  4. IoBroker.homepilot Adapter
125 Beiträge 21 Kommentatoren 35.7k Aufrufe 5 Beobachtet
  • P
    P
    pustekuchen
    @pix:
    Kannst du mir mal die JSON schicken, wenn der Aktor ausgeschaltet ist?
    Pix `
    {  "response": "get_visible_devices",  "status": "ok",  "devices": [    {      "did": 10009,      "name": "Gartenbeleuchtung",      "description": " ",      "initialized": 1,      "position": 0,      "productName": "Universal-Aktor",      "serial": "43",      "statusesMap": {        "Position": 0,        "Manuellbetrieb": 0      },      "status_changed": 1466276021,      "deviceGroup": 1,      "iconSet": {        "name": "Ein-Aus-Schalter",        "description": "Ein- Aus-Schalter Icon-Set",        "strMin": "An",        "strMax": "Aus",        "valMax": 100,        "valMin": 0,        "sprite": {          "imageUri": "images/sets/ein-aus-schalter1.png",          "numTiles": 2        },        "k": "iconset5"      },      "iconSetInverted": 0,      "paired": 0,      "statusValid": true,      "uid": "43 XX XX",      "visible": true,      "groups": [        5003      ],      "favoredId": 5013,      "properties": {        "generic": 3,        "wind": 3,        "trigger": 3,        "closingContact": 3,        "dusk": 3,        "smoke": 3,        "sun": 3,        "temperature": 3,        "manual": 3,        "time": 2,        "dawn": 3,        "dust": 3,        "favored": 0,        "smartphone": 3,        "motion": 3,        "temperator": 3,        "warning": 3,        "rain": 3,        "states": [          {            "cfgKey": "setAutomationOverall",            "cfgId": 99,            "state": 0          },          {            "cfgKey": "setSunAuto",            "cfgId": 105,            "state": 0          },          {            "cfgKey": "setEveningAuto",            "cfgId": 107,            "state": 1          },          {            "cfgKey": "setTimeAuto",            "cfgId": 101,            "state": 1          },          {            "cfgKey": "setMorningAuto",            "cfgId": 103,            "state": 1          }        ]      },      "sortId": 718,      "sTypes": [],      "version": "2.2",      "sync": -2147480277,      "messages": [],      "hasErrors": 0,      "autos": [        3,        2,        0,        1,        4      ]    },
    • P
      P
      pustekuchen
      @pix:
          } else if (controller == 'state') { // control via state e.g. Universal-Aktor switch (100 ist true, <100 is false);
              if (input.search(/(true)|(false)\b/gmi) != -1) { // check if "true" or "false"
                  valid = true;
                  if (input || input === 'true') { // switch is on
                      url = 'http://' + ip + '/deviceajax.do?cid=9&did=' + deviceid + '&goto=100&command=1';
                  } else url = 'http://' + ip + '/deviceajax.do?cid=9&did=' + deviceid + '&goto=0&command=1'; // switch is off
                  adapter.log.debug('Input: ' + input + ' URL: '  + url);
              } else valid = false;
      Habe im Code gesehen, du setzt cid=9 mit Position N auch beim Schaltaktor ein. Für die Schaltaktoren gibt es doch den CID 10 für AN und 11 für AUS. Ist der CID 10 bzw. 11 für den Datenpunkt STATE nicht besser geeignet? Dummerweise gibt das JSON als Rückmeldung trotzdem den Wert als "POSITION" aus.
      Also sieht es dann so aus:
                  valid = true;
                      url = 'http://' + ip + '/deviceajax.do?cid=10&did=' + deviceid + '&command=1';
                  } else url = 'http://' + ip + '/deviceajax.do?cid=11&did=' + deviceid + '&command=1'; // switch is off
      • P
        P
        pix
        Du hast recht. Macht ja auch Sinn. Ich war immer noch überzeugt, true sei Position 100, false sei 0; auch beim Setzen. Aber Cid ist ja genau dafür da. Mach ich morgen!
        Muss mir wohl auch mal so einen Aktor zulegen.
        Gute Nacht,
        Pix
        Gesendet mit Tapatalk
        • P
          P
          pustekuchen
          @pix:
          Gute Nacht,
          Pix
          Gesendet mit Tapatalk `
          Cool. Kannst du evtl. noch die Synctime in den Settings einstellbar machen? Und was noch schick wäre: Eine Fehlermeldung, wenn der Homepilot nicht erreichbar ist, oder ist das schon drin? Ich würde gerne eine "Servicemeldung" à la Homematic einblenden lassen, wenn die Verbindung nicht möglich ist.
          • L
            L
            leo013
            Hallo Pix,
            das Design von deinem widget passt leider nicht zu meiner Visu ;-)
            Ich glaube das Widget, das ich nutze ist von Bluefox.
            Im Moment kann ich mit der Tastensteuerung leben, die Gurtwickler laufen automatisch über
            die Dämmerungs- und Sonnenaufgangsfunktion, sowie Beschattung bei starken Sonneneinfall.
            Ich habe fast meine komplette Dashui-Visu auf iobroker umgestellt, muss nur noch meine beiden Homeduino einbinden
            Nochmals herzlichen Dank für die schnelle Umsetzung!
            Wolfgang
            • P
              P
              pix
              0.0.5 ist fertig
              https://github.com/Pix–-/ioBroker.homepilot
              Neu:
              • Die Dauer in Sekunden zwischen den Synchronisierungen Homepilot <> ioBroker lässt sich nun einstellen (default 12s).
              • Switches/Schalter (Serie 43 und 46) werden nun per Commad ID gesetzt, aber noch über Position/Level aus Homepilot gelesen.
              • Datenpunkt UNREACH erstellt.
                Wenn Homepilot nicht erreichbar, wird UNREACH auf true gesetzt (zB für Alarmierung). Bitte prüfen, ob das Setzen auf true bei Adapter Installation bis zum ersten einlesen schon die Alarmierung auslöst. Dann muss ich das ändern.
              • Readme aufgehübscht
              Pix
              • M
                M
                mdsv
                bei mir geht die Installation leider nicht. Sowohl über die GUI, als auch die Konsole.
                Müsste es gehen????
                404 https://registry.npmjs.org/iobroker.homepilot
                npm ERR! TypeError: Cannot read property 'latest' of undefined
                npm ERR! at next (/usr/local/lib/node_modules/npm/lib/cache.js:687:35)
                npm ERR! at /usr/local/lib/node_modules/npm/lib/cache.js:675:5
                npm ERR! at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:142:7)
                npm ERR! at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:133:7
                npm ERR! at Object.oncomplete (fs.js:107:15)
                npm ERR! If you need help, you may report this log at:
                npm ERR! <http://github.com/isaacs/npm/issues>
                npm ERR! or email it to:
                npm ERR! npm-@googlegroups.com
                • P
                  P
                  pustekuchen
                  @pix:
                  0.0.5 ist fertig
                  Neu:
                  Pix `
                  Neue Version installiert, leider geht das ausschalten der Schaltaktoren über STATE false immer noch nicht. Edit: Einschalten geht, aber ausschalten dann nicht mehr.
                  • P
                    P
                    pix
                    Seltsam, hier der Code, der das Schalten übernimmt:
                                valid = true;
                                newcid = (input || input === 'true') ? '10' : '11'; // hier sollte bei 'false' eigentlich '11' gesetzt werden
                                if (valid) url = 'http://' + ip + '/deviceajax.do?did=' + deviceid + '&cid=' + newcid + '&command=1'; // switch ON / OFF
                                adapter.log.debug('Switch ' + deviceid + ' new status detected: ' + input + ' URL: '  + url);
                    Was sagt das Log (hier 6. Zeile, also Adapter bitte auf debug stellen)?
                    Pix
                    • P
                      P
                      pustekuchen
                      Log sagt:
                      homepilot-0 2016-06-19 15:09:24.490 warn Wrong type of data input. Please try again
                      homepilot-0 2016-06-19 15:09:20.895 warn Wrong type of data input. Please try again
                      homepilot-0 2016-06-19 15:09:19.959 info Command sent to Homepilot because "false" written to State "homepilot.0.devices.Steckdosenaktor.10006.state"
                      homepilot-0 2016-06-19 15:09:13.213 warn Wrong type of data input. Please try again
                      homepilot-0 2016-06-19 15:09:12.220 info Command sent to Homepilot because "true" written to State "homepilot.0.devices.Steckdosenaktor.10006.state"
                      homepilot-0 2016-06-19 15:09:09.915 warn Wrong type of data input. Please try again
                      homepilot-0 2016-06-19 15:08:57.730 warn Wrong type of data input. Please try again
                      Hätte ich jetzt seit dem du geantwortet hast nochmal updaten müssen?
                      • P
                        P
                        pix
                        Nein, hätest du nicht. Habe nichts verändert.
                        Du sagst ja, dass das Einschalten funktioniert, nur das Ausschalten nicht.
                        Also true geht, false nicht.
                        Seltsam ist ja, dass durch diese Zeile
                        genau nach "true" gefragt wird (sowohl als boolean, als auch als Zeichenkette) und falls kein true kommt, und dazu gehört 'false' ja, dann soll die 11 gesetzt werden (für AUS).
                        Mir fehlt nur diese Zeile in der Logausgabe:
                        Deshalb bitte mal den Adapter auf DEBUG stellen (Reiter Instanzen, Expertenmodus. Logstufe) 261_bildschirmfoto_2016-06-19_um_22.03.12.jpg
                        Pix
                        • P
                          P
                          pustekuchen
                          Ok, hier die Debug-Ausgabe nachdem ich ausgeschaltet habe:
                          homepilot.0 Wrong type of data input. Please try again
                          homepilot.0	2016-06-19 22:25:51.217	debug	homepilot.0 State: state device: 10006 command: 0
                          homepilot.0	2016-06-19 22:25:51.216	debug	homepilot.0 input value: 0
                          homepilot.0	2016-06-19 22:25:51.216	debug	homepilot.0 stateChange homepilot.0.devices.Steckdosenaktor.10006.state {"val":"0","ack":false,"ts":1466367951198,"q":0,"from":"system.adapter.web.0","lc":1466367951198}
                          homepilot.0	2016-06-19 22:25:51.214	debug	inMem message homepilot.0.* homepilot.0.devices.Steckdosenaktor.10006.state
                          homepilot.0	2016-06-19 22:25:50.318	info	homepilot.0 Command sent to Homepilot because "false" written to State "homepilot.0.devices.Steckdosenaktor.10006.state"
                          homepilot.0	2016-06-19 22:25:50.318	debug	homepilot.0 Switch 10006 new status detected: false URL: http://192.168.178.5/deviceajax.do?did=10006&cid=10&command=1
                          homepilot.0	2016-06-19 22:25:50.317	debug	homepilot.0 State: state device: 10006 command: false
                          homepilot.0	2016-06-19 22:25:50.317	debug	homepilot.0 input value: false
                          homepilot.0	2016-06-19 22:25:50.317	debug	homepilot.0 stateChange homepilot.0.devices.Steckdosenaktor.10006.state {"val":false,"ack":false,"ts":1466367950226,"q":0,"from":"system.adapter.web.0","lc":1466367950226}
                          homepilot.0	2016-06-19 22:25:50.315	debug	inMem message homepilot.0.* homepilot.0.devices.Steckdosenaktor.10006.state
                          homepilot.0	2016-06-19 22:25:46.005	debug	homepilot.0 Homepilot adapter started...
                          homepilot.0	2016-06-19 22:25:46.005	debug	homepilot.0 Homepilot station and ioBroker synchronize every 12s
                          homepilot.0	2016-06-19 22:25:46.004	debug	homepilot.0 initializing objects
                          Edit: Ok, jetzt habe ich herausgefunden, dass der CID falsch ist, bei STATE false wird 10, also Einschalten benutzt anstatt 11.
                          Gesendet von meinem iPad mit Tapatalk HD
                          • P
                            P
                            pix
                            Vielen Dank für die Rückmeldung. Jetzt habe ich den Fehler wohl gefunden:
                            Input ist ja kein Typ boolean, sondern ein Typ String. Deshalb wird die obige Abfrage immer '10' ergeben, da auch der übergebene String 'false' eben ein String ist und die Variable füllt. Es wird ja nur gerpüft, ob was drin steht, erst nach dem ODER wird geprüft, obt das auch "true" ist.
                            Da ich oben weiter eh schon die Regex-Abfrage für plausible Eingaben habe, konnte ich die natürlich weiter unten auch nutzen.
                            if (input.search(/(true)(EIN)(AN)(ON)|([10-11])|(false)(AUS)(OFF)\b\b/gmi) != -1) { // check if "true" or "false"
                                        valid = true;
                                        if (input.search(/(true)(EIN)(AN)(ON)|(10)\b\b/gmi) != -1 ) newcid = '10';
                                        if (input.search(/(false)(AUS)(OFF)|(11)\b\b/gmi) != -1 ) newcid = '11';
                            Es sind jetzt eben auch die in der https://github.com/Pix–-/ioBroker.homepilot/blob/master/README.md#command-id aufgezählten CID Anweisungen möglich (zB "AUS" oder "off" oder "EiN", wenn es sein muss :) )
                            Neue Version 0.0.6 mit Korrektur ist da.
                            Pix
                            • P
                              P
                              pustekuchen
                              Nach Update kann ich jetzt nur noch an- der ausschalten, wenn ich "10" oder "11" in STATE schreibe. "true" oder "false" oder "AN" oder "AUS", gehen nicht.
                              Geht nicht:
                              homepilot.0 2016-06-20 15:11:40.520 debug homepilot.0 finished reading Homepilot Data
                              homepilot.0 2016-06-20 15:11:40.518 debug homepilot.0 reading homepilot JSON ...
                              TypeError: 2016-06-20 13:11:36.854 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                              TypeError: 2016-06-20 13:11:36.854 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                              TypeError: 2016-06-20 13:11:36.854 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                              TypeError: 2016-06-20 13:11:36.854 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12)
                              TypeError: 2016-06-20 13:11:36.854 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10)
                              TypeError: 2016-06-20 13:11:36.854 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                              TypeError: 2016-06-20 13:11:36.854 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
                              TypeError: 2016-06-20 13:11:36.854 error at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2036:80)
                              TypeError: 2016-06-20 13:11:36.854 error at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.homepilot/main.js:22:9)
                              TypeError: 2016-06-20 13:11:36.854 error at controlHomepilot (/opt/iobroker/node_modules/iobroker.homepilot/main.js:166:23)
                              TypeError: 2016-06-20 13:11:36.854 error Cannot read property 'warn' of undefined
                              message 2016-06-20 13:11:36.836 error homepilot.0.devices.Steckdosenaktor.10006.state [object Object] Cannot read property 'warn' of undefined
                              homepilot-0 2016-06-20 13:11:36.832 debug State: state device: 10006 command: true
                              homepilot-0 2016-06-20 13:11:36.828 debug input value: true
                              homepilot-0 2016-06-20 13:11:36.826 debug stateChange homepilot.0.devices.Steckdosenaktor.10006.state {"val":true,"ack":false,"ts":1466428296807,"q":0,"from":"system.adapter.admin.0","lc":1466428296807}
                              inMem 2016-06-20 13:11:36.816 debug message homepilot.0.* homepilot.0.devices.Steckdosenaktor.10006.state val=true, ack=false, ts=1466428296807, q=0, from=system.adapter.admin.0, lc=1466428296807
                              homepilot-0 2016-06-20 13:11:28.451 debug Homepilot adapter started...
                              homepilot-0 2016-06-20 13:11:28.450 debug Homepilot station and ioBroker synchronize every 12s
                              homepilot-0 2016-06-20 13:11:28.446 debug initializing objects
                              homepilot-0 2016-06-20 13:11:28.431 info starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.homepilot
                              homepilot-0 2016-06-20 13:11:28.208 debug statesDB connected
                              homepilot-0 2016-06-20 13:11:28.158 debug objectDB connected
                              Geht schon: (mit "10")
                              homepilot.0	2016-06-20 15:14:04.759	debug	homepilot.0 reading homepilot JSON ...
                              homepilot-0	2016-06-20 13:14:01.388	info	Command sent to Homepilot because "10" written to State "homepilot.0.devices.Steckdosenaktor.10006.state"
                              homepilot-0	2016-06-20 13:14:01.377	debug	Switch 10006 new status detected: 10 URL: http://192.168.178.5/deviceajax.do?did=10006&cid=10&command=1
                              homepilot-0	2016-06-20 13:14:01.374	debug	State: state device: 10006 command: 10
                              homepilot-0	2016-06-20 13:14:01.374	debug	input value: 10
                              homepilot-0	2016-06-20 13:14:01.373	debug	stateChange homepilot.0.devices.Steckdosenaktor.10006.state {"val":10,"ack":false,"ts":1466428441359,"q":0,"from":"system.adapter.admin.0","lc":1466428441359}
                              inMem	2016-06-20 13:14:01.370	debug	message homepilot.0.* homepilot.0.devices.Steckdosenaktor.10006.state val=10, ack=false, ts=1466428441359, q=0, from=system.adapter.admin.0, lc=1466428441359
                              • P
                                P
                                pix
                                Danke für die Rückmeldung. Tut mir leid, waren Flüchtigkeitsfehler. Hab schon einen Schreibfehler gefunden: "adapter.lo.warn"
                                Ausserdem fehlte in der RegEx Abfrage wohl einige ODER :oops:
                                Ich lade mal schnell eine neue Version hoch 0.0.7. 8-)
                                Pix
                                • P
                                  P
                                  pustekuchen
                                  @pix:
                                  Pix `
                                  Danke, jetzt läufts! ;)
                                  • P
                                    P
                                    pustekuchen
                                    Ich wollte nochmal auf die Einstellungsmöglichkeit des Manuellbetriebs der Aktoren/Rollotrons zurückkommen.
                                    Wäre es möglich einen Datenpunkt "OVERALL_AUTOMATION" mit Typ boolean (true/false) für jedes Gerät einzuführen?
                                    Das Setzen der Automation bzw. des Manuellbetriebs geschieht mittels folgender Anfrage:````
                                    http://homepilot/deviceajax.do?automation=1&data={"did":10005,"automation":3,"state":false}
                                    Dabei ist "automation:3" die Funktion, um den Manuellmodus zu aktivieren "state:true" bzw. zu deaktiveren "state:false".
                                    Ausgelesen werden kann der Status des Geräts mittels````
                                    "statusesMap":{"Position":100,"Manuellbetrieb":0}
                                    ````innerhalb der Standardabfrage von````
                                    http://homepilot/deviceajax.do?devices=1
                                    ````, also "Manuellbetrieb":0 für deaktiviert bzw. "Manuellbetrieb":1 für aktivert.
                                    Wäre vielleicht für den ein oder anderen eine sinnvolle Ergänzung! :idea:
                                    EDIT:
                                    Habe gerade eine weitere sinnvolle Ergänzung gefunden, eine Rückmeldung, ob der Aktor erreichbar ist und sich zurückmeldet. Diese Info verbirgt sich hinter der Rückmeldung auf die Abfrage mit````
                                    ````bei````
                                    "statusValid":false,
                                    ````, "true", wenn der Befehl angekommen ist und das Gerät sich zurückmeldet und "false", wenn nicht. Habe es eben ausprobiert mit einer Schaltsteckdose. Gilt aber m.E. für alle Geräte.
                                    Damit könnte man noch einen "UNREACH"-Datenpunkt einführen.
                                    • P
                                      P
                                      pix
                                      Hallo pustekuchen,
                                      die nächsten Tage wird das erstmal nix. Habe da beruflich viel zu tun.
                                      Vielleicht danach. Wozu ist denn der manuelle Modus?
                                      Pix
                                      • P
                                        P
                                        pustekuchen
                                        Beispiel: Terrasse. Ich benutze den FDK bzw TFK der Homematic für den Fensterstatus. Ist an der Terrasse die Türe offen oder gekippt, dann geht der Rollo auf manuell und fährt abends nicht herunter, damit man sich nicht aussperrt, wenn man noch draußen sitzt. Sobald die Türe geschlossen wird, geht der Rollo wieder auf Automatik.
                                        • P
                                          P
                                          pix
                                          Ah verstehe. Das braucht man aber nur, wenn die Steuerung /Automatik von Homepilot gemacht wird, oder?
                                          Ist jedenfalls sinnvoll. Vielleicht kann ich nächste Woche was machen.
                                          Pix
                                          84.2k
