  4. Adapter: ebus
    6.6k
Adapter: ebus
ebus adapter
712 Beiträge 73 Kommentatoren 331.3k Aufrufe 60 Beobachtet
  • J Jui
    @Rene_HM
    Hallo Rene,
    Habe Schwierigkeiten mit der ebus Version 2.0.0
    Es werden in Objekte keine Werte mehr angezeigt, nach der NEU Installation des Adapter 2.0.0 gar nichts mehr.
    Hier der Auszug aus der LOG Datei des ioBroker.
    host.raspberrypi	2020-06-15 19:35:03.583	info	instance system.adapter.ebus.0 terminated with code 0 (NO_ERROR)
    ebus.0	2020-06-15 19:35:03.071	info	(18102) Terminated (NO_ERROR): Without reason
    ebus.0	2020-06-15 19:35:03.069	info	(18102) all history done (exit)
    ebus.0	2020-06-15 19:35:03.068	debug	(18102) delete
    ebus.0	2020-06-15 19:35:03.066	debug	(18102) delete
    sql.0	2020-06-15 19:35:02.972	info	(18899) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value
    ebus.0	2020-06-15 19:35:02.925	info	(18102) all http done
    ebus.0	2020-06-15 19:35:02.778	debug	(18102) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":fals
    ebus.0	2020-06-15 19:35:02.716	debug	(18102) request data from http://192.168.178.47:8890/data
    ebus.0	2020-06-15 19:35:02.713	debug	(18102) all telnet done
    ebus.0	2020-06-15 19:35:02.711	debug	(18102) received 33.31;ok for Ntc1Sensor
    ebus.0	2020-06-15 19:35:02.559	debug	(18102) received 23.4375 for DisplayedOutsideTemp
    ebus.0	2020-06-15 19:35:01.530	debug	(18102) telnet connected
    ebus.0	2020-06-15 19:35:01.509	debug	(18102) connect telnet to IP 192.168.178.47 port 8888
    ebus.0	2020-06-15 19:35:01.508	debug	(18102) to poll ctr 2 vals: DisplayedOutsideTemp,Ntc1Sensor org DisplayedOutsideTemp,Ntc1Sensor org length 31
    ebus.0	2020-06-15 19:35:01.478	debug	(18102) init common variables
    ebus.0	2020-06-15 19:35:01.473	debug	(18102) init variables
    ebus.0	2020-06-15 19:35:01.473	debug	(18102) start with interface ebusd
    ebus.0	2020-06-15 19:35:01.472	debug	(18102) set timeout to 60 sec
    ebus.0	2020-06-15 19:35:01.444	info	(18102) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4
    host.raspberrypi	2020-06-15 19:35:00.015	info	instance system.adapter.ebus.0 started with pid 18102
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #229
    @Jui sagte in Adapter: ebus:
    Das log hier sieht nicht schlecht aus, aus meiner Sicht macht der Adapter was er soll... kannst du mal alle Objekte von ebus.0 löschen und dann beobachten, welche Objekte der Adapter wieder anlegt? bitte davon mal einen screenshoot posten....
    • Rene_HMR Rene_HM
      Jui
      #230
      @Rene_HM
      Danke für Deine Antwort und Hilfe!
      Habe die Objekte gelöscht, danach kam das im log:
      host.raspberrypi	2020-06-16 17:15:02.476	info	instance system.adapter.ebus.0 terminated with code 0 (NO_ERROR)
      sql.0	2020-06-16 17:15:02.239	info	(16559) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value
      ebus.0	2020-06-16 17:15:02.016	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.016	warn	(8746) Object ebus.0.global.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.015	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.014	warn	(8746) Object ebus.0.global.messages is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.013	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.013	warn	(8746) Object ebus.0.global.masters is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.012	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.011	warn	(8746) Object ebus.0.global.reconnects is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.011	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.010	warn	(8746) Object ebus.0.global.qq is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.009	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.009	warn	(8746) Object ebus.0.global.maxsymbollatency is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.008	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.007	warn	(8746) Object ebus.0.global.minsymbollatency is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.006	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.006	warn	(8746) Object ebus.0.global.maxarbitrationmicros is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.005	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.004	warn	(8746) Object ebus.0.global.minarbitrationmicros is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.003	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.003	warn	(8746) Object ebus.0.global.maxsymbolrate is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:02.002	warn	(8746) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:15:02.001	warn	(8746) Object ebus.0.global.symbolrate is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:15:01.952	info	(8746) Terminated (NO_ERROR): Without reason
      ebus.0	2020-06-16 17:15:01.950	info	(8746) all history done (exit)
      ebus.0	2020-06-16 17:15:01.949	debug	(8746) delete
      ebus.0	2020-06-16 17:15:01.947	debug	(8746) delete
      ebus.0	2020-06-16 17:15:01.903	info	(8746) all http done
      ebus.0	2020-06-16 17:15:01.734	debug	(8746) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":false
      ebus.0	2020-06-16 17:15:01.703	debug	(8746) request data from http://192.168.178.47:8890/data
      ebus.0	2020-06-16 17:15:01.701	debug	(8746) all telnet done
      ebus.0	2020-06-16 17:15:01.700	debug	(8746) received 38.94;ok for Ntc1Sensor
      ebus.0	2020-06-16 17:15:01.534	debug	(8746) received 24.25 for DisplayedOutsideTemp
      ebus.0	2020-06-16 17:15:01.342	debug	(8746) telnet connected
      ebus.0	2020-06-16 17:15:01.323	debug	(8746) connect telnet to IP 192.168.178.47 port 8888
      ebus.0	2020-06-16 17:15:01.322	debug	(8746) to poll ctr 2 vals: DisplayedOutsideTemp,Ntc1Sensor org DisplayedOutsideTemp,Ntc1Sensor org length 31
      ebus.0	2020-06-16 17:15:01.294	debug	(8746) init common variables
      ebus.0	2020-06-16 17:15:01.290	debug	(8746) init variables
      ebus.0	2020-06-16 17:15:01.289	debug	(8746) start with interface ebusd
      ebus.0	2020-06-16 17:15:01.289	debug	(8746) set timeout to 60 sec
      ebus.0	2020-06-16 17:15:01.263	info	(8746) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4
      host.raspberrypi	2020-06-16 17:15:00.016	info	instance system.adapter.ebus.0 started with pid 8746
      fritzdect.0	2020-06-16 17:14:06.644	info	(15925) Comet ID: 133560913928 identified for command (mode) : 1
      fritzdect.0	2020-06-16 17:14:06.636	info	(15925) Comet ID: 133560851704 identified for command (mode) : 0
      sql.0	2020-06-16 17:10:03.434	info	(16559) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value
      host.raspberrypi	2020-06-16 17:10:03.364	info	instance system.adapter.ebus.0 terminated with code 0 (NO_ERROR)
      sql.0	2020-06-16 17:10:03.155	info	(16559) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value
      ebus.0	2020-06-16 17:10:02.972	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.971	warn	(7557) Object ebus.0.global.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.971	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.970	warn	(7557) Object ebus.0.global.messages is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.969	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.968	warn	(7557) Object ebus.0.global.masters is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.967	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.966	warn	(7557) Object ebus.0.global.reconnects is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.965	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.964	warn	(7557) Object ebus.0.global.qq is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.964	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.963	warn	(7557) Object ebus.0.global.maxsymbollatency is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.962	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.962	warn	(7557) Object ebus.0.global.minsymbollatency is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.961	warn	(7557) Object ebus.0.global.maxarbitrationmicros is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.960	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.959	warn	(7557) Object ebus.0.global.minarbitrationmicros is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.958	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.958	warn	(7557) Object ebus.0.global.maxsymbolrate is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.956	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.956	warn	(7557) Object ebus.0.global.symbolrate is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.742	info	(7557) Terminated (NO_ERROR): Without reason
      ebus.0	2020-06-16 17:10:02.740	info	(7557) all history done (exit)
      ebus.0	2020-06-16 17:10:02.739	debug	(7557) delete
      ebus.0	2020-06-16 17:10:02.735	debug	(7557) delete
      ebus.0	2020-06-16 17:10:02.652	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.652	warn	(7557) Object ebus.0.global.signal is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.650	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.650	warn	(7557) Object ebus.0.global.updatecheck is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.649	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.648	warn	(7557) Object ebus.0.global.version is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.642	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.641	warn	(7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.sensor.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.641	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.640	warn	(7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.sensor.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.639	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.639	warn	(7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.temp.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.638	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.638	warn	(7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.temp.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.637	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.636	warn	(7557) Object ebus.0.vms.messages.Ntc1Sensor.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.636	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.635	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.suffix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.635	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.634	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.suffix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.633	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.633	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.counter.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.632	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.632	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.counter.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.631	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.631	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.supplier.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.630	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.630	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.supplier.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.629	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.629	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.product.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.628	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.627	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.product.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.627	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.626	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.week.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.626	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.625	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.week.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.624	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.624	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.year.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.623	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.623	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.year.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.622	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.622	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.prefix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.621	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.620	warn	(7557) Object ebus.0.scan.ed.messages.id.fields.prefix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.620	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.619	warn	(7557) Object ebus.0.scan.ed.messages.id.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.619	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.618	warn	(7557) Object ebus.0.scan.ed.messages..fields.HW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.617	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.617	warn	(7557) Object ebus.0.scan.ed.messages..fields.HW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.616	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.616	warn	(7557) Object ebus.0.scan.ed.messages..fields.SW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.615	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.615	warn	(7557) Object ebus.0.scan.ed.messages..fields.SW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.614	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.613	warn	(7557) Object ebus.0.scan.ed.messages..fields.ID.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.613	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.612	warn	(7557) Object ebus.0.scan.ed.messages..fields.ID.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.612	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.611	warn	(7557) Object ebus.0.scan.ed.messages..fields.MF.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.610	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.610	warn	(7557) Object ebus.0.scan.ed.messages..fields.MF.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.609	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.609	warn	(7557) Object ebus.0.scan.ed.messages..lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.608	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.608	warn	(7557) Object ebus.0.scan.15.messages.id.fields.suffix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.607	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.606	warn	(7557) Object ebus.0.scan.15.messages.id.fields.suffix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.605	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.605	warn	(7557) Object ebus.0.scan.15.messages.id.fields.counter.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.604	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.604	warn	(7557) Object ebus.0.scan.15.messages.id.fields.counter.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.603	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.603	warn	(7557) Object ebus.0.scan.15.messages.id.fields.supplier.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.602	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.602	warn	(7557) Object ebus.0.scan.15.messages.id.fields.supplier.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.601	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.600	warn	(7557) Object ebus.0.scan.15.messages.id.fields.product.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.600	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.599	warn	(7557) Object ebus.0.scan.15.messages.id.fields.product.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.599	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.598	warn	(7557) Object ebus.0.scan.15.messages.id.fields.week.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.597	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.597	warn	(7557) Object ebus.0.scan.15.messages.id.fields.week.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.596	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.596	warn	(7557) Object ebus.0.scan.15.messages.id.fields.year.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.595	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.595	warn	(7557) Object ebus.0.scan.15.messages.id.fields.year.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.594	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.593	warn	(7557) Object ebus.0.scan.15.messages.id.fields.prefix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.593	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.592	warn	(7557) Object ebus.0.scan.15.messages.id.fields.prefix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.592	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.591	warn	(7557) Object ebus.0.scan.15.messages.id.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.590	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.590	warn	(7557) Object ebus.0.scan.15.messages..fields.HW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.589	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.589	warn	(7557) Object ebus.0.scan.15.messages..fields.HW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.588	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.588	warn	(7557) Object ebus.0.scan.15.messages..fields.SW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.587	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.586	warn	(7557) Object ebus.0.scan.15.messages..fields.SW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.586	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.585	warn	(7557) Object ebus.0.scan.15.messages..fields.ID.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.585	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.584	warn	(7557) Object ebus.0.scan.15.messages..fields.ID.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.583	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.583	warn	(7557) Object ebus.0.scan.15.messages..fields.MF.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.582	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.582	warn	(7557) Object ebus.0.scan.15.messages..fields.MF.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.581	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.581	warn	(7557) Object ebus.0.scan.15.messages..lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.580	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.579	warn	(7557) Object ebus.0.scan.08.messages.id.fields.suffix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.579	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.578	warn	(7557) Object ebus.0.scan.08.messages.id.fields.suffix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.578	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.577	warn	(7557) Object ebus.0.scan.08.messages.id.fields.counter.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.576	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.576	warn	(7557) Object ebus.0.scan.08.messages.id.fields.counter.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.575	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.575	warn	(7557) Object ebus.0.scan.08.messages.id.fields.supplier.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.574	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.574	warn	(7557) Object ebus.0.scan.08.messages.id.fields.supplier.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.573	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.572	warn	(7557) Object ebus.0.scan.08.messages.id.fields.product.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.572	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.571	warn	(7557) Object ebus.0.scan.08.messages.id.fields.product.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.571	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.570	warn	(7557) Object ebus.0.scan.08.messages.id.fields.week.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.569	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.569	warn	(7557) Object ebus.0.scan.08.messages.id.fields.week.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.568	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.568	warn	(7557) Object ebus.0.scan.08.messages.id.fields.year.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.567	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.566	warn	(7557) Object ebus.0.scan.08.messages.id.fields.year.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.566	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.565	warn	(7557) Object ebus.0.scan.08.messages.id.fields.prefix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.565	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.564	warn	(7557) Object ebus.0.scan.08.messages.id.fields.prefix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.563	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.563	warn	(7557) Object ebus.0.scan.08.messages.id.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.562	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.562	warn	(7557) Object ebus.0.scan.08.messages..fields.HW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.561	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.561	warn	(7557) Object ebus.0.scan.08.messages..fields.HW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.560	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.559	warn	(7557) Object ebus.0.scan.08.messages..fields.SW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.559	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.558	warn	(7557) Object ebus.0.scan.08.messages..fields.SW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.558	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.557	warn	(7557) Object ebus.0.scan.08.messages..fields.ID.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.556	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.556	warn	(7557) Object ebus.0.scan.08.messages..fields.ID.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.555	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.555	warn	(7557) Object ebus.0.scan.08.messages..fields.MF.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.554	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.553	warn	(7557) Object ebus.0.scan.08.messages..fields.MF.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.553	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.552	warn	(7557) Object ebus.0.scan.08.messages..lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.551	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.551	warn	(7557) Object ebus.0.scan.06.messages.id.fields.suffix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.550	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.550	warn	(7557) Object ebus.0.scan.06.messages.id.fields.suffix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.549	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.549	warn	(7557) Object ebus.0.scan.06.messages.id.fields.counter.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.548	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.547	warn	(7557) Object ebus.0.scan.06.messages.id.fields.counter.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.547	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.546	warn	(7557) Object ebus.0.scan.06.messages.id.fields.supplier.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.545	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.545	warn	(7557) Object ebus.0.scan.06.messages.id.fields.supplier.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.544	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.544	warn	(7557) Object ebus.0.scan.06.messages.id.fields.product.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.543	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.542	warn	(7557) Object ebus.0.scan.06.messages.id.fields.product.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.542	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.541	warn	(7557) Object ebus.0.scan.06.messages.id.fields.week.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.541	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.540	warn	(7557) Object ebus.0.scan.06.messages.id.fields.week.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.539	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.539	warn	(7557) Object ebus.0.scan.06.messages.id.fields.year.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.538	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.537	warn	(7557) Object ebus.0.scan.06.messages.id.fields.year.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.536	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.536	warn	(7557) Object ebus.0.scan.06.messages.id.fields.prefix.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.535	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.535	warn	(7557) Object ebus.0.scan.06.messages.id.fields.prefix.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.534	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.534	warn	(7557) Object ebus.0.scan.06.messages.id.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.533	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.532	warn	(7557) Object ebus.0.scan.06.messages..fields.HW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.532	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.531	warn	(7557) Object ebus.0.scan.06.messages..fields.HW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.530	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.530	warn	(7557) Object ebus.0.scan.06.messages..fields.SW.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.529	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.529	warn	(7557) Object ebus.0.scan.06.messages..fields.SW.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.528	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.527	warn	(7557) Object ebus.0.scan.06.messages..fields.ID.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.527	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.526	warn	(7557) Object ebus.0.scan.06.messages..fields.ID.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.525	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.525	warn	(7557) Object ebus.0.scan.06.messages..fields.MF.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.524	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.524	warn	(7557) Object ebus.0.scan.06.messages..fields.MF.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.523	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.522	warn	(7557) Object ebus.0.scan.06.messages..lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.522	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.521	warn	(7557) Object ebus.0.broadcast.messages.vdatetime.fields.date.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.520	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.520	warn	(7557) Object ebus.0.broadcast.messages.vdatetime.fields.date.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.519	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.519	warn	(7557) Object ebus.0.broadcast.messages.vdatetime.fields.time.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.518	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.518	warn	(7557) Object ebus.0.broadcast.messages.vdatetime.fields.time.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.517	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.516	warn	(7557) Object ebus.0.broadcast.messages.vdatetime.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.516	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.515	warn	(7557) Object ebus.0.broadcast.messages.outsidetemp.fields.temp2.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.515	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.514	warn	(7557) Object ebus.0.broadcast.messages.outsidetemp.fields.temp2.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.513	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.513	warn	(7557) Object ebus.0.broadcast.messages.outsidetemp.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.512	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.512	warn	(7557) Object ebus.0.bai.messages.StatusCirPump.fields.0.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.511	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.511	warn	(7557) Object ebus.0.bai.messages.StatusCirPump.fields.0.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.510	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.509	warn	(7557) Object ebus.0.bai.messages.StatusCirPump.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.509	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.508	warn	(7557) Object ebus.0.bai.messages.Status02.fields.4.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.508	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.507	warn	(7557) Object ebus.0.bai.messages.Status02.fields.4.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.506	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.506	warn	(7557) Object ebus.0.bai.messages.Status02.fields.3.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.505	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.505	warn	(7557) Object ebus.0.bai.messages.Status02.fields.3.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.504	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.503	warn	(7557) Object ebus.0.bai.messages.Status02.fields.2.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.503	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.502	warn	(7557) Object ebus.0.bai.messages.Status02.fields.2.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.502	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.501	warn	(7557) Object ebus.0.bai.messages.Status02.fields.1.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.500	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.500	warn	(7557) Object ebus.0.bai.messages.Status02.fields.1.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.499	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.499	warn	(7557) Object ebus.0.bai.messages.Status02.fields.0.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.498	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.497	warn	(7557) Object ebus.0.bai.messages.Status02.fields.0.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.497	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.496	warn	(7557) Object ebus.0.bai.messages.Status02.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.495	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.495	warn	(7557) Object ebus.0.bai.messages.Status01.fields.5.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.494	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.494	warn	(7557) Object ebus.0.bai.messages.Status01.fields.5.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.493	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.493	warn	(7557) Object ebus.0.bai.messages.Status01.fields.4.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.492	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.491	warn	(7557) Object ebus.0.bai.messages.Status01.fields.4.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.490	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.490	warn	(7557) Object ebus.0.bai.messages.Status01.fields.3.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.489	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.489	warn	(7557) Object ebus.0.bai.messages.Status01.fields.3.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.486	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.486	warn	(7557) Object ebus.0.bai.messages.Status01.fields.2.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.485	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.485	warn	(7557) Object ebus.0.bai.messages.Status01.fields.2.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.484	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.484	warn	(7557) Object ebus.0.bai.messages.Status01.fields.1.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.483	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.482	warn	(7557) Object ebus.0.bai.messages.Status01.fields.1.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.481	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.481	warn	(7557) Object ebus.0.bai.messages.Status01.fields.0.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.480	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.480	warn	(7557) Object ebus.0.bai.messages.Status01.fields.0.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.479	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.478	warn	(7557) Object ebus.0.bai.messages.Status01.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.478	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.477	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.releaseCooling.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.477	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.476	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.releaseCooling.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.475	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.475	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.releaseBackup.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.474	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.474	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.releaseBackup.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.473	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.473	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.remoteControlHcPump.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.472	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.471	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.remoteControlHcPump.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.471	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.470	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.disablehwcload.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.470	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.469	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.disablehwcload.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.468	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.468	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.disablehwctapping.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.467	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.467	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.disablehwctapping.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.466	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.465	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.disablehc.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.465	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.464	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.disablehc.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.464	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.463	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.hwcflowtempdesired.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.462	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.462	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.hwcflowtempdesired.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.461	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.461	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.hwctempdesired.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.460	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.460	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.hwctempdesired.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.459	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.458	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.flowtempdesired.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.458	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.457	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.flowtempdesired.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.456	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.456	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.hcmode.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.455	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.455	warn	(7557) Object ebus.0.bai.messages.SetMode.fields.hcmode.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.454	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.454	warn	(7557) Object ebus.0.bai.messages.SetMode.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.453	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.452	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.temp2.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.452	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.451	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.temp2.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.451	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.450	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.bdate.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.449	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.449	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.bdate.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.448	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.448	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.btime.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.447	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.447	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.btime.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.446	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.445	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.dcfstate.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.445	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.444	warn	(7557) Object ebus.0.bai.messages.DateTime.fields.dcfstate.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.443	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.443	warn	(7557) Object ebus.0.bai.messages.DateTime.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.442	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.442	warn	(7557) Object ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.name is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.441	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.441	warn	(7557) Object ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.440	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:02.439	warn	(7557) Object ebus.0.700.messages.DisplayedOutsideTemp.lastup is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:02.374	info	(7557) all http done
      ebus.0	2020-06-16 17:10:02.133	debug	(7557) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":false
      ebus.0	2020-06-16 17:10:02.091	debug	(7557) request data from http://192.168.178.47:8890/data
      ebus.0	2020-06-16 17:10:02.089	debug	(7557) all telnet done
      ebus.0	2020-06-16 17:10:02.088	debug	(7557) received 38.94;ok for Ntc1Sensor
      ebus.0	2020-06-16 17:10:01.871	debug	(7557) received 24.25 for DisplayedOutsideTemp
      ebus.0	2020-06-16 17:10:01.553	debug	(7557) telnet connected
      ebus.0	2020-06-16 17:10:01.549	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:01.548	warn	(7557) Object ebus.0.history.error is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:01.519	debug	(7557) connect telnet to IP 192.168.178.47 port 8888
      ebus.0	2020-06-16 17:10:01.518	debug	(7557) to poll ctr 2 vals: DisplayedOutsideTemp,Ntc1Sensor org DisplayedOutsideTemp,Ntc1Sensor org length 31
      ebus.0	2020-06-16 17:10:01.506	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:01.506	warn	(7557) Object ebus.0.history.date is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:01.505	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:01.504	warn	(7557) Object ebus.0.history.value1 is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:01.504	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:01.503	warn	(7557) Object ebus.0.cmdResult is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:01.502	warn	(7557) This object will not be created in future versions. Please report this to the developer.
      ebus.0	2020-06-16 17:10:01.501	warn	(7557) Object ebus.0.cmd is invalid: obj.type has to exist
      ebus.0	2020-06-16 17:10:01.473	debug	(7557) init common variables
      ebus.0	2020-06-16 17:10:01.468	debug	(7557) init variables
      ebus.0	2020-06-16 17:10:01.468	debug	(7557) start with interface ebusd
      ebus.0	2020-06-16 17:10:01.467	debug	(7557) set timeout to 60 sec
      ebus.0	2020-06-16 17:10:01.438	info	(7557) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4
      host.raspberrypi	2020-06-16 17:10:00.016	info	instance system.adapter.ebus.0 started with pid 7557
      In Objekte legt er Ordner an, jedoch keine Werte:
      Und wenn ich die Statusansicht wechsel, wird ebus nicht angezeigt:
      Es hatte Wochen funktioniert???
      Rene_HMR 1 Antwort Letzte Antwort
      • J Jui
        @Rene_HM
        Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        #231
        @Jui muss ich mir anschauen, scheint ein bug zu sein...
        • Rene_HMR Rene_HM
          Jui
          schrieb am zuletzt editiert von Jui
          #232
          @Rene_HM
          Okay , Die Version 1.0.0 hatte Wochen funktioniert.
          Vielleicht hilft es Dir bei der Fehlersuche:
          • ich hatte von 1.0.0 auf 2.0.0 gewechselt, danach lief alles tadellos weiter, Werte wurden angezeigt und erneuert.
          • dann habe ich neue Datenpunkte hinzu genommen, die Config im ebusd erneuert, die alten Werte wurden weiter tadellos angezeigt , die neuen Werte erschienen nicht unter Objekte
          • dann ebus Adapter deinstalliert und neu installiert
          • dann kamen unter Objekte gar keine Werte mehr (so wie jetzt), im Log und unter http//.../data sind aktuelle Werte immer zu sehen
          • dann ebusd Config wieder auf die letzte Einstellung geändert, auch ohne Erfolg ...
          Auf die alte Version kann ich nicht wechseln um zu testen.
          • J Jui
            @Rene_HM
            Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #233
            @Jui ich habe die version 2.1.0 im github und npm (latest repo). Die sollte das Problem beheben...
            • Rene_HMR Rene_HM
              Jui
              #234
              @Rene_HM TOP!
              Update auf 2.1.0 durchgeführt, dann unter Objekte ebus.0 gelöscht und mit dem nächsten Abruf sind die Werte wieder da.
              DANKE!
              • KnallochseK Nicht stören
                Knallochse
                #235
                Mit der Version 2.1.0 habe ich alle 5min folgende Fehlermeldung im Log
                ebus.0	2020-06-19 19:35:03.268	error	(1063) history.value1 not found null
                ebus.0	2020-06-19 19:35:03.266	error	(1063) history.date not found null
                ebus.0	2020-06-19 19:35:02.306	error	(1063) object cmd not found null
                Das hatte ich vorher nicht.
                Ich hatte beim Umstieg auf 2.1.0 alle Ebus Objekte gelöscht und neu anlegen lassen.
                Kann ich hier etwas tun, um die Fehler zu beseitigen?
                • KnallochseK Knallochse
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #236
                  @Knallochse Das sind nur logs, die ich beim Umbau eingebaut hatte. Im Moment bitte ignorieren, außer irgendetwas geht nicht (z.Bsp. Kommandos direkt auf ebusd schreiben...)
                  KnallochseK 1 Antwort Letzte Antwort
                  • Rene_HMR Rene_HM
                    Knallochse
                    #237
                    @Rene_HM Danke, dann weiß ich Bescheid
                    • Rene_HMR Rene_HM
                      Ich denke nicht, dass Vaillant ebusd direkt unetrstützt.
                      Ich vermute, dass das Modul VR 920 intern mit den anderen Modulen der Heizung per ebus kommuniziert. Auf der anderen Seite steht dann Ethernet / IP zur Kommunikation mit Tablet usw zur Verfügung. Der Adapter unterstützt dies aber nicht.
                      Aus meiner Sicht zwei Möglichkeiten:
                      • Integration des Vaillant-Internetmodul VR 920 als Adapter in ioBroker
                      • ein zusätzliches ebus-Interface mit Raspberry Pi o.ä. an den ebus anschliessen und den ebusd dann auf dem Raspberry Pi laufen lassen. Dann kann man den Adapter hier verwenden.
                      Bei der ersten Variante kann ich leider nicht helfen, da ich dieses Modul nicht zur Verfügung habe…
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #238
                      @Rene_HM sagte in Adapter: ebus:
                      Wegen Heizungs Neuanschaffung bekomme ich ein VR 921 I-Modul dazu was auch EEbus kann .
                      Laut I-Net soll es auch mit Homematic CCU3 laufen , aber leider keine Infos dazu im I-Net wie es einzubinden ist gefunden .
                      eQ-3 integriert EEBUS in Smart Home Systeme
                      Wie kann ich dich darin unterstützen , damit du dieses Modul integrieren kannst ?
                      C 1 Antwort Letzte Antwort
                      • GlasfaserG Glasfaser
                        cactus-online
                        #239
                        @Glasfaser
                        eebus ist nicht ebus. Was auch immer EQ3 da treibt, mit diesen Adapter hier hat das nichts zu tun denke ich.
                        Ob der HMIP Adapter damit etwas anfangen kann müsste an jener Stelle im Forum diskutiert werden.
                        • C cactus-online
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #240
                          @cactus-online sagte in Adapter: ebus:
                          @Glasfaser
                          Das ist mir schon klar
                          Hallo ... war nur eine Andeutung ...mehr nicht
                          Ich wollte hier keine diskutieren anfangen , habe nur @Rene_HM angefragt ob ich Ihn bei dem integrieren des VR 921 I-Net Modul was auch eBus kann , unterstützen kann .
                            @Glasfaser
                            cactus-online
                            schrieb am zuletzt editiert von cactus-online
                            #241
                            @Glasfaser: Ok, das konnte ich dem Post so nicht entnehmen. Wenn eBus unterstützt wird, müsste dann nicht der eBus-Daemon die Nachrichten dekodieren (können). Der Adapter holt sich doch alles vom ebusd. Eine Anpassung des Adapters wäre doch gar nicht nötig, oder was meinst Du?
                            • C cactus-online
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #242
                              @cactus-online
                              ich dachte es geht eventuell ohne den Ebusd , also per Schnittstelle direkt zum Internetmodul VR 921 den ich habe .
                              Hatte auch in der Zwischenzeit etwas gefunden Test Adapter Vaillant multiMatic v0.0.x, ist aber nicht so doll ..
                              Bin deinem Rat zu Ebusd gefolgt 👍
                              ... klappt auch alles mit diesem Ebus Adapter ,
                              aber da ich den Witterungsgeführte Regelung sensoCOMFORT VRC 720 haben, sind nicht alle Werte vorhanden nur leider ein kleiner Bruchteil davon. 😠
                              Die 15.700.cvs auf 15.720.cvs geändert.
                              @cactus-online hast du vielleicht ein Rat woran das liegen kann ?
                              root@DietPi:~# ebusctl info
                              version: ebusd 3.4.v3.4-20-gedfe09a
                              signal: acquired
                              symbol rate: 47
                              max symbol rate: 106
                              min arbitration micros: 2185
                              max arbitration micros: 8069
                              min symbol latency: 5
                              max symbol latency: 12
                              reconnects: 0
                              masters: 4
                              conditional: 3
                              poll: 0
                              update: 10
                              address 00: master #1
                              address 03: master #11
                              address 05: slave #1, scanned "MF=Vaillant;ID=VR921;SW=2007;HW=5703"
                              address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0104;HW=7803", loaded "vaillant/bai.308523.inc", "vaillant/08.bai.csv"
                              address 10: master #2
                              address 15: slave #2, scanned "MF=Vaillant;ID=72000;SW=0122;HW=7703", loaded "vaillant/15.720.csv"
                              address 31: master #8, ebusd
                              address 36: slave #8, ebusd
                              root@DietPi:~#
                              root@DietPi:~/ebusd/contrib/scripts# ./readall.sh
                              720 AdaptHeatCurve = no
                              720 BankHolidayEndPeriod = ERR: invalid position in decode
                              720 BankHolidayStartPeriod = ERR: invalid position in decode
                              720 ccTimer.Friday = ERR: invalid position in decode
                              720 ccTimer.Monday = ERR: invalid position in decode
                              720 ccTimer.Saturday = ERR: invalid position in decode
                              720 ccTimer.Sunday =
                              720 ccTimer.Thursday = ERR: invalid position in decode
                              720 ccTimer.Tuesday = ERR: invalid position in decode
                              720 ccTimer.Wednesday = ERR: invalid position in decode
                              720 ContinuosHeating =
                              720 currenterror =
                              720 CylinderChargeHyst =
                              720 CylinderChargeOffset =
                              720 Date =
                              720 DisplayedOutsideTemp =
                              720 errorhistory =
                              720 FrostOverRideTime =
                              720 Hc1ActualFlowTempDesired =
                              720 Hc1AutoOffMode =
                              720 Hc1CircuitType =
                              720 Hc1ExcessTemp =
                              720 Hc1FlowTemp =
                              720 Hc1HeatCurve =
                              720 Hc1HeatCurveAdaption =
                              720 Hc1MaxFlowTempDesired =
                              720 Hc1MinFlowTempDesired =
                              720 Hc1MixerMovement =
                              720 Hc1PumpStatus =
                              720 Hc1RoomTempSwitchOn =
                              720 Hc1Status =
                              720 Hc1SummerTempLimit =
                              720 Hc2ActualFlowTempDesired =
                              720 Hc2AutoOffMode =
                              720 Hc2CircuitType = inactive
                              720 Hc2ExcessTemp =
                              720 Hc2FlowTemp = -
                              720 Hc2HeatCurve = 1.2
                              720 Hc2HeatCurveAdaption =
                              720 Hc2MaxFlowTempDesired =
                              720 Hc2MinFlowTempDesired =
                              720 Hc2MixerMovement =
                              720 Hc2PumpStatus =
                              720 Hc2RoomTempSwitchOn =
                              720 Hc2Status =
                              720 Hc2SummerTempLimit =
                              720 Hc3ActualFlowTempDesired =
                              720 Hc3AutoOffMode =
                              720 Hc3CircuitType =
                              720 Hc3ExcessTemp =
                              720 Hc3FlowTemp =
                              720 Hc3HeatCurve = 1.2
                              720 Hc3HeatCurveAdaption =
                              720 Hc3MaxFlowTempDesired =
                              720 Hc3MinFlowTempDesired =
                              720 Hc3MixerMovement =
                              720 Hc3PumpStatus =
                              720 Hc3RoomTempSwitchOn =
                              720 Hc3Status =
                              720 Hc3SummerTempLimit =
                              720 HcStorageTempBottom =
                              720 HcStorageTempTop =
                              720 HolidayEndPeriod =
                              720 HolidayStartPeriod =
                              720 HolidayTemp =
                              720 HwcBankHolidayEndPeriod =
                              720 HwcBankHolidayStartPeriod =
                              720 HwcFlowTemp =
                              720 HwcHolidayEndPeriod = 01.01.2019
                              720 HwcHolidayStartPeriod = 01.01.2019
                              720 HwcLockTime = 60
                              720 HwcMaxFlowTempDesired =
                              720 HwcOpMode =
                              720 HwcParallelLoading =
                              720 HwcSFMode = auto
                              720 HwcStorageTemp = 54.5
                              720 HwcStorageTempBottom = -
                              720 HwcStorageTempTop = -
                              720 HwcTempDesired =
                              720 hwcTimer.Friday =
                              720 hwcTimer.Monday = ERR: invalid position in decode
                              720 hwcTimer.Saturday = ERR: invalid position in decode
                              720 hwcTimer.Sunday = ERR: invalid position in decode
                              720 hwcTimer.Thursday = ERR: invalid position in decode
                              720 hwcTimer.Tuesday = ERR: invalid position in decode
                              720 hwcTimer.Wednesday = ERR: invalid position in decode
                              720 HydraulicScheme = 1
                              720 Installer1 = ERR: invalid position in decode
                              720 Installer2 = ERR: invalid position in decode
                              720 KeyCodeforConfigMenu = 0
                              720 MaintenanceDate = 01.01.2019
                              720 MaintenanceDue = no
                              720 MaxCylinderChargeTime = 60
                              720 MaxRoomHumidity = 40
                              720 MultiRelaySetting = circulation
                              720 noiseReductionTimer.Friday = ERR: invalid position in decode
                              720 noiseReductionTimer.Monday = ERR: invalid position in decode
                              720 noiseReductionTimer.Saturday = ERR: invalid position in decode
                              720 noiseReductionTimer.Sunday = ERR: invalid position in decode
                              720 noiseReductionTimer.Thursday = ERR: invalid position in decode
                              720 noiseReductionTimer.Tuesday = ERR: invalid position in decode
                              720 noiseReductionTimer.Wednesday = ERR: invalid position in decode
                              720 OpMode = ERR: invalid position in decode
                              720 OpModeEffect = ERR: invalid position in decode
                              720 OutsideTempAvg =
                              720 PhoneNumber1 =
                              720 PhoneNumber2 =
                              720 PrEnergySum =
                              720 PrEnergySumHc = 1
                              720 PrEnergySumHcLastMonth = 0
                              720 PrEnergySumHcThisMonth = 1
                              720 PrEnergySumHwc =
                              720 PrEnergySumHwcLastMonth = 0
                              720 PrEnergySumHwcThisMonth =
                              720 PrFuelSum =
                              720 PrFuelSumHc = 12
                              720 PrFuelSumHcLastMonth = 0
                              720 PrFuelSumHcThisMonth =
                              720 PrFuelSumHwc =
                              720 PrFuelSumHwcLastMonth =
                              720 PrFuelSumHwcThisMonth = 108
                              720 PumpAdditionalTime = 5
                              720 SFMode = ERR: invalid position in decode
                              720 SolarYieldTotal = 0
                              720 SystemFlowTemp = -
                              720 tariffTimer.Friday = ERR: invalid position in decode
                              720 tariffTimer.Monday = ERR: invalid position in decode
                              720 tariffTimer.Saturday = ERR: invalid position in decode
                              720 tariffTimer.Sunday = ERR: invalid position in decode
                              720 tariffTimer.Thursday = ERR: invalid position in decode
                              720 tariffTimer.Tuesday = ERR: invalid position in decode
                              720 tariffTimer.Wednesday = ERR: invalid position in decode
                              720 Time = 15:30:05
                              720 ventilationTimer.Friday = ERR: invalid position in decode
                              720 ventilationTimer.Monday = ERR: invalid position in decode
                              720 ventilationTimer.Saturday = ERR: invalid position in decode
                              720 ventilationTimer.Sunday = ERR: invalid position in decode
                              720 ventilationTimer.Thursday = ERR: invalid position in decode
                              720 ventilationTimer.Tuesday = ERR: invalid position in decode
                              720 ventilationTimer.Wednesday = ERR: invalid position in decode
                              720 WaterPressure =
                              720 YieldTotal =
                              720 z1ActualRoomTempDesired =
                              720 z1BankHolidayEndPeriod = ERR: invalid position in decode
                              720 z1BankHolidayStartPeriod = ERR: invalid position in decode
                              720 z1CoolingTemp =
                              720 z1CoolingTimer.Friday =
                              720 z1CoolingTimer.Monday = ERR: invalid position in decode
                              720 z1CoolingTimer.Saturday = ERR: invalid position in decode
                              720 z1CoolingTimer.Sunday = ERR: invalid position in decode
                              720 z1CoolingTimer.Thursday = ERR: invalid position in decode
                              720 z1CoolingTimer.Tuesday = ERR: invalid position in decode
                              720 z1CoolingTimer.Wednesday = ERR: invalid position in decode
                              720 z1DayTemp = ERR: invalid position in decode
                              720 z1HolidayEndPeriod = 01.01.2019
                              720 z1HolidayStartPeriod = 01.01.2019
                              720 z1HolidayTemp =
                              720 z1Name1 =
                              720 z1Name2 =
                              720 z1NightTemp =
                              720 z1OpMode =
                              720 z1QuickVetoTemp =
                              720 z1RoomTemp =
                              720 z1RoomZoneMapping =
                              720 z1SFMode =
                              720 z1Shortname =
                              720 z1Timer.Friday =
                              720 z1Timer.Monday =
                              720 z1Timer.Saturday =
                              720 z1Timer.Sunday =
                              720 z1Timer.Thursday = ERR: invalid position in decode
                              720 z1Timer.Tuesday = ERR: invalid position in decode
                              720 z1Timer.Wednesday = ERR: invalid position in decode
                              720 z1ValveStatus = 0
                              720 z2ActualRoomTempDesired = 0.0
                              720 z2BankHolidayEndPeriod = ERR: invalid position in decode
                              720 z2BankHolidayStartPeriod = ERR: invalid position in decode
                              720 z2CoolingTemp =
                              720 z2CoolingTimer.Friday =
                              720 z2CoolingTimer.Monday =
                              720 z2CoolingTimer.Saturday = ERR: invalid position in decode
                              720 z2CoolingTimer.Sunday = ERR: invalid position in decode
                              720 z2CoolingTimer.Thursday = ERR: invalid position in decode
                              720 z2CoolingTimer.Tuesday = ERR: invalid position in decode
                              720 z2CoolingTimer.Wednesday = ERR: invalid position in decode
                              720 z2DayTemp = ERR: invalid position in decode
                              720 z2HolidayEndPeriod = 01.01.2019
                              720 z2HolidayStartPeriod = 01.01.2019
                              720 z2HolidayTemp =
                              720 z2Name1 =
                              720 z2Name2 =
                              720 z2NightTemp =
                              720 z2OpMode =
                              720 z2QuickVetoTemp =
                              720 z2RoomTemp =
                              720 z2RoomZoneMapping =
                              720 z2SFMode =
                              720 z2Shortname =
                              720 z2Timer.Friday =
                              720 z2Timer.Monday =
                              720 z2Timer.Saturday =
                              720 z2Timer.Sunday = ERR: invalid position in decode
                              720 z2Timer.Thursday = ERR: invalid position in decode
                              720 z2Timer.Tuesday = ERR: invalid position in decode
                              720 z2Timer.Wednesday = ERR: invalid position in decode
                              720 z2ValveStatus = 0
                              720 z3ActualRoomTempDesired = 0.0
                              720 z3BankHolidayEndPeriod = ERR: invalid position in decode
                              720 z3BankHolidayStartPeriod = ERR: invalid position in decode
                              720 z3DayTemp = ERR: invalid position in decode
                              720 z3HolidayEndPeriod = 01.01.2019
                              720 z3HolidayStartPeriod = 01.01.2019
                              720 z3HolidayTemp =
                              720 z3Name1 =
                              720 z3Name2 = ERR: invalid position in decode
                              720 z3NightTemp =
                              720 z3OpMode =
                              720 z3QuickVetoTemp =
                              720 z3RoomTemp =
                              720 z3RoomZoneMapping =
                              720 z3SFMode =
                              720 z3Shortname =
                              720 z3ValveStatus =
                              Ausgabe html.txt
                              Ausgabe grab.txt
                              @Timmerx hat du alle Daten vorhanden , da du schreibst es funktioniert bei dir !?
                                @cactus-online
                                signal: acquired
                                symbol rate: 47
                                reconnects: 0
                                masters: 4
                                conditional: 3
                                poll: 0
                                update: 10
                                root@DietPi:~#
                                720 currenterror =
                                720 Date =
                                720 errorhistory =
                                720 Hc1ExcessTemp =
                                720 Hc1FlowTemp =
                                720 Hc1HeatCurve =
                                720 Hc1PumpStatus =
                                720 Hc1Status =
                                720 Hc2ExcessTemp =
                                720 Hc2FlowTemp = -
                                720 Hc2PumpStatus =
                                720 Hc2Status =
                                720 Hc3ExcessTemp =
                                720 Hc3FlowTemp =
                                720 Hc3PumpStatus =
                                720 Hc3Status =
                                720 HolidayTemp =
                                720 HwcFlowTemp =
                                720 HwcOpMode =
                                720 PhoneNumber1 =
                                720 PhoneNumber2 =
                                720 PrEnergySum =
                                720 PrFuelSum =
                                720 PrFuelSumHwc =
                                720 Time = 15:30:05
                                720 WaterPressure =
                                720 YieldTotal =
                                720 z1CoolingTemp =
                                720 z1HolidayTemp =
                                720 z1Name1 =
                                720 z1Name2 =
                                720 z1NightTemp =
                                720 z1OpMode =
                                720 z1RoomTemp =
                                720 z1SFMode =
                                720 z1Shortname =
                                720 z2CoolingTemp =
                                720 z2HolidayTemp =
                                720 z2Name1 =
                                720 z2Name2 =
                                720 z2NightTemp =
                                720 z2OpMode =
                                720 z2RoomTemp =
                                720 z2SFMode =
                                720 z2Shortname =
                                720 z3HolidayTemp =
                                720 z3Name1 =
                                720 z3NightTemp =
                                720 z3OpMode =
                                720 z3RoomTemp =
                                720 z3SFMode =
                                720 z3Shortname =
                                720 z3ValveStatus =
                                Ausgabe html.txt
                                Ausgabe grab.txt
                                cactus-online
                                #243
                                @Glasfaser Aus meiner Sicht ist das kein Thema für das ioBroker Forum. ICh würde diese Frage eher hier (https://ebusd.eu/discussion/) platzieren.
                                VG,
                                TF
                                • C cactus-online
                                  VG,
                                  TF
                                  Kanumouse
                                  #244
                                  Ich habe eine Vaillant aurocompacht VSC 196/3-5 mit Regler VR470 und integrierten Solarregler.
                                  Mein ebus läuft nach anfänglichen Schwierigkeiten super und ich bekomme eine Menge Daten von der Heizung.
                                  Was mir nur nicht gelingt, sind Daten von der Solaranlage zu empfangen. Ist eventuell der integrierte Solarregler nicht am ebus angeschlossen oder gibt es andere Ursachen?
                                  Ich benutze ebusd 3.4 mit automatischer Konfiguration. Fehlt da eventuell noch eine spezifische .csv-Konfig-Datei?
                                  Kann mir da jemans helfen?
                                  HiltexH 1 Antwort Letzte Antwort
                                  • K Kanumouse
                                    HiltexH Offline
                                    HiltexH Offline
                                    Hiltex
                                    #245
                                    @Kanumouse Weißt du, welcher Solarregler da eingebaut ist?
                                    Ich bin nicht ganz sicher, ob es sich dabei tatsächlich um ein separates Bauteil handelt, aber bei mir ist der VR700 Regler eingebaut und der Solarregler meldet sich unter einer anderen Adresse mit dem Namen VMS01. Dafür habe ich eine separate Konfiguration erstellt. Findest du in meinem Github-Repository:
                                    https://github.com/Standarduser/ebusd-configuration
                                    Ich habe dazu ein Pullrequest erstellt, das bisher jedoch noch nicht angenommen wurde.
                                    Was dir also momentan bleibt, ist auf lokale Konfigurationsdateien umzustellen und zu probieren, ob die Datei geladen wird.
                                    Blog: indibit.de
                                    • HiltexH Hiltex
                                      Kanumouse
                                      #246
                                      @Hiltex
                                      Danke für den Tipp.
                                      Ich habe die letzte Version von Github mit der 06.vms.csv geladen.
                                      Leider werden immer noch keine Werte aus dem Solarkreis erkannt.
                                      ebusctl info bring folgendes Ergebnis:
                                      version: ebusd 3.4.v3.3-51-g57eae05
                                      update check: revision v3.4 available, vaillant/08.bai.csv: different version available, vaillant/hcmode.inc: different version available
                                      signal: acquired
                                      symbol rate: 17
                                      max symbol rate: 81
                                      min arbitration micros: 1335
                                      max arbitration micros: 4971
                                      min symbol latency: 4
                                      max symbol latency: 7
                                      reconnects: 0
                                      masters: 3
                                      conditional: 0
                                      poll: 1
                                      update: 10
                                      address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0518;HW=7401", loaded "vaillant/bai.0010003886.inc" ([PROD='0010009352']), "vaillant/08.bai.csv"
                                      address 15: slave #2, scanned "MF=Vaillant;ID=47000;SW=0128;HW=6002", loaded "vaillant/15.470.csv"
                                      address 26: slave, scanned "MF=Vaillant;ID=47000;SW=0128;HW=6002"
                                      Im Moment komme ich nicht weiter?
                                      • K Kanumouse
                                        @Hiltex
                                        Danke für den Tipp.
                                        signal: acquired
                                        symbol rate: 17
                                        max symbol rate: 81
                                        reconnects: 0
                                        masters: 3
                                        conditional: 0
                                        poll: 1
                                        update: 10
                                        HiltexH Offline
                                        HiltexH Offline
                                        Hiltex
                                        #247
                                        @Kanumouse dann scheint dein System anders zu funktionieren. Da kann ich dir leider auch nicht helfen
                                        Blog: indibit.de
                                        • HiltexH Hiltex
                                          Kanumouse
                                          #248
                                          @Hiltex
                                          Kann mir vielleicht jemand diesen Ausschnitt des Log-Files deuten?
                                          Hier findetd ebusd offensichtlich unter zwei Adressen die ID=47000 und kann natürlich das Init-File mit der Adresse 26 bei den csv-Dateien nicht finden, oder?
                                          2020-09-07 18:04:15.989 [bus notice] scan 08: ;Vaillant;BAI00;0518;7401
                                          2020-09-07 18:04:15.989 [update notice] store 08 ident: done
                                          2020-09-07 18:04:15.989 [update notice] sent scan-read scan.08 QQ=31: Vaillant;BAI00;0518;7401
                                          2020-09-07 18:04:22.558 [bus notice] scan 15: ;Vaillant;47000;0128;6002
                                          2020-09-07 18:04:22.558 [update notice] store 15 ident: done
                                          2020-09-07 18:04:22.558 [update notice] sent scan-read scan.15 QQ=31: Vaillant;47000;0128;6002
                                          2020-09-07 18:04:22.954 [main notice] read common config file vaillant/broadcast.csv
                                          2020-09-07 18:04:22.956 [main notice] read common config file vaillant/scan.csv
                                          2020-09-07 18:04:22.956 [main notice] read common config file vaillant/general.csv
                                          2020-09-07 18:04:22.959 [main notice] read scan config file vaillant/08.bai.csv for ID "bai00", SW0518, HW7401
                                          2020-09-07 18:04:23.908 [update notice] sent scan-read scan.08 id QQ=31:
                                          2020-09-07 18:04:24.255 [update notice] sent scan-read scan.08 id QQ=31:
                                          2020-09-07 18:04:25.078 [update notice] sent scan-read scan.08 id QQ=31:
                                          2020-09-07 18:04:27.014 [update notice] sent scan-read scan.08 id QQ=31: 21;12;03;0010009352;3100;005027;N2
                                          2020-09-07 18:04:27.067 [main notice] found messages: 207 (0 conditional on 24 conditions, 0 poll, 10 update)
                                          2020-09-07 18:04:27.828 [update notice] sent scan-read scan.08 id QQ=31: 21;12;03;0010009352;3100;005027;N2
                                          2020-09-07 18:04:29.789 [update notice] sent scan-read scan.08 id QQ=31: 21;12;03;0010009352;3100;005027;N2
                                          2020-09-07 18:04:30.635 [update notice] sent scan-read scan.08 id QQ=31: 21;12;03;0010009352;3100;005027;N2
                                          2020-09-07 18:04:32.603 [update notice] sent scan-read scan.08 id QQ=31: 21;12;03;0010009352;3100;005027;N2
                                          2020-09-07 18:04:32.603 [bus notice] scan 08: ;21;12;03;0010009352;3100;005027;N2
                                          2020-09-07 18:04:35.057 [update notice] received read bai Status01 QQ=10: 31.0;28.0;18.000;46.0;65.0;off
                                          2020-09-07 18:04:35.291 [update notice] sent unknown MS cmd: 3115b5090124 / 09003231313230353030
                                          2020-09-07 18:04:36.111 [update notice] sent scan-read scan.15 id QQ=31:
                                          2020-09-07 18:04:38.053 [update notice] sent scan-read scan.15 id QQ=31:
                                          2020-09-07 18:04:38.208 [update notice] received read bai DateTime QQ=10: sync;18:04:46;-.-.-;18.000
                                          2020-09-07 18:04:38.445 [update notice] sent scan-read scan.15 id QQ=31: 21;12;05;0020108127;0082;008433;N7
                                          2020-09-07 18:04:38.445 [bus notice] scan 15: ;21;12;05;0020108127;0082;008433;N7
                                          2020-09-07 18:04:38.471 [main notice] read scan config file vaillant/15.470.csv for ID "47000", SW0128, HW6002
                                          2020-09-07 18:04:38.487 [main notice] found messages: 458 (0 conditional on 24 conditions, 1 poll, 10 update)
                                          2020-09-07 18:04:39.802 [bus notice] scan 26: ;Vaillant;47000;0128;6002
                                          2020-09-07 18:04:39.803 [update notice] store 26 ident: done
                                          2020-09-07 18:04:39.803 [update notice] sent scan-read scan.26 QQ=31: Vaillant;47000;0128;6002
                                          2020-09-07 18:04:39.803 [bus notice] scan 26: ;Vaillant;47000;0128;6002
                                          2020-09-07 18:04:41.187 [update notice] sent unknown MS cmd: 3126b5090124 / 09003231313230353030
                                          2020-09-07 18:04:42.012 [update notice] sent scan-read scan.26 id QQ=31:
                                          2020-09-07 18:04:43.988 [update notice] sent scan-read scan.26 id QQ=31:
                                          2020-09-07 18:04:44.842 [update notice] sent scan-read scan.26 id QQ=31: 21;12;05;0020108127;0082;008433;N7
                                          2020-09-07 18:04:44.842 [bus notice] scan 26: ;21;12;05;0020108127;0082;008433;N7
                                          2020-09-07 18:04:44.843 [main error] unable to load scan config 26: no file from vaillant with prefix 26 matches ID "47000", SW0128, HW6002
                                          2020-09-07 18:04:44.843 [main error] scan config 26: ERR: element not found
