- ioBroker Community Home
- Deutsch
- Skripten / Logik
- Blockly
- [Gelöst] HUE Motion Sensor Lampe an/aus -> Problem Haustier
@Sanweb
Versuche es mal so:
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="#?8llkQ_(?e?!}{7|0%B">duschen</variable> <variable type="timeout" id="timeout">timeout</variable> </variables> <block type="on_ext" id="JT^Sb~%?woKrqm#,_x?/" x="780" y="-2572"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="g+hFwJ/p}d6]YQ~EspD*"> <field name="oid">default</field> </shadow> <block type="text" id="K:Nj#+xP3L91=WcyB3vk"> <field name="TEXT">deconz.0.Sensors.15.buttonevent</field> </block> </value> <statement name="STATEMENT"> <block type="controls_if" id="5t#hR+Cr;XhCLt708]?;"> <value name="IF0"> <block type="logic_compare" id="*0/lSkBjPe!Q0-7A]`}t"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="p;(Kh@GTK/#PhbUs|2Fk"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="math_number" id="L}L-PyHNK43~ZBR#G]Yv"> <field name="NUM">1002</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="jv6hg}OB#s?,w0H*NI_d"> <field name="NAME">timeout</field> <next> <block type="variables_set" id="IQn)a22MZbX!@$BeNSbo"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id=",=d^~(K|T,0?]S978@zB"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> <next> <block type="comment" id="j^MxUgu8?7{mlu]rA:Tf"> <field name="COMMENT">Bewegung</field> <next> <block type="on_ext" id="Vo2d_MmTq==sR.4ZWR$O"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="Czsj]a1TUk|+~h~ORP[b"> <field name="oid">deconz.0.Sensors.2.presence</field> </shadow> </value> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id=".AnY7,uE8z6%68I_9r!J"> <field name="NAME">timeout</field> <next> <block type="controls_if" id="+RZ{~*8u`F-{891w*mat"> <value name="IF0"> <block type="logic_operation" id="WMPSk~z%).|`E/DHlrcn" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="C4LtUkpka$={[9/VCOva"> <value name="BOOL"> <block type="on_source" id="+d+_sgAE*[8U#u/8-`=!"> <field name="ATTR">state.val</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="W1{FG$?i1lP8NHMpEzzu"> <value name="BOOL"> <block type="variables_get" id="B^v6/7~q9mb|4}(2Qk$c"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_settimeout" id="b8c{g!jXe$]dFOh^QXP["> <field name="NAME">timeout</field> <field name="DELAY">30</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="comment" id="vvNPR8V{Zt(;|2~TmxfO"> <field name="COMMENT">Licht ein?</field> <next> <block type="controls_if" id="ub/zHL/V?|rXYe|9Al6y"> <value name="IF0"> <block type="get_value" id="FrcZZNPN%#R(^G6NN|LM"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> <statement name="DO0"> <block type="control" id="$86HuP~`N{LaY4I7md,3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="1UP*Me:;gW3cC?+vbh94"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="comment" id="#NX^q_VjK@F9iUWAWPA}"> <field name="COMMENT">Tür öffnet</field> <next> <block type="on_ext" id="/V]t?I@Gjkc^eMR_n#)|"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">gt</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="z.rf;Ppk-,EU=pVr7wQN"> <field name="oid">deconz.0.Sensors.5.open</field> </shadow> </value> <statement name="STATEMENT"> <block type="comment" id="S+(!XQne8~@_%_R_(8!Q"> <field name="COMMENT">dunkel und Licht aus?</field> <next> <block type="controls_if" id="!muI`Yamueo@M|l(k(*v"> <value name="IF0"> <block type="logic_operation" id="F[YWS@t_RdTz=1pg)U=J" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="iUk6};go{0_ftNa[9VUb"> <value name="BOOL"> <block type="get_value" id="2NG.@e5:!/WW%;U$]|v`"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.1.daylight</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="QzU)|^M:2SQsEF%CPjDi"> <value name="BOOL"> <block type="get_value" id="+gD/U?X!ZU|7OJiYPclr"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=":TjQf-tu@Q#kgie^P)@o"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*ClGOYPry2taM^E+%*n#"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <next> <block type="variables_set" id="Yv+SY!mIdF7[u6`DuzRn"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id="7{xAyMA5Inv$Sj56J$Xs"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </xml>@paul53
Passt meins nicht? 🤔😔 -
@padrino sagte:
Passt meins nicht?
Wenn das stimmt ?
@padrino sagte in [Gelöst] HUE Motion Sensor Lampe an/aus -> Problem Haustier:
Wenn Du drückst und der Wert war "1002" ist er danach immer noch "1002" - wenn auch "aktualisiert".
, dann nicht.
Produktiv: Asus PN 42 / N100 / 8 GB / 500 GB; Proxmox mit 2 VM (iob / openCCU) -
@padrino sagte:
Passt meins nicht?
Wenn das stimmt ?
, dann nicht.
Ich war doch schon weiter. ;)
Aber es interessiert mich, lerne gerne (aus Fehlern).
Beide Scripte funktionieren leider nicht. Ich habe beide Scripte erstellt und als erstes erst einmal getestet, wenn ich die Tür auf und zu mache, ob das Licht an geht und sich nach dem Timeout wieder ausschaltet. Ergebnis war: Tür ging auf und zu, Licht ging an und nicht wieder aus ... Der Datenpunkt von "Buttonevent" stand vor öffnen der Tür auf 1002, auch wenn ich ihn händisch mal auf 0 setze, ist das Ergebnis gleich, das Licht geht nicht wieder aus bei Tür auf und zu machen ohne Nutzung des Buttons.
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="#?8llkQ_(?e?!}{7|0%B">duschen</variable> <variable type="timeout" id="timeout">timeout</variable> </variables> <block type="comment" id="^H8S@6|A=FINJo802%?S" x="788" y="-2612"> <field name="COMMENT">Button</field> <next> <block type="on_ext" id="JT^Sb~%?woKrqm#,_x?/"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="g+hFwJ/p}d6]YQ~EspD*"> <field name="oid">deconz.0.Sensors.15.buttonevent</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="5t#hR+Cr;XhCLt708]?;"> <value name="IF0"> <block type="logic_compare" id="*0/lSkBjPe!Q0-7A]`}t"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="p;(Kh@GTK/#PhbUs|2Fk"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="math_number" id="L}L-PyHNK43~ZBR#G]Yv"> <field name="NUM">1002</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="jv6hg}OB#s?,w0H*NI_d"> <field name="NAME">timeout</field> <next> <block type="variables_set" id="IQn)a22MZbX!@$BeNSbo"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id=",=d^~(K|T,0?]S978@zB"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> <next> <block type="comment" id="j^MxUgu8?7{mlu]rA:Tf"> <field name="COMMENT">Bewegung</field> <next> <block type="on_ext" id="Vo2d_MmTq==sR.4ZWR$O"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="Czsj]a1TUk|+~h~ORP[b"> <field name="oid">deconz.0.Sensors.2.presence</field> </shadow> </value> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id=".AnY7,uE8z6%68I_9r!J"> <field name="NAME">timeout</field> <next> <block type="controls_if" id="+RZ{~*8u`F-{891w*mat"> <value name="IF0"> <block type="logic_operation" id="WMPSk~z%).|`E/DHlrcn" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="C4LtUkpka$={[9/VCOva"> <value name="BOOL"> <block type="on_source" id="+d+_sgAE*[8U#u/8-`=!"> <field name="ATTR">state.val</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="W1{FG$?i1lP8NHMpEzzu"> <value name="BOOL"> <block type="variables_get" id="B^v6/7~q9mb|4}(2Qk$c"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_settimeout" id="b8c{g!jXe$]dFOh^QXP["> <field name="NAME">timeout</field> <field name="DELAY">30</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="comment" id="vvNPR8V{Zt(;|2~TmxfO"> <field name="COMMENT">Licht ein?</field> <next> <block type="controls_if" id="ub/zHL/V?|rXYe|9Al6y"> <value name="IF0"> <block type="get_value" id="FrcZZNPN%#R(^G6NN|LM"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> <statement name="DO0"> <block type="control" id="$86HuP~`N{LaY4I7md,3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="1UP*Me:;gW3cC?+vbh94"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="comment" id="#NX^q_VjK@F9iUWAWPA}"> <field name="COMMENT">Tür öffnet</field> <next> <block type="on_ext" id="/V]t?I@Gjkc^eMR_n#)|"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">gt</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="z.rf;Ppk-,EU=pVr7wQN"> <field name="oid">deconz.0.Sensors.5.open</field> </shadow> </value> <statement name="STATEMENT"> <block type="comment" id="S+(!XQne8~@_%_R_(8!Q"> <field name="COMMENT">dunkel und Licht aus?</field> <next> <block type="controls_if" id="!muI`Yamueo@M|l(k(*v"> <value name="IF0"> <block type="logic_operation" id="F[YWS@t_RdTz=1pg)U=J" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="iUk6};go{0_ftNa[9VUb"> <value name="BOOL"> <block type="get_value" id="2NG.@e5:!/WW%;U$]|v`"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.1.daylight</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="QzU)|^M:2SQsEF%CPjDi"> <value name="BOOL"> <block type="get_value" id="+gD/U?X!ZU|7OJiYPclr"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=":TjQf-tu@Q#kgie^P)@o"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*ClGOYPry2taM^E+%*n#"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <next> <block type="variables_set" id="Yv+SY!mIdF7[u6`DuzRn"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id="7{xAyMA5Inv$Sj56J$Xs"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </xml> -
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="#?8llkQ_(?e?!}{7|0%B">duschen</variable> <variable type="timeout" id="timeout">timeout</variable> </variables> <block type="comment" id="^H8S@6|A=FINJo802%?S" x="788" y="-2612"> <field name="COMMENT">Button</field> <next> <block type="on_ext" id="JT^Sb~%?woKrqm#,_x?/"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="g+hFwJ/p}d6]YQ~EspD*"> <field name="oid">deconz.0.Sensors.15.buttonevent</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="5t#hR+Cr;XhCLt708]?;"> <value name="IF0"> <block type="logic_compare" id="*0/lSkBjPe!Q0-7A]`}t"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="p;(Kh@GTK/#PhbUs|2Fk"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="math_number" id="L}L-PyHNK43~ZBR#G]Yv"> <field name="NUM">1002</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="jv6hg}OB#s?,w0H*NI_d"> <field name="NAME">timeout</field> <next> <block type="variables_set" id="IQn)a22MZbX!@$BeNSbo"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id=",=d^~(K|T,0?]S978@zB"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> <next> <block type="comment" id="j^MxUgu8?7{mlu]rA:Tf"> <field name="COMMENT">Bewegung</field> <next> <block type="on_ext" id="Vo2d_MmTq==sR.4ZWR$O"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="Czsj]a1TUk|+~h~ORP[b"> <field name="oid">deconz.0.Sensors.2.presence</field> </shadow> </value> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id=".AnY7,uE8z6%68I_9r!J"> <field name="NAME">timeout</field> <next> <block type="controls_if" id="+RZ{~*8u`F-{891w*mat"> <value name="IF0"> <block type="logic_operation" id="WMPSk~z%).|`E/DHlrcn" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="C4LtUkpka$={[9/VCOva"> <value name="BOOL"> <block type="on_source" id="+d+_sgAE*[8U#u/8-`=!"> <field name="ATTR">state.val</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="W1{FG$?i1lP8NHMpEzzu"> <value name="BOOL"> <block type="variables_get" id="B^v6/7~q9mb|4}(2Qk$c"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_settimeout" id="b8c{g!jXe$]dFOh^QXP["> <field name="NAME">timeout</field> <field name="DELAY">30</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="comment" id="vvNPR8V{Zt(;|2~TmxfO"> <field name="COMMENT">Licht ein?</field> <next> <block type="controls_if" id="ub/zHL/V?|rXYe|9Al6y"> <value name="IF0"> <block type="get_value" id="FrcZZNPN%#R(^G6NN|LM"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> <statement name="DO0"> <block type="control" id="$86HuP~`N{LaY4I7md,3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="1UP*Me:;gW3cC?+vbh94"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="comment" id="#NX^q_VjK@F9iUWAWPA}"> <field name="COMMENT">Tür öffnet</field> <next> <block type="on_ext" id="/V]t?I@Gjkc^eMR_n#)|"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">gt</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="z.rf;Ppk-,EU=pVr7wQN"> <field name="oid">deconz.0.Sensors.5.open</field> </shadow> </value> <statement name="STATEMENT"> <block type="comment" id="S+(!XQne8~@_%_R_(8!Q"> <field name="COMMENT">dunkel und Licht aus?</field> <next> <block type="controls_if" id="!muI`Yamueo@M|l(k(*v"> <value name="IF0"> <block type="logic_operation" id="F[YWS@t_RdTz=1pg)U=J" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="iUk6};go{0_ftNa[9VUb"> <value name="BOOL"> <block type="get_value" id="2NG.@e5:!/WW%;U$]|v`"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.1.daylight</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="QzU)|^M:2SQsEF%CPjDi"> <value name="BOOL"> <block type="get_value" id="+gD/U?X!ZU|7OJiYPclr"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=":TjQf-tu@Q#kgie^P)@o"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*ClGOYPry2taM^E+%*n#"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <next> <block type="variables_set" id="Yv+SY!mIdF7[u6`DuzRn"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id="7{xAyMA5Inv$Sj56J$Xs"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </xml>@Sanweb sagte:
Dann logge mal das Verhalten von "buttonevent" mit einem Debug output Wert vor der Abfrage auf Wert == 1002.
@padrino
Hab es eben einmal ausprobiert und das Script soweit geändert, das ich die Variable nun weg gelassen habe und nun direkt mit dem Wert vergleiche.Der Datenpunkt "buttonpressed" steht stets IMMER auf 0, sofern KEINE Aktion mit dem Button erfolgt. Erst wenn der Button z.B. kurz gedrückt wird, springt er von "0" auf "1002" und dann wieder automatisch zurück auf "0". Also "1002" wird von Beginn bis Ende des "Drückvorganges" gesetzt, wird zu lange gedrückt, erscheint der Wert "1003".
Bei diesem Verhalten musste ich davon ausgehen, das sich der Wert "wird ändert" von Objekt ID "Sensor 15 buttonpressed" so korrekt erst einmal ist.
@Sanweb sagte:
Das widerspricht der Aussage:
@Sanweb sagte in [Gelöst] HUE Motion Sensor Lampe an/aus -> Problem Haustier:Der Datenpunkt von "Buttonevent" stand vor öffnen der Tür auf 1002,
Ich habe irgendwo gelesen, dass 1002 "loslassen" und 1000 "drücken" entspricht. Dann müsste mit 1000 verglichen werden.
EDIT: Kann man nicht Release after press verwenden ?
@Sanweb sagte:
es Widerspricht nicht meiner Aussage, da ich in meinem Beitrag z.B. vom 18.08. z.B. den Datenpunkt "sensor 15 buttonpressed" zuerst benutzt hatte, welcher nicht stehen blieb und beim drücken den Wert "1002" gab und beim los lassen den Wert "0" widergab. Da ich mit diesem "gespringe" nicht zurecht kam, schrieb ich am 20.08., das ich auf den manipulierbaren Datenpunkt "Sensor 15 buttonevent" gewechselt bin. Diesen Datenpunkt hast Du auch in Deinem Scriptvorschlag ja auch benutzt.Habe eben einmal das Script auf den alten Datenpunkt "Sensor 15 buttonpressed" abgeändert und neu gestestet. Den Datenpunkt " ... release_press" wäre sicherlich auch verwendbar, der wird aber so schnell von iobroker aktuallisiert, das ich auf Anhie nicht sagen könnte, ob er überhaupt auf "true" gestanden hat ....
Müsste ich dennoch jetzt vergleichen, ob "1002" oder "0" steht, da nun "Objekt wurde aktuallisiert" benutzt wird? DA es funktioniert, wohl offenbar nicht ...
Funktioniert jetzt tadellos wie es soll. Vielen Dank für deine/eure Hilfe.
Lieber Paul, bei Dir bin ich mittlerweile sehr erstaunt, wie Du Dir "mal eben so" die ganzen Scripte anscheinend regelrecht aus dem "Ärmel schüttelst" ...
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="#?8llkQ_(?e?!}{7|0%B">duschen</variable> <variable type="timeout" id="timeout">timeout</variable> </variables> <block type="comment" id="^H8S@6|A=FINJo802%?S" x="788" y="-2612"> <field name="COMMENT">Button</field> <next> <block type="on_ext" id="JT^Sb~%?woKrqm#,_x?/"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="g+hFwJ/p}d6]YQ~EspD*"> <field name="oid">deconz.0.Sensors.15.buttonpressed</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="5t#hR+Cr;XhCLt708]?;"> <value name="IF0"> <block type="logic_compare" id="*0/lSkBjPe!Q0-7A]`}t"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="p;(Kh@GTK/#PhbUs|2Fk"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="math_number" id="L}L-PyHNK43~ZBR#G]Yv"> <field name="NUM">1002</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="jv6hg}OB#s?,w0H*NI_d"> <field name="NAME">timeout</field> <next> <block type="variables_set" id="IQn)a22MZbX!@$BeNSbo"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id=",=d^~(K|T,0?]S978@zB"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> </block> </statement> <next> <block type="comment" id="j^MxUgu8?7{mlu]rA:Tf"> <field name="COMMENT">Bewegung</field> <next> <block type="on_ext" id="Vo2d_MmTq==sR.4ZWR$O"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="Czsj]a1TUk|+~h~ORP[b"> <field name="oid">deconz.0.Sensors.2.presence</field> </shadow> </value> <statement name="STATEMENT"> <block type="timeouts_cleartimeout" id=".AnY7,uE8z6%68I_9r!J"> <field name="NAME">timeout</field> <next> <block type="controls_if" id="+RZ{~*8u`F-{891w*mat"> <value name="IF0"> <block type="logic_operation" id="WMPSk~z%).|`E/DHlrcn" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="C4LtUkpka$={[9/VCOva"> <value name="BOOL"> <block type="on_source" id="+d+_sgAE*[8U#u/8-`=!"> <field name="ATTR">state.val</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="W1{FG$?i1lP8NHMpEzzu"> <value name="BOOL"> <block type="variables_get" id="B^v6/7~q9mb|4}(2Qk$c"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_settimeout" id="b8c{g!jXe$]dFOh^QXP["> <field name="NAME">timeout</field> <field name="DELAY">30</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="comment" id="vvNPR8V{Zt(;|2~TmxfO"> <field name="COMMENT">Licht ein?</field> <next> <block type="controls_if" id="ub/zHL/V?|rXYe|9Al6y"> <value name="IF0"> <block type="get_value" id="FrcZZNPN%#R(^G6NN|LM"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> <statement name="DO0"> <block type="control" id="$86HuP~`N{LaY4I7md,3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="1UP*Me:;gW3cC?+vbh94"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </statement> <next> <block type="comment" id="#NX^q_VjK@F9iUWAWPA}"> <field name="COMMENT">Tür öffnet</field> <next> <block type="on_ext" id="/V]t?I@Gjkc^eMR_n#)|"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">gt</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="z.rf;Ppk-,EU=pVr7wQN"> <field name="oid">deconz.0.Sensors.5.open</field> </shadow> </value> <statement name="STATEMENT"> <block type="comment" id="S+(!XQne8~@_%_R_(8!Q"> <field name="COMMENT">dunkel und Licht aus?</field> <next> <block type="controls_if" id="!muI`Yamueo@M|l(k(*v"> <value name="IF0"> <block type="logic_operation" id="F[YWS@t_RdTz=1pg)U=J" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_negate" id="iUk6};go{0_ftNa[9VUb"> <value name="BOOL"> <block type="get_value" id="2NG.@e5:!/WW%;U$]|v`"> <field name="ATTR">val</field> <field name="OID">deconz.0.Sensors.1.dark</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="QzU)|^M:2SQsEF%CPjDi"> <value name="BOOL"> <block type="get_value" id="+gD/U?X!ZU|7OJiYPclr"> <field name="ATTR">val</field> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=":TjQf-tu@Q#kgie^P)@o"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.Badezimmerlicht.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="*ClGOYPry2taM^E+%*n#"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <next> <block type="variables_set" id="Yv+SY!mIdF7[u6`DuzRn"> <field name="VAR" id="#?8llkQ_(?e?!}{7|0%B">duschen</field> <value name="VALUE"> <block type="logic_boolean" id="7{xAyMA5Inv$Sj56J$Xs"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </xml>Muss da dennoch der vergleich auf "0" mit rein? Also mit "sonst setzte duschen auf falsch"?
@Sanweb sagte:
Nein, "setze duschen auf falsch" darf nur beim Tür öffnen erfolgen.
@Sanweb
Könntest Du mein Skript mal mit dem richtigen Datenpunkt testen, da mich interessiert, ob es läuft. =)
Finde auch das von Paul sind nicht soviel anders aus. ;) -
@Sanweb
Finde auch das von Paul sind nicht soviel anders aus. ;)@padrino sagte:
@Sanweb Könntest Du mein Skript mal mit dem richtigen Datenpunkt testen, da mich interessiert, ob es läuft.
Mit dem richtigen Datenpunkt "buttonpressed" wird es funktionieren. "stop timeout" im mache-Zweig ist unnötig, da es bei jedem Trigger erfolgt.
