  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 769.2k Aufrufe 93 Beobachtet
  • M muckel
    so, alles neu gemacht. adapter/instance/objects
    selbes ergebnis:
    broadlink2.0	2020-06-17 19:15:28.539	info	(24020) found macs:
    broadlink2.0	2020-06-17 19:15:28.539	info	(24020) broadlink2.0 started and found 0 devices named
    broadlink2.0	2020-06-17 19:15:28.538	info	(24020) Poll every 30 secods.
    broadlink2.0	2020-06-17 19:15:19.457	info	(24020) sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'}
    broadlink2.0	2020-06-17 19:15:18.995	info	(24020) sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'}
    broadlink2.0	2020-06-17 19:15:18.497	info	(24020) sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'}
    broadlink2.0	2020-06-17 19:15:18.234	info	(24020) UDP socket listening on 0.0.0.0:15001
    broadlink2.0	2020-06-17 19:15:18.231	info	(24020) Discover Broadlink devices for 10sec on broadlink2.0
    broadlink2.0	2020-06-17 19:15:18.230	info	(24020) macObjects: []
    broadlink2.0	2020-06-17 19:15:18.228	info	(24020) Devices to rename:
    broadlink2.0	2020-06-17 19:15:18.228	info	(24020) Devices to add: []
    broadlink2.0	2020-06-17 19:15:18.227	info	(24020) Scanning additional IP's: 192.168.0.140
    broadlink2.0	2020-06-17 19:15:18.226	info	(24020) broadlink2 initialization started...
    broadlink2.0	2020-06-17 19:15:18.073	info	(24020) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.16.2, js-controller: 3.1.5
    frankjokeF Offline
    frankjokeF Offline
    frankjoke
    #748
    @muckel
    Hallo muckel, mit welcher app hast du den mini ins netz geholt? wenn du das mit einer neueren app (die auch Alexa unterstützt) machst dann geht er nicht in broadlink2 da der mini dann in der 'cloud-mode' arbeitet und und er meine Authentifizierungsanfragen nicht beantwortet. Du musst eine alte broadlink-app ( ich verwende e smart home oder e-control ) verwenden und dabei sicherstellen dass dein Handy dabei im2.4GHz-Wlan ist wo auch der RM hin soll.
    Frank,
    NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
    Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
    M 2 Antworten Letzte Antwort
      @muckel ja, ok. Heute installiert, es gab gestern spät ein update, da sind viele Fehler weg..
      muckel
      #749
      @ilovegym
      anscheinend nicht alle fehler.
      du weißt auch nicht mehr weiter?
      • frankjokeF frankjoke
        @muckel
        muckel
        #750
        @frankjoke
        verstehe, das muss ich ausprobieren.
        • M moj090
          @frankjoke
          Ich hab eben nochmal den Adapter über Githup aktualisiert aber bekomme noch immer die Fehlermeldung :(
          broadlink2.0	2020-06-16 20:57:39.874	info	(19554) sendPacket error: could not send after 3 trials!: SendPacketErr { command: 238,cmdHex: '0xee',payload: <Buffer 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00>,err: 'The device storage is full
          frankjokeF Offline
          frankjokeF Offline
          frankjoke
          #751
          @moj090
          Aus irgend einem - mir nicht bekannten - Grund hat dein Gerät intern keinen Speicher mehr :The device storage is full
          Vielleicht hast beim Anlernen ein Problem dass die Taste zu lang sendet oder die Kombination zu lang ist und damit nicht in den Speicher des Gerätes passt.
          Frank,
            @moj090
            muckel
            #752
            @frankjoke
            ich lade gerade e smart home runter und reset :-)
            melde mich wieder
            danke für die tipps
            • Christoph1337C Christoph1337
              @frankjoke
              Okay das scheint zu klappen. Nur bei dem obersten Wert fehlt der "true/false" Wert. Mal gucken ob es trotzdem geht.
              Ich bin gespannt wie sich der Adapter noch weiter entwickelt. Ich finde den SUPER!
              Warum werden die Codes eigentlich immer unter "L" abgelegt?
              Beste Grüße
              frankjokeF Offline
              frankjokeF Offline
              frankjoke
              #753
              @Christoph1337
              Das Fehlen von false/true bedeutet nur dass du wahrscheinlich die taste noch nie gedrückt hast, aber da der state ein Button ist ist es wurst was du sendest, er reagiert bei jedem Schalten/umschalten.
              wegen dem 'L': Das werde ich in der neuen 3.0-Version ändern, dort wird dann für alle RM's in einem zentralen Folder mit benennbaren Unterfoldern und Namen gelernt und alle RM's die der Adapter erkennt können dann auf diese einzige, auch in der Konfig editierbare Basis Zugreifen (und exportieren/importieren).
              Frank,
              Christoph1337C 1 Antwort Letzte Antwort
                @frankjoke
                Hi Frank,
                habe gestern abend die Version von Git gezogen, und bis heute früh nur einen Fehler im Log!
                Die Broadlinks funktionieren nun dauerhaft!
                Super! Vielen Dank.
                Würde vorschlagen, den Adapter so ins latest zu schieben.
                Weitere Änderungen an Datenpunkten oder Config dann für ne neue Rev... oder?
                frankjokeF Offline
                frankjokeF Offline
                frankjoke
                #754
                @ilovegym sagte in Adapter: broadlink2:
                genau das hab ich vor, muss noch readme etwas anpassen und einige Texte und debug/infos ändern aber dann wird er als V2.1 bis zum Wochenende auf latest gehen bevor ich mit 2.9.9 auf einem neuen branch die beta für 3.0 starten werde (in 2-3 Wochen).
                Frank,
                  @muckel
                  muckel
                  #755
                  @frankjoke sagte in Adapter: broadlink2:
                  @muckel
                  Alles erledigt und funktioniert.
                  Danke für den Tipp mit der App.
                  • frankjokeF Offline
                    frankjokeF Offline
                    frankjoke
                    schrieb am zuletzt editiert von frankjoke
                    #756
                    Ok, habe readme und einige andere 'Kleinigkeiten' upgedatet und den Adapter jetzt als 2.1.0 auf git.
                    Habe ihn von dort auf 4 meiner Testsysteme installiert (Windows, Linux und js-controller 2+ und 3+ sowie nodejs 10+ und 12+) installiert und er funktioniert überall.
                    Wenn ich kein negatives feedback von euch krieg dann werd ich morgen ein npm-release von 2.1.0 machen und damit sollte er dann bald als solcher auch auf latest erscheinen.
                    LG!
                    Frank,
                    • systemofapwneS Offline
                      systemofapwne
                      #757
                      Vielen Dank für die Änderungen, besonders das finden von Geräten außerhalb des eigenen Netzwerkes.
                      Allerdings funktioniert dies nicht direkt mit docker Containern, da hier kein bi-direktionales routing stattfindet: Ein docker container kann standardmäßig ohne Probleme in Zugriff auf das host-lan nehmen. Umgekehrt geht dies allerdings nicht.
                      Das Problem liegt nun darin, dass "Broadlink.discover" die IP des jeweiligen hots in das "discover-paket" schreibt. In einem docker container wäre dies die interne docker ip. Das paket wird nun erfolgreich das broadlink Gerät erreichen, diese allerdings wird nun versuchen, eine Antwort an die interne IP des docker container zu senden -> Dies schlägt fehl.
                      Ich habe einen Kommentar mit ausführlichen Beispielen auf github hinzugefügt: https://github.com/frankjoke/ioBroker.broadlink2/issues/79#issuecomment-645655995
                        @Christoph1337
                        Christoph1337C Offline
                        Christoph1337
                        #758
                        @frankjoke Sehr cool! Ich bin gespannt
                        • F Offline
                          Flugschüler
                          #759
                          Bei mir kommt folgende Fehlermeldung:
                          Failed to authenticate device RM4:undefined, 24:df:a7:34:ab:f2, 192.168.1.127 with err TypeError: Cannot read property 'command' of null
                          Broadlink 4 mini wird nicht erkannt, hat jemand eine Idee?
                          frankjokeF 1 Antwort Letzte Antwort
                            Muchul
                            #760
                            Wäre es eventuell sinnvoller für die neue Version einen eigenen Thread zu eröffnen?
                            Hier wird es langsam zu voll.
                              SchuetzeSchulz
                              #761
                              ich habe Probleme beim Einrichten eines States.
                              Ich habe im Objektebaum folgende angelernten Codes:
                              Den State "Klima_Schlafzimmer" (zum Ein- und Ausschalten der Klimaanlage) habe ich wie folgt angelegt:
                              Wenn ich den jedoch schalten will, kommt folgendes im Log:
                              Hat da jemand eine Idee zu?
                              • S SchuetzeSchulz
                                frankjokeF Offline
                                frankjokeF Offline
                                frankjoke
                                #762
                                @SchuetzeSchulz
                                Kannst mal schauen, sehe keinen RM: unter broadlink.0 und dort sollte dann States drunter sein.
                                Wenn du direkt irgendwo states anlegst weiß er nicht mit welchen RM er das senden soll!
                                Frank,
                                • M Muchul
                                  frankjokeF Offline
                                  frankjokeF Offline
                                  frankjoke
                                  #763
                                  @Muchul sagte in Adapter: broadlink2:
                                  Mach ich bei V3.0 dann!
                                  Frank,
                                  • F Flugschüler
                                    frankjokeF Offline
                                    frankjokeF Offline
                                    frankjoke
                                    #764
                                    @Flugschüler sagte in Adapter: broadlink2:
                                    Hast du ein paar Einträge zurück gelesen mit welcher app du den RM4 inst netz geholt hast? die nneuesten Apps funktionieren nicht mit broadlink2!
                                    Frank,
                                      @SchuetzeSchulz
                                      SchuetzeSchulz
                                      #765
                                      @SchuetzeSchulz
                                      Der wurde doch vom Adapter umbenannt.
                                      • P Offline
                                        P-A-L-A-D-I-N
                                        #766
                                        Entschuldigt bitte, wenn ich den Thread mit ein wenig Offtopic störe - aber da hier die geballte Broadlink-Kompetenz versammelt ist, hoffe ich doch, daß Ihr mir bei meinem Problem helfen könnt!
                                        Ich habe Probleme, meine Geräte in die IHC for EU App zu bekommen!
                                        Mein RM Pro und mein RM Pro Plus haben sich ohne Probleme sofort finden und einrichten lassen - mit aktiviertem 5GHz-Netz, 40MHz-Kanalbreite (Autokanal), Standard n+g+b usw. Alles kein Problem; es lief glatt wie in einem Werbevideo! ;-)
                                        Mein erster RM Mini 3 hat, nach etwas "Herumgezicke" ebenfalls ins Netz gefunden. Nummer 2 und 3 allerdings weigern sich vehement, von der App richtig gefunden zu werden!
                                        Ich habe schon zig Neustarts der Fritzbox gemacht, das 5GHz-Netz komplett abgeschaltet, den Standard auf nur b+g gestellt, verschiedene Kanäle manuell ausgewählt (13, 1), um die Bandbreite von 40 auf 20 MHz zu reduzieren,... Ich habe sogar extra mein altes Xperia Z Tablet nochmal ausgegraben, die App dort installiert und es dann (auch direkt neben dem Router) noch gefühlte hundert Mal probiert! Nichts klappt!
                                        In der IHC for EU App werden mir die Geräte mit einem Fragezeichen unter "Device" angezeigt. Sie sind also definitiv vorhanden, werden aber nur eben nicht als RM Mini 3 angezeigt, sondern als unbekanntes oder nicht korrekt eingerichtetes Gerät.
                                        Wenn ich auf das Fragezeichen tippe, kommt der Errorcode 14061 und danach die Meldung, daß meine Internetverbindung zu schlecht sei: "The internet connection is poor. Please check your network connection or try again."
                                        In der Netzwerkübersicht meiner Fritzbox sind die Geräte übrigens jedes Mal sofort aufgetaucht (und es wurden auch entsprechende Einträge unter "Objekte" angelegt) - die Verbindung ins Netzwerk steht also, nur die App möchte da irgendwie nicht mitspielen...
                                        Hat jemand eine Ahnung, was ich noch versuchen könnte, um die RM Minis in die App zu bekommen?
                                          muckel
                                          #767
                                          @frankjoke
                                          Hallo Frank!
                                          Vielleicht kannst du mir nochmals helfen.
                                          Habe noch einen RM4Pro auf welchen ich eine RF-Fernbedienung anlernen wollte.
                                          Der RM4Pro wird im Adapter richtig erkannt, aber lt. LED (orange wie bei IR anlernen?) nicht in den RF-Lernmodus. (keine orange LED) und erkennt mein RF Signal auch nicht.
                                          gibt es da auch einen Trick? Oder muss ich das was umstellen?
                                          danke im Voraus
                                          Liebe Grüße Erich
                                          D frankjokeF 2 Antworten Letzte Antwort
