  3. Entwicklung
  4. [gelöst] npm registry umstellen
    5.5k
npmregistrynexusjavaskript adapter
22 Beiträge 2 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • smartmetaS Offline
    smartmetaS Offline
    smartmeta
    schrieb am zuletzt editiert von smartmeta
    Hi @AlCalzone,
    okay
    npm i oho-iobroker-tools@latest
    und Adapter neu starten habe ich gemacht. Leider keine Verbesserung.
    Ich habe den Adapter jetzt mal mit Chrome remote gedebuggt.
    Die Types werden auch laut log richtig geladen
    2020-07-02 15:27:56.404  - debug: javascript.0 (9826) Loaded TypeScript definitions for node: ["@types/node/index.d.ts","@types/node/base.d.ts","@types/node/globals.global.d.ts","@types/node/assert.d.ts","@types/node/globals.d.ts","@types/node/async_hooks.d.ts","@types/node/buffer.d.ts","@types/node/child_process.d.ts","@types/node/cluster.d.ts","@types/node/console.d.ts","@types/node/constants.d.ts","@types/node/crypto.d.ts","@types/node/dgram.d.ts","@types/node/dns.d.ts","@types/node/domain.d.ts","@types/node/events.d.ts","@types/node/fs.d.ts","@types/node/http.d.ts","@types/node/http2.d.ts","@types/node/https.d.ts","@types/node/inspector.d.ts","@types/node/module.d.ts","@types/node/net.d.ts","@types/node/os.d.ts","@types/node/path.d.ts","@types/node/perf_hooks.d.ts","@types/node/process.d.ts","@types/node/punycode.d.ts","@types/node/querystring.d.ts","@types/node/readline.d.ts","@types/node/repl.d.ts","@types/node/stream.d.ts","@types/node/string_decoder.d.ts","@types/node/timers.d.ts","@types/node/tls.d.ts","@types/node/trace_events.d.ts","@types/node/tty.d.ts","@types/node/url.d.ts","@types/node/util.d.ts","@types/node/v8.d.ts","@types/node/vm.d.ts","@types/node/worker_threads.d.ts","@types/node/zlib.d.ts"]
    2020-07-02 15:29:06.080  - debug: javascript.0 (9826) Loaded TypeScript definitions for request: []
    2020-07-02 15:30:22.450  - debug: javascript.0 (9826) Loaded TypeScript definitions for oho-iobroker-tools: ["@types/oho-iobroker-tools/lib/index.d.ts"]
    2020-07-02 15:31:05.172  - info: javascript.0 (9826) requesting all states
    Trotzdem kann ich das Modul nicht in den Scripten nutzen:
    Das Modul habe ich auch schon auf das nötigste reduziert um Fehler auszuschliessen (naja die test.js könnte ich auch noch löschen):
    Zusätzlich habe ich noch mal ein neues Node-Projekt erstellt, in dem genau der Code (wie im Script) verwendet wird:
    import {A} from 'oho-iobroker-tools';
    const a = new A();
    console.log (a.add(1,2));
    Da klappt das wunderbar.
    Wo muss ich den Breakpoint setzen,
    damit ich mit
    iobroker stop iobroker.javascript
    >The adapter "javascript.0" was stopped.
    node --inspect-brk=0.0.0.0:9229 node_modules/iobroker.javascript/main.js --debug
    das Ausführen meine Sciptes MODULEX im Javascript-Adapter debuggen kann?
    • smartmetaS smartmeta
      Hi @AlCalzone,
      okay
      const a = new A();
      damit ich mit
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @smartmeta das @types vor dem modulnamen erscheint mir in deinem Fall falsch. Dein Modul bringt ja die Typen mit. Müsste ich mir mal anschauen. Gibt es das auf npm?
      smartmetaS 1 Antwort Letzte Antwort
      • AlCalzoneA AlCalzone
        smartmetaS Offline
        smartmetaS Offline
        smartmeta
        @AlCalzone
        Nein, das gibt es nicht auf NPM. Ich habe leider nicht genug Zeit um ein Modul auf NPM dauerhaft zu betreuen.
        Habs dir hier mal angehangen:
        oho-iobroker-tools-1.0.4.tgz
          @AlCalzone
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @smartmeta Fix ist hier:
          https://github.com/ioBroker/ioBroker.javascript/pull/610
          Du kannst ihn testen, indem du den Adapter von der URL https://github.com/AlCalzone/ioBroker.javascript/tarball/types-resolve-fixes installierst.
            smartmetaS Offline
            smartmeta
            @AlCalzone sagte in npm registry umstellen:
            Hi @AlCalzone,
            vielen Dank schon mal für den PR. Sehr cool, dass du mir hilfst.
            Ich habe
             "iobroker.javascript": "https://github.com/AlCalzone/ioBroker.javascript/tarball/types-resolve-fixes",
            in die package.json eingetragen und
            sudo -u iobroker  npm i
            aufgerufen. Bekomme nun
            │ Manual installation of ioBroker is no longer supported  │
            │ on Linux, OSX and FreeBSD!                              │
            │ Please refer to the documentation on how to install it! │
            │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
            Wie ist denn der vorgesehene Weg für das manuelle Nachinstallieren von Adaptern?
            Denn in der Doku habe ich leider auch nichts dazu gefunden.
              Hi @AlCalzone,
              Ich habe
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @smartmeta package.json solltest du nur im absoluten Notfall bearbeiten, z.B. um eine kaputte Datei zu korrigieren.
              Du suchst das hier: https://www.iobroker.net/#de/documentation/tutorial/adapter.md, was übrigens der 1. Link in dem von dir gefundenen Artikel war 🙈
              Entweder du installierst den Adapter direkt per npm:
              cd /opt/iobroker
              npm i https://github.com/AlCalzone/ioBroker.javascript/tarball/types-resolve-fixes
              Benutzerwechsel ist hier nicht nötig, das passiert automatisch.
              Oder (bevorzugt) über den Admin:
                cd /opt/iobroker
                smartmetaS Offline
                smartmetaS Offline
                smartmeta
                @AlCalzone
                der erste Link in dem von mir gefunden Dokument (Update eines Adapters) ist leider nicht verlinkt.
                Aber der Link https://www.iobroker.net/#de/documentation/tutorial/adapter.md ist gut. Danke!
                Installation über
                probiere ich später aus.
                  smartmetaS Offline
                  smartmeta
                  @AlCalzone
                  Okay, eingetragen und der Adapter ist neu geladen.
                  Zur Sicherheit auch noch mal nachgesehen, dass deine Änderung in
                  /lib/typescriptTools.js
                  auch drin ist. Alles okay.
                  Dann zur Sicherheit noch mal
                  iobroker stop
                  iobroker start
                  Leider funktioniert das TS-Modul noch immer nicht.
                  Ich versuche das am Wochenende mal zu debuggen.
                    smartmetaS Offline
                    smartmeta
                    Hi @AlCalzone,
                    da mein Typescript ModulX bei mir noch immer nicht läuft, bin ich noch mal einen Schritt zurück gegangen.
                    Ich versuche jetzt das Modul oho-iobroker-tools in einer reinen Javascript Umgebung.
                    Zuerst ein Test in PHPStorm ganz ohne iobroker:
                    Nun den gleichen Code
                    var oho_iobroker_tools_1 = require("oho-iobroker-tools");
                    var a = new oho_iobroker_tools_1.A();
                    console.log(a.add(1, 20));
                    im Javascript-Adapter :
                    Wie auch in der Typescript-Variante wird die Klasse A nicht gefunden.
                    Kannst du noch mal bitte schauen, ob das bei dir klappt. Vielleicht mache ich ja nur etwas ganz banales falsch.
                      Hi @AlCalzone,
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @smartmeta Installier bitte nochmal die neueste Version aus dem Branch:
                        smartmetaS Offline
                        smartmeta
                        @AlCalzone
                        vielen Dank, sehr cool.
                        Mit deinem Branch funktioniert es jetzt sowohl im Javascript als auch im Typescript.
                          smartmetaS Offline
                          smartmeta
                          @AlCalzone
                          Nur aus Neugier: Wann kommen die Änderungen in den Master?
                            @AlCalzone
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @smartmeta Der PR ist jetzt germerged. Wann released wird, ist in Klärung.
                              smartmetaS Offline
                              smartmeta
                              @AlCalzone okay, danke.
