  5. Blockly Skript HILFE!
    5.5k
blocklyjavascript
16 Beiträge 3 Kommentatoren 1.4k Aufrufe 1 Beobachtet
    @marcuskl
    Jetzt lehne ich mich mal gaaanz weit aus dem fenster:
    Habe keine Ahnung ob das klappt
     <variables>
       <variable type="" id="Gq+hJ(]M`1q4wk?WuJ31">Vorhanden</variable>
       <variable type="" id="Fy9)NJ*Ri:E`D+MB6J*f">MAC</variable>
       <variable type="undefined" id="timeout">timeout</variable>
     </variables>
     <block type="variables_set" id="b?BSL:ogTW]j@@}IXTdy" x="137" y="213">
       <field name="VAR" id="Gq+hJ(]M`1q4wk?WuJ31" variabletype="">Vorhanden</field>
       <value name="VALUE">
         <block type="math_number" id="(25wfY#Z(sP6%O=*7e)V">
           <field name="NUM">0</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="9$1@9m;7SV$`bj)P@X=U">
           <field name="VAR" id="Fy9)NJ*Ri:E`D+MB6J*f" variabletype="">MAC</field>
             <block type="text" id="[4IW*L=|_Zw4,CpyWGs`">
               <field name="TEXT">AA:BB:CC:DD:EE</field>
             </block>
           </value>
           <next>
             <block type="on_ext" id="xc-DsF{ac!rVre7_uoQi">
               <mutation items="1"></mutation>
               <value name="OID0">
                 <shadow type="field_oid" id="Fr:Ep{+?+wkP4]a#}3rG">
                 </shadow>
                 <block type="get_value" id="Hiwj!G,5TU(CPs+auE85">
                   <field name="OID">ID auswählen</field>
                 </block>
               </value>
               <statement name="STATEMENT">
                 <block type="variables_set" id="VG?0Zr#Q@]7+#w:Fad!d">
                     <block type="text_indexOf" id="sgIH(vOqM{-sQocl]GMW">
                       <field name="END">FIRST</field>
                         <block type="get_value" id=")2|@peC4tY9(sYh~Zw#X">
                         </block>
                       </value>
                       <value name="FIND">
                         <shadow type="text" id="Ua3tgy@JGu7#jTxWWB0H">
                           <field name="TEXT">abc</field>
                         </shadow>
                         <block type="variables_get" id="}=oG^:2Vj|=n9T.Si;sA">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="controls_if" id="e,kKh-V[.9j(3h=JmJ5+">
                       <value name="IF0">
                         <block type="logic_compare" id="-{OAcLsNe,2NFlOO{w;5">
                           <field name="OP">GT</field>
                           <value name="A">
                             <block type="variables_get" id="GBqZ^Tv3@`LFJU`VSdM?">
                             </block>
                           </value>
                           <value name="B">
                             <block type="math_number" id="K5C$+Wno;s50BbSzv3PY">
                             </block>
                           </value>
                         </block>
                       </value>
                       <statement name="DO0">
                         <block type="update" id=")w,I?.Zz+a/v5GJ@%UnW">
                           <mutation delay_input="false"></mutation>
                             <block type="logic_boolean" id="1S3p5gnIHm7I4_-rZ02P">
                             </block>
                           </value>
                           <next>
                             <block type="timeouts_settimeout" id="~3N1n$a0ZpSz%6bVFYIN">
                               <field name="DELAY">1000</field>
                               <field name="UNIT">ms</field>
                                 <block type="variables_set" id="b)QCrh-hDu--U0l[1Lih">
                                     <block type="math_number" id="1k,HkrQ5b8xH2T=J~rs+">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="comment" id="%=d[,A+5G-[+dy/E)3^e" x="463" y="237">
       <field name="COMMENT">Datenpunkt</field>
     </block>
     <block type="comment" id="iERPrzZexHT(|#FH*d[[" x="588" y="312">
     </block>
    </xml>
    @paul53 wird mir schon die Leviten lesen ;-)
    @Homoran sagte):
    Ja, für einen Fehler, der Dir nicht mehr passieren sollte: Trigger auf einen Wert ?
      @Homoran sagte):
      @paul53 sagte in Blockly Skript HILFE!:
      Ääähm
      Was ist denn da passiert
      nee, so war das wirklich nicht gemeint - Sorry!
      Dämliches C&P
      so muss es
      marcusklM paul53P 2 Antworten Letzte Antwort
        Ääähm
        Dämliches C&P
        so muss es
        marcusklM Offline
        marcusklM Offline
        marcuskl
        @Homoran funktioniert danke :)
        Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
        Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
          Ääähm
          Dämliches C&P
          so muss es
          @Homoran sagte in Blockly Skript HILFE!:
          so muss es
          Ich gehe mal davon aus, dass der Datenpunkt einen JSON-String enthält. Dann kann man es so ähnlich machen, wie @Homoran vorgeschlagen hat.
          Zur Erläuterung:
          Die Variable Vorhanden ist 0 bei "nicht gefunden" und > 0 bei "gefunden"
          nicht nicht Vorhanden wandelt alle Werte <> 0 nach true und den Wert 0 nach false.
           <variables>
           </variables>
           <block type="variables_set" id="9$1@9m;7SV$`bj)P@X=U" x="137" y="239">
                 <field name="TEXT">7e:82:14:a7:67:64</field>
               </block>
             </value>
             <next>
                 <value name="OID0">
                   </shadow>
                 </value>
                           <block type="on_source" id="5./8v/8wMV{yFATu)oNK">
                           </block>
                         </value>
                         <value name="FIND">
                           </shadow>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                           <block type="logic_negate" id="7*{{jb}$p/`G!G$WSj^j">
                             <value name="BOOL">
                               <block type="logic_negate" id="/]MSH9:MdQx=N,h$G]6v">
                                 <value name="BOOL">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
           <block type="comment" id="%=d[,A+5G-[+dy/E)3^e" x="363" y="263">
           </block>
          </xml>
            so muss es
            Zur Erläuterung:
             <variables>
             </variables>
                 </block>
               </value>
               <next>
                   <value name="OID0">
                     </shadow>
                   </value>
                             </block>
                           </value>
                           <value name="FIND">
                             </shadow>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                               <value name="BOOL">
                                   <value name="BOOL">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
             </block>
            </xml>
            Zur Erläuterung:
            und die muss nicht zur Sicherheit wieder auf 0 gesetzt werden, damit beim nächsten Durchlauf auch alles stimmt?
              Zur Erläuterung:
              @Homoran sagte:
              Nein, die Position im String wird jedesmal wieder neu ermittelt und wird bei "nicht vorhanden" automatisch zu 0.
                @Homoran sagte:
                @paul53 Danke!
                • marcusklM marcuskl
                  @marcuskl sagte:
                  Im Script von @Homoran bleibt der Datenpunkt-Wert immer auf true, wenn er einmal auf true gesetzt wurde.
                  marcusklM HomoranH 2 Antworten Letzte Antwort
                    @marcuskl sagte:
                    marcusklM Offline
                    marcusklM Offline
                    marcuskl
                    @Homoran habe ein sonst setze objelt auf false gemacht.
                    So setzt es wenn nicht vorhanden auf false.
                      @marcuskl sagte:
                      so was hatte ich befürchtet - auch hier Danke!
