  4. js-controller 3.1 jetzt im STABLE!
    6.8k
js-controller
100 Beiträge 38 Kommentatoren 33.7k Aufrufe 36 Beobachtet
    @Nies
    sudo chown -R 1001:1001 /home/iobroker/.npm
    Oder
    npm cache clean
    NiesN Offline
    NiesN Offline
    Nies
    #70
    @Thomas-Braun sagte in js-controller 3.1 jetzt im STABLE!:
    Danke für die Hilfe!
    Problem bleibt bestehen.
    pi@rpi4:/opt/iobroker $ iobroker stop
    pi@rpi4:~ $ npm cache clean --force
    pi@rpi4:/opt/iobroker $ sudo chown -R 1001:1001 /home/iobroker/.npm
    pi@rpi4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code EACCES
    npm ERR! syscall scandir
    npm ERR! path /home/iobroker/.npm/_logs
    npm ERR! errno -13
    npm ERR!
    npm ERR! Your cache folder contains root-owned files, due to a bug in
    npm ERR! previous versions of npm which has since been addressed.
    npm ERR!
    npm ERR! To permanently fix this problem, please run:
    npm ERR!   sudo chown -R 1001:1001 "/home/iobroker/.npm"
    glob error [Error: EACCES: permission denied, scandir '/home/iobroker/.npm/_logs'] {
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
      path: '/home/iobroker/.npm/_logs'
    npm ERR! syscall open
    npm ERR! path /home/iobroker/.npm/_cacache/index-v5/1d/a8/f99642a9eccb731a5f4be46c26b08f83c59d3cff19a70c94e745504ac47e
    npm ERR! errno -13
    npm ERR!
    npm ERR!
    • NiesN Nies
      npm ERR! errno -13
      npm ERR!
      npm ERR!
        errno: -13,
        code: 'EACCES',
        syscall: 'scandir',
      npm ERR! errno -13
      npm ERR!
      npm ERR!
      #71
      @Nies Malden iobroker Fixer versucht?
      NiesN 1 Antwort Letzte Antwort
      • apollon77A apollon77
        NiesN Offline
        NiesN Offline
        Nies
        #72
        @apollon77 Ja, der fixer lief schon mehrmalig durch. Keine Änderung.
        • NiesN Nies
          #73
          @Nies Mal /home/iobroker/.npm gelöscht?
            NiesN Offline
            NiesN Offline
            Nies
            #74
            @apollon77 auch kein Erfolg. Soll ich npm neu installieren? Wenn ja, welche Methode?
            pi@rpi4:~ $ sudo rm -R /home/iobroker/.npm
            npm WARN using --force I sure hope you know what you are doing.
            pi@rpi4:~ $ cd /opt/iobroker
            pi@rpi4:/opt/iobroker $ iobroker fix
            library: loaded
            Library version=2020-06-12
                Welcome to the ioBroker installation fixer!
                Script version: 2020-06-15
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 https://repos.influxdata.com/debian buster InRelease
            Ign:3 https://dl.bintray.com/fg2it/deb-rpi-1b buster InRelease
            Fehl:4 https://dl.bintray.com/fg2it/deb-rpi-1b buster Release
              404  Not Found [IP: 52.29.71.114 443]
            OK:5 https://deb.nodesource.com/node_10.x buster InRelease
            OK:6 https://deb.nodesource.com/node_12.x buster InRelease
            Holen:7 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            E: Das Depot »https://dl.bintray.com/fg2it/deb-rpi-1b buster Release« enthält keine Release-Datei.
            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/3)
                Checking autostart (3/3)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            npm ERR! errno -13
            npm ERR!
            npm ERR!
              errno: -13,
              code: 'EACCES',
              syscall: 'scandir',
            npm ERR! errno -13
            npm ERR!
            npm ERR!
            • NiesN Nies
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              npm ERR! errno -13
              npm ERR!
              npm ERR!
                errno: -13,
                code: 'EACCES',
                syscall: 'scandir',
              npm ERR! errno -13
              npm ERR!
              npm ERR!
              #75
              @Nies
              Hast du den Cache denn mal gelöscht?
              cd /opt/iobroker
                @Nies
                cd /opt/iobroker
                NiesN Offline
                NiesN Offline
                Nies
                #76
                @Thomas-Braun Ja, ich habe es doch immer gepostet, was ich versucht habe.
                D.h. vor 2 Std auf deinen Hinweis hin habe ich sudo chown -R 1001:1001 /home/iobroker/.npm und npm cache clean --force gemacht.
                Zuletzt habe ich auf @apollon77 Hinweis hin sudo rm -R /home/iobroker/.npm , dann npm cache clean --force , dann aus /opt/iobroker heraus iobroker fix und sudo -H -u iobroker npm install iobroker.js-controller gemacht.
                Die npm Berechtigungsfehler (Error: EACCES: permission denied, scandir '/home/iobroker/.npm/_logs') bleiben.
                Thomas BraunT AlCalzoneA 2 Antworten Letzte Antwort
                • NiesN Nies
                  #77
                  @Nies
                  sudo rm -rf /home/iobroker/.npm/_logs
                    @Nies
                    NiesN Offline
                    NiesN Offline
                    Nies
                    #78
                    @Thomas-Braun Ja, /home/iobroker/.npm habe ich gelöscht.
                    Warum bringt mir sudo -H -u iobroker npm install iobroker.js-controller trotz nicht existentem /home/iobroker/.npm den Fehler immernoch?
                    npm ERR! errno -13
                    npm ERR!
                    npm ERR!
                      errno: -13,
                      code: 'EACCES',
                      syscall: 'scandir',
                    npm ERR! errno -13
                    npm ERR!
                    npm ERR!
                    • NiesN Nies
                      npm ERR! errno -13
                      npm ERR!
                      npm ERR!
                        errno: -13,
                        code: 'EACCES',
                        syscall: 'scandir',
                      npm ERR! errno -13
                      npm ERR!
                      npm ERR!
                      #79
                      @Nies
                      ls -la /home/iobroker/.npm/
                      • NiesN Nies
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #80
                        @Thomas-Braun
                        @Nies sagte in js-controller 3.1 jetzt im STABLE!:
                        löscht den Cache des Users pi. Probier mal
                        sudo -H -u iobroker npm cache clean --force
                        • AlCalzoneA AlCalzone
                          @Thomas-Braun
                          #81
                          @AlCalzone Arrrgh, natürlich... Da hab ich aber megagepennt.
                          • AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            #82
                            Blöde Idee: Gehört /home/iobroker möglicherweise root?
                            @Nies
                              @Nies
                              NiesN Offline
                              NiesN Offline
                              Nies
                              #83
                              @AlCalzone @Thomas-Braun Nein, /home/iobroker gehört nicht root.
                              pi@rpi4:~ $ ls -la /home/iobroker
                              insgesamt 40
                              drwx------ 5 pi       pi       4096 Aug 23 22:57 .
                              drwxr-xr-x 4 root     root     4096 Jan 20  2020 ..
                              -rw-r--r-- 1 iobroker iobroker  220 Apr 18  2019 .bash_logout
                              -rw-r--r-- 1 iobroker iobroker 3523 Sep 26  2019 .bashrc
                              drwxr-xr-x 3 iobroker iobroker 4096 Jan 20  2020 .cache
                              drwx------ 3 iobroker iobroker 4096 Jan 20  2020 .config
                              -rwx------ 1 iobroker iobroker 5462 Apr  5 14:06 getParrot9333.pl
                              -rw-r--r-- 1 iobroker iobroker  807 Apr 18  2019 .profile
                              drwx------ 2 iobroker iobroker 4096 Feb  3  2020 .ssh
                              Entschuldigung für doofe Fragen. Ist es relevant, aus welchem Ordner ich npm cache clean ausführe? /home/iobroker oder /opt/iobroker oder root?
                              aus /home/iobroker:
                              pi@rpi4:/home/iobroker $ sudo -H -u iobroker npm cache clean --force
                              Error: EACCES: permission denied, scandir '/home/iobroker'
                              aus /opt/iobroker:
                              pi@rpi4:/opt/iobroker $ sudo -H -u iobroker npm cache clean --force
                              npm ERR! errno -13
                              npm ERR!
                              npm ERR!
                                errno: -13,
                                code: 'EACCES',
                                syscall: 'scandir',
                              npm ERR! syscall lstat
                              npm ERR! errno -13
                              npm ERR!
                              npm ERR!
                              aus root:
                              pi@rpi4:/ $ sudo -H -u iobroker npm cache clean --force
                              npm ERR! errno -13
                              npm ERR!
                              npm ERR!
                                errno: -13,
                                code: 'EACCES',
                                syscall: 'scandir',
                              npm ERR! errno -13
                              npm ERR!
                              npm ERR!
                                Kueppert
                                schrieb am zuletzt editiert von Kueppert
                                #84
                                kurze Frage/Hinweis: im Fehlertext steht das Verzeichnis in " ":
                                Wenn ich das richtig gelesen habe, wurde der Befehl aber ohne " " abgesetzt (bin auch kein Linux-Profi, ist mir nur beim Lesen ins Auge gesprungen?!)
                                VG Thorsten
                                • NiesN Nies
                                  insgesamt 40
                                  aus /home/iobroker:
                                  aus /opt/iobroker:
                                  npm ERR! errno -13
                                  npm ERR!
                                  npm ERR!
                                    errno: -13,
                                    code: 'EACCES',
                                    syscall: 'scandir',
                                  npm ERR! errno -13
                                  npm ERR!
                                  npm ERR!
                                  aus root:
                                  npm ERR! errno -13
                                  npm ERR!
                                  npm ERR!
                                    errno: -13,
                                    code: 'EACCES',
                                    syscall: 'scandir',
                                  npm ERR! errno -13
                                  npm ERR!
                                  npm ERR!
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #85
                                  An sich ist es egal, von wo du cache clean ausführst, es muss nur der richtige User sein.
                                  /home/iobroker/.npm existiert auch nicht mehr, d.h. löschen kannst du dir sparen.
                                  Aber auch nicht iobroker. Bei mir funktioniert es mit Owner iobroker und 755 (hoffe @Thomas-Braun bringt mich für diesen Vorschlag nicht um) - probiers mal so:
                                  sudo chown iobroker:iobroker /home/iobroker
                                  sudo chmod 755 /home/iobroker
                                  Danach sollte npm seine Verzeichnisse wieder selbst herstellen.
                                  • K Kueppert
                                    VG Thorsten
                                    NiesN Offline
                                    NiesN Offline
                                    Nies
                                    #86
                                    ES KLAPPT!
                                    @Kueppert Mit "" hatte ich auch probiert. Daran lag es nicht. Ich danke dir trotzdem für deinen Versuch.
                                    @AlCalzone Du hattest Recht. Mein home Verzeichnis war wohl doch im Besitz von root.
                                    Abhilfe brachte
                                    sudo chown -R -c iobroker:iobroker /home/iobroker
                                    Auf diesen Befehl hin kamen folgende 3 Zeilen: (nur noch sinngemäß, da ich zum testen das Update des js-controllers angestoßen habe und die 3 Zeilen oben aus dem Terminal rausgerutscht sind...)
                                    Der Benutzer von /home/iobroker/.ssh...blabla wurde von root:root zu iobroker:iobroker geändert.
                                    Der Benutzer von /home/iobroker wurde von pi:pi zu iobroker:iobroker geändert.
                                    js-controller konnte nun erfolgreich aktualisiert werden. Danke für euren super Support.
                                      NiesN Offline
                                      NiesN Offline
                                      Nies
                                      #87
                                      @AlCalzone Jepp, so hats geklappt. Danke dir!
                                        Kueppert
                                        #88
                                        Hallo in die Runde,
                                        mal was neues. Hab gerade das Update vom Controller auf v4.6.23 gemacht und folgenden Hinweis erhalten:
                                        javascript.0	2020-08-24 17:47:41.484	error	(16299) deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                        javascript.0	2020-08-24 17:47:41.480	error	(16299) WARN
                                        javascript.0	2020-08-24 17:47:41.477	error	(16299)
                                        javascript.0	2020-08-24 17:47:41.474	error	(16299) npm
                                        Ist das ne Info, die ich einfach ignorieren kann? Hab nur ich das beim Update?? Hab in der Suche nach diesem Hinweis/Fehler nicht hier im Forum gefunden bisher. Normalerweise werden Fehler dieser Art ja immer fix gemeldet...
                                        Danke und vG, Thorsten
                                        • K Kueppert
                                          Hallo in die Runde,
                                          crunchipC Offline
                                          crunchipC Offline
                                          #89
                                          @Kueppert sagte in js-controller 3.1 jetzt im STABLE!:
                                          nicht gaaaaaaanz richtig,
                                          hättest du ein controller update gemacht, wärst du zwar im richtigen Thread😊
                                          du hast aber Adapter Javascript ein Update verpasst, klitzekleiner Unterschied😜
                                          aber Spass beiseite, hatte heut auch endlich mal das Update angestoßen und kam auch die Meldung.
                                          apollon77A K 2 Antworten Letzte Antwort
