  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Onkyo
Onkyo
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
120 Beiträge 4 Kommentatoren 35.0k Aufrufe
  • I
    I
    instalator
    #105
    @Eisbaeeer:
    Hi
    I changed my vis to test further. In zone 1 there is no "radio preset" available. The radio preset in zone2 doesn´t working. If I try to set the preset to "2" for preset memory 2, the receiver doesn´t recognize that. It doesn´t matter, what you type in, no reaction.
    The other "net-usb" things are not tested at the moment.
    Greetings Eisbaeeer `
    Hallo!
    Zuletzt hatte ich den Hörer nachließ. Ich nahm es für eine kostenlose Ersatzkarte hdmi zur Reparatur. Ich kann den Fahrer nur 2 Wochen überprüfen.
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • EisbaeeerE
      EisbaeeerE
      Eisbaeeer
      #106
      Hi Installator
      The translation does not make sense. I think it´s better to write in english.
      I changed the "eiscp-commands.json" to get the status working in onkyo adapter. I changed the both "standby" to "false" states in zone1 and zone2.
      You can compare the file with yours:
      Now I get the correct feedback and my power buttons are working. Can you change this in your code?
      My opinion is, that the adapter has too much overhead for the target function. It is not clear, why we need so much alias for the commands?
      Who needs this and for wich function?
      My main feature is to control the onkyo through VIS.
      Can someone explain how do you use the adapter and the other functions?
      My first adapter was created without an extra "node_module" for eiscp. I realized all in RAW mode wihtout too much overhead.
      The other issue is, that I get now zone3, zone4 …., but I don´t have this zones!
      For me the adapter now doing that what he should. So all is fine and I am happy. I can use it as it is.
      Eisbaeeer
      139_eiscp-commands.json.txt
      Kein support per PM. Bitte im Forum Fragen stellen!
      • I
        I
        instalator
        #107
        @Eisbaeeer:
        Hi Installator
        Eisbaeeer `
        Hello! I can not yet test the driver. I gave my ressiver in the replacement motherboard repair hdmi
        • EisbaeeerE
          EisbaeeerE
          Eisbaeeer
          #108
          Ahh, OK! No problem.
          Gesendet von meinem SM-G920F mit Tapatalk
          • I
            I
            instalator
            #109
            @Eisbaeeer:
            @instalator:
            @instalator:
            I changed the driver. Objects are created automatically. Replace folder with the drivers, and delete all the objects in Onkio driver and restart the IOB.
            filename="iobroker.onkyo.rar" index="2">~~ What result?
            I tested with the main power button. Result is, that the button doesn´t change the colour, because the status in iobroker is NOT "true" or "false" or "1" or "0". And this can not be working. Only this 4 states are allowed in iobroker. The object get´s the state (value) "standby".
            I have attached a screenshot of my test. The buttons left of the marked are my working buttons who changes the logo by selecting a picture for the value "false" and an other for the value "true".
            I tested the "Mute" button, too. This is working how it should !!!
            So it seems, that only the feedback of power button is wrong. Can you change that from "standby" to "false" and if the receiver is on to "true"?
            At the moment we get:
            Receiver off = "standby"
            Receiver on = "1"
            Correct feedbacks will be:
            Receiver off = "false"
            Receiver on = "true"
            filename="Screenshot.png" index="2">~~
            Eisbaeeer `
            I changed the code to standby to False.
            What do you do before prevented as in the picture?
            • I
              I
              instalator
              #110
              Eisbaeeer
              [{"tpl":"tplHqButton","data":{"visibility-cond":"==","visibility-val":1,"oid":"onkyo.0.system-power","min":"standby","max":"true","iconName":"/vis/img/dashui/avSony.png","btIconWidth":"47","offsetAuto":false,"leftOffset":"4","topOffset":"7","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","usejQueryStyle":false,"changeEffect":"waves","testActive":false,"waveColor":"#FFFFFF","oid-working":"","filterkey":"media","pushButton":false,"gestures-offsetX":0,"gestures-offsetY":0},"style":{"left":"26px","top":"171px","z-index":"3","border-radius":"50px","width":"50px","height":"50px"},"widgetSet":"hqwidgets"}]
              • I
                I
                instalator
                #111
                Это объекты которые созданы автоматически, на основе файла команд.
                These are objects that are created automatically based on the file command.
                • EisbaeeerE
                  EisbaeeerE
                  Eisbaeeer
                  #112
                  That's strange because I don't have a zone 3 and 4! Anyway, I'm happy now with my solution. I will not spend more time to debug. My buttons are working and I don't need more. Thanks.
                  • I
                    I
                    instalator
                    #113
                    @Eisbaeeer:
                    Gesendet von meinem SM-G920F mit Tapatalk `
                    Which model is your AV receiver?
                    • EisbaeeerE
                      EisbaeeerE
                      Eisbaeeer
                      #114
                      TX-NR626
                      • I
                        I
                        instalator
                        #115
                        @Eisbaeeer:
                        TX-NR626
                        )) Your receiver is not in the command file. https://github.com/GermanBluefox/node-e … mands.json
                        Now I'll add it for you.
                        • I
                          I
                          instalator
                          #116
                          @instalator:
                          @Eisbaeeer:
                          TX-NR626
                          Now I'll add it for you. `
                          266_eiscp-commands.rar
                          • I
                            I
                            instalator
                            #117
                            @Eisbaeeer:
                            TX-NR626
                            Now the driver work? any comments?
                            • EisbaeeerE
                              EisbaeeerE
                              Eisbaeeer
                              #118
                              Don't have time to test now.
                              • EisbaeeerE
                                EisbaeeerE
                                Eisbaeeer
                                #119
                                Hi Instalator
                                I tested now with the new driver. But I get zone 1-4.
                                Next thing, I can not select "bluetooth" as input device or the command is not realized?
                                In spoiler you find the log.
                                ! ioBroker.adminAdapterInstanzenObjekteZuständeEreignisseGruppenBenutzerAufzählungenHostsLogSkripte
                                ! Admin
                                ! Log Log-Größe: 0.81 MB
                                ! Zeit Nachricht
                                ! x
                                ! onkyo-0 2016-04-30 22:05:52 error Error: ERROR (arg_not_exist) Argument bluetooth does not exist in command input-selector
                                ! onkyo-0 2016-04-30 22:05:52 info stateChange onkyo.0.input-selector {"val":"bluetooth","ack":false,"ts":1462046753,"q":0,"from":"system.adapter.admin.1","lc":1462046753}
                                ! onkyo-0 2016-04-30 22:05:46 error Error: ERROR (arg_not_exist) Argument cd,tv,cd does not exist in command input-selector
                                ! onkyo-0 2016-04-30 22:05:46 info stateChange onkyo.0.input-selector {"val":"cd,tv,cd","ack":false,"ts":1462046746,"q":0,"from":"system.adapter.admin.1","lc":1462046746}
                                ! onkyo-0 2016-04-30 22:05:15 info stateChange onkyo.0.command {"val":"PR302","ack":true,"ts":1462046715,"q":0,"from":"system.adapter.onkyo.0","lc":1462046715}
                                ! onkyo-0 2016-04-30 22:05:15 info Create new object: onkyo.0.zone3.preset, role = media
                                ! onkyo-0 2016-04-30 22:05:15 info Got message: {"command":"preset","zone":"zone3","iscp_command":"PR302","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:14 info stateChange onkyo.0.command {"val":"TU310440","ack":true,"ts":1462046715,"q":0,"from":"system.adapter.onkyo.0","lc":1462046715}
                                ! onkyo-0 2016-04-30 22:05:14 info Create new object: onkyo.0.zone3.tuning, role = media
                                ! onkyo-0 2016-04-30 22:05:14 info Got message: {"command":"tuning","zone":"zone3","iscp_command":"TU310440","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:14 info stateChange onkyo.0.command {"val":"SL3N/A","ack":true,"ts":1462046714,"q":0,"from":"system.adapter.onkyo.0","lc":1462046714}
                                ! onkyo-0 2016-04-30 22:05:14 info Create new object: onkyo.0.zone3.selector, role = media
                                ! onkyo-0 2016-04-30 22:05:14 info Got message: {"command":"selector","zone":"zone3","iscp_command":"SL3N/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:13 info stateChange onkyo.0.command {"val":"BL3N/A","ack":true,"ts":1462046714,"q":0,"from":"system.adapter.onkyo.0","lc":1462046714}
                                ! onkyo-0 2016-04-30 22:05:13 info Create new object: onkyo.0.zone3.balance, role = media
                                ! onkyo-0 2016-04-30 22:05:13 info Got message: {"command":"balance","zone":"zone3","iscp_command":"BL3N/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:13 info stateChange onkyo.0.command {"val":"TN3N/A","ack":true,"ts":1462046713,"q":0,"from":"system.adapter.onkyo.0","lc":1462046713}
                                ! onkyo-0 2016-04-30 22:05:13 info Create new object: onkyo.0.zone3.tone, role = media
                                ! onkyo-0 2016-04-30 22:05:13 info Got message: {"command":"tone","zone":"zone3","iscp_command":"TN3N/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:12 info stateChange onkyo.0.command {"val":"VL3N/A","ack":true,"ts":1462046713,"q":0,"from":"system.adapter.onkyo.0","lc":1462046713}
                                ! onkyo-0 2016-04-30 22:05:12 info Create new object: onkyo.0.zone3.volume, role = media.volume
                                ! onkyo-0 2016-04-30 22:05:12 info Got message: {"command":"volume","zone":"zone3","iscp_command":"VL3N/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:12 info stateChange onkyo.0.zone3.muting {"val":false,"ack":true,"ts":1462046712,"q":0,"from":"system.adapter.onkyo.0","lc":1462046712}
                                ! onkyo-0 2016-04-30 22:05:12 info stateChange onkyo.0.command {"val":"MT300","ack":true,"ts":1462046712,"q":0,"from":"system.adapter.onkyo.0","lc":1462046712}
                                ! onkyo-0 2016-04-30 22:05:12 info Create new object: onkyo.0.zone3.muting, role = media
                                ! onkyo-0 2016-04-30 22:05:12 info Got message: {"command":"muting","zone":"zone3","argument":"off","iscp_command":"MT300","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:12 info stateChange onkyo.0.zone3.power {"val":"standby","ack":true,"ts":1462046712,"q":0,"from":"system.adapter.onkyo.0","lc":1462046712}
                                ! onkyo-0 2016-04-30 22:05:11 info stateChange onkyo.0.command {"val":"PW300","ack":true,"ts":1462046712,"q":0,"from":"system.adapter.onkyo.0","lc":1462046712}
                                ! onkyo-0 2016-04-30 22:05:11 info Create new object: onkyo.0.zone3.power, role = button
                                ! onkyo-0 2016-04-30 22:05:11 info Got message: {"command":"power","zone":"zone3","argument":"standby","iscp_command":"PW300","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:10 info stateChange onkyo.0.command {"val":"PRZ02","ack":true,"ts":1462046710,"q":0,"from":"system.adapter.onkyo.0","lc":1462046710}
                                ! onkyo-0 2016-04-30 22:05:10 info Create new object: onkyo.0.zone2.preset, role = media
                                ! onkyo-0 2016-04-30 22:05:10 info Got message: {"command":"preset","zone":"zone2","iscp_command":"PRZ02","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:09 info stateChange onkyo.0.command {"val":"TUZ10440","ack":true,"ts":1462046710,"q":0,"from":"system.adapter.onkyo.0","lc":1462046710}
                                ! onkyo-0 2016-04-30 22:05:09 info Create new object: onkyo.0.zone2.tuning, role = media
                                ! onkyo-0 2016-04-30 22:05:09 info Got message: {"command":"tuning","zone":"zone2","iscp_command":"TUZ10440","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:09 info stateChange onkyo.0.zone2.selector {"val":"fm","ack":true,"ts":1462046709,"q":0,"from":"system.adapter.onkyo.0","lc":1462046709}
                                ! onkyo-0 2016-04-30 22:05:09 info stateChange onkyo.0.command {"val":"SLZ24","ack":true,"ts":1462046709,"q":0,"from":"system.adapter.onkyo.0","lc":1462046709}
                                ! onkyo-0 2016-04-30 22:05:09 info Create new object: onkyo.0.zone2.selector, role = media
                                ! onkyo-0 2016-04-30 22:05:09 info Got message: {"command":"selector","zone":"zone2","argument":"fm","iscp_command":"SLZ24","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:08 info stateChange onkyo.0.command {"val":"ZBLN/A","ack":true,"ts":1462046709,"q":0,"from":"system.adapter.onkyo.0","lc":1462046709}
                                ! onkyo-0 2016-04-30 22:05:08 info Create new object: onkyo.0.zone2.balance, role = media
                                ! onkyo-0 2016-04-30 22:05:08 info Got message: {"command":"balance","zone":"zone2","iscp_command":"ZBLN/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:08 info stateChange onkyo.0.command {"val":"ZTNN/A","ack":true,"ts":1462046708,"q":0,"from":"system.adapter.onkyo.0","lc":1462046708}
                                ! onkyo-0 2016-04-30 22:05:08 info Create new object: onkyo.0.zone2.tone, role = media
                                ! onkyo-0 2016-04-30 22:05:08 info Got message: {"command":"tone","zone":"zone2","iscp_command":"ZTNN/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:07 info stateChange onkyo.0.command {"val":"ZVLN/A","ack":true,"ts":1462046708,"q":0,"from":"system.adapter.onkyo.0","lc":1462046708}
                                ! onkyo-0 2016-04-30 22:05:07 info Create new object: onkyo.0.zone2.volume, role = media.volume
                                ! onkyo-0 2016-04-30 22:05:07 info Got message: {"command":"volume","zone":"zone2","iscp_command":"ZVLN/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:07 info stateChange onkyo.0.zone2.muting {"val":false,"ack":true,"ts":1462046707,"q":0,"from":"system.adapter.onkyo.0","lc":1462046707}
                                ! onkyo-0 2016-04-30 22:05:07 info stateChange onkyo.0.command {"val":"ZMT00","ack":true,"ts":1462046707,"q":0,"from":"system.adapter.onkyo.0","lc":1462046707}
                                ! onkyo-0 2016-04-30 22:05:07 info Create new object: onkyo.0.zone2.muting, role = media
                                ! onkyo-0 2016-04-30 22:05:07 info Got message: {"command":"muting","zone":"zone2","argument":"off","iscp_command":"ZMT00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:06 info stateChange onkyo.0.zone2.power {"val":"standby","ack":true,"ts":1462046707,"q":0,"from":"system.adapter.onkyo.0","lc":1462046707}
                                ! onkyo-0 2016-04-30 22:05:06 info stateChange onkyo.0.command {"val":"ZPW00","ack":true,"ts":1462046707,"q":0,"from":"system.adapter.onkyo.0","lc":1462046707}
                                ! onkyo-0 2016-04-30 22:05:06 info Create new object: onkyo.0.zone2.power, role = button
                                ! onkyo-0 2016-04-30 22:05:06 info Got message: {"command":"power","zone":"zone2","argument":"standby","iscp_command":"ZPW00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:01 info stateChange onkyo.0.command {"val":"NSTSxx","ack":true,"ts":1462046702,"q":0,"from":"system.adapter.onkyo.0","lc":1462046702}
                                ! onkyo-0 2016-04-30 22:05:01 info Create new object: onkyo.0.net-usb-play-status, role = media
                                ! onkyo-0 2016-04-30 22:05:01 info Got message: {"command":"net-usb-play-status","zone":"main","iscp_command":"NSTSxx","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:01 info stateChange onkyo.0.command {"val":"NTR0001/0001","ack":true,"ts":1462046701,"q":0,"from":"system.adapter.onkyo.0","lc":1462046701}
                                ! onkyo-0 2016-04-30 22:05:01 info Create new object: onkyo.0.net-usb-track-info, role = media
                                ! onkyo-0 2016-04-30 22:05:01 info Got message: {"command":"net-usb-track-info","zone":"main","iscp_command":"NTR0001/0001","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:05:00 info Create new object: onkyo.0.net-usb-time-info, role = media
                                ! onkyo-0 2016-04-30 22:05:00 info Got message: {"command":"net-usb-time-info","zone":"main","iscp_command":"NTM–:--/--:--","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:29 info Starting AVR discovery
                                ! onkyo-0 2016-04-30 22:04:50 info stateChange onkyo.0.command {"val":"PRS02","ack":true,"ts":1462046690,"q":0,"from":"system.adapter.onkyo.0","lc":1462046690}
                                ! onkyo-0 2016-04-30 22:04:50 info Create new object: onkyo.0.zone4.preset, role = media
                                ! onkyo-0 2016-04-30 22:04:50 info Got message: {"command":"preset","zone":"zone4","iscp_command":"PRS02","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:49 info stateChange onkyo.0.music-optimizer {"val":false,"ack":true,"ts":1462046689,"q":0,"from":"system.adapter.onkyo.0","lc":1462046689}
                                ! onkyo-0 2016-04-30 22:04:49 info stateChange onkyo.0.command {"val":"MOT00","ack":true,"ts":1462046689,"q":0,"from":"system.adapter.onkyo.0","lc":1462046689}
                                ! onkyo-0 2016-04-30 22:04:49 info Create new object: onkyo.0.music-optimizer, role = media
                                ! onkyo-0 2016-04-30 22:04:49 info Got message: {"command":"music-optimizer","zone":"main","argument":"off","iscp_command":"MOT00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:48 info stateChange onkyo.0.audyssey-dynamic-volume {"val":"medium","ack":true,"ts":1462046688,"q":0,"from":"system.adapter.onkyo.0","lc":1462046688}
                                ! onkyo-0 2016-04-30 22:04:48 info stateChange onkyo.0.command {"val":"ADV02","ack":true,"ts":1462046688,"q":0,"from":"system.adapter.onkyo.0","lc":1462046688}
                                ! onkyo-0 2016-04-30 22:04:48 info Create new object: onkyo.0.audyssey-dynamic-volume, role = media.volume
                                ! onkyo-0 2016-04-30 22:04:48 info Got message: {"command":"audyssey-dynamic-volume","zone":"main","argument":"medium","iscp_command":"ADV02","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:47 info stateChange onkyo.0.audyssey-dynamic-eq {"val":true,"ack":true,"ts":1462046688,"q":0,"from":"system.adapter.onkyo.0","lc":1462046688}
                                ! onkyo-0 2016-04-30 22:04:47 info stateChange onkyo.0.command {"val":"ADQ01","ack":true,"ts":1462046688,"q":0,"from":"system.adapter.onkyo.0","lc":1462046688}
                                ! onkyo-0 2016-04-30 22:04:47 info Create new object: onkyo.0.audyssey-dynamic-eq, role = media
                                ! onkyo-0 2016-04-30 22:04:47 info Got message: {"command":"audyssey-dynamic-eq","zone":"main","argument":"on","iscp_command":"ADQ01","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:47 info stateChange onkyo.0.audyssey-2eq-multeq-multeq-xt {"val":["on","movie"],"ack":true,"ts":1462046687,"q":0,"from":"system.adapter.onkyo.0","lc":1462046687}
                                ! onkyo-0 2016-04-30 22:04:47 info stateChange onkyo.0.command {"val":"ADY01","ack":true,"ts":1462046687,"q":0,"from":"system.adapter.onkyo.0","lc":1462046687}
                                ! onkyo-0 2016-04-30 22:04:47 info Create new object: onkyo.0.audyssey-2eq-multeq-multeq-xt, role = media
                                ! onkyo-0 2016-04-30 22:04:47 info Got message: {"command":"audyssey-2eq-multeq-multeq-xt","zone":"main","argument":["on","movie"],"iscp_command":"ADY01","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:46 info stateChange onkyo.0.cinema-filter {"val":false,"ack":true,"ts":1462046687,"q":0,"from":"system.adapter.onkyo.0","lc":1462046687}
                                ! onkyo-0 2016-04-30 22:04:46 info stateChange onkyo.0.command {"val":"RAS00","ack":true,"ts":1462046687,"q":0,"from":"system.adapter.onkyo.0","lc":1462046687}
                                ! onkyo-0 2016-04-30 22:04:46 info Create new object: onkyo.0.cinema-filter, role = media
                                ! onkyo-0 2016-04-30 22:04:46 info Got message: {"command":"cinema-filter","zone":"main","argument":"off","iscp_command":"RAS00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:46 info stateChange onkyo.0.late-night {"val":false,"ack":true,"ts":1462046686,"q":0,"from":"system.adapter.onkyo.0","lc":1462046686}
                                ! onkyo-0 2016-04-30 22:04:46 info stateChange onkyo.0.command {"val":"LTN00","ack":true,"ts":1462046686,"q":0,"from":"system.adapter.onkyo.0","lc":1462046686}
                                ! onkyo-0 2016-04-30 22:04:46 info Create new object: onkyo.0.late-night, role = media
                                ! onkyo-0 2016-04-30 22:04:46 info Got message: {"command":"late-night","zone":"main","argument":"off","iscp_command":"LTN00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:45 info stateChange onkyo.0.listening-mode {"val":["plii","pliix-movie"],"ack":true,"ts":1462046686,"q":0,"from":"system.adapter.onkyo.0","lc":1462046686}
                                ! onkyo-0 2016-04-30 22:04:45 info stateChange onkyo.0.command {"val":"LMD80","ack":true,"ts":1462046686,"q":0,"from":"system.adapter.onkyo.0","lc":1462046686}
                                ! onkyo-0 2016-04-30 22:04:45 info Create new object: onkyo.0.listening-mode, role = media
                                ! onkyo-0 2016-04-30 22:04:45 info Got message: {"command":"listening-mode","zone":"main","argument":["plii","pliix-movie"],"iscp_command":"LMD80","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:45 info stateChange onkyo.0.video-picture-mode {"val":"custom","ack":true,"ts":1462046685,"q":0,"from":"system.adapter.onkyo.0","lc":1462046685}
                                ! onkyo-0 2016-04-30 22:04:45 info stateChange onkyo.0.command {"val":"VPM01","ack":true,"ts":1462046685,"q":0,"from":"system.adapter.onkyo.0","lc":1462046685}
                                ! onkyo-0 2016-04-30 22:04:45 info Create new object: onkyo.0.video-picture-mode, role = media
                                ! onkyo-0 2016-04-30 22:04:45 info Got message: {"command":"video-picture-mode","zone":"main","argument":"custom","iscp_command":"VPM01","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:44 info stateChange onkyo.0.video-wide-mode {"val":"full","ack":true,"ts":1462046685,"q":0,"from":"system.adapter.onkyo.0","lc":1462046685}
                                ! onkyo-0 2016-04-30 22:04:44 info stateChange onkyo.0.command {"val":"VWM02","ack":true,"ts":1462046685,"q":0,"from":"system.adapter.onkyo.0","lc":1462046685}
                                ! onkyo-0 2016-04-30 22:04:44 info Create new object: onkyo.0.video-wide-mode, role = media
                                ! onkyo-0 2016-04-30 22:04:44 info Got message: {"command":"video-wide-mode","zone":"main","argument":"full","iscp_command":"VWM02","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:43 info stateChange onkyo.0.monitor-out-resolution {"val":"1080p","ack":true,"ts":1462046684,"q":0,"from":"system.adapter.onkyo.0","lc":1462046684}
                                ! onkyo-0 2016-04-30 22:04:43 info stateChange onkyo.0.command {"val":"RES05","ack":true,"ts":1462046684,"q":0,"from":"system.adapter.onkyo.0","lc":1462046684}
                                ! onkyo-0 2016-04-30 22:04:43 info Create new object: onkyo.0.monitor-out-resolution, role = media
                                ! onkyo-0 2016-04-30 22:04:43 info Got message: {"command":"monitor-out-resolution","zone":"main","argument":"1080p","iscp_command":"RES05","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:43 info stateChange onkyo.0.hdmi-audio-out {"val":"auto","ack":true,"ts":1462046683,"q":0,"from":"system.adapter.onkyo.0","lc":1462046683}
                                ! onkyo-0 2016-04-30 22:04:43 info stateChange onkyo.0.command {"val":"HAO02","ack":true,"ts":1462046683,"q":0,"from":"system.adapter.onkyo.0","lc":1462046683}
                                ! onkyo-0 2016-04-30 22:04:43 info Create new object: onkyo.0.hdmi-audio-out, role = media
                                ! onkyo-0 2016-04-30 22:04:43 info Got message: {"command":"hdmi-audio-out","zone":"main","argument":"auto","iscp_command":"HAO02","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:42 info stateChange onkyo.0.hdmi-output-selector {"val":["yes","out"],"ack":true,"ts":1462046683,"q":0,"from":"system.adapter.onkyo.0","lc":1462046683}
                                ! onkyo-0 2016-04-30 22:04:42 info stateChange onkyo.0.command {"val":"HDO01","ack":true,"ts":1462046683,"q":0,"from":"system.adapter.onkyo.0","lc":1462046683}
                                ! onkyo-0 2016-04-30 22:04:42 info Create new object: onkyo.0.hdmi-output-selector, role = media
                                ! onkyo-0 2016-04-30 22:04:42 info Got message: {"command":"hdmi-output-selector","zone":"main","argument":["yes","out"],"iscp_command":"HDO01","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:41 info stateChange onkyo.0.audio-selector {"val":"arc","ack":true,"ts":1462046682,"q":0,"from":"system.adapter.onkyo.0","lc":1462046682}
                                ! onkyo-0 2016-04-30 22:04:41 info stateChange onkyo.0.command {"val":"SLA07","ack":true,"ts":1462046682,"q":0,"from":"system.adapter.onkyo.0","lc":1462046682}
                                ! onkyo-0 2016-04-30 22:04:41 info Create new object: onkyo.0.audio-selector, role = media
                                ! onkyo-0 2016-04-30 22:04:41 info Got message: {"command":"audio-selector","zone":"main","argument":"arc","iscp_command":"SLA07","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:40 info stateChange onkyo.0.input-selector {"val":["cd","tv","cd"],"ack":true,"ts":1462046681,"q":0,"from":"system.adapter.onkyo.0","lc":1462046681}
                                ! onkyo-0 2016-04-30 22:04:40 info stateChange onkyo.0.command {"val":"SLI23","ack":true,"ts":1462046681,"q":0,"from":"system.adapter.onkyo.0","lc":1462046681}
                                ! onkyo-0 2016-04-30 22:04:40 info Create new object: onkyo.0.input-selector, role = media
                                ! onkyo-0 2016-04-30 22:04:40 info Got message: {"command":"input-selector","zone":"main","argument":["cd","tv","cd"],"iscp_command":"SLI23","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:40 info stateChange onkyo.0.command {"val":"IFV","ack":true,"ts":1462046680,"q":0,"from":"system.adapter.onkyo.0","lc":1462046680}
                                ! onkyo-0 2016-04-30 22:04:40 info Create new object: onkyo.0.video-infomation, role = media
                                ! onkyo-0 2016-04-30 22:04:40 info Got message: {"command":"video-infomation","zone":"main","iscp_command":"IFV","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:39 info stateChange onkyo.0.command {"val":"IFAN/A","ack":true,"ts":1462046680,"q":0,"from":"system.adapter.onkyo.0","lc":1462046680}
                                ! onkyo-0 2016-04-30 22:04:39 info Create new object: onkyo.0.audio-infomation, role = media
                                ! onkyo-0 2016-04-30 22:04:39 info Got message: {"command":"audio-infomation","zone":"main","iscp_command":"IFAN/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:39 info stateChange onkyo.0.dimmer-level {"val":"bright","ack":true,"ts":1462046679,"q":0,"from":"system.adapter.onkyo.0","lc":1462046679}
                                ! onkyo-0 2016-04-30 22:04:39 info stateChange onkyo.0.command {"val":"DIM00","ack":true,"ts":1462046679,"q":0,"from":"system.adapter.onkyo.0","lc":1462046679}
                                ! onkyo-0 2016-04-30 22:04:39 info Create new object: onkyo.0.dimmer-level, role = media
                                ! onkyo-0 2016-04-30 22:04:39 info Got message: {"command":"dimmer-level","zone":"main","argument":"bright","iscp_command":"DIM00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:38 info stateChange onkyo.0.display-mode {"val":"selector-volume","ack":true,"ts":1462046679,"q":0,"from":"system.adapter.onkyo.0","lc":1462046679}
                                ! onkyo-0 2016-04-30 22:04:38 info stateChange onkyo.0.command {"val":"DIF00","ack":true,"ts":1462046679,"q":0,"from":"system.adapter.onkyo.0","lc":1462046679}
                                ! onkyo-0 2016-04-30 22:04:38 info Create new object: onkyo.0.display-mode, role = media
                                ! onkyo-0 2016-04-30 22:04:38 info Got message: {"command":"display-mode","zone":"main","argument":"selector-volume","iscp_command":"DIF00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:38 info stateChange onkyo.0.command {"val":"CTL00","ack":true,"ts":1462046678,"q":0,"from":"system.adapter.onkyo.0","lc":1462046678}
                                ! onkyo-0 2016-04-30 22:04:38 info Create new object: onkyo.0.center-temporary-level, role = media
                                ! onkyo-0 2016-04-30 22:04:38 info Got message: {"command":"center-temporary-level","zone":"main","iscp_command":"CTL00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:37 info stateChange onkyo.0.command {"val":"SWL-7","ack":true,"ts":1462046678,"q":0,"from":"system.adapter.onkyo.0","lc":1462046678}
                                ! onkyo-0 2016-04-30 22:04:37 info Create new object: onkyo.0.subwoofer-temporary-level, role = media
                                ! onkyo-0 2016-04-30 22:04:37 info Got message: {"command":"subwoofer-temporary-level","zone":"main","iscp_command":"SWL-7","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:37 info stateChange onkyo.0.command {"val":"SLP00","ack":true,"ts":1462046677,"q":0,"from":"system.adapter.onkyo.0","lc":1462046677}
                                ! onkyo-0 2016-04-30 22:04:37 info Create new object: onkyo.0.sleep-set, role = media
                                ! onkyo-0 2016-04-30 22:04:37 info Got message: {"command":"sleep-set","zone":"main","iscp_command":"SLP00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:33 info stateChange onkyo.0.command {"val":"TFRB+AT+6","ack":true,"ts":1462046674,"q":0,"from":"system.adapter.onkyo.0","lc":1462046674}
                                ! onkyo-0 2016-04-30 22:04:33 info Create new object: onkyo.0.tone-front, role = media
                                ! onkyo-0 2016-04-30 22:04:33 info Got message: {"command":"tone-front","zone":"main","iscp_command":"TFRB+AT+6","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:33 info stateChange onkyo.0.command {"val":"MVL0F","ack":true,"ts":1462046673,"q":0,"from":"system.adapter.onkyo.0","lc":1462046673}
                                ! onkyo-0 2016-04-30 22:04:33 info stateChange onkyo.0.volume {"val":15,"ack":true,"ts":1462046673,"q":0,"from":"system.adapter.onkyo.0","lc":1462046673}
                                ! onkyo-0 2016-04-30 22:04:33 info stateChange onkyo.0.master-volume {"val":15,"ack":true,"ts":1462046673,"q":0,"from":"system.adapter.onkyo.0","lc":1462046673}
                                ! onkyo-0 2016-04-30 22:04:33 info Got message: {"command":["master-volume","volume"],"zone":"main","argument":15,"iscp_command":"MVL0F","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:32 info stateChange onkyo.0.volume {"val":15,"ack":true,"ts":1462046673,"q":0,"from":"system.adapter.onkyo.0","lc":1462046673}
                                ! onkyo-0 2016-04-30 22:04:32 info stateChange onkyo.0.master-volume {"val":15,"ack":true,"ts":1462046673,"q":0,"from":"system.adapter.onkyo.0","lc":1462046673}
                                ! onkyo-0 2016-04-30 22:04:32 info stateChange onkyo.0.command {"val":"MVL0F","ack":true,"ts":1462046673,"q":0,"from":"system.adapter.onkyo.0","lc":1462046673}
                                ! onkyo-0 2016-04-30 22:04:32 info Create new object: onkyo.0.volume, role = media.volume
                                ! onkyo-0 2016-04-30 22:04:32 info Create new object: onkyo.0.master-volume, role = media.volume
                                ! onkyo-0 2016-04-30 22:04:32 info Got message: {"command":["master-volume","volume"],"zone":"main","argument":15,"iscp_command":"MVL0F","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:31 info stateChange onkyo.0.command {"val":"SPBN/A","ack":true,"ts":1462046672,"q":0,"from":"system.adapter.onkyo.0","lc":1462046672}
                                ! onkyo-0 2016-04-30 22:04:31 info Create new object: onkyo.0.speaker-b, role = media
                                ! onkyo-0 2016-04-30 22:04:31 info Got message: {"command":"speaker-b","zone":"main","iscp_command":"SPBN/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:31 info stateChange onkyo.0.command {"val":"SPAN/A","ack":true,"ts":1462046671,"q":0,"from":"system.adapter.onkyo.0","lc":1462046671}
                                ! onkyo-0 2016-04-30 22:04:31 info Create new object: onkyo.0.speaker-a, role = media
                                ! onkyo-0 2016-04-30 22:04:31 info Got message: {"command":"speaker-a","zone":"main","iscp_command":"SPAN/A","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:30 info stateChange onkyo.0.audio-muting {"val":false,"ack":true,"ts":1462046671,"q":0,"from":"system.adapter.onkyo.0","lc":1462046671}
                                ! onkyo-0 2016-04-30 22:04:30 info stateChange onkyo.0.command {"val":"AMT00","ack":true,"ts":1462046671,"q":0,"from":"system.adapter.onkyo.0","lc":1462046671}
                                ! onkyo-0 2016-04-30 22:04:30 info Create new object: onkyo.0.audio-muting, role = media
                                ! onkyo-0 2016-04-30 22:04:30 info Got message: {"command":"audio-muting","zone":"main","argument":"off","iscp_command":"AMT00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:30 info stateChange onkyo.0.system-power {"val":"standby","ack":true,"ts":1462046670,"q":0,"from":"system.adapter.onkyo.0","lc":1462046670}
                                ! onkyo-0 2016-04-30 22:04:30 info stateChange onkyo.0.command {"val":"PWR00","ack":true,"ts":1462046670,"q":0,"from":"system.adapter.onkyo.0","lc":1462046670}
                                ! onkyo-0 2016-04-30 22:04:30 info Create new object: onkyo.0.system-power, role = button
                                ! onkyo-0 2016-04-30 22:04:30 info Got message: {"command":"system-power","zone":"main","argument":"standby","iscp_command":"PWR00","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:30 info stateChange onkyo.0.command {"val":"NLSC-P","ack":true,"ts":1462046670,"q":0,"from":"system.adapter.onkyo.0","lc":1462046670}
                                ! onkyo-0 2016-04-30 22:04:30 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1462046670,"q":0,"from":"system.adapter.onkyo.0","lc":1462046670}
                                ! onkyo-0 2016-04-30 22:04:30 info Create new object: onkyo.0.command, role = media
                                ! onkyo-0 2016-04-30 22:04:30 info Create new object: onkyo.0.net-usb-list-info, role = media
                                ! onkyo-0 2016-04-30 22:04:30 info Got message: {"command":"net-usb-list-info","zone":"main","iscp_command":"NLSC-P","host":"192.168.1.72","port":"60128","model":"TX-NR626"}
                                ! onkyo-0 2016-04-30 22:04:30 error Error: ERROR (arg_not_exist) Argument query does not exist in command internet-radio-preset
                                ! onkyo-0 2016-04-30 22:04:30 error Error: ERROR (arg_not_exist) Argument query does not exist in command net-tune-network
                                ! onkyo-0 2016-04-30 22:04:30 error Error: ERROR (arg_not_exist) Argument query does not exist in command listening-mode
                                Eisbaeeer
                                • I
                                  I
                                  instalator
                                  #120
                                  @Eisbaeeer:
                                  Hi Instalator
                                  Eisbaeeer `
                                  https://github.com/GermanBluefox/node-eiscp/pull/6
                                  33.2k
                                  84.4k
