  4. [fixed] Fehler beim Updaten von sayit
    2.5k
    4.4k
3 Beiträge 2 Kommentatoren 786 Aufrufe
    tesso
    seit den Wochenende habe ich ein Problem damit den sayit Adapter upzudaten.
    Auch ein deinstallieren und neu installiert schlägt fehl.
    root@pi01:/opt/iobroker# iobroker upgrade sayit
    npm install iobroker.sayit --production --prefix "/opt/iobroker" (System call)
    npm http GET https://registry.npmjs.org/iobroker.sayit
    npm http 304 https://registry.npmjs.org/iobroker.sayit
    npm http GET https://registry.npmjs.org/jsftp
    npm http GET https://registry.npmjs.org/ivona-node
    npm http 304 https://registry.npmjs.org/jsftp
    npm http 304 https://registry.npmjs.org/ivona-node
    npm http GET https://registry.npmjs.org/aws4
    npm http 304 https://registry.npmjs.org/aws4
    npm http GET https://registry.npmjs.org/lru-cache
    npm http 304 https://registry.npmjs.org/lru-cache
    npm http GET https://registry.npmjs.org/debug/2.2.0
    npm http GET https://registry.npmjs.org/ftp-response-parser/1.0.0
    npm http GET https://registry.npmjs.org/parse-listing/1.1.3
    npm http GET https://registry.npmjs.org/once/1.3.0
    npm http GET https://registry.npmjs.org/unorm/1.4.1
    npm http GET https://registry.npmjs.org/event-stream/3.1.7
    npm http 304 https://registry.npmjs.org/debug/2.2.0
    npm http 304 https://registry.npmjs.org/parse-listing/1.1.3
    npm http 304 https://registry.npmjs.org/unorm/1.4.1
    npm http 304 https://registry.npmjs.org/ftp-response-parser/1.0.0
    npm http 304 https://registry.npmjs.org/once/1.3.0
    npm http 304 https://registry.npmjs.org/event-stream/3.1.7
    npm http GET https://registry.npmjs.org/ms/0.7.1
    npm http 304 https://registry.npmjs.org/ms/0.7.1
    npm http GET https://registry.npmjs.org/pause-stream/0.0.11
    npm http GET https://registry.npmjs.org/split
    npm http GET https://registry.npmjs.org/stream-combiner
    npm http GET https://registry.npmjs.org/through
    npm http GET https://registry.npmjs.org/duplexer
    npm http GET https://registry.npmjs.org/from
    npm http GET https://registry.npmjs.org/map-stream
    npm http 304 https://registry.npmjs.org/pause-stream/0.0.11
    npm http 304 https://registry.npmjs.org/stream-combiner
    npm http 304 https://registry.npmjs.org/from
    npm http 200 https://registry.npmjs.org/split
    npm http 304 https://registry.npmjs.org/duplexer
    npm http 304 https://registry.npmjs.org/through
    npm http 304 https://registry.npmjs.org/map-stream
    npm http GET https://registry.npmjs.org/readable-stream
    npm http 304 https://registry.npmjs.org/readable-stream
    npm http GET https://registry.npmjs.org/core-util-is
    npm http GET https://registry.npmjs.org/isarray/0.0.1
    npm http GET https://registry.npmjs.org/string_decoder
    npm http GET https://registry.npmjs.org/inherits
    npm http 304 https://registry.npmjs.org/isarray/0.0.1
    npm http 304 https://registry.npmjs.org/inherits
    npm http 304 https://registry.npmjs.org/string_decoder
    npm http 304 https://registry.npmjs.org/core-util-is
    Killed
    npm ERR! iobroker.sayit@1.0.0 install: `node main.js --install`
    npm ERR! Exit status 137
    npm ERR!
    npm ERR! Failed at the iobroker.sayit@1.0.0 install script.
    npm ERR! This is most likely a problem with the iobroker.sayit package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node main.js --install
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls iobroker.sayit
    npm ERR! There is likely additional logging output above.
    npm ERR! System Linux 3.18.11-v7+
    npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sayit" "--production" "--prefix" "/opt/iobroker"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v0.10.22
    npm ERR! npm -v 1.3.14
    npm ERR! code ELIFECYCLE
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! not ok code 0
    host.pi01 Cannot install iobroker.sayit: 1
    Hat jemand eine Idee wie ich den Fehler eingrenzen kann?
    • BluefoxB Offline
      BluefoxB Offline
      /opt/iobroker/npm-debug.log ?
        tesso
        Thema hat sich erledigt.
        Das System machte nach über einem Jahr updaten immer mehr Probleme. Habe mich entschlossen, alles neu aufzubauen. Mit jessie und ohne Restmüll läuft jetzt alles wieder flott. auch die sayit Updateprobleme sind plötzlich weg.
