  4. Node-Red
  5. Node-Red Hilfe
    6.6k
Node-Red Hilfe
103 Beiträge 3 Kommentatoren 15.1k Aufrufe 2 Beobachtet
  • mickymM mickym
    @stefan22 dann ist das noch eine ebene tiefer. mach mal die Debug node hinter die JSON Node und poste was im Debug fenster kommt.
    Ich sehe halt nicht wie das JSON Objekt aussieht.
    Also entweder ist es wie nun im Flow:
    msg.payload.entry = 0 oder 1
    oder msg.payload.event.entry = 0 oder 1
    ich habe aber mal den Flow angepasst - also nochmal importieren.
            "id": "68445dbe.e7b174",
            "type": "http in",
            "z": "95192ab3.686148",
            "name": "",
            "url": "/geofancy",
            "method": "get",
            "upload": false,
            "swaggerDoc": "",
            "x": 180,
            "y": 240,
            "wires": [
                    "780be9d.7dd5618",
                    "c167a924.fc6e08"
            "id": "b0d69307.06bbf",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 570,
            "y": 140,
            "wires": []
            "id": "780be9d.7dd5618",
            "type": "http response",
            "name": "",
            "statusCode": "",
            "headers": {},
            "x": 390,
            "y": 100,
            "wires": []
            "id": "c167a924.fc6e08",
            "type": "json",
            "name": "",
            "property": "payload",
            "action": "",
            "pretty": false,
            "x": 380,
            "y": 240,
            "wires": [
                    "d4a40755.da6318",
                    "b0d69307.06bbf"
            "id": "b974c6a8.2a6948",
            "type": "udp out",
            "name": "",
            "addr": "",
            "iface": "",
            "port": "",
            "ipv": "udp4",
            "outport": "",
            "base64": false,
            "multicast": "false",
            "x": 950,
            "y": 280,
            "wires": []
            "id": "d4a40755.da6318",
            "type": "switch",
            "name": "",
            "property": "payload.entry",
            "propertyType": "msg",
            "rules": [
                    "t": "eq",
                    "v": "0",
                    "vt": "num"
                    "t": "eq",
                    "v": "1",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 530,
            "y": 240,
            "wires": [
                    "c373e33d.018b9"
                    "69ba9e47.902"
            "id": "c373e33d.018b9",
            "type": "change",
            "name": "setze true",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 700,
            "y": 200,
            "wires": [
                    "b974c6a8.2a6948",
                    "d74c2041.014ed"
            "id": "69ba9e47.902",
            "type": "change",
            "name": "setze false",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 710,
            "y": 280,
            "wires": [
                    "b974c6a8.2a6948",
                    "d74c2041.014ed"
            "id": "d74c2041.014ed",
            "type": "debug",
            "name": "KNXGerät",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "x": 970,
            "y": 200,
            "wires": []
    ich sehe Du hast die Change Node genommen.
    Dann muss es halt heissen: msg.payload.event.entry im Vergleich ist nur der Wert der zu vergleichen ist also 0 oder 1
    stefan22
    @mickym 9A6DE770-7568-460D-A704-C6A9CAFB63EE.jpeg 188F7C46-BC2D-4396-BC8E-8589A89BAD0F.jpeg
    So kommt entry bei kommen und gehen an
    • S stefan22
      mickymM Online
      mickymM Online
      mickym
      @stefan22 Ich sehe das zwar immer noch nicht genau - da wenn Du die Debug node nach dem JSON Node steckst - dann wird nicht mehr der JSON string sondern das Objekt ausgegeben:
      Ich gehe aber mal davon aus - dass es direkt entry:0 oder 1 heißt
              "type": "http in",
              "name": "",
              "url": "/geofancy",
              "method": "get",
              "upload": false,
              "swaggerDoc": "",
              "x": 160,
              "y": 680,
              "wires": [
                      "780be9d.7dd5618",
                      "c167a924.fc6e08"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 550,
              "y": 580,
              "wires": []
              "name": "",
              "statusCode": "",
              "headers": {},
              "x": 370,
              "y": 540,
              "wires": []
              "type": "json",
              "name": "",
              "action": "",
              "pretty": false,
              "x": 360,
              "y": 680,
              "wires": [
                      "b0d69307.06bbf",
                      "d93825a1.3614d8"
              "type": "debug",
              "name": "KNXGerät",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 830,
              "y": 680,
              "wires": []
              "id": "d93825a1.3614d8",
              "type": "change",
              "name": "translate entry",
              "rules": [
                      "t": "change",
                      "p": "payload.entry",
                      "pt": "msg",
                      "from": "1",
                      "fromt": "num",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "pt": "msg",
                      "from": "0",
                      "fromt": "num",
                      "to": "false",
                      "tot": "bool"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload.entry",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 580,
              "y": 680,
              "wires": [
                      "d74c2041.014ed"
      ggf. sind halt die 0 oder 1 doch strings - aber das sieht man eben nach der JSON Node - an dem Java Objekt.
      • mickymM mickym
                "type": "http in",
                "name": "",
                "url": "/geofancy",
                "method": "get",
                "upload": false,
                "swaggerDoc": "",
                "x": 160,
                "y": 680,
                "wires": [
                        "780be9d.7dd5618",
                        "c167a924.fc6e08"
                "type": "debug",
                "name": "",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 550,
                "y": 580,
                "wires": []
                "name": "",
                "statusCode": "",
                "headers": {},
                "x": 370,
                "y": 540,
                "wires": []
                "type": "json",
                "name": "",
                "action": "",
                "pretty": false,
                "x": 360,
                "y": 680,
                "wires": [
                        "b0d69307.06bbf",
                        "d93825a1.3614d8"
                "type": "debug",
                "name": "KNXGerät",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 830,
                "y": 680,
                "wires": []
                "type": "change",
                "rules": [
                        "t": "change",
                        "pt": "msg",
                        "from": "1",
                        "fromt": "num",
                        "to": "true",
                        "tot": "bool"
                        "t": "change",
                        "pt": "msg",
                        "from": "0",
                        "fromt": "num",
                        "to": "false",
                        "tot": "bool"
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 580,
                "y": 680,
                "wires": [
                        "d74c2041.014ed"
        stefan22
        @mickym ich hab’s die JsonNode muss unter Aktion Immer in JavaScript-Objekt konvertieren stehen . Jetzt bekomm ich auch Objekt True and False beim KNX Gerät 😊
        • S stefan22
          mickymM Online
          mickymM Online
          mickym
          @stefan22
          Wenn Du die 1. Option lässt - dann erkennt der JSON Node automatisch in was er konvertieren muss. Sobald ein String eingeht - kommt ein Objekt raus. Wenn Du den Node mit einem Objekt fütterst kommt der String raus. ;)
          "Konvertieren zwischen JSON Zeichenfolge und Objekt"
          • mickymM mickym
            @stefan22
            stefan22
            @mickym lach das machtS aber nicht lass ich das erste bekomm ich beim KNX nur undefined 🤔
            • S stefan22
              stefan22
              @stefan22 so ich muss mich für heut leider ausklinken. 😤 um 5 Uhr klingelt der Wecker . Erstma danke für alles .
              • S stefan22
                mickymM Online
                mickymM Online
                mickym
                @stefan22 OK - ich glaube Du hast das Prinzip in etwa verstanden . Dann gN8. ;)
                • mickymM mickym
                  stefan22
                  @mickym dir auch . Falls es dir nix aus macht würd ich dich gern noch mit Fragen belästigen 😂 wie zb was du mit den Ebenen gemeint hast . Guads Nächtle
                  • S stefan22
                    mickymM Online
                    mickymM Online
                    mickym
                    @stefan22 said in Node-Red Hilfe:
                    Hier mal ein Flow - JSON String wird in JAVA Objekt gewandelt und Zugriff in Node-Red auf die einzelnen Ebenen:
                            "id": "97bae588.9799e8",
                            "type": "inject",
                            "z": "8ed5790c.6a1888",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "{   \"FirstName\": \"Fred\",   \"Surname\": \"Smith\",   \"Age\": 28,   \"Address\": {     \"Street\": \"Hursley Park\",     \"City\": \"Winchester\",     \"Postcode\": \"SO21 2JN\"   },   \"Phone\": [     {       \"type\": \"home\",       \"number\": \"0203 544 1234\"     },     {       \"type\": \"office\",       \"number\": \"01962 001234\"     },     {       \"type\": \"office\",       \"number\": \"01962 001235\"     },     {       \"type\": \"mobile\",       \"number\": \"077 7700 1234\"     }   ],   \"Email\": [     {       \"type\": \"work\",       \"address\": [\"fred.smith@my-work.com\", \"fsmith@my-work.com\"]     },     {       \"type\": \"home\",       \"address\": [\"freddy@my-social.com\", \"frederic.smith@very-serious.com\"]     }   ],   \"Other\": {     \"Over 18 ?\": true,     \"Misc\": null,     \"Alternative.Address\": {       \"Street\": \"Brick Lane\",       \"City\": \"London\",       \"Postcode\": \"E1 6RF\"     }   } }",
                            "payloadType": "str",
                            "x": 170,
                            "y": 180,
                            "wires": [
                                    "9478e068.1996f",
                                    "eba2bc65.7a84e"
                            "id": "9478e068.1996f",
                            "type": "debug",
                            "name": "Kein Objekt - String - Ebene 0",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 430,
                            "y": 80,
                            "wires": []
                            "id": "eba2bc65.7a84e",
                            "type": "json",
                            "name": "",
                            "action": "",
                            "pretty": false,
                            "x": 370,
                            "y": 180,
                            "wires": [
                                    "56ecb3c4.3b043c",
                                    "3dffdc6c.fbe1f4",
                                    "19f597c9.9b6798",
                                    "c247ca8c.d769b8",
                                    "dbe07379.31f3e",
                                    "1c006873.31a2e8",
                                    "4f084632.928e88"
                            "id": "56ecb3c4.3b043c",
                            "type": "debug",
                            "name": "Objekt Ebene 0 - enthält gesamtes Projekt",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 820,
                            "y": 80,
                            "wires": []
                            "id": "3dffdc6c.fbe1f4",
                            "type": "change",
                            "name": "First Name",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.FirstName",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 790,
                            "y": 180,
                            "wires": [
                                    "269e90a7.c4aba"
                            "id": "269e90a7.c4aba",
                            "type": "debug",
                            "name": "1. Ebene im Objekt z.Bsp. FirstName",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 1210,
                            "y": 80,
                            "wires": []
                            "id": "19f597c9.9b6798",
                            "type": "change",
                            "name": "Adresse - Straße",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.Address.Street",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 620,
                            "y": 340,
                            "wires": [
                                    "f8d70dc4.bcdc2"
                            "id": "f8d70dc4.bcdc2",
                            "type": "debug",
                            "name": "2. Ebene im Objekt z.Bsp. Adresse-Straße",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 940,
                            "y": 340,
                            "wires": []
                            "id": "c247ca8c.d769b8",
                            "type": "change",
                            "name": "Objekt 0 im Array Telefonnummern",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.Phone.0.type",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 680,
                            "y": 440,
                            "wires": [
                                    "3f3e7fa7.d5fa9"
                            "id": "3f3e7fa7.d5fa9",
                            "type": "debug",
                            "name": "3. Ebene im Objekt z.Bsp. 1. Telefon Objekt - Typ",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 1090,
                            "y": 440,
                            "wires": []
                            "id": "90e7c28.3d7cd4",
                            "type": "debug",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 1090,
                            "y": 500,
                            "wires": []
                            "id": "dbe07379.31f3e",
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.Phone[0].type",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 680,
                            "y": 500,
                            "wires": [
                                    "90e7c28.3d7cd4"
                            "id": "5f8e439c.1b10bc",
                            "type": "debug",
                            "name": "4. Ebene im Objekt z.Bsp. 1. private E-Mail Adresse",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 1090,
                            "y": 560,
                            "wires": []
                            "id": "1c006873.31a2e8",
                            "type": "change",
                            "name": "Objekt 0 im Array private E-Mail Adresse",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.Email.1.address.0",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 700,
                            "y": 560,
                            "wires": [
                                    "5f8e439c.1b10bc"
                            "id": "4f084632.928e88",
                            "type": "change",
                            "name": "alle privaten E-Mails",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.Email.1",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 640,
                            "y": 640,
                            "wires": [
                                    "7d26ab46.cb6d24"
                            "id": "7d26ab46.cb6d24",
                            "type": "debug",
                            "name": "1. Ebene als Objekt",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 910,
                            "y": 640,
                            "wires": []
                    Im Debug Fenster - die Ausgabe des JSON Strings als String aus der 1. Debug Node (Kein Objekt - String - Ebene 0) - deswegen flach alles in rot.
                    Sobald mit dem JSON Node in Objekt umgewandelt wurde - kannst Du die einzelnen Objekte im Debug-Fenster aufmachen oder komprimieren.
                    Ebene 0 ist also aus meiner Sicht das ganze Objekt.
                    Die anderen Nodes zeigen wie Du auf die verschiedenen Ebenen direkt zugreifst.
                    Im letzten Beispiel siehst Du das man auch ganze Objekte aus den unteren Ebenen "herauslösen kann":
                    s. alle privaten E-Mails:
                    • mickymM mickym
                              "type": "inject",
                              "name": "",
                              "props": [
                                      "p": "payload"
                                      "p": "topic",
                                      "vt": "str"
                              "repeat": "",
                              "crontab": "",
                              "once": false,
                              "onceDelay": 0.1,
                              "topic": "",
                              "x": 170,
                              "y": 180,
                              "wires": [
                                      "9478e068.1996f",
                                      "eba2bc65.7a84e"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 430,
                              "y": 80,
                              "wires": []
                              "type": "json",
                              "name": "",
                              "action": "",
                              "pretty": false,
                              "x": 370,
                              "y": 180,
                              "wires": [
                                      "56ecb3c4.3b043c",
                                      "3dffdc6c.fbe1f4",
                                      "19f597c9.9b6798",
                                      "c247ca8c.d769b8",
                                      "dbe07379.31f3e",
                                      "1c006873.31a2e8",
                                      "4f084632.928e88"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 820,
                              "y": 80,
                              "wires": []
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 790,
                              "y": 180,
                              "wires": [
                                      "269e90a7.c4aba"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1210,
                              "y": 80,
                              "wires": []
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 620,
                              "y": 340,
                              "wires": [
                                      "f8d70dc4.bcdc2"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 940,
                              "y": 340,
                              "wires": []
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 680,
                              "y": 440,
                              "wires": [
                                      "3f3e7fa7.d5fa9"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1090,
                              "y": 440,
                              "wires": []
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1090,
                              "y": 500,
                              "wires": []
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 680,
                              "y": 500,
                              "wires": [
                                      "90e7c28.3d7cd4"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1090,
                              "y": 560,
                              "wires": []
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 700,
                              "y": 560,
                              "wires": [
                                      "5f8e439c.1b10bc"
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 640,
                              "y": 640,
                              "wires": [
                                      "7d26ab46.cb6d24"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 910,
                              "y": 640,
                              "wires": []
                      stefan22
                      @mickym Moin. So ich bin auch wieder daheim angekommen , sorry das ich mich jetzt erst wieder melde aber bei 13 -14 Stunden am Tag war ich abends zu platt um den Lapi nochmal aufzumachen.
                      • S stefan22
                        stefan22
                        @stefan22 . So hier mal das fertige Ergebnis dank mickym.
                        • S stefan22
                          stefan22
                          @stefan22 Moin Mickym kurz Frage wie bekomm ich ne Max Speicherung über einen gewissen Zeitraum hin.
                          Sprich ich möchte die Aussentemperatur über 24 Stunden loggen und mit dem max Wert vom vorhergehenden Tag
                          meine Heizung am nächsten Tag schalten.
                          Gruss Stefan
                          • S stefan22
                            Gruss Stefan
                            mickymM Online
                            mickymM Online
                            mickym
                            @stefan22 Hallo stefan,
                            dafür gibt es fix und fertig den aggregator node - der schmeisst Dir dann aber frühestens nach Ablauf der Zeit (bzw. mit dem Haken am Tageswechsel einen Wert aus.
                            Die obige Node wird Dir also mit Einstellung 1 Tag erst ab Mitternacht einen Wert ausspuken - bzw. ohne den Haken (Submit incomplete interval on start) erst nach 24 Std.. ;)
                            Am Anfang hat der ja noch keinen Wert drin. Um das mit dem Haken besser verständlich zu machen - gibts in der Beschreibung zu dem Node die folgende Erklärung, wenn man das zum Beispiel auf 4 Stunden einstellt. Dann gibt die Node wohl nicht nach den vollen 4 Stunden mit dem Haken den Wert aus, sondern tageszeitabhängig. ;)
                            • Submit incomplete interval on start? option
                              The Aggregator node aggregates on a whole unit of time selected. For example, every 4 hours starting at 12:30:00 will aggregate at [16:00:00], 20:00:00, 00:00:00 etc. The first aggregation result at 16:00:00, containing the values over the first "incomplete" timespan of 3.5 hours (12:30 - 16:00), is only outputted if the "Submit incomplete interval on start?" option is selected. If the option is not selected, the first output would be at 20:00 with the values between 16:00 and 20:00.
                            • In practise this option should be deselected if you have to ensure that all aggregation results are based on an equal timespan. If this is not an issue or you explicitly want also the first values aggregated for your application, then this option should be selected.
                            Also die aggregator Node einfach hinter Deinen Sensor der Dir die Aussentemperatur auswirft und dann bekommst Du alle 24 Std. den max Wert geliefert. ;) Easy. :o
                            Ansonsten kann das auch mit einer Function node selbst etwas intranspartenter implementieren. Da bist Du noch flexibler kostet aber mehr Aufwand.
                            • S stefan22
                              @haselchen Nur ich habe kein iBroker laufen
                              mickymM Online
                              mickymM Online
                              mickym
                              Du hast ja anfangs geschrieben, dass Du kein iobroker laufen hast. Komisch ;) - dass Du hier trotzdem in dem Forum gelandet bist.
                              Einen großen Vorteil, den dieses System hat - auch wenn Du keine sonstigen Adapter verwendest, ist eben die Datenspeicherung und das man hier jederzeit den Status sehen kann.
                              Node-Red nutze ich vor allem als Logikmaschine (die meisten iobroker User - nutzen hier eher Blockly) und bei der Speicherung von Daten bleibt es Dir überlassen, ob Du hier auf Adapter zugreifst oder diese mit Node-Red selbst ermittelst (wie mit Deinem http - Node). ;)
                              • S stefan22
                                Gruss Stefan
                                mickymM Online
                                mickymM Online
                                mickym
                                @stefan22 Für die Initialisierung kannst Du aber auch eine normale Inject Node bei Start von Node-Red benutzen, bevor der aggregator Node einen Wert ausspukt.
                                • mickymM mickym
                                  stefan22
                                  @mickym Tja was soll ich sagen. Es gibt mittlerweile soviele Sachen von - bis. Im Endeffekt habe ich ein stabiles KNX System .
                                  Meine Server sind von Real KNX . Diese beinhalten eine einfach Visu für die iPhones .
                                  Wobei mir das aber auch so gefällt.
                                  Sicherlich könnte ich auch über Real KNX schöne Dashboards erstellen.
                                  Der Node - Red wird ausschliesslich als Logik Erweiterung bei Real KNX hergenommen.
                                  Mango ich kenne mich nicht mit Programmiersprachen aus.
                                  Sicherlich hab ich mal vor 15 Jahren mit Java rumgespielt, habe es aber nie gebraucht.
                                  Weshalb ich mich für Real KNX entschieden habe , ist das diese eine Offline Sprachsteuerung wo die Komponenten in eine 55 x 55
                                  Unterputzdose passen und die Daten nicht an einen Cloud geschickt werden.
                                  Somit entfällt bei mir Alexa und Co für die Sprachsteuerung.
                                  War purer Zufall das ich hier jemanden gefunden hat der es auf den Kasten hat und mir das so erklären kann damit ich es auch verstehe.
                                  Gruss
                                  • S stefan22
                                    Gruss
                                    mickymM Online
                                    mickymM Online
                                    mickym
                                    @stefan22 OK - dann dürfte Dir aber der Tipp mit der aggregator Node soweit erst mal hoffentlich weiter geholfen haben.
                                    S 2 Antworten Letzte Antwort
                                    • mickymM mickym
                                      stefan22
                                      @mickym Na das auf jedenfall. Wie gesagt wenn ich mal nen Anfang habe, dann komm ich schon irgendwie weiter. :) Dankeschön. Es gibt wenig deutsche Foren zwecks Node-Red.
                                      Kommt mir zumindest so vor.
                                      • mickymM mickym
                                        stefan22
                                        @mickym Soooo ich hätt da mal wieder ein kleines Problem Lach . Ich bekomme nen Werte String von meinen IPSteckdosen per UDP rein diesen möchte ich umändern. Damit ich meine 3 Steckdosen mit True und False auswerten kann.
                                        NET-PwrCtrl:ANEL.INTERN :192.168.2.16:255.255.255.0:192.168.2.1:0.4.163.18.8.89:Nr. 1,1:Nr. 2,1:Nr. 3,1:Nr. 4,0:Nr. 5,0:Nr. 6,0:Nr. 7,0:Nr. 8,0:248:80:NET-PWRCTRL_04.6:H:xor:
                                        So kommt der Code rein.
                                        Jetzt hab ich es per Change Node probiert Sprich Nr. 1,1 durch True zu ersetzen Nr.1,0 durch false . Hm leider klappt das nicht.
                                        mickymM 3 Antworten Letzte Antwort
                                        • S stefan22
                                          mickymM Online
                                          mickymM Online
                                          mickym
                                          @stefan22 Du musst doch den String erst mal aufteilen nach den Bedeutungen. - siehe Flow danach!
