  4. (gelöst) Gestern Updates gemacht, heute nicht erreichbar ?
    6.6k
raspberry 3
52 Beiträge 7 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • HumidorH Humidor
    2020-08-27 04:58:36.675 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 04:59:07.506 - error: host.humidor Cannot read disk size: Error: spawn ENOMEM
    2020-08-27 04:59:35.959 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 04:59:35.964 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 04:59:35.973 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 04:59:36.769 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 04:59:37.770 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 04:59:37.847 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:00:37.148 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:00:37.152 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:00:37.163 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 05:00:38.280 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:00:39.289 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:00:39.335 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:01:38.695 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:01:38.700 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:01:38.703 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 05:01:39.549 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:01:40.534 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:01:40.621 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:02:40.073 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:02:40.076 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 05:02:40.078 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:02:41.015 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:02:42.059 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:02:42.114 - info: web.0 (25245) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 05:03:41.588 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:03:41.609 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 05:03:41.614 - info: web.0 (25245) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 05:14:25.754 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.176 please reconnect the Device
    2020-08-27 05:17:05.527 - info: harmony.0 (28176) [CONNECT] lost Connection to HamonyHub3001 (192.168.0.135)
    2020-08-27 05:40:24.040 - error: iot.0 (2442) Error by device connection: "This socket has been ended by the other party"
    2020-08-27 06:02:55.794 - info: cloud.0 (1138) Connection changed: transport close
    2020-08-27 05:46:01.524 - info: iot.0 (2442) Connection changed: disconnect
    2020-08-27 05:52:57.147 - info: iot.0 (2442) Connection lost
    2020-08-27 06:09:57.685 - info: cloud.0 (1138) Connection lost
    2020-08-27 07:27:39.956 - error: host.humidor Cannot read disk size: Error: spawn ENOMEM
    2020-08-27 05:28:26.159 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.177 please reconnect the Device
    2020-08-27 05:46:12.717 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.176 please reconnect the Device
    2020-08-27 06:00:30.886 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.177 please reconnect the Device
    2020-08-27 06:21:19.287 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.176 please reconnect the Device
    2020-08-27 06:36:17.000 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.177 please reconnect the Device
    2020-08-27 06:56:28.302 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.176 please reconnect the Device
    2020-08-27 07:18:13.783 - warn: hs100.0 (1258) getDevice Socket connection Timeout ip: 192.168.0.177 please reconnect the Device
    2020-08-27 08:04:17.579 - error: iot.0 (2442) Error by device connection: "premature close"
    2020-08-27 08:30:05.986 - info: host.humidor iobroker.js-controller version 3.1.6 js-controller starting
    2020-08-27 08:30:05.997 - info: host.humidor Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2020-08-27 08:30:05.998 - info: host.humidor hostname: humidor, node: v12.18.2
    2020-08-27 08:30:06.002 - info: host.humidor ip addresses: 192.168.0.153 fe80::212e:9e36:4462:6d29
    2020-08-27 08:30:06.632 - error: host.humidor Cannot parse /opt/iobroker/iobroker-data/states.json: SyntaxError: Unexpected token t in JSON at position 366115
    2020-08-27 08:30:06.747 - info: host.humidor connected to Objects and States
    2020-08-27 08:30:07.366 - info: host.humidor 18 instances found
    2020-08-27 08:30:07.468 - info: host.humidor starting 17 instances
    2020-08-27 08:30:07.527 - info: host.humidor instance system.adapter.admin.0 started with pid 608
    2020-08-27 08:30:11.513 - info: host.humidor instance system.adapter.info.0 started with pid 619
    2020-08-27 08:30:12.596 - info: admin.0 (608) starting. Version 4.1.7 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:30:12.739 - info: admin.0 (608) requesting all states
    2020-08-27 08:30:12.743 - info: admin.0 (608) requesting all objects
    2020-08-27 08:30:14.044 - info: admin.0 (608) received all objects
    2020-08-27 08:30:14.519 - info: admin.0 (608) http server listening on port 8081
    2020-08-27 08:30:14.521 - info: admin.0 (608) Use link "http://localhost:8081" to configure.
    2020-08-27 08:30:15.490 - info: host.humidor instance system.adapter.zigbee.0 started with pid 638
    2020-08-27 08:30:19.495 - info: host.humidor instance system.adapter.web.0 started with pid 653
    2020-08-27 08:30:20.596 - info: zigbee.0 (638) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:30:20.669 - info: zigbee.0 (638) Starting Zigbee...
    2020-08-27 08:30:21.648 - info: info.0 (619) starting. Version 1.7.7 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:30:23.471 - info: web.0 (653) starting. Version 3.0.12 in /opt/iobroker/node_modules/iobroker.web, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:30:23.507 - info: host.humidor instance system.adapter.harmony.0 started with pid 850
    2020-08-27 08:30:24.027 - info: zigbee.0 (638) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
    2020-08-27 08:30:24.039 - info: zigbee.0 (638) Disable LED
    2020-08-27 08:30:24.049 - info: zigbee.0 (638) --> transmitPower : normal
    2020-08-27 08:30:24.080 - info: zigbee.0 (638) Currently 3 devices are joined:
    2020-08-27 08:30:24.105 - info: zigbee.0 (638) 0x00158d00042704c0 (addr 44909): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2020-08-27 08:30:24.113 - info: zigbee.0 (638) 0x00158d00053f90d3 (addr 17184): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2020-08-27 08:30:24.118 - info: zigbee.0 (638) 0x00124b00210c308b (addr 29135): GL-MC-001 - Gledopto Zigbee USB mini LED controller RGB + CCT (Router)
    2020-08-27 08:30:24.122 - info: zigbee.0 (638) Zigbee started
    2020-08-27 08:30:24.154 - info: web.0 (653) socket.io server listening on port 8082
    2020-08-27 08:30:24.165 - info: web.0 (653) http server listening on port 8082
    2020-08-27 08:32:53.030 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.170
    2020-08-27 08:32:53.033 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.170
    2020-08-27 08:32:53.703 - info: harmony.0 (850) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.harmony, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:32:53.769 - info: harmony.0 (850) [DISCOVER] Searching for Harmony Hubs on 192.168.000.135
    2020-08-27 08:32:53.828 - info: host.humidor instance system.adapter.telegram.0 started with pid 1137
    2020-08-27 08:32:56.123 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.170
    2020-08-27 08:32:56.165 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:32:56.333 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.170 flot
    2020-08-27 08:32:56.339 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.170 flot
    2020-08-27 08:32:57.800 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.170
    2020-08-27 08:32:57.830 - info: host.humidor instance system.adapter.javascript.0 started with pid 1148
    2020-08-27 08:32:57.985 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:32:58.287 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:32:58.409 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.170
    2020-08-27 08:32:58.479 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.170
    2020-08-27 08:32:59.114 - info: telegram.0 (1137) starting. Version 1.5.9 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:01.825 - info: host.humidor instance system.adapter.cloud.0 started with pid 1161
    2020-08-27 08:33:03.844 - info: javascript.0 (1148) starting. Version 4.6.26 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:04.086 - info: harmony.0 (850) [DISCOVER] Discovered HamonyHub3001 (192.168.0.135) and will try to connect
    2020-08-27 08:33:04.134 - info: javascript.0 (1148) requesting all states
    2020-08-27 08:33:04.138 - info: javascript.0 (1148) requesting all objects
    2020-08-27 08:33:04.223 - info: harmony.0 (850) [CONNECT] Connecting to HamonyHub3001 (192.168.0.135)
    2020-08-27 08:33:05.430 - info: javascript.0 (1148) received all objects
    2020-08-27 08:33:05.450 - info: harmony.0 (850) [CONNECT] Connected to HamonyHub3001 (192.168.0.135)
    2020-08-27 08:33:05.524 - info: javascript.0 (1148) received all states
    2020-08-27 08:33:05.668 - info: javascript.0 (1148) Start javascript script.js.common.Humi_Temp
    2020-08-27 08:33:05.831 - info: host.humidor instance system.adapter.iot.0 started with pid 1180
    2020-08-27 08:33:05.794 - info: javascript.0 (1148) script.js.common.Humi_Temp: registered 1 subscription and 0 schedules
    2020-08-27 08:33:05.795 - info: javascript.0 (1148) Start javascript script.js.common.Humi_Door
    2020-08-27 08:33:05.807 - info: javascript.0 (1148) script.js.common.Humi_Door: registered 1 subscription and 0 schedules
    2020-08-27 08:33:05.810 - info: javascript.0 (1148) Start javascript script.js.common.Humi_Humidity
    2020-08-27 08:33:05.821 - info: javascript.0 (1148) script.js.common.Humi_Humidity: registered 2 subscriptions and 0 schedules
    2020-08-27 08:33:05.823 - info: javascript.0 (1148) Start javascript script.js.common.Humi_Lights
    2020-08-27 08:33:05.832 - info: javascript.0 (1148) script.js.common.Humi_Lights: registered 1 subscription and 0 schedules
    2020-08-27 08:33:05.849 - info: javascript.0 (1148) Start javascript script.js.common.Humi_Meldung
    2020-08-27 08:33:05.885 - info: javascript.0 (1148) script.js.common.Humi_Meldung: registered 2 subscriptions and 1 schedule
    2020-08-27 08:33:06.388 - info: harmony.0 (850) [PROCESS] Synced hub config for HamonyHub3001 (192.168.0.135)
    2020-08-27 08:33:06.714 - info: cloud.0 (1161) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:06.842 - warn: cloud.0 (1161) Please use ioBroker.iot for alexa control
    2020-08-27 08:33:06.849 - info: cloud.0 (1161) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
    2020-08-27 08:33:07.223 - info: cloud.0 (1161) Trying to connect as system.user.admin
    2020-08-27 08:33:07.783 - info: cloud.0 (1161) Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
    2020-08-27 08:33:07.788 - info: cloud.0 (1161) Connection changed: io client disconnect
    2020-08-27 08:33:09.823 - info: host.humidor instance system.adapter.hue.0 started with pid 1195
    2020-08-27 08:33:11.300 - info: iot.0 (1180) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.iot, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:11.359 - info: iot.0 (1180) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2020-08-27 08:33:12.461 - info: iot.0 (1180) Connection changed: connect
    2020-08-27 08:33:13.409 - info: hue.0 (1195) starting. Version 3.3.5 in /opt/iobroker/node_modules/iobroker.hue, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:13.935 - info: hue.0 (1195) skip switch: Daylight.configured
    2020-08-27 08:33:13.937 - info: hue.0 (1195) skip switch: Daylight.sunriseoffset
    2020-08-27 08:33:13.938 - info: hue.0 (1195) skip switch: Daylight.sunsetoffset
    2020-08-27 08:33:13.946 - info: hue.0 (1195) skip switch: Dimmer Switch 2 SceneCycle.status
    2020-08-27 08:33:13.950 - info: hue.0 (1195) skip switch: Licht-Status.status
    2020-08-27 08:33:13.951 - info: hue.0 (1195) created/updated 4 sensor channels
    2020-08-27 08:33:13.965 - info: hue.0 (1195) created/updated 5 light channels
    2020-08-27 08:33:13.979 - info: hue.0 (1195) created/updated 5 groups channels
    2020-08-27 08:33:13.984 - info: hue.0 (1195) created/updated 8 scenes
    2020-08-27 08:33:13.985 - info: hue.0 (1195) creating/updating bridge device
    2020-08-27 08:33:16.421 - info: vis.0 (1214) starting. Version 1.2.11 in /opt/iobroker/node_modules/iobroker.vis, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:16.820 - info: vis.0 (1214) vis license is OK.
    2020-08-27 08:33:17.819 - info: host.humidor instance system.adapter.fritzdect.0 started with pid 1229
    2020-08-27 08:33:19.239 - info: vis.0 (1214) Terminated (NO_ERROR): Without reason
    2020-08-27 08:33:19.792 - info: host.humidor instance system.adapter.vis.0 terminated while should be started once
    2020-08-27 08:33:21.834 - info: host.humidor instance system.adapter.history.0 started with pid 1240
    2020-08-27 08:33:22.337 - info: fritzdect.0 (1229) starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:22.391 - info: fritzdect.0 (1229) entered ready
    2020-08-27 08:33:24.906 - info: history.0 (1240) starting. Version 1.9.10 in /opt/iobroker/node_modules/iobroker.history, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:25.049 - info: history.0 (1240) enabled logging of zigbee.0.00158d00042704c0.temperature (Count=1), Alias=false
    2020-08-27 08:33:25.051 - info: history.0 (1240) enabled logging of zigbee.0.00158d00042704c0.humidity (Count=2), Alias=false
    2020-08-27 08:33:25.834 - info: host.humidor instance system.adapter.backitup.0 started with pid 1259
    2020-08-27 08:33:26.795 - info: fritzdect.0 (1229) Talking to FritzBox with firmware: 07.13
    2020-08-27 08:33:27.003 - info: fritzdect.0 (1229) create Devices 2
    2020-08-27 08:33:27.006 - info: fritzdect.0 (1229) setting up Switch/DECT2xx object Espresso
    2020-08-27 08:33:27.030 - info: fritzdect.0 (1229) setting up Switch/DECT2xx object Ultimaker
    2020-08-27 08:33:29.830 - info: host.humidor instance system.adapter.hs100.0 started with pid 1266
    2020-08-27 08:33:32.474 - info: hs100.0 (1266) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:32.523 - info: hs100.0 (1266) Start with IP : 192.168.0.176
    2020-08-27 08:33:32.625 - info: hs100.0 (1266) Start with IP : 192.168.0.177
    2020-08-27 08:33:33.840 - info: host.humidor instance system.adapter.rpi2.0 started with pid 1285
    2020-08-27 08:33:34.566 - info: backitup.0 (1259) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:34.666 - info: backitup.0 (1259) [iobroker] backup was activated at 06:10 every 1 day(s)
    2020-08-27 08:33:36.040 - info: rpi2.0 (1285) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v12.18.2, js-controller: 3.1.6
    2020-08-27 08:33:36.272 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 08:33:36.279 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 08:33:36.282 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 08:33:38.133 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:33:39.317 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:33:39.369 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:34:07.820 - info: cloud.0 (1161) Trying to connect as system.user.admin
    2020-08-27 08:34:08.146 - info: cloud.0 (1161) Connection changed: connect
    2020-08-27 08:34:38.528 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 08:34:38.534 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.116 flot
    2020-08-27 08:34:38.546 - info: web.0 (653) <==Disconnect system.user.admin from 192.168.0.116 vis.0
    2020-08-27 08:34:39.643 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:34:40.596 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    2020-08-27 08:34:40.641 - info: web.0 (653) ==>Connected system.user.admin from 192.168.0.116
    @Humidor sagte in Gestern Updates gemacht, heute nicht erreichbar ?:
    Error: spawn ENOMEM
    RAM ist voll.
    HumidorH 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Error: spawn ENOMEM
      RAM ist voll.
      HumidorH Offline
      HumidorH Offline
      Humidor
      @apollon77 sagte in Gestern Updates gemacht, heute nicht erreichbar ?:
      Error: spawn ENOMEM
      RAM ist voll.
      OK, wie kommt das??
      BG
      • HumidorH Humidor
        Systemdata Bitte Ausfüllen
        Hardwaresystem: Pi3B +
        Arbeitsspeicher: 1GB
        Festplattenart: SD-Karte
        Betriebssystem: Raspb
        Node-Version: 12.18.2
        Nodejs-Version: 12.18.2
        NPM-Version: 6.14.5
        Installationsart: Skript
        Image genutzt: Ja
        Ort iobroker
        Kann ich etwas für euch rausfinden, ich werde dann den Pi Spannungslos machen und wieder aktivieren, verm. fkt. er dann wieder normal.
        BG
        Jan1
        Hardwaresystem:
        Pi3B +
        Arbeitsspeicher:
        1GB
        ist eben nicht viel
        • J Jan1
          Hardwaresystem:
          Pi3B +
          Arbeitsspeicher:
          1GB
          ist eben nicht viel
          HumidorH Offline
          HumidorH Offline
          Humidor
          @Jan1 sagte in Gestern Updates gemacht, heute nicht erreichbar ?:
          Hardwaresystem:
          Pi3B +
          Arbeitsspeicher:
          1GB
          ist eben nicht viel
          dh iobroker killt sich selbst an den Ressourcen?
          Datenträger verfügbar: 83.4 %, gesamte RAM-Nutzung: 920 MB / Frei: 44% = 411 MB
          BG
          • HumidorH Humidor
            Hardwaresystem:
            Pi3B +
            Arbeitsspeicher:
            1GB
            ist eben nicht viel
            Jan1
            @Humidor
            Es gibt viel Möglichkeiten warum der RAM ausgeht. Ich hatte auch den PI3B+ und eher weniger Probleme mit dem RAM, aber war immer schwer an der Grenze.
            Viele Adapter und Instanzen, oder einfach ein Script, das ein Loop auslöst und das 1GB RAM reicht nicht mehr. Im Log wird es ja angezeigt, dass zu dem Zeitpunkt kein RAM mehr zur Verfügung stand. Da Du jetzt wieder genügend frei hast, tippe ich auf ein fehlerhaftes Script.
            • J Jan1
              @Humidor
              HumidorH Offline
              HumidorH Offline
              Humidor
              @Jan1
              letzte Script Änderung war diese:
              Bild Text
              BG
              • HumidorH Humidor
                @Thomas-Braun sagte in Gestern Updates gemacht, heute nicht erreichbar ?:
                @Humidor Wenn du da jetzt gar nicht mehr dran kommst bleibt dir wohl leider nichts anderes übrig als die Kiste vom Strom zu nehmen. Kannst dann nur hoffen, das sich das Dateisystem dabei nicht zerlegt. Dann
                sudo apt update
                sudo apt dist-upgrade
                sudo reboot
                läuft gerade
                HumidorH Offline
                HumidorH Offline
                Humidor
                @Humidor
                jetzt sagt er mir ich soll iQontrol updaten
                BG
                • HumidorH Humidor
                  @Humidor
                  Jan1
                  @Humidor
                  es kann auch bei einem Update der RAM ausgehen und je nach dem was Du gerade updatest, kann es dabei zu einem Abbruch kommen, wie geschrieben, es gibt sehr viele Möglichkeiten.
                  • J Jan1
                    @Humidor
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    @Jan1
                    OK, dann gehe ich von einem RAM Überlauf aus, da er viele Adapter hintereinander upgedatet hat. Das mach ich dann so nicht mehr. Danke!
                    BG
                    J apollon77A 2 Antworten Letzte Antwort
                    • HumidorH Humidor
                      @Jan1
                      Jan1
                      @Humidor
                      Wenn Du updatest, dann schalte vorher ein paar Adapter aus, das spart schon mal viel RAM und somit sollte ein Update auch nicht zu einem RAM Überlauf führen.
                      @Thomas-Braun wird dir dann noch was zum Runlevel sagen, was unter Umständen noch mal richtig spart ;-)
                      • J Jan1
                        @Humidor
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        @Jan1
                        Danke!
                        kann man zu dem ständigen pollen vom web. auf ein sinnlose?? IP Adresse was sagen oder abstellen? gibt es noch weitere Einträge die Optimierung haben möchten ?
                        BG
                        • HumidorH Humidor
                          @Jan1
                          @Humidor Sorry aber das ist blödsinn. Wenn das RAM so "voll" ist das es bei einem Update eines normalen Adapters (ich nehme jetzt mal "sql" aus gewisen gründen aus) kritisch wird ist einfach generell zuviel am laufen.
                          Also die üblichen Fragen bei "uups RAM knapp" ist: Wieviele Instanzen laufen denn so bei dir?
                          Was sagt "top" wenn du nach RAM verbrauch schaust?
                          Bedenke bitte das jeder Adapter mindestens 30-50MB RAM benötigt, einige wenige auch mal mehr. Bedeutet das bei 50MB im Schnitt und 20 Instanten laut Adam Riess schon 1 GB voll ist - und da hat das Linux System selbst noch nichts gehabt. Daher liegt ein sinnvolles Limit bei 1GB (und ohne den Compact Mode zu nutzen) bei 10-12 Instanzen ...
                            HumidorH Offline
                            HumidorH Offline
                            Humidor
                            @apollon77 Datenträger verfügbar: 83.3 %, gesamte RAM-Nutzung: 865 MB / Frei: 42% = 390 MB [Host: humidor - 14 Prozesse]
                            BG
                            • HumidorH Humidor
                              das passt aber bei 1GB RAM nicht
                              HumidorH HomoranH 2 Antworten Letzte Antwort
                                HumidorH Offline
                                HumidorH Offline
                                Humidor
                                @Homoran
                                standard raspi3b+, ich hab daran nix verändert
                                BG
                                  @Homoran sagte in Gestern Updates gemacht, heute nicht erreichbar ?:
                                  bitte wie von @apollon77 gebeten, die ausgabe von top auf der Konsole
                                    HumidorH Offline
                                    HumidorH Offline
                                    Humidor
                                    schrieb am zuletzt editiert von Humidor
                                    @Homoran
                                    Bild Text
                                    BG
                                    • HumidorH Humidor
                                      @Homoran
                                      Bild Text
                                      @Humidor bitte nicht das wichtigste oben abschneiden
                                        HumidorH Offline
                                        HumidorH Offline
                                        Humidor
                                        hab ich schon gesehen und geändert
                                        BG
                                        • HumidorH Humidor
                                          @Humidor ok - das erklärt die Werte in dem admin
                                          102 free + 210 buffered = 301 avail.
                                          Wenn du jetzt noch den output von iobroker list instances als text in code-tags zeigst, kann man noch besser sehen, wie dicht du an der Klippe stehst
