  5. [gelöst] Gerät per Mac Adr & Blockly ansprechen
    5.5k
158 Beiträge 8 Kommentatoren 22.2k Aufrufe 5 Beobachtet
  • AphofisA Aphofis
    @fastfoot
    wohin muss den der block
    fastfoot
    #89
    @Aphofis sagte in Gerät per Mac Adr & Blockly ansprechen:
    @fastfoot
     <variables>
       <variable id="aQubq9Vy-qj1gT{2OW;x">MAC</variable>
       <variable id="@[II(5R#h[a47`qET5k.">cmd</variable>
       <variable id="Fk6H`kq}eo!FPH!Ld2Ii">result</variable>
       <variable id="0@Y{~/hRy0d:vMQ1kCo@">url</variable>
     </variables>
     <block type="variables_set" id="Gj`MNS[$a0S:B!TUcx-%" x="38" y="138">
       <field name="VAR" id="aQubq9Vy-qj1gT{2OW;x">MAC</field>
       <value name="VALUE">
         <block type="text" id="V?)NQY:Z1bfh@J6KO8xg">
           <field name="TEXT">24:5e:be:0d:f1:b9</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="$c5Ud:#38C(q.uOF_;YC">
           <field name="VAR" id="@[II(5R#h[a47`qET5k.">cmd</field>
             <block type="text_join" id="2t+}?FeN#iG0J=~8q#|w" inline="true">
               <value name="ADD0">
                 <block type="text" id="w;^U.Vi%Z+6O=_j{oVD(">
                   <field name="TEXT">arp -a|grep </field>
                 </block>
               </value>
               <value name="ADD1">
                 <block type="variables_get" id="tH;y-cdpJdNS0#XCa8{X">
                 </block>
               </value>
               <value name="ADD2">
                 <block type="text" id="/t^Hm3;6![lRLzr3V@FX">
                   <field name="TEXT">|cut -f2 -d" "|cut -f2|cut -c2-16|cut -f1 -d ")"</field>
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="exec" id="Ra4`1SB0/Eog44pt9iJZ" inline="true">
               <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
               <field name="WITH_STATEMENT">TRUE</field>
               <field name="LOG"></field>
               <value name="COMMAND">
                 <shadow type="text" id="@QX{2frW2vhyd`CI;c:s">
                   <field name="TEXT">arp -a|grep 24:5e:be:0d:f1:b9|cut -f2 -d" "|cut -f2|cut -c2-16|cut -f1 -d ")"</field>
                 </shadow>
                 <block type="variables_get" id="|uJ{n?p{=za?mcVLIRON">
                 </block>
               </value>
               <statement name="STATEMENT">
                 <block type="variables_set" id="?iyp2/H]@8^4[PC2zLRB">
                   <field name="VAR" id="Fk6H`kq}eo!FPH!Ld2Ii">result</field>
                     <block type="text_trim" id="n^cdC!!B_}1rfyX0Jf54">
                       <field name="MODE">RIGHT</field>
                       <value name="TEXT">
                         <shadow type="text">
                           <field name="TEXT">abc</field>
                         </shadow>
                         <block type="variables_get" id=",|hfzf!Nd.fM|aAqMvS3">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="2;J*T*TpGNH`Ml_U^%63">
                       <field name="VAR" id="0@Y{~/hRy0d:vMQ1kCo@">url</field>
                         <block type="text_join" id="uNUY7tNxUZ3!oh#}bHXB" inline="true">
                           <value name="ADD0">
                             <block type="text" id="2GJK-1Bvmp)s6NC9.,:2">
                               <field name="TEXT">http://</field>
                             </block>
                           </value>
                           <value name="ADD1">
                             <block type="variables_get" id="/Dkdf,;.$]{U?-+%6q]I">
                             </block>
                           </value>
                           <value name="ADD2">
                             <block type="text" id="W[)hj~HEq7,*GOK28V%|">
                               <field name="TEXT">/cm?user=benutzer&amp;passwort=passwort</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="debug" id="?{mh|9:IPCBzf@bm4g=y" inline="true">
                           <value name="TEXT">
                             <shadow type="text" id="g/_Y3S(JG]HJS{wR6YI[">
                             </shadow>
                             <block type="variables_get" id="63@w*D4._cHwf:)n~#Nh">
                             </block>
                           </value>
                           <next>
                             <block type="update" id="QIux{@Cmil$IGVm2^=AS">
                               <field name="OID">0_userdata.0.BlocklyXML</field>
                                 <block type="variables_get" id="o09,K@:bm8P/u6/rKMsj">
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    AphofisA 1 Antwort Letzte Antwort
    • AphofisA Aphofis
      @fastfoot
      ist nur die Frage warum im Datenpunkt zweimal die IP ausgegeben wird!
      192.168.0.57192.168.0.57
      fastfoot
      #90
      @fastfoot
      was sagt denn der LOG, bzw wenn du den DP kopierst? Ist vlt nur eine Sache der Optik, bei mir ist das nicht! Auch nicht mit deinem Blockly
      • F fastfoot
        @fastfoot
         <variables>
         </variables>
             </block>
           </value>
           <next>
                   <value name="ADD0">
                     </block>
                   </value>
                   <value name="ADD1">
                     </block>
                   </value>
                   <value name="ADD2">
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                     </shadow>
                     </block>
                   </value>
                           <value name="TEXT">
                             </shadow>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                               <value name="ADD0">
                                 </block>
                               </value>
                               <value name="ADD1">
                                 </block>
                               </value>
                               <value name="ADD2">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                               <value name="TEXT">
                                 </shadow>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
        </xml>
        AphofisA Offline
        AphofisA Offline
        Aphofis
        schrieb am zuletzt editiert von Aphofis
        #91
        @fastfoot sagte in Gerät per Mac Adr & Blockly ansprechen:
        jetzt kommen fehler!!!
        der erste Blockly war besser nur das halt im datenpunkt die IP doppelt angegeben ist
        javascript.0	2020-06-23 23:07:29.237	warn	(31412) at Pipe._handle.close (net.js:607:12)
        javascript.0	2020-06-23 23:07:29.237	warn	(31412) at Socket.EventEmitter.emit (domain.js:448:20)
        javascript.0	2020-06-23 23:07:29.236	warn	(31412) at Socket.emit (events.js:198:13)
        javascript.0	2020-06-23 23:07:29.235	warn	(31412) at Socket.stream.socket.on (internal/child_process.js:389:11)
        javascript.0	2020-06-23 23:07:29.234	warn	(31412) at maybeClose (internal/child_process.js:982:16)
        javascript.0	2020-06-23 23:07:29.233	warn	(31412) at ChildProcess.EventEmitter.emit (domain.js:448:20)
        javascript.0	2020-06-23 23:07:29.232	warn	(31412) at ChildProcess.emit (events.js:198:13)
        javascript.0	2020-06-23 23:07:29.231	warn	(31412) at ChildProcess.exithandler (child_process.js:285:7)
        javascript.0	2020-06-23 23:07:29.230	warn	(31412) at script.js.ESP_Reboot.Aqu_Control_IP_Abfrage:10:3
        javascript.0	2020-06-23 23:07:29.229	warn	(31412) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
        javascript.0	2020-06-23 23:07:29.225	warn	(31412) You are assigning a string to the state "Aqua_Control.0.IP_MAC_Abgleich.Aqua_Control" which expects a number. Please fix your code to use a number or change the state type to string. This war
        javascript.0	2020-06-23 23:07:29.224	info	192.168.0.57/cm?user=benutzer&passwort=passwort
        javascript.0	2020-06-23 23:07:29.224	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: http://192.168.0.57
        javascript.0	2020-06-23 23:07:29.188	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: registered 0 subscriptions and 0 schedules
        javascript.0	2020-06-23 23:07:29.146	info	(31412) Start javascript script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
        javascript.0	2020-06-23 23:07:28.224	info	(31412) Stop script script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
        Kopierte Datenpunkt Ausgabe ist so:
        F 1 Antwort Letzte Antwort
        • AphofisA Aphofis
          fastfoot
          #92
          @Aphofis
          das liegt an deinem DP!!! auch die reine IP ist ein string und keine number. Musst du abändern, ist dann evtl auch der Grund für das doppelte Erscheinen
          • F fastfoot
            @Aphofis
            AphofisA Offline
            AphofisA Offline
            Aphofis
            #93
            @fastfoot
            Ich prüfe
            klappt nicht am besten wir machen morgen weiter!
            • AphofisA Aphofis
              @fastfoot
              Ich prüfe
              fastfoot
              #94
              @fastfoot
              Ich prüfe
              im RAW unter common den type von number nach string abändern, das sollte es tun
              • F fastfoot
                @fastfoot
                Ich prüfe
                AphofisA Offline
                AphofisA Offline
                Aphofis
                #95
                @fastfoot
                ist so trotzdessen doppelte IP
                Aqua_Control	state     IP MAC Abgleich.Aqua_Control      state	       string			192.168.0.57 192.168.0.57
                • AphofisA Aphofis
                  @fastfoot
                  fastfoot
                  #96
                  @fastfoot
                  und im LOG ist der Fehler weg?
                  • F fastfoot
                    @fastfoot
                    AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    #97
                    @fastfoot
                    In der LOG stehts so da:
                    javascript.0	2020-06-23 23:30:26.524	info	192.168.0.57
                    javascript.0	2020-06-23 23:30:26.524	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: http://192.168.0.57
                    javascript.0	2020-06-23 23:30:26.481	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: registered 0 subscriptions and 0 schedules
                    javascript.0	2020-06-23 23:30:26.456	info	(31412) Start javascript script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
                    so ist es komplett ab dem stoppen
                    javascript.0	2020-06-23 23:30:26.524	info	/cm?user=benutzer&passwort=passwort
                    javascript.0	2020-06-23 23:30:25.485	info	(31412) Stop script script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
                    • AphofisA Aphofis
                      @fastfoot
                      fastfoot
                      #98
                      @Aphofis
                      wenn du in den state reinklickst, ist es dann auch so? Kann eig. nicht sein
                      • F fastfoot
                        @Aphofis
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        #99
                        • AphofisA Aphofis
                          fastfoot
                          #100
                          @Aphofis
                          probier mal noch die role zu ändern
                            "common": {
                              "name": "Aqua_Control.0.IP_MAC_Abgleich.Aqua_Control",
                              "role": "text",
                              "type": "string",
                          • F fastfoot
                            @Aphofis
                              "common": {
                                "role": "text",
                                "type": "string",
                            AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            #101
                            @fastfoot wird trotzdessen doppelt angezeigt
                            • AphofisA Offline
                              AphofisA Offline
                              Aphofis
                              #102
                              lass uns Morgen weiter machen ich muss Augenlappenpflege machen morgen eine Stressige Grossbaustelle!
                              • AphofisA Aphofis
                                fastfoot
                                #103
                                ja ok, ich hätte auch nur noch eine einzige Idee, die du morgen testen kannst: ein Blockly mit nur diesem Inhalt
                                • F fastfoot
                                  AphofisA Offline
                                  AphofisA Offline
                                  Aphofis
                                  #104
                                  @fastfoot
                                  Hatte ich heute früh getestet! Wenn nur die Aktualisierung wird nur einmal die IP angezeigt.
                                  Aber woran es liebt das die nun zweimal ausgegeben wird keine Ahnung
                                  • AphofisA Aphofis
                                    @fastfoot
                                    fastfoot
                                    #105
                                    @fastfoot
                                    da fällt mir jetzt auch nichts mehr ein, die Länge der IP beträgt 14 Zeichen. Ich denke es liegt an deinem DP oder ein anderes Skrip ist noch im Spiel. Du könntest noch den DP neu erstellen, mit type=string. Ansonsten wäre interessant was denn Andere hier für Ergebnisse haben. Hier noch einmal das Endergebnis:
                                     <variables>
                                       <variable id="0N!Pxj|%o,hrP:$Wm2WE">ip</variable>
                                     </variables>
                                           <field name="TEXT">MACADRESSE_ENTRAGEN keine Großbuchstaben!!!</field>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="comment" id="H;=Y7NT2TXV-Gs]VB$O+">
                                           <field name="COMMENT">ermittelt den Gerätenamen</field>
                                           <next>
                                             <block type="variables_set" id="ANCrs)lzX+xxTghREp[.">
                                                 <block type="text_join" id="IxyBhYQL+iZa#PFe)9~7" inline="true">
                                                   <value name="ADD0">
                                                     <block type="text" id="0s)wG{GvjG1.@@+V/aSr">
                                                     </block>
                                                   </value>
                                                   <value name="ADD1">
                                                     <block type="variables_get" id="{S|p_K(0Lf_(^t{(8,b?">
                                                     </block>
                                                   </value>
                                                   <value name="ADD2">
                                                     <block type="text" id="I^t@Iu.(q%D!J*WaRFQa">
                                                       <field name="TEXT">|cut -f1 -d" "</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="comment" id="+Ys6+MxbbJZ#NA)9)0{2">
                                                   <field name="COMMENT">ermittelt IP-Adresse</field>
                                                   <next>
                                                           <value name="ADD0">
                                                             </block>
                                                           </value>
                                                           <value name="ADD1">
                                                             </block>
                                                           </value>
                                                           <value name="ADD2">
                                                               <field name="TEXT">|cut -f2 -d"("|cut -f1 -d")"</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="exec" id="2!bNa75D5snVE!jky@@." inline="true">
                                                             <shadow type="text" id="^!S#xfBrYSkE3IIEA|rP">
                                                             </shadow>
                                                             <block type="variables_get" id="OCMYegrGVigEscI9|L(L">
                                                             </block>
                                                           </value>
                                                             <block type="variables_set" id="L]J.=sLuX-3~:q^phHdI">
                                                               <field name="VAR" id="0N!Pxj|%o,hrP:$Wm2WE">ip</field>
        <block type="text_trim" id="ieQ%=JdT2@lsW*HynVxx">
        <field name="MODE">BOTH</field>
        <value name="TEXT">
        <shadow type="text" id="PYvpEBV*CvA*:pz@RD@9">
        </shadow>
        <block type="convert_tostring" id="Lm-b^FX_25OE0xK.;2lJ">
        <block type="variables_get" id="=({0X#Vd(gZfW5P7YuI(">
        </block>
        </value>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <block type="controls_if" id="z`?p:wuv4qf@FB.^P`IN">
        <value name="IF0">
        <block type="logic_negate" id="oS4QJFW.#h11BEG)C]6#">
        <value name="BOOL">
        <block type="logic_compare" id="kmSbl@isO%v0V2M2KV%q">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="variables_get" id="!2hJmAo:{WQVvmo#MSpw">
        </block>
        </value>
        <value name="B">
        <block type="text" id="D,uO-gM;I-Q]GD6b~D,0">
        <field name="TEXT"></field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <statement name="DO0">
        <block type="update" id="[8fA(|Z;CZFWcXyOVkM.">
        <field name="OID">0_userdata.0.ipaddress</field>
        <block type="variables_get" id="57Ns7WblYc`pSoPfT[we">
        </block>
        </value>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="debug" id="[[H]7mGw_,7D]-2K[vi9" inline="true">
        <value name="TEXT">
        <shadow type="text" id="FP4|qtV]4IE}b_oww8Gh">
        <field name="TEXT">Keine IP Adresse gefunden!</field>
        </shadow>
        </value>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                    </xml>
                                    • F fastfoot
                                      @fastfoot
                                       <variables>
                                       </variables>
                                           </block>
                                         </value>
                                         <next>
                                             <next>
                                                     <value name="ADD0">
                                                       </block>
                                                     </value>
                                                     <value name="ADD1">
                                                       </block>
                                                     </value>
                                                     <value name="ADD2">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                     <next>
                                                             <value name="ADD0">
                                                               </block>
                                                             </value>
                                                             <value name="ADD1">
                                                               </block>
                                                             </value>
                                                             <value name="ADD2">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </shadow>
                                                               </block>
                                                             </value>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="BOOL">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </statement>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                      </xml>
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #106
                                      @fastfoot
                                      habe es getestet - arp funktioniert jetzt bei mir
                                      die richtge ipadresse steht im datenpunkt - so wie es sein soll
                                      • liv-in-skyL liv-in-sky
                                        @fastfoot
                                        fastfoot
                                        schrieb am zuletzt editiert von fastfoot
                                        #107
                                        @liv-in-sky sagte in Gerät per Mac Adr & Blockly ansprechen:
                                        @fastfoot
                                        Danke fürs Testen, somit bleibt nur die Fage weshalb es beim Fragesteller doppelt eingetragen wird.
                                        • F fastfoot
                                          @fastfoot
                                          AphofisA Offline
                                          AphofisA Offline
                                          Aphofis
                                          #108
                                          @fastfoot
                                          Also ich hab den DP noch mal neu erstellt und den Blockly Code komplett noch mal neu gemacht und ich hatte mal in der Pi Konsole den Befehl eingegeben und arp postet zweimal den Geräte Namen und keine IP adresse!
                                          arp -a|grep 2c:f4:32:57:b7:14 |cut -f1 -d" "
                                          ergibt in der Konsolen Ausgabe folgendes
                                          Aqua-Control.fritz.box
                                          gebe ich die zweite abfrage in die Konsole ein! kommt das
                                          pi@AquaPi:~ $ arp -a|grep 2c:f4:32:57:b7:14 |cut -f2 -d"("|cut -f1 -d")"
                                          192.168.0.5
                                          192.168.0.57
                                          192.168.0.5
                                          Wieder hat das Gerät in der Fritzbox eine neue IP bekommen vorher war es die 57 jetzt ist es die 5 obwohl die 57 für das Gerät fixiert ist. Ich weiß auch nicht mehr weiter
                                          harrymH 1 Antwort Letzte Antwort
