  4. iobroker nicht mehr erreichbar - Fehlersuche?
    6.7k
raspberry pi 4
21 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
    @cherberg
    Bitte Konsolenoutput in </> CodeTags. So mag das keiner lesen.
    cherberg
    @Thomas-Braun
    ah ja, das sieht in der Tat besser aus :-)
    pi@raspberrypi:~ $ dmseg
    -bash: dmseg: Kommando nicht gefunden.
    pi@raspberrypi:~ $ sudo dmseg
    sudo: dmseg: Befehl nicht gefunden
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (cro                                                            sstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 20                                                            19
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
    [    0.000000] On node 0 totalpages: 1012736
    [    0.000000]   DMA zone: 1728 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
    [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with                                                             crng_init=0
    [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
    [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma                                                            =256M  smsc95xx.macaddr=DC:A6:32:42:A3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_                                                            size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda2 rootfstype=ext                                                            4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial                                                            -consoles
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 3735592K/4050944K available (8192K kernel code, 661K rwda                                                            ta, 2352K rodata, 2048K init, 850K bss, 53208K reserved, 262144K cma-reserved, 3                                                            264512K highmem)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                       lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                       pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                       modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                         .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                         .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 662 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 28124 entries in 83 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                                                             0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980                                                            46511102ns
    [    0.000018] Switching to timer-based delay loop, resolution 18ns
    [    0.000237] Console: colour dummy device 80x30
    [    0.000260] console [tty1] enabled
    [    0.000301] Calibrating delay loop (skipped), value calculated using timer fr                                                            equency.. 108.00 BogoMIPS (lpj=540000)
    [    0.000323] pid_max: default: 32768 minimum: 301
    [    0.000581] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000599] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001329] CPU: Testing write buffer coherency: ok
    [    0.001727] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.002354] Setting up static identity map for 0x200000 - 0x20003c
    [    0.002508] rcu: Hierarchical SRCU implementation.
    [    0.003351] smp: Bringing up secondary CPUs ...
    [    0.004208] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.005199] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.006150] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.006281] smp: Brought up 1 node, 4 CPUs
    [    0.006294] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.006304] CPU: All CPU(s) started in HYP mode.
    [    0.006312] CPU: Virtualization extensions available.
    [    0.007078] devtmpfs: initialized
    [    0.017355] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8                                                             rev 0
    [    0.017555] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                                                            x_idle_ns: 19112604462750000 ns
    [    0.017576] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.025056] pinctrl core: initialized pinctrl subsystem
    [    0.025881] NET: Registered protocol family 16
    [    0.028602] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.030041] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint                                                             registers.
    [    0.030052] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.030239] Serial: AMBA PL011 UART driver
    [    0.033266] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.068965] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dma                                                            chans=0x1
    [    0.071375] vgaarb: loaded
    [    0.071747] SCSI subsystem initialized
    [    0.071933] usbcore: registered new interface driver usbfs
    [    0.071990] usbcore: registered new interface driver hub
    [    0.072084] usbcore: registered new device driver usb
    [    0.090380] raspberrypi-firmware soc:firmware: Attached to firmware from 2019                                                            -09-24 17:34, variant start
    [    0.100111] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8                                                            fa065b414d8fc07c525e7ddffc8
    [    0.111600] clocksource: Switched to clocksource arch_sys_counter
    [    0.188683] VFS: Disk quotas dquot_6.6.0
    [    0.188757] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.188905] FS-Cache: Loaded
    [    0.189081] CacheFiles: Loaded
    [    0.189573] simple-framebuffer: probe of 0.framebuffer failed with error -12
    [    0.198603] NET: Registered protocol family 2
    [    0.199237] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144                                                             bytes)
    [    0.199261] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.199331] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.199401] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.199511] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.199538] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.199826] NET: Registered protocol family 1
    [    0.200345] RPC: Registered named UNIX socket transport module.
    [    0.200354] RPC: Registered udp transport module.
    [    0.200363] RPC: Registered tcp transport module.
    [    0.200372] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.200387] PCI: CLS 0 bytes, default 64
    [    0.203389] Initialise system trusted keyrings
    [    0.203563] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    0.212467] FS-Cache: Netfs 'nfs' registered for caching
    [    0.212934] NFS: Registering the id_resolver key type
    [    0.212982] Key type id_resolver registered
    [    0.212991] Key type id_legacy registered
    [    0.213010] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.215184] Key type asymmetric registered
    [    0.215195] Asymmetric key parser 'x509' registered
    [    0.215305] bounce: pool size: 64 pages
    [    0.215343] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                                                            50)
    [    0.215497] io scheduler noop registered
    [    0.215508] io scheduler deadline registered (default)
    [    0.215659] io scheduler cfq registered
    [    0.215670] io scheduler mq-deadline registered (default)
    [    0.215680] io scheduler kyber registered
    [    0.239092] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, thres                                                            hold 0x00000000c0000000
    [    0.239111] brcm-pcie fd500000.pcie: could not get clock
    [    0.239171] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.239208] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf800                                                            0000
    [    0.291634] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
    [    0.291880] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    0.291896] pci_bus 0000:00: root bus resource [bus 00-01]
    [    0.291912] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff]                                                             (bus address [0xf8000000-0xfbffffff])
    [    0.291953] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    0.292089] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    0.294805] PCI: bus0: Fast back to back transfers disabled
    [    0.294822] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec                                                            onfiguring
    [    0.295030] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    0.295152] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    0.295463] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    0.298215] PCI: bus1: Fast back to back transfers disabled
    [    0.298231] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
    [    0.298277] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    0.298295] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64                                                            bit]
    [    0.298365] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.298382] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    0.298594] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    0.298759] pcieport 0000:00:00.0: Signaling PME with IRQ 56
    [    0.298916] pcieport 0000:00:00.0: AER enabled with IRQ 56
    [    0.299081] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    0.300901] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    [    0.302883] iproc-rng200 fe104000.rng: hwrng registered
    [    0.303104] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000                                                            000(1024 MiB)
    [    0.303598] vc-sm: Videocore shared memory driver
    [    0.303982] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2                                                            00000
    [    0.313697] brd: module loaded
    [    0.323092] loop: module loaded
    [    0.323827] Loading iSCSI transport class v2.0-870.
    [    0.325451] libphy: Fixed MDIO Bus: probed
    [    0.325861] bcmgenet fd580000.genet: failed to get enet clock
    [    0.325877] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
    [    0.325894] bcmgenet fd580000.genet: failed to get enet-wol clock
    [    0.325909] bcmgenet fd580000.genet: failed to get enet-eee clock
    [    0.325932] bcmgenet: Skipping UMAC reset
    [    0.326152] unimac-mdio unimac-mdio.-19: DMA mask not set
    [    0.341630] libphy: bcmgenet MII bus: probed
    [    0.382124] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrva                                                            l)
    [    0.382995] usbcore: registered new interface driver r8152
    [    0.383055] usbcore: registered new interface driver lan78xx
    [    0.383112] usbcore: registered new interface driver smsc95xx
    [    0.383408] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    0.383438] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe                                                            r 1
    [    0.385673] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu                                                            irks 0x0000001000000890
    [    0.385973] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of ir                                                            q 57
    [    0.386832] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc                                                            dDevice= 4.19
    [    0.386846] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                                                            1
    [    0.386857] usb usb1: Product: xHCI Host Controller
    [    0.386868] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
    [    0.386878] usb usb1: SerialNumber: 0000:01:00.0
    [    0.387376] hub 1-0:1.0: USB hub found
    [    0.387455] hub 1-0:1.0: 1 port detected
    [    0.387912] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    0.387934] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe                                                            r 2
    [    0.387952] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    0.388360] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc                                                            dDevice= 4.19
    [    0.388373] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=                                                            1
    [    0.388384] usb usb2: Product: xHCI Host Controller
    [    0.388395] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
    [    0.388406] usb usb2: SerialNumber: 0000:01:00.0
    [    0.388888] hub 2-0:1.0: USB hub found
    [    0.388946] hub 2-0:1.0: 4 ports detected
    [    0.390130] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.415682] dwc_otg fe980000.usb: base=(ptrval)
    [    0.615976] Core Release: 2.80a
    [    0.615995] Setting default values for core params
    [    0.616021] Finished setting default values for core params
    [    0.816349] Using Buffer DMA mode
    [    0.816359] Periodic Transfer Interrupt Enhancement - disabled
    [    0.816368] Multiprocessor Interrupt Enhancement - disabled
    [    0.816378] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    0.816436] Dedicated Tx FIFOs mode
    [    0.816968] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded34                                                            000 dma = 0x00000000ded34000 len=9024
    [    0.816990] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    0.817001] dwc_otg: Microframe scheduler enabled
    [    0.817067] WARN::hcd_init_fiq:457: FIQ on core 1
    [    0.817083] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
    [    0.817099] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
    [    0.817135] dwc_otg fe980000.usb: DWC OTG Controller
    [    0.817164] dwc_otg fe980000.usb: new USB bus registered, assigned bus number                                                             3
    [    0.817197] dwc_otg fe980000.usb: irq 38, io mem 0x00000000
    [    0.817248] Init: Port Power? op_state=1
    [    0.817258] Init: Power Port (0)
    [    0.817523] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bc                                                            dDevice= 4.19
    [    0.817536] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=                                                            1
    [    0.817548] usb usb3: Product: DWC OTG Controller
    [    0.817559] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
    [    0.817569] usb usb3: SerialNumber: fe980000.usb
    [    0.818067] hub 3-0:1.0: USB hub found
    [    0.818114] hub 3-0:1.0: 1 port detected
    [    0.818695] dwc_otg: FIQ enabled
    [    0.818704] dwc_otg: NAK holdoff enabled
    [    0.818713] dwc_otg: FIQ split-transaction FSM enabled
    [    0.818726] Module dwc_common_port init
    [    0.818921] usbcore: registered new interface driver uas
    [    0.819034] usbcore: registered new interface driver usb-storage
    [    0.819195] mousedev: PS/2 mouse device common for all mice
    [    0.820361] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    0.820536] bcm2835-cpufreq: min=600000 max=1500000
    [    0.821071] sdhci: Secure Digital Host Controller Interface driver
    [    0.821080] sdhci: Copyright(c) Pierre Ossman
    [    0.821453] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    0.821863] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.824782] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.824927] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.825068] usbcore: registered new interface driver usbhid
    [    0.825077] usbhid: USB HID core driver
    [    0.825771] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    [    0.827043] [vc_sm_connected_init]: start
    [    0.833132] [vc_sm_connected_init]: end - returning 0
    [    0.834197] Initializing XFRM netlink socket
    [    0.834224] NET: Registered protocol family 17
    [    0.834316] Key type dns_resolver registered
    [    0.834646] Registering SWP/SWPB emulation handler
    [    0.835214] registered taskstats version 1
    [    0.835229] Loading compiled-in X.509 certificates
    [    0.842892] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    0.842952] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud                                                             = 0) is a PL011 rev2
    [    0.846208] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 6250000                                                            0) is a 16550
    [    0.846639] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive                                                            r
    [    0.847109] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor d                                                            river
    [    0.847715] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    0.847727] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    0.872154] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
    [    0.892103] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    0.893703] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.895302] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.898169] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    0.899767] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.904291] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A                                                            DMA
    [    0.906585] of_cfs_init
    [    0.906677] of_cfs_init: OK
    [    0.907311] Waiting for root device /dev/sda2...
    [    0.954475] random: fast init done
    [    0.961644] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.007358] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.008480] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    [    1.010035] mmc1: new high speed SDIO card at address 0001
    [    1.011342]  mmcblk0: p1 p2
    [    1.144259] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd                                                            Device= 4.20
    [    1.144273] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.144285] usb 1-1: Product: USB2.0 Hub
    [    1.145892] hub 1-1:1.0: USB hub found
    [    1.146249] hub 1-1:1.0: 4 ports detected
    [    1.292002] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
    [    1.324875] usb 2-2: New USB device found, idVendor=1f75, idProduct=0621, bcd                                                            Device= 0.36
    [    1.324889] usb 2-2: New USB device strings: Mfr=4, Product=5, SerialNumber=6
    [    1.324900] usb 2-2: SerialNumber: 20200109
    [    1.328434] usb-storage 2-2:1.0: USB Mass Storage device detected
    [    1.328914] scsi host0: usb-storage 2-2:1.0
    [    2.700480] scsi 0:0:0:0: Direct-Access     Intenso  SSD Sata III          PQ                                                            : 0 ANSI: 6
    [    2.701531] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112                                                             GiB)
    [    2.702317] sd 0:0:0:0: [sda] Write Protect is off
    [    2.702331] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
    [    2.703147] sd 0:0:0:0: [sda] No Caching mode page found
    [    2.703177] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [    2.706539]  sda: sda1 sda2
    [    2.709755] sd 0:0:0:0: [sda] Attached SCSI disk
    [    2.733128] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [    2.733139] EXT4-fs (sda2): write access will be enabled during recovery
    [    2.867438] EXT4-fs (sda2): orphan cleanup on readonly fs
    [    2.882975] EXT4-fs (sda2): 3 orphan inodes deleted
    [    2.882987] EXT4-fs (sda2): recovery complete
    [    2.889207] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts:                                                             (null)
    [    2.889251] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [    2.889995] devtmpfs: mounted
    [    2.896231] Freeing unused kernel memory: 2048K
    [    2.931858] Run /sbin/init as init process
    [    3.135168] systemd[1]: System time before build time, advancing clock.
    [    3.162065] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL                                                            INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +                                                            XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr                                                            id)
    [    3.162708] systemd[1]: Detected architecture arm.
    [    3.169917] systemd[1]: Set hostname to <raspberrypi>.
    [    3.446347] systemd[1]: File /lib/systemd/system/systemd-journald.service:12                                                             configures an IP firewall (IPAddressDeny=any), but the local system does not sup                                                            port BPF/cgroup based firewalling.
    [    3.446368] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni                                                            ng is only shown for the first loaded unit using IP firewalling.)
    [    3.723332] systemd[1]: /lib/systemd/system/deconz.service:8: Unknown lvalue                                                             'StartLimitIntervalSec' in section 'Service', ignoring
    [    3.784631] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.793246] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.793832] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.794202] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.798052] systemd[1]: Created slice User and Session Slice.
    [    3.798198] systemd[1]: Reached target Swap.
    [    3.798734] systemd[1]: Listening on fsck to fsckd communication Socket.
    [    4.471631] EXT4-fs (sda2): re-mounted. Opts: (null)
    [    4.575833] systemd-journald[106]: Received request to flush runtime journal                                                             from PID 1
    [    7.468661] random: crng init done
    [    7.468673] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.835219] uart-pl011 fe201000.serial: no DMA platform data
    [    8.330639] bcmgenet: Skipping UMAC reset
    [    8.432181] bcmgenet fd580000.genet: configuring instance for external RGMII                                                             (no delay)
    [    8.480507] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1                                                            02396k FS
    [    9.511740] bcmgenet fd580000.genet eth0: Link is Down
    [   12.631763] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow cont                                                            rol rx/tx
    [   29.812200] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hc                                                            d
    [   86.202128] device eth0 entered promiscuous mode
    [ 5002.260018] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hc
      @cherberg
      dmesg
      cat /var/log/messages
      cherberg
      @Thomas-Braun
      und hier der Output von
      um 19:41 war der letzte Crash.
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:42:A3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Memory: 3735592K/4050944K available (8192K kernel code, 661K rwdata, 2352K rodata, 2048K init, 850K bss, 53208K reserved, 262144K cma-reserved, 3264512K highmem)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 662 kB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] ftrace: allocating 28124 entries in 83 pages
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      Jun  4 19:41:33 raspberrypi kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      Jun  4 19:41:33 raspberrypi kernel: [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      Jun  4 19:41:33 raspberrypi kernel: [    0.000018] Switching to timer-based delay loop, resolution 18ns
      Jun  4 19:41:33 raspberrypi kernel: [    0.000237] Console: colour dummy device 80x30
      Jun  4 19:41:33 raspberrypi kernel: [    0.000260] console [tty1] enabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.000301] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000323] pid_max: default: 32768 minimum: 301
      Jun  4 19:41:33 raspberrypi kernel: [    0.000581] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.000599] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.001329] CPU: Testing write buffer coherency: ok
      Jun  4 19:41:33 raspberrypi kernel: [    0.001727] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      Jun  4 19:41:33 raspberrypi kernel: [    0.002354] Setting up static identity map for 0x200000 - 0x20003c
      Jun  4 19:41:33 raspberrypi kernel: [    0.002508] rcu: Hierarchical SRCU implementation.
      Jun  4 19:41:33 raspberrypi kernel: [    0.003351] smp: Bringing up secondary CPUs ...
      Jun  4 19:41:33 raspberrypi kernel: [    0.004208] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      Jun  4 19:41:33 raspberrypi kernel: [    0.005199] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      Jun  4 19:41:33 raspberrypi kernel: [    0.006150] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      Jun  4 19:41:33 raspberrypi kernel: [    0.006281] smp: Brought up 1 node, 4 CPUs
      Jun  4 19:41:33 raspberrypi kernel: [    0.006294] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      Jun  4 19:41:33 raspberrypi kernel: [    0.006304] CPU: All CPU(s) started in HYP mode.
      Jun  4 19:41:33 raspberrypi kernel: [    0.006312] CPU: Virtualization extensions available.
      Jun  4 19:41:33 raspberrypi kernel: [    0.007078] devtmpfs: initialized
      Jun  4 19:41:33 raspberrypi kernel: [    0.017355] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      Jun  4 19:41:33 raspberrypi kernel: [    0.017555] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      Jun  4 19:41:33 raspberrypi kernel: [    0.017576] futex hash table entries: 1024 (order: 4, 65536 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.025056] pinctrl core: initialized pinctrl subsystem
      Jun  4 19:41:33 raspberrypi kernel: [    0.025881] NET: Registered protocol family 16
      Jun  4 19:41:33 raspberrypi kernel: [    0.028602] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      Jun  4 19:41:33 raspberrypi kernel: [    0.030041] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      Jun  4 19:41:33 raspberrypi kernel: [    0.030052] hw-breakpoint: maximum watchpoint size is 8 bytes.
      Jun  4 19:41:33 raspberrypi kernel: [    0.030239] Serial: AMBA PL011 UART driver
      Jun  4 19:41:33 raspberrypi kernel: [    0.033266] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.068965] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
      Jun  4 19:41:33 raspberrypi kernel: [    0.071375] vgaarb: loaded
      Jun  4 19:41:33 raspberrypi kernel: [    0.071747] SCSI subsystem initialized
      Jun  4 19:41:33 raspberrypi kernel: [    0.071933] usbcore: registered new interface driver usbfs
      Jun  4 19:41:33 raspberrypi kernel: [    0.071990] usbcore: registered new interface driver hub
      Jun  4 19:41:33 raspberrypi kernel: [    0.072084] usbcore: registered new device driver usb
      Jun  4 19:41:33 raspberrypi kernel: [    0.090380] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:34, variant start
      Jun  4 19:41:33 raspberrypi kernel: [    0.100111] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8fa065b414d8fc07c525e7ddffc8
      Jun  4 19:41:33 raspberrypi kernel: [    0.111600] clocksource: Switched to clocksource arch_sys_counter
      Jun  4 19:41:33 raspberrypi kernel: [    0.188683] VFS: Disk quotas dquot_6.6.0
      Jun  4 19:41:33 raspberrypi kernel: [    0.188757] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.188905] FS-Cache: Loaded
      Jun  4 19:41:33 raspberrypi kernel: [    0.189081] CacheFiles: Loaded
      Jun  4 19:41:33 raspberrypi kernel: [    0.189573] simple-framebuffer: probe of 0.framebuffer failed with error -12
      Jun  4 19:41:33 raspberrypi kernel: [    0.198603] NET: Registered protocol family 2
      Jun  4 19:41:33 raspberrypi kernel: [    0.199237] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.199261] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.199331] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.199401] TCP: Hash tables configured (established 8192 bind 8192)
      Jun  4 19:41:33 raspberrypi kernel: [    0.199511] UDP hash table entries: 512 (order: 2, 16384 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.199538] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.199826] NET: Registered protocol family 1
      Jun  4 19:41:33 raspberrypi kernel: [    0.200345] RPC: Registered named UNIX socket transport module.
      Jun  4 19:41:33 raspberrypi kernel: [    0.200354] RPC: Registered udp transport module.
      Jun  4 19:41:33 raspberrypi kernel: [    0.200363] RPC: Registered tcp transport module.
      Jun  4 19:41:33 raspberrypi kernel: [    0.200372] RPC: Registered tcp NFSv4.1 backchannel transport module.
      Jun  4 19:41:33 raspberrypi kernel: [    0.203389] Initialise system trusted keyrings
      Jun  4 19:41:33 raspberrypi kernel: [    0.203563] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      Jun  4 19:41:33 raspberrypi kernel: [    0.212467] FS-Cache: Netfs 'nfs' registered for caching
      Jun  4 19:41:33 raspberrypi kernel: [    0.212934] NFS: Registering the id_resolver key type
      Jun  4 19:41:33 raspberrypi kernel: [    0.212982] Key type id_resolver registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.212991] Key type id_legacy registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.213010] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      Jun  4 19:41:33 raspberrypi kernel: [    0.215184] Key type asymmetric registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.215195] Asymmetric key parser 'x509' registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.215305] bounce: pool size: 64 pages
      Jun  4 19:41:33 raspberrypi kernel: [    0.215343] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
      Jun  4 19:41:33 raspberrypi kernel: [    0.215497] io scheduler noop registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.215508] io scheduler deadline registered (default)
      Jun  4 19:41:33 raspberrypi kernel: [    0.215659] io scheduler cfq registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.215670] io scheduler mq-deadline registered (default)
      Jun  4 19:41:33 raspberrypi mtp-probe: checking bus 2, device 2: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-2"
      Jun  4 19:41:33 raspberrypi kernel: [    0.215680] io scheduler kyber registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.239092] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
      Jun  4 19:41:33 raspberrypi kernel: [    0.239111] brcm-pcie fd500000.pcie: could not get clock
      Jun  4 19:41:33 raspberrypi kernel: [    0.239171] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      Jun  4 19:41:33 raspberrypi kernel: [    0.239208] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
      Jun  4 19:41:33 raspberrypi kernel: [    0.291634] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
      Jun  4 19:41:33 raspberrypi kernel: [    0.291880] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      Jun  4 19:41:33 raspberrypi kernel: [    0.291896] pci_bus 0000:00: root bus resource [bus 00-01]
      Jun  4 19:41:33 raspberrypi kernel: [    0.291912] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
      Jun  4 19:41:33 raspberrypi kernel: [    0.294805] PCI: bus0: Fast back to back transfers disabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.294822] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
      Jun  4 19:41:33 raspberrypi kernel: [    0.298215] PCI: bus1: Fast back to back transfers disabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.298277] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      Jun  4 19:41:33 raspberrypi kernel: [    0.298295] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      Jun  4 19:41:33 raspberrypi kernel: [    0.298365] pci 0000:00:00.0: PCI bridge to [bus 01]
      Jun  4 19:41:33 raspberrypi kernel: [    0.298382] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      Jun  4 19:41:33 raspberrypi kernel: [    0.298594] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      Jun  4 19:41:33 raspberrypi kernel: [    0.298759] pcieport 0000:00:00.0: Signaling PME with IRQ 56
      Jun  4 19:41:33 raspberrypi kernel: [    0.298916] pcieport 0000:00:00.0: AER enabled with IRQ 56
      Jun  4 19:41:33 raspberrypi kernel: [    0.299081] pci 0000:01:00.0: enabling device (0140 -> 0142)
      Jun  4 19:41:33 raspberrypi kernel: [    0.300901] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.302883] iproc-rng200 fe104000.rng: hwrng registered
      Jun  4 19:41:33 raspberrypi kernel: [    0.303104] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      Jun  4 19:41:33 raspberrypi kernel: [    0.303598] vc-sm: Videocore shared memory driver
      Jun  4 19:41:33 raspberrypi kernel: [    0.303982] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      Jun  4 19:41:33 raspberrypi kernel: [    0.313697] brd: module loaded
      Jun  4 19:41:33 raspberrypi kernel: [    0.323092] loop: module loaded
      Jun  4 19:41:33 raspberrypi kernel: [    0.323827] Loading iSCSI transport class v2.0-870.
      Jun  4 19:41:33 raspberrypi mtp-probe: bus: 2, device: 2 was not an MTP device
      Jun  4 19:41:33 raspberrypi kernel: [    0.325451] libphy: Fixed MDIO Bus: probed
      Jun  4 19:41:33 raspberrypi kernel: [    0.325861] bcmgenet fd580000.genet: failed to get enet clock
      Jun  4 19:41:33 raspberrypi kernel: [    0.325877] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
      Jun  4 19:41:33 raspberrypi kernel: [    0.325894] bcmgenet fd580000.genet: failed to get enet-wol clock
      Jun  4 19:41:33 raspberrypi kernel: [    0.325909] bcmgenet fd580000.genet: failed to get enet-eee clock
      Jun  4 19:41:33 raspberrypi kernel: [    0.325932] bcmgenet: Skipping UMAC reset
      Jun  4 19:41:33 raspberrypi kernel: [    0.326152] unimac-mdio unimac-mdio.-19: DMA mask not set
      Jun  4 19:41:33 raspberrypi kernel: [    0.341630] libphy: bcmgenet MII bus: probed
      Jun  4 19:41:33 raspberrypi kernel: [    0.382124] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
      Jun  4 19:41:33 raspberrypi kernel: [    0.382995] usbcore: registered new interface driver r8152
      Jun  4 19:41:33 raspberrypi kernel: [    0.383055] usbcore: registered new interface driver lan78xx
      Jun  4 19:41:33 raspberrypi kernel: [    0.383112] usbcore: registered new interface driver smsc95xx
      Jun  4 19:41:33 raspberrypi kernel: [    0.383408] xhci_hcd 0000:01:00.0: xHCI Host Controller
      Jun  4 19:41:33 raspberrypi kernel: [    0.383438] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      Jun  4 19:41:33 raspberrypi kernel: [    0.385673] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
      Jun  4 19:41:33 raspberrypi kernel: [    0.385973] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 57
      Jun  4 19:41:33 raspberrypi kernel: [    0.386832] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      Jun  4 19:41:33 raspberrypi kernel: [    0.386846] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      Jun  4 19:41:33 raspberrypi kernel: [    0.386857] usb usb1: Product: xHCI Host Controller
      Jun  4 19:41:33 raspberrypi kernel: [    0.386868] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
      Jun  4 19:41:33 raspberrypi kernel: [    0.386878] usb usb1: SerialNumber: 0000:01:00.0
      Jun  4 19:41:33 raspberrypi kernel: [    0.387376] hub 1-0:1.0: USB hub found
      Jun  4 19:41:33 raspberrypi kernel: [    0.387455] hub 1-0:1.0: 1 port detected
      Jun  4 19:41:33 raspberrypi kernel: [    0.387912] xhci_hcd 0000:01:00.0: xHCI Host Controller
      Jun  4 19:41:33 raspberrypi kernel: [    0.387934] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      Jun  4 19:41:33 raspberrypi kernel: [    0.387952] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      Jun  4 19:41:33 raspberrypi kernel: [    0.388360] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
      Jun  4 19:41:33 raspberrypi kernel: [    0.388373] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      Jun  4 19:41:33 raspberrypi kernel: [    0.388384] usb usb2: Product: xHCI Host Controller
      Jun  4 19:41:33 raspberrypi kernel: [    0.388395] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
      Jun  4 19:41:33 raspberrypi kernel: [    0.388406] usb usb2: SerialNumber: 0000:01:00.0
      Jun  4 19:41:33 raspberrypi kernel: [    0.388888] hub 2-0:1.0: USB hub found
      Jun  4 19:41:33 raspberrypi kernel: [    0.388946] hub 2-0:1.0: 4 ports detected
      Jun  4 19:41:33 raspberrypi kernel: [    0.390130] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      Jun  4 19:41:33 raspberrypi kernel: [    0.415682] dwc_otg fe980000.usb: base=(ptrval)
      Jun  4 19:41:33 raspberrypi kernel: [    0.615976] Core Release: 2.80a
      Jun  4 19:41:33 raspberrypi kernel: [    0.615995] Setting default values for core params
      Jun  4 19:41:33 raspberrypi kernel: [    0.616021] Finished setting default values for core params
      Jun  4 19:41:33 raspberrypi kernel: [    0.816349] Using Buffer DMA mode
      Jun  4 19:41:33 raspberrypi kernel: [    0.816359] Periodic Transfer Interrupt Enhancement - disabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.816368] Multiprocessor Interrupt Enhancement - disabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.816378] OTG VER PARAM: 0, OTG VER FLAG: 0
      Jun  4 19:41:33 raspberrypi kernel: [    0.816436] Dedicated Tx FIFOs mode
      Jun  4 19:41:33 raspberrypi kernel: [    0.816968] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded34000 dma = 0x00000000ded34000 len=9024
      Jun  4 19:41:33 raspberrypi kernel: [    0.816990] FIQ FSM acceleration enabled for :
      Jun  4 19:41:33 raspberrypi kernel: [    0.816990] Non-periodic Split Transactions
      Jun  4 19:41:33 raspberrypi kernel: [    0.816990] Periodic Split Transactions
      Jun  4 19:41:33 raspberrypi kernel: [    0.816990] High-Speed Isochronous Endpoints
      Jun  4 19:41:33 raspberrypi kernel: [    0.816990] Interrupt/Control Split Transaction hack enabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.817067] WARN::hcd_init_fiq:457: FIQ on core 1
      Jun  4 19:41:33 raspberrypi kernel: [    0.817083] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
      Jun  4 19:41:33 raspberrypi kernel: [    0.817099] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
      Jun  4 19:41:33 raspberrypi kernel: [    0.817135] dwc_otg fe980000.usb: DWC OTG Controller
      Jun  4 19:41:33 raspberrypi kernel: [    0.817164] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
      Jun  4 19:41:33 raspberrypi kernel: [    0.817197] dwc_otg fe980000.usb: irq 38, io mem 0x00000000
      Jun  4 19:41:33 raspberrypi kernel: [    0.817248] Init: Port Power? op_state=1
      Jun  4 19:41:33 raspberrypi kernel: [    0.817258] Init: Power Port (0)
      Jun  4 19:41:33 raspberrypi kernel: [    0.817523] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      Jun  4 19:41:33 raspberrypi kernel: [    0.817536] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      Jun  4 19:41:33 raspberrypi kernel: [    0.817548] usb usb3: Product: DWC OTG Controller
      Jun  4 19:41:33 raspberrypi kernel: [    0.817559] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
      Jun  4 19:41:33 raspberrypi kernel: [    0.817569] usb usb3: SerialNumber: fe980000.usb
      Jun  4 19:41:33 raspberrypi kernel: [    0.818067] hub 3-0:1.0: USB hub found
      Jun  4 19:41:33 raspberrypi kernel: [    0.818114] hub 3-0:1.0: 1 port detected
      Jun  4 19:41:33 raspberrypi kernel: [    0.818921] usbcore: registered new interface driver uas
      Jun  4 19:41:33 raspberrypi kernel: [    0.819034] usbcore: registered new interface driver usb-storage
      Jun  4 19:41:33 raspberrypi kernel: [    0.819195] mousedev: PS/2 mouse device common for all mice
      Jun  4 19:41:33 raspberrypi kernel: [    0.820361] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      Jun  4 19:41:33 raspberrypi kernel: [    0.820536] bcm2835-cpufreq: min=600000 max=1500000
      Jun  4 19:41:33 raspberrypi kernel: [    0.821071] sdhci: Secure Digital Host Controller Interface driver
      Jun  4 19:41:33 raspberrypi kernel: [    0.821080] sdhci: Copyright(c) Pierre Ossman
      Jun  4 19:41:33 raspberrypi kernel: [    0.821453] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      Jun  4 19:41:33 raspberrypi kernel: [    0.821863] sdhci-pltfm: SDHCI platform and OF driver helper
      Jun  4 19:41:33 raspberrypi kernel: [    0.824782] ledtrig-cpu: registered to indicate activity on CPUs
      Jun  4 19:41:33 raspberrypi kernel: [    0.824927] hidraw: raw HID events driver (C) Jiri Kosina
      Jun  4 19:41:33 raspberrypi kernel: [    0.825068] usbcore: registered new interface driver usbhid
      Jun  4 19:41:33 raspberrypi kernel: [    0.825077] usbhid: USB HID core driver
      Jun  4 19:41:33 raspberrypi kernel: [    0.825771] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
      Jun  4 19:41:33 raspberrypi kernel: [    0.827043] [vc_sm_connected_init]: start
      Jun  4 19:41:33 raspberrypi kernel: [    0.833132] [vc_sm_connected_init]: end - returning 0
      Jun  4 19:41:33 raspberrypi kernel: [    0.834197] Initializing XFRM netlink socket
      Jun  4 19:41:33 raspberrypi kernel: [    0.834224] NET: Registered protocol family 17
      Jun  4 19:41:33 raspberrypi kernel: [    0.834316] Key type dns_resolver registered
      Jun  4 19:41:33 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
      Jun  4 19:41:33 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="321" x-info="https://www.rsyslog.com"] start
      Jun  4 19:41:33 raspberrypi kernel: [    0.834646] Registering SWP/SWPB emulation handler
      Jun  4 19:41:33 raspberrypi kernel: [    0.835214] registered taskstats version 1
      Jun  4 19:41:33 raspberrypi kernel: [    0.835229] Loading compiled-in X.509 certificates
      Jun  4 19:41:33 raspberrypi kernel: [    0.842892] uart-pl011 fe201000.serial: cts_event_workaround enabled
      Jun  4 19:41:33 raspberrypi kernel: [    0.842952] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
      Jun  4 19:41:33 raspberrypi kernel: [    0.846208] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 62500000) is a 16550
      Jun  4 19:41:33 raspberrypi kernel: [    0.846639] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      Jun  4 19:41:33 raspberrypi kernel: [    0.847109] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
      Jun  4 19:41:33 raspberrypi kernel: [    0.847715] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      Jun  4 19:41:33 raspberrypi kernel: [    0.847727] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      Jun  4 19:41:33 raspberrypi kernel: [    0.872154] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
      Jun  4 19:41:33 raspberrypi kernel: [    0.892103] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.893703] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.895302] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.898169] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.899767] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      Jun  4 19:41:33 raspberrypi kernel: [    0.904291] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      Jun  4 19:41:33 raspberrypi kernel: [    0.906585] of_cfs_init
      Jun  4 19:41:33 raspberrypi kernel: [    0.906677] of_cfs_init: OK
      Jun  4 19:41:33 raspberrypi kernel: [    0.907311] Waiting for root device /dev/sda2...
      Jun  4 19:41:33 raspberrypi kernel: [    0.954475] random: fast init done
      Jun  4 19:41:33 raspberrypi kernel: [    0.961644] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      Jun  4 19:41:33 raspberrypi kernel: [    1.007358] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
      Jun  4 19:41:33 raspberrypi kernel: [    1.008480] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
      Jun  4 19:41:33 raspberrypi kernel: [    1.010035] mmc1: new high speed SDIO card at address 0001
      Jun  4 19:41:33 raspberrypi kernel: [    1.011342]  mmcblk0: p1 p2
      Jun  4 19:41:33 raspberrypi kernel: [    1.144259] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
      Jun  4 19:41:33 raspberrypi kernel: [    1.144273] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      Jun  4 19:41:33 raspberrypi kernel: [    1.144285] usb 1-1: Product: USB2.0 Hub
      Jun  4 19:41:33 raspberrypi kernel: [    1.145892] hub 1-1:1.0: USB hub found
      Jun  4 19:41:33 raspberrypi kernel: [    1.146249] hub 1-1:1.0: 4 ports detected
      Jun  4 19:41:33 raspberrypi kernel: [    1.292002] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
      Jun  4 19:41:33 raspberrypi kernel: [    1.324875] usb 2-2: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
      Jun  4 19:41:33 raspberrypi kernel: [    1.324889] usb 2-2: New USB device strings: Mfr=4, Product=5, SerialNumber=6
      Jun  4 19:41:33 raspberrypi kernel: [    1.324900] usb 2-2: SerialNumber: 20200109
      Jun  4 19:41:33 raspberrypi kernel: [    1.328434] usb-storage 2-2:1.0: USB Mass Storage device detected
      Jun  4 19:41:33 raspberrypi kernel: [    1.328914] scsi host0: usb-storage 2-2:1.0
      Jun  4 19:41:33 raspberrypi kernel: [    2.700480] scsi 0:0:0:0: Direct-Access     Intenso  SSD Sata III          PQ: 0 ANSI: 6
      Jun  4 19:41:33 raspberrypi kernel: [    2.701531] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
      Jun  4 19:41:33 raspberrypi kernel: [    2.702317] sd 0:0:0:0: [sda] Write Protect is off
      Jun  4 19:41:33 raspberrypi kernel: [    2.706539]  sda: sda1 sda2
      Jun  4 19:41:33 raspberrypi kernel: [    2.709755] sd 0:0:0:0: [sda] Attached SCSI disk
      Jun  4 19:41:33 raspberrypi kernel: [    2.733128] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      Jun  4 19:41:33 raspberrypi kernel: [    2.733139] EXT4-fs (sda2): write access will be enabled during recovery
      Jun  4 19:41:33 raspberrypi kernel: [    2.867438] EXT4-fs (sda2): orphan cleanup on readonly fs
      Jun  4 19:41:33 raspberrypi kernel: [    2.882975] EXT4-fs (sda2): 3 orphan inodes deleted
      Jun  4 19:41:33 raspberrypi kernel: [    2.882987] EXT4-fs (sda2): recovery complete
      Jun  4 19:41:33 raspberrypi kernel: [    2.889207] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      Jun  4 19:41:33 raspberrypi kernel: [    2.889251] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      Jun  4 19:41:33 raspberrypi kernel: [    2.889995] devtmpfs: mounted
      Jun  4 19:41:33 raspberrypi kernel: [    2.896231] Freeing unused kernel memory: 2048K
      Jun  4 19:41:33 raspberrypi kernel: [    2.931858] Run /sbin/init as init process
      Jun  4 19:41:33 raspberrypi kernel: [    3.784631] random: systemd: uninitialized urandom read (16 bytes read)
      Jun  4 19:41:33 raspberrypi kernel: [    3.793246] random: systemd: uninitialized urandom read (16 bytes read)
      Jun  4 19:41:33 raspberrypi kernel: [    3.794202] random: systemd: uninitialized urandom read (16 bytes read)
      Jun  4 19:41:33 raspberrypi kernel: [    4.471631] EXT4-fs (sda2): re-mounted. Opts: (null)
      Jun  4 19:41:33 raspberrypi kernel: [    7.468661] random: crng init done
      Jun  4 19:41:33 raspberrypi kernel: [    7.468673] random: 7 urandom warning(s) missed due to ratelimiting
      Jun  4 19:41:33 raspberrypi kernel: [    7.835219] uart-pl011 fe201000.serial: no DMA platform data
      Jun  4 19:41:34 raspberrypi udisksd[352]: udisks daemon version 2.8.1 starting
      Jun  4 19:41:34 raspberrypi kernel: [    8.330639] bcmgenet: Skipping UMAC reset
      Jun  4 19:41:34 raspberrypi kernel: [    8.432181] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
      Jun  4 19:41:34 raspberrypi udisksd[352]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
      Jun  4 19:41:34 raspberrypi udisksd[352]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
      Jun  4 19:41:34 raspberrypi kernel: [    8.480507] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
      Jun  4 19:41:34 raspberrypi udisksd[352]: Failed to load the 'mdraid' libblockdev plugin
      Jun  4 19:41:34 raspberrypi udisksd[352]: Failed to load the 'crypto' libblockdev plugin
      Jun  4 19:41:34 raspberrypi lightdm[446]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
      Jun  4 19:41:34 raspberrypi udisksd[352]: Acquired the name org.freedesktop.UDisks2 on the system message bus
      Jun  4 19:41:35 raspberrypi kernel: [    9.511740] bcmgenet fd580000.genet eth0: Link is Down
      Jun  4 19:41:35 raspberrypi lightdm[527]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
      Jun  4 19:41:35 raspberrypi lightdm[547]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
      Jun  4 19:41:36 raspberrypi lightdm[561]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
      Jun  4 19:41:36 raspberrypi lightdm[570]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
      Jun  4 19:41:38 raspberrypi kernel: [   12.631763] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      Jun  4 19:41:55 raspberrypi kernel: [   29.812200] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
      Jun  4 20:59:50 raspberrypi kernel: [   86.202128] device eth0 entered promiscuous mode
      Jun  4 22:21:46 raspberrypi kernel: [ 5002.260018] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
      • C Offline
        cherberg
        @cherberg said in iobroker nicht mehr erreichbar - Fehlersuche?:
        Ich habe mal proaktiv die offenbar fehlenden Module
        libblockdev-crypto2
        libblockdev-mdraid2
        nachinstalliert, aber das ist nur ein laienhafter Versuch, ob das mein Problem löst wage ich zu bezweifeln :-)
        • C cherberg
          libblockdev-crypto2
          libblockdev-mdraid2
          @cherberg
          Deine Festplatte hat 'nen Schuss:
          Kannst auch nochmal mit
          mount | sort | grep ^/dev
          schauen wie die eingehängt wurde.
          C 2 Antworten Letzte Antwort
            @cherberg
            cherberg
            @Thomas-Braun
            hm, das ist ne nagelneue SSD (günstig Intenso), ich hänge die mal an meinen Windows PC und prüfe die SMART Werte der Platte.
            Allerdings habe ich die Partitionen auf der SSD von einer SD Karte geklont.
            Kann es sein, dass die SSD an sich in Ordnung ist, ich auf diesem Weg aber Defekte im Filesystem mit geklont habe? Gibt es ein Tool zur Korrektur des Filesystems wie checkdisk unter Windows? Google meint fsck, aber das läuft nicht:
            pi@raspberrypi:~ $ sudo fsck
            fsck from util-linux 2.33.1
            e2fsck 1.44.5 (15-Dec-2018)
            /dev/sda2 is mounted.
            e2fsck: Cannot continue, aborting.
              @cherberg
              cherberg
              @Thomas-Braun said in iobroker nicht mehr erreichbar - Fehlersuche?:
              Das gibt folgendes aus:
              pi@raspberrypi:~ $ mount | sort | grep ^/dev
              /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
              /dev/sda2 on / type ext4 (rw,noatime)
              • C cherberg
                @Thomas-Braun
                @cherberg Ja, beim clonen werden auch Fehler geklont.
                Ein fsck kann nur auf nichteingehängten Dateisystemen erfolgen.
                Außerdem hat das System das bereits versucht.
                Jedenfalls ist / auch wieder rw (les-/schreibbar) gemounted worden, dass passt.
                C 1 Antwort Letzte Antwort
                  cherberg
                  @Thomas-Braun
                  hm was wäre denn nun der Weg der Wahl?
                  Soll ich die Platte mal an einen anderen RPI hängen und fsck ausführen oder hilft hier nur eine Neuinstallation? Vor der habe ich allerdings Respekt. Ich habe schon einiges gebastelt und geskripted. BackItUp habe ich nocht nicht zum Laufen bekommen und wäre echt aufgeschmissen wenn ich alles neu machen müsste :-(
                  • C cherberg
                    @Thomas-Braun
                    @cherberg Ich würde es mal beobachten...
                    Was mich wundert: Hattest du nicht geschrieben, dass /boot auf der SD-Karte läge?
                    Laut deinem mount liegt das auf sda1 (Also der Festplatte)
                      cherberg
                      @Thomas-Braun
                      Also der Pi4 kann ja (noch) nicht direkt von USB booten. Daher gibt es die Anleitung die SD Karte zuerst auf eine HDD/SSD zu klonen.
                      In der Bootpartition der SD Karte in der cmdline.txt dann den Eintrag für die Rootpartition so zu ändern, so dass das System diese auf der SSD/HDD sucht: root=/dev/sda2
                      Beim Start wird dann wohl von der SD gebootet, das System liegt aber auf der SSD. Daher sollte es keine Alterung mehr geben wie es sie gibt wenn das gesamte System auf der SD liegt.
                      Daher ist auf der SSD wegen des Klonvorgangs auch eine Boot Partition vorhanden, diese ist aber nur ein ungenutztes Überbleibsel.
                        cherberg
                        @Thomas-Braun
                        naja beobachten tue ich es ja schon seit einiger Zeit und habe leider immer mal wieder Abbrüche die nur durch einen Neustart (Stecker ziehen) gelöst werden können :-(
                        • C cherberg
                          @Thomas-Braun
                          @cherberg
                          who -r
                          free -h
                          • C cherberg
                            @Thomas-Braun
                            Meister MopperM Offline
                            Meister Mopper
                            @cherberg sagte in iobroker nicht mehr erreichbar - Fehlersuche?:
                            @Thomas-Braun
                            Also der Pi4 kann ja (noch) nicht direkt von USB booten....
                            Es gibt mittlerweile eine beta-Lösung zum booten von SSD. Bei mir funktioniert es bisher super.
                            Proxmox und HA ...
                              @cherberg
                              who -r
                              free -h
                              cherberg
                              free -h
                              pi@raspberrypi:~ $ who -r
                                       Runlevel 5   2020-06-04 23:11
                              pi@raspberrypi:~ $ free -h
                              Mem:          3,8Gi       1,0Gi       2,3Gi        16Mi       523Mi       2,7Gi
                              Swap:          99Mi          0B        99Mi
                              pi@raspberrypi:~ $
                              • C cherberg
                                free -h
                                Swap:          99Mi          0B        99Mi
                                pi@raspberrypi:~ $
                                @cherberg
                                Speicher ist genug vorhanden.
                                Ich würde aber den Raspberry als Server in RunLevel 3 betreiben.
                                sudo raspi-config
                                Und dann
                                3 - B1 - B1 oder B2
                                wählen. Neustart.
                                  @cherberg
                                  sudo raspi-config
                                  Und dann
                                  3 - B1 - B1 oder B2
                                  wählen. Neustart.
                                  cherberg
                                  sudo raspi-config
                                  ja ich hatte vorher einen Pi2 mit nur 1 GB RAM, der kam dann mit einigen Adaptern schnell an die Grenzen und durch kontinuierliches swappen frass er SD Karten wie andere Leute Chips 😵
                                  Der Runlevel ist nun auf 3:
                                           Runlevel 3   2020-06-05 14:21
                                  Mem:          3,8Gi       936Mi       2,5Gi        24Mi       391Mi       2,8Gi
                                  Swap:          99Mi          0B        99Mi
                                  pi@raspberrypi:~ $
                                  • C cherberg
                                    sudo raspi-config
                                    Swap:          99Mi          0B        99Mi
                                    pi@raspberrypi:~ $
                                    cherberg
                                    @cherberg
                                    Nur zur Info nach vielen Versuchen habe ich mich entschieden das System komplett neu aufzusetzen und hierbei einen neuen SATA Adapter und auch eine neue Festplatte zu verwenden. Ich alles neu installiert und habe lediglich die Skripte exportiert und wieder importiert. Seit einigen Wochen läuft das System nun stabil.
