  4. HS100 Adapter Fehlermeldungen
    6.8k
hs100 adapterfehler im log
190 Beiträge 23 Kommentatoren 37.0k Aufrufe 22 Beobachtet
  • arteckA arteck
    nicht zu früh freuen.. ich bin auch noch am testen..
    muckel
    #73
    @arteck
    Test läuft seit Mittags
    Uuups; war das jetzt ein Ausrutscher?
    Hatte ich mit der .../error Version nicht mehr
    host.SmartHome	2020-05-05 16:55:43.422	info	Restart adapter system.adapter.hs100.0 because enabled
    host.SmartHome	2020-05-05 16:55:43.422	info	instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at TCP.<anonymous> (net.js:672:12)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at Socket.emit (events.js:310:20)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at Object.onceWrapper (events.js:417:26)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[3]: TCP 192.168.0.44:9999 Error: TCP Socket Closed. segment:0 hadError:false
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[2]: at TCP.<anonymous> (net.js:672:12)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[2]: at Socket.emit (events.js:310:20)
    host.SmartHome	2020-05-05 16:55:43.422	error	Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[2]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[2]: TCP 192.168.0.44:9999 Error: TCP Socket Closed. segment:0 hadError:false
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at TCP.<anonymous> (net.js:672:12)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at Socket.emit (events.js:310:20)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[1]: TCP 192.168.0.39:9999 Error: TCP Socket Closed. segment:0 hadError:false
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[0]: at TCP.<anonymous> (net.js:672:12)
    host.SmartHome	2020-05-05 16:55:43.421	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
    host.SmartHome	2020-05-05 16:55:43.420	error	Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
    host.SmartHome	2020-05-05 16:55:43.420	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    host.SmartHome	2020-05-05 16:55:43.418	error	Caught by controller[0]: TCP 192.168.0.45:9999 Error: TCP Socket Closed. segment:0 hadError:false
    hs100.0	2020-05-05 16:55:42.983	error	at TCP.<anonymous> (net.js:672:12)
    hs100.0	2020-05-05 16:55:42.983	error	at Socket.emit (events.js:310:20)
    hs100.0	2020-05-05 16:55:42.983	error	at Object.onceWrapper (events.js:417:26)
    hs100.0	2020-05-05 16:55:42.983	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    hs100.0	2020-05-05 16:55:42.983	error	(28099) Error: TCP Socket Closed. segment:0 hadError:false
    hs100.0	2020-05-05 16:55:42.982	error	(28099) uncaught exception: TCP Socket Closed. segment:0 hadError:false
    hs100.0	2020-05-05 16:55:42.950	error	at TCP.<anonymous> (net.js:672:12)
    hs100.0	2020-05-05 16:55:42.950	error	at Socket.emit (events.js:310:20)
    hs100.0	2020-05-05 16:55:42.950	error	at Object.onceWrapper (events.js:417:26)
    hs100.0	2020-05-05 16:55:42.950	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    hs100.0	2020-05-05 16:55:42.950	error	(28099) Error: TCP Socket Closed. segment:0 hadError:false
    hs100.0	2020-05-05 16:55:42.950	error	(28099) uncaught exception: TCP Socket Closed. segment:0 hadError:false
    hs100.0	2020-05-05 16:55:42.881	info	(28099) Terminated (NO_ERROR): Without reason
    hs100.0	2020-05-05 16:55:42.880	info	(28099) terminating
    hs100.0	2020-05-05 16:55:42.877	error	at TCP.<anonymous> (net.js:672:12)
    hs100.0	2020-05-05 16:55:42.877	error	at Socket.emit (events.js:310:20)
    hs100.0	2020-05-05 16:55:42.877	error	at Object.onceWrapper (events.js:417:26)
    hs100.0	2020-05-05 16:55:42.877	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
    hs100.0	2020-05-05 16:55:42.877	error	(28099) Error: TCP Socket Closed. segment:0 hadError:false
    hs100.0	2020-05-05 16:55:42.875	error	(28099) uncaught exception: TCP Socket Closed. segment:0 hadError:false
      skokarl
      schrieb am zuletzt editiert von skokarl
      #74
      so,
      vor 17 Stunden Adapter aktualisiert.
      Test bist jetzt :
      NICHTS, KEIN ERROR
      @muckel....den Upload hattest Du gemacht ?
      • B Berchemer
        @arteck sagte in HS100 Adapter Fehlermeldungen:
        https://github.com/arteck/ioBroker.hs100
        Test läuft auch hier :-)
        Berchemer
        schrieb am zuletzt editiert von Berchemer
        #75
        @Berchemer sagte in HS100 Adapter Fehlermeldungen:
        Sorry... Hatte vor 9 Stunden von Github installiert, Upload durchgeführt, dann lief es sorgenfrei... Bis vor Kurzem:
        2020-05-05 17:31:42.282 - debug: hs100.0 (32448) HS Plug 192.1.1.132
        2020-05-05 17:31:42.282 - debug: hs100.0 (32448) HS Plug 192.1.1.131
        2020-05-05 17:31:42.467 - debug: hs100.0 (32448) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:31:42
        2020-05-05 17:31:42.548 - debug: hs100.0 (32448) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:31:42
        2020-05-05 17:31:43.720 - debug: hs100.0 (32448) Refresh Data HS110 192.1.1.132
        2020-05-05 17:31:44.581 - debug: hs100.0 (32448) Month value HS110(EU) 192.1.1.132
        2020-05-05 17:31:45.017 - debug: hs100.0 (32448) Day value HS110(EU) 0.32 192.1.1.132
        2020-05-05 17:31:52.469 - error: hs100.0 (32448) uncaught exception: TCP Timeout
        2020-05-05 17:31:52.469 - error: hs100.0 (32448) Error: TCP Timeout
        at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
        at listOnTimeout (internal/timers.js:549:17)
        at processTimers (internal/timers.js:492:7)
        2020-05-05 17:31:52.470 - debug: hs100.0 (32448) Send error setDevState : Error: TCP Timeout
        2020-05-05 17:31:52.472 - info: hs100.0 (32448) terminating
        2020-05-05 17:31:52.472 - info: hs100.0 (32448) Terminated (NO_ERROR): Without reason
        2020-05-05 17:31:52.983 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Timeout
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[1]: at processTimers (internal/timers.js:492:7)
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
        2020-05-05 17:31:52.984 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
        2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
        2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
        2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
        2020-05-05 17:31:52.985 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
        2020-05-05 17:31:52.985 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
        2020-05-05 17:31:52.985 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
        2020-05-05 17:32:23.031 - info: host.SERVER instance system.adapter.hs100.0 started with pid 28913
        2020-05-05 17:32:23.223 - debug: hs100.0 (28913) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2020-05-05 17:32:23.232 - debug: hs100.0 (28913) Objects client ready ... initialize now
        2020-05-05 17:32:23.233 - debug: hs100.0 (28913) Objects create System PubSub Client
        2020-05-05 17:32:23.234 - debug: hs100.0 (28913) Objects create User PubSub Client
        2020-05-05 17:32:23.234 - debug: hs100.0 (28913) Objects client initialize lua scripts
        2020-05-05 17:32:23.241 - debug: hs100.0 (28913) Objects connected to redis: 0.0.0.0:9001
        2020-05-05 17:32:23.242 - debug: hs100.0 (28913) objectDB connected
        2020-05-05 17:32:23.243 - debug: hs100.0 (28913) Redis States: Use Redis connection: 0.0.0.0:9000
        2020-05-05 17:32:23.247 - debug: hs100.0 (28913) States create User PubSub Client
        2020-05-05 17:32:23.248 - debug: hs100.0 (28913) States create System PubSub Client
        2020-05-05 17:32:23.254 - debug: hs100.0 (28913) States connected to redis: 0.0.0.0:9000
        2020-05-05 17:32:23.254 - debug: hs100.0 (28913) statesDB connected
        2020-05-05 17:32:23.412 - info: hs100.0 (28913) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
        2020-05-05 17:32:23.424 - debug: hs100.0 (28913) Host = SERVER
        2020-05-05 17:32:23.446 - debug: hs100.0 (28913) undefined generated 192.1.1.131
        2020-05-05 17:32:23.447 - debug: hs100.0 (28913) undefined generated 192.1.1.132
        2020-05-05 17:32:23.700 - debug: hs100.0 (28913) HS Plug 192.1.1.132
        2020-05-05 17:32:23.701 - debug: hs100.0 (28913) HS Plug 192.1.1.131
        2020-05-05 17:32:25.700 - debug: hs100.0 (28913) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:32:25
        2020-05-05 17:32:26.862 - debug: hs100.0 (28913) Refresh Data HS110 192.1.1.132
        2020-05-05 17:32:27.735 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.132
        2020-05-05 17:32:28.169 - debug: hs100.0 (28913) Day value HS110(EU) 0.32 192.1.1.132
        2020-05-05 17:32:30.162 - debug: hs100.0 (28913) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:32:30
        2020-05-05 17:32:30.453 - debug: hs100.0 (28913) Refresh Data HS110 192.1.1.131
        2020-05-05 17:32:30.744 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.131
        2020-05-05 17:32:31.034 - debug: hs100.0 (28913) Day value HS110(EU) 0.438 192.1.1.131
        2020-05-05 17:34:23.703 - debug: hs100.0 (28913) HS Plug 192.1.1.132
        2020-05-05 17:34:23.705 - debug: hs100.0 (28913) HS Plug 192.1.1.131
        2020-05-05 17:34:23.920 - debug: hs100.0 (28913) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:34:23
        2020-05-05 17:34:25.080 - debug: hs100.0 (28913) Refresh Data HS110 192.1.1.132
        2020-05-05 17:34:25.952 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.132
        2020-05-05 17:34:26.182 - debug: hs100.0 (28913) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:34:26
        2020-05-05 17:34:26.390 - debug: hs100.0 (28913) Day value HS110(EU) 0.32 192.1.1.132
        2020-05-05 17:34:32.058 - error: hs100.0 (28913) uncaught exception: TCP Socket Closed. segment:0 hadError:false
        2020-05-05 17:34:32.058 - error: hs100.0 (28913) Error: TCP Socket Closed. segment:0 hadError:false
        at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        at TCP. (net.js:672:12)
        2020-05-05 17:34:32.059 - debug: hs100.0 (28913) Send error setDevState : Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-05 17:34:32.061 - info: hs100.0 (28913) terminating
        2020-05-05 17:34:32.061 - info: hs100.0 (28913) Terminated (NO_ERROR): Without reason
        2020-05-05 17:34:32.304 - debug: hs100.0 (28913) Month value HS110(EU) 192.1.1.131
        2020-05-05 17:34:32.576 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
        2020-05-05 17:34:32.578 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
        2020-05-05 17:34:32.578 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
        2020-05-05 17:34:32.579 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
        2020-05-05 17:35:00.052 - info: host.SERVER instance system.adapter.dwd.0 started with pid 31169
        2020-05-05 17:35:02.620 - info: host.SERVER instance system.adapter.hs100.0 started with pid 31227
        2020-05-05 17:35:02.811 - debug: hs100.0 (31227) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2020-05-05 17:35:02.822 - debug: hs100.0 (31227) Objects client ready ... initialize now
        2020-05-05 17:35:02.823 - debug: hs100.0 (31227) Objects create System PubSub Client
        2020-05-05 17:35:02.823 - debug: hs100.0 (31227) Objects create User PubSub Client
        2020-05-05 17:35:02.824 - debug: hs100.0 (31227) Objects client initialize lua scripts
        2020-05-05 17:35:02.834 - debug: hs100.0 (31227) Objects connected to redis: 0.0.0.0:9001
        2020-05-05 17:35:02.836 - debug: hs100.0 (31227) objectDB connected
        2020-05-05 17:35:02.837 - debug: hs100.0 (31227) Redis States: Use Redis connection: 0.0.0.0:9000
        2020-05-05 17:35:02.842 - debug: hs100.0 (31227) States create User PubSub Client
        2020-05-05 17:35:02.842 - debug: hs100.0 (31227) States create System PubSub Client
        2020-05-05 17:35:02.851 - debug: hs100.0 (31227) States connected to redis: 0.0.0.0:9000
        2020-05-05 17:35:02.851 - debug: hs100.0 (31227) statesDB connected
        2020-05-05 17:35:03.034 - info: hs100.0 (31227) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
        2020-05-05 17:35:03.044 - debug: hs100.0 (31227) Host = SERVER
        2020-05-05 17:35:03.070 - debug: hs100.0 (31227) undefined generated 192.1.1.131
        2020-05-05 17:35:03.114 - debug: hs100.0 (31227) undefined generated 192.1.1.132
        2020-05-05 17:35:03.413 - debug: hs100.0 (31227) HS Plug 192.1.1.132
        2020-05-05 17:35:03.415 - debug: hs100.0 (31227) HS Plug 192.1.1.131
        2020-05-05 17:35:05.443 - debug: hs100.0 (31227) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.5 17:35:05
        2020-05-05 17:35:06.605 - debug: hs100.0 (31227) Refresh Data HS110 192.1.1.132
        2020-05-05 17:35:07.476 - debug: hs100.0 (31227) Month value HS110(EU) 192.1.1.132
        2020-05-05 17:35:07.912 - debug: hs100.0 (31227) Day value HS110(EU) 0.32 192.1.1.132
        2020-05-05 17:35:10.191 - debug: hs100.0 (31227) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.5 17:35:10
        2020-05-05 17:35:12.684 - debug: hs100.0 (31227) Refresh Data HS110 192.1.1.131
        2020-05-05 17:35:13.529 - debug: hs100.0 (31227) Month value HS110(EU) 192.1.1.131
        2020-05-05 17:35:13.965 - debug: hs100.0 (31227) Day value HS110(EU) 0.44 192.1.1.131
        • B Berchemer
          skokarl
          #76
          @Berchemer
          bei mir seit 17 Std. sauber
          • S skokarl
            so,
            Test bist jetzt :
            NICHTS, KEIN ERROR
            muckel
            #77
            @skokarl
            natürlich, hab ja dazugelernt :-)
            Bis jetzt kam es nicht mehr.
            • M muckel
              @skokarl
              skokarl
              #78
              @muckel sagte in HS100 Adapter Fehlermeldungen:
              @skokarl
              Du hattest doch eben noch von Fehler gesprochen ?
              M 2 Antworten Letzte Antwort
              • S skokarl
                @skokarl
                muckel
                #79
                @skokarl
                Siehe Logfile. Das kam einmalig. Seither nichts mehr. Seltsam
                • S skokarl
                  @skokarl
                  muckel
                  #80
                  @skokarl
                  wieder
                  host.SmartHome	2020-05-05 20:04:43.615	error	Caught by controller[0]: at TCP.<anonymous> (net.js:672:12)
                  host.SmartHome	2020-05-05 20:04:43.615	error	Caught by controller[0]: at Socket.emit (events.js:310:20)
                  host.SmartHome	2020-05-05 20:04:43.614	error	Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                  host.SmartHome	2020-05-05 20:04:43.614	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                  host.SmartHome	2020-05-05 20:04:43.612	error	Caught by controller[0]: TCP 192.168.0.42:9999 Error: TCP Socket Closed. segment:0 hadError:false
                  hs100.0	2020-05-05 20:04:43.076	info	(24753) Terminated (NO_ERROR): Without reason
                  hs100.0	2020-05-05 20:04:43.075	info	(24753) terminating
                  hs100.0	2020-05-05 20:04:43.023	error	at TCP.<anonymous> (net.js:672:12)
                  hs100.0	2020-05-05 20:04:43.023	error	at Socket.emit (events.js:310:20)
                  hs100.0	2020-05-05 20:04:43.023	error	at Object.onceWrapper (events.js:417:26)
                  hs100.0	2020-05-05 20:04:43.023	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.hs100/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                  hs100.0	2020-05-05 20:04:43.023	error	(24753) Error: TCP Socket Closed. segment:0 hadError:false
                  hs100.0	2020-05-05 20:04:43.019	error	(24753) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                  • WinniW Offline
                    WinniW Offline
                    Winni
                    schrieb am zuletzt editiert von Winni
                    #81
                    Sorry, falscher Thread
                      skokarl
                      #82
                      seit 26 Stunden sauber !!!!
                      scheint als wäre ich raus ...😀
                      @arteck sieht gut aus.
                        Berchemer
                        #83
                        Nachdem es bei mir über 12 Stunden ohne Fehler lief, habe ich auch mal sicherheitshalber den Adapter gestoppt, den Objekte-Ordner gelöscht und neu gestartet. Mal sehen, wie es jetzt weitergeht :-)
                        • B Berchemer
                          skokarl
                          #84
                          gute Idee, mach ich auch noch
                            Berchemer
                            #85
                            Btw. Nachdem ich wegen des Neuanlegens des Objektebaums die Protokollierung durch den SQL-Adapter wieder eingeschaltet habe, wollte ich die Monatscounter als Zähler im sql-Reiter definieren. Der sql-Adapter meckerte daraufhin, dass man string-Datenpunkte nicht als Counter definieren könne und ich stellte fest, dass die Datenpunkte mit Stromstärke, Leistung, Gesamtmenge usw. nicht als number, sondern als string definiert sind.
                            Ich gehe nicht davon aus, dass das das Problem ist, dem wir hier seit Tagen hinterherjagen. Aber sollte man die bei Neuanlage nicht als number statt string definieren? In dem Zusammenhang könnt eman ggf. auch die Unit der Datenpunkte bei Neuanlage mit angeben. Könnte u.a. der automatischen Erkennung durch den Adapter SourceAnalytics helfen, wenn bei den Werte auch Watt oder kwh oder V usw. als Unit stehen würde. Ist sicherlich nichts Dringliches, nur eine Verschönerung :-)
                            Wer weiß, ob es auch damit zusammenhängen könnte aber ganz nebenbei habe ich auch mal die Firmware der beiden Steckdosen angehoben von
                            1.5.4 Build 180815 Rel 121440
                            auf
                            1.5.6 Build 191125 Rel 083657
                            Vielleicht hilft es ja.
                            Jetzt lasse ich aber den Adapter und die Steckdosen mal wieder in Ruhe damit sie ordentlich weiter laufen und sperre den Steckdosen nach dem Update wieder den Internetzugang :-)
                              Berchemer
                              #86
                              Lief so schön durch... Über 12 Stunden... Und dann 😖
                              2020-05-07 09:20:18.669 - debug: hs100.0 (5004) HS Plug 192.1.1.132
                              2020-05-07 09:20:18.671 - debug: hs100.0 (5004) HS Plug 192.1.1.131
                              2020-05-07 09:20:18.869 - debug: hs100.0 (5004) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 09:20:18
                              2020-05-07 09:20:18.875 - debug: hs100.0 (5004) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 09:20:18
                              2020-05-07 09:20:20.037 - debug: hs100.0 (5004) Refresh Data HS110 192.1.1.131
                              2020-05-07 09:20:20.045 - debug: hs100.0 (5004) Refresh Data HS110 192.1.1.132
                              2020-05-07 09:20:20.902 - debug: hs100.0 (5004) Month value HS110(EU) 192.1.1.132
                              2020-05-07 09:20:20.909 - debug: hs100.0 (5004) Month value HS110(EU) 192.1.1.131
                              2020-05-07 09:20:21.338 - debug: hs100.0 (5004) Day value HS110(EU) 0.166 192.1.1.132
                              2020-05-07 09:20:21.352 - debug: hs100.0 (5004) Day value HS110(EU) 0.169 192.1.1.131
                              2020-05-07 09:22:18.673 - debug: hs100.0 (5004) HS Plug 192.1.1.132
                              2020-05-07 09:22:18.675 - debug: hs100.0 (5004) HS Plug 192.1.1.131
                              2020-05-07 09:22:18.833 - debug: hs100.0 (5004) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 09:22:18
                              2020-05-07 09:22:19.995 - debug: hs100.0 (5004) Refresh Data HS110 192.1.1.132
                              2020-05-07 09:22:20.867 - debug: hs100.0 (5004) Month value HS110(EU) 192.1.1.132
                              2020-05-07 09:22:21.302 - debug: hs100.0 (5004) Day value HS110(EU) 0.166 192.1.1.132
                              2020-05-07 09:22:21.604 - debug: hs100.0 (5004) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 09:22:21
                              2020-05-07 09:22:27.668 - error: hs100.0 (5004) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                              2020-05-07 09:22:27.669 - error: hs100.0 (5004) Error: TCP Socket Closed. segment:0 hadError:false
                              2020-05-07 09:22:27.672 - info: hs100.0 (5004) terminating
                              2020-05-07 09:22:27.672 - info: hs100.0 (5004) Terminated (NO_ERROR): Without reason
                              2020-05-07 09:22:27.747 - error: hs100.0 (5004) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                              2020-05-07 09:22:27.748 - error: hs100.0 (5004) Error: TCP Socket Closed. segment:0 hadError:false
                              2020-05-07 09:22:28.034 - debug: hs100.0 (5004) Day value HS110(EU) 0.169 192.1.1.131
                              2020-05-07 09:22:28.188 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
                              2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                              2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                              2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
                              2020-05-07 09:22:28.190 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
                              2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Socket Closed. segment:0 hadError:false
                              2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                              2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
                              2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
                              2020-05-07 09:22:28.191 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
                              2020-05-07 09:22:28.191 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                              2020-05-07 09:22:28.191 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                              2020-05-07 09:22:58.208 - info: host.SERVER instance system.adapter.hs100.0 started with pid 7002
                              2020-05-07 09:22:58.527 - debug: hs100.0 (7002) Redis Objects: Use Redis connection: 0.0.0.0:9001
                              2020-05-07 09:22:58.538 - debug: hs100.0 (7002) Objects client ready ... initialize now
                              2020-05-07 09:22:58.539 - debug: hs100.0 (7002) Objects create System PubSub Client
                              2020-05-07 09:22:58.539 - debug: hs100.0 (7002) Objects create User PubSub Client
                              2020-05-07 09:22:58.540 - debug: hs100.0 (7002) Objects client initialize lua scripts
                              2020-05-07 09:22:58.548 - debug: hs100.0 (7002) Objects connected to redis: 0.0.0.0:9001
                              2020-05-07 09:22:58.549 - debug: hs100.0 (7002) objectDB connected
                              2020-05-07 09:22:58.550 - debug: hs100.0 (7002) Redis States: Use Redis connection: 0.0.0.0:9000
                              2020-05-07 09:22:58.555 - debug: hs100.0 (7002) States create User PubSub Client
                              2020-05-07 09:22:58.555 - debug: hs100.0 (7002) States create System PubSub Client
                              2020-05-07 09:22:58.563 - debug: hs100.0 (7002) States connected to redis: 0.0.0.0:9000
                              2020-05-07 09:22:58.564 - debug: hs100.0 (7002) statesDB connected
                              2020-05-07 09:22:58.786 - info: hs100.0 (7002) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                              2020-05-07 09:22:58.794 - debug: hs100.0 (7002) Host = SERVER
                              2020-05-07 09:22:58.815 - debug: hs100.0 (7002) undefined generated 192.1.1.131
                              2020-05-07 09:22:58.817 - debug: hs100.0 (7002) undefined generated 192.1.1.132
                              2020-05-07 09:22:59.100 - debug: hs100.0 (7002) HS Plug 192.1.1.132
                              2020-05-07 09:22:59.101 - debug: hs100.0 (7002) HS Plug 192.1.1.131
                              2020-05-07 09:23:00.692 - debug: hs100.0 (7002) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 09:23:00
                              2020-05-07 09:23:01.128 - debug: hs100.0 (7002) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 09:23:01
                              2020-05-07 09:23:02.290 - debug: hs100.0 (7002) Refresh Data HS110 192.1.1.132
                              2020-05-07 09:23:03.162 - debug: hs100.0 (7002) Month value HS110(EU) 192.1.1.132
                              2020-05-07 09:23:03.173 - debug: hs100.0 (7002) Refresh Data HS110 192.1.1.131
                              2020-05-07 09:23:03.599 - debug: hs100.0 (7002) Day value HS110(EU) 0.167 192.1.1.132
                              2020-05-07 09:23:04.480 - debug: hs100.0 (7002) Month value HS110(EU) 192.1.1.131
                              2020-05-07 09:23:04.916 - debug: hs100.0 (7002) Day value HS110(EU) 0.169 192.1.1.131
                                Berchemer
                                #87
                                Und erneut:
                                2020-05-07 15:43:41.066 - debug: hs100.0 (13537) HS Plug 192.1.1.132
                                2020-05-07 15:43:41.066 - debug: hs100.0 (13537) HS Plug 192.1.1.131
                                2020-05-07 15:43:41.237 - debug: hs100.0 (13537) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:43:41
                                2020-05-07 15:43:41.299 - debug: hs100.0 (13537) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:43:41
                                2020-05-07 15:43:42.399 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.132
                                2020-05-07 15:43:42.461 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.131
                                2020-05-07 15:43:43.271 - debug: hs100.0 (13537) Month value HS110(EU) 192.1.1.132
                                2020-05-07 15:43:43.333 - debug: hs100.0 (13537) Month value HS110(EU) 192.1.1.131
                                2020-05-07 15:43:43.707 - debug: hs100.0 (13537) Day value HS110(EU) 0.332 192.1.1.132
                                2020-05-07 15:43:43.768 - debug: hs100.0 (13537) Day value HS110(EU) 0.228 192.1.1.131
                                2020-05-07 15:45:41.068 - debug: hs100.0 (13537) HS Plug 192.1.1.132
                                2020-05-07 15:45:41.070 - debug: hs100.0 (13537) HS Plug 192.1.1.131
                                2020-05-07 15:45:41.224 - debug: hs100.0 (13537) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:45:41
                                2020-05-07 15:45:41.287 - debug: hs100.0 (13537) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:45:41
                                2020-05-07 15:45:42.345 - error: hs100.0 (13537) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                2020-05-07 15:45:42.346 - error: hs100.0 (13537) Error: TCP Socket Closed. segment:0 hadError:false
                                2020-05-07 15:45:42.348 - info: hs100.0 (13537) terminating
                                2020-05-07 15:45:42.349 - info: hs100.0 (13537) Terminated (NO_ERROR): Without reason
                                2020-05-07 15:45:42.450 - debug: hs100.0 (13537) Refresh Data HS110 192.1.1.131
                                2020-05-07 15:45:42.870 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                                2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
                                2020-05-07 15:45:42.871 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
                                2020-05-07 15:45:42.871 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                2020-05-07 15:45:42.871 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                2020-05-07 15:46:12.886 - info: host.SERVER instance system.adapter.hs100.0 started with pid 5874
                                2020-05-07 15:46:13.079 - debug: hs100.0 (5874) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                2020-05-07 15:46:13.090 - debug: hs100.0 (5874) Objects client ready ... initialize now
                                2020-05-07 15:46:13.091 - debug: hs100.0 (5874) Objects create System PubSub Client
                                2020-05-07 15:46:13.092 - debug: hs100.0 (5874) Objects create User PubSub Client
                                2020-05-07 15:46:13.092 - debug: hs100.0 (5874) Objects client initialize lua scripts
                                2020-05-07 15:46:13.101 - debug: hs100.0 (5874) Objects connected to redis: 0.0.0.0:9001
                                2020-05-07 15:46:13.102 - debug: hs100.0 (5874) objectDB connected
                                2020-05-07 15:46:13.103 - debug: hs100.0 (5874) Redis States: Use Redis connection: 0.0.0.0:9000
                                2020-05-07 15:46:13.109 - debug: hs100.0 (5874) States create User PubSub Client
                                2020-05-07 15:46:13.110 - debug: hs100.0 (5874) States create System PubSub Client
                                2020-05-07 15:46:13.117 - debug: hs100.0 (5874) States connected to redis: 0.0.0.0:9000
                                2020-05-07 15:46:13.118 - debug: hs100.0 (5874) statesDB connected
                                2020-05-07 15:46:13.294 - info: hs100.0 (5874) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                2020-05-07 15:46:13.305 - debug: hs100.0 (5874) Host = SERVER
                                2020-05-07 15:46:13.333 - debug: hs100.0 (5874) undefined generated 192.1.1.131
                                2020-05-07 15:46:13.375 - debug: hs100.0 (5874) undefined generated 192.1.1.132
                                2020-05-07 15:46:13.537 - debug: hs100.0 (5874) HS Plug 192.1.1.132
                                2020-05-07 15:46:13.539 - debug: hs100.0 (5874) HS Plug 192.1.1.131
                                2020-05-07 15:46:13.873 - debug: hs100.0 (5874) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.7 15:46:13
                                2020-05-07 15:46:15.424 - debug: hs100.0 (5874) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.7 15:46:15
                                2020-05-07 15:46:16.588 - debug: hs100.0 (5874) Refresh Data HS110 192.1.1.131
                                2020-05-07 15:46:17.458 - debug: hs100.0 (5874) Month value HS110(EU) 192.1.1.131
                                2020-05-07 15:46:17.824 - debug: hs100.0 (5874) Refresh Data HS110 192.1.1.132
                                2020-05-07 15:46:17.894 - debug: hs100.0 (5874) Day value HS110(EU) 0.228 192.1.1.131
                                2020-05-07 15:46:19.132 - debug: hs100.0 (5874) Month value HS110(EU) 192.1.1.132
                                2020-05-07 15:46:20.438 - debug: hs100.0 (5874) Day value HS110(EU) 0.333 192.1.1.132
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #88
                                  version 1.1.5 ist draussen
                                  wenns damit nicht besser ist muss ich ein issue erstellen .. bei tplink-smarthome-api
                                  das ist nicht meine bibliothek.. und hab keine einfluss druff
                                  B 2 Antworten Letzte Antwort
                                    Berchemer
                                    #89
                                    Und wieder fast 24 Stunden später 😬
                                    2020-05-08 15:38:22.814 - debug: hs100.0 (5127) HS Plug 192.1.1.132
                                    2020-05-08 15:38:22.814 - debug: hs100.0 (5127) HS Plug 192.1.1.131
                                    2020-05-08 15:38:23.087 - debug: hs100.0 (5127) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.8 15:38:23
                                    2020-05-08 15:38:23.111 - debug: hs100.0 (5127) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.8 15:38:23
                                    2020-05-08 15:38:24.273 - debug: hs100.0 (5127) Refresh Data HS110 192.1.1.131
                                    2020-05-08 15:38:25.146 - debug: hs100.0 (5127) Month value HS110(EU) 192.1.1.131
                                    2020-05-08 15:38:25.581 - debug: hs100.0 (5127) Day value HS110(EU) 0.262 192.1.1.131
                                    2020-05-08 15:38:29.058 - error: hs100.0 (5127) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.058 - error: hs100.0 (5127) Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.059 - debug: hs100.0 (5127) Send error setDevState : Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.061 - info: hs100.0 (5127) terminating
                                    2020-05-08 15:38:29.061 - info: hs100.0 (5127) Terminated (NO_ERROR): Without reason
                                    2020-05-08 15:38:29.188 - error: hs100.0 (5127) uncaught exception: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.188 - error: hs100.0 (5127) Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.475 - debug: hs100.0 (5127) Day value HS110(EU) 0.333 192.1.1.132
                                    2020-05-08 15:38:29.576 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Object.onceWrapper (events.js:417:26)
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at Socket.emit (events.js:310:20)
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[0]: at TCP. (net.js:672:12)
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
                                    2020-05-08 15:38:29.577 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
                                    2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
                                    2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                    2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                    2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
                                    2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at Socket.emit (events.js:310:20)
                                    2020-05-08 15:38:29.578 - error: host.SERVER Caught by controller[2]: at TCP. (net.js:672:12)
                                    2020-05-08 15:38:29.578 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                    2020-05-08 15:38:29.578 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                    2020-05-08 15:38:59.591 - info: host.SERVER instance system.adapter.hs100.0 started with pid 11771
                                    2020-05-08 15:38:59.780 - debug: hs100.0 (11771) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                    2020-05-08 15:38:59.790 - debug: hs100.0 (11771) Objects client ready ... initialize now
                                    2020-05-08 15:38:59.791 - debug: hs100.0 (11771) Objects create System PubSub Client
                                    2020-05-08 15:38:59.791 - debug: hs100.0 (11771) Objects create User PubSub Client
                                    2020-05-08 15:38:59.792 - debug: hs100.0 (11771) Objects client initialize lua scripts
                                    2020-05-08 15:38:59.799 - debug: hs100.0 (11771) Objects connected to redis: 0.0.0.0:9001
                                    2020-05-08 15:38:59.800 - debug: hs100.0 (11771) objectDB connected
                                    2020-05-08 15:38:59.801 - debug: hs100.0 (11771) Redis States: Use Redis connection: 0.0.0.0:9000
                                    2020-05-08 15:38:59.806 - debug: hs100.0 (11771) States create User PubSub Client
                                    2020-05-08 15:38:59.807 - debug: hs100.0 (11771) States create System PubSub Client
                                    2020-05-08 15:38:59.813 - debug: hs100.0 (11771) States connected to redis: 0.0.0.0:9000
                                    2020-05-08 15:38:59.814 - debug: hs100.0 (11771) statesDB connected
                                    2020-05-08 15:38:59.984 - info: hs100.0 (11771) starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                    2020-05-08 15:38:59.992 - debug: hs100.0 (11771) Host = SERVER
                                    2020-05-08 15:39:00.036 - debug: hs100.0 (11771) undefined generated 192.1.1.131
                                    2020-05-08 15:39:00.078 - debug: hs100.0 (11771) undefined generated 192.1.1.132
                                    2020-05-08 15:39:00.316 - debug: hs100.0 (11771) HS Plug 192.1.1.132
                                    2020-05-08 15:39:00.317 - debug: hs100.0 (11771) HS Plug 192.1.1.131
                                    2020-05-08 15:39:02.320 - debug: hs100.0 (11771) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.8 15:39:02
                                    2020-05-08 15:39:02.324 - debug: hs100.0 (11771) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.8 15:39:02
                                    2020-05-08 15:39:03.482 - debug: hs100.0 (11771) Refresh Data HS110 192.1.1.132
                                    2020-05-08 15:39:03.487 - debug: hs100.0 (11771) Refresh Data HS110 192.1.1.131
                                    2020-05-08 15:39:04.353 - debug: hs100.0 (11771) Month value HS110(EU) 192.1.1.132
                                    2020-05-08 15:39:04.358 - debug: hs100.0 (11771) Month value HS110(EU) 192.1.1.131
                                    2020-05-08 15:39:04.791 - debug: hs100.0 (11771) Day value HS110(EU) 0.333 192.1.1.132
                                    2020-05-08 15:39:04.794 - debug: hs100.0 (11771) Day value HS110(EU) 0.262 192.1.1.131
                                    2020-05-08 15:40:00.015 - info: host.SERVER instance system.adapter.dwd.0 started with pid 12366
                                    2020-05-08 15:40:00.685 - info: dwd.0 (12366) starting. Version 2.4.8 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
                                    2020-05-08 15:40:01.386 - info: dwd.0 (12366) Terminated (NO_ERROR): Without reason
                                    2020-05-08 15:40:01.893 - info: host.SERVER instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                                    • arteckA arteck
                                      Berchemer
                                      #90
                                      Dann installiere ich erneut :-)
                                      Btw. Der Beitrag von eben war noch mit der alten Version!
                                      • arteckA arteck
                                        Berchemer
                                        #91
                                        Sorry :-(
                                        Etwas mehr als 21 Stunden hat der Adapter durchgehalten :-)
                                        Nach "normaler" Installation (Update) des Adapters über den Infotab habe ich sicherheitshalber trotzdem noch einmal upload angeklickt. System danach neu gestartet. Und etwas mehr als 21 Stunden später:
                                        2020-05-09 14:27:02.185 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                        2020-05-09 14:27:02.186 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                        2020-05-09 14:27:02.400 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:27:02
                                        2020-05-09 14:27:03.562 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                        2020-05-09 14:27:04.434 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                        2020-05-09 14:27:04.870 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                        2020-05-09 14:27:05.512 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:27:05
                                        2020-05-09 14:27:06.675 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.131
                                        2020-05-09 14:27:07.547 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.131
                                        2020-05-09 14:27:07.983 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.218 IP : 192.1.1.131
                                        2020-05-09 14:29:02.188 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                        2020-05-09 14:29:02.189 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                        2020-05-09 14:29:02.392 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:29:02
                                        2020-05-09 14:29:02.395 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:29:02
                                        2020-05-09 14:29:03.554 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                        2020-05-09 14:29:03.557 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.131
                                        2020-05-09 14:29:04.429 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                        2020-05-09 14:29:04.439 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.131
                                        2020-05-09 14:29:04.861 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                        2020-05-09 14:29:04.865 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.218 IP : 192.1.1.131
                                        2020-05-09 14:31:02.191 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                        2020-05-09 14:31:02.193 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                        2020-05-09 14:31:03.665 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:31:03
                                        2020-05-09 14:31:04.828 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                        2020-05-09 14:31:05.699 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                        2020-05-09 14:31:06.135 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                        2020-05-09 14:31:12.193 - debug: hs100.0 (12363) IP not found : 192.1.1.131
                                        2020-05-09 14:33:02.194 - debug: hs100.0 (12363) HS Plug 192.1.1.132
                                        2020-05-09 14:33:02.194 - debug: hs100.0 (12363) HS Plug 192.1.1.131
                                        2020-05-09 14:33:02.462 - debug: hs100.0 (12363) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:33:02
                                        2020-05-09 14:33:02.754 - debug: hs100.0 (12363) Refresh Data HS110 192.1.1.132
                                        2020-05-09 14:33:03.043 - debug: hs100.0 (12363) Month value Model : HS110(EU) IP : 192.1.1.132
                                        2020-05-09 14:33:03.332 - debug: hs100.0 (12363) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                        2020-05-09 14:33:07.852 - debug: hs100.0 (12363) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:33:07
                                        2020-05-09 14:33:17.854 - error: hs100.0 (12363) uncaught exception: TCP Timeout
                                        2020-05-09 14:33:17.854 - error: hs100.0 (12363) Error: TCP Timeout
                                        2020-05-09 14:33:17.855 - debug: hs100.0 (12363) Error getDevice192.1.1.131
                                        2020-05-09 14:33:17.857 - info: hs100.0 (12363) terminating
                                        2020-05-09 14:33:17.857 - info: hs100.0 (12363) Terminated (NO_ERROR): Without reason
                                        2020-05-09 14:33:18.393 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.131:9999 Error: TCP Timeout
                                        2020-05-09 14:33:18.396 - error: host.SERVER Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                        2020-05-09 14:33:18.396 - error: host.SERVER Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
                                        2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[1]: at processTimers (internal/timers.js:492:7)
                                        2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.131:9999 Error: TCP Timeout
                                        2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                        2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
                                        2020-05-09 14:33:18.397 - error: host.SERVER Caught by controller[2]: at processTimers (internal/timers.js:492:7)
                                        2020-05-09 14:33:18.397 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                                        2020-05-09 14:33:18.398 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
                                        2020-05-09 14:33:48.516 - info: host.SERVER instance system.adapter.hs100.0 started with pid 28253
                                        2020-05-09 14:33:48.766 - debug: hs100.0 (28253) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                        2020-05-09 14:33:48.778 - debug: hs100.0 (28253) Objects client ready ... initialize now
                                        2020-05-09 14:33:48.778 - debug: hs100.0 (28253) Objects create System PubSub Client
                                        2020-05-09 14:33:48.779 - debug: hs100.0 (28253) Objects create User PubSub Client
                                        2020-05-09 14:33:48.779 - debug: hs100.0 (28253) Objects client initialize lua scripts
                                        2020-05-09 14:33:48.787 - debug: hs100.0 (28253) Objects connected to redis: 0.0.0.0:9001
                                        2020-05-09 14:33:48.790 - debug: hs100.0 (28253) objectDB connected
                                        2020-05-09 14:33:48.791 - debug: hs100.0 (28253) Redis States: Use Redis connection: 0.0.0.0:9000
                                        2020-05-09 14:33:48.796 - debug: hs100.0 (28253) States create User PubSub Client
                                        2020-05-09 14:33:48.796 - debug: hs100.0 (28253) States create System PubSub Client
                                        2020-05-09 14:33:48.803 - debug: hs100.0 (28253) States connected to redis: 0.0.0.0:9000
                                        2020-05-09 14:33:48.803 - debug: hs100.0 (28253) statesDB connected
                                        2020-05-09 14:33:48.976 - info: hs100.0 (28253) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
                                        2020-05-09 14:33:48.985 - debug: hs100.0 (28253) Host = SERVER
                                        2020-05-09 14:33:49.007 - debug: hs100.0 (28253) create state
                                        2020-05-09 14:33:49.008 - debug: hs100.0 (28253) undefined generated 192.1.1.131
                                        2020-05-09 14:33:49.050 - debug: hs100.0 (28253) create state
                                        2020-05-09 14:33:49.050 - debug: hs100.0 (28253) undefined generated 192.1.1.132
                                        2020-05-09 14:33:49.352 - debug: hs100.0 (28253) HS Plug 192.1.1.132
                                        2020-05-09 14:33:49.354 - debug: hs100.0 (28253) HS Plug 192.1.1.131
                                        2020-05-09 14:33:51.380 - debug: hs100.0 (28253) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.9 14:33:51
                                        2020-05-09 14:33:52.543 - debug: hs100.0 (28253) Refresh Data HS110 192.1.1.132
                                        2020-05-09 14:33:53.449 - debug: hs100.0 (28253) Month value Model : HS110(EU) IP : 192.1.1.132
                                        2020-05-09 14:33:53.884 - debug: hs100.0 (28253) Day value for Model : HS110(EU) Energy : 0.243 IP : 192.1.1.132
                                        2020-05-09 14:33:56.679 - debug: hs100.0 (28253) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.9 14:33:56
                                        2020-05-09 14:33:57.841 - debug: hs100.0 (28253) Refresh Data HS110 192.1.1.131
                                        2020-05-09 14:33:58.713 - debug: hs100.0 (28253) Month value Model : HS110(EU) IP : 192.1.1.131
                                        2020-05-09 14:33:59.153 - debug: hs100.0 (28253) Day value for Model : HS110(EU) Energy : 0.219 IP : 192.1.1.131
                                        • B Berchemer
                                          Sorry :-(
                                          skokarl
                                          #92
                                          @Berchemer @arteck
                                          Sag mal.....kann es sein, dass da irgendwas volläuft ?
                                          Kann doch nicht sein das es einen Tag funktioniert und dann plötzlich nicht mehr ?
                                          nur so eine Idee ....
                                          B arteckA 2 Antworten Letzte Antwort
