  4. [Adapter] Shelly Adapter mit MQTT
    6.5k
shellymqtt
213 Beiträge 43 Kommentatoren 67.2k Aufrufe 27 Beobachtet
    maxpd
    #93
    mein Shelly Adapter (3.1.6) startet ständig neu. Ich habe 3 Shelly Devices im Einsatz.
    shelly.0	2020-04-12 06:36:08.655	info	(4720) Shelly device 192.168.178.40 (shelly1 / shelly1-93F1CA / SHSW-1#93F1CA#1) with CoAP connected!
    shelly.0	2020-04-12 06:36:02.254	info	(4720) Listening for Shelly packets in the network
    shelly.0	2020-04-12 06:36:02.173	info	(4720) Starting Shelly adapter in CoAP modus.
    shelly.0	2020-04-12 06:36:02.121	info	(4720) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.19.0
    shelly.0	2020-04-12 06:35:30.183	error	(4369) Error handling Shelly data: Error: No reply in 247s
    shelly.0	2020-04-12 06:31:31.281	info	(4369) Shelly device 192.168.178.112 (shellyswitch25 / shellyswitch25-740842 / SHSW-25#740842#1) with CoAP connected!
    shelly.0	2020-04-12 06:31:22.698	info	(4369) Shelly device 192.168.178.40 (shelly1 / shelly1-93F1CA / SHSW-1#93F1CA#1) with CoAP connected!
    shelly.0	2020-04-12 06:31:17.451	info	(4369) Listening for Shelly packets in the network
    shelly.0	2020-04-12 06:31:17.372	info	(4369) Starting Shelly adapter in CoAP modus.
    shelly.0	2020-04-12 06:31:17.321	info	(4369) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.19.0
    shelly.0	2020-04-12 06:30:45.162	error	(3991) Error handling Shelly data: Error: No reply in 247s
    shelly.0	2020-04-12 06:26:51.526	info	(3991) Shelly device 192.168.178.40 (shelly1 / shelly1-93F1CA / SHSW-1#93F1CA#1) with CoAP connected!
    shelly.0	2020-04-12 06:26:45.896	info	(3991) Shelly device 192.168.178.112 (shellyswitch25 / shellyswitch25-740842 / SHSW-25#740842#1) with CoAP connected!
    shelly.0	2020-04-12 06:26:38.111	info	(3991) Listening for Shelly packets in the network
    shelly.0	2020-04-12 06:26:38.028	info	(3991) Starting Shelly adapter in CoAP modus.
    shelly.0	2020-04-12 06:26:37.960	info	(3991) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.19.0
    shelly.0	2020-04-12 06:26:32.701	info	(3967) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    shelly.0	2020-04-12 06:26:32.700	info	(3967) terminating
    shelly.0	2020-04-12 06:26:32.699	info	(3967) Closing Adapter
    shelly.0	2020-04-12 06:26:32.697	info	(3967) Got terminate signal TERMINATE_YOURSELF
    shelly.0	2020-04-12 06:26:32.523	info	(3967) Listening for Shelly packets in the network
    shelly.0	2020-04-12 06:26:32.446	info	(3967) Starting Shelly adapter in CoAP modus.
    shelly.0	2020-04-12 06:26:32.391	info	(3967) starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.19.0
    maxpd
    StuebiS 1 Antwort Letzte Antwort
    • M maxpd
      StuebiS Offline
      StuebiS Offline
      Stuebi
      #94
      @maxpd , siehe hier https://forum.iobroker.net/topic/26110/test-adapter-shelly-v3-1-x/67
      Eine Lösung gibt es aber nicht
      ioBroker auf Synology DS216+II im Docker Container
      • StuebiS Stuebi
        maxpd
        #95
        @Stuebi danke dir.
        Bis zu welcher Version lief es denn, dann downgrade ich dort hin.
        maxpd
        • M maxpd
          @Stuebi danke dir.
          StuebiS Offline
          StuebiS Offline
          Stuebi
          #96
          @maxpd , da hilft kein downgrade. Meistens verschwindet der Fehler irgendwann wieder.
          • StuebiS Stuebi
            maxpd
            #97
            @Stuebi Ok, leider reagieren die Aktoren oft nicht. Das heißt ich muss von COAP zu MQTT wechseln.
            maxpd
            • FoodFighterF FoodFighter
              ich muss jetzt mal nachfragen, weil mir einiges nicht ganz klar ist.
              Zum Setup: ich nutze iobroker in einem Docker-Container (Bridge-Mode) , daher kommt mir die MQTT-Einstellung des Adapters sehr gelegen.
              Weiterhin nutze ich einen Moquitto MQTT Broker in einem weiterem Container auf Port 1883 (Standart). Über diesen laufen auch diverse andere MQTT-Geräte.
              Wenn ich nun alles richtig verstehe, macht der Shelly-Adapter einen eigenen MQTT-Server auf, sobald man MQTT aktiviert (default auf Port 1882).
              Es ist also nicht möglich die Shellies alle an einen bestehenden Broker senden zu lassen (in meinem falle Mosquitto) und gleichzeitig den Shelly-Adapter mit der MQTT Funktion zu nutzen - sehe ich das richtig?
              Ich möchte die Shellys weiterhin an Mosquitto senden lassen, da diese Daten u.U. noch von anderen Containern außer ioBroker verwendet werden sollen.
              Wenn ich dem Shelly-Adapter nun einfach Port 1883 zuweise und ihm das gleichen MQTT-User+Pwd zuweise, kommen keine Ergebnisse an. (Vermutlich weil der Port 1883 schon dem Mosquitto-Container zugewiesen ist).
              Ist es denn nicht möglich, dass sich dieser Shelly-Adapter die Daten einfach aus dem mqtt-client-Adapter raus zieht, welcher die Daten ja erfolgreich beim MQTT-Broker abholt? (Falls nein, wieso nicht?)
              [Edit]
              Bzw. wäre es machbar die Einstellungen derart zu erweitern, dass man den Shelly-Adapter zwischen MQTT-Server und Client umschalten könnte, für diejenigen, die den mqtt-client ohnehin schon für andere Geräte nutzen?
              [/Edit]
              COAP fällt in meinem Falle flach, wegen der Bridge-Einstellung, die ich so auch gerne beibehalten würde.
              Den Shelly-Adapter würde ich jedoch gerne zusätzlich zum bestehenden Mosquitto nutzen, da dieser Adapter doch einige Funktionen bietet, die das Arbeiten mit den Shellys in iobroker deutlich vereinfachen.
              [Edit]
              Was mir auch noch unklar scheint -> wenn man die Shellys per MQTT auf den Shelly-Adapter senden lässt, wird scheinbar die custom-MQTT-Prefix, die man im Shelly hinterlegt, ignoriert - ist das gewollt?
              Für Dumme steht es sogar in der github-repo, dass die Präfix nicht angepackt werden darf...
              Diggewuff
              #98
              @FoodFighter said in [Adapter] Shelly Adapter mit MQTT:
              [Edit]
              [/Edit]
              [Edit]
              Ich würde auch gerne meinen bereits vorhandenen MQTT Broker verwenden. Kann der Adapter sich nicht einfach zu diesem subscriben?
              E 1 Antwort Letzte Antwort
              • D Diggewuff
                [Edit]
                [/Edit]
                [Edit]
                e-s
                #99
                @Diggewuff
                Du kannst doch direkt alles an einen eigenen mqtt schicken und den Adapter weglassen.
                  Diggewuff
                  #100
                  Ich möchte ungern alle topics für meine Shellies manuell konfigurieren. Das macht der Shelly Adapter ja super. Und zusätzlich finde ich klasse auch http für Datenpunkte zu nutzen die über MQTT nicht zur Verfügung stehen.
                  Das einzige was ich schade finde ist, dass der Adapter die MQTT Schnittstelle der Shellies komplett für sich alleine beansprucht, da der dedizierte eigene Broker verwendet werden muss auf, den sich ausschließlich Shelly Geräte verbinden können, so dass eine Zentralisierung der MQTT Vernetzung nicht mer möglich ist. Es seihe denn man verwendet ausschließlich Shelly Devices und nur IOBroker.
                  G StuebiS 2 Antworten Letzte Antwort
                  • D Diggewuff
                    Gwenselah
                    #101
                    @Diggewuff
                    Mein Shelly-MQTT läuft über einen anderen Port, als z.B. der Sonoff
                    • D Diggewuff
                      StuebiS Offline
                      StuebiS Offline
                      Stuebi
                      #102
                      @Diggewuff sagte in [Adapter] Shelly Adapter mit MQTT:
                      ich kann dir nicht folgen was Du eigentlich vor hast.
                      Ich nutze ioBroker um verschiedenste Anbieter wie z.B. Shelly hersteller- und protokollneutral miteinander zu verbinden.
                      Ich wüsste nicht, warum ich noch einen Broker wie Mosquitto vor ioBroker schalten sollte.
                      • StuebiS Stuebi
                        e-s
                        #103
                        @Stuebi
                        ich glaube er möchte nur einen port am system für mqtt offen haben, dieser soll dann die mqtt daten sammeln und alle weiteren Adapter holen sich von dem die Infos.
                        Ich glaube das ist genau das selbe wie hier
                        N 1 Antwort Letzte Antwort
                        • E e-s
                          @Stuebi
                          N Offline
                          N Offline
                          NetFritz
                          #104
                          @e-s Hallo
                          Ich habe z.Z. Probleme mit meinen Shelly 1-PM der per MQTT an ioBroker sendet.
                          Ich kann die Webseite vom Shelly 1-PM aufrufen und Schalten dort wird mir auch die Schalterstellung und die Leistung angezeigt.
                          In ioBroker Objekten unter den Shelly sind keine Änderungen zu sehen.
                          Habe den Shelly Adapter auf 3.2.8 geupdatet, keine Änderungen.
                          Habe alle Einstellungen im Shelly und ioBroker kontrolliert.
                          Wenn ich den Adapter neu starte bekomme ich in der Log folgende Meldungen:
                          shelly.0	2020-05-14 16:02:10.313	info	(22654) Starting Shelly adapter in MQTT modus. Listening on 0.0.0.0:1882
                          shelly.0	2020-05-14 16:02:10.224	info	(22654) Starting Adapter shelly.0 in version 3.2.8
                          shelly.0	2020-05-14 16:02:10.147	info	(22654) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.18.0
                          Wenn ich dann schalte sind auch in der Log keine Eintragungen vom Shelly
                          und auch keine aus javascript wo ich ein script laufen lasse welche die Leistung in die Laufzeit überwache und es werden Daten in InfluxDB gesandt.
                          Was kann ich machen ?
                          Gruß NetFritz
                          KnallochseK 1 Antwort Letzte Antwort
                          • N NetFritz
                            @e-s Hallo
                            Gruß NetFritz
                            KnallochseK Nicht stören
                            Knallochse
                            #105
                            @NetFritz Unter welcher HW läuft dei Iobroker? Zeig mal die MQTT Einstellungsseite deines Shelly
                            • N Offline
                              N Offline
                              NetFritz
                              #106
                              Hallo
                              Mein ioBroker läuft auf einem Timberwolfserver im Doker Container.
                              Hier meine MQTT Shelly Einstellungen.
                              Gruß NetFritz
                              • N NetFritz
                                Hallo
                                Gruß NetFritz
                                e-s
                                #107
                                @NetFritz
                                Und wie sehen die mqtt Einstellungen im adapter aus?
                                • N Offline
                                  N Offline
                                  NetFritz
                                  #108
                                  Hallo
                                  Hier die MQTT Adapter Einstellungen.
                                  Ich habe mir mal eben die Shelly Objekte angeshen.
                                  Die haben alle den Zeitstempel vom 03. oder 04.05.20 .
                                  Außer der connection Heute am 14.05.20 16:58.
                                  Gruß NetFritz
                                  • N NetFritz
                                    Hallo
                                    Gruß NetFritz
                                    StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    #109
                                    @NetFritz , Du siehst im ioBroker Logfile wenn sich die Shelly Geräte am Adapter anmelden. Das scheint nicht der Fall zu sein.
                                    Wie ist denn die IP-Adresse von Deinem ioBroker im Docker Container? Wie ist der Docker Container konfiguriert? Im Host, Bride oder MCVLAN Modus?
                                    • N Offline
                                      N Offline
                                      NetFritz
                                      #110
                                      Hallo
                                      Der ioBroker Container ist im MCVLAN Modus konfiguriert.
                                      Die IP-Adresse ist 192.168.2.2
                                      Gruß NetFritz
                                      • N NetFritz
                                        Hallo
                                        Gruß NetFritz
                                        e-s
                                        #111
                                        @NetFritz
                                        Habe gerade gesehen, die gleiche Einstellung hat ja schon mal funktioniert.
                                        Was hast du genau alles verändert, also wonach ist dir aufgefallen das es nicht mehr funktioniert.
                                        • N Offline
                                          N Offline
                                          NetFritz
                                          #112
                                          Hallo
                                          Habe den Fehler wohl gefunden.
                                          In der Shelly Webseite steht die IP 192.168.2.3
                                          Auf 192.168.2.2 geändert
                                          Hatte erst letzte Woche in der Fritzbox den Container eine feste IP vergeben.
                                          War garnicht so einfach da das Häcken fehlte.
                                          Erst nachdem ich den Container gestopt habe konnte ich ihn in der Fritz löschen, dann den Container in der Fritz unter Gerät hinzugefügt, dann konnte ich auch das Häckchen setzen.
                                          Danke u. Gruß NetFritz
