">
        <field name="TEXT">kWh.</field>
        </block>
        </value>
        <value name="ADD9">
        <block type="time_get" id="Y::7Q};)~]J%;pazFL$-">
        </block>
        </value>
        <value name="ADD10">
        <block type="text" id=":9AW!oL(k/~DAOIvpo.B">
        <field name="TEXT">Kosten:</field>
        </block>
        </value>
        <value name="ADD11">
        <block type="math_rndfixed" id=",4=#-lGzI:f:Ap/,[n?9">
        <value name="x">
        <shadow type="math_number" id="xB4np%~c;TqHj([{.Tdr">
        </shadow>
        <block type="get_value_var" id="||^gpO+zJzH_~C;0aP*_">
        <value name="OID">
        </shadow>
        <block type="variables_get" id="}++0hy7-PR)Tb-8D|:)p">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD12">
        <block type="text" id="Mjs)p.:/ObS*R{2tiwa7">
        <field name="TEXT">€</field>
        </block>
        </value>
        </block>
        </value>
        <block type="text" id="F-U1oN3NElzVk6CJ);7R">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <block type="timeouts_settimeout" id="5eCX;s4%zZGWS;Kg_9D1">
        <field name="DELAY">40</field>
        <block type="variables_set" id="3p2f0I240p9[+F;-I-k/">
        <block type="math_number" id="pEblBF9FjJdAXjifbc)">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
                                                              </block>
                                                            </statement>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </xml>
                            Oder was faslch umgesetzt?
                            Muss jetzt bloss mal schaune, das ich ein wenig Geschirr dreckig mache 😊
                            • SlowmanS Slowman
                              @Asgothian
                                <variables>
                                </variables>
                                    </block>
                                  </value>
                                  <next>
                                        </block>
                                      </value>
                                      <next>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                              <next>
                                                  <value name="OID0">
                                                    </shadow>
                                                  </value>
                                                      <value name="IF0">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                              <next>
        </shadow>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                      <value name="IF1">
                                                          <value name="A">
                                                              <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                          <next>
        <value name="IF0">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="A">
        </shadow>
        <value name="x">
        </shadow>
        <value name="A">
        </shadow>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        <next>
        <next>
        <value name="x">
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <next>
        </block>
        </value>
        <next>
        <next>
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        <value name="ADD6">
        </block>
        </value>
        <value name="ADD7">
        </shadow>
        <value name="x">
        </shadow>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD8">
        </block>
        </value>
        <value name="ADD9">
        </block>
        </value>
        </block>
        </value>
        <value name="x">
        </shadow>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
                                                              </statement>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </xml>
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #96
                              @Slowman
                              das ist soweit ok. Aber:
                              Die Werte werden möglicherweise weiter nicht passen:
                              Die Werte in dem Screenshot oben kommen ja von den jeweiligen "Energy" Datenpunkten deiner Energiemessung. Und da sieht man:
                              Waschmaschine: Anfang 99.43, Ende 99.15. - Delta 0.4
                              Spülmaschine: Anfang 119345, Ende 159382 - Delta 40000
                              Wenn ich mir die Faustregel "Ein Waschgang kostet im Schnitt ca. 30 cent" anschaue, dann scheint die Waschmaschine den Energiewert in kW anzugeben während bei der Spülmaschine eher Watt angegeben sind.
                              Du musst also nachschauen in welchen Einheiten deine Energiemessung stattfindet. Nur wenn da auch vergleichbare Einheiten genutzt werden kannst du identische Skripte nutzen. Ansonsten musst du die Formel hier anpassen: Screen Shot 2020-08-30 at 12.08.15 .png
                              A.
                                @Slowman
                                A.
                                SlowmanS Offline
                                SlowmanS Offline
                                Slowman
                                #97
                                @Asgothian
                                Danke, man eh darauf bin ich nicht gekommen 🙄
                                Sind beides Shellys, da denkt man an so was nicht.
                                • SlowmanS Slowman
                                  @Asgothian
                                  SlowmanS Offline
                                  SlowmanS Offline
                                  Slowman
                                  #98
                                  @Asgothian
                                  Muss doch irgendwo ein Fehler sein 🙄
                                  • SlowmanS Slowman
                                    @Asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #99
                                    @Slowman Stimmt.. lesen hilft..
                                    bei diesen Bausteinen muss das "wert von" weg..
                                    Statt dessen einfach "Stromverbrauch pro Waschgang" nehmen.
                                    Das gleiche überall da wo mit der Variable rechnen willst.
                                    A.
                                      A.
                                      SlowmanS Offline
                                      SlowmanS Offline
                                      Slowman
                                      #100
                                      @Asgothian
                                      Danke, habe es jetzt abgeändert.
                                      • SlowmanS Slowman
                                        @Asgothian
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #101
                                        @Slowman so sollte es passen
                                          SlowmanS Offline
                                          SlowmanS Offline
                                          Slowman
                                          #102
                                          @Asgothian
                                          Mit dem niedrigen KW Anzeige, kenne ich den Fehler. Aber warum der Preis 0,00€ nicht. Schaut noch mal einer rüber.
