  4. Lichtschalter und iobroker und manuelles auslösen
    2.8k
    4.8k
    4.1k
how-tovis
70 Beiträge 2 Kommentatoren 8.5k Aufrufe 2 Beobachtet
  • E Ente
    @CrunkFX
    Und deployed ist es auch.
    CrunkFXC Offline
    CrunkFXC Offline
    CrunkFX
    Forum Testing
    @Ente Also nachmal:
    [{"id":"eeaafec1.64e1c8","type":"ioBroker in","z":"816d1036.bc2a78","name":"","topic":"0_userdata.0.example_state.Test","payloadType":"value","onlyack":"","func":"rbe","gap":"","fireOnStart":"false","x":550,"y":260,"wires":[["a0eca12f.40b61"]]},{"id":"1ee747f3.f1012","type":"ioBroker out","z":"816d1036.bc2a78","name":"","topic":"0_userdata.0.example_state.Test","ack":"false","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":1320,"y":320,"wires":[]},{"id":"8ee7ecff.83d5a8","type":"ewelink-power-state-read","z":"816d1036.bc2a78","name":"","deviceId":"1000519e49","channel":1,"auth":"","x":680,"y":320,"wires":[["884e67c2.8507a8"]]},{"id":"75ded6ec.b0fc7","type":"ewelink-power-state-write","z":"816d1036.bc2a78","name":"","deviceId":"1000519e49","channel":1,"auth":"","x":1300,"y":260,"wires":[object Object]},{"id":"6789feab.7e625","type":"inject","z":"816d1036.bc2a78","name":"","topic":"","payload":" ","payloadType":"str","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":490,"y":320,"wires":[["8ee7ecff.83d5a8"]]},{"id":"884e67c2.8507a8","type":"switch","z":"816d1036.bc2a78","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"on","vt":"str"},{"t":"cont","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":870,"y":320,"wires":[["60c17500.006144"],["c79b99e8.9954a"]]},{"id":"60c17500.006144","type":"change","z":"816d1036.bc2a78","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":300,"wires":[["1ee747f3.f1012"]]},{"id":"c79b99e8.9954a","type":"change","z":"816d1036.bc2a78","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":340,"wires":[["1ee747f3.f1012"]]},{"id":"a0eca12f.40b61","type":"change","z":"816d1036.bc2a78","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":260,"wires":[["75ded6ec.b0fc7"]]}]
    E 1 Antwort Letzte Antwort
    • CrunkFXC CrunkFX
      @Ente Also nachmal:
      Ente
      deployed.
      CrunkFXC 1 Antwort Letzte Antwort
      • E Ente
        deployed.
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        @Ente OK passiert irgendwas? Siehst du irgendwo werte?
        • CrunkFXC CrunkFX
          Ente
          @CrunkFX
          Böde Frage, wo soll ich denn die Werte sehen? Muss ich irgendwas in IOB oder vis integrieren?
          • E Ente
            @CrunkFX
            CrunkFXC Offline
            CrunkFXC Offline
            CrunkFX
            Forum Testing
            @Ente Nein wenn dort Werte rauskommen, stehen die unter dem State, bei dir hier:1cd34157-096b-435e-ae64-713488121280-grafik.png
            • CrunkFXC CrunkFX
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              @Ente importier das mal, drück den Knopf links und zeig was im Debug fenster steht
              [{"id":"8ee7ecff.83d5a8","type":"ewelink-power-state-read","z":"816d1036.bc2a78","name":"","deviceId":"1000519e49","channel":1,"auth":"","x":660,"y":500,"wires":[["b7be1488.deabe"]]},{"id":"6789feab.7e625","type":"inject","z":"816d1036.bc2a78","name":"","topic":"","payload":"<-- Da klicken","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":430,"y":500,"wires":[["8ee7ecff.83d5a8"]]},{"id":"b7be1488.deabe","type":"debug","z":"816d1036.bc2a78","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":900,"y":500,"wires":[]}]
              • CrunkFXC CrunkFX
                Ente
                • E Ente
                  Ente
                  Das steht im IOB
                  • E Ente
                    Das steht im IOB
                    Ente
                    Können wir morgen weiter machen. Mein 5jähriger stand grad da, schlecht geträumt. Ich kümmere mich mal um ihn.
                    Bitte nicht falsch verstehen, ist echt krass, Deine Unterstützung. :-)👍
                    CrunkFXC 2 Antworten Letzte Antwort
                    • E Ente
                      CrunkFXC Offline
                      CrunkFXC Offline
                      CrunkFX
                      Forum Testing
                      @Ente Gar kein Problem. Dann werde ich morgen mal 2 Sonoff geräte rauskramen und via Ewelink mitmachen vielleich findet sich ja eine einfache lösung.
                      • E Ente
                        CrunkFXC Offline
                        CrunkFXC Offline
                        CrunkFX
                        Forum Testing
                        @Ente Ich hab mal bei mit einen Sonoff 4ch R2 in eWeLink eingebunden. Die API ist wirklich sehr schlecht von eWeLink. Das könnte einder der gründe sein warum das vorher bei dir nicht funktioniert hat. Wie auch immer, ich hab mir einen kleinen Flow gebastelt, mit dem schalten und abfragen in einem Datenpunkt möglich ist. Wichtig ist das der Taster nicht schnell hintereinander betätigt oder abgefragt wird, da sonst "Err 503" kommt. Probier mal diesen Flow aus, ich sollte alle deine Angaben korrekt eingefügt haben, du kannst aber gerne nochmal nachschauen ob Device ID und IOB Datenpunkt korrekt sind.
                        [{"id":"95fe1d43.5b40e","type":"ioBroker in","z":"816d1036.bc2a78","name":"IOB Datenpunkt","topic":"0_userdata.0.example_state.Test","payloadType":"value","onlyack":"","func":"rbe","gap":"","fireOnStart":"false","x":340,"y":160,"wires":[["33ce8287.5bc756"]]},{"id":"32a2cf7a.f26bd","type":"ioBroker out","z":"816d1036.bc2a78","name":"IOB Datenpunkt","topic":"0_userdata.0.example_state.Text","ack":"false","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":980,"y":280,"wires":[]},{"id":"11450bfd.8107c4","type":"ewelink-power-state-read","z":"816d1036.bc2a78","name":"Zustand abfragen","deviceId":"1000519e49","channel":1,"auth":"f9622a6.c35c9d8","x":550,"y":220,"wires":[["b9390314.6cf9f"]]},{"id":"dc47e9fb.4654","type":"ewelink-power-state-write","z":"816d1036.bc2a78","name":"eWeLink Status senden","deviceId":"1000519e49","channel":1,"auth":"f9622a6.c35c9d8","x":1070,"y":160,"wires":[object Object]},{"id":"33ce8287.5bc756","type":"change","z":"816d1036.bc2a78","name":"Werte konvertieren","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":160,"wires":[["f6d231f2.e928f"]]},{"id":"c1a8c003.a50b8","type":"change","z":"816d1036.bc2a78","name":"An in Bool konvertieren","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":260,"wires":[["32a2cf7a.f26bd"]]},{"id":"fc6b2932.787fb8","type":"switch","z":"816d1036.bc2a78","name":"On Off Filter","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"on","vt":"str"},{"t":"cont","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":990,"y":220,"wires":[["c1a8c003.a50b8"],["33c0bd48.c102e2"]]},{"id":"33c0bd48.c102e2","type":"change","z":"816d1036.bc2a78","name":"Aus in Bool konvertieren","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":300,"wires":[["32a2cf7a.f26bd"]]},{"id":"b9390314.6cf9f","type":"json","z":"816d1036.bc2a78","name":"JSON in String konvertieren","property":"payload","action":"","pretty":false,"x":780,"y":220,"wires":[["fc6b2932.787fb8"]]},{"id":"9979a035.4da09","type":"ewelink-event-listener","z":"816d1036.bc2a78","name":"Änderung abfragen","deviceId":"1000519e49","auth":"f9622a6.c35c9d8","x":350,"y":220,"wires":[["11450bfd.8107c4","aabd4846.2161e8"]]},{"id":"57fcee70.43879","type":"change","z":"816d1036.bc2a78","name":"Zustandsüberwachung unterbrechen","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":360,"wires":[object Object]},{"id":"aabd4846.2161e8","type":"trigger","z":"816d1036.bc2a78","op1":"ok","op2":"nok","op1type":"str","op2type":"str","duration":"300","extend":false,"units":"ms","reset":"","bytopic":"all","name":"","x":540,"y":360,"wires":[["57fcee70.43879"]]},{"id":"f6d231f2.e928f","type":"switch","z":"816d1036.bc2a78","name":"Zustandsüberwachung unterbrechen","property":"payload","propertyType":"flow","rules":[{"t":"neq","v":"ok","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":790,"y":160,"wires":[["dc47e9fb.4654"],[]]},{"id":"f9622a6.c35c9d8","type":"ewelink-credentials","z":""}]
                        MFG
                        CrunkFX
                        • CrunkFXC CrunkFX
                          MFG
                          CrunkFX
                          Ente
                          @CrunkFX said in Lichtschalter und iobroker und manuelles auslösen:
                          Danke für den Flow. Habe ihn importiert. Alles auf grün:
                          Der node Auslöser 300 macht kurz einen grünen Punkt, wenn ich das Licht via Alexa schalte.
                          Bei object, object ändert sich nichts.
                          Was mache ich als nächsten Schritt?
                          • E Ente
                            CrunkFXC Offline
                            CrunkFXC Offline
                            CrunkFX
                            Forum Testing
                            schrieb am zuletzt editiert von CrunkFX
                            @Ente OK setz mal einen debug node darein und verbinde ihn mit der rechten seite von Zustand abfragen
                            Dann wieder rechts in dem fenster mit der Wanze ein Foto machen
                            • CrunkFXC CrunkFX
                              Ente
                              @CrunkFX
                              Interressanterweise ist Änderung abfagen = disconnected und die anderen beiden connected. Wenn ich Änderung abfragen connecte, werden die anderen beiden disconnected.
                              Alle 3 connecten bekomme ich nicht mehr hin.
                              • E Ente
                                @CrunkFX
                                CrunkFXC Offline
                                CrunkFXC Offline
                                CrunkFX
                                Forum Testing
                                @Ente Kannst du mal direkt am schalter schalten?
                                • CrunkFXC CrunkFX
                                  Ente
                                  @CrunkFX
                                  Nur wenn "Änderung abfragen" auf connected steht - die anderen beiden sind dann disconnected - reagiert "Auslöser" auf den manuellen Schaltvorgang.
                                  • E Ente
                                    @CrunkFX
                                    CrunkFXC Offline
                                    CrunkFXC Offline
                                    CrunkFX
                                    Forum Testing
                                    @Ente Merkwürdig probier mal:
                                    [{"id":"2c6f1c60.9ed564","type":"inject","z":"4de100fa.230358","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":89.10000610351562,"y":63,"wires":[["e58321fc.b31aa"]]},{"id":"e58321fc.b31aa","type":"ewelink-power-state-write","z":"4de100fa.230358","name":"","deviceId":"","channel":1,"auth":"","x":290.10000228881836,"y":63.38750648498535,"wires":[["b70fe210.fdb2"]]},{"id":"b70fe210.fdb2","type":"debug","z":"4de100fa.230358","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":512,"y":61,"wires":[]}]
                                    und trage einmal mauell alle Werte ein. Die devive ID kannst du auch in der ewelink app sehen
                                    • CrunkFXC CrunkFX
                                      Ente
                                      #66
                                      @CrunkFX
                                      • E Ente
                                        @CrunkFX
                                        CrunkFXC Offline
                                        CrunkFXC Offline
                                        CrunkFX
                                        Forum Testing
                                        #67
                                        @Ente Zumindest einmal hat er den State bekommen. Hast du bei den credentials als region eu eingegeben?
                                        • CrunkFXC CrunkFX
                                          Ente
                                          #68
                                          @CrunkFX
                                          Ja, und diese Meldung kommt jetzt:
                                          11.6.2020, 19:06:17node: eWeLink Status senden
                                          msg : error
                                          "TypeError: Cannot convert undefined or null to object"
