  4. Adapter: ebus
    6.6k
Adapter: ebus
ebus adapter
712 Beiträge 73 Kommentatoren 331.3k Aufrufe 60 Beobachtet
  • MassiveAttackM Online
    MassiveAttack
    #205
    ich blicke nicht mehr durch, hier nochmals meine config, habe ich einen fehler?
    EBUSD_OPTS="-f --scanconfig=full -d 192.168.0.65:5000 --latency=100000 --receivetimeout=100000 -p 8888 --configpath=/etc/ebusd/ --accesslevel=* --httpport=8889 -l /var/log/ebusd.log --htmlpath=/var/www/"
    die configs "_templates.csv, broadcast.csv, memory.csv" liegen und /etc/ebusd/
    alle anderen (vaillant) configs liegen unter /etc/ebusd/vaillant
    beim starten bekomme ich immer:
    2020-04-29 11:31:56.766 [update notice] received unknown MS cmd: 1026b5230f05ff0000000000ffff000000000000 / 0101
    2020-04-29 11:31:57.011 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
    2020-04-29 11:31:57.258 [update notice] received unknown MS cmd: 1076b51303040d00 / 02ffff
    2020-04-29 11:31:57.473 [update notice] received unknown BC cmd: 10feb51603013013
    2020-04-29 11:32:03.180 [update notice] received unknown MS cmd: 1008b5110101 / 096d3b3013ff5d0000ff
    2020-04-29 11:32:03.361 [main error] scan config 26: ERR: arbitration lost
    2020-04-29 11:32:03.447 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3a3013ff5d0000ff
    2020-04-29 11:32:03.714 [update notice] received unknown MS cmd: 1076b512030f0001 / 07eb020000801603
    2020-04-29 11:32:04.011 [update notice] received unknown MS cmd: 1026b5230106 / 101f02720173010080760100800080403c
    2020-04-29 11:32:04.304 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
    2020-04-29 11:32:04.574 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
    2020-04-29 11:32:04.841 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
    2020-04-29 11:32:05.128 [update notice] received unknown MS cmd: 1026b5230f05ff0000000000ffff000000000000 / 0101
    2020-04-29 11:32:05.373 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
    2020-04-29 11:32:13.265 [update notice] received unknown MS cmd: 1008b5110101 / 096d3a3013ff5d0000ff
    2020-04-29 11:32:13.532 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3a3013ff5d0000ff
    2020-04-29 11:32:13.799 [update notice] received unknown MS cmd: 1076b512030f0001 / 07eb020000801603
    2020-04-29 11:32:14.096 [update notice] received unknown MS cmd: 1026b5230106 / 102402720173010080760100800080403c
    2020-04-29 11:32:14.388 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
    2020-04-29 11:32:14.654 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
    2020-04-29 11:32:14.921 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
    2020-04-29 11:32:15.101 [main error] scan config 76: ERR: arbitration lost
    ebusctl info:
    ebusctl info
    version: ebusd 3.4.v3.3-51-g57eae05
    access: *
    signal: acquired
    symbol rate: 99
    max symbol rate: 111
    reconnects: 0
    masters: 4
    conditional: 0
    poll: 0
    update: 4
    address 03: master #11
    address 08: slave #11
    address 10: master #2
    address 26: slave
    address 31: master #8, ebusd
    address 36: slave #8, ebusd
    address 71: master #9
    address 76: slave #9
    • M mameier1234
      @MassiveAttack ich würde mal sagen: ja...
      Telnetserver ist wie gesagt natürlich vorraussetzung, dass du per Telnet auf die Kiste zugreifen kannst...
      Deshalb gibt es ja auch den Parameter TelnetPort (8888)
      MassiveAttack
      #206
      @mameier1234
      wenn ich richtig gelesen habe, hast du doch auch den esera ethernet adapter. was hast du für einstellungen am "serial" tab? in der anleitung steht, man soll bei character: "0A" verwenden, bei mir geht das aber nur mit dem standard "00".
      könntest du mir bitte deine einstellungen posten? danke
      • MassiveAttackM MassiveAttack
        @mameier1234
        ähmm, moment. ein "normales" telnet zum ebusd funktioniert ja, "find", "scan" usw liefern auch werte. jedoch ein explizietes "read -c 700 Hc1FlowTemp" liefert: ERR arbitration lost
        also telnet an sich geht mMn, oder sehe ich das falsch?
        mameier1234
        #207
        @MassiveAttack sagte in Adapter: ebus:
        @mameier1234
        ebusctl ist kein telnet !
        Grüße,
        Martin
          @mameier1234
          mameier1234
          #208
          @mameier1234
          Ich habe den Raspberry aufsatz... Mit dem Esera hatte ich immer Probleme... im Fhem Forum gab es mal Sammelbestellungen für das Ding..
          Grüße,
          Martin
          • M mameier1234
            @mameier1234
            mameier1234
            schrieb am zuletzt editiert von mameier1234
            #209
            @mameier1234 so sieht das bei mir aus...
            telnet 192.168.160.160 8888
            Trying 192.168.160.160...
            Connected to raspberry-iobroker.fritz.box.
            Escape character is '^]'.
            info
            version: ebusd 3.3.v3.3
            update check: version 3.4 available
            signal: acquired
            symbol rate: 46
            max symbol rate: 118
            min arbitration micros: 5
            max arbitration micros: 58
            min symbol latency: 4
            max symbol latency: 5
            reconnects: 0
            masters: 3
            conditional: 9
            poll: 0
            update: 10
            address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0703;HW=7401", loaded "vaillant/bai.0010006341.inc" ([PROD='0010006341']), "vaillant/08.bai.csv"
            address 15: slave #2, scanned "MF=Vaillant;ID=UI   ;SW=0324;HW=6201", loaded "vaillant/15.ui.csv"
            address 23: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0306;HW=6301", loaded "vaillant/23.solsy.cc.csv"
            address 25: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0306;HW=6301", loaded "vaillant/25.solsy.hwc.csv"
            address 26: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0306;HW=6301", loaded "vaillant/26.solsy.hc.csv"
            address 50: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0306;HW=6301", loaded "vaillant/50.solsy.mc.csv"
            address ec: slave, scanned "MF=Vaillant;ID=SOLSY;SW=0306;HW=6301", loaded "vaillant/ec.solsy.sc.csv"
            find flame
            bai Flame = off
            bai FlameSensingASIC = no data stored
            read -c bai Flame
            off
            Das muss !! funktionieren ... ohne Telnet auf dem Server geht das nicht.
            Grüße,
            Martin
            TimmerxT MassiveAttackM 2 Antworten Letzte Antwort
            • M mameier1234
              info
              signal: acquired
              symbol rate: 46
              reconnects: 0
              masters: 3
              conditional: 9
              poll: 0
              update: 10
              find flame
              bai Flame = off
              read -c bai Flame
              off
              TimmerxT Offline
              TimmerxT Offline
              Timmerx
              #210
              Hi Leute,
              ich glaube ich bin noch einen Schritt zurück.
              Ich habe nur eine .csv Datei installiert, die hmu.csv
              Wie kann ich hier weitere installieren ? oder Updatet das automitisch?
              update check: revision v3.4 available
              signal: acquired
              symbol rate: 46
              max symbol rate: 226
              min arbitration micros: 721
              max arbitration micros: 2222
              min symbol latency: 0
              max symbol latency: 17
              reconnects: 5
              masters: 5
              conditional: 0
              poll: 0
              update: 9
              address 00: master #1
              address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0307;HW=0403", loaded "vaillant/08.hmu.csv"
              address 15: slave #2, scanned "MF=Vaillant;ID=72000;SW=0118;HW=7703"
              address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0307;HW=0403"
              • TimmerxT Timmerx
                Hi Leute,
                signal: acquired
                symbol rate: 46
                reconnects: 5
                masters: 5
                conditional: 0
                poll: 0
                update: 9
                mameier1234
                #211
                @Timmerx wenn die datenpakete erkannt werden, dann holt er sich die files normalerweise automatisch..
                Grüße,
                Martin
                TimmerxT 1 Antwort Letzte Antwort
                • M mameier1234
                  TimmerxT Offline
                  TimmerxT Offline
                  Timmerx
                  schrieb am zuletzt editiert von Timmerx
                  #212
                  das tut er leider nicht hab auch schonmal neugestartet leider ist immer noch nur die hmu.csv drin
                  das habe ich in der Config stehen
                  EBUSD_OPTS="-c, --configpath=http://ebusd.eu/config/ -d /dev/ttyUSB2 -p 8888  --latency=0 --receivetimeout=100000 -l /var/log/ebusd.log  --scanconfig  --httpport=8891 --htmlpath=/var/ebusd/html"
                  • M mameier1234
                    info
                    signal: acquired
                    symbol rate: 46
                    reconnects: 0
                    masters: 3
                    conditional: 9
                    poll: 0
                    update: 10
                    find flame
                    bai Flame = off
                    read -c bai Flame
                    off
                    MassiveAttack
                    schrieb am zuletzt editiert von MassiveAttack
                    #213
                    @mameier1234
                    das funktioniert auch! dennoch bekomme ich bei einem aufruf eines bestimmten DPs ein timeout!
                    aktuell habe ich wieder das problem, dass keine addresse eine passende vaillant findet, geschweige denn ein csv ladet. schön langsam hau ich den hut drauf...so ein dre...
                      @mameier1234
                      mameier1234
                      #214
                      @MassiveAttack ich hatte früher auch den tcp-adapter... die einstellerei mit dem Potti war auch nicht gerade einfach...
                      Dann habe ich irgenwann die Raspi-Erweiterung aus dem fhem-board geholt.. Die hat sich selbst eingestellt.. Nach ca. einem Jahr, dann plötzlich keine Werte mehr vom Brenner.
                      Das Problem war die Steuerplatine des Brenners.. Heizungsbauer sagte neu... ich habe gegoogelt und festgestellt, dass 2 Kondensatoren im Wert von 40 cent schuld waren. Neue reingelötet und der Bus hat wieder funktioniert..
                      Ganz ehrlich ? Das ist ein Bastelhobby.. Wenn du das nicht willst, dann geh zu deinem Heizungsbauer und hoffe , dass er Dir ne fertige Lösung mit Support geben kann. Meiner konnte das eher nicht, und der ist jedes mal platt , wenn er sieht, was ich hier bei mir umgesetzt habe...
                      Fehlschläge gehören dazu, und manchmal muss man die Sache auch einfach mal ruhen lassen.. z.B. das Wasserzähler Projekt.. ich bin seit nem 1/2 Jahr drann... jetzt ist der Groschen gefallen und ich bin happy... So was kann man nicht kaufen ! Und ich hatte sehr viele Fehlversuche.. Aber es hat sich gelohnt...
                      Nochmal zu ebusd... im Fhem Forum gibt es da einen sehr langen Grundlagen-Thread.. hat wenig mit dem Adapater hier zu tun, aber hilft fürs Verständniss... Die Erfolge kommen in kleinen Schritten, aber sie kommen.
                      Nur Mut !
                      Grüße,
                      Martin
                      • TimmerxT Offline
                        TimmerxT Offline
                        Timmerx
                        #215
                        SO ich glaube ich bin tetwas weiter gekommen
                        ich habe mit Filezilla die neuen .csv Dateien eingefügt jetzt zeigt mir ebusctl info schon mal ein weiteres GErät an ec mit der /vaillant/ec.sol.sc.csv
                        Jetzt würde ich geren noch die .csv für den ID=72000 und die ID=VWZ finden
                        ![alt text](d9b67ae4-2946-42ba-9b4b-f66b57d81670-grafik.png image url)
                          MassiveAttack
                          #216
                          bei meiner ebusctl ausgabe fehlen "min/max arbitration micros" & "min/max symbol latency". kann mir wer sagen warum? und ist das wichtig?
                          aktuell stehe ich nachwievor vor dem problem, dass ich zwar ein paar sachen sehe, diese jedoch NICHT automatisch aktualisiert werden (außer broadcast). wie kann ich das triggern? außer die DPs manuell abfragen, da das nicht geht und in ein timeout läuft...
                          • HiltexH Hiltex
                            Den Brenner und den Regler (VRC700). An die Solardaten komme ich irgendwie nicht ran, obwohl mir der Regler auch einen Ertrag anzeigt.
                            Jui
                            #217
                            @Hiltex Dein Eintrag ist ja schon etwas älter, dennoch die Frage, hast Du die Solardaten gefunden? Ich habe den ebusd seit einigen Tagen im Einsatz und versuche die interessanten Daten von den unwichtigen zu trennen. Die Daten vom Warmwassertauscher auf dem Dach habe ich nicht gefunden, genauso wie die den Luftfeutigskeitssensor, der im Wandsteuergerät angezeigt wird.
                            HiltexH 1 Antwort Letzte Antwort
                            • J Jui
                              HiltexH Offline
                              HiltexH Offline
                              Hiltex
                              #218
                              @Jui Die Solardaten kommen vom Gerät VMS01. Folgende Datenpunkte sind verfügbar:
                              ASIDetected
                              BufferPumpPower
                              CountryZone
                              CurrentASCStateforASI
                              CurrentASCStateforExternals
                              currenterror
                              CurrentFlow
                              CurrentSystemMode
                              CurrentVPMLoadingMode
                              Date
                              DateAndTimeIsSet
                              errorhistory
                              ExternalHcRequest
                              ExternalHcTempDesired
                              ExternalHwcRequest
                              ExternalHwcTempDesired
                              FlowSensorFrequency
                              ForceStartSolPumpKick
                              InternalHcTempDesired
                              InternalHwcTempDesired
                              MonitorMatlabLast5minSolAverage
                              MonitorMatlabState
                              MonitorOverheatState
                              Ntc1Sensor
                              Ntc2Sensor
                              RequestForExternalDateTimeSetting
                              RunTimeBufferPumpHours
                              RunTimeBufferPumpMinutes
                              RunTimePump1Hours
                              RunTimePump1Minutes
                              SolPumpPower
                              SolPumpRelay
                              Time
                              Variante
                              YieldCurrentDay
                              YieldTotal
                              Es gibt dafür leider keine Konfig-Datei. Die habe ich selbst erstellt und einen Pull Request erstellt, der bisher jedoch noch nicht angenommen wurde. Solange arbeite ich mit lokalen Daten und meiner zusätzlichen Datei, die du hier herunterladen kannst:
                              https://github.com/Standarduser/ebusd-configuration/blob/master/ebusd-2.1.x/de/vaillant/06.vms.csv
                              Meine derzeitige Visualisierung sieht so aus:
                              Ich sehe unter BAI und 700 noch einige sinnvolle Datenpunkte, die man gut visualisieren könnte, aber ich hatte bisher noch keine Muse, mich damit zu beschäftigen. Das wichtigste habe ich, den Rest mache ich vielleicht irgendwann.
                              Blog: indibit.de
                              • HiltexH Hiltex
                                ASIDetected
                                BufferPumpPower
                                CountryZone
                                currenterror
                                CurrentFlow
                                CurrentSystemMode
                                Date
                                DateAndTimeIsSet
                                errorhistory
                                ExternalHcRequest
                                ExternalHwcRequest
                                FlowSensorFrequency
                                MonitorMatlabState
                                Ntc1Sensor
                                Ntc2Sensor
                                RunTimePump1Hours
                                RunTimePump1Minutes
                                SolPumpPower
                                SolPumpRelay
                                Time
                                Variante
                                YieldCurrentDay
                                YieldTotal
                                Jui
                                #219
                                @Hiltex deine VIS sieht ja sehr gut! Da bin ich noch weit entfernt von, ich sammle erst mal die Datenpunkte um dann zu wissen was alles rein kann und soll.
                                Und die Solaranlage finde ich schon gut.
                                Wichtig ist mir auch sowas wie Wasserdruck und Fehlermeldung usw. um Alarme auszulösen, usw usw ... das ist noch oben keine Grenze
                                Okay, also entweder warte ich bis Deine Konfig-Datei übernommen wurde und dann die Daten automatisch kommen oder schreibe mir auch eine eigene Konfig-Datei. Habe ich das so richtig verstanden?
                                Die VMS01 ID ist in meinem Scan zu sehen.
                                Danke für Deine Antwort und Hilfe
                                • J Jui
                                  HiltexH Offline
                                  HiltexH Offline
                                  Hiltex
                                  #220
                                  @Jui Du brauchst keine eigene Konfig-Datei schreiben, du kannst doch einfach meine verwenden.
                                  Blog: indibit.de
                                  • TimmerxT Offline
                                    TimmerxT Offline
                                    Timmerx
                                    #221
                                    Ich habe jetzt mal die 15.700.csv in 15.720 umbenannt leider wird die Datei nicht gefunden und zugewiesen.
                                    Ich habe in der kopierten 15.700.csv alle Verknüpfungen von 15.700 in 15.720 geändert und auch die Rechte auf dem Pi auf 644 gestellt. Leider ohne Erfolg
                                    Kann mir jemand erklären wie man seine eigene .csv erstellt?
                                    • TimmerxT Timmerx
                                      HiltexH Offline
                                      HiltexH Offline
                                      Hiltex
                                      #222
                                      @Timmerx Über die Parameter muss man ebusd mitteilen, woher er die Config-Dateien laden soll. Standard (ohne Pfadangabe) ist dabei direkt aus dem Internet.
                                      Du kannst die Dateien im Prinzip abspeichern, wo du willst, und den Pfad entsprechend angeben. Damit alles einwandfrei funktioniert benötigst du alle Dateien aus dem Github-Repository.
                                      Wenn die Quell-Datei 15.700.csv dann zum Beispiel unter /etc/ebusd/ebusd-2.1.x/de/vaillant/15.700.csv zu finden ist, dann muss die Pfadangabe /etc/ebusd/ebusd-2.1.x/de lauten.
                                      Diesen Pfad trägst du in die Datei /etc/default/ebusd unter EBUSD_OPTS ein.
                                      Insgesamt könnte die Zeile dann so aussehen (bitte an deinen Bedarf anpassen):
                                      EBUSD_OPTS="--device=192.168.243.86:5000 --httpport=8889 --scanconfig --latency=30000 --configpath=/etc/ebusd/ebusd-2.1.x/de"
                                      Es bedarf dabei keiner Konkreten Angabe, welche Datei geladen werden soll, nur die Pfadangabe muss richtig sein. Wenn also 15.720.csv ebenfalls in diesem Pfad liegt und diese soweit korrekt ist, lädt er die automatisch.
                                      Das war das grundsätzliche, eleganter ist der Weg über Symlink. Dazu gehst du wie folgt vor:
                                      Auf der Kommandozeile:
                                      cd~
                                      git clone https://github.com/john30/ebusd-configuration.git
                                      if [ -d /etc/ebusd ]; then sudo mv /etc/ebusd /etc/ebusd.old; fi
                                      sudo ln -s $PWD/ebusd-configuration/ebusd-2.1.x/de /etc/ebusd
                                      Die Dateien liegen nun im Stammordner deines aktuellen Benutzers, können aber über den Pfad /etc/ebusd/ erreicht werden, sodass die Konfiguration in /etc/default/ebusd so aussehen könnte:
                                      EBUSD_OPTS="--device=192.168.243.86:5000 --httpport=8889 --scanconfig --latency=30000 --configpath=/etc/ebusd"
                                      Ich hoffe das war verständlich, sonst frag einfach nochmal.
                                      Dein Vorgehen, die Datei einfach zu kopieren und entsprechend anzupassen, war ansonsten korrekt.
                                      Blog: indibit.de
                                      J 2 Antworten Letzte Antwort
                                      • TimmerxT Offline
                                        TimmerxT Offline
                                        Timmerx
                                        #223
                                        vielen Dank für die wirklich ausführliche Erklärung.
                                        Ich weiß allerding nicht, ob ich mein Problem damit lösen kann.
                                        Das Problem ist das ich eine VRC720 habe und nicht die VRC700 bei der VRC700 wird die 15.700.csv geladen.
                                        Bei meiner VRC720 wird die 15.700.csv nicht geladen, weil die natürlich auch nicht passt.
                                        Ich denke ich brauche ein 15.720.csv. Da meine "MF=Vaillant;ID=72000;SW=0118;HW=7703 und nicht ID=70000 ist.
                                        Da sich die VRC700 und die VRC720 eigentlich nicht unterscheiden möchte ich die 15.700 in 15.720 umbenennen, damit die dann auch geladen wird. Das klappt aber leider nicht. Es scheint aber wohl schon mal jemand geschafft zu haben.
                                        link text
                                        Ich denke ich muss hier irgendwas mit Symlink anstellen.
                                        HiltexH L 2 Antworten Letzte Antwort
                                        • TimmerxT Timmerx
                                          link text
                                          HiltexH Offline
                                          HiltexH Offline
                                          Hiltex
                                          #224
                                          @Timmerx Es ist eigentlich egal, ob du einen Symlink verwendest, die Datei umbenennst oder kopierst und mit einem anderen Namen einfügst. Das Ergebnis ist immer das gleiche, nur die Eleganz unterscheidet sich 😉
                                          Blog: indibit.de
