  4. lupusec Adapter Fehler
iobrokerlupusec
135 Beiträge 13 Kommentatoren 26.3k Aufrufe 10 Beobachtet
    anno171986
    @Stuebi
    Habe danach den Haken weg gemacht und auf Speichern und beenden geklickt. Da ist der Adapter aber nicht richtig gestartet. Habe dann nochmal manuell den Adapter neugestartet:
    lupusec.0	2020-07-03 10:15:25.141	error	(23091) Lupusec Alarmsystem 192.168.178.34 is not reachable
    lupusec.0	2020-07-03 10:15:25.056	info	(23091) Starting Adapter lupusec.0 in version 1.2.8
    lupusec.0	2020-07-03 10:15:25.007	info	(23091) starting. Version 1.2.8 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
    host.raspberrypi	2020-07-03 10:15:21.376	info	instance system.adapter.lupusec.0 started with pid 23091
    host.raspberrypi	2020-07-03 10:15:03.516	info	Restart adapter system.adapter.lupusec.0 because enabled
    host.raspberrypi	2020-07-03 10:15:03.513	info	instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
    lupusec.0	2020-07-03 10:15:02.962	info	(23075) Terminated (NO_ERROR): Without reason
    lupusec.0	2020-07-03 10:15:02.960	info	(23075) terminating
    lupusec.0	2020-07-03 10:15:02.942	warn	(23075) Restart initiated
    lupusec.0	2020-07-03 10:15:02.940	info	(23075) Restarting Adapter because of changeing Sentry settings
    lupusec.0	2020-07-03 10:15:02.878	info	(23075) Starting Adapter lupusec.0 in version 1.2.8
    lupusec.0	2020-07-03 10:15:02.834	info	(23075) starting. Version 1.2.8 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
    lupusec.0	2020-07-03 10:15:02.803	info	(23075) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    host.raspberrypi	2020-07-03 10:14:59.233	info	instance system.adapter.lupusec.0 started with pid 23075
    host.raspberrypi	2020-07-03 10:14:56.783	info	instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    lupusec.0	2020-07-03 10:14:56.228	info	(23057) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    lupusec.0	2020-07-03 10:14:56.224	info	(23057) terminating
    lupusec.0	2020-07-03 10:14:56.221	info	(23057) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2020-07-03 10:14:56.211	info	stopInstance system.adapter.lupusec.0 send kill signal
    host.raspberrypi	2020-07-03 10:14:56.209	info	stopInstance system.adapter.lupusec.0 (force=false, process=true)
    Ergebnis laut Log das Selbe und auch unter Objekte tauchen nur 2 von circa 20 Geräten auf.
    StuebiS 1 Antwort Letzte Antwort
    • A anno171986
      @Stuebi
      StuebiS Offline
      StuebiS Offline
      Stuebi
      @anno171986 , beendet sich der Adapter und startet neu? Wird dieser unter Instanzen rot angezeigt? Welche 2 Geräte werden angezeigt?
      ioBroker auf Synology DS216+II im Docker Container
      • StuebiS Stuebi
        anno171986
        @Stuebi nein, trotz der Fehlermeldung startet er nicht neu und unter Adapter ist er grün.
        Ein Pad und ein BWM, aber die Werte aktualisiert er nicht.
          anno171986
          @Stuebi Hier noch zwei Screenshots. Hat sich auch über den ganzen Tag nichts geändert. Musste man die Objekte per Hand in ioBroker hinzufügen, oder sind die automatisch da, sobald die Verbindung zwischen ioBroker und lupusec Alarmanlage besteht? Bin mir da nicht mehr sicher wie das war 😕
          • A anno171986
            StuebiS Offline
            StuebiS Offline
            Stuebi
            @anno171986 , man muss keine Objekte manuell anlegen. Was mich wundert ist, das 2 Objekte angelegt werden und dann der Adapter abbricht.
            Hast du ein Firmware Update bei der Alarmanlage gerade vorgenommen?
            • StuebiS Stuebi
              anno171986
              @Stuebi
              Soll ich den Adapter Mal deinstallieren? Ich habe das schon einmal gemacht, aber da war irgendwie nur die Instanz weg, aber nicht der Adapter. Wie geht man denn vor, wenn man einen Adapter komplett deinstallieren möchte.
              Nein, habe nichts an der Alarmanlage aktualisiert.
              • A anno171986
                @Stuebi
                StuebiS Offline
                StuebiS Offline
                Stuebi
                @anno171986, um den Fehler einzugrenzen habe ich noch ein Änderung vorgenommen. Bitte lade die Version 1.2.9 von GitHub. Wie das geht steht hier. Was steht jetzt im Logfile wenn Du den Adapter neu startest?
                • StuebiS Stuebi
                  anno171986
                  @Stuebi Habe 1.2.9 installiert.
                  Jetzt wird die Instanz auch nicht mehr grün.
                  hier das Log:
                  host.raspberrypi	2020-07-04 14:01:05.212	info	Do not restart adapter system.adapter.lupusec.0 because desired by instance
                  host.raspberrypi	2020-07-04 14:01:05.209	error	instance system.adapter.lupusec.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                  lupusec.0	2020-07-04 14:01:04.657	info	(26195) Terminated (ADAPTER_REQUESTED_TERMINATION): Not reachable
                  lupusec.0	2020-07-04 14:01:04.653	error	(26195) Lupusec Alarmsystem 192.168.178.34 is not reachable
                  lupusec.0	2020-07-04 14:01:04.586	info	(26195) Starting Adapter lupusec.0 in version 1.2.9
                  lupusec.0	2020-07-04 14:01:04.542	info	(26195) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
                  lupusec.0	2020-07-04 14:01:04.515	info	(26195) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  host.raspberrypi	2020-07-04 14:01:01.017	info	instance system.adapter.lupusec.0 started with pid 26195
                  host.raspberrypi	2020-07-04 14:00:58.335	info	Restart adapter system.adapter.lupusec.0 because enabled
                  host.raspberrypi	2020-07-04 14:00:58.333	info	instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                  lupusec.0	2020-07-04 14:00:57.794	info	(26180) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  lupusec.0	2020-07-04 14:00:57.783	info	(26180) Terminated (NO_ERROR): Without reason
                  lupusec.0	2020-07-04 14:00:57.780	info	(26180) terminating
                  lupusec.0	2020-07-04 14:00:57.747	warn	(26180) Restart initiated
                  lupusec.0	2020-07-04 14:00:57.745	info	(26180) Restarting Adapter because of changeing Sentry settings
                  lupusec.0	2020-07-04 14:00:57.637	info	(26180) Starting Adapter lupusec.0 in version 1.2.9
                  lupusec.0	2020-07-04 14:00:57.592	info	(26180) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
                  host.raspberrypi	2020-07-04 14:00:53.864	info	instance system.adapter.lupusec.0 started with pid 26180
                  host.raspberrypi	2020-07-04 14:00:51.948	info	Do not restart adapter system.adapter.lupusec.0 because desired by instance
                  host.raspberrypi	2020-07-04 14:00:51.946	error	instance system.adapter.lupusec.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                  Einstellungen:
                  IP: 192.168.178.34
                  Port: 443
                  HTTPS aktiviert
                  Weiterleiten von Fehlern aktiviert
                  192.168.178.34 ist vom Browser erreichbar.
                  • A anno171986
                    hier das Log:
                    Einstellungen:
                    IP: 192.168.178.34
                    Port: 443
                    HTTPS aktiviert
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    @anno171986 sagte in lupusec Adapter Fehler:
                    Der Lupusec Adapter schickt einen Ping an die Alarmanlage. Dieser schlägt aber leider fehl und der Adapter beendet sich. Ich könnte mir vorstellen, es liegt an den Berechtigungen.
                    Ich habe jetzt nochmals eine Änderung vorgenommen. Bitte lade nochmals die Version 1.2.9 per GitHub runter und starte die Instanz neu. Was steht jetzt im Logfile?
                    • StuebiS Stuebi
                      anno171986
                      @Stuebi
                      Anbei das Log:
                      host.raspberrypi	2020-07-04 16:54:11.034	info	Do not restart adapter system.adapter.lupusec.0 because desired by instance
                      host.raspberrypi	2020-07-04 16:54:11.033	error	instance system.adapter.lupusec.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                      lupusec.0	2020-07-04 16:54:10.499	info	(26556) Terminated (ADAPTER_REQUESTED_TERMINATION): Not reachable
                      lupusec.0	2020-07-04 16:54:10.495	error	(26556) Lupusec Alarmsystem 192.168.178.34 is not reachable
                      lupusec.0	2020-07-04 16:54:10.416	info	(26556) Starting Adapter lupusec.0 in version 1.2.9
                      lupusec.0	2020-07-04 16:54:10.367	info	(26556) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
                      lupusec.0	2020-07-04 16:54:10.334	info	(26556) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      host.raspberrypi	2020-07-04 16:54:06.903	info	instance system.adapter.lupusec.0 started with pid 26556
                      host.raspberrypi	2020-07-04 16:52:54.739	info	Do not restart adapter system.adapter.lupusec.0 because desired by instance
                      host.raspberrypi	2020-07-04 16:52:54.738	error	instance system.adapter.lupusec.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                      lupusec.0	2020-07-04 16:52:54.183	info	(26536) Terminated (ADAPTER_REQUESTED_TERMINATION): Not reachable
                      lupusec.0	2020-07-04 16:52:54.179	error	(26536) Lupusec Alarmsystem 192.168.178.34 is not reachable
                      lupusec.0	2020-07-04 16:52:54.102	info	(26536) Starting Adapter lupusec.0 in version 1.2.9
                      lupusec.0	2020-07-04 16:52:54.037	info	(26536) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
                      lupusec.0	2020-07-04 16:52:53.989	info	(26536) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      host.raspberrypi	2020-07-04 16:52:50.307	info	instance system.adapter.lupusec.0 started with pid 26536
                      host.raspberrypi	2020-07-04 16:52:22.835	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                      host.raspberrypi	2020-07-04 16:52:22.542	info	iobroker exit 0
                      host.raspberrypi	2020-07-04 16:52:21.278	info	iobroker upload [0] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/11.png icons/11.png image/png
                      host.raspberrypi	2020-07-04 16:52:21.207	info	iobroker upload [1] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/13.png icons/13.png image/png
                      host.raspberrypi	2020-07-04 16:52:21.135	info	iobroker upload [2] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/19.png icons/19.png image/png
                      host.raspberrypi	2020-07-04 16:52:21.060	info	iobroker upload [3] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/2.png icons/2.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.990	info	iobroker upload [4] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/20.png icons/20.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.919	info	iobroker upload [5] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/22.png icons/22.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.850	info	iobroker upload [6] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/23.png icons/23.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.781	info	iobroker upload [7] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/24.png icons/24.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.712	info	iobroker upload [8] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/26.png icons/26.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.645	info	iobroker upload [9] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/37.png icons/37.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.584	info	iobroker upload [10] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/39.png icons/39.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.521	info	iobroker upload [11] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/4.png icons/4.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.460	info	iobroker upload [12] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/45.png icons/45.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.396	info	iobroker upload [13] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/46.png icons/46.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.334	info	iobroker upload [14] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/48.png icons/48.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.271	info	iobroker upload [15] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/5.png icons/5.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.199	info	iobroker upload [16] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/50.png icons/50.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.137	info	iobroker upload [17] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/54.png icons/54.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.074	info	iobroker upload [18] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/57.png icons/57.png image/png
                      host.raspberrypi	2020-07-04 16:52:20.008	info	iobroker upload [19] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/58.png icons/58.png image/png
                      host.raspberrypi	2020-07-04 16:52:19.937	info	iobroker upload [20] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/66.png icons/66.png image/png
                      host.raspberrypi	2020-07-04 16:52:19.266	info	iobroker upload [30] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/zentrale.png icons/zentrale.png image/png
                      host.raspberrypi	2020-07-04 16:49:39.593	info	iobroker npm install https://github.com/schmupu/ioBroker.lupusec/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                      host.raspberrypi	2020-07-04 16:49:39.590	info	iobroker NPM version: 6.14.5
                      host.raspberrypi	2020-07-04 16:49:38.330	info	iobroker install https://github.com/schmupu/ioBroker.lupusec/tarball/master
                      host.raspberrypi	2020-07-04 16:49:35.509	info	iobroker url "https://github.com/schmupu/ioBroker.lupusec/tarball/master" lupusec
                      An den Berechtigungen habe ich wie gesagt nichts wissentlich geändert. Ich bin von einer SD Karte auf eine externe SSD umgestiegen und habe die Datei umkopiert. Ich glaube es war nach dieser Anleitung.
                      • A anno171986
                        @Stuebi
                        Anbei das Log:
                        StuebiS Offline
                        StuebiS Offline
                        Stuebi
                        @anno171986 , kannst Du eigentlich auch als User iobroker vom PI aus die Alarmanlage ohne sudo pingen?
                        • StuebiS Stuebi
                          anno171986
                          @Stuebi Nein, nur mit sudo:
                          pi@raspberrypi:~ $ ping -c 4 192.168.178.34
                          ping: socket: Die Operation ist nicht erlaubt
                          pi@raspberrypi:~ $ sudo ping -c 4 192.168.178.34
                          PING 192.168.178.34 (192.168.178.34) 56(84) bytes of data.
                          64 bytes from 192.168.178.34: icmp_seq=1 ttl=64 time=7.78 ms
                          64 bytes from 192.168.178.34: icmp_seq=2 ttl=64 time=9.07 ms
                          64 bytes from 192.168.178.34: icmp_seq=3 ttl=64 time=11.5 ms
                          64 bytes from 192.168.178.34: icmp_seq=4 ttl=64 time=6.44 ms
                          --- 192.168.178.34 ping statistics ---
                          4 packets transmitted, 4 received, 0% packet loss, time 8ms
                          rtt min/avg/max/mdev = 6.440/8.692/11.480/1.858 ms
                          Thomas BraunT StuebiS 2 Antworten Letzte Antwort
                          • A anno171986
                            Thomas BraunT Offline
                            @anno171986
                            Was liefert denn
                            ls -la /bin/ping
                            sowie
                            groups
                            als user pi?
                              @anno171986
                              Was liefert denn
                              ls -la /bin/ping
                              sowie
                              groups
                              als user pi?
                              anno171986
                              @Thomas-Braun
                              pi@raspberrypi:~ $ ls -la /bin/ping
                              -rwxr-xr-x 1 root root 55720 Jan 14 00:29 /bin/ping
                              pi@raspberrypi:~ $ groups
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                              • A anno171986
                                StuebiS Offline
                                StuebiS Offline
                                Stuebi
                                #66
                                @anno171986 , okay das passt genau zu deinem Fehler:
                                https://www.kevinhooke.com/2016/03/10/raspbian-jessie-ping-operation-not-permitted/
                                Versuche das einmal aus und starte den Adapter neu:
                                sudo chmod u+s /bin/ping
                                A M D 3 Antworten Letzte Antwort
                                • StuebiS Stuebi
                                  anno171986
                                  #67
                                  @Stuebi said in lupusec Adapter Fehler:
                                  Habe es ausgeführt, Instanz neugestartet, die Instanz wird grün und es sind auch alle (auf den ersten Blick) Geräte da.
                                  hier noch das Log:
                                  lupusec.0	2020-07-04 17:40:40.225	info	(26685) Delete channel lupusec.0.webcams.cam4
                                  lupusec.0	2020-07-04 17:40:40.223	info	(26685) Delete channel lupusec.0.webcams.cam3
                                  lupusec.0	2020-07-04 17:40:40.221	info	(26685) Delete channel lupusec.0.webcams.cam2
                                  lupusec.0	2020-07-04 17:40:40.219	info	(26685) Delete channel lupusec.0.webcams.cam1
                                  lupusec.0	2020-07-04 17:40:26.581	info	(26685) Polltime 1 sec.
                                  lupusec.0	2020-07-04 17:40:26.579	info	(26685) Connecting to Lupusec with https://192.168.178.34:443
                                  lupusec.0	2020-07-04 17:40:26.403	info	(26685) Checking the ioBroker Lupusec configuration
                                  lupusec.0	2020-07-04 17:40:26.399	info	(26685) Lupusec Alarmsystem 192.168.178.34 is alive
                                  lupusec.0	2020-07-04 17:40:26.284	info	(26685) Starting Adapter lupusec.0 in version 1.2.9
                                  lupusec.0	2020-07-04 17:40:26.242	info	(26685) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.lupusec, node: v12.18.1, js-controller: 3.1.4
                                  lupusec.0	2020-07-04 17:40:26.217	info	(26685) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                  host.raspberrypi	2020-07-04 17:40:22.736	info	instance system.adapter.lupusec.0 started with pid 26685
                                  Vielen, vielen Dank
                                  • StuebiS Stuebi
                                    mucki
                                    schrieb am zuletzt editiert von mucki
                                    #68
                                    @Stuebi
                                    Darf ich mich hier kurz reinhängen?
                                    Ich recherchiere gerade intensive Probleme mit meiner XT2 Plus.
                                    Problem: ca. 1x am Tag (manchmal auch "nur" alle 2 Tage) schmiert die XT2 Plus komplett ab und bootet alle 20 Sekunden neu.
                                    Die Fehlersituation ist damit vollkommen gleich wie bei dem Fehler vor der Firmware 3.2G und dem Google Push Service vor einiger Zeit (nur der vollständigkeithalber - nutze selber nur iOS Geräte)
                                    Wenn ich mich recht entsinne, habe ich vor kurzem den Lupusec Adapter auf 1.2.6 aktualisiert.
                                    Hier mal ein Log von iobroker bei so einem Absturz:
                                    2020-08-26 16:19:15.600 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListPSSGet) : RequestError: Error: socket hang up
                                    2020-08-26 16:19:15.601 - error: lupusec.0 (2007) Poll rythmus chnaged to 15 seconds because of error!
                                    2020-08-26 16:19:15.601 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListPSSGet) : RequestError: Error: socket hang up
                                    2020-08-26 16:19:15.602 - error: lupusec.0 (2007) Poll rythmus chnaged to 30 seconds because of error!
                                    2020-08-26 16:19:15.602 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListPSSGet) : RequestError: Error: socket hang up
                                    2020-08-26 16:19:15.602 - error: lupusec.0 (2007) Poll rythmus chnaged to 45 seconds because of error!
                                    2020-08-26 16:19:15.602 - error: lupusec.0 (2007) Poll rythmus chnaged to 60 seconds because of error!
                                    2020-08-26 16:19:15.669 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: connect ECONNREFUSED 192.168.2.50:443
                                    2020-08-26 16:19:15.670 - error: lupusec.0 (2007) Poll rythmus chnaged to 75 seconds because of error!
                                    2020-08-26 16:19:15.670 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: connect ECONNREFUSED 192.168.2.50:443
                                    2020-08-26 16:19:15.670 - error: lupusec.0 (2007) Poll rythmus chnaged to 90 seconds because of error!
                                    2020-08-26 16:19:15.673 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: connect ECONNREFUSED 192.168.2.50:443
                                    2020-08-26 16:19:15.673 - error: lupusec.0 (2007) Poll rythmus chnaged to 105 seconds because of error!
                                    2020-08-26 16:19:15.673 - error: lupusec.0 (2007) Poll rythmus chnaged to 120 seconds because of error!
                                    2020-08-26 16:19:16.200 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/panelCondGet) : RequestError: Error: connect ECONNREFUSED 192.168.2.50:443
                                    2020-08-26 16:19:16.200 - error: lupusec.0 (2007) Poll rythmus chnaged to 135 seconds because of error!
                                    2020-08-26 16:19:16.201 - error: lupusec.0 (2007) Poll rythmus chnaged to 150 seconds because of error!
                                    2020-08-26 16:19:16.201 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/panelCondGet) : RequestError: Error: connect ECONNREFUSED 192.168.2.50:443
                                    2020-08-26 16:19:16.201 - error: lupusec.0 (2007) Poll rythmus chnaged to 165 seconds because of error!
                                    2020-08-26 16:19:16.201 - error: lupusec.0 (2007) Poll rythmus chnaged to 180 seconds because of error!
                                    2020-08-26 16:19:45.924 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListPSSGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:19:45.924 - error: lupusec.0 (2007) Poll rythmus chnaged to 195 seconds because of error!
                                    2020-08-26 16:19:45.925 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListPSSGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:19:45.925 - error: lupusec.0 (2007) Poll rythmus chnaged to 210 seconds because of error!
                                    2020-08-26 16:19:45.925 - error: lupusec.0 (2007) Poll rythmus chnaged to 225 seconds because of error!
                                    2020-08-26 16:19:45.926 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListPSSGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:19:45.926 - error: lupusec.0 (2007) Poll rythmus chnaged to 240 seconds because of error!
                                    2020-08-26 16:20:31.159 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:20:31.161 - error: lupusec.0 (2007) Poll rythmus chnaged to 255 seconds because of error!
                                    2020-08-26 16:20:31.161 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:20:31.161 - error: lupusec.0 (2007) Poll rythmus chnaged to 270 seconds because of error!
                                    2020-08-26 16:20:31.162 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/deviceListGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:20:31.162 - error: lupusec.0 (2007) Poll rythmus chnaged to 285 seconds because of error!
                                    2020-08-26 16:20:31.162 - error: lupusec.0 (2007) Poll rythmus chnaged to 300 seconds because of error!
                                    2020-08-26 16:22:02.146 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/panelCondGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:22:02.146 - error: lupusec.0 (2007) Poll rythmus chnaged to 300 seconds because of error!
                                    2020-08-26 16:22:02.147 - error: lupusec.0 (2007) Error: Error in deviceGenericGet (/action/panelCondGet) : StatusCodeError: 401 - "Zugriff verweigert: Sitzung abgelaufen!"
                                    2020-08-26 16:22:02.147 - error: lupusec.0 (2007) Poll rythmus chnaged to 300 seconds because of error!
                                    (Ist nur ein Ausschnitt - das geht noch länger weiter...)
                                    Bei so einem Absturz ist auch die iobroker Oberfläche kaum/nicht erreichbar. Kann das mit dem hier diskutierten Problem zusammenhängen? Ich habe gerade mal versuchsweise ein Downgrade auf die Version 1.2.3 durchgeführt und schaue mal, ob weitere Abstürze an der Tagesordnung stehen....
                                    • M mucki
                                      @Stuebi
                                      StuebiS Offline
                                      StuebiS Offline
                                      Stuebi
                                      #69
                                      @mucki , ich werde mir das am Wochenende einmal anschauen.
                                      • StuebiS Stuebi
                                        mucki
                                        #70
                                        @Stuebi
                                        Vielen Dank!
                                        Aber ich befürchte, ich stehe mit dem Problem alleine da.
                                        Habe ja wie geschrieben den Adapter auf 1.2.3 runter gezogen. Damit hatte ich gestern um 19:57 das gleiche Problem (alle 10 Sekunden Neustarts mit Piepen / alle 3 LEDs an).
                                        Da ich zu Hause war konnte ich einige Tests machen:
                                        a) Netzstecker raus und Akku aus -> Netzstecker wieder rein -> XT2 startet immer noch alle 10 Sekunden neu
                                        b) Netzwerkstecker raus -> Piepen hört auf (und damit wohl die Neustarts)
                                        c) XT2 vom Switch abgesteckt und mit neuem Netzwerkkabel direkt in die FritzBox angeschlossen -> Neustarts/Piepen fangen wieder an
                                        d) Lupusec Instanz im iObroker angehalten -> weiterhin Neustarts/Piepen
                                        e) In der Fritzbox den Internetzugriff für die XT2 gesperrt -> weiterhin Neustarts/Piepen
                                        Nach einer guten halben Stunde war das Problem wie durch Geisterhand ohne zutun vorbei und die XT2 war wieder ansprechbar als wäre nie etwas gewesen.
                                        Diese halbe Stunde mit den Neustarts habe ich jetzt zu verschiedenen Uhrzeiten täglich und ich weiß nicht, wo ich noch suchen sollte.
                                        Muss die XT2 wohl einschicken und überprüfen lassen (in der Hoffnung, dass es doch ein Hardwaredefekt ist und nichts mit meinem Netzwerk zu tun hat).
                                        • M mucki
                                          @Stuebi
                                          Vielen Dank!
                                          StuebiS Offline
                                          StuebiS Offline
                                          Stuebi
                                          #71
                                          @mucki , ich würde mit der Lupusec Hoteline sprechen. Auf die Alarmanlage möchte man sich ja verlassen können. Vielleicht ist ja nur das Netzteil defekt?
                                          M 2 Antworten Letzte Antwort
