  4. Test Adapter Shelly v3.1.x
    6.6k
shellyadapter
282 Beiträge 36 Kommentatoren 62.7k Aufrufe 36 Beobachtet
  • G Gsiberger
    @Stuebi
    Habe heute einen Shelly 1 mit externem Modul für Temperaturfühler in Betrieb genommen.
    Die Temperaturwerte werden aber bei den Objekten nicht übernommen:
    Im Debuglog werden Werte aufgeführt:
    2020-04-12 19:55:01.930  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/relay/0 = off
    2020-04-12 19:55:01.931  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/relay/0 / {"type":"Buffer","data":[111,102,102]}
    2020-04-12 19:55:01.931  - debug: shelly.0 (7573) Create State : SHSW-1#F3D6AF#1.Relay0.Switch, Payload: {"type":"Buffer","data":[111,102,102]} for shelly1-F3D6AF
    2020-04-12 19:55:01.931  - debug: shelly.0 (7573) Create State : SHSW-1#F3D6AF#1.Relay0.Switch, Payload: off for shelly1-F3D6AF
    2020-04-12 19:55:01.932  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/input/0 = 0
    2020-04-12 19:55:01.932  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/input/0 / {"type":"Buffer","data":[48]}
    2020-04-12 19:55:01.932  - debug: shelly.0 (7573) Create State : SHSW-1#F3D6AF#1.Relay0.Input, Payload: {"type":"Buffer","data":[48]} for shelly1-F3D6AF
    2020-04-12 19:55:01.933  - debug: shelly.0 (7573) Create State : SHSW-1#F3D6AF#1.Relay0.Input, Payload: 0 for shelly1-F3D6AF
    2020-04-12 19:55:01.933  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/ext_temperature/0 = 48.4
    2020-04-12 19:55:01.933  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/ext_temperature/0 / {"type":"Buffer","data":[52,56,46,52]}
    2020-04-12 19:55:01.934  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/ext_temperature_f/0 = 119.2
    2020-04-12 19:55:01.934  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/ext_temperature_f/0 / {"type":"Buffer","data":[49,49,57,46,50]}
    2020-04-12 19:55:01.934  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/ext_temperature/1 = 43.4
    2020-04-12 19:55:01.935  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/ext_temperature/1 / {"type":"Buffer","data":[52,51,46,52]}
    2020-04-12 19:55:01.935  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/ext_temperature_f/1 = 110.1
    2020-04-12 19:55:01.935  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/ext_temperature_f/1 / {"type":"Buffer","data":[49,49,48,46,49]}
    2020-04-12 19:55:01.936  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/ext_temperature/2 = 14.6
    2020-04-12 19:55:01.936  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/ext_temperature/2 / {"type":"Buffer","data":[49,52,46,54]}
    2020-04-12 19:55:01.936  - debug: shelly.0 (7573) Publish 192.168.1.59 (shelly1 / shelly1-F3D6AF / SHSW-1#F3D6AF#1) payload: shellies/shelly1-F3D6AF/ext_temperature_f/2 = 58.2
    2020-04-12 19:55:01.937  - debug: shelly.0 (7573) MQTT Message for shelly1-F3D6AF : shellies/shelly1-F3D6AF/ext_temperature_f/2 / {"type":"Buffer","data":[53,56,46,50]}
    Das wären die Temperaturen:
    Firmware Shelly: 20200320-123430/v1.6.2@514044b4 (=aktuellste Firmware)
    Version Shelly Adapter: 3.2.3
    Shelly Protokoll: MQTT and http
    StuebiS Offline
    StuebiS Offline
    Stuebi
    #189
    @Gsiberger , Du kannst einmal die Version 3.2.4 von GitHub downloaden und testen. ioBroker Admin Oberfläche öffnen, auf Adapter klicken, über externe URL installieren (GitHub Katze) und dann Shelly auswählen.
    In der Version sollte MQTT mit den ext. temperature funktionieren.
    Bitte kurze Rückmeldung
    ioBroker auf Synology DS216+II im Docker Container
    G 1 Antwort Letzte Antwort
    • harrymH Offline
      harrymH Offline
      harrym
      #190
      @Stuebi wenn du etwas änderst ... denk bitte auch daran, dass auch der DHT22 von dem Addon unterstützt wird. Ich bekomme den Sensor aber erst ab Mittwoch .... kann dir dann gerne weitere Infos liefern.
      ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
      • StuebiS Stuebi
        Gsiberger
        #191
        @Stuebi
        Vielen Dank für die schnelle Bearbeitung
        Kurt
        • E Offline
          erazor86
          #192
          ich habe jetzt auch seit einigen Wochen die Temperatursensoren über den Shelly mit coap eingebunden. Shelly adapterversion ist 3.2.3... funktionier einwandfrei.
          Heute wollte ich jedoch einen Temperatur und Feuchtigkeitssensor einbinden. Die Temperatur wird angezeigt, die Feuchtigkeit jedoch nicht... ist das schon bekannt?
            klassisch
            #193
            Im Shelly-Forum gibt es eine Umfrage zur Anbindung der Shelly-Geräte.
            ioBroker ist ganz vorne mit dabei - Dank diesem prima Adapter!
            • Dr. BakteriusD Online
              Dr. Bakterius
              #194
              Kann vielleicht jemand bei folgendem Problem helfen: https://forum.iobroker.net/topic/34163/shelly-1-status-wird-verzögert-übertragen
                K_o_bold
                #195
                @Stuebi ,
                unterstützt der Adapter schon den neuen Shelly Gas ?
                Ich habe einen davon kürzlich bestellt und er müsste demnächst geliefert werden.. :-)
                StuebiS 1 Antwort Letzte Antwort
                • K K_o_bold
                  @Stuebi ,
                  StuebiS Offline
                  StuebiS Offline
                  Stuebi
                  #196
                  @K_o_bold , der wird momentan nicht unterstützt. Ich muss sehen wie ich es zeitlich schaffe diesen einzubinden.
                  • harrymH Offline
                    harrymH Offline
                    harrym
                    #197
                    @Stuebi ich bekomme mit der Adapterversion 3.2.9 vom RGBW2 im color mode folgede Errormeldungen im Log:
                    2020-06-12 15:38:35.132  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white1.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:35.133  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white2.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:35.133  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white3.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:40.502  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white1.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:40.502  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white2.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:40.502  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white3.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:45.919  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white1.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:45.919  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white2.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    2020-06-12 15:38:45.920  - error: shelly.0 (5330) Error in function httpIoBrokerState for state SHRGBW2#6EAADC#1.white3.ButtonType and request{"url":"http://192.168.178.162/settings","timeout":5000,"headers":{"Authorization":"Basic YWRtaW46TUtnPTE3NmNtIQ=="}} for 192.168.178.162 (shellyrgbw2 / shellyrgbw2-6EAADC / SHRGBW2#6EAADC#1) (TypeError: Cannot read property 'btn_type' of undefined)
                    • harrymH harrym
                      StuebiS Offline
                      StuebiS Offline
                      Stuebi
                      #198
                      @harrym , ja die Version 3.2.9 ist auch noch nicht ganz offiziell. Ich implementiere da noch einige Dinge. Wenn Du die Version 3.2.9 jetzt nochmals installierst sollte der Fehler verschwunden sein.
                      harrymH 1 Antwort Letzte Antwort
                      • StuebiS Stuebi
                        harrymH Offline
                        harrymH Offline
                        harrym
                        #199
                        @Stuebi läuft ;)
                        • StuebiS Stuebi
                          K_o_bold
                          #200
                          @Stuebi , alles klar.
                          Ich stehe gerne für Tests zur Verfügung.
                          Ich habe ihn gestern bekommen.
                          • K K_o_bold
                            StuebiS Offline
                            StuebiS Offline
                            Stuebi
                            #201
                            @K_o_bold , okay, dann schließe einmal Dein Shelly Gas an und stelle den Shelly Adapter auf Debug Modus. Ich benötige die Ausgaben für den Shelly Gas im Logfile (wenn es geht nur die vom Shelly Gas).
                            Du solltest so etwas in der Art sehen:
                            {"G":[[0,66,15],[0,55,0],[0,77,95],[0,88,-1],[0,99,0]]}
                            .SHDW-1#F02FAE#1.{"blk":[{"I":1, "D":"sensors"}],"sen":[{"I":66, "D":"lux", "T":"L", "R":"0/100000", "L":1},{"I":55, "D":"State", "T":"S", "R":"0/1", "L":1},{"I":77, "D":"battery", "T":"B", "R":"0/100", "L":1},{"I":88, "D":"tilt", "T":"S", "R":"0/180", "L":1},{"I":99, "D":"vibration", "T":"S", "R":"0/1", "L":1}]}
                            Am besten die Infos als GitHub Issue erfassen.
                              K_o_bold
                              #202
                              @Stuebi ,
                              ich habe grade ein issue auf github zum Thema Shelly Gas erstellt..
                              • K K_o_bold
                                @Stuebi ,
                                harrymH Offline
                                harrymH Offline
                                harrym
                                #203
                                @K_o_bold gugg bitte nochmals auf den Post von @Stuebi ... adapter in den Debug Modus usw ....
                                • harrymH harrym
                                  K_o_bold
                                  #204
                                  @harrym ,
                                  ich habe es genau so gemacht. Leider findet er kein Gerät.
                                  Das ist die log Ausgabe wenn ich den Adapter starte:
                                  shelly.0	2020-06-17 21:56:27.887	info	(27532) Listening for Shelly packets in the network
                                  shelly.0	2020-06-17 21:56:27.852	info	(27532) Starting Shelly adapter in CoAP modus.
                                  shelly.0	2020-06-17 21:56:27.834	info	(27532) Starting Adapter shelly.0 in version 3.2.8
                                  shelly.0	2020-06-17 21:56:27.820	info	(27532) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.20.1, js-controller: 3.1.4
                                  shelly.0	2020-06-17 21:56:27.735	debug	(27532) Plugin sentry Initialize Plugin (enabled=true)
                                  shelly.0	2020-06-17 21:56:27.489	debug	(27532) statesDB connected
                                  shelly.0	2020-06-17 21:56:27.489	debug	(27532) States connected to redis: 127.0.0.1:6379
                                  shelly.0	2020-06-17 21:56:27.485	debug	(27532) States create System PubSub Client
                                  shelly.0	2020-06-17 21:56:27.483	debug	(27532) States create User PubSub Client
                                  shelly.0	2020-06-17 21:56:27.480	debug	(27532) Redis States: Use Redis connection: 127.0.0.1:6379
                                  shelly.0	2020-06-17 21:56:27.479	debug	(27532) objectDB connected
                                  shelly.0	2020-06-17 21:56:27.475	debug	(27532) Objects connected to redis: 127.0.0.1:9001
                                  shelly.0	2020-06-17 21:56:27.468	debug	(27532) Objects client initialize lua scripts
                                  shelly.0	2020-06-17 21:56:27.468	debug	(27532) Objects create User PubSub Client
                                  shelly.0	2020-06-17 21:56:27.467	debug	(27532) Objects create System PubSub Client
                                  shelly.0	2020-06-17 21:56:27.465	debug	(27532) Objects client ready ... initialize now
                                  shelly.0	2020-06-17 21:56:27.446	debug	(27532) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  host.nuc	2020-06-17 21:56:26.765	info	instance system.adapter.shelly.0 started with pid 27532
                                  • K K_o_bold
                                    @harrym ,
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    #205
                                    @K_o_bold installier dir bitte den shelly adapter 3.3.2 via GIT! du hast noch ne ältere Version.
                                      K_o_bold
                                      #206
                                      auch mit der aktuellsten Version leider ohne Erfolg:
                                      shelly.0	2020-06-17 22:13:22.184	info	(5007) Listening for Shelly packets in the network
                                      shelly.0	2020-06-17 22:13:22.150	info	(5007) Starting Shelly adapter in CoAP modus.
                                      shelly.0	2020-06-17 22:13:22.133	info	(5007) Polltime of the shelly devices: 10 sec.
                                      shelly.0	2020-06-17 22:13:22.133	info	(5007) Starting Adapter shelly.0 in version 3.3.2
                                      shelly.0	2020-06-17 22:13:22.119	info	(5007) starting. Version 3.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.20.1, js-controller: 3.1.4
                                      shelly.0	2020-06-17 22:13:22.035	debug	(5007) Plugin sentry Initialize Plugin (enabled=true)
                                      shelly.0	2020-06-17 22:13:21.861	debug	(5007) statesDB connected
                                      shelly.0	2020-06-17 22:13:21.861	debug	(5007) States connected to redis: 127.0.0.1:6379
                                      shelly.0	2020-06-17 22:13:21.857	debug	(5007) States create System PubSub Client
                                      shelly.0	2020-06-17 22:13:21.856	debug	(5007) States create User PubSub Client
                                      shelly.0	2020-06-17 22:13:21.853	debug	(5007) Redis States: Use Redis connection: 127.0.0.1:6379
                                      shelly.0	2020-06-17 22:13:21.851	debug	(5007) objectDB connected
                                      shelly.0	2020-06-17 22:13:21.847	debug	(5007) Objects connected to redis: 127.0.0.1:9001
                                      shelly.0	2020-06-17 22:13:21.840	debug	(5007) Objects client initialize lua scripts
                                      shelly.0	2020-06-17 22:13:21.840	debug	(5007) Objects create User PubSub Client
                                      shelly.0	2020-06-17 22:13:21.839	debug	(5007) Objects create System PubSub Client
                                      shelly.0	2020-06-17 22:13:21.837	debug	(5007) Objects client ready ... initialize now
                                      shelly.0	2020-06-17 22:13:21.820	debug	(5007) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.nuc	2020-06-17 22:13:21.213	info	instance system.adapter.shelly.0 started with pid 5007
                                      • K K_o_bold
                                        harrymH Offline
                                        harrymH Offline
                                        harrym
                                        schrieb am zuletzt editiert von harrym
                                        #207
                                        @K_o_bold stell den adapter bitte von info auf debug um .... unter instanzen, expertenmodus ... dann auf debug wechseln.
                                        • harrymH harrym
                                          K_o_bold
                                          schrieb am zuletzt editiert von K_o_bold
                                          #208
                                          @harrym ,
                                          die logs die ich gepostet habe, wurden aus dem debug modus erzeugt.
                                          Die COAP Einstellungen im Adapter sehen wie folgt aus:
                                          Und der Shelly GAS ist nicht im mqtt Modus
