  4. Lichtschalter und iobroker und manuelles auslösen
    2.8k
    4.8k
    4.1k
how-tovis
70 Beiträge 2 Kommentatoren 8.5k Aufrufe 2 Beobachtet
  • E Ente
    CrunkFXC Offline
    CrunkFXC Offline
    CrunkFX
    Forum Testing
    @Ente Wenn du test gegen Test getauscht hast kannst du das ja mal testen. Werte auslesen und schalten in einem Datenpunkt ist in Nodered sehr kompliziert. evtl. lösen wir das gleich anders
    E 1 Antwort Letzte Antwort
    • CrunkFXC CrunkFX
      Ente
      @CrunkFX
      Und deployed ist es auch.
      CrunkFXC 2 Antworten Letzte Antwort
      • E Ente
        @CrunkFX
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        @Ente OK ich sehe gerade in der API das da kein string rauskommt sonder ein json element. Das muss gesondert behandelt werden.
        • E Ente
          @CrunkFX
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          @Ente Also nachmal:
          [{"id":"eeaafec1.64e1c8","type":"ioBroker in","z":"816d1036.bc2a78","name":"","topic":"0_userdata.0.example_state.Test","payloadType":"value","onlyack":"","func":"rbe","gap":"","fireOnStart":"false","x":550,"y":260,"wires":[["a0eca12f.40b61"]]},{"id":"1ee747f3.f1012","type":"ioBroker out","z":"816d1036.bc2a78","name":"","topic":"0_userdata.0.example_state.Test","ack":"false","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":1320,"y":320,"wires":[]},{"id":"8ee7ecff.83d5a8","type":"ewelink-power-state-read","z":"816d1036.bc2a78","name":"","deviceId":"1000519e49","channel":1,"auth":"","x":680,"y":320,"wires":[["884e67c2.8507a8"]]},{"id":"75ded6ec.b0fc7","type":"ewelink-power-state-write","z":"816d1036.bc2a78","name":"","deviceId":"1000519e49","channel":1,"auth":"","x":1300,"y":260,"wires":[object Object]},{"id":"6789feab.7e625","type":"inject","z":"816d1036.bc2a78","name":"","topic":"","payload":" ","payloadType":"str","repeat":"1","crontab":"","once":false,"onceDelay":0.1,"x":490,"y":320,"wires":[["8ee7ecff.83d5a8"]]},{"id":"884e67c2.8507a8","type":"switch","z":"816d1036.bc2a78","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"on","vt":"str"},{"t":"cont","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":870,"y":320,"wires":[["60c17500.006144"],["c79b99e8.9954a"]]},{"id":"60c17500.006144","type":"change","z":"816d1036.bc2a78","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":300,"wires":[["1ee747f3.f1012"]]},{"id":"c79b99e8.9954a","type":"change","z":"816d1036.bc2a78","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":340,"wires":[["1ee747f3.f1012"]]},{"id":"a0eca12f.40b61","type":"change","z":"816d1036.bc2a78","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":260,"wires":[["75ded6ec.b0fc7"]]}]
          • CrunkFXC CrunkFX
            @Ente Also nachmal:
            Ente
            deployed.
            CrunkFXC 1 Antwort Letzte Antwort
            • E Ente
              deployed.
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              @Ente OK passiert irgendwas? Siehst du irgendwo werte?
              • CrunkFXC CrunkFX
                Ente
                @CrunkFX
                Böde Frage, wo soll ich denn die Werte sehen? Muss ich irgendwas in IOB oder vis integrieren?
                • E Ente
                  @CrunkFX
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @Ente Nein wenn dort Werte rauskommen, stehen die unter dem State, bei dir hier:1cd34157-096b-435e-ae64-713488121280-grafik.png
                  • CrunkFXC CrunkFX
                    CrunkFXC Offline
                    CrunkFXC Offline
                    CrunkFX
                    Forum Testing
                    @Ente importier das mal, drück den Knopf links und zeig was im Debug fenster steht
                    [{"id":"8ee7ecff.83d5a8","type":"ewelink-power-state-read","z":"816d1036.bc2a78","name":"","deviceId":"1000519e49","channel":1,"auth":"","x":660,"y":500,"wires":[["b7be1488.deabe"]]},{"id":"6789feab.7e625","type":"inject","z":"816d1036.bc2a78","name":"","topic":"","payload":"<-- Da klicken","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":430,"y":500,"wires":[["8ee7ecff.83d5a8"]]},{"id":"b7be1488.deabe","type":"debug","z":"816d1036.bc2a78","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":900,"y":500,"wires":[]}]
                    • CrunkFXC CrunkFX
                      Ente
                      • E Ente
                        Ente
                        Das steht im IOB
                        • E Ente
                          Das steht im IOB
                          Ente
                          Können wir morgen weiter machen. Mein 5jähriger stand grad da, schlecht geträumt. Ich kümmere mich mal um ihn.
                          Bitte nicht falsch verstehen, ist echt krass, Deine Unterstützung. :-)👍
                          • E Ente
                            CrunkFXC Offline
                            CrunkFXC Offline
                            CrunkFX
                            Forum Testing
                            @Ente Gar kein Problem. Dann werde ich morgen mal 2 Sonoff geräte rauskramen und via Ewelink mitmachen vielleich findet sich ja eine einfache lösung.
                            • E Ente
                              CrunkFXC Offline
                              CrunkFXC Offline
                              CrunkFX
                              Forum Testing
                              @Ente Ich hab mal bei mit einen Sonoff 4ch R2 in eWeLink eingebunden. Die API ist wirklich sehr schlecht von eWeLink. Das könnte einder der gründe sein warum das vorher bei dir nicht funktioniert hat. Wie auch immer, ich hab mir einen kleinen Flow gebastelt, mit dem schalten und abfragen in einem Datenpunkt möglich ist. Wichtig ist das der Taster nicht schnell hintereinander betätigt oder abgefragt wird, da sonst "Err 503" kommt. Probier mal diesen Flow aus, ich sollte alle deine Angaben korrekt eingefügt haben, du kannst aber gerne nochmal nachschauen ob Device ID und IOB Datenpunkt korrekt sind.
                              [{"id":"95fe1d43.5b40e","type":"ioBroker in","z":"816d1036.bc2a78","name":"IOB Datenpunkt","topic":"0_userdata.0.example_state.Test","payloadType":"value","onlyack":"","func":"rbe","gap":"","fireOnStart":"false","x":340,"y":160,"wires":[["33ce8287.5bc756"]]},{"id":"32a2cf7a.f26bd","type":"ioBroker out","z":"816d1036.bc2a78","name":"IOB Datenpunkt","topic":"0_userdata.0.example_state.Text","ack":"false","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":980,"y":280,"wires":[]},{"id":"11450bfd.8107c4","type":"ewelink-power-state-read","z":"816d1036.bc2a78","name":"Zustand abfragen","deviceId":"1000519e49","channel":1,"auth":"f9622a6.c35c9d8","x":550,"y":220,"wires":[["b9390314.6cf9f"]]},{"id":"dc47e9fb.4654","type":"ewelink-power-state-write","z":"816d1036.bc2a78","name":"eWeLink Status senden","deviceId":"1000519e49","channel":1,"auth":"f9622a6.c35c9d8","x":1070,"y":160,"wires":[object Object]},{"id":"33ce8287.5bc756","type":"change","z":"816d1036.bc2a78","name":"Werte konvertieren","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":160,"wires":[["f6d231f2.e928f"]]},{"id":"c1a8c003.a50b8","type":"change","z":"816d1036.bc2a78","name":"An in Bool konvertieren","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":260,"wires":[["32a2cf7a.f26bd"]]},{"id":"fc6b2932.787fb8","type":"switch","z":"816d1036.bc2a78","name":"On Off Filter","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"on","vt":"str"},{"t":"cont","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":990,"y":220,"wires":[["c1a8c003.a50b8"],["33c0bd48.c102e2"]]},{"id":"33c0bd48.c102e2","type":"change","z":"816d1036.bc2a78","name":"Aus in Bool konvertieren","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":300,"wires":[["32a2cf7a.f26bd"]]},{"id":"b9390314.6cf9f","type":"json","z":"816d1036.bc2a78","name":"JSON in String konvertieren","property":"payload","action":"","pretty":false,"x":780,"y":220,"wires":[["fc6b2932.787fb8"]]},{"id":"9979a035.4da09","type":"ewelink-event-listener","z":"816d1036.bc2a78","name":"Änderung abfragen","deviceId":"1000519e49","auth":"f9622a6.c35c9d8","x":350,"y":220,"wires":[["11450bfd.8107c4","aabd4846.2161e8"]]},{"id":"57fcee70.43879","type":"change","z":"816d1036.bc2a78","name":"Zustandsüberwachung unterbrechen","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":360,"wires":[object Object]},{"id":"aabd4846.2161e8","type":"trigger","z":"816d1036.bc2a78","op1":"ok","op2":"nok","op1type":"str","op2type":"str","duration":"300","extend":false,"units":"ms","reset":"","bytopic":"all","name":"","x":540,"y":360,"wires":[["57fcee70.43879"]]},{"id":"f6d231f2.e928f","type":"switch","z":"816d1036.bc2a78","name":"Zustandsüberwachung unterbrechen","property":"payload","propertyType":"flow","rules":[{"t":"neq","v":"ok","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":790,"y":160,"wires":[["dc47e9fb.4654"],[]]},{"id":"f9622a6.c35c9d8","type":"ewelink-credentials","z":""}]
                              MFG
                              CrunkFX
                              • CrunkFXC CrunkFX
                                MFG
                                CrunkFX
                                Ente
                                @CrunkFX said in Lichtschalter und iobroker und manuelles auslösen:
                                Danke für den Flow. Habe ihn importiert. Alles auf grün:
                                Der node Auslöser 300 macht kurz einen grünen Punkt, wenn ich das Licht via Alexa schalte.
                                Bei object, object ändert sich nichts.
                                Was mache ich als nächsten Schritt?
                                • E Ente
                                  CrunkFXC Offline
                                  CrunkFXC Offline
                                  CrunkFX
                                  Forum Testing
                                  schrieb am zuletzt editiert von CrunkFX
                                  @Ente OK setz mal einen debug node darein und verbinde ihn mit der rechten seite von Zustand abfragen
                                  Dann wieder rechts in dem fenster mit der Wanze ein Foto machen
                                  • CrunkFXC CrunkFX
                                    Ente
                                    @CrunkFX
                                    Interressanterweise ist Änderung abfagen = disconnected und die anderen beiden connected. Wenn ich Änderung abfragen connecte, werden die anderen beiden disconnected.
                                    Alle 3 connecten bekomme ich nicht mehr hin.
                                    • E Ente
                                      @CrunkFX
                                      CrunkFXC Offline
                                      CrunkFXC Offline
                                      CrunkFX
                                      Forum Testing
                                      @Ente Kannst du mal direkt am schalter schalten?
                                      • CrunkFXC CrunkFX
                                        Ente
                                        @CrunkFX
                                        Nur wenn "Änderung abfragen" auf connected steht - die anderen beiden sind dann disconnected - reagiert "Auslöser" auf den manuellen Schaltvorgang.
                                        • E Ente
                                          @CrunkFX
                                          CrunkFXC Offline
                                          CrunkFXC Offline
                                          CrunkFX
                                          Forum Testing
                                          @Ente Merkwürdig probier mal:
                                          [{"id":"2c6f1c60.9ed564","type":"inject","z":"4de100fa.230358","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":89.10000610351562,"y":63,"wires":[["e58321fc.b31aa"]]},{"id":"e58321fc.b31aa","type":"ewelink-power-state-write","z":"4de100fa.230358","name":"","deviceId":"","channel":1,"auth":"","x":290.10000228881836,"y":63.38750648498535,"wires":[["b70fe210.fdb2"]]},{"id":"b70fe210.fdb2","type":"debug","z":"4de100fa.230358","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":512,"y":61,"wires":[]}]
                                          und trage einmal mauell alle Werte ein. Die devive ID kannst du auch in der ewelink app sehen
