  4. DENON Adapter Probleme?!
    6.6k
denon adapterdenon
53 Beiträge 11 Kommentatoren 7.1k Aufrufe 10 Beobachtet
  • NegaleinN Negalein
    @foxriver76 sagte in DENON Adapter Probleme?!:
    Bzgl. dem Problem.. wenn du den Adapter auf Debug stellst + AVR davor aus machst, dann steht am Anfang check receiver type und es kommt wohl keine Antwort. Du könntest mal während er aus ist via settings.expertCommand den Befehl MV? senden. Auf diesen würde ich auch im Standby eine Antwort erwarten.
    denon.0	2020-03-31 21:57:27.926	warn	(16673) AVR timed out due to no response
    denon.0	2020-03-31 21:56:52.926	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:56:52.925	debug	(16673) [INFO] ==> Message sent: SV01?
    denon.0	2020-03-31 21:56:52.924	debug	(16673) [INFO] ==> Message sent: SV?
    denon.0	2020-03-31 21:56:52.924	debug	(16673) [CONNECT] Connected --> Check receiver type
    denon.0	2020-03-31 21:56:52.923	info	(16673) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
    denon.0	2020-03-31 21:56:52.922	info	(16673) [CONNECT] Trying to connect to 10.0.1.38:23
    denon.0	2020-03-31 21:56:51.723	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:56:51.722	debug	(16673) [INFO] ==> Message sent: SV01?
    denon.0	2020-03-31 21:56:51.721	debug	(16673) [INFO] ==> Message sent: SV?
    denon.0	2020-03-31 21:56:51.721	debug	(16673) [CONNECT] Connected --> Check receiver type
    denon.0	2020-03-31 21:56:51.720	info	(16673) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
    denon.0	2020-03-31 21:56:51.718	info	(16673) [CONNECT] Trying to connect to 10.0.1.38:23
    denon.0	2020-03-31 21:56:22.922	debug	(16673) [INFO] ==> Message sent: MV?
    denon.0	2020-03-31 21:56:22.921	warn	(16673) Connection closed: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
    denon.0	2020-03-31 21:56:22.918	debug	(16673) [COMMAND] State Change - ID: settings.expertCommand; State: MV?
    denon.0	2020-03-31 21:56:21.716	warn	(16673) AVR timed out due to no response
    denon.0	2020-03-31 21:55:46.716	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:55:46.715	debug	(16673) [INFO] ==> Message sent: SV01?
    denon.0	2020-03-31 21:55:46.713	debug	(16673) [INFO] ==> Message sent: SV?
    denon.0	2020-03-31 21:55:46.712	debug	(16673) [CONNECT] Connected --> Check receiver type
    denon.0	2020-03-31 21:55:46.712	info	(16673) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
    denon.0	2020-03-31 21:55:46.702	info	(16673) [CONNECT] Trying to connect to 10.0.1.38:23
    denon.0	2020-03-31 21:55:46.699	info	(16673) [START] Starting DENON AVR adapter
    denon.0	2020-03-31 21:55:46.620	info	(16673) starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.denon, node: v10.17.0
    denon.0	2020-03-31 21:55:41.770	warn	(24837) Connection closed: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
    denon.0	2020-03-31 21:55:41.690	info	(24837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    denon.0	2020-03-31 21:55:41.689	info	(24837) terminating
    denon.0	2020-03-31 21:55:41.688	info	(24837) [END] Stopping Denon AVR adapter...
    denon.0	2020-03-31 21:55:41.687	info	(24837) Got terminate signal TERMINATE_YOURSELF
    denon.0	2020-03-31 21:58:17.155	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:58:17.056	debug	(16673) [INFO] ==> Message sent: Z3SMART ?
    denon.0	2020-03-31 21:58:16.956	debug	(16673) [INFO] ==> Message sent: Z2SMART ?
    denon.0	2020-03-31 21:58:16.855	debug	(16673) [INFO] ==> Message sent: Z3QUICK ?
    denon.0	2020-03-31 21:58:16.826	debug	(16673) [DATA] <== Incoming data: Z2QUICK0
    denon.0	2020-03-31 21:58:16.755	debug	(16673) [INFO] ==> Message sent: Z2QUICK ?
    denon.0	2020-03-31 21:58:16.655	debug	(16673) [INFO] ==> Message sent: PR00TR?
    denon.0	2020-03-31 21:58:16.555	debug	(16673) [INFO] ==> Message sent: MSSMART ?
    denon.0	2020-03-31 21:58:16.514	debug	(16673) [DATA] <== Incoming data: MSQUICK0
    denon.0	2020-03-31 21:58:16.474	debug	(16673) [DATA] <== Incoming data: NSE8 [ 0/5 ]
    denon.0	2020-03-31 21:58:16.455	debug	(16673) [INFO] ==> Message sent: MSQUICK ?
    denon.0	2020-03-31 21:58:16.431	debug	(16673) [DATA] <== Incoming data: NSE7
    denon.0	2020-03-31 21:58:16.384	debug	(16673) [DATA] <== Incoming data: Z2SLPOFF
    denon.0	2020-03-31 21:58:16.354	debug	(16673) [INFO] ==> Message sent: Z3SLP?
    denon.0	2020-03-31 21:58:16.345	debug	(16673) [DATA] <== Incoming data: SLPOFF
    denon.0	2020-03-31 21:58:16.313	debug	(16673) [DATA] <== Incoming data: NSE6
    denon.0	2020-03-31 21:58:16.275	debug	(16673) [DATA] <== Incoming data: NSE5Flickr
    denon.0	2020-03-31 21:58:16.254	debug	(16673) [INFO] ==> Message sent: Z2SLP?
    denon.0	2020-03-31 21:58:16.234	debug	(16673) [DATA] <== Incoming data: NSE4Last.Fm
    denon.0	2020-03-31 21:58:16.193	debug	(16673) [DATA] <== Incoming data: NSE3Media Server
    denon.0	2020-03-31 21:58:16.154	debug	(16673) [INFO] ==> Message sent: SLP?
    denon.0	2020-03-31 21:58:16.153	debug	(16673) [DATA] <== Incoming data: NSE2Internet Radio
    denon.0	2020-03-31 21:58:16.114	debug	(16673) [DATA] <== Incoming data: Favorites
    denon.0	2020-03-31 21:58:16.113	debug	(16673) [DATA] <== Incoming data: NSE1
    denon.0	2020-03-31 21:58:16.072	debug	(16673) [DATA] <== Incoming data: NSE0Network
    denon.0	2020-03-31 21:58:16.054	debug	(16673) [INFO] ==> Message sent: NSE
    denon.0	2020-03-31 21:58:15.035	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:58:14.934	debug	(16673) [INFO] ==> Message sent: Z3SMART ?
    denon.0	2020-03-31 21:58:14.835	debug	(16673) [INFO] ==> Message sent: Z2SMART ?
    denon.0	2020-03-31 21:58:14.735	debug	(16673) [INFO] ==> Message sent: Z3QUICK ?
    denon.0	2020-03-31 21:58:14.681	debug	(16673) [DATA] <== Incoming data: Z2QUICK0
    denon.0	2020-03-31 21:58:14.635	debug	(16673) [INFO] ==> Message sent: Z2QUICK ?
    denon.0	2020-03-31 21:58:14.534	debug	(16673) [INFO] ==> Message sent: PR00TR?
    denon.0	2020-03-31 21:58:14.435	debug	(16673) [INFO] ==> Message sent: MSSMART ?
    denon.0	2020-03-31 21:58:14.423	debug	(16673) [DATA] <== Incoming data: MSQUICK0
    denon.0	2020-03-31 21:58:14.362	debug	(16673) [DATA] <== Incoming data: Z2SLPOFF
    denon.0	2020-03-31 21:58:14.335	debug	(16673) [INFO] ==> Message sent: MSQUICK ?
    denon.0	2020-03-31 21:58:14.329	debug	(16673) [DATA] <== Incoming data: SLPOFF
    denon.0	2020-03-31 21:58:14.272	debug	(16673) [DATA] <== Incoming data: NSE8 [ 0/5 ]
    denon.0	2020-03-31 21:58:14.235	debug	(16673) [INFO] ==> Message sent: Z3SLP?
    denon.0	2020-03-31 21:58:14.233	debug	(16673) [DATA] <== Incoming data: NSE7
    denon.0	2020-03-31 21:58:14.193	debug	(16673) [DATA] <== Incoming data: NSE6
    denon.0	2020-03-31 21:58:14.154	debug	(16673) [DATA] <== Incoming data: NSE5Flickr
    denon.0	2020-03-31 21:58:14.134	debug	(16673) [INFO] ==> Message sent: Z2SLP?
    denon.0	2020-03-31 21:58:14.114	debug	(16673) [DATA] <== Incoming data: NSE4Last.Fm
    denon.0	2020-03-31 21:58:14.074	debug	(16673) [DATA] <== Incoming data: NSE3Media Server
    denon.0	2020-03-31 21:58:14.033	debug	(16673) [INFO] ==> Message sent: SLP?
    denon.0	2020-03-31 21:58:14.032	debug	(16673) [DATA] <== Incoming data: NSE2Internet Radio
    denon.0	2020-03-31 21:58:13.994	debug	(16673) [DATA] <== Incoming data: Favorites
    denon.0	2020-03-31 21:58:13.993	debug	(16673) [DATA] <== Incoming data: NSE1
    denon.0	2020-03-31 21:58:13.953	debug	(16673) [DATA] <== Incoming data: NSE0Network
    denon.0	2020-03-31 21:58:13.933	debug	(16673) [INFO] ==> Message sent: NSE
    denon.0	2020-03-31 21:58:12.921	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:58:12.820	debug	(16673) [INFO] ==> Message sent: Z3SMART ?
    denon.0	2020-03-31 21:58:12.720	debug	(16673) [INFO] ==> Message sent: Z2SMART ?
    denon.0	2020-03-31 21:58:12.619	debug	(16673) [INFO] ==> Message sent: Z3QUICK ?
    denon.0	2020-03-31 21:58:12.585	debug	(16673) [DATA] <== Incoming data: Z2QUICK0
    denon.0	2020-03-31 21:58:12.514	debug	(16673) [INFO] ==> Message sent: Z2QUICK ?
    denon.0	2020-03-31 21:58:12.415	debug	(16673) [INFO] ==> Message sent: PR00TR?
    denon.0	2020-03-31 21:58:12.314	debug	(16673) [INFO] ==> Message sent: MSSMART ?
    denon.0	2020-03-31 21:58:12.272	debug	(16673) [DATA] <== Incoming data: MSQUICK0
    denon.0	2020-03-31 21:58:12.233	debug	(16673) [DATA] <== Incoming data: NSE8 [ 0/5 ]
    denon.0	2020-03-31 21:58:12.215	debug	(16673) [INFO] ==> Message sent: MSQUICK ?
    denon.0	2020-03-31 21:58:12.193	debug	(16673) [DATA] <== Incoming data: NSE7
    denon.0	2020-03-31 21:58:12.143	debug	(16673) [DATA] <== Incoming data: Z2SLPOFF
    denon.0	2020-03-31 21:58:12.114	debug	(16673) [INFO] ==> Message sent: Z3SLP?
    denon.0	2020-03-31 21:58:12.105	debug	(16673) [DATA] <== Incoming data: SLPOFF
    denon.0	2020-03-31 21:58:12.074	debug	(16673) [DATA] <== Incoming data: NSE6
    denon.0	2020-03-31 21:58:12.034	debug	(16673) [DATA] <== Incoming data: NSE5Flickr
    denon.0	2020-03-31 21:58:12.013	debug	(16673) [INFO] ==> Message sent: Z2SLP?
    denon.0	2020-03-31 21:58:11.993	debug	(16673) [DATA] <== Incoming data: NSE4Last.Fm
    denon.0	2020-03-31 21:58:11.954	debug	(16673) [DATA] <== Incoming data: NSE3Media Server
    denon.0	2020-03-31 21:58:11.914	debug	(16673) [DATA] <== Incoming data: NSE2Internet Radio
    denon.0	2020-03-31 21:58:11.913	debug	(16673) [INFO] ==> Message sent: SLP?
    denon.0	2020-03-31 21:58:11.874	debug	(16673) [DATA] <== Incoming data: Favorites
    denon.0	2020-03-31 21:58:11.873	debug	(16673) [DATA] <== Incoming data: NSE1
    denon.0	2020-03-31 21:58:11.832	debug	(16673) [DATA] <== Incoming data: NSE0Network
    denon.0	2020-03-31 21:58:11.812	debug	(16673) [INFO] ==> Message sent: NSE
    denon.0	2020-03-31 21:58:10.787	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:58:10.687	debug	(16673) [INFO] ==> Message sent: Z3SMART ?
    denon.0	2020-03-31 21:58:10.587	debug	(16673) [INFO] ==> Message sent: Z2SMART ?
    denon.0	2020-03-31 21:58:10.487	debug	(16673) [INFO] ==> Message sent: Z3QUICK ?
    denon.0	2020-03-31 21:58:10.423	debug	(16673) [DATA] <== Incoming data: Z2QUICK0
    denon.0	2020-03-31 21:58:10.387	debug	(16673) [INFO] ==> Message sent: Z2QUICK ?
    denon.0	2020-03-31 21:58:10.286	debug	(16673) [INFO] ==> Message sent: PR00TR?
    denon.0	2020-03-31 21:58:10.186	debug	(16673) [INFO] ==> Message sent: MSSMART ?
    denon.0	2020-03-31 21:58:10.178	debug	(16673) [DATA] <== Incoming data: MSQUICK0
    denon.0	2020-03-31 21:58:10.138	debug	(16673) [DATA] <== Incoming data: Z2SLPOFF
    denon.0	2020-03-31 21:58:10.086	debug	(16673) [INFO] ==> Message sent: MSQUICK ?
    denon.0	2020-03-31 21:58:10.072	debug	(16673) [DATA] <== Incoming data: NSE8 [ 0/5 ]
    denon.0	2020-03-31 21:58:10.033	debug	(16673) [DATA] <== Incoming data: NSE7
    denon.0	2020-03-31 21:58:09.991	debug	(16673) [DATA] <== Incoming data: NSE6
    denon.0	2020-03-31 21:58:09.986	debug	(16673) [INFO] ==> Message sent: Z3SLP?
    denon.0	2020-03-31 21:58:09.952	debug	(16673) [DATA] <== Incoming data: NSE5Flickr
    denon.0	2020-03-31 21:58:09.912	debug	(16673) [DATA] <== Incoming data: NSE4Last.Fm
    denon.0	2020-03-31 21:58:09.885	debug	(16673) [INFO] ==> Message sent: Z2SLP?
    denon.0	2020-03-31 21:58:09.871	debug	(16673) [DATA] <== Incoming data: NSE3Media Server
    denon.0	2020-03-31 21:58:09.832	debug	(16673) [DATA] <== Incoming data: SLPOFF
    denon.0	2020-03-31 21:58:09.792	debug	(16673) [DATA] <== Incoming data: NSE2Internet Radio
    denon.0	2020-03-31 21:58:09.786	debug	(16673) [INFO] ==> Message sent: SLP?
    denon.0	2020-03-31 21:58:09.752	debug	(16673) [DATA] <== Incoming data: Favorites
    denon.0	2020-03-31 21:58:09.751	debug	(16673) [DATA] <== Incoming data: NSE1
    denon.0	2020-03-31 21:58:09.711	debug	(16673) [DATA] <== Incoming data: NSE0Network
    denon.0	2020-03-31 21:58:09.685	debug	(16673) [INFO] ==> Message sent: NSE
    denon.0	2020-03-31 21:58:08.664	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:58:08.563	debug	(16673) [INFO] ==> Message sent: Z3SMART ?
    denon.0	2020-03-31 21:58:08.463	debug	(16673) [INFO] ==> Message sent: Z2SMART ?
    denon.0	2020-03-31 21:58:08.362	debug	(16673) [INFO] ==> Message sent: Z3QUICK ?
    denon.0	2020-03-31 21:58:08.301	debug	(16673) [DATA] <== Incoming data: Z2QUICK0
    denon.0	2020-03-31 21:58:08.263	debug	(16673) [INFO] ==> Message sent: Z2QUICK ?
    denon.0	2020-03-31 21:58:08.162	debug	(16673) [INFO] ==> Message sent: PR00TR?
    denon.0	2020-03-31 21:58:08.062	debug	(16673) [INFO] ==> Message sent: MSSMART ?
    denon.0	2020-03-31 21:58:08.043	debug	(16673) [DATA] <== Incoming data: MSQUICK0
    denon.0	2020-03-31 21:58:07.983	debug	(16673) [DATA] <== Incoming data: Z2SLPOFF
    denon.0	2020-03-31 21:58:07.963	debug	(16673) [INFO] ==> Message sent: MSQUICK ?
    denon.0	2020-03-31 21:58:07.950	debug	(16673) [DATA] <== Incoming data: SLPOFF
    denon.0	2020-03-31 21:58:07.913	debug	(16673) [DATA] <== Incoming data: NSE8 [ 0/5 ]
    denon.0	2020-03-31 21:58:07.871	debug	(16673) [DATA] <== Incoming data: NSE7
    denon.0	2020-03-31 21:58:07.862	debug	(16673) [INFO] ==> Message sent: Z3SLP?
    denon.0	2020-03-31 21:58:07.834	debug	(16673) [DATA] <== Incoming data: NSE6
    denon.0	2020-03-31 21:58:07.791	debug	(16673) [DATA] <== Incoming data: NSE5Flickr
    denon.0	2020-03-31 21:58:07.761	debug	(16673) [INFO] ==> Message sent: Z2SLP?
    denon.0	2020-03-31 21:58:07.751	debug	(16673) [DATA] <== Incoming data: NSE4Last.Fm
    denon.0	2020-03-31 21:58:07.714	debug	(16673) [DATA] <== Incoming data: NSE3Media Server
    denon.0	2020-03-31 21:58:07.671	debug	(16673) [DATA] <== Incoming data: NSE2Internet Radio
    denon.0	2020-03-31 21:58:07.661	debug	(16673) [INFO] ==> Message sent: SLP?
    denon.0	2020-03-31 21:58:07.631	debug	(16673) [DATA] <== Incoming data: Favorites
    denon.0	2020-03-31 21:58:07.631	debug	(16673) [DATA] <== Incoming data: NSE1
    denon.0	2020-03-31 21:58:07.584	debug	(16673) [DATA] <== Incoming data: NSE0Network
    denon.0	2020-03-31 21:58:07.561	debug	(16673) [INFO] ==> Message sent: NSE
    denon.0	2020-03-31 21:58:05.456	debug	(16673) [DATA] <== Incoming data: PWON
    denon.0	2020-03-31 21:57:57.932	debug	(16673) [INFO] ==> Message sent: BDSTATUS?
    denon.0	2020-03-31 21:57:57.931	debug	(16673) [INFO] ==> Message sent: SV01?
    denon.0	2020-03-31 21:57:57.931	debug	(16673) [INFO] ==> Message sent: SV?
    denon.0	2020-03-31 21:57:57.930	debug	(16673) [CONNECT] Connected --> Check receiver type
    denon.0	2020-03-31 21:57:57.930	info	(16673) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
    denon.0	2020-03-31 21:57:57.928	info	(16673) [CONNECT] Trying to connect to 10.0.1.38:23
    @dslraser sagte in DENON Adapter Probleme?!:
    Ich habe aktuell auch einen aus der HEOS Familie. Bei mir funktioniert der Adapter.
    Meiner ist keiner mit HEOS
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    @Negalein Problem ist, dass der Adapter schon disconnected war als du MV? gesendet hast. Nach connect sind nur 35 Sekunden Zeit das was passiert.
    Videotutorials & mehr
    • foxriver76F foxriver76
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      Ok, hab mich jetzt beeilt und hat geklappt.
      denon.0	2020-03-31 22:17:51.548	debug	(29669) [INFO] ==> Message sent: BDSTATUS?
      denon.0	2020-03-31 22:17:51.447	debug	(29669) [INFO] ==> Message sent: Z3SMART ?
      denon.0	2020-03-31 22:17:51.347	debug	(29669) [INFO] ==> Message sent: Z2SMART ?
      denon.0	2020-03-31 22:17:51.247	debug	(29669) [INFO] ==> Message sent: Z3QUICK ?
      denon.0	2020-03-31 22:17:51.162	debug	(29669) [DATA] <== Incoming data: Z2QUICK0
      denon.0	2020-03-31 22:17:51.147	debug	(29669) [INFO] ==> Message sent: Z2QUICK ?
      denon.0	2020-03-31 22:17:51.046	debug	(29669) [INFO] ==> Message sent: PR00TR?
      denon.0	2020-03-31 22:17:50.947	debug	(29669) [INFO] ==> Message sent: MSSMART ?
      denon.0	2020-03-31 22:17:50.922	debug	(29669) [DATA] <== Incoming data: MSQUICK0
      denon.0	2020-03-31 22:17:50.867	debug	(29669) [DATA] <== Incoming data: Z2SLPOFF
      denon.0	2020-03-31 22:17:50.847	debug	(29669) [INFO] ==> Message sent: MSQUICK ?
      denon.0	2020-03-31 22:17:50.837	debug	(29669) [DATA] <== Incoming data: SLPOFF
      denon.0	2020-03-31 22:17:50.776	debug	(29669) [DATA] <== Incoming data: NSE8 [ 0/5 ]
      denon.0	2020-03-31 22:17:50.747	debug	(29669) [INFO] ==> Message sent: Z3SLP?
      denon.0	2020-03-31 22:17:50.736	debug	(29669) [DATA] <== Incoming data: NSE7
      denon.0	2020-03-31 22:17:50.697	debug	(29669) [DATA] <== Incoming data: NSE6
      denon.0	2020-03-31 22:17:50.656	debug	(29669) [DATA] <== Incoming data: NSE5Flickr
      denon.0	2020-03-31 22:17:50.647	debug	(29669) [INFO] ==> Message sent: Z2SLP?
      denon.0	2020-03-31 22:17:50.617	debug	(29669) [DATA] <== Incoming data: NSE4Last.Fm
      denon.0	2020-03-31 22:17:50.576	debug	(29669) [DATA] <== Incoming data: NSE3Media Server
      denon.0	2020-03-31 22:17:50.546	debug	(29669) [INFO] ==> Message sent: SLP?
      denon.0	2020-03-31 22:17:50.536	debug	(29669) [DATA] <== Incoming data: NSE2Internet Radio
      denon.0	2020-03-31 22:17:50.497	debug	(29669) [DATA] <== Incoming data: Favorites
      denon.0	2020-03-31 22:17:50.496	debug	(29669) [DATA] <== Incoming data: NSE1
      denon.0	2020-03-31 22:17:50.467	debug	(29669) [DATA] <== Incoming data: NSE0Network
      denon.0	2020-03-31 22:17:50.447	debug	(29669) [INFO] ==> Message sent: NSE
      denon.0	2020-03-31 22:17:49.422	debug	(29669) [INFO] ==> Message sent: BDSTATUS?
      denon.0	2020-03-31 22:17:49.323	debug	(29669) [INFO] ==> Message sent: Z3SMART ?
      denon.0	2020-03-31 22:17:49.223	debug	(29669) [INFO] ==> Message sent: Z2SMART ?
      denon.0	2020-03-31 22:17:49.122	debug	(29669) [INFO] ==> Message sent: Z3QUICK ?
      denon.0	2020-03-31 22:17:49.046	debug	(29669) [DATA] <== Incoming data: Z2QUICK0
      denon.0	2020-03-31 22:17:49.022	debug	(29669) [INFO] ==> Message sent: Z2QUICK ?
      denon.0	2020-03-31 22:17:48.922	debug	(29669) [INFO] ==> Message sent: PR00TR?
      denon.0	2020-03-31 22:17:48.823	debug	(29669) [INFO] ==> Message sent: MSSMART ?
      denon.0	2020-03-31 22:17:48.806	debug	(29669) [DATA] <== Incoming data: MSQUICK0
      denon.0	2020-03-31 22:17:48.752	debug	(29669) [DATA] <== Incoming data: Z2SLPOFF
      denon.0	2020-03-31 22:17:48.723	debug	(29669) [INFO] ==> Message sent: MSQUICK ?
      denon.0	2020-03-31 22:17:48.721	debug	(29669) [DATA] <== Incoming data: SLPOFF
      denon.0	2020-03-31 22:17:48.660	debug	(29669) [DATA] <== Incoming data: NSE8 [ 0/5 ]
      denon.0	2020-03-31 22:17:48.622	debug	(29669) [INFO] ==> Message sent: Z3SLP?
      denon.0	2020-03-31 22:17:48.621	debug	(29669) [DATA] <== Incoming data: NSE7
      denon.0	2020-03-31 22:17:48.581	debug	(29669) [DATA] <== Incoming data: NSE6
      denon.0	2020-03-31 22:17:48.540	debug	(29669) [DATA] <== Incoming data: NSE5Flickr
      denon.0	2020-03-31 22:17:48.523	debug	(29669) [INFO] ==> Message sent: Z2SLP?
      denon.0	2020-03-31 22:17:48.501	debug	(29669) [DATA] <== Incoming data: NSE4Last.Fm
      denon.0	2020-03-31 22:17:48.460	debug	(29669) [DATA] <== Incoming data: NSE3Media Server
      denon.0	2020-03-31 22:17:48.423	debug	(29669) [INFO] ==> Message sent: SLP?
      denon.0	2020-03-31 22:17:48.421	debug	(29669) [DATA] <== Incoming data: NSE2Internet Radio
      denon.0	2020-03-31 22:17:48.382	debug	(29669) [DATA] <== Incoming data: Favorites
      denon.0	2020-03-31 22:17:48.381	debug	(29669) [DATA] <== Incoming data: NSE1
      denon.0	2020-03-31 22:17:48.345	debug	(29669) [DATA] <== Incoming data: NSE0Network
      denon.0	2020-03-31 22:17:48.322	debug	(29669) [INFO] ==> Message sent: NSE
      denon.0	2020-03-31 22:17:47.304	debug	(29669) [INFO] ==> Message sent: BDSTATUS?
      denon.0	2020-03-31 22:17:47.204	debug	(29669) [INFO] ==> Message sent: Z3SMART ?
      denon.0	2020-03-31 22:17:47.104	debug	(29669) [INFO] ==> Message sent: Z2SMART ?
      denon.0	2020-03-31 22:17:47.004	debug	(29669) [INFO] ==> Message sent: Z3QUICK ?
      denon.0	2020-03-31 22:17:46.926	debug	(29669) [DATA] <== Incoming data: Z2QUICK0
      denon.0	2020-03-31 22:17:46.903	debug	(29669) [INFO] ==> Message sent: Z2QUICK ?
      denon.0	2020-03-31 22:17:46.803	debug	(29669) [INFO] ==> Message sent: PR00TR?
      denon.0	2020-03-31 22:17:46.703	debug	(29669) [INFO] ==> Message sent: MSSMART ?
      denon.0	2020-03-31 22:17:46.687	debug	(29669) [DATA] <== Incoming data: MSQUICK0
      denon.0	2020-03-31 22:17:46.646	debug	(29669) [DATA] <== Incoming data: Z2SLPOFF
      denon.0	2020-03-31 22:17:46.603	debug	(29669) [INFO] ==> Message sent: MSQUICK ?
      denon.0	2020-03-31 22:17:46.582	debug	(29669) [DATA] <== Incoming data: NSE8 [ 0/5 ]
      denon.0	2020-03-31 22:17:46.540	debug	(29669) [DATA] <== Incoming data: NSE7
      denon.0	2020-03-31 22:17:46.503	debug	(29669) [INFO] ==> Message sent: Z3SLP?
      denon.0	2020-03-31 22:17:46.500	debug	(29669) [DATA] <== Incoming data: NSE6
      denon.0	2020-03-31 22:17:46.461	debug	(29669) [DATA] <== Incoming data: NSE5Flickr
      denon.0	2020-03-31 22:17:46.420	debug	(29669) [DATA] <== Incoming data: NSE4Last.Fm
      denon.0	2020-03-31 22:17:46.402	debug	(29669) [INFO] ==> Message sent: Z2SLP?
      denon.0	2020-03-31 22:17:46.380	debug	(29669) [DATA] <== Incoming data: NSE3Media Server
      denon.0	2020-03-31 22:17:46.331	debug	(29669) [DATA] <== Incoming data: SLPOFF
      denon.0	2020-03-31 22:17:46.302	debug	(29669) [INFO] ==> Message sent: SLP?
      denon.0	2020-03-31 22:17:46.300	debug	(29669) [DATA] <== Incoming data: NSE2Internet Radio
      denon.0	2020-03-31 22:17:46.261	debug	(29669) [DATA] <== Incoming data: Favorites
      denon.0	2020-03-31 22:17:46.260	debug	(29669) [DATA] <== Incoming data: NSE1
      denon.0	2020-03-31 22:17:46.220	debug	(29669) [DATA] <== Incoming data: NSE0Network
      denon.0	2020-03-31 22:17:46.200	debug	(29669) [INFO] ==> Message sent: NSE
      denon.0	2020-03-31 22:17:45.178	debug	(29669) [INFO] ==> Message sent: BDSTATUS?
      denon.0	2020-03-31 22:17:45.079	debug	(29669) [INFO] ==> Message sent: Z3SMART ?
      denon.0	2020-03-31 22:17:44.979	debug	(29669) [INFO] ==> Message sent: Z2SMART ?
      denon.0	2020-03-31 22:17:44.878	debug	(29669) [INFO] ==> Message sent: Z3QUICK ?
      denon.0	2020-03-31 22:17:44.806	debug	(29669) [DATA] <== Incoming data: Z2QUICK0
      denon.0	2020-03-31 22:17:44.776	debug	(29669) [INFO] ==> Message sent: Z2QUICK ?
      denon.0	2020-03-31 22:17:44.675	debug	(29669) [INFO] ==> Message sent: PR00TR?
      denon.0	2020-03-31 22:17:44.576	debug	(29669) [INFO] ==> Message sent: MSSMART ?
      denon.0	2020-03-31 22:17:44.567	debug	(29669) [DATA] <== Incoming data: MSQUICK0
      denon.0	2020-03-31 22:17:44.526	debug	(29669) [DATA] <== Incoming data: Z2SLPOFF
      denon.0	2020-03-31 22:17:44.476	debug	(29669) [INFO] ==> Message sent: MSQUICK ?
      denon.0	2020-03-31 22:17:44.460	debug	(29669) [DATA] <== Incoming data: NSE8 [ 0/5 ]
      denon.0	2020-03-31 22:17:44.420	debug	(29669) [DATA] <== Incoming data: NSE7
      denon.0	2020-03-31 22:17:44.379	debug	(29669) [DATA] <== Incoming data: NSE6
      denon.0	2020-03-31 22:17:44.376	debug	(29669) [INFO] ==> Message sent: Z3SLP?
      denon.0	2020-03-31 22:17:44.340	debug	(29669) [DATA] <== Incoming data: NSE5Flickr
      denon.0	2020-03-31 22:17:44.299	debug	(29669) [DATA] <== Incoming data: NSE4Last.Fm
      denon.0	2020-03-31 22:17:44.276	debug	(29669) [INFO] ==> Message sent: Z2SLP?
      denon.0	2020-03-31 22:17:44.259	debug	(29669) [DATA] <== Incoming data: NSE3Media Server
      denon.0	2020-03-31 22:17:44.220	debug	(29669) [DATA] <== Incoming data: SLPOFF
      denon.0	2020-03-31 22:17:44.179	debug	(29669) [DATA] <== Incoming data: NSE2Internet Radio
      denon.0	2020-03-31 22:17:44.175	debug	(29669) [INFO] ==> Message sent: SLP?
      denon.0	2020-03-31 22:17:44.140	debug	(29669) [DATA] <== Incoming data: Favorites
      denon.0	2020-03-31 22:17:44.139	debug	(29669) [DATA] <== Incoming data: NSE1
      denon.0	2020-03-31 22:17:44.099	debug	(29669) [DATA] <== Incoming data: NSE0Network
      denon.0	2020-03-31 22:17:44.076	debug	(29669) [INFO] ==> Message sent: NSE
      denon.0	2020-03-31 22:17:43.058	debug	(29669) [INFO] ==> Message sent: BDSTATUS?
      denon.0	2020-03-31 22:17:42.958	debug	(29669) [INFO] ==> Message sent: Z3SMART ?
      denon.0	2020-03-31 22:17:42.858	debug	(29669) [INFO] ==> Message sent: Z2SMART ?
      denon.0	2020-03-31 22:17:42.757	debug	(29669) [INFO] ==> Message sent: Z3QUICK ?
      denon.0	2020-03-31 22:17:42.685	debug	(29669) [DATA] <== Incoming data: Z2QUICK0
      denon.0	2020-03-31 22:17:42.658	debug	(29669) [INFO] ==> Message sent: Z2QUICK ?
      denon.0	2020-03-31 22:17:42.558	debug	(29669) [INFO] ==> Message sent: PR00TR?
      denon.0	2020-03-31 22:17:42.458	debug	(29669) [INFO] ==> Message sent: MSSMART ?
      denon.0	2020-03-31 22:17:42.445	debug	(29669) [DATA] <== Incoming data: MSQUICK0
      denon.0	2020-03-31 22:17:42.390	debug	(29669) [DATA] <== Incoming data: Z2SLPOFF
      denon.0	2020-03-31 22:17:42.358	debug	(29669) [INFO] ==> Message sent: MSQUICK ?
      denon.0	2020-03-31 22:17:42.355	debug	(29669) [DATA] <== Incoming data: SLPOFF
      denon.0	2020-03-31 22:17:42.299	debug	(29669) [DATA] <== Incoming data: NSE8 [ 0/5 ]
      denon.0	2020-03-31 22:17:42.259	debug	(29669) [DATA] <== Incoming data: NSE7
      denon.0	2020-03-31 22:17:42.257	debug	(29669) [INFO] ==> Message sent: Z3SLP?
      denon.0	2020-03-31 22:17:42.221	debug	(29669) [DATA] <== Incoming data: NSE6
      denon.0	2020-03-31 22:17:42.181	debug	(29669) [DATA] <== Incoming data: NSE5Flickr
      denon.0	2020-03-31 22:17:42.156	debug	(29669) [INFO] ==> Message sent: Z2SLP?
      denon.0	2020-03-31 22:17:42.141	debug	(29669) [DATA] <== Incoming data: NSE4Last.Fm
      denon.0	2020-03-31 22:17:42.103	debug	(29669) [DATA] <== Incoming data: NSE3Media Server
      denon.0	2020-03-31 22:17:42.059	debug	(29669) [DATA] <== Incoming data: NSE2Internet Radio
      denon.0	2020-03-31 22:17:42.055	debug	(29669) [INFO] ==> Message sent: SLP?
      denon.0	2020-03-31 22:17:42.020	debug	(29669) [DATA] <== Incoming data: Favorites
      denon.0	2020-03-31 22:17:42.019	debug	(29669) [DATA] <== Incoming data: NSE1
      denon.0	2020-03-31 22:17:41.974	debug	(29669) [DATA] <== Incoming data: NSE0Network
      denon.0	2020-03-31 22:17:41.954	debug	(29669) [INFO] ==> Message sent: NSE
      denon.0	2020-03-31 22:17:39.871	debug	(29669) [DATA] <== Incoming data: MVMAX 98
      denon.0	2020-03-31 22:17:39.848	debug	(29669) [DATA] <== Incoming data: MV38
      denon.0	2020-03-31 22:17:39.833	debug	(29669) [INFO] ==> Message sent: MV?
      denon.0	2020-03-31 22:17:39.833	debug	(29669) [COMMAND] State Change - ID: settings.expertCommand; State: MV?
      denon.0	2020-03-31 22:17:33.298	debug	(29669) [INFO] ==> Message sent: BDSTATUS?
      denon.0	2020-03-31 22:17:33.297	debug	(29669) [INFO] ==> Message sent: SV01?
      denon.0	2020-03-31 22:17:33.295	debug	(29669) [INFO] ==> Message sent: SV?
      denon.0	2020-03-31 22:17:33.294	debug	(29669) [CONNECT] Connected --> Check receiver type
      denon.0	2020-03-31 22:17:33.294	info	(29669) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
      denon.0	2020-03-31 22:17:33.281	info	(29669) [CONNECT] Trying to connect to 10.0.1.38:23
      denon.0	2020-03-31 22:17:33.278	info	(29669) [START] Starting DENON AVR adapter
      denon.0	2020-03-31 22:17:33.243	info	(29669) starting. Version 1.7.2 in /opt/iobroker/node_modules/iobroker.denon, node: v10.17.0
      denon.0	2020-03-31 22:17:27.578	warn	(20447) Connection closed: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      denon.0	2020-03-31 22:17:27.498	info	(20447) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      denon.0	2020-03-31 22:17:27.497	info	(20447) terminating
      denon.0	2020-03-31 22:17:27.495	info	(20447) [END] Stopping Denon AVR adapter...
      denon.0	2020-03-31 22:17:27.494	info	(20447) Got terminate signal TERMINATE_YOURSELF
      denon.0	2020-03-31 22:12:46.796	info	(20447) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
      denon.0	2020-03-31 22:12:46.795	info	(20447) [CONNECT] Trying to connect to 10.0.1.38:23
      denon.0	2020-03-31 22:12:16.794	warn	(20447) AVR timed out due to no response
      denon.0	2020-03-31 22:11:41.792	info	(20447) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
      denon.0	2020-03-31 22:11:41.790	info	(20447) [CONNECT] Trying to connect to 10.0.1.38:23
      denon.0	2020-03-31 22:11:11.789	warn	(20447) AVR timed out due to no response
      denon.0	2020-03-31 22:10:36.788	info	(20447) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
      denon.0	2020-03-31 22:10:36.786	info	(20447) [CONNECT] Trying to connect to 10.0.1.38:23
      denon.0	2020-03-31 22:10:06.785	warn	(20447) AVR timed out due to no response
      denon.0	2020-03-31 22:09:31.783	info	(20447) [CONNECT] Adapter connected to DENON-AVR: 10.0.1.38:23
      denon.0	2020-03-31 22:09:31.782	info	(20447) [CONNECT] Trying to connect to 10.0.1.38:23
      ° Fixer ---> iob fix
      foxriver76F 2 Antworten Letzte Antwort
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @Negalein top, baue ich morgen um. Danke fürs testen
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          @Negalein Gerne mal 1.7.3 ausprobieren, sobald diese im Repo auftaucht.
          4 1 Antwort Letzte Antwort
            4 Offline
            4 Offline
            4-Real
            @foxriver76 Danke dir fürs schnelle Handeln! werde auch mal mit testen und dann berichten. Sieht soweit ganz gut aus, das im Standby keine Timeouts entstehen.
            Werde mal am ende der Woche berichten! :-)
            Danke!!
            • foxriver76F Offline
              foxriver76F Offline
              foxriver76
              Ups.. bitte 1.7.4 nehmen @Negalein @4-Real, habe da (in 1.7.3) in geistiger Umnachtung über das neue Kommando den falschen Receiver-Typen zugeordnet.
                4 Offline
                4 Offline
                4-Real
                @foxriver76 Jau hast recht :D
                Hatte komischerweise 8 Zonen :D aber alles gut, passiert mal, danke dir erstmal das du so schnell reagierst!
                Wieder nur 2 Zonen, wie sonst auch! Danke dir! Siehst soweit alles gut aus, werde berichten!
                  steimi
                  Habe den Denon-Adapter auf die 1.7.6 (von der 1.7.5) aktualisiert. Leider funktioniert die Lautstärke-Regelung nicht mehr - wenn ich bei zoneMain das Volume ändere bleibt der Wert rot und wird nicht grün. Im Log kommt nachfolgende Meldung. Zurück auf Adapter-Version 1.7.5 ist wieder alles okay.
                  [COMMAND] volume is not a valid US state
                  • c_hoch_bC Offline
                    c_hoch_bC Offline
                    c_hoch_b
                    ich hatte nach dem Update auf 1.7.5 und 1.7.6 die hier schon genannten Fehler (AVR timed out due to response) in folge keine Steuerung möglich.
                    Nach dem Downgrade auf 1.7.4 ist wieder alles schick. Vorher hatte ich auch keine dieser Probleme.
                    K.a. obs ne rolle Spielt, ich habe nen Marantz mit akt. FW. Dürfte aber nicht, ist ja die selbe SW.
                    Viele Grüße
                    Raspi 4, MacOS, CCU 2, Conbee2, HomeKit/ Yahka, Homebridge, Hue,-Bulb/Switches/Sensors, Harmony, Kodi, Tado, Osram, Xiaomi, HomeMatic, Marantz, VU+, Alexa (Echo‘s)
                    • S steimi
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      @steimi 1.7.7 bitte
                        @steimi 1.7.7 bitte
                        steimi
                        schrieb am zuletzt editiert von steimi
                        @foxriver76 gleich aus Github installiert, funktioniert wieder mit der Lautstärke. Danke
                        edit: ich habe einen Denon X4500
                        • BostilB Offline
                          BostilB Offline
                          Bostil
                          schrieb am zuletzt editiert von Bostil
                          Hi @foxriver76 - Danke für deine Hilfe per Mail. Leider bin ich immer noch unfähig, den Favoriten per Knopfdruck auf meinem Denon X-2000 abzurufen. Vielleicht bist du so nett und prüfst mal, ob ich es zumindest richtig umgesetzt habe:
                          • habe meinen Denon auf Internet-Radio / WDR4 umgestellt
                          • dann im iobroker-Admin unter Objekten "savePreset" auf "1" editiert
                          • über eine material design Schaltfläche schreibe ich in "loadPreset" eine 1, aber leider reagiert der Receiver darauf nicht
                          • Favorite Station 1 im Denon 1 ist ebenfalls der Sender "WDR4" (screen 2)
                          Vielen DANK dir - trotz meiner Probleme: Ein toller Adapter!!!
                          P.S: Bei den OnlinePresets habe ich nichts angepasst, hier erscheinen aber auch keine realen Einträge, sondern nur Platzhalter:
                          • BostilB Bostil
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            @Bostil Glaube vor dem Laden muss manuell selectInput korrekt gesetzt werden, also z. B. auf IRADIO. Unter info.onlinePresets kann man auch sehen, ob die Zuordnung mittels savePreset funtkioniert hat.
                            • BostilB Offline
                              BostilB Offline
                              Bostil
                              Danke dir @foxriver76
                              Es will anscheinend nicht so recht. Habe Sender eingestellt, SourceInput steht auch auf "IRadio", schreibe in "SavePreset" die 1, aber leider tut sich an den OnlinePresets nichts. Aber dann ist es leider so, und hier würde ich ungerne deine weiteren Ressourcen beanspruchen ...
                              • BostilB Bostil
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                @Bostil Aber es ist schon Internet Radio, was diese Favoriten Station im Webinterface darstellen und nicht klassischer Tuner? Dafür gäbe es potentiell extra Presets.
                                  @foxriver76 Laut Screenshot ist der Eingang "Network"
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    @Homoran Wo? Bin evtl blind..
                                      gaaaanz oben
                                        gaaaanz oben
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        @Homoran Ach auf dem von der Weboberfläche.. Dann probier mal selectInput auf Net zu setzen. Bei mir ging es mit IRADIO, evtl gibts das beim X2000 nicht? Finde leider sehr wenig zu dem Modell
                                        BostilB 1 Antwort Letzte Antwort
                                          BostilB Offline
                                          BostilB Offline
                                          Bostil
                                          @foxriver76 War wirklich der IRadio-Tuner also digital und nicht FM. Probiere nachher weiter und Berichte wieder.
                                          Danke euch.
