Adapter: broadlink2
@frankjoke
Jetzt funktioniert alles, ohne jegliche Fehlermeldungen.
Dankeschön! -
Habe garade auf die aktuelle Beta 2.0.9 geupdatet. Ist ein RM3pro+
Hier die Logausgaben zum Adapter. Anlernmodus lässt sich nicht aktivieren.broadlink2.0 2020-06-08 11:42:15.043 warn (24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.Learn=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609335037,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 159144 broadlink2.0 2020-06-08 11:41:23.893 warn (24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609283886,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591 broadlink2.0 2020-06-08 11:40:36.006 info (24205) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87 broadlink2.0 2020-06-08 11:40:36.005 warn (24205) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' } broadlink2.0 2020-06-08 11:38:57.813 info (24205) found macs: 34:ea:34:4a:2e:b8 broadlink2.0 2020-06-08 11:38:57.812 info (24205) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:38:57.812 info (24205) Poll every 30 secods. broadlink2.0 2020-06-08 11:38:49.945 info (24205) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 11:38:49.812 info (24205) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 11:38:49.806 info (24205) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 11:38:49.784 info (24205) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ] broadlink2.0 2020-06-08 11:38:49.781 info (24205) Devices to rename: broadlink2.0 2020-06-08 11:38:49.780 info (24205) Devices to add: broadlink2.0 2020-06-08 11:38:49.775 info (24205) broadlink2 initialization started... broadlink2.0 2020-06-08 11:38:49.647 info (24205) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4 broadlink2.0 2020-06-08 11:38:43.270 error at processImmediate (timers.js:658:5) broadlink2.0 2020-06-08 11:38:43.270 error at tryOnImmediate (timers.js:676:5) broadlink2.0 2020-06-08 11:38:43.270 error at runCallback (timers.js:706:11) broadlink2.0 2020-06-08 11:38:43.270 error at Broadlink.parsePublic (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:1194:28) broadlink2.0 2020-06-08 11:38:43.270 error (696) TypeError: Cannot read property '34:ea:34:4a:2e:b8' of null broadlink2.0 2020-06-08 11:38:43.269 error (696) uncaught exception: Cannot read property '34:ea:34:4a:2e:b8' of null broadlink2.0 2020-06-08 11:38:42.996 warn (696) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 11:38:42.992 info (696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 11:38:42.990 info (696) terminating broadlink2.0 2020-06-08 11:38:42.983 info (696) Close all connections... broadlink2.0 2020-06-08 11:38:42.982 info (696) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 11:38:42.968 info (696) Got terminate signal TERMINATE_YOURSELFEdit: Anlernmodus starten wohl jetzt mit _Lern & _LernRF (Unterstrich davor - Neue Buttons)
Es wird auch in den Anlernmodus gegangen (rot LED am RM3pro+ leuchtet)
Ich bekomme aber leider keine Taste angelernt.broadlink2.0 2020-06-08 12:04:21.368 info (25263) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87 broadlink2.0 2020-06-08 12:04:21.368 warn (25263) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' } broadlink2.0 2020-06-08 12:04:15.572 info (25263) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87 broadlink2.0 2020-06-08 12:04:15.571 warn (25263) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' } broadlink2.0 2020-06-08 12:03:47.511 warn (25263) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.SendCode=RM:RMPROPLUS-4a-2e-b8 { val:'b2058403180b0c18170c0c18170b0c18170c0c181700021104000128992f0c170c180b18180c0b180b180c18170c0c170c180b1 broadlink2.0 2020-06-08 12:03:34.312 warn (25263) Code to send to RM:RMPROPLUS-4a-2e-b8 needs to start with CODE_ broadlink2.0 2020-06-08 12:03:25.316 warn (25263) Code to send to RM:RMPROPLUS-4a-2e-b8 needs to start with CODE_ broadlink2.0 2020-06-08 12:01:37.203 warn (25263) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/ broadlink2.0 2020-06-08 12:01:37.089 info (25263) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 12:01:37.043 info (25263) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 12:00:49.145 info (25263) found macs: 34:ea:34:4a:2e:b8 broadlink2.0 2020-06-08 12:00:49.144 info (25263) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 12:00:49.144 info (25263) Poll every 30 secods. broadlink2.0 2020-06-08 12:00:41.302 info (25263) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 12:00:41.152 info (25263) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 12:00:41.147 info (25263) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 12:00:41.129 info (25263) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ] broadlink2.0 2020-06-08 12:00:41.125 info (25263) Devices to rename: broadlink2.0 2020-06-08 12:00:41.125 info (25263) Devices to add: broadlink2.0 2020-06-08 12:00:41.121 info (25263) broadlink2 initialization started... broadlink2.0 2020-06-08 12:00:40.973 info (25263) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4 broadlink2.0 2020-06-08 12:00:36.139 warn (25102) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 12:00:36.139 info (25102) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 12:00:36.138 info (25102) terminating broadlink2.0 2020-06-08 12:00:36.136 info (25102) Close all connections... broadlink2.0 2020-06-08 12:00:36.135 info (25102) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 12:00:36.134 info (25102) Got terminate signal TERMINATE_YOURSELF broadlink2.0 2020-06-08 11:59:55.317 warn (25102) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:59:55.315 warn (25102) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:58:39.943 warn (25102) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/ broadlink2.0 2020-06-08 11:58:39.820 info (25102) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:58:39.770 info (25102) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:58:30.507 info (25102) found macs: 34:ea:34:4a:2e:b8 broadlink2.0 2020-06-08 11:58:30.506 info (25102) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:58:30.505 info (25102) Poll every 30 secods. broadlink2.0 2020-06-08 11:58:22.646 info (25102) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 11:58:22.444 info (25102) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 11:58:22.439 info (25102) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 11:58:22.421 info (25102) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ] broadlink2.0 2020-06-08 11:58:22.417 info (25102) Devices to rename: broadlink2.0 2020-06-08 11:58:22.416 info (25102) Devices to add: broadlink2.0 2020-06-08 11:58:22.411 info (25102) broadlink2 initialization started... broadlink2.0 2020-06-08 11:58:22.254 info (25102) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4 broadlink2.0 2020-06-08 11:58:17.356 warn (25026) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 11:58:17.356 info (25026) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 11:58:17.355 info (25026) terminating broadlink2.0 2020-06-08 11:58:17.353 info (25026) Close all connections... broadlink2.0 2020-06-08 11:58:17.352 info (25026) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 11:58:17.351 info (25026) Got terminate signal TERMINATE_YOURSELF broadlink2.0 2020-06-08 11:58:09.197 warn (25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:58:09.196 warn (25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:58:04.236 warn (25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:58:04.235 warn (25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:57:37.335 warn (25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:57:37.332 warn (25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:56:53.917 warn (25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/ broadlink2.0 2020-06-08 11:56:52.947 info (25026) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:56:52.900 info (25026) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:56:49.729 info (25026) found macs: 34:ea:34:4a:2e:b8 broadlink2.0 2020-06-08 11:56:49.729 info (25026) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:56:49.728 info (25026) Poll every 30 secods. broadlink2.0 2020-06-08 11:56:41.899 info (25026) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 11:56:41.187 info (25026) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 11:56:41.181 info (25026) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 11:56:41.163 info (25026) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ] broadlink2.0 2020-06-08 11:56:41.159 info (25026) Devices to rename: broadlink2.0 2020-06-08 11:56:41.158 info (25026) Devices to add: broadlink2.0 2020-06-08 11:56:41.153 info (25026) broadlink2 initialization started... broadlink2.0 2020-06-08 11:56:40.975 info (25026) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4 broadlink2.0 2020-06-08 11:56:36.247 warn (24899) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 11:56:36.247 info (24899) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 11:56:36.246 info (24899) terminating broadlink2.0 2020-06-08 11:56:36.243 info (24899) Close all connections... broadlink2.0 2020-06-08 11:56:36.243 info (24899) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 11:56:36.241 info (24899) Got terminate signal TERMINATE_YOURSELF broadlink2.0 2020-06-08 11:55:12.308 warn (24899) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/ broadlink2.0 2020-06-08 11:55:11.351 info (24899) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:55:11.305 info (24899) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:55:07.742 info (24899) found macs: 34:ea:34:4a:2e:b8 broadlink2.0 2020-06-08 11:55:07.741 info (24899) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:55:07.741 info (24899) Poll every 30 secods. broadlink2.0 2020-06-08 11:54:59.891 info (24899) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 11:54:59.731 info (24899) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 11:54:59.725 info (24899) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 11:54:59.700 info (24899) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ] broadlink2.0 2020-06-08 11:54:59.696 info (24899) Devices to rename: broadlink2.0 2020-06-08 11:54:59.695 info (24899) Devices to add: broadlink2.0 2020-06-08 11:54:59.691 info (24899) broadlink2 initialization started... broadlink2.0 2020-06-08 11:54:59.528 info (24899) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4 broadlink2.0 2020-06-08 11:54:54.694 warn (24790) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 11:54:54.693 info (24790) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 11:54:54.692 info (24790) terminating broadlink2.0 2020-06-08 11:54:54.690 info (24790) Close all connections... broadlink2.0 2020-06-08 11:54:54.690 info (24790) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 11:54:54.688 info (24790) Got terminate signal TERMINATE_YOURSELF broadlink2.0 2020-06-08 11:54:09.692 warn (24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._Learn = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/nod broadlink2.0 2020-06-08 11:54:09.691 warn (24790) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:53:45.954 warn (24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:53:45.952 warn (24790) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:52:26.943 warn (24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/ broadlink2.0 2020-06-08 11:52:26.803 info (24790) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:52:26.755 info (24790) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:52:07.159 info (24790) found macs: 34:ea:34:4a:2e:b8 broadlink2.0 2020-06-08 11:52:07.159 info (24790) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:52:07.158 info (24790) Poll every 30 secods. broadlink2.0 2020-06-08 11:51:59.370 info (24790) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 11:51:59.118 info (24790) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 11:51:59.113 info (24790) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 11:51:59.090 info (24790) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ] broadlink2.0 2020-06-08 11:51:59.086 info (24790) Devices to rename: broadlink2.0 2020-06-08 11:51:59.085 info (24790) Devices to add: broadlink2.0 2020-06-08 11:51:59.081 info (24790) broadlink2 initialization started... broadlink2.0 2020-06-08 11:51:58.948 info (24790) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4 broadlink2.0 2020-06-08 11:51:54.404 warn (24205) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 11:51:54.403 info (24205) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 11:51:54.402 info (24205) terminating broadlink2.0 2020-06-08 11:51:54.400 info (24205) Close all connections... broadlink2.0 2020-06-08 11:51:54.399 info (24205) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 11:51:54.397 info (24205) Got terminate signal TERMINATE_YOURSELF broadlink2.0 2020-06-08 11:51:01.448 warn (24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609861443,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591 broadlink2.0 2020-06-08 11:50:43.238 warn (24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:50:43.237 warn (24205) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:50:19.531 warn (24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n broadlink2.0 2020-06-08 11:50:19.529 warn (24205) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again! broadlink2.0 2020-06-08 11:48:13.964 warn (24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/ broadlink2.0 2020-06-08 11:48:13.865 info (24205) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8 broadlink2.0 2020-06-08 11:48:13.819 info (24205) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8Edit2: Anlernen von IR Signalen per _Learn geht . Das senden bereits angelernter RF-Signale funktioniert auch.
Irgendwas stimmt jetzt nicht mehr.... Aktuelle Version vom Git gestern Abend.
Wenn ich das auch Manuell mal auslöse in den Objekten gehts nicht und das Log sagt das:
(Adapter gerade extra neu gestartet)broadlink2.0 2020-06-08 15:04:39.223 info (19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:04:39.222 warn (19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:04:34.753 info (19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:04:34.752 warn (19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:04:13.950 info (19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:04:13.947 warn (19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:03:32.527 info (19157) found macs: c8:f7:42:da:2d:ad broadlink2.0 2020-06-08 15:03:32.525 info (19157) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad broadlink2.0 2020-06-08 15:03:32.523 info (19157) Poll every 30 secods. broadlink2.0 2020-06-08 15:03:25.019 info (19157) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 15:03:24.385 info (19157) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 15:03:24.377 info (19157) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 15:03:24.342 info (19157) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ] broadlink2.0 2020-06-08 15:03:24.335 info (19157) Devices to rename: broadlink2.0 2020-06-08 15:03:24.333 info (19157) Devices to add: [] broadlink2.0 2020-06-08 15:03:24.324 info (19157) broadlink2 initialization started... broadlink2.0 2020-06-08 15:03:24.042 info (19157) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5 broadlink2.0 2020-06-08 15:03:10.521 warn (11721) Adapter will exit in latest 1 sec with code false! broadlink2.0 2020-06-08 15:03:10.518 info (11721) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason broadlink2.0 2020-06-08 15:03:10.515 info (11721) terminating broadlink2.0 2020-06-08 15:03:10.512 info (11721) Close all connections... broadlink2.0 2020-06-08 15:03:10.510 info (11721) Adapter disconnected and stopped with dostop(false) and callback(true) broadlink2.0 2020-06-08 15:03:10.507 info (11721) Got terminate signal TERMINATE_YOURSELFUpdate: Nach dem Neustart des Broadlink, also Strom am Broadlink selber geht es wieder mh.
Update2: Geht doch nicht, kurz dann gehts wieder nicht Log:
broadlink2.0 2020-06-08 15:34:57.365 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:57.362 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:28.467 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:28.466 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:25.932 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:25.931 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:24.708 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:24.706 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:22.501 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:22.499 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:33:25.137 info (2279) found macs: c8:f7:42:da:2d:ad broadlink2.0 2020-06-08 15:33:25.136 info (2279) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad broadlink2.0 2020-06-08 15:33:25.135 info (2279) Poll every 30 secods. broadlink2.0 2020-06-08 15:33:17.283 info (2279) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 15:33:17.125 info (2279) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 15:33:17.117 info (2279) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 15:33:17.082 info (2279) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ] broadlink2.0 2020-06-08 15:33:17.076 info (2279) Devices to rename: broadlink2.0 2020-06-08 15:33:17.074 info (2279) Devices to add: [] broadlink2.0 2020-06-08 15:33:17.065 info (2279) broadlink2 initialization started... broadlink2.0 2020-06-08 15:33:16.822 info (2279) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5 -
broadlink2.0 2020-06-08 15:34:57.365 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:57.362 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:28.467 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:28.466 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:25.932 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:25.931 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:24.708 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:24.706 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:34:22.501 info (2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80 broadlink2.0 2020-06-08 15:34:22.499 warn (2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'} broadlink2.0 2020-06-08 15:33:25.137 info (2279) found macs: c8:f7:42:da:2d:ad broadlink2.0 2020-06-08 15:33:25.136 info (2279) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad broadlink2.0 2020-06-08 15:33:25.135 info (2279) Poll every 30 secods. broadlink2.0 2020-06-08 15:33:17.283 info (2279) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus broadlink2.0 2020-06-08 15:33:17.125 info (2279) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-08 15:33:17.117 info (2279) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-08 15:33:17.082 info (2279) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ] broadlink2.0 2020-06-08 15:33:17.076 info (2279) Devices to rename: broadlink2.0 2020-06-08 15:33:17.074 info (2279) Devices to add: [] broadlink2.0 2020-06-08 15:33:17.065 info (2279) broadlink2 initialization started... broadlink2.0 2020-06-08 15:33:16.822 info (2279) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5das
Error 'No result delivered! No err check possible!'resultiert automatisch auscould not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send'
Dieses besagt dass das Gerät nicht auf irgendwelche Kommuniklation reagiert, 3x versucht der Adapter ein Ikommando zu senden und das Gerät meldet sich nicht mit der Bestätigung das Kommando empüfangen bzw ausgeführt zu haben.
Solche Kommandos sind auch momentaner Status oder Temperatur auslesen.Das eigenartige bei dir ist dass zwei verschiedene mac-Adressen auftauchen und aber nur ein Gerät davon gefunden wird.
Kann es sein dass du ein altes Gerät noch irgenwie unter broadlink.0 hast?
@Einklaus,
Mein T1 hat leider beim Weihnachtsputz meiner Frau den Geist aufgegeben, ist runtergefallen und genau auf's displaqy und man kann es nicht mehr bedienen, deshalb kann ich nicht mehr testen :(
Habe nur zusätzlichen Fehlerstatus der Antwort abgefragt aber bin mir jetzt nicht sicher ob beim T1 die Fehlermeldung auch wirklich auf der gleichen Position ist wie bei den anderen Geräten da es doppelte Verschlüsselung macht.@Knallochse
Hast schon mal 10 Sekunden gewartet und erneut auf lern geklickt?
Übrigens, auch du hast 2 verschienene mac's in der konfig und nur eine wird gefunden!Ich arbeite daran den Adapter anders konfigurieren zu können und in der Konfig auch die angelernten states zu haben damit man a) die selben codes auf mehreren RM's verwenden kann oder b) nur einen Platz hat um gelerntes zu managen.
@P-A-L-A-D-I-N
das würde ich auch gerne aber kann ich nur wenn du die mobile app entschlüsselst und die Zugriff-api's und Schnittstelle auf die cloud kennst! Das Broadlink das nicht offenlegt kann ich das nicht.
Ich persönlich verbiete allen BL-Geräten mit der cloud zu sprechen da ich nicht will dass wenn ich irgend ein Gerät sein oder ausschalte das an die cloud gemeldet wird! Ich steuere meine 9 aktiven Geräte NUR über ioBroker da ich über Vis und ioBroker-app sowieso das von überall machen kann ! Die Räüme und Gruppen kann ich auch nicht verwenden da bei mkir ein Homematic IR-Sensor einen Broadlink-UP-Schalter und vielleicht noch eine Zigbee-Lampe schalten muss und das nur mit ioBroker geht da die einzelnen Steuersysteme sich gegenseitig sonst nicht kennen. -
das
@Einklaus,
@P-A-L-A-D-I-N
Ich persönlich verbiete allen BL-Geräten mit der cloud zu sprechen da ich nicht will dass wenn ich irgend ein Gerät sein oder ausschalte das an die cloud gemeldet wird! Ich steuere meine 9 aktiven Geräte NUR über ioBroker da ich über Vis und ioBroker-app sowieso das von überall machen kann ! Die Räüme und Gruppen kann ich auch nicht verwenden da bei mkir ein Homematic IR-Sensor einen Broadlink-UP-Schalter und vielleicht noch eine Zigbee-Lampe schalten muss und das nur mit ioBroker geht da die einzelnen Steuersysteme sich gegenseitig sonst nicht kennen.@frankjoke sagte in Adapter: broadlink2:
das
Nein kein altes Gerät, das ist der Mini der derzeit nicht im Betrieb ist, aber vom Test die Tage
noch in den Objekten steht. -
das
@Einklaus,
@P-A-L-A-D-I-N
Ich persönlich verbiete allen BL-Geräten mit der cloud zu sprechen da ich nicht will dass wenn ich irgend ein Gerät sein oder ausschalte das an die cloud gemeldet wird! Ich steuere meine 9 aktiven Geräte NUR über ioBroker da ich über Vis und ioBroker-app sowieso das von überall machen kann ! Die Räüme und Gruppen kann ich auch nicht verwenden da bei mkir ein Homematic IR-Sensor einen Broadlink-UP-Schalter und vielleicht noch eine Zigbee-Lampe schalten muss und das nur mit ioBroker geht da die einzelnen Steuersysteme sich gegenseitig sonst nicht kennen.@frankjoke Das mit den 2 Mac Adressen verstehe ich nicht. Ich habe und hatte immer nur den einen Broadlink 3.
In der Fritzbox wird auch nur 1 Broadlink mit der Mac Adresse angezeigt. Die 2. Mac-Adresse gibt es in der Fritzbox nicht (Weder unter verbundene noch ungenutzte Verbindungen)Edit: Bin wieder auf 2.0.3 zurück und da wird nur 1 Mac Adresse gefunden
Habe noch ein Reserve Gerät, kann es dir gerne zum Testen zusenden.
@Einklaus
Habe ein kleines Update auf git gemacht bei dem ich den Zusatztest beim T1 wieder herausgenommen hab und auch sonst sollten weniger/keine Doppelmeldungen mehr auftauchen.Warum allerdings Geräte manchmal einfach offline sind hab ich noch nicht herausgefunden.
@Einklaus ,
Danke, aber das machen wir nur wenn du und andere Fehler finden sie ich mit euren Beschreibungen nicht beheben kann!Übrigens, habe auch schon LB1 (die Glühbirnen) integriert und ich kann sie auslesen (den Zustand und Status) aber hab's nicht geschafft ihnen Befehle zu senden, muss mal ein Python-Programm schreiben um zu sehen ob's dort geht oder auch nicht!
@Einklaus ,
@frankjoke
Wäre es sehr aufwendig etwas zu implementieren, dass zusätzlich zur "automatischen Gerätesuche" den Usern optional die Angabe von "IP-Adressen und Gerätenamen" für die Broadlinks ermöglicht? -
@frankjoke
Wenn du irgendwann ein Gerät zum Testen brauchst, einfach schreiben. Schicke es dir dann natürlich zu.
Die Flureon Geräte machen auch keine Fehlermeldung mehr, deine Änderung haben gewirkt.Danke nochmalig für deine Arbeiten
@Einklaus ,
@frankjoke
ich hab die aktuelle Version von Git gezogen, jetzt kommen sendPacket errors, die waren vorher nicht da, hier mal ein Logauszug, die Abstände sind vielleicht interesant?broadlink2.0 2020-06-09 17:29:42.730 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:29:07.682 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:28:33.368 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:27:57.682 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:27:22.703 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:26:47.703 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:21:32.607 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'} broadlink2.0 2020-06-09 17:19:12.814 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:18:38.380 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:18:02.668 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:17:27.768 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:16:52.758 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} host.iobroker 2020-06-09 17:15:08.753 info instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR) host.iobroker 2020-06-09 17:15:00.028 info instance system.adapter.openweathermap.0 started with pid 12742 broadlink2.0 2020-06-09 17:12:12.752 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'} host.iobroker 2020-06-09 17:11:00.028 warn instance system.adapter.odl.0 already running with pid 3398 broadlink2.0 2020-06-09 17:09:18.462 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:08:42.741 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:08:09.803 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:08:07.580 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'} broadlink2.0 2020-06-09 17:07:32.678 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} broadlink2.0 2020-06-09 17:06:57.648 warn (20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}Es geht hier um den RM-Mini, den ich hab, der State sieht so aus:
{ "common": { "name": "RM:0x2737_34:ea:34:41:45:14", "read": true, "write": true, "state": "state", "role": "level", "type": "boolean" }, "type": "state", "_id": "broadlink2.0.RM:0x2737_34:ea:34:41:45:14", "native": { "host": { "address": "192.168.5.151", "family": "IPv4", "port": 80, "size": 128, "devtype": 10039, "type": "rm", "name": "RM:0x2737_34:ea:34:41:45:14", "devname": "RM Mini", "mac": "34:ea:34:41:45:14" } }, "from": "system.adapter.broadlink2.0", "user": "system.user.admin", "ts": 1554387878423, "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }Meine Geräte sehen in den Objekten so aus, ich habe in der konfig nichts eingetragen, und die Objekte vor dem Updaten des Adapters gelöscht, um zu sehen, obs an irgendwelchen alten Einträgen liegt..
@frankjoke
@ilovegym Teste mal folgendes:
Broadlink ohne Strom, Adapter deaktivieren, Broadlink Strom wieder drann, kurz danach Adapter wieder aktivieren.
Dann geht er bei mir kurze Zeit und dann ist wieder Ende.@deta hmm das geht bei mir.. keine Probleme.. der Adapter läuft.. halt n paar Warnings im log.. aber so funktioniert alles...
@ilovegym sagte in Adapter: broadlink2:
Kannst du damit auch Steuern , wenn er diese Warn ausgibt? Ich kann 1 2 Befehle geben und dann Ende, geht nix mehr.
@deta nee wenn die warnings kommen, gehts nicht. aber die kommen so alle 10 -20 minuten mal.. dann ist wieder ruhe..
@frankjoke
@ilovegym
Ich habe gerade auf Git das Timeout für sendMessage wieder heruntergestzt da ich sehe dass deshalb nicht weniger fehler kommen.Ich bin schon beim verzweifeln da mit der jetztigen ich mit der jetzigen Version nur noch sehr sporadisch timout-Fehler hab.
Diese entstehen wenn der Adapter nicht nach (jetzt 900 ms, davor 2 Sekunden) ein Antwort vom gerät bekommt.
Der adapter versucht das 3x (mit kurzer, steigender Wartezeit dazwischen von 100-600 ms) und gibt dann erst 'nen Fehler aus! Bei mir läft's oft stundenlang ohne Fehler und dann sind Fehler, aber bei unterschiedlichen Geräten und nicht permanent so wie bei dir.Ich tippe schon auf ein Netzwerkproblem da auch mein NAS ab und zu (>=1x / Woche) Fehlermeldungen liefert dass das Netzwerk was hat.
Bitte wieder mit letzter Version weitertesten damit ich sehe ob Das einen Einfluss hat(te).
edit:
habe noch einige Parameter leicht geändert da ich herausgefunden hab das mein Pc (schnellstes gerät)= am wenigsten Probleme hatte und nie die Fehler brachte, die VM auf dem QNAP NAS hatte öfter Probleme, aber allesamt auch nur all 30-50 Minuten und der Rasp4 mit buster drauf zeigte öfter Probleme.
Also nahm ich an dass vielleicht Probleme auftauchen wenn verschiedene Processe (das poll oder ein sen/learn-Befehl) zufällig fast gleichzeitig auftreten bzw inerhalb des timouts.
Deshalb hab ich zusätzliche checks eingeführt damit alte Befehle beendet werden bevor neue gesendet werden, das scheint zu wirken, zumindest hatte ich keine Fehler in der deltzten Stunde auf den 3 rechnern!
@ilovegym
edit:
@frankjoke
vielen Dank! Ich habe gestern Abend den Mini mal beobachtet, und gesehen, dass er ab und zu 3x blau blinkt - schliesse doch auf ein Netzwerkproblem, er steht genau zwischen Repeater und Router.Ich habe die neue Version von dir mal installiert, beobachte das heute ein paar Stunden, und dann werde ich den RM mal woanders hinstellen.
@ilovegym
edit:
@frankjoke
Also, nach kurzer Zeit sieht es so aus, ich habe um 7.54 Uhr deine neue Version von Git installiert, und um 8:33 habe ich den Broadlink umgestellt, da die Fehler immer noch kamen und er ab und blau blinkte.
Die Fehlermeldung um 8.33 vom javascript stammt noch von einem alten Datenpunkt, den es nicht mehr gibt, hab dann direct aus dem Adapter auf den Button gedrückt, funktioneren tut er.Als nächstes werd ich ihn mal resetten und neu einbinden, dieses geblinke mag ich nicht..
Zusammengefasst: blinken stört, fehlermeldungen im log stören, aber funktionieren tuts...Übrigens, nach Hause telefonieren dürfen die ganzen Broadlink bei mir nicht, sind im Router geblockt.
2020-06-10 07:53:57.668 - info: host.iobroker iobroker url "https://github.com/frankjoke/ioBroker.broadlink2.git" 2020-06-10 07:54:00.173 - info: host.iobroker iobroker install https://github.com/frankjoke/ioBroker.broadlink2/tarball/38c9254700134c52d28dd11b1dfa148ef3c89ce8 2020-06-10 07:54:00.501 - info: host.iobroker iobroker npm install https://github.com/frankjoke/ioBroker.broadlink2/tarball/38c9254700134c52d28dd11b1dfa148ef3c89ce8 --loglevel error --prefix "/opt/iobroker" (System call) 2020-06-10 07:54:39.037 - info: host.iobroker iobroker upload [5] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/words.js words.js application/javascript 2020-06-10 07:54:39.166 - info: host.iobroker iobroker upload [4] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/style.css style.css text/css 2020-06-10 07:54:39.221 - info: host.iobroker iobroker upload [3] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index_m.html index_m.html text/html 2020-06-10 07:54:39.277 - info: host.iobroker iobroker upload [2] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index.html index.html text/html 2020-06-10 07:54:39.335 - info: host.iobroker iobroker upload [1] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink2.png broadlink2.png image/png 2020-06-10 07:54:39.391 - info: host.iobroker iobroker upload [0] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink.png broadlink.png image/png 2020-06-10 07:54:39.854 - info: host.iobroker iobroker Update "system.adapter.broadlink2.0" 2020-06-10 07:54:39.864 - info: host.iobroker stopInstance system.adapter.broadlink2.0 (force=false, process=true) 2020-06-10 07:54:39.866 - info: host.iobroker stopInstance system.adapter.broadlink2.0 send kill signal 2020-06-10 07:54:39.876 - warn: broadlink2.0 (20291) Adapter will exit in latest 1 sec with code false! 2020-06-10 07:54:41.147 - info: host.iobroker instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2020-06-10 07:54:42.899 - info: host.iobroker instance system.adapter.broadlink2.0 started with pid 25056 2020-06-10 07:57:15.842 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'} 2020-06-10 07:57:18.195 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 07:57:51.002 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 07:58:27.652 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 07:59:01.008 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 07:59:36.054 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:07:11.024 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:07:46.040 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:08:21.083 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:08:56.065 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:09:31.218 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:10:06.081 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:17:06.244 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:17:42.590 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:18:16.271 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:18:51.145 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:19:26.042 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:27:01.040 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:27:36.153 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:28:11.172 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:28:46.062 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:29:21.046 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:29:56.165 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:32:16.788 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:32:51.280 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:33:27.986 - warn: javascript.0 (19353) State "broadlink2.0.RM:RMMINI-41-45-14.L.TV_on" not found 2020-06-10 08:33:36.453 - warn: javascript.0 (19353) State "broadlink2.0.RM:RMMINI-41-45-14.L.TV_on" not found 2020-06-10 08:37:31.927 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:38:06.072 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:38:41.063 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:39:16.058 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'} 2020-06-10 08:39:51.776 - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
