  4. Regelmäßige neustarts von Iobroker
neustartsiobrokerabsturz
17 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • C canim
    Hallo, hab leider das Problem,dass ca alle 15 min mein Iobroker neustartet . Kann mir einer evt aus dem log sagen warum? bzw helfen das der Iobroker permanent läuft.
    * 2020-07-09 19:30:25.107  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    * 2020-07-09 19:52:28.786  - info: javascript.0 (1250) Stop script script.js.Waschmaschine
    * 2020-07-09 19:52:28.787  - info: admin.0 (643) terminating http server on port 8081
    * 2020-07-09 19:52:28.792  - info: yeelight-2.0 (1206) cleaned everything up...
    * 2020-07-09 19:52:28.789  - info: javascript.0 (1250) Stop script script.js.Trockner
    * 2020-07-09 19:52:28.790  - info: javascript.0 (1250) Stop script script.js.Küchen_Led_An
    * 2020-07-09 19:52:28.791  - info: javascript.0 (1250) Stop script script.js.Wohnzimmer_Led
    * 2020-07-09 19:52:28.792  - info: javascript.0 (1250) Stop script script.js.Tablet_Akku
    * 2020-07-09 19:52:28.793  - info: javascript.0 (1250) Stop script script.js.Kinderzimmer_Heizung_Aus
    * 2020-07-09 19:52:28.785  - info: host.raspberrypi received SIGTERM
    * 2020-07-09 19:52:28.809  - info: trashschedule.0 (1172) cleaned everything up...
    * 2020-07-09 19:52:28.809  - info: info.0 (665) cleaned everything up...
    * 2020-07-09 19:52:28.812  - info: web.0 (1191) terminated http server on port 8082
    * 2020-07-09 19:52:28.811  - info: backitup.0 (676) cleaned everything up...
    * 2020-07-09 19:52:28.809  - info: tado.0 (1232) cleaned everything up...
    * 2020-07-09 19:52:28.821  - info: admin.0 (643) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.824  - info: discovery.0 (658) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.827  - info: info.0 (665) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.830  - info: backitup.0 (676) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.831  - info: alexa2.0 (710) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.819  - info: shelly.0 (1239) Closing Adapter
    * 2020-07-09 19:52:28.835  - info: trashschedule.0 (1172) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.837  - info: web.0 (1191) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.837  - info: yeelight-2.0 (1206) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.843  - info: fullybrowser.0 (1217) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.847  - info: tado.0 (1232) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.808  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    * 2020-07-09 19:52:28.809  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
    * 2020-07-09 19:52:28.810  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=true)
    * 2020-07-09 19:52:28.811  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    * 2020-07-09 19:52:28.811  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
    * 2020-07-09 19:52:28.812  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    * 2020-07-09 19:52:28.812  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
    * 2020-07-09 19:52:28.813  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    * 2020-07-09 19:52:28.814  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    * 2020-07-09 19:52:28.814  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 (force=false, process=true)
    * 2020-07-09 19:52:28.815  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
    * 2020-07-09 19:52:28.815  - info: host.raspberrypi stopInstance system.adapter.tado.0 (force=false, process=true)
    * 2020-07-09 19:52:28.816  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=true)
    * 2020-07-09 19:52:28.817  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    * 2020-07-09 19:52:28.817  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
    * 2020-07-09 19:52:28.818  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    * 2020-07-09 19:52:28.819  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    * 2020-07-09 19:52:28.823  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
    * 2020-07-09 19:52:28.826  - info: host.raspberrypi stopInstance system.adapter.info.0 send kill signal
    * 2020-07-09 19:52:28.827  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    * 2020-07-09 19:52:28.829  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
    * 2020-07-09 19:52:28.832  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal
    * 2020-07-09 19:52:28.835  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
    * 2020-07-09 19:52:28.836  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 send kill signal
    * 2020-07-09 19:52:28.839  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 send kill signal
    * 2020-07-09 19:52:28.842  - info: host.raspberrypi stopInstance system.adapter.tado.0 send kill signal
    * 2020-07-09 19:52:28.844  - info: host.raspberrypi stopInstance system.adapter.shelly.0 send kill signal
    * 2020-07-09 19:52:28.846  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    * 2020-07-09 19:52:28.851  - info: javascript.0 (1250) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.853  - info: shelly.0 (1239) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 19:52:28.867  - info: admin.0 (643) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.867  - info: yeelight-2.0 (1206) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.868  - info: info.0 (665) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.868  - info: javascript.0 (1250) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.870  - info: trashschedule.0 (1172) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.871  - info: tado.0 (1232) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.872  - info: fullybrowser.0 (1217) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.870  - info: discovery.0 (658) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.872  - info: backitup.0 (676) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.874  - info: web.0 (1191) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.874  - info: alexa2.0 (710) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:28.877  - info: shelly.0 (1239) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 19:52:29.506  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.511  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.514  - info: host.raspberrypi instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.517  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.520  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.523  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.527  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.530  - info: host.raspberrypi instance system.adapter.yeelight-2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.533  - info: host.raspberrypi instance system.adapter.fullybrowser.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.536  - info: host.raspberrypi instance system.adapter.tado.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.539  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.647  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 19:52:29.647  - info: host.raspberrypi All instances are stopped.
    * 2020-07-09 19:52:29.781  - info: host.raspberrypi received SIGTERM
    * 2020-07-09 19:52:50.910  - info: host.raspberrypi iobroker.js-controller version 3.1.6 js-controller starting
    * 2020-07-09 19:52:50.916  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    * 2020-07-09 19:52:50.916  - info: host.raspberrypi hostname: raspberrypi, node: v12.18.2
    * 2020-07-09 19:52:50.918  - info: host.raspberrypi ip addresses: 192.168.2.133 2003:6:3150:a637:ebf1:f1a4:b7b8:28e7 fe80::64aa:a59e:c72:aaff
    * 2020-07-09 19:52:51.457  - info: host.raspberrypi connected to Objects and States
    * 2020-07-09 19:52:51.835  - info: host.raspberrypi 16 instances found
    * 2020-07-09 19:52:51.870  - info: host.raspberrypi starting 15 instances
    * 2020-07-09 19:52:51.922  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 644
    * 2020-07-09 19:52:54.219  - info: admin.0 (644) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:52:54.307  - info: admin.0 (644) requesting all states
    * 2020-07-09 19:52:54.308  - info: admin.0 (644) requesting all objects
    * 2020-07-09 19:52:55.319  - info: admin.0 (644) received all objects
    * 2020-07-09 19:52:55.538  - info: admin.0 (644) http server listening on port 8081
    * 2020-07-09 19:52:55.539  - info: admin.0 (644) Use link "http://localhost:8081" to configure.
    * 2020-07-09 19:52:55.890  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 659
    * 2020-07-09 19:53:32.266  - info: host.raspberrypi instance system.adapter.info.0 started with pid 670
    * 2020-07-09 19:53:32.900  - info: discovery.0 (659) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:53:34.698  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 689
    * 2020-07-09 19:53:36.952  - info: info.0 (670) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:53:38.740  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 785
    * 2020-07-09 19:53:42.730  - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 1093
    * 2020-07-09 19:53:43.634  - info: alexa2.0 (785) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:53:43.861  - info: alexa2.0 (785) Proxy IP not set, use first network interface (192.168.2.133) instead
    * 2020-07-09 19:53:44.105  - info: backitup.0 (689) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:53:44.223  - info: trashschedule.0 (1093) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:53:46.710  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1203
    * 2020-07-09 19:53:48.657  - info: web.0 (1203) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.web, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:53:48.772  - info: alexa2.0 (785) Alexa-Push-Connection established. Disable Polling
    * 2020-07-09 19:53:51.909  - info: host.raspberrypi instance system.adapter.yeelight-2.0 started with pid 1218
    * 2020-07-09 19:53:53.880  - info: web.0 (1203) socket.io server listening on port 8082
    * 2020-07-09 19:53:53.884  - info: web.0 (1203) http server listening on port 8082
    * 2020-07-09 19:53:54.696  - info: host.raspberrypi instance system.adapter.fullybrowser.0 started with pid 1225
    * 2020-07-09 19:53:58.507  - info: web.0 (1203) ==>Connected system.user.admin from ::ffff:192.168.2.102
    * 2020-07-09 19:54:00.146  - info: host.raspberrypi instance system.adapter.tado.0 started with pid 1236
    * 2020-07-09 19:54:06.315  - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 1243
    * 2020-07-09 19:54:06.451  - info: web.0 (1203) <==Disconnect system.user.admin from ::ffff:192.168.2.102 vis.0
    * 2020-07-09 19:54:07.135  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 1254
    * 2020-07-09 19:54:08.672  - warn: yeelight-2.0 (1218) slow connection to objects DB. Still waiting ...
    * 2020-07-09 19:54:08.704  - info: fullybrowser.0 (1225) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:54:09.645  - info: yeelight-2.0 (1218) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:54:09.661  - info: web.0 (1203) ==>Connected system.user.admin from ::ffff:192.168.2.102
    * 2020-07-09 19:54:10.850  - info: tado.0 (1236) starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.tado, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:54:11.429  - info: shelly.0 (1243) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:54:11.537  - info: tado.0 (1236) Connected to Tado cloud, initialyzing ...
    * 2020-07-09 19:54:11.470  - info: shelly.0 (1243) Starting Adapter shelly.0 in version 3.3.4
    * 2020-07-09 19:54:11.471  - info: shelly.0 (1243) Polltime of the shelly devices: 5 sec.
    * 2020-07-09 19:54:11.500  - info: shelly.0 (1243) Starting Shelly adapter in CoAP modus.
    * 2020-07-09 19:54:11.707  - info: shelly.0 (1243) Listening for Shelly packets in the network
    * 2020-07-09 19:54:12.218  - info: javascript.0 (1254) starting. Version 4.6.17 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:54:12.674  - info: shelly.0 (1243) Shelly device 192.168.2.105 (shellyplug-s / shellyplug-s-51CDC5 / SHPLG-S#51CDC5#1) with CoAP connected!
    * 2020-07-09 19:54:16.688  - info: javascript.0 (1254) requesting all states
    * 2020-07-09 19:54:16.690  - info: javascript.0 (1254) requesting all objects
    * 2020-07-09 19:54:17.046  - info: shelly.0 (1243) Shelly device 192.168.2.149 (shellyplug-s / shellyplug-s-B86382 / SHPLG-S#B86382#1) with CoAP connected!
    * 2020-07-09 19:54:17.506  - info: javascript.0 (1254) received all objects
    * 2020-07-09 19:54:17.556  - info: javascript.0 (1254) received all states
    * 2020-07-09 19:54:17.937  - warn: vis.0 (1277) slow connection to objects DB. Still waiting ...
    * 2020-07-09 19:54:18.368  - info: javascript.0 (1254) Start javascript script.js.Waschmaschine
    * 2020-07-09 19:54:18.431  - info: vis.0 (1277) starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.vis, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 19:54:18.708  - info: vis.0 (1277) vis license is OK.
    * 2020-07-09 19:54:19.225  - info: tado.0 (1236) Initialisation finished,  connected to Tado Cloud service refreshing every : 5 seconds
    * 2020-07-09 19:54:21.465  - info: shelly.0 (1243) Shelly device 192.168.2.135 (shellyplug-s / shellyplug-s-F8C0CD / SHPLG-S#F8C0CD#1) with CoAP connected!
    * 2020-07-09 19:54:21.505  - info: shelly.0 (1243) Shelly device 192.168.2.138 (shellyplug-s / shellyplug-s-8012F9 / SHPLG-S#8012F9#1) with CoAP connected!
    * 2020-07-09 19:54:21.968  - info: shelly.0 (1243) Shelly device 192.168.2.131 (shellydimmer / shellydimmer-F35CB6 / SHDM-1#F35CB6#1) with CoAP connected!
    * 2020-07-09 19:54:24.326  - info: javascript.0 (1254) script.js.Waschmaschine: registered 1 subscription and 0 schedules
    * 2020-07-09 19:54:24.405  - info: javascript.0 (1254) Start javascript script.js.Trockner
    * 2020-07-09 19:54:24.411  - info: javascript.0 (1254) script.js.Trockner: registered 1 subscription and 0 schedules
    * 2020-07-09 19:54:24.412  - info: javascript.0 (1254) Start javascript script.js.Küchen_Led_An
    * 2020-07-09 19:54:24.418  - info: javascript.0 (1254) script.js.Küchen_Led_An: registered 1 subscription and 0 schedules
    * 2020-07-09 19:54:24.419  - info: javascript.0 (1254) Start javascript script.js.Wohnzimmer_Led
    * 2020-07-09 19:54:24.425  - info: javascript.0 (1254) script.js.Wohnzimmer_Led: registered 1 subscription and 0 schedules
    * 2020-07-09 19:54:24.426  - info: javascript.0 (1254) Start javascript script.js.Tablet_Akku
    * 2020-07-09 19:54:24.430  - info: javascript.0 (1254) script.js.Tablet_Akku: registered 1 subscription and 0 schedules
    * 2020-07-09 19:54:24.431  - info: javascript.0 (1254) Start javascript script.js.Kinderzimmer_Heizung_Aus
    * 2020-07-09 19:54:24.436  - info: javascript.0 (1254) script.js.Kinderzimmer_Heizung_Aus: registered 3 subscriptions and 0 schedules
    * 2020-07-09 19:54:26.720  - info: alexa2.0 (785) Subscribing to states...
    * 2020-07-09 19:55:10.417  - info: vis.0 (1277) Terminated (NO_ERROR): Without reason
    * 2020-07-09 19:55:11.210  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    * 2020-07-09 20:17:19.940  - info: tado.0 (1236) cleaned everything up...
    * 2020-07-09 20:17:19.975  - info: trashschedule.0 (1093) cleaned everything up...
    * 2020-07-09 20:17:19.973  - info: info.0 (670) cleaned everything up...
    * 2020-07-09 20:17:19.943  - info: yeelight-2.0 (1218) cleaned everything up...
    * 2020-07-09 20:17:19.950  - info: javascript.0 (1254) Stop script script.js.Waschmaschine
    * 2020-07-09 20:17:19.954  - info: backitup.0 (689) cleaned everything up...
    * 2020-07-09 20:17:19.980  - info: web.0 (1203) terminated http server on port 8082
    * 2020-07-09 20:17:19.974  - info: admin.0 (644) terminating http server on port 8081
    * 2020-07-09 20:17:19.985  - info: javascript.0 (1254) Stop script script.js.Trockner
    * 2020-07-09 20:17:19.987  - info: javascript.0 (1254) Stop script script.js.Küchen_Led_An
    * 2020-07-09 20:17:19.988  - info: javascript.0 (1254) Stop script script.js.Wohnzimmer_Led
    * 2020-07-09 20:17:19.990  - info: javascript.0 (1254) Stop script script.js.Tablet_Akku
    * 2020-07-09 20:17:19.992  - info: javascript.0 (1254) Stop script script.js.Kinderzimmer_Heizung_Aus
    * 2020-07-09 20:17:19.998  - info: shelly.0 (1243) Closing Adapter
    * 2020-07-09 20:17:20.008  - info: host.raspberrypi received SIGTERM
    * 2020-07-09 20:17:20.048  - info: admin.0 (644) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.050  - info: discovery.0 (659) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.051  - info: info.0 (670) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.054  - info: backitup.0 (689) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.056  - info: trashschedule.0 (1093) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.056  - info: alexa2.0 (785) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.057  - info: web.0 (1203) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.059  - info: yeelight-2.0 (1218) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.060  - info: fullybrowser.0 (1225) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.063  - info: tado.0 (1236) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.065  - info: shelly.0 (1243) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.069  - info: javascript.0 (1254) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:17:20.030  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    * 2020-07-09 20:17:20.031  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
    * 2020-07-09 20:17:20.033  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=true)
    * 2020-07-09 20:17:20.034  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    * 2020-07-09 20:17:20.036  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
    * 2020-07-09 20:17:20.037  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    * 2020-07-09 20:17:20.037  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
    * 2020-07-09 20:17:20.038  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    * 2020-07-09 20:17:20.039  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    * 2020-07-09 20:17:20.039  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 (force=false, process=true)
    * 2020-07-09 20:17:20.040  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
    * 2020-07-09 20:17:20.041  - info: host.raspberrypi stopInstance system.adapter.tado.0 (force=false, process=true)
    * 2020-07-09 20:17:20.042  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=true)
    * 2020-07-09 20:17:20.042  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    * 2020-07-09 20:17:20.043  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
    * 2020-07-09 20:17:20.043  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    * 2020-07-09 20:17:20.046  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    * 2020-07-09 20:17:20.048  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
    * 2020-07-09 20:17:20.050  - info: host.raspberrypi stopInstance system.adapter.info.0 send kill signal
    * 2020-07-09 20:17:20.051  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    * 2020-07-09 20:17:20.053  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
    * 2020-07-09 20:17:20.054  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal
    * 2020-07-09 20:17:20.055  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
    * 2020-07-09 20:17:20.057  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 send kill signal
    * 2020-07-09 20:17:20.059  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 send kill signal
    * 2020-07-09 20:17:20.060  - info: host.raspberrypi stopInstance system.adapter.tado.0 send kill signal
    * 2020-07-09 20:17:20.061  - info: host.raspberrypi stopInstance system.adapter.shelly.0 send kill signal
    * 2020-07-09 20:17:20.062  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    * 2020-07-09 20:17:20.078  - info: fullybrowser.0 (1225) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.080  - info: tado.0 (1236) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.081  - info: alexa2.0 (785) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.079  - info: trashschedule.0 (1093) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.084  - info: discovery.0 (659) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.085  - info: backitup.0 (689) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.089  - info: web.0 (1203) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.092  - info: shelly.0 (1243) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.093  - info: admin.0 (644) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.092  - info: yeelight-2.0 (1218) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.095  - info: javascript.0 (1254) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.095  - info: info.0 (670) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:17:20.720  - info: host.raspberrypi instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.724  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.727  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.730  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.733  - info: host.raspberrypi instance system.adapter.yeelight-2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.736  - info: host.raspberrypi instance system.adapter.fullybrowser.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.739  - info: host.raspberrypi instance system.adapter.tado.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.746  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.750  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.754  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.757  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.799  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:17:20.800  - info: host.raspberrypi All instances are stopped.
    * 2020-07-09 20:17:20.937  - info: host.raspberrypi received SIGTERM
    * 2020-07-09 20:17:20.938  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=false)
    * 2020-07-09 20:17:20.938  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
    * 2020-07-09 20:17:20.939  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
    * 2020-07-09 20:17:20.939  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
    * 2020-07-09 20:17:20.939  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=false)
    * 2020-07-09 20:17:20.939  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=false)
    * 2020-07-09 20:17:20.939  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.tado.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=false)
    * 2020-07-09 20:17:20.940  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=false)
    * 2020-07-09 20:17:20.941  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
    * 2020-07-09 20:17:20.941  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    * 2020-07-09 20:17:22.786  - info: host.raspberrypi terminated
    * 2020-07-09 20:17:34.280  - info: host.raspberrypi iobroker.js-controller version 3.1.6 js-controller starting
    * 2020-07-09 20:17:34.285  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    * 2020-07-09 20:17:34.286  - info: host.raspberrypi hostname: raspberrypi, node: v12.18.2
    * 2020-07-09 20:17:34.288  - info: host.raspberrypi ip addresses: 192.168.2.133 2003:6:3150:a637:ebf1:f1a4:b7b8:28e7 fe80::64aa:a59e:c72:aaff
    * 2020-07-09 20:17:34.796  - info: host.raspberrypi connected to Objects and States
    * 2020-07-09 20:17:35.173  - info: host.raspberrypi 16 instances found
    * 2020-07-09 20:17:35.209  - info: host.raspberrypi starting 15 instances
    * 2020-07-09 20:17:35.261  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 638
    * 2020-07-09 20:17:37.682  - info: admin.0 (638) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:17:37.789  - info: admin.0 (638) requesting all states
    * 2020-07-09 20:17:37.790  - info: admin.0 (638) requesting all objects
    * 2020-07-09 20:17:38.817  - info: admin.0 (638) received all objects
    * 2020-07-09 20:17:39.049  - info: admin.0 (638) http server listening on port 8081
    * 2020-07-09 20:17:39.050  - info: admin.0 (638) Use link "http://localhost:8081" to configure.
    * 2020-07-09 20:17:39.235  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 661
    * 2020-07-09 20:17:42.889  - info: discovery.0 (661) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:17:43.227  - info: host.raspberrypi instance system.adapter.info.0 started with pid 676
    * 2020-07-09 20:17:47.227  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 695
    * 2020-07-09 20:17:48.311  - info: info.0 (676) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:22.013  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 861
    * 2020-07-09 20:18:28.043  - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 1165
    * 2020-07-09 20:18:28.273  - info: alexa2.0 (861) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:28.439  - info: alexa2.0 (861) Proxy IP not set, use first network interface (192.168.2.133) instead
    * 2020-07-09 20:18:36.180  - info: alexa2.0 (861) Alexa-Push-Connection established. Disable Polling
    * 2020-07-09 20:18:37.675  - info: host.raspberrypi instance system.adapter.yeelight-2.0 started with pid 1182
    * 2020-07-09 20:18:37.839  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1189
    * 2020-07-09 20:18:37.988  - info: host.raspberrypi instance system.adapter.fullybrowser.0 started with pid 1196
    * 2020-07-09 20:18:38.417  - info: trashschedule.0 (1165) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:42.014  - info: host.raspberrypi instance system.adapter.tado.0 started with pid 1211
    * 2020-07-09 20:18:42.208  - info: web.0 (1189) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.web, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:42.683  - info: web.0 (1189) socket.io server listening on port 8082
    * 2020-07-09 20:18:42.688  - info: web.0 (1189) http server listening on port 8082
    * 2020-07-09 20:18:43.522  - info: fullybrowser.0 (1196) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:43.956  - info: backitup.0 (695) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:46.007  - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 1242
    * 2020-07-09 20:18:46.300  - info: web.0 (1189) ==>Connected system.user.admin from ::ffff:192.168.2.102
    * 2020-07-09 20:18:54.906  - warn: yeelight-2.0 (1182) slow connection to objects DB. Still waiting ...
    * 2020-07-09 20:18:55.094  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 1257
    * 2020-07-09 20:18:55.238  - info: web.0 (1189) <==Disconnect system.user.admin from ::ffff:192.168.2.102 vis.0
    * 2020-07-09 20:18:56.364  - info: yeelight-2.0 (1182) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:56.595  - info: web.0 (1189) ==>Connected system.user.admin from ::ffff:192.168.2.102
    * 2020-07-09 20:18:57.342  - info: vis.0 (1258) starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.vis, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:57.635  - info: tado.0 (1211) starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.tado, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:57.659  - info: vis.0 (1258) vis license is OK.
    * 2020-07-09 20:18:59.021  - info: tado.0 (1211) Connected to Tado cloud, initialyzing ...
    * 2020-07-09 20:18:59.097  - info: shelly.0 (1242) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:18:59.146  - info: shelly.0 (1242) Starting Adapter shelly.0 in version 3.3.4
    * 2020-07-09 20:18:59.148  - info: shelly.0 (1242) Polltime of the shelly devices: 5 sec.
    * 2020-07-09 20:18:59.177  - info: shelly.0 (1242) Starting Shelly adapter in CoAP modus.
    * 2020-07-09 20:19:05.323  - info: tado.0 (1211) Initialisation finished,  connected to Tado Cloud service refreshing every : 5 seconds
    * 2020-07-09 20:19:13.485  - info: alexa2.0 (861) Subscribing to states...
    * 2020-07-09 20:19:15.923  - info: shelly.0 (1242) Listening for Shelly packets in the network
    * 2020-07-09 20:19:18.209  - info: shelly.0 (1242) Shelly device 192.168.2.149 (shellyplug-s / shellyplug-s-B86382 / SHPLG-S#B86382#1) with CoAP connected!
    * 2020-07-09 20:19:20.876  - info: javascript.0 (1257) starting. Version 4.6.17 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:19:22.376  - info: shelly.0 (1242) Shelly device 192.168.2.135 (shellyplug-s / shellyplug-s-F8C0CD / SHPLG-S#F8C0CD#1) with CoAP connected!
    * 2020-07-09 20:19:24.600  - info: javascript.0 (1257) requesting all states
    * 2020-07-09 20:19:24.603  - info: javascript.0 (1257) requesting all objects
    * 2020-07-09 20:19:24.638  - info: shelly.0 (1242) Shelly device 192.168.2.131 (shellydimmer / shellydimmer-F35CB6 / SHDM-1#F35CB6#1) with CoAP connected!
    * 2020-07-09 20:19:25.620  - info: javascript.0 (1257) received all objects
    * 2020-07-09 20:19:25.839  - info: vis.0 (1258) Terminated (NO_ERROR): Without reason
    * 2020-07-09 20:19:26.675  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    * 2020-07-09 20:19:25.655  - info: javascript.0 (1257) received all states
    * 2020-07-09 20:19:25.864  - info: javascript.0 (1257) Start javascript script.js.Waschmaschine
    * 2020-07-09 20:19:26.717  - info: javascript.0 (1257) script.js.Waschmaschine: registered 1 subscription and 0 schedules
    * 2020-07-09 20:19:26.718  - info: javascript.0 (1257) Start javascript script.js.Trockner
    * 2020-07-09 20:19:26.724  - info: javascript.0 (1257) script.js.Trockner: registered 1 subscription and 0 schedules
    * 2020-07-09 20:19:26.725  - info: javascript.0 (1257) Start javascript script.js.Küchen_Led_An
    * 2020-07-09 20:19:26.736  - info: javascript.0 (1257) script.js.Küchen_Led_An: registered 1 subscription and 0 schedules
    * 2020-07-09 20:19:26.815  - info: javascript.0 (1257) Start javascript script.js.Wohnzimmer_Led
    * 2020-07-09 20:19:26.822  - info: javascript.0 (1257) script.js.Wohnzimmer_Led: registered 1 subscription and 0 schedules
    * 2020-07-09 20:19:26.823  - info: javascript.0 (1257) Start javascript script.js.Tablet_Akku
    * 2020-07-09 20:19:26.830  - info: javascript.0 (1257) script.js.Tablet_Akku: registered 1 subscription and 0 schedules
    * 2020-07-09 20:19:26.831  - info: javascript.0 (1257) Start javascript script.js.Kinderzimmer_Heizung_Aus
    * 2020-07-09 20:19:26.838  - info: javascript.0 (1257) script.js.Kinderzimmer_Heizung_Aus: registered 3 subscriptions and 0 schedules
    * 2020-07-09 20:19:28.371  - info: shelly.0 (1242) Shelly device 192.168.2.105 (shellyplug-s / shellyplug-s-51CDC5 / SHPLG-S#51CDC5#1) with CoAP connected!
    * 2020-07-09 20:19:30.470  - info: shelly.0 (1242) Shelly device 192.168.2.138 (shellyplug-s / shellyplug-s-8012F9 / SHPLG-S#8012F9#1) with CoAP connected!
    * 2020-07-09 20:42:06.303  - info: info.0 (676) cleaned everything up...
    * 2020-07-09 20:42:06.317  - info: host.raspberrypi received SIGTERM
    * 2020-07-09 20:42:06.319  - info: yeelight-2.0 (1182) cleaned everything up...
    * 2020-07-09 20:42:06.317  - info: web.0 (1189) terminated http server on port 8082
    * 2020-07-09 20:42:06.327  - info: shelly.0 (1242) Closing Adapter
    * 2020-07-09 20:42:06.349  - info: tado.0 (1211) cleaned everything up...
    * 2020-07-09 20:42:06.351  - info: javascript.0 (1257) Stop script script.js.Waschmaschine
    * 2020-07-09 20:42:06.376  - info: discovery.0 (661) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.312  - info: trashschedule.0 (1165) cleaned everything up...
    * 2020-07-09 20:42:06.379  - info: info.0 (676) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.382  - info: backitup.0 (695) cleaned everything up...
    * 2020-07-09 20:42:06.345  - info: admin.0 (638) terminating http server on port 8081
    * 2020-07-09 20:42:06.391  - info: alexa2.0 (861) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.368  - info: javascript.0 (1257) Stop script script.js.Trockner
    * 2020-07-09 20:42:06.370  - info: javascript.0 (1257) Stop script script.js.Küchen_Led_An
    * 2020-07-09 20:42:06.372  - info: javascript.0 (1257) Stop script script.js.Wohnzimmer_Led
    * 2020-07-09 20:42:06.374  - info: javascript.0 (1257) Stop script script.js.Tablet_Akku
    * 2020-07-09 20:42:06.384  - info: javascript.0 (1257) Stop script script.js.Kinderzimmer_Heizung_Aus
    * 2020-07-09 20:42:06.390  - info: backitup.0 (695) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.394  - info: trashschedule.0 (1165) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.396  - info: web.0 (1189) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.396  - info: admin.0 (638) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.398  - info: yeelight-2.0 (1182) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.399  - info: fullybrowser.0 (1196) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.403  - info: tado.0 (1211) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.406  - info: shelly.0 (1242) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.343  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    * 2020-07-09 20:42:06.344  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
    * 2020-07-09 20:42:06.346  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=true)
    * 2020-07-09 20:42:06.347  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    * 2020-07-09 20:42:06.348  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
    * 2020-07-09 20:42:06.349  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    * 2020-07-09 20:42:06.351  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
    * 2020-07-09 20:42:06.352  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    * 2020-07-09 20:42:06.353  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    * 2020-07-09 20:42:06.353  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 (force=false, process=true)
    * 2020-07-09 20:42:06.354  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
    * 2020-07-09 20:42:06.355  - info: host.raspberrypi stopInstance system.adapter.tado.0 (force=false, process=true)
    * 2020-07-09 20:42:06.358  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=true)
    * 2020-07-09 20:42:06.359  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    * 2020-07-09 20:42:06.360  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
    * 2020-07-09 20:42:06.366  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    * 2020-07-09 20:42:06.369  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    * 2020-07-09 20:42:06.372  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
    * 2020-07-09 20:42:06.376  - info: host.raspberrypi stopInstance system.adapter.info.0 send kill signal
    * 2020-07-09 20:42:06.385  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    * 2020-07-09 20:42:06.387  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
    * 2020-07-09 20:42:06.391  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal
    * 2020-07-09 20:42:06.394  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
    * 2020-07-09 20:42:06.396  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 send kill signal
    * 2020-07-09 20:42:06.398  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 send kill signal
    * 2020-07-09 20:42:06.399  - info: host.raspberrypi stopInstance system.adapter.tado.0 send kill signal
    * 2020-07-09 20:42:06.401  - info: host.raspberrypi stopInstance system.adapter.shelly.0 send kill signal
    * 2020-07-09 20:42:06.404  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    * 2020-07-09 20:42:06.409  - info: javascript.0 (1257) Got terminate signal TERMINATE_YOURSELF
    * 2020-07-09 20:42:06.415  - info: trashschedule.0 (1165) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.420  - info: web.0 (1189) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.424  - info: yeelight-2.0 (1182) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.417  - info: discovery.0 (661) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.427  - info: shelly.0 (1242) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.429  - info: admin.0 (638) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.417  - info: alexa2.0 (861) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.425  - info: fullybrowser.0 (1196) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.429  - info: info.0 (676) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.434  - info: backitup.0 (695) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.438  - info: tado.0 (1211) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.438  - info: javascript.0 (1257) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    * 2020-07-09 20:42:06.990  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.059  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.063  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.066  - info: host.raspberrypi instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.069  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.072  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.075  - info: host.raspberrypi instance system.adapter.yeelight-2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.078  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.081  - info: host.raspberrypi instance system.adapter.fullybrowser.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.084  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.099  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    * 2020-07-09 20:42:07.294  - info: host.raspberrypi received SIGTERM
    * 2020-07-09 20:42:07.294  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=false)
    * 2020-07-09 20:42:07.294  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
    * 2020-07-09 20:42:07.295  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
    * 2020-07-09 20:42:07.295  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
    * 2020-07-09 20:42:07.295  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=false)
    * 2020-07-09 20:42:07.295  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=false)
    * 2020-07-09 20:42:07.296  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
    * 2020-07-09 20:42:07.296  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    * 2020-07-09 20:42:07.296  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    * 2020-07-09 20:42:07.296  - info: host.raspberrypi stopInstance system.adapter.yeelight-2.0 (force=false, process=false)
    * 2020-07-09 20:42:07.297  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=false)
    * 2020-07-09 20:42:07.297  - info: host.raspberrypi stopInstance system.adapter.tado.0 (force=false, process=true)
    * 2020-07-09 20:42:07.297  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=false)
    * 2020-07-09 20:42:07.297  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=false)
    * 2020-07-09 20:42:07.298  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
    * 2020-07-09 20:42:07.298  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    * 2020-07-09 20:42:07.298  - info: host.raspberrypi stopInstance system.adapter.tado.0 send kill signal
    * 2020-07-09 20:42:07.308  - warn: host.raspberrypi instance system.adapter.tado.0 terminated due to SIGTERM
    * 2020-07-09 20:42:07.309  - info: host.raspberrypi instance system.adapter.tado.0 terminated with code null ()
    * 2020-07-09 20:42:07.309  - info: host.raspberrypi All instances are stopped.
    * 2020-07-09 20:42:07.625  - info: host.raspberrypi terminated
    * 2020-07-09 20:42:07.677  - info: host.raspberrypi terminated
    * 2020-07-09 20:42:23.391  - info: host.raspberrypi iobroker.js-controller version 3.1.6 js-controller starting
    * 2020-07-09 20:42:23.396  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    * 2020-07-09 20:42:23.397  - info: host.raspberrypi hostname: raspberrypi, node: v12.18.2
    * 2020-07-09 20:42:23.399  - info: host.raspberrypi ip addresses: 192.168.2.133 2003:6:3150:a637:ebf1:f1a4:b7b8:28e7 fe80::64aa:a59e:c72:aaff
    * 2020-07-09 20:42:23.946  - info: host.raspberrypi connected to Objects and States
    * 2020-07-09 20:42:24.324  - info: host.raspberrypi 16 instances found
    * 2020-07-09 20:42:24.358  - info: host.raspberrypi starting 15 instances
    * 2020-07-09 20:42:24.410  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 634
    * 2020-07-09 20:42:26.813  - info: admin.0 (634) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:42:26.895  - info: admin.0 (634) requesting all states
    * 2020-07-09 20:42:26.896  - info: admin.0 (634) requesting all objects
    * 2020-07-09 20:42:27.906  - info: admin.0 (634) received all objects
    * 2020-07-09 20:42:28.378  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 657
    * 2020-07-09 20:42:28.116  - info: admin.0 (634) http server listening on port 8081
    * 2020-07-09 20:42:28.117  - info: admin.0 (634) Use link "http://localhost:8081" to configure.
    * 2020-07-09 20:42:35.102  - info: host.raspberrypi instance system.adapter.info.0 started with pid 668
    * 2020-07-09 20:42:35.840  - info: discovery.0 (657) starting. Version 2.3.7 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:42:36.376  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 687
    * 2020-07-09 20:43:08.698  - info: info.0 (668) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.info, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:43:10.422  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 1021
    * 2020-07-09 20:43:11.258  - info: backitup.0 (687) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:43:14.179  - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 1163
    * 2020-07-09 20:43:17.709  - info: alexa2.0 (1021) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:43:17.933  - info: alexa2.0 (1021) Proxy IP not set, use first network interface (192.168.2.133) instead
    * 2020-07-09 20:43:18.063  - info: trashschedule.0 (1163) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.18.2, js-controller: 3.1.6
    * 2020-07-09 20:43:18.179  - info: host.raspberrypi instance system.adapter
    Top
    Tasks: 126 total,   1 running, 125 sleeping,   0 stopped,   0 zombie
    %Cpu0  :  2.6 us,  2.3 sy,  0.0 ni, 95.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    %Cpu1  :  4.7 us,  2.3 sy,  0.0 ni, 93.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    %Cpu2  :  0.0 us,  1.3 sy,  0.0 ni, 98.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    %Cpu3  :  1.7 us,  1.3 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3827.9 total,   3041.5 free,    561.8 used,    224.7 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3293.7 avail Mem
    1238 iobroker  20   0  171948  84948  27456 S   7.9   2.2   1:11.26 node
      610 iobroker  20   0  186340 100048  27448 S   5.6   2.6   1:20.07 node
     1246 iobroker  20   0  195652 103592  27456 S   2.3   2.6   0:23.50 node
        7 root      20   0       0      0      0 I   1.0   0.0   0:02.79 kworker/u+
     1154 iobroker  20   0  153880  61572  27980 S   0.7   1.6   0:09.28 node
     1209 iobroker  20   0  147296  51580  27348 S   0.7   1.3   0:04.86 node
       14 root      rt   0       0      0      0 S   0.3   0.0   0:00.74 migration+
       19 root      rt   0       0      0      0 S   0.3   0.0   0:00.64 migration+
       24 root      rt   0       0      0      0 S   0.3   0.0   0:00.56 migration+
      113 root      20   0   21240   7080   6248 S   0.3   0.2   0:00.70 systemd-j+
      639 iobroker  20   0  166228  81496  28876 S   0.3   2.1   0:34.29 node
      673 iobroker  20   0  150864  58600  27996 S   0.3   1.5   0:05.50 node
      692 iobroker  20   0  170336  81800  28332 S   0.3   2.1   0:06.96 node
     1174 iobroker  20   0  156988  62632  27780 S   0.3   1.6   0:05.65 node
     6020 root      20   0       0      0      0 I   0.3   0.0   0:00.32 kworker/0+
     6751 pi        20   0   10188   2884   2524 R   0.3   0.1   0:00.09 top
        1 root      20   0   33724   7908   6372 S   0.0   0.2   0:03.38 systemd
    Platform: linux
    os: linux
    Architecture: arm
    CPUs: 4
    Speed: 600 MHz
    Model: ARMv7 Processor rev 3 (v7l)
    RAM: 3.7 GB
    System uptime: 00:12:31
    Node.js: v12.18.2
    Disk size: 13.9 GiB
    Disk free: 11.2 GiB
    adapters count: 355
    NPM: v6.14.6
    Uptime: 00:12:37
    Active instances: 12
    @canim Pack den Text bitte in CodeTags. </>
    • C Offline
      canim
      sorry :)
      • arteckA Offline
        arteckA Offline
        arteck
        kann sein das dein iobroker mehrere male läuft..
        mach ein
        pkill io
        so lange bist du keine ionroker mehr im top siehst
        C 1 Antwort Letzte Antwort
        • arteckA arteck
          mach ein
          pkill io
          canim
          schrieb am zuletzt editiert von canim
          @arteck Iobroker sind die unterschiedlichen instanzen,
            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
           3780 iobroker  20   0  150156  46940  26308 S  28.6   1.2   0:05.94 io.tado.0
           3168 iobroker  20   0  177292  91372  25320 S  20.9   2.3   0:21.59 iobroker.+
           3820 iobroker  20   0  200648  92420  25424 S  10.6   2.4   0:06.34 io.javasc+
           3735 iobroker  20   0  159336  57056  25732 S  10.0   1.5   0:08.43 io.web.0
           3795 iobroker  20   0  152720  65256  25408 S   3.3   1.7   0:04.34 io.shelly+
            481 root      20   0       0      0      0 I   2.7   0.0   0:03.84 kworker/u+
           3187 iobroker  20   0  170916  65132  26728 S   2.3   1.7   0:06.82 io.admin.0
             15 root      20   0       0      0      0 S   0.7   0.0   0:00.29 ksoftirqd+
             90 root       0 -20       0      0      0 I   0.7   0.0   0:00.47 kworker/1+
            225 root      20   0       0      0      0 I   0.7   0.0   0:02.46 kworker/0+
           3217 iobroker  20   0  151756  60832  26320 S   0.7   1.6   0:03.07 io.info.0
              9 root      20   0       0      0      0 S   0.3   0.0   0:00.45 ksoftirqd+
             30 root      20   0       0      0      0 I   0.3   0.0   0:02.75 kworker/0+
             55 root      20   0       0      0      0 I   0.3   0.0   0:00.16 kworker/3+
           3176 pi        20   0   10188   2876   2516 R   0.3   0.1   0:00.28 top
           3705 iobroker  20   0  154240  51956  26296 S   0.3   1.3   0:07.23 io.alexa2+
              1 root      20   0   32700   7928   6412 S   0.0   0.2   0:03.36 systemd
          ist beim kopieren nicht mitgekommen. da bringt glaub ich nichts mit pkill io
          bin jetzt von node 12 auf 10 runtergegangen ob das problem weg ist. hatte vorher 10 drauf gehabt da lief der iobroker locker über 10 tage Betriebszeit
          • C canim
            @canim
            Bist du sicher, dass node sauber installiert ist?
            Hau uns mal das im die Ohren:
            which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            • C Offline
              canim
              v10.21.0
              /usr/bin/node
              v10.21.0
              /usr/bin/npm
              6.14.4
              nodejs:
                Installed: 10.21.0-1nodesource1
                Candidate: 10.21.0-1nodesource1
                Version table:
               *** 10.21.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                   10.21.0~dfsg-1~deb10u1+rpi1 500
              > v10.21.0
              Thrown:
              v10.21.0
              SyntaxError: Unexpected number
              > /usr/bin/node
              Thrown:
              /usr/bin/node
              SyntaxError: Invalid regular expression flags
              > v10.21.0
              Thrown:
              v10.21.0
              > /usr/bin/npm
              Thrown:
              /usr/bin/npm
              > 6.14.4
              Thrown:
              6.14.4
              > nodejs:
              ...   Installed: 10.21.0-1nodesource1
              Thrown:
              Thrown:
              >   Version table:
              Thrown:
                Version table:
              SyntaxError: Unexpected identifier
              Thrown:
              SyntaxError: Unexpected token **
              Thrown:
              Thrown:
              SyntaxError: Unexpected token var
              Thrown:
              >         500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Package                                 s
              Thrown:
              • C canim
                v10.21.0
                /usr/bin/node
                v10.21.0
                /usr/bin/npm
                6.14.4
                nodejs:
                  Version table:
                > v10.21.0
                Thrown:
                v10.21.0
                > /usr/bin/node
                Thrown:
                /usr/bin/node
                > v10.21.0
                Thrown:
                v10.21.0
                > /usr/bin/npm
                Thrown:
                /usr/bin/npm
                > 6.14.4
                Thrown:
                6.14.4
                > nodejs:
                Thrown:
                Thrown:
                >   Version table:
                Thrown:
                  Version table:
                Thrown:
                Thrown:
                Thrown:
                Thrown:
                Thrown:
                @canim
                Eigentlich passt das soweit, allerdings sind die Meldungen mit Thrown mehr als ungewöhnlich. Zeig mal die komplette Ein- und Ausgabe. Da stimmt doch irgendwas nicht.
                  @canim
                  canim
                  @Thomas-Braun was meinst du genau mit Ein und Ausgabe? Danke für die schnelle Antwort
                  • C canim
                    @canim Die komplette Eingabe inkl Login prompt.
                    Ungefähr so:
                    pi@raspberrypi:~$ node -v
                    v14.5.0
                    pi@raspberrypi:~$
                      Ungefähr so:
                      v14.5.0
                      pi@raspberrypi:~$
                      canim
                      @Thomas-Braun
                      > Linux raspberrypi 5.4.50-v7l+ #1324 SMP Wed Jul 1 17:06:14 BST 2020 armv7l
                      > The programs included with the Debian GNU/Linux system are free software;
                      > the exact distribution terms for each program are described in the
                      > individual files in /usr/share/doc/*/copyright.
                      > Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      > permitted by applicable law.
                      > Last login: Sat Jul 11 23:51:28 2020 from 192.168.2.100
                      > pi@raspberrypi:~ $ node -v
                      > v10.21.0
                      > pi@raspberrypi:~ $
                      • C canim
                        @Thomas-Braun
                        > v10.21.0
                        > pi@raspberrypi:~ $
                        @canim Was hast du denn da für 'nen komischen Kernel drin? Mal mit rpi-update rumgemacht?
                        Installier den stable kernel.
                        • C Offline
                          canim
                          puh , kann ich dir so jetzt nicht, könnte möglich sein. Bin jetzt gut seit ca 1 Monat Aktiv mit Linux beschäftigt, und einiges über Anleitung gemacht. Vorkenntnisse sind da, kannst mir eben schnell sagen wie ich auf ein Stable Kern komme? "Befehl."
                          • C canim
                            @canim Ganz ehrlich: DAS sollte man schon wissen.
                            Und mit einem Monat 'Erfahrung' haut man sich keinen bleeding-edge-Kram auf das System!
                            Versuch mal so wieder in stable reinzukommen:
                            sudo apt update
                            sudo apt install --reinstall raspberrypi-bootloader raspberrypi-kernel
                            sudo reboot
                            Kann aber auch in die Hose gehen. Aber als bleeding-edger ist das ja kein Problem für dich
                            • C Offline
                              canim
                              Super Danke ,lass ich gerade laufen
                              • C canim
                                @canim Wenn die Kiste wieder hochgekommen ist:
                                uname -a
                                Da sollte dann ein 4er-Kernel gemeldet werden:
                                pi@raspberrypi:~$ uname -a
                                Linux raspberrypi 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
                                Und dann lässt du die Finger von rpi-update!
                                  uname -a
                                  canim
                                  @Thomas-Braun alles klar danke :), jetzt ist mir was peinliches aufgefallen...
                                  Hab den Übeltäter gefunden, der alle 15 min mein Pi neustartet ....
                                  Das war der Watchdog der Aktiv bzw aktiv gestellt hatte, lief eine Zeitlang gut mit dem Wert aber jetzt nicht mehr, hab den jetzt Deaktiv ,siehe da der Controller ist seit gestern wieder Aktiv
