  4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
vodafone speedtest
208 Beiträge 43 Kommentatoren 52.4k Aufrufe 33 Beobachtet
  • GlasfaserG Glasfaser
    @peterbaumert
    Test :
    Instanz wechselt rot gelb.
    hier der Debug log ( Adapter nach dem Debug Log gestoppt )
    host.iobrokerv4	2020-04-20 19:32:14.167	info	Do not restart adapter system.adapter.vodafone-speedtest.0 because disabled or deleted
    host.iobrokerv4	2020-04-20 19:32:14.166	error	instance system.adapter.vodafone-speedtest.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    vodafone-speedtest.0	2020-04-20 19:32:13.626	warn	(7868) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    vodafone-speedtest.0	2020-04-20 19:32:13.547	error	(7868) adapter disabled
    host.iobrokerv4	2020-04-20 19:31:52.621	info	"system.adapter.vodafone-speedtest.0" disabled
    web.0	2020-04-20 19:31:51.559	info	(507) ==>Connected system.user.admin from ::ffff:192.168.178.28
    host.iobrokerv4	2020-04-20 19:31:41.657	info	Restart adapter system.adapter.vodafone-speedtest.0 because enabled
    host.iobrokerv4	2020-04-20 19:31:41.653	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
    host.iobrokerv4	2020-04-20 19:31:41.652	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
    web.0	2020-04-20 19:31:41.321	info	(507) <==Disconnect system.user.admin from ::ffff:192.168.178.28 vis.0
    vodafone-speedtest.0	2020-04-20 19:31:34.819	debug	(7359) interval: #2 @Mon Apr 20 2020 19:31:34 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:34.066	debug	(7359) interval: #3 @Mon Apr 20 2020 19:31:34 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:33.314	debug	(7359) interval: #4 @Mon Apr 20 2020 19:31:33 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:32.560	debug	(7359) interval: #5 @Mon Apr 20 2020 19:31:32 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:31.808	debug	(7359) interval: #6 @Mon Apr 20 2020 19:31:31 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:31.057	debug	(7359) interval: #7 @Mon Apr 20 2020 19:31:31 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:30.305	debug	(7359) interval: #8 @Mon Apr 20 2020 19:31:30 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:29.554	debug	(7359) interval: #9 @Mon Apr 20 2020 19:31:29 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:28.805	debug	(7359) interval: #10 @Mon Apr 20 2020 19:31:28 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:28.054	debug	(7359) interval: #11 @Mon Apr 20 2020 19:31:28 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:27.304	debug	(7359) interval: #12 @Mon Apr 20 2020 19:31:27 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:26.555	debug	(7359) interval: #13 @Mon Apr 20 2020 19:31:26 GMT+0200 (GMT+02:00)
    vodafone-speedtest.0	2020-04-20 19:31:21.833	debug	(7359) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"
    vodafone-speedtest.0	2020-04-20 19:31:21.832	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.832	debug	(7359) Create_state called for : upstreamBooked with value : 50
    vodafone-speedtest.0	2020-04-20 19:31:21.831	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.831	debug	(7359) Create_state called for : downstreamBooked with value : 1000
    vodafone-speedtest.0	2020-04-20 19:31:21.830	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.830	debug	(7359) Create_state called for : upstreamSpeed with value : 54784
    vodafone-speedtest.0	2020-04-20 19:31:21.829	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.828	debug	(7359) Create_state called for : downstreamSpeed with value : 1095680
    vodafone-speedtest.0	2020-04-20 19:31:21.828	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.827	debug	(7359) Create_state called for : ipCountry with value : DE
    vodafone-speedtest.0	2020-04-20 19:31:21.827	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.826	debug	(7359) Create_state called for : ip with value : xxxxxxxxxxxxxxxxx
    vodafone-speedtest.0	2020-04-20 19:31:21.826	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.825	debug	(7359) Create_state called for : isp with value : Vodafone GmbH
    vodafone-speedtest.0	2020-04-20 19:31:21.825	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.824	debug	(7359) Create_state called for : isCustomer with value : true
    vodafone-speedtest.0	2020-04-20 19:31:21.824	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.823	debug	(7359) Create_state called for : modem.text with value : AVM
    vodafone-speedtest.0	2020-04-20 19:31:21.823	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.822	debug	(7359) Create_state called for : modem.name with value : AVM Fritz!Box 6591
    vodafone-speedtest.0	2020-04-20 19:31:21.822	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.821	debug	(7359) Create_state called for : modem.code with value : 6591
    vodafone-speedtest.0	2020-04-20 19:31:21.820	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.820	debug	(7359) Create_state called for : modem.vendor with value : AVM
    vodafone-speedtest.0	2020-04-20 19:31:21.818	debug	(7359) Write value : false
    vodafone-speedtest.0	2020-04-20 19:31:21.817	debug	(7359) Create_state called for : modem with value : undefined
    vodafone-speedtest.0	2020-04-20 19:31:20.727	info	(7359) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v10.20.1
    vodafone-speedtest.0	2020-04-20 19:31:19.830	debug	(7359) statesDB connected
    vodafone-speedtest.0	2020-04-20 19:31:19.829	debug	(7359) States connected to redis: 127.0.0.1:9000
    vodafone-speedtest.0	2020-04-20 19:31:19.805	debug	(7359) States create System PubSub Client
    vodafone-speedtest.0	2020-04-20 19:31:19.803	debug	(7359) States create User PubSub Client
    vodafone-speedtest.0	2020-04-20 19:31:19.791	debug	(7359) Redis States: Use Redis connection: 127.0.0.1:9000
    vodafone-speedtest.0	2020-04-20 19:31:19.789	debug	(7359) objectDB connected
    vodafone-speedtest.0	2020-04-20 19:31:19.782	debug	(7359) Objects connected to redis: 127.0.0.1:9001
    vodafone-speedtest.0	2020-04-20 19:31:19.743	debug	(7359) Objects client initialize lua scripts
    vodafone-speedtest.0	2020-04-20 19:31:19.742	debug	(7359) Objects create User PubSub Client
    vodafone-speedtest.0	2020-04-20 19:31:19.741	debug	(7359) Objects create System PubSub Client
    vodafone-speedtest.0	2020-04-20 19:31:19.670	debug	(7359) Objects client ready ... initialize now
    vodafone-speedtest.0	2020-04-20 19:31:19.047	debug	(7359) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iobrokerv4	2020-04-20 19:31:18.198	info	instance system.adapter.vodafone-speedtest.0 started with pid 7359
    host.iobrokerv4	2020-04-20 19:31:18.148	info	"system.adapter.vodafone-speedtest.0" enabled
    peterbaumertP Offline
    peterbaumert
    @Glasfaser Hey, was hast du denn für ein Betriebssystem? Hast du curl installiert? Ich habe das vergessen zu erwähnen, dass das Voraussetzung ist.
    GlasfaserG AlCalzoneA 2 Antworten Letzte Antwort
    • peterbaumertP peterbaumert
      GlasfaserG Offline
      GlasfaserG Offline
      @peterbaumert
      Siehst du nicht mein Signatur ?
      Dort steht alles drin !??
      Kann eigentlich alles ausführen ...
      peterbaumertP 1 Antwort Letzte Antwort
        Aktuelle Test Version 0.0.2
        Veröffentlichungsdatum 20.04.2020
        Github Link https://github.com/peterbaumert/ioBroker.vodafone-speedtest
        0.0.2 (2020-04-19)
        Added actual settings in Admin interface
        first version ready for testing
        Hi Zusammen,
        ich habe mal einen speedtest Adapter geschrieben, der genau wie https://speedtest.vodafone.de funktioniert, da bei mir zumindest die Werte von Speedtest.net sehr abweichen zu denen des Vodafone Speedtests. Für Kunden von Vodafone kann dies also durchaus interessant sein.
        Bin über jede Anregung dankbar und steinigt mich bitte nicht wenn ich mal nicht antworte :)
        Die Einstellung der Lokalen Adresse hat noch keine Funktion, das kommt später noch.
        Viele Grüße
        Pete
        arteckA Offline
        arteckA Offline
        arteck
        @peterbaumert laufen tut der bleibt aber gelb..
        sind das sekunden .. dann würde ich es aber dazuschreiben
        wasndas
          @peterbaumert
          peterbaumert
          schrieb am zuletzt editiert von peterbaumert
          @Glasfaser Hey, nein ich sehe keine Signatur von dir. Könntest du den log mal auf silly stellen und schicken?
          @arteck Das ist das Intervall in Minuten wann der Speedtest immer ausgeführt wird. Schreibe ich dazu stimmt. Das mit dem Speicher schaue ich mir mal an danke. Glaube das mit dem "Verbunden mit..." hatte ich noch nicht fertig implementiert. mache ich auch noch.
          Danke für das feedback.
          Pete
            Pete
            GlasfaserG Offline
            GlasfaserG Offline
            @peterbaumert sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
            Synology 918+ 16GB - ioBroker in Docker v4.1.0
            Kenne kein silly !
            Der Debug Log ist oben im Spoiler ....
            Aber hier nochmal :
              0.0.2 (2020-04-19)
              Hi Zusammen,
              Viele Grüße
              Pete
              Dr. BakteriusD Offline
              Dr. Bakterius
              schrieb am zuletzt editiert von Dr. Bakterius
              @peterbaumert Danke für deinen Adapter. Ich bin zwar kein vodafone-Kunde, habe den Adapter trotzdem getestet und mit den Werten im Browser verglichen.
              Meist wird bei mir die Instanz auch gelb angezeigt. Einmal war sie bis zum nächsten Test grün, dann wieder gelb. Im Log dazu aber keine Auffälligkeiten (auf debug gestellt).
              Ich habe eine 250/50 Mbit/s Verbindung und im Browser wird mir 162-268/32-54 Mbit/s (mehrere Test hintereinander) vom Vodafon-Test getestet. Speedtest.net misst zum Vodafon-Server in Frankfurt so zwischen 85-124/23-41 Mbit/s. Zu Servern in näheren Umfeld entsprechen die Werte meinem Produkt - also 250/50 Mbit/s. Der Adapter misst immer so um die 260-265/55-68 Mbit/s.
              Der Adapter misst also ziemlich optimistisch. 😏
              • peterbaumertP Offline
                peterbaumert
                Danke @Dr-Bakterius für das Feedback,
                ja der Adapter und auch Vodafone speedtest Seite haben sehr interessante Messverhalten ;)
                Es werden x Werte genommen und dann an Vodafone Server gesendet, welcher dir dann deinen Speed ausrechnet und zurückschickt. Ich habe extra nicht selbst ausgerechnet, weil ich das Messverfahren so nah wie möglich am original lassen wollte.
                Das mit dem Geld und Grün kommt in einer neueren Version dann :)
                Pete
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  Ohne genauer hingeschaut zu haben, was du damit treibst:
                  Es gibt aber genügend Möglichkeiten in Node.js, Web-Requests zu machen (ich bevorzuge https://www.npmjs.com/package/axios), dass man dafür nicht auf Bordmittel ausweichen muss, die nur auf manchen Systemen zur Verfügung stehen.
                    peterbaumert
                    Hi @AlCalzone ja da hast du recht, leider funktioniert das dort aber mit dem Upload nicht. Da Vodafone bei ihrer Seite zwei mal "Content-Length" zurückliefert und node direkt ein error schmeißt. Egal ob axios,https oder sonstige "Board-Mittel" ich hatte das erst so versucht, da ich eigentlich auch keine sonder-locken will, leider ist dies hier aber nicht möglich :(
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @peterbaumert Alles klar. Dann trag curl am besten in io-package.json in den osDependencies ein, so wie hier:
                      https://github.com/ioBroker/ioBroker.zwave/blob/e3056eeb2f95524256dee73b7cf17b5402196c7d/io-package.json#L99-L101
                      Da der Adapter wohl auf Windows nicht läuft, solltest du ihn wohl auch auf Linux und ggf. OSX beschränken:
                      https://github.com/iobroker-community-adapters/ioBroker.rpi2/blob/f48dd198c0710560a255184b6319bee29c5c7bcb/io-package.json#L130-L132
                      OSX heißt "darwin", dafür musst du entsprechend auch die osDependencies angeben.
                        peterbaumert
                        Ah okay, danke für die Tips @AlCalzone, aber auf Windows gibt es auch curl und sollte laufen. Zumindest bei den Travis builds kamen keine Fehler, getestet hab ich es natürlich nicht :D
                        • J.A.R.V.I.S.J Offline
                          J.A.R.V.I.S.
                          schrieb am zuletzt editiert von J.A.R.V.I.S.
                          Windows 10
                          Node 10
                          js-controller 2.28
                          Bei mir funktioniert der Test unter Windows obgleich mit Curl oder ohne auch nicht.
                          Mit Curl:
                          2020-04-21 17:13:48.230 - info: vodafone-speedtest.0 (12840) starting. Version 0.0.2 in E:/Program Files/iobroker/SmartHome/node_modules/iobroker.vodafone-speedtest, node: v10.16.3
                          2020-04-21 17:13:48.746 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem with value : undefined
                          2020-04-21 17:13:48.747 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.753 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.vendor with value :
                          2020-04-21 17:13:48.753 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.754 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.code with value : null
                          2020-04-21 17:13:48.754 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.755 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.name with value : null
                          2020-04-21 17:13:48.755 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.756 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.text with value : null
                          2020-04-21 17:13:48.756 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.757 - debug: vodafone-speedtest.0 (12840) Create_state called for : isCustomer with value : false
                          2020-04-21 17:13:48.757 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.758 - debug: vodafone-speedtest.0 (12840) Create_state called for : isp with value : Vodafone GmbH
                          2020-04-21 17:13:48.759 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.759 - debug: vodafone-speedtest.0 (12840) Create_state called for : ip with value : xxx.xxx.xxx.xxx
                          2020-04-21 17:13:48.760 - debug: vodafone-speedtest.0 (12840) Create_state called for : ipCountry with value : DE
                          2020-04-21 17:13:48.760 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.761 - debug: vodafone-speedtest.0 (12840) Create_state called for : downstreamSpeed with value : 0
                          2020-04-21 17:13:48.761 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.762 - debug: vodafone-speedtest.0 (12840) Create_state called for : upstreamSpeed with value : 0
                          2020-04-21 17:13:48.762 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.763 - debug: vodafone-speedtest.0 (12840) Create_state called for : downstreamBooked with value : null
                          2020-04-21 17:13:48.763 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) Create_state called for : upstreamBooked with value : null
                          2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) Write value : false
                          2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"xxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"xxx.xxx.xxx.xxx","isCustomer":false,"vendor":"","modemType":null,"plannedImprovement":null,"isO2Customer":false,"swapScenario":null,"swapLink":null}
                          2020-04-21 17:13:54.010 - debug: vodafone-speedtest.0 (12840) interval: #13 @Tue Apr 21 2020 17:13:54 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:54.758 - debug: vodafone-speedtest.0 (12840) interval: #12 @Tue Apr 21 2020 17:13:54 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:55.508 - debug: vodafone-speedtest.0 (12840) interval: #11 @Tue Apr 21 2020 17:13:55 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:56.259 - debug: vodafone-speedtest.0 (12840) interval: #10 @Tue Apr 21 2020 17:13:56 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:57.009 - debug: vodafone-speedtest.0 (12840) interval: #9 @Tue Apr 21 2020 17:13:57 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:57.760 - debug: vodafone-speedtest.0 (12840) interval: #8 @Tue Apr 21 2020 17:13:57 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:58.508 - debug: vodafone-speedtest.0 (12840) interval: #7 @Tue Apr 21 2020 17:13:58 GMT+0200 (GMT+02:00)
                          2020-04-21 17:13:59.259 - debug: vodafone-speedtest.0 (12840) interval: #6 @Tue Apr 21 2020 17:13:59 GMT+0200 (GMT+02:00)
                          2020-04-21 17:14:00.009 - debug: vodafone-speedtest.0 (12840) interval: #5 @Tue Apr 21 2020 17:14:00 GMT+0200 (GMT+02:00)
                          2020-04-21 17:14:00.760 - debug: vodafone-speedtest.0 (12840) interval: #4 @Tue Apr 21 2020 17:14:00 GMT+0200 (GMT+02:00)
                          2020-04-21 17:14:01.510 - debug: vodafone-speedtest.0 (12840) interval: #3 @Tue Apr 21 2020 17:14:01 GMT+0200 (GMT+02:00)
                          2020-04-21 17:14:02.261 - debug: vodafone-speedtest.0 (12840) interval: #2 @Tue Apr 21 2020 17:14:02 GMT+0200 (GMT+02:00)
                          2020-04-21 17:14:03.011 - debug: vodafone-speedtest.0 (12840) interval: #1 @Tue Apr 21 2020 17:14:03 GMT+0200 (GMT+02:00)
                          2020-04-21 17:14:03.257 - error: vodafone-speedtest.0 (12840) uncaught exception: Curl handle is closed.
                          2020-04-21 17:14:03.257 - error: vodafone-speedtest.0 (12840) Error: Curl handle is closed.
                          at Curl.close (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\node_modules\node-libcurl\dist\Curl.js:284:21)
                          at Timeout.stopDownloadTest (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\main.js:475:29)
                          at ontimeout (timers.js:436:11)
                          at tryOnTimeout (timers.js:300:5)
                          at listOnTimeout (timers.js:263:5)
                          at Timer.processTimers (timers.js:223:10)
                          2020-04-21 17:14:03.257 - info: vodafone-speedtest.0 (12840) cleaned everything up...
                          2020-04-21 17:14:03.259 - info: vodafone-speedtest.0 (12840) terminating
                          2020-04-21 17:14:03.259 - info: vodafone-speedtest.0 (12840) Terminated (NO_ERROR): Without reason
                          2020-04-21 17:14:03.792 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: Error: Curl handle is closed.
                          2020-04-21 17:14:03.793 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Curl.close (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\node_modules\node-libcurl\dist\Curl.js:284:21)
                          2020-04-21 17:14:03.793 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Timeout.stopDownloadTest (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\main.js:475:29)
                          2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at ontimeout (timers.js:436:11)
                          2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
                          2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at listOnTimeout (timers.js:263:5)
                          2020-04-21 17:14:03.795 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
                          2020-04-21 17:14:03.795 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 terminated with code 0 (NO_ERROR)
                          Ohne Curl:
                          2020-04-21 17:10:43.716 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 started with pid 16092
                          2020-04-21 17:10:44.198 - debug: vodafone-speedtest.0 (16092) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-04-21 17:10:44.212 - debug: vodafone-speedtest.0 (16092) Objects client ready ... initialize now
                          2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects create System PubSub Client
                          2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects create User PubSub Client
                          2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects client initialize lua scripts
                          2020-04-21 17:10:44.219 - debug: vodafone-speedtest.0 (16092) Objects connected to redis: 127.0.0.1:9001
                          2020-04-21 17:10:44.222 - debug: vodafone-speedtest.0 (16092) objectDB connected
                          2020-04-21 17:10:44.223 - debug: vodafone-speedtest.0 (16092) Redis States: Use Redis connection: 127.0.0.1:6379
                          2020-04-21 17:10:44.227 - debug: vodafone-speedtest.0 (16092) States create User PubSub Client
                          2020-04-21 17:10:44.230 - debug: vodafone-speedtest.0 (16092) States create System PubSub Client
                          2020-04-21 17:10:44.232 - debug: vodafone-speedtest.0 (16092) States connected to redis: 127.0.0.1:6379
                          2020-04-21 17:10:44.233 - debug: vodafone-speedtest.0 (16092) statesDB connected
                          2020-04-21 17:10:44.256 - info: vodafone-speedtest.0 (16092) starting. Version 0.0.2 in E:/Program Files/iobroker/SmartHome/node_modules/iobroker.vodafone-speedtest, node: v10.16.3
                          2020-04-21 17:10:44.783 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem with value : undefined
                          2020-04-21 17:10:44.784 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.vendor with value :
                          2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.code with value : null
                          2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.name with value : null
                          2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.text with value : null
                          2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Create_state called for : isCustomer with value : false
                          2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Create_state called for : isp with value : Vodafone GmbH
                          2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Create_state called for : ip with value : xxx.xxx.xxx.xxx
                          2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Create_state called for : ipCountry with value : DE
                          2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Create_state called for : downstreamSpeed with value : 0
                          2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Create_state called for : upstreamSpeed with value : 0
                          2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Create_state called for : downstreamBooked with value : null
                          2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Write value : false
                          2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Create_state called for : upstreamBooked with value : null
                          2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"xxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"xxx.xxx.xxx.xxx","isCustomer":false,"vendor":"","modemType":null,"plannedImprovement":null,"isO2Customer":false,"swapScenario":null,"swapLink":null}
                          2020-04-21 17:10:50.036 - debug: vodafone-speedtest.0 (16092) interval: #13 @Tue Apr 21 2020 17:10:50 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:50.788 - debug: vodafone-speedtest.0 (16092) interval: #12 @Tue Apr 21 2020 17:10:50 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:51.536 - debug: vodafone-speedtest.0 (16092) interval: #11 @Tue Apr 21 2020 17:10:51 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:52.286 - debug: vodafone-speedtest.0 (16092) interval: #10 @Tue Apr 21 2020 17:10:52 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:53.036 - debug: vodafone-speedtest.0 (16092) interval: #9 @Tue Apr 21 2020 17:10:53 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:53.786 - debug: vodafone-speedtest.0 (16092) interval: #8 @Tue Apr 21 2020 17:10:53 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:54.538 - debug: vodafone-speedtest.0 (16092) interval: #7 @Tue Apr 21 2020 17:10:54 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:55.287 - debug: vodafone-speedtest.0 (16092) interval: #6 @Tue Apr 21 2020 17:10:55 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:56.036 - debug: vodafone-speedtest.0 (16092) interval: #5 @Tue Apr 21 2020 17:10:56 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:56.786 - debug: vodafone-speedtest.0 (16092) interval: #4 @Tue Apr 21 2020 17:10:56 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:57.536 - debug: vodafone-speedtest.0 (16092) interval: #3 @Tue Apr 21 2020 17:10:57 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:58.286 - debug: vodafone-speedtest.0 (16092) interval: #2 @Tue Apr 21 2020 17:10:58 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:59.036 - debug: vodafone-speedtest.0 (16092) interval: #1 @Tue Apr 21 2020 17:10:59 GMT+0200 (GMT+02:00)
                          2020-04-21 17:10:59.287 - warn: vodafone-speedtest.0 (16092) startDownload abort: undefined
                          2020-04-21 17:10:59.288 - warn: vodafone-speedtest.0 (16092) startDownload abort: undefined
                          2020-04-21 17:10:59.379 - debug: vodafone-speedtest.0 (16092) result:{"type":"download","value":940000}
                          2020-04-21 17:10:59.786 - debug: vodafone-speedtest.0 (16092) interval: #0 @Tue Apr 21 2020 17:10:59 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:02.379 - debug: vodafone-speedtest.0 (16092) interval: #16 @Tue Apr 21 2020 17:11:02 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:03.129 - debug: vodafone-speedtest.0 (16092) interval: #15 @Tue Apr 21 2020 17:11:03 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:03.878 - debug: vodafone-speedtest.0 (16092) interval: #14 @Tue Apr 21 2020 17:11:03 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:04.628 - debug: vodafone-speedtest.0 (16092) interval: #13 @Tue Apr 21 2020 17:11:04 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:05.378 - debug: vodafone-speedtest.0 (16092) interval: #12 @Tue Apr 21 2020 17:11:05 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:06.130 - debug: vodafone-speedtest.0 (16092) interval: #11 @Tue Apr 21 2020 17:11:06 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:06.880 - debug: vodafone-speedtest.0 (16092) interval: #10 @Tue Apr 21 2020 17:11:06 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:07.630 - debug: vodafone-speedtest.0 (16092) interval: #9 @Tue Apr 21 2020 17:11:07 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:08.379 - debug: vodafone-speedtest.0 (16092) interval: #8 @Tue Apr 21 2020 17:11:08 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:09.130 - debug: vodafone-speedtest.0 (16092) interval: #7 @Tue Apr 21 2020 17:11:09 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:09.879 - debug: vodafone-speedtest.0 (16092) interval: #6 @Tue Apr 21 2020 17:11:09 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:10.630 - debug: vodafone-speedtest.0 (16092) interval: #5 @Tue Apr 21 2020 17:11:10 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:11.380 - debug: vodafone-speedtest.0 (16092) interval: #4 @Tue Apr 21 2020 17:11:11 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:12.130 - debug: vodafone-speedtest.0 (16092) interval: #3 @Tue Apr 21 2020 17:11:12 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:12.880 - debug: vodafone-speedtest.0 (16092) interval: #2 @Tue Apr 21 2020 17:11:12 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:13.631 - debug: vodafone-speedtest.0 (16092) interval: #1 @Tue Apr 21 2020 17:11:13 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:13.717 - error: vodafone-speedtest.0 (16092) result: Unknown Error 500
                          2020-04-21 17:11:14.381 - debug: vodafone-speedtest.0 (16092) interval: #0 @Tue Apr 21 2020 17:11:14 GMT+0200 (GMT+02:00)
                          2020-04-21 17:11:26.626 - info: host.DESKTOP-GG5M5BF stopInstance system.adapter.vodafone-speedtest.0 (force=false, process=true)
                          2020-04-21 17:11:26.627 - info: vodafone-speedtest.0 (16092) Got terminate signal TERMINATE_YOURSELF
                          2020-04-21 17:11:26.627 - info: vodafone-speedtest.0 (16092) cleaned everything up...
                          2020-04-21 17:11:26.628 - info: vodafone-speedtest.0 (16092) terminating
                          2020-04-21 17:11:26.628 - info: vodafone-speedtest.0 (16092) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2020-04-21 17:11:26.627 - info: host.DESKTOP-GG5M5BF stopInstance system.adapter.vodafone-speedtest.0 send kill signal
                          2020-04-21 17:11:27.190 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                            peterbaumert
                            @J-A-R-V-I-S
                            Die Einstellung "Use Curl" ist nur dafür da ob er auch für den Download curl nutzen soll, das muss ich noch besser beschreieben. Es geht darum ob du Curl installiert hast. Der Download ohne den Curl haken sieht gut aus und du scheinst 940mbit hinbekommen zu haben :)
                            Hier https://curl.haxx.se/windows/ solltest du curl installieren können, oder wenn du den Windows Package Manager Chocolatey nutz: https://chocolatey.org/packages/curl
                            Pete
                            J.A.R.V.I.S.J 1 Antwort Letzte Antwort
                              @J-A-R-V-I-S
                              Pete
                              J.A.R.V.I.S.
                              @peterbaumert Curl ist schon von Windows vorhanden, oder benötigt man eine andere Version?
                                peterbaumert
                                @J-A-R-V-I-S dann hab ich nichts gesagt :D und teste es die tage selbst mal um genau zu sehen was das problem ist.
                                Danke für deine Rückmeldungen.
                                Pete
                                • J.A.R.V.I.S.J J.A.R.V.I.S.
                                  peterbaumert
                                  @J-A-R-V-I-S kannst du dir mal die aktuelle master ausm github installieren und testen ob es damit geht?
                                    J.A.R.V.I.S.
                                    @peterbaumert mit Curl funktioniert es jetzt, ohne auch, aber dann kommen immer noch die ganze Zeit die Warn-Meldungen.
                                    Und ich glaube der Test ist ein bisschen unrealistisch, der zeigt beim Download immer 940 an.
                                      peterbaumert
                                      @J-A-R-V-I-S ok das schonmal gut, was hast du denn für eine Leitung? Die meldungen nehm ich noch raus bzw ändere sie in silly
                                      J.A.R.V.I.S.J GlasfaserG 2 Antworten Letzte Antwort
                                        J.A.R.V.I.S.
                                        @peterbaumert 1Gbit Leitung, aber ich hatte bei anderen Tests noch nie konstant 940Mbit.
                                        ostseereiterO 1 Antwort Letzte Antwort
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @peterbaumert
                                          Passt auch nicht mehr .... neu von Git
                                          ohne "Use curl for download too"
                                          host.iobrokerv4	2020-04-23 15:49:10.198	info	"system.adapter.vodafone-speedtest.0" disabled
                                          vodafone-speedtest.0	2020-04-23 15:48:51.082	debug	(9795) interval: #0 @Thu Apr 23 2020 15:48:51 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:50.409	debug	(9795) result:{"type":"upload","value":51730}
                                          vodafone-speedtest.0	2020-04-23 15:48:50.408	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:50.407	debug	(9795) Create_state called for : Results.upload_Mb with value : 51.73
                                          vodafone-speedtest.0	2020-04-23 15:48:50.406	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:50.406	debug	(9795) Create_state called for : Results.upload_MB with value : 6.46625
                                          vodafone-speedtest.0	2020-04-23 15:48:50.405	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:50.404	debug	(9795) Create_state called for : Results.download_Mb with value : 940
                                          vodafone-speedtest.0	2020-04-23 15:48:50.404	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:50.403	debug	(9795) Create_state called for : Results.download_MB with value : 117.5
                                          vodafone-speedtest.0	2020-04-23 15:48:50.401	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:50.401	debug	(9795) Create_state called for : Results.Last_Run with value : Thu Apr 23 2020 15:48:50 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:50.332	debug	(9795) interval: #1 @Thu Apr 23 2020 15:48:50 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:49.582	debug	(9795) interval: #2 @Thu Apr 23 2020 15:48:49 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:48.832	debug	(9795) interval: #3 @Thu Apr 23 2020 15:48:48 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:48.082	debug	(9795) interval: #4 @Thu Apr 23 2020 15:48:48 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:47.332	debug	(9795) interval: #5 @Thu Apr 23 2020 15:48:47 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:46.581	debug	(9795) interval: #6 @Thu Apr 23 2020 15:48:46 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:45.832	debug	(9795) interval: #7 @Thu Apr 23 2020 15:48:45 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:45.081	debug	(9795) interval: #8 @Thu Apr 23 2020 15:48:45 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:44.330	debug	(9795) interval: #9 @Thu Apr 23 2020 15:48:44 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:43.580	debug	(9795) interval: #10 @Thu Apr 23 2020 15:48:43 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:42.820	debug	(9795) interval: #11 @Thu Apr 23 2020 15:48:42 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:42.070	debug	(9795) interval: #12 @Thu Apr 23 2020 15:48:42 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:41.316	debug	(9795) interval: #13 @Thu Apr 23 2020 15:48:41 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:40.565	debug	(9795) interval: #14 @Thu Apr 23 2020 15:48:40 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:39.815	debug	(9795) interval: #15 @Thu Apr 23 2020 15:48:39 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:39.069	debug	(9795) interval: #16 @Thu Apr 23 2020 15:48:39 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:34.086	debug	(9795) interval: #0 @Thu Apr 23 2020 15:48:34 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:33.604	debug	(9795) result:{"type":"download","value":940000}
                                          vodafone-speedtest.0	2020-04-23 15:48:33.524	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.523	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.522	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.521	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.520	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.519	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.518	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.517	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.516	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.515	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.513	warn	(9795) startDownload abort: undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:33.337	debug	(9795) interval: #1 @Thu Apr 23 2020 15:48:33 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:32.591	debug	(9795) interval: #2 @Thu Apr 23 2020 15:48:32 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:31.846	debug	(9795) interval: #3 @Thu Apr 23 2020 15:48:31 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:31.084	debug	(9795) interval: #4 @Thu Apr 23 2020 15:48:31 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:30.330	debug	(9795) interval: #5 @Thu Apr 23 2020 15:48:30 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:29.576	debug	(9795) interval: #6 @Thu Apr 23 2020 15:48:29 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:28.825	debug	(9795) interval: #7 @Thu Apr 23 2020 15:48:28 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:28.077	debug	(9795) interval: #8 @Thu Apr 23 2020 15:48:28 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:27.315	debug	(9795) interval: #9 @Thu Apr 23 2020 15:48:27 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:26.560	debug	(9795) interval: #10 @Thu Apr 23 2020 15:48:26 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:25.809	debug	(9795) interval: #11 @Thu Apr 23 2020 15:48:25 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:25.065	debug	(9795) interval: #12 @Thu Apr 23 2020 15:48:25 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:24.271	debug	(9795) interval: #13 @Thu Apr 23 2020 15:48:24 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:48:23.429	debug	(9795) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"
                                          vodafone-speedtest.0	2020-04-23 15:48:23.428	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.426	debug	(9795) Create_state called for : upstreamBooked with value : 50
                                          vodafone-speedtest.0	2020-04-23 15:48:23.425	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.424	debug	(9795) Create_state called for : downstreamBooked with value : 1000
                                          vodafone-speedtest.0	2020-04-23 15:48:23.424	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.423	debug	(9795) Create_state called for : upstreamSpeed with value : 54784
                                          vodafone-speedtest.0	2020-04-23 15:48:23.423	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.422	debug	(9795) Create_state called for : downstreamSpeed with value : 1095680
                                          vodafone-speedtest.0	2020-04-23 15:48:23.422	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.421	debug	(9795) Create_state called for : ipCountry with value : DE
                                          vodafone-speedtest.0	2020-04-23 15:48:23.420	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.420	debug	(9795) Create_state called for : ip with value : xxxxxxxxxxxxxxxxxxx
                                          vodafone-speedtest.0	2020-04-23 15:48:23.419	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.419	debug	(9795) Create_state called for : isp with value : Vodafone GmbH
                                          vodafone-speedtest.0	2020-04-23 15:48:23.418	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.418	debug	(9795) Create_state called for : isCustomer with value : true
                                          vodafone-speedtest.0	2020-04-23 15:48:23.417	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.417	debug	(9795) Create_state called for : modem.text with value : AVM
                                          vodafone-speedtest.0	2020-04-23 15:48:23.416	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.416	debug	(9795) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                                          vodafone-speedtest.0	2020-04-23 15:48:23.415	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.414	debug	(9795) Create_state called for : modem.code with value : 6591
                                          vodafone-speedtest.0	2020-04-23 15:48:23.414	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.413	debug	(9795) Create_state called for : modem.vendor with value : AVM
                                          vodafone-speedtest.0	2020-04-23 15:48:23.411	debug	(9795) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:48:23.410	debug	(9795) Create_state called for : modem with value : undefined
                                          vodafone-speedtest.0	2020-04-23 15:48:22.392	info	(9795) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                                          vodafone-speedtest.0	2020-04-23 15:48:21.674	debug	(9795) statesDB connected
                                          vodafone-speedtest.0	2020-04-23 15:48:21.673	debug	(9795) States connected to redis: 127.0.0.1:9000
                                          vodafone-speedtest.0	2020-04-23 15:48:21.654	debug	(9795) States create System PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:48:21.652	debug	(9795) States create User PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:48:21.640	debug	(9795) Redis States: Use Redis connection: 127.0.0.1:9000
                                          vodafone-speedtest.0	2020-04-23 15:48:21.638	debug	(9795) objectDB connected
                                          vodafone-speedtest.0	2020-04-23 15:48:21.633	debug	(9795) Objects connected to redis: 127.0.0.1:9001
                                          vodafone-speedtest.0	2020-04-23 15:48:21.591	debug	(9795) Objects client initialize lua scripts
                                          vodafone-speedtest.0	2020-04-23 15:48:21.587	debug	(9795) Objects create User PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:48:21.585	debug	(9795) Objects create System PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:48:21.581	debug	(9795) Objects client ready ... initialize now
                                          vodafone-speedtest.0	2020-04-23 15:48:21.528	debug	(9795) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.iobrokerv4	2020-04-23 15:48:20.916	info	instance system.adapter.vodafone-speedtest.0 started with pid 9795
                                          mit "Use curl for download too"
                                          host.iobrokerv4	2020-04-23 15:52:37.906	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
                                          host.iobrokerv4	2020-04-23 15:52:37.904	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
                                          vodafone-speedtest.0	2020-04-23 15:52:35.372	debug	(12159) interval: #2 @Thu Apr 23 2020 15:52:35 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:34.621	debug	(12159) interval: #3 @Thu Apr 23 2020 15:52:34 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:33.867	debug	(12159) interval: #4 @Thu Apr 23 2020 15:52:33 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:33.117	debug	(12159) interval: #5 @Thu Apr 23 2020 15:52:33 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:32.366	debug	(12159) interval: #6 @Thu Apr 23 2020 15:52:32 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:31.618	debug	(12159) interval: #7 @Thu Apr 23 2020 15:52:31 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:30.857	debug	(12159) interval: #8 @Thu Apr 23 2020 15:52:30 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:30.109	debug	(12159) interval: #9 @Thu Apr 23 2020 15:52:30 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:29.346	debug	(12159) interval: #10 @Thu Apr 23 2020 15:52:29 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:28.596	debug	(12159) interval: #11 @Thu Apr 23 2020 15:52:28 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:27.846	debug	(12159) interval: #12 @Thu Apr 23 2020 15:52:27 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:27.099	debug	(12159) interval: #13 @Thu Apr 23 2020 15:52:27 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:52:25.367	debug	(12159) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":
                                          vodafone-speedtest.0	2020-04-23 15:52:25.365	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.365	debug	(12159) Create_state called for : upstreamBooked with value : 50
                                          vodafone-speedtest.0	2020-04-23 15:52:25.364	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.364	debug	(12159) Create_state called for : downstreamBooked with value : 1000
                                          vodafone-speedtest.0	2020-04-23 15:52:25.363	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.363	debug	(12159) Create_state called for : upstreamSpeed with value : 54784
                                          vodafone-speedtest.0	2020-04-23 15:52:25.362	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.361	debug	(12159) Create_state called for : downstreamSpeed with value : 1095680
                                          vodafone-speedtest.0	2020-04-23 15:52:25.360	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.360	debug	(12159) Create_state called for : ipCountry with value : DE
                                          vodafone-speedtest.0	2020-04-23 15:52:25.359	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.358	debug	(12159) Create_state called for : ip with value : xxxxxxxxxxxxxxxxxxx
                                          vodafone-speedtest.0	2020-04-23 15:52:25.357	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.357	debug	(12159) Create_state called for : isp with value : Vodafone GmbH
                                          vodafone-speedtest.0	2020-04-23 15:52:25.356	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.355	debug	(12159) Create_state called for : isCustomer with value : true
                                          vodafone-speedtest.0	2020-04-23 15:52:25.354	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.353	debug	(12159) Create_state called for : modem.text with value : AVM
                                          vodafone-speedtest.0	2020-04-23 15:52:25.352	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.351	debug	(12159) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                                          vodafone-speedtest.0	2020-04-23 15:52:25.346	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.345	debug	(12159) Create_state called for : modem.code with value : 6591
                                          vodafone-speedtest.0	2020-04-23 15:52:25.344	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.344	debug	(12159) Create_state called for : modem.vendor with value : AVM
                                          vodafone-speedtest.0	2020-04-23 15:52:25.341	debug	(12159) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:52:25.340	debug	(12159) Create_state called for : modem with value : undefined
                                          vodafone-speedtest.0	2020-04-23 15:52:24.278	info	(12159) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                                          vodafone-speedtest.0	2020-04-23 15:52:23.522	debug	(12159) statesDB connected
                                          vodafone-speedtest.0	2020-04-23 15:52:23.521	debug	(12159) States connected to redis: 127.0.0.1:9000
                                          vodafone-speedtest.0	2020-04-23 15:52:23.500	debug	(12159) States create System PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:52:23.498	debug	(12159) States create User PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:52:23.486	debug	(12159) Redis States: Use Redis connection: 127.0.0.1:9000
                                          vodafone-speedtest.0	2020-04-23 15:52:23.484	debug	(12159) objectDB connected
                                          vodafone-speedtest.0	2020-04-23 15:52:23.479	debug	(12159) Objects connected to redis: 127.0.0.1:9001
                                          vodafone-speedtest.0	2020-04-23 15:52:23.443	debug	(12159) Objects client initialize lua scripts
                                          vodafone-speedtest.0	2020-04-23 15:52:23.442	debug	(12159) Objects create User PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:52:23.441	debug	(12159) Objects create System PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:52:23.438	debug	(12159) Objects client ready ... initialize now
                                          vodafone-speedtest.0	2020-04-23 15:52:23.392	debug	(12159) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.iobrokerv4	2020-04-23 15:52:22.618	info	instance system.adapter.vodafone-speedtest.0 started with pid 12159
                                          host.iobrokerv4	2020-04-23 15:51:52.536	info	Restart adapter system.adapter.vodafone-speedtest.0 because enabled
                                          host.iobrokerv4	2020-04-23 15:51:52.536	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
                                          host.iobrokerv4	2020-04-23 15:51:52.535	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
                                          vodafone-speedtest.0	2020-04-23 15:51:50.104	debug	(11688) interval: #3 @Thu Apr 23 2020 15:51:50 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:49.361	debug	(11688) interval: #4 @Thu Apr 23 2020 15:51:49 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:48.269	debug	(11688) interval: #5 @Thu Apr 23 2020 15:51:48 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:47.516	debug	(11688) interval: #6 @Thu Apr 23 2020 15:51:47 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:46.764	debug	(11688) interval: #7 @Thu Apr 23 2020 15:51:46 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:46.015	debug	(11688) interval: #8 @Thu Apr 23 2020 15:51:46 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:45.263	debug	(11688) interval: #9 @Thu Apr 23 2020 15:51:45 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:44.510	debug	(11688) interval: #10 @Thu Apr 23 2020 15:51:44 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:43.761	debug	(11688) interval: #11 @Thu Apr 23 2020 15:51:43 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:43.009	debug	(11688) interval: #12 @Thu Apr 23 2020 15:51:43 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:42.262	debug	(11688) interval: #13 @Thu Apr 23 2020 15:51:42 GMT+0200 (GMT+02:00)
                                          vodafone-speedtest.0	2020-04-23 15:51:40.597	debug	(11688) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":
                                          vodafone-speedtest.0	2020-04-23 15:51:40.596	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.596	debug	(11688) Create_state called for : upstreamBooked with value : 50
                                          vodafone-speedtest.0	2020-04-23 15:51:40.595	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.594	debug	(11688) Create_state called for : downstreamBooked with value : 1000
                                          vodafone-speedtest.0	2020-04-23 15:51:40.594	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.593	debug	(11688) Create_state called for : upstreamSpeed with value : 54784
                                          vodafone-speedtest.0	2020-04-23 15:51:40.592	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.592	debug	(11688) Create_state called for : downstreamSpeed with value : 1095680
                                          vodafone-speedtest.0	2020-04-23 15:51:40.591	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.591	debug	(11688) Create_state called for : ipCountry with value : DE
                                          vodafone-speedtest.0	2020-04-23 15:51:40.590	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.589	debug	(11688) Create_state called for : ip with value : xxxxxxxxxxxxxxxx
                                          vodafone-speedtest.0	2020-04-23 15:51:40.589	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.588	debug	(11688) Create_state called for : isp with value : Vodafone GmbH
                                          vodafone-speedtest.0	2020-04-23 15:51:40.588	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.587	debug	(11688) Create_state called for : isCustomer with value : true
                                          vodafone-speedtest.0	2020-04-23 15:51:40.586	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.585	debug	(11688) Create_state called for : modem.text with value : AVM
                                          vodafone-speedtest.0	2020-04-23 15:51:40.585	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.584	debug	(11688) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                                          vodafone-speedtest.0	2020-04-23 15:51:40.583	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.583	debug	(11688) Create_state called for : modem.code with value : 6591
                                          vodafone-speedtest.0	2020-04-23 15:51:40.582	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.582	debug	(11688) Create_state called for : modem.vendor with value : AVM
                                          vodafone-speedtest.0	2020-04-23 15:51:40.579	debug	(11688) Write value : false
                                          vodafone-speedtest.0	2020-04-23 15:51:40.578	debug	(11688) Create_state called for : modem with value : undefined
                                          vodafone-speedtest.0	2020-04-23 15:51:39.442	info	(11688) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                                          vodafone-speedtest.0	2020-04-23 15:51:38.814	debug	(11688) statesDB connected
                                          vodafone-speedtest.0	2020-04-23 15:51:38.813	debug	(11688) States connected to redis: 127.0.0.1:9000
                                          vodafone-speedtest.0	2020-04-23 15:51:38.794	debug	(11688) States create System PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:51:38.791	debug	(11688) States create User PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:51:38.779	debug	(11688) Redis States: Use Redis connection: 127.0.0.1:9000
                                          vodafone-speedtest.0	2020-04-23 15:51:38.777	debug	(11688) objectDB connected
                                          vodafone-speedtest.0	2020-04-23 15:51:38.772	debug	(11688) Objects connected to redis: 127.0.0.1:9001
                                          vodafone-speedtest.0	2020-04-23 15:51:38.737	debug	(11688) Objects client initialize lua scripts
                                          vodafone-speedtest.0	2020-04-23 15:51:38.736	debug	(11688) Objects create User PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:51:38.735	debug	(11688) Objects create System PubSub Client
                                          vodafone-speedtest.0	2020-04-23 15:51:38.732	debug	(11688) Objects client ready ... initialize now
                                          vodafone-speedtest.0	2020-04-23 15:51:38.691	debug	(11688) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.iobrokerv4	2020-04-23 15:51:38.093	info	instance system.adapter.vodafone-speedtest.0 started with pid 11688
