  4. iobroker nicht mehr erreichbar - Fehlersuche?
    6.7k
raspberry pi 4
21 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
    @cherberg
    dmesg
    cat /var/log/messages
    cherberg
    @Thomas-Braun
    und hier der Output von
    um 19:41 war der letzte Crash.
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:42:A3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Memory: 3735592K/4050944K available (8192K kernel code, 661K rwdata, 2352K rodata, 2048K init, 850K bss, 53208K reserved, 262144K cma-reserved, 3264512K highmem)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 662 kB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] ftrace: allocating 28124 entries in 83 pages
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    Jun  4 19:41:33 raspberrypi kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    Jun  4 19:41:33 raspberrypi kernel: [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    Jun  4 19:41:33 raspberrypi kernel: [    0.000018] Switching to timer-based delay loop, resolution 18ns
    Jun  4 19:41:33 raspberrypi kernel: [    0.000237] Console: colour dummy device 80x30
    Jun  4 19:41:33 raspberrypi kernel: [    0.000260] console [tty1] enabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.000301] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000323] pid_max: default: 32768 minimum: 301
    Jun  4 19:41:33 raspberrypi kernel: [    0.000581] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.000599] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.001329] CPU: Testing write buffer coherency: ok
    Jun  4 19:41:33 raspberrypi kernel: [    0.001727] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Jun  4 19:41:33 raspberrypi kernel: [    0.002354] Setting up static identity map for 0x200000 - 0x20003c
    Jun  4 19:41:33 raspberrypi kernel: [    0.002508] rcu: Hierarchical SRCU implementation.
    Jun  4 19:41:33 raspberrypi kernel: [    0.003351] smp: Bringing up secondary CPUs ...
    Jun  4 19:41:33 raspberrypi kernel: [    0.004208] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    Jun  4 19:41:33 raspberrypi kernel: [    0.005199] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    Jun  4 19:41:33 raspberrypi kernel: [    0.006150] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    Jun  4 19:41:33 raspberrypi kernel: [    0.006281] smp: Brought up 1 node, 4 CPUs
    Jun  4 19:41:33 raspberrypi kernel: [    0.006294] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    Jun  4 19:41:33 raspberrypi kernel: [    0.006304] CPU: All CPU(s) started in HYP mode.
    Jun  4 19:41:33 raspberrypi kernel: [    0.006312] CPU: Virtualization extensions available.
    Jun  4 19:41:33 raspberrypi kernel: [    0.007078] devtmpfs: initialized
    Jun  4 19:41:33 raspberrypi kernel: [    0.017355] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    Jun  4 19:41:33 raspberrypi kernel: [    0.017555] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    Jun  4 19:41:33 raspberrypi kernel: [    0.017576] futex hash table entries: 1024 (order: 4, 65536 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.025056] pinctrl core: initialized pinctrl subsystem
    Jun  4 19:41:33 raspberrypi kernel: [    0.025881] NET: Registered protocol family 16
    Jun  4 19:41:33 raspberrypi kernel: [    0.028602] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    Jun  4 19:41:33 raspberrypi kernel: [    0.030041] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    Jun  4 19:41:33 raspberrypi kernel: [    0.030052] hw-breakpoint: maximum watchpoint size is 8 bytes.
    Jun  4 19:41:33 raspberrypi kernel: [    0.030239] Serial: AMBA PL011 UART driver
    Jun  4 19:41:33 raspberrypi kernel: [    0.033266] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.068965] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
    Jun  4 19:41:33 raspberrypi kernel: [    0.071375] vgaarb: loaded
    Jun  4 19:41:33 raspberrypi kernel: [    0.071747] SCSI subsystem initialized
    Jun  4 19:41:33 raspberrypi kernel: [    0.071933] usbcore: registered new interface driver usbfs
    Jun  4 19:41:33 raspberrypi kernel: [    0.071990] usbcore: registered new interface driver hub
    Jun  4 19:41:33 raspberrypi kernel: [    0.072084] usbcore: registered new device driver usb
    Jun  4 19:41:33 raspberrypi kernel: [    0.090380] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:34, variant start
    Jun  4 19:41:33 raspberrypi kernel: [    0.100111] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8fa065b414d8fc07c525e7ddffc8
    Jun  4 19:41:33 raspberrypi kernel: [    0.111600] clocksource: Switched to clocksource arch_sys_counter
    Jun  4 19:41:33 raspberrypi kernel: [    0.188683] VFS: Disk quotas dquot_6.6.0
    Jun  4 19:41:33 raspberrypi kernel: [    0.188757] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.188905] FS-Cache: Loaded
    Jun  4 19:41:33 raspberrypi kernel: [    0.189081] CacheFiles: Loaded
    Jun  4 19:41:33 raspberrypi kernel: [    0.189573] simple-framebuffer: probe of 0.framebuffer failed with error -12
    Jun  4 19:41:33 raspberrypi kernel: [    0.198603] NET: Registered protocol family 2
    Jun  4 19:41:33 raspberrypi kernel: [    0.199237] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.199261] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.199331] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.199401] TCP: Hash tables configured (established 8192 bind 8192)
    Jun  4 19:41:33 raspberrypi kernel: [    0.199511] UDP hash table entries: 512 (order: 2, 16384 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.199538] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.199826] NET: Registered protocol family 1
    Jun  4 19:41:33 raspberrypi kernel: [    0.200345] RPC: Registered named UNIX socket transport module.
    Jun  4 19:41:33 raspberrypi kernel: [    0.200354] RPC: Registered udp transport module.
    Jun  4 19:41:33 raspberrypi kernel: [    0.200363] RPC: Registered tcp transport module.
    Jun  4 19:41:33 raspberrypi kernel: [    0.200372] RPC: Registered tcp NFSv4.1 backchannel transport module.
    Jun  4 19:41:33 raspberrypi kernel: [    0.203389] Initialise system trusted keyrings
    Jun  4 19:41:33 raspberrypi kernel: [    0.203563] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    Jun  4 19:41:33 raspberrypi kernel: [    0.212467] FS-Cache: Netfs 'nfs' registered for caching
    Jun  4 19:41:33 raspberrypi kernel: [    0.212934] NFS: Registering the id_resolver key type
    Jun  4 19:41:33 raspberrypi kernel: [    0.212982] Key type id_resolver registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.212991] Key type id_legacy registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.213010] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    Jun  4 19:41:33 raspberrypi kernel: [    0.215184] Key type asymmetric registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.215195] Asymmetric key parser 'x509' registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.215305] bounce: pool size: 64 pages
    Jun  4 19:41:33 raspberrypi kernel: [    0.215343] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
    Jun  4 19:41:33 raspberrypi kernel: [    0.215497] io scheduler noop registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.215508] io scheduler deadline registered (default)
    Jun  4 19:41:33 raspberrypi kernel: [    0.215659] io scheduler cfq registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.215670] io scheduler mq-deadline registered (default)
    Jun  4 19:41:33 raspberrypi mtp-probe: checking bus 2, device 2: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-2"
    Jun  4 19:41:33 raspberrypi kernel: [    0.215680] io scheduler kyber registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.239092] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
    Jun  4 19:41:33 raspberrypi kernel: [    0.239111] brcm-pcie fd500000.pcie: could not get clock
    Jun  4 19:41:33 raspberrypi kernel: [    0.239171] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    Jun  4 19:41:33 raspberrypi kernel: [    0.239208] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
    Jun  4 19:41:33 raspberrypi kernel: [    0.291634] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
    Jun  4 19:41:33 raspberrypi kernel: [    0.291880] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    Jun  4 19:41:33 raspberrypi kernel: [    0.291896] pci_bus 0000:00: root bus resource [bus 00-01]
    Jun  4 19:41:33 raspberrypi kernel: [    0.291912] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
    Jun  4 19:41:33 raspberrypi kernel: [    0.294805] PCI: bus0: Fast back to back transfers disabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.294822] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    Jun  4 19:41:33 raspberrypi kernel: [    0.298215] PCI: bus1: Fast back to back transfers disabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.298277] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    Jun  4 19:41:33 raspberrypi kernel: [    0.298295] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    Jun  4 19:41:33 raspberrypi kernel: [    0.298365] pci 0000:00:00.0: PCI bridge to [bus 01]
    Jun  4 19:41:33 raspberrypi kernel: [    0.298382] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    Jun  4 19:41:33 raspberrypi kernel: [    0.298594] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    Jun  4 19:41:33 raspberrypi kernel: [    0.298759] pcieport 0000:00:00.0: Signaling PME with IRQ 56
    Jun  4 19:41:33 raspberrypi kernel: [    0.298916] pcieport 0000:00:00.0: AER enabled with IRQ 56
    Jun  4 19:41:33 raspberrypi kernel: [    0.299081] pci 0000:01:00.0: enabling device (0140 -> 0142)
    Jun  4 19:41:33 raspberrypi kernel: [    0.300901] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.302883] iproc-rng200 fe104000.rng: hwrng registered
    Jun  4 19:41:33 raspberrypi kernel: [    0.303104] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    Jun  4 19:41:33 raspberrypi kernel: [    0.303598] vc-sm: Videocore shared memory driver
    Jun  4 19:41:33 raspberrypi kernel: [    0.303982] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    Jun  4 19:41:33 raspberrypi kernel: [    0.313697] brd: module loaded
    Jun  4 19:41:33 raspberrypi kernel: [    0.323092] loop: module loaded
    Jun  4 19:41:33 raspberrypi kernel: [    0.323827] Loading iSCSI transport class v2.0-870.
    Jun  4 19:41:33 raspberrypi mtp-probe: bus: 2, device: 2 was not an MTP device
    Jun  4 19:41:33 raspberrypi kernel: [    0.325451] libphy: Fixed MDIO Bus: probed
    Jun  4 19:41:33 raspberrypi kernel: [    0.325861] bcmgenet fd580000.genet: failed to get enet clock
    Jun  4 19:41:33 raspberrypi kernel: [    0.325877] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
    Jun  4 19:41:33 raspberrypi kernel: [    0.325894] bcmgenet fd580000.genet: failed to get enet-wol clock
    Jun  4 19:41:33 raspberrypi kernel: [    0.325909] bcmgenet fd580000.genet: failed to get enet-eee clock
    Jun  4 19:41:33 raspberrypi kernel: [    0.325932] bcmgenet: Skipping UMAC reset
    Jun  4 19:41:33 raspberrypi kernel: [    0.326152] unimac-mdio unimac-mdio.-19: DMA mask not set
    Jun  4 19:41:33 raspberrypi kernel: [    0.341630] libphy: bcmgenet MII bus: probed
    Jun  4 19:41:33 raspberrypi kernel: [    0.382124] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
    Jun  4 19:41:33 raspberrypi kernel: [    0.382995] usbcore: registered new interface driver r8152
    Jun  4 19:41:33 raspberrypi kernel: [    0.383055] usbcore: registered new interface driver lan78xx
    Jun  4 19:41:33 raspberrypi kernel: [    0.383112] usbcore: registered new interface driver smsc95xx
    Jun  4 19:41:33 raspberrypi kernel: [    0.383408] xhci_hcd 0000:01:00.0: xHCI Host Controller
    Jun  4 19:41:33 raspberrypi kernel: [    0.383438] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    Jun  4 19:41:33 raspberrypi kernel: [    0.385673] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
    Jun  4 19:41:33 raspberrypi kernel: [    0.385973] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 57
    Jun  4 19:41:33 raspberrypi kernel: [    0.386832] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    Jun  4 19:41:33 raspberrypi kernel: [    0.386846] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Jun  4 19:41:33 raspberrypi kernel: [    0.386857] usb usb1: Product: xHCI Host Controller
    Jun  4 19:41:33 raspberrypi kernel: [    0.386868] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
    Jun  4 19:41:33 raspberrypi kernel: [    0.386878] usb usb1: SerialNumber: 0000:01:00.0
    Jun  4 19:41:33 raspberrypi kernel: [    0.387376] hub 1-0:1.0: USB hub found
    Jun  4 19:41:33 raspberrypi kernel: [    0.387455] hub 1-0:1.0: 1 port detected
    Jun  4 19:41:33 raspberrypi kernel: [    0.387912] xhci_hcd 0000:01:00.0: xHCI Host Controller
    Jun  4 19:41:33 raspberrypi kernel: [    0.387934] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    Jun  4 19:41:33 raspberrypi kernel: [    0.387952] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    Jun  4 19:41:33 raspberrypi kernel: [    0.388360] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    Jun  4 19:41:33 raspberrypi kernel: [    0.388373] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Jun  4 19:41:33 raspberrypi kernel: [    0.388384] usb usb2: Product: xHCI Host Controller
    Jun  4 19:41:33 raspberrypi kernel: [    0.388395] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
    Jun  4 19:41:33 raspberrypi kernel: [    0.388406] usb usb2: SerialNumber: 0000:01:00.0
    Jun  4 19:41:33 raspberrypi kernel: [    0.388888] hub 2-0:1.0: USB hub found
    Jun  4 19:41:33 raspberrypi kernel: [    0.388946] hub 2-0:1.0: 4 ports detected
    Jun  4 19:41:33 raspberrypi kernel: [    0.390130] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    Jun  4 19:41:33 raspberrypi kernel: [    0.415682] dwc_otg fe980000.usb: base=(ptrval)
    Jun  4 19:41:33 raspberrypi kernel: [    0.615976] Core Release: 2.80a
    Jun  4 19:41:33 raspberrypi kernel: [    0.615995] Setting default values for core params
    Jun  4 19:41:33 raspberrypi kernel: [    0.616021] Finished setting default values for core params
    Jun  4 19:41:33 raspberrypi kernel: [    0.816349] Using Buffer DMA mode
    Jun  4 19:41:33 raspberrypi kernel: [    0.816359] Periodic Transfer Interrupt Enhancement - disabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.816368] Multiprocessor Interrupt Enhancement - disabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.816378] OTG VER PARAM: 0, OTG VER FLAG: 0
    Jun  4 19:41:33 raspberrypi kernel: [    0.816436] Dedicated Tx FIFOs mode
    Jun  4 19:41:33 raspberrypi kernel: [    0.816968] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded34000 dma = 0x00000000ded34000 len=9024
    Jun  4 19:41:33 raspberrypi kernel: [    0.816990] FIQ FSM acceleration enabled for :
    Jun  4 19:41:33 raspberrypi kernel: [    0.816990] Non-periodic Split Transactions
    Jun  4 19:41:33 raspberrypi kernel: [    0.816990] Periodic Split Transactions
    Jun  4 19:41:33 raspberrypi kernel: [    0.816990] High-Speed Isochronous Endpoints
    Jun  4 19:41:33 raspberrypi kernel: [    0.816990] Interrupt/Control Split Transaction hack enabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.817067] WARN::hcd_init_fiq:457: FIQ on core 1
    Jun  4 19:41:33 raspberrypi kernel: [    0.817083] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
    Jun  4 19:41:33 raspberrypi kernel: [    0.817099] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
    Jun  4 19:41:33 raspberrypi kernel: [    0.817135] dwc_otg fe980000.usb: DWC OTG Controller
    Jun  4 19:41:33 raspberrypi kernel: [    0.817164] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
    Jun  4 19:41:33 raspberrypi kernel: [    0.817197] dwc_otg fe980000.usb: irq 38, io mem 0x00000000
    Jun  4 19:41:33 raspberrypi kernel: [    0.817248] Init: Port Power? op_state=1
    Jun  4 19:41:33 raspberrypi kernel: [    0.817258] Init: Power Port (0)
    Jun  4 19:41:33 raspberrypi kernel: [    0.817523] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    Jun  4 19:41:33 raspberrypi kernel: [    0.817536] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Jun  4 19:41:33 raspberrypi kernel: [    0.817548] usb usb3: Product: DWC OTG Controller
    Jun  4 19:41:33 raspberrypi kernel: [    0.817559] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
    Jun  4 19:41:33 raspberrypi kernel: [    0.817569] usb usb3: SerialNumber: fe980000.usb
    Jun  4 19:41:33 raspberrypi kernel: [    0.818067] hub 3-0:1.0: USB hub found
    Jun  4 19:41:33 raspberrypi kernel: [    0.818114] hub 3-0:1.0: 1 port detected
    Jun  4 19:41:33 raspberrypi kernel: [    0.818921] usbcore: registered new interface driver uas
    Jun  4 19:41:33 raspberrypi kernel: [    0.819034] usbcore: registered new interface driver usb-storage
    Jun  4 19:41:33 raspberrypi kernel: [    0.819195] mousedev: PS/2 mouse device common for all mice
    Jun  4 19:41:33 raspberrypi kernel: [    0.820361] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    Jun  4 19:41:33 raspberrypi kernel: [    0.820536] bcm2835-cpufreq: min=600000 max=1500000
    Jun  4 19:41:33 raspberrypi kernel: [    0.821071] sdhci: Secure Digital Host Controller Interface driver
    Jun  4 19:41:33 raspberrypi kernel: [    0.821080] sdhci: Copyright(c) Pierre Ossman
    Jun  4 19:41:33 raspberrypi kernel: [    0.821453] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    Jun  4 19:41:33 raspberrypi kernel: [    0.821863] sdhci-pltfm: SDHCI platform and OF driver helper
    Jun  4 19:41:33 raspberrypi kernel: [    0.824782] ledtrig-cpu: registered to indicate activity on CPUs
    Jun  4 19:41:33 raspberrypi kernel: [    0.824927] hidraw: raw HID events driver (C) Jiri Kosina
    Jun  4 19:41:33 raspberrypi kernel: [    0.825068] usbcore: registered new interface driver usbhid
    Jun  4 19:41:33 raspberrypi kernel: [    0.825077] usbhid: USB HID core driver
    Jun  4 19:41:33 raspberrypi kernel: [    0.825771] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    Jun  4 19:41:33 raspberrypi kernel: [    0.827043] [vc_sm_connected_init]: start
    Jun  4 19:41:33 raspberrypi kernel: [    0.833132] [vc_sm_connected_init]: end - returning 0
    Jun  4 19:41:33 raspberrypi kernel: [    0.834197] Initializing XFRM netlink socket
    Jun  4 19:41:33 raspberrypi kernel: [    0.834224] NET: Registered protocol family 17
    Jun  4 19:41:33 raspberrypi kernel: [    0.834316] Key type dns_resolver registered
    Jun  4 19:41:33 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
    Jun  4 19:41:33 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="321" x-info="https://www.rsyslog.com"] start
    Jun  4 19:41:33 raspberrypi kernel: [    0.834646] Registering SWP/SWPB emulation handler
    Jun  4 19:41:33 raspberrypi kernel: [    0.835214] registered taskstats version 1
    Jun  4 19:41:33 raspberrypi kernel: [    0.835229] Loading compiled-in X.509 certificates
    Jun  4 19:41:33 raspberrypi kernel: [    0.842892] uart-pl011 fe201000.serial: cts_event_workaround enabled
    Jun  4 19:41:33 raspberrypi kernel: [    0.842952] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
    Jun  4 19:41:33 raspberrypi kernel: [    0.846208] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 62500000) is a 16550
    Jun  4 19:41:33 raspberrypi kernel: [    0.846639] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    Jun  4 19:41:33 raspberrypi kernel: [    0.847109] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
    Jun  4 19:41:33 raspberrypi kernel: [    0.847715] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    Jun  4 19:41:33 raspberrypi kernel: [    0.847727] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    Jun  4 19:41:33 raspberrypi kernel: [    0.872154] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
    Jun  4 19:41:33 raspberrypi kernel: [    0.892103] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.893703] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.895302] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.898169] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.899767] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Jun  4 19:41:33 raspberrypi kernel: [    0.904291] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    Jun  4 19:41:33 raspberrypi kernel: [    0.906585] of_cfs_init
    Jun  4 19:41:33 raspberrypi kernel: [    0.906677] of_cfs_init: OK
    Jun  4 19:41:33 raspberrypi kernel: [    0.907311] Waiting for root device /dev/sda2...
    Jun  4 19:41:33 raspberrypi kernel: [    0.954475] random: fast init done
    Jun  4 19:41:33 raspberrypi kernel: [    0.961644] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    Jun  4 19:41:33 raspberrypi kernel: [    1.007358] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    Jun  4 19:41:33 raspberrypi kernel: [    1.008480] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    Jun  4 19:41:33 raspberrypi kernel: [    1.010035] mmc1: new high speed SDIO card at address 0001
    Jun  4 19:41:33 raspberrypi kernel: [    1.011342]  mmcblk0: p1 p2
    Jun  4 19:41:33 raspberrypi kernel: [    1.144259] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
    Jun  4 19:41:33 raspberrypi kernel: [    1.144273] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    Jun  4 19:41:33 raspberrypi kernel: [    1.144285] usb 1-1: Product: USB2.0 Hub
    Jun  4 19:41:33 raspberrypi kernel: [    1.145892] hub 1-1:1.0: USB hub found
    Jun  4 19:41:33 raspberrypi kernel: [    1.146249] hub 1-1:1.0: 4 ports detected
    Jun  4 19:41:33 raspberrypi kernel: [    1.292002] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    Jun  4 19:41:33 raspberrypi kernel: [    1.324875] usb 2-2: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
    Jun  4 19:41:33 raspberrypi kernel: [    1.324889] usb 2-2: New USB device strings: Mfr=4, Product=5, SerialNumber=6
    Jun  4 19:41:33 raspberrypi kernel: [    1.324900] usb 2-2: SerialNumber: 20200109
    Jun  4 19:41:33 raspberrypi kernel: [    1.328434] usb-storage 2-2:1.0: USB Mass Storage device detected
    Jun  4 19:41:33 raspberrypi kernel: [    1.328914] scsi host0: usb-storage 2-2:1.0
    Jun  4 19:41:33 raspberrypi kernel: [    2.700480] scsi 0:0:0:0: Direct-Access     Intenso  SSD Sata III          PQ: 0 ANSI: 6
    Jun  4 19:41:33 raspberrypi kernel: [    2.701531] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
    Jun  4 19:41:33 raspberrypi kernel: [    2.702317] sd 0:0:0:0: [sda] Write Protect is off
    Jun  4 19:41:33 raspberrypi kernel: [    2.706539]  sda: sda1 sda2
    Jun  4 19:41:33 raspberrypi kernel: [    2.709755] sd 0:0:0:0: [sda] Attached SCSI disk
    Jun  4 19:41:33 raspberrypi kernel: [    2.733128] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    Jun  4 19:41:33 raspberrypi kernel: [    2.733139] EXT4-fs (sda2): write access will be enabled during recovery
    Jun  4 19:41:33 raspberrypi kernel: [    2.867438] EXT4-fs (sda2): orphan cleanup on readonly fs
    Jun  4 19:41:33 raspberrypi kernel: [    2.882975] EXT4-fs (sda2): 3 orphan inodes deleted
    Jun  4 19:41:33 raspberrypi kernel: [    2.882987] EXT4-fs (sda2): recovery complete
    Jun  4 19:41:33 raspberrypi kernel: [    2.889207] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    Jun  4 19:41:33 raspberrypi kernel: [    2.889251] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    Jun  4 19:41:33 raspberrypi kernel: [    2.889995] devtmpfs: mounted
    Jun  4 19:41:33 raspberrypi kernel: [    2.896231] Freeing unused kernel memory: 2048K
    Jun  4 19:41:33 raspberrypi kernel: [    2.931858] Run /sbin/init as init process
    Jun  4 19:41:33 raspberrypi kernel: [    3.784631] random: systemd: uninitialized urandom read (16 bytes read)
    Jun  4 19:41:33 raspberrypi kernel: [    3.793246] random: systemd: uninitialized urandom read (16 bytes read)
    Jun  4 19:41:33 raspberrypi kernel: [    3.794202] random: systemd: uninitialized urandom read (16 bytes read)
    Jun  4 19:41:33 raspberrypi kernel: [    4.471631] EXT4-fs (sda2): re-mounted. Opts: (null)
    Jun  4 19:41:33 raspberrypi kernel: [    7.468661] random: crng init done
    Jun  4 19:41:33 raspberrypi kernel: [    7.468673] random: 7 urandom warning(s) missed due to ratelimiting
    Jun  4 19:41:33 raspberrypi kernel: [    7.835219] uart-pl011 fe201000.serial: no DMA platform data
    Jun  4 19:41:34 raspberrypi udisksd[352]: udisks daemon version 2.8.1 starting
    Jun  4 19:41:34 raspberrypi kernel: [    8.330639] bcmgenet: Skipping UMAC reset
    Jun  4 19:41:34 raspberrypi kernel: [    8.432181] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
    Jun  4 19:41:34 raspberrypi udisksd[352]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
    Jun  4 19:41:34 raspberrypi udisksd[352]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
    Jun  4 19:41:34 raspberrypi kernel: [    8.480507] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    Jun  4 19:41:34 raspberrypi udisksd[352]: Failed to load the 'mdraid' libblockdev plugin
    Jun  4 19:41:34 raspberrypi udisksd[352]: Failed to load the 'crypto' libblockdev plugin
    Jun  4 19:41:34 raspberrypi lightdm[446]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jun  4 19:41:34 raspberrypi udisksd[352]: Acquired the name org.freedesktop.UDisks2 on the system message bus
    Jun  4 19:41:35 raspberrypi kernel: [    9.511740] bcmgenet fd580000.genet eth0: Link is Down
    Jun  4 19:41:35 raspberrypi lightdm[527]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jun  4 19:41:35 raspberrypi lightdm[547]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jun  4 19:41:36 raspberrypi lightdm[561]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jun  4 19:41:36 raspberrypi lightdm[570]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jun  4 19:41:38 raspberrypi kernel: [   12.631763] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    Jun  4 19:41:55 raspberrypi kernel: [   29.812200] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    Jun  4 20:59:50 raspberrypi kernel: [   86.202128] device eth0 entered promiscuous mode
    Jun  4 22:21:46 raspberrypi kernel: [ 5002.260018] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    • C Offline
      cherberg
      @cherberg said in iobroker nicht mehr erreichbar - Fehlersuche?:
      Ich habe mal proaktiv die offenbar fehlenden Module
      libblockdev-crypto2
      libblockdev-mdraid2
      nachinstalliert, aber das ist nur ein laienhafter Versuch, ob das mein Problem löst wage ich zu bezweifeln :-)
      • C cherberg
        libblockdev-crypto2
        libblockdev-mdraid2
        @cherberg
        Deine Festplatte hat 'nen Schuss:
        Kannst auch nochmal mit
        mount | sort | grep ^/dev
        schauen wie die eingehängt wurde.
        C 2 Antworten Letzte Antwort
          @cherberg
          cherberg
          @Thomas-Braun
          hm, das ist ne nagelneue SSD (günstig Intenso), ich hänge die mal an meinen Windows PC und prüfe die SMART Werte der Platte.
          Allerdings habe ich die Partitionen auf der SSD von einer SD Karte geklont.
          Kann es sein, dass die SSD an sich in Ordnung ist, ich auf diesem Weg aber Defekte im Filesystem mit geklont habe? Gibt es ein Tool zur Korrektur des Filesystems wie checkdisk unter Windows? Google meint fsck, aber das läuft nicht:
          pi@raspberrypi:~ $ sudo fsck
          fsck from util-linux 2.33.1
          e2fsck 1.44.5 (15-Dec-2018)
          /dev/sda2 is mounted.
          e2fsck: Cannot continue, aborting.
            @cherberg
            cherberg
            @Thomas-Braun said in iobroker nicht mehr erreichbar - Fehlersuche?:
            Das gibt folgendes aus:
            pi@raspberrypi:~ $ mount | sort | grep ^/dev
            /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
            /dev/sda2 on / type ext4 (rw,noatime)
            • C cherberg
              @Thomas-Braun
              @cherberg Ja, beim clonen werden auch Fehler geklont.
              Ein fsck kann nur auf nichteingehängten Dateisystemen erfolgen.
              Außerdem hat das System das bereits versucht.
              Jedenfalls ist / auch wieder rw (les-/schreibbar) gemounted worden, dass passt.
              C 1 Antwort Letzte Antwort
                cherberg
                @Thomas-Braun
                hm was wäre denn nun der Weg der Wahl?
                Soll ich die Platte mal an einen anderen RPI hängen und fsck ausführen oder hilft hier nur eine Neuinstallation? Vor der habe ich allerdings Respekt. Ich habe schon einiges gebastelt und geskripted. BackItUp habe ich nocht nicht zum Laufen bekommen und wäre echt aufgeschmissen wenn ich alles neu machen müsste :-(
                • C cherberg
                  @Thomas-Braun
                  @cherberg Ich würde es mal beobachten...
                  Was mich wundert: Hattest du nicht geschrieben, dass /boot auf der SD-Karte läge?
                  Laut deinem mount liegt das auf sda1 (Also der Festplatte)
                    cherberg
                    @Thomas-Braun
                    Also der Pi4 kann ja (noch) nicht direkt von USB booten. Daher gibt es die Anleitung die SD Karte zuerst auf eine HDD/SSD zu klonen.
                    In der Bootpartition der SD Karte in der cmdline.txt dann den Eintrag für die Rootpartition so zu ändern, so dass das System diese auf der SSD/HDD sucht: root=/dev/sda2
                    Beim Start wird dann wohl von der SD gebootet, das System liegt aber auf der SSD. Daher sollte es keine Alterung mehr geben wie es sie gibt wenn das gesamte System auf der SD liegt.
                    Daher ist auf der SSD wegen des Klonvorgangs auch eine Boot Partition vorhanden, diese ist aber nur ein ungenutztes Überbleibsel.
                      cherberg
                      @Thomas-Braun
                      naja beobachten tue ich es ja schon seit einiger Zeit und habe leider immer mal wieder Abbrüche die nur durch einen Neustart (Stecker ziehen) gelöst werden können :-(
                      • C cherberg
                        @Thomas-Braun
                        @cherberg
                        who -r
                        free -h
                        • C cherberg
                          @Thomas-Braun
                          Meister MopperM Offline
                          Meister Mopper
                          @cherberg sagte in iobroker nicht mehr erreichbar - Fehlersuche?:
                          @Thomas-Braun
                          Also der Pi4 kann ja (noch) nicht direkt von USB booten....
                          Es gibt mittlerweile eine beta-Lösung zum booten von SSD. Bei mir funktioniert es bisher super.
                          Proxmox und HA ...
                            @cherberg
                            who -r
                            free -h
                            cherberg
                            free -h
                            pi@raspberrypi:~ $ who -r
                                     Runlevel 5   2020-06-04 23:11
                            pi@raspberrypi:~ $ free -h
                            Mem:          3,8Gi       1,0Gi       2,3Gi        16Mi       523Mi       2,7Gi
                            Swap:          99Mi          0B        99Mi
                            pi@raspberrypi:~ $
                            • C cherberg
                              free -h
                              Swap:          99Mi          0B        99Mi
                              pi@raspberrypi:~ $
                              @cherberg
                              Speicher ist genug vorhanden.
                              Ich würde aber den Raspberry als Server in RunLevel 3 betreiben.
                              sudo raspi-config
                              Und dann
                              3 - B1 - B1 oder B2
                              wählen. Neustart.
                                @cherberg
                                sudo raspi-config
                                Und dann
                                3 - B1 - B1 oder B2
                                wählen. Neustart.
                                cherberg
                                sudo raspi-config
                                ja ich hatte vorher einen Pi2 mit nur 1 GB RAM, der kam dann mit einigen Adaptern schnell an die Grenzen und durch kontinuierliches swappen frass er SD Karten wie andere Leute Chips 😵
                                Der Runlevel ist nun auf 3:
                                         Runlevel 3   2020-06-05 14:21
                                Mem:          3,8Gi       936Mi       2,5Gi        24Mi       391Mi       2,8Gi
                                Swap:          99Mi          0B        99Mi
                                pi@raspberrypi:~ $
                                • C cherberg
                                  sudo raspi-config
                                  Swap:          99Mi          0B        99Mi
                                  pi@raspberrypi:~ $
                                  cherberg
                                  @cherberg
                                  Nur zur Info nach vielen Versuchen habe ich mich entschieden das System komplett neu aufzusetzen und hierbei einen neuen SATA Adapter und auch eine neue Festplatte zu verwenden. Ich alles neu installiert und habe lediglich die Skripte exportiert und wieder importiert. Seit einigen Wochen läuft das System nun stabil.
