  4. Windanzeige mit Ventus W132 & Wemos D1 Mini
    5.4k
45 Beiträge 14 Kommentatoren 12.6k Aufrufe 17 Beobachtet
  • C Offline
    claus1993
    schrieb am zuletzt editiert von claus1993
    Hier mal noch die komplette Fehlermeldung
    Arduino: 1.8.8 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\claus\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\claus\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\claus\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10808 -build-path C:\Users\claus\AppData\Local\Temp\arduino_build_156623 -warnings=none -build-cache C:\Users\claus\AppData\Local\Temp\arduino_cache_901311 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -verbose C:\Users\claus\Documents\Arduino\Windmesser\Windmesser.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\claus\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\claus\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\claus\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10808 -build-path C:\Users\claus\AppData\Local\Temp\arduino_build_156623 -warnings=none -build-cache C:\Users\claus\AppData\Local\Temp\arduino_cache_901311 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -verbose C:\Users\claus\Documents\Arduino\Windmesser\Windmesser.ino
    Using board 'd1_mini' from platform in folder: C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
    Using core 'esp8266' from platform in folder: C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
    Build-Optionen wurden verändert, alles wird neu kompiliert
    Detecting libraries used...
    "C:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\claus\\AppData\\Local\\Temp\\arduino_build_156623/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\d1_mini" "C:\\Users\\claus\\AppData\\Local\\Temp\\arduino_build_156623\\sketch\\Windmesser.ino.cpp" -o nul
    Windmesser:30:25: error: common_wifi.h: No such file or directory
     #include <common_wifi.h>
    compilation terminated.
    exit status 1
    WIFI und MQTT Namen sowie Passwörter habe ich bewusst noch nicht eingetragen :-)
    • C Offline
      claus1993
      Dann gebe ich mir mal selber eine Antwort :-)
      Da ich die Befehle direkt in den Sketch kopiert habe, benötige ich die externen Libraries nicht. Externe Libraries werden in den gleichen Ordner abgelegt wie der Sketch und im Sketch mit include eingebunden.
      Habe die #include für <common_wifi.h>, <Common_mqtt.h>, <esp_pins.h> und <private_wifi.h> mit einen // davor als Kommentar gesetzt. Den Sketch auf meinen ESP geflasht und jetzt habe ich die Values in meinem ioBroker :-)
      Weiterhin habe ich meine Zugriffsdaten für mein WLAN und MQTT im Sketch eingetragen.
      W 1 Antwort Letzte Antwort
        mwyraz
        schrieb am zuletzt editiert von mwyraz
        Top ;-)
        Please enter a longer post. Posts should contain at least 8 character(s).
        Freu mich, dass es geht. Ja, die Libs entfallen, wenn du deren Inhalt reinkopierst kannst die Zeilen rauslöschen.
        Edit: ich versuche mal, meinen Blogpost incl. "Schaltplan" zeitnah fertig zu machen und poste dann den Link hier.
        • F Offline
          feli1
          schrieb am zuletzt editiert von feli1
          ...habe in dem Sketch von @claus1993 vom 9.Okt die includes "common_wifi.h, common_mqtt.h, private_wifi.h und esp_pins.h" auskommentiert, die Wlan und MQTT Login Daten eingetragen und den Sketch erfolgreich geflasht.
          Der Wemos meldet sich erfolgreich in der Fritzbox an, alles scheint ok. Leider wird mein MQTT Adapter im IO Broker nicht grün. Mit dem MQTT Beispiel- Sketch aus dem Arduino IDE wird er dagegen sofort grün.
          Habe im Moment keine Idee wie ich weitermachen könnte.
          Hat jemand einen Vorschlag?
          • C claus1993
            W Offline
            W Offline
            Wayne1983
            @claus1993 Hallo. Vielleicht könntest du mir helfen. Habe alle lt. deiner Beschreibung erledigt.
            Bekomme aber immer folgende Fehlermeldung.
            Danke.
            • H Offline
              hugo1215
              habe auch das Script von @claus1993 genommen und auch die #include für <common_wifi.h>, <Common_mqtt.h>, <esp_pins.h> und <private_wifi.h> mit einen // auskommentiert.
              Habe meine Wlan daten und MQTT daten eingeben. Im Wlan habe ich diesen auch gefunden nur leider sehe ich diese noch nicht im MQTT im Iobroker.
              Habe ich was übersehen? Sensor ist auch angeschlossen.
              • C Offline
                claus1993
                Sorry das tut mir leid das es nicht funktioniert...bin leider kein Profi was das programmieren betrifft und wurschtele mich auch immer so durch. meist ist es ein Trial and Error...
                @Wayne1983
                du hast die Meldung zu dem D2 Pin gesehen? Hast du deine Data Leitung dort angesetzt?
                Hatte in einem anderen Sketch auch ein Problem und habe dann D2 durch den GPIO Pin ersetzt. Vielleicht hilft das.
                @hugo1215
                hast du die Daten korrekt eingegeben? Funktionieren andere MQTT Exports? Hast du auch deine IP und Port Nummer verwendet und nicht die die im Skript steht?
                Aufgrund eines Rechner Crashs habe ich den Sketch leider nicht mehr sonst würde ich ihn hier posten :-(
                • H Offline
                  hugo1215
                  schrieb am zuletzt editiert von hugo1215
                  Hallo @claus1993,
                  also normal funktionieren die Exports. Habe 4 Wemos laufen wo ESP EASY läuft mit meinem Einstellungen.
                  Hatte einen Kleine Fehler gefunden. hehe. Wass aber passiert ist das es sich immer wieder mit meinem WLAN verbinden will das hat er auch macht immer ein Reconnect und somit kommt er nicht zum verbinden mit dem MQTT server und kann dann im weiteren Verlauf nicht die Daten vom Windmesser weiterleiten.
                  H 1 Antwort Letzte Antwort
                  • C Offline
                    claus1993
                    @hugo1215
                    sorry dann kann ich leider nicht weiterhelfen. Sollte mir etwas einfallen würde ich mich melden.
                    • premoP Offline
                      premoP Offline
                      premo
                      schrieb am zuletzt editiert von premo
                      Falls Interesse besteht dann könnte ich mal ein einfaches Ansteuern der Markise anbieten.
                      Bei mir ist ein Eltako WS Windsensor mit Wemos D1 mini im Einsatz.
                      Mit dem Skript wird über MQTT die Windstärke in km/h in IOBroker
                      angezeigt.
                      Der Eltako WS erzeugt pro Umdrehung 2 Impulse, beim W132 wird nur 1 Impuls erzeugt.
                      Dieses muss im Skript noch eingestellt werden.
                      Anbei die Beschreibung mit Skript
                      esp8266-anemometer-master.zip Beschreibung.zip
                      Gerade noch was Intressantes gefunden.
                      https://gist.github.com/micw/098709efc83a9d9ebf16d14cea4ca38e
                      • H Offline
                        hugo1215
                        hallo @premo
                        danke das du dein Script zur verfügung stellst. Werde es mal ausprobieren. WO stelle ich die Impulse in deinem Script ein. Ein bisschen erfahrung habe ich aber nicht genug.
                        Denn Link von Github kenne ich schon leider klappt es damit nicht.
                        premoP 1 Antwort Letzte Antwort
                        • C claus1993
                          @hugo1215
                          hugo1215
                          @claus1993 sagte in Windanzeige mit Ventus W132 & Wemos D1 Mini:
                          @hugo1215
                          Hallo @claus1993,
                          habe den Fehler gefunden. Bei den Board Verwaltung im Arduino Programm muss die Version 2.4.1 installiert sein. Dann klappt es.
                          Bekomme jetzt auch die Daten in Iobroker. Soweit so gut. Kann man die Daten auch schneller Abrufen und nicht nur alle 30 sek??
                          C ? 2 Antworten Letzte Antwort
                          • H hugo1215
                            @hugo1215
                            Hallo @claus1993,
                            claus1993
                            @hugo1215 freut mich das es jetzt läuft. Was eine Verkürzung der Abfragezeit betrifft meine ich gelesen zu haben das der Skript Vergleichswerte zur Berechnung benötigt. Wenn dem so ist müsste man den Skript und die Berechnung anpassen.
                            • C claus1993
                              hugo1215
                              @claus1993 hast du einen Tip wo ich schauen kann??
                              • H hugo1215
                                hallo @premo
                                premoP Offline
                                premoP Offline
                                premo
                                @hugo1215 sagte in Windanzeige mit Ventus W132 & Wemos D1 Mini:
                                In der "myconfig_samples.h"
                                In der Zeile 16
                                const float number_reed = 1
                                • C claus1993
                                  @mwyraz
                                  Habe mal alles in einen Sketch kopiert und ihn dann überprüfen lassen.
                                  Beim kopieren habe ich die define und include untereinander geschrieben. Den Rest der einzelnen Sketche habe ich dann darunter kopiert. Zusätzlich habe ich die define für die Userberechtigungen in den Sketch kopiert. Im Endeffekt habe ich aus 4 einzelnen Sketchen einen einzigen erstellt.
                                   * Ein ESP8622 NodeMCU Develompent Board, welches Sensorwerte via MQTT verschickt
                                   * http://frightanic.com/iot/comparison-of-esp8266-nodemcu-development-boards/
                                   * Umbau eines W132 Windsensors von ELV
                                   * - Abtrennen des 433 MHZ-Senders, welcher mit 3 Leitungen (Schwarz, Rot, Blau) an der Logik-Platine angeschlossen ist
                                   * - Anschließen des ESP-8266
                                   *   - Schwarz -> GND
                                   *   - Rot -> 3.3V
                                   *   - Blau -> D2
                                   * Eine Beschreibung des Protokoll ist unter http://www.tfd.hu/tfdhu/files/wsprotocol/auriol_protocol_v20.pdf zu finden, hilfreich ist auch https://sourceforge.net/p/wmrx00/discussion/855158/thread/b3a47730/
                                   * - Bits und Sync-Signale werden über die Abstände der fallenden Flanke codiert
                                   * - diese Implementierung nutzt dazu einen Interrupt auf der fallenden Flanke
                                  #define MQTT_ALIVE_TOPIC "sensor/%s/alive"
                                  #define MQTT_DATA_TOPIC "sensor/%s/%s"
                                  #define MQTT_KEEPALIVE 10
                                  #define WIFI_SSID "mywifi"
                                  #define WIFI_PASSWORD "topsecret"
                                  #define MQTT_HOST "10.10.10.1"
                                  #define MQTT_PORT 1883
                                  #define MQTT_USERNAME "sensor"
                                  #define MQTT_PASSWORD "secret"
                                  #include <common_mqtt.h>
                                  #include <esp_pins.h>
                                  #include <ESP8266WiFi.h>
                                  #include <WiFiUdp.h>
                                  #include <private_wifi.h>
                                  #include <PubSubClient.h>
                                  #define PIN_ANEMOMETER D2
                                  void setup_wifi() {
                                    delay(10);
                                    // We start by connecting to a WiFi network
                                    Serial.println();
                                    Serial.print("Connecting to ");
                                    Serial.println(WIFI_SSID);
                                    WiFi.mode(WIFI_STA); // disable hotspot
                                    WiFi.begin(WIFI_SSID,WIFI_PASSWORD);
                                    wdt_reset(); // Watchdock resetten
                                    while (WiFi.status() != WL_CONNECTED) {
                                      delay(500);
                                      Serial.print(".");
                                    Serial.println("");
                                    Serial.println("WiFi connected");
                                    Serial.println("IP address: ");
                                    Serial.println(WiFi.localIP());
                                  extern const char* MQTT_FALSE = "0";
                                  extern const char* MQTT_TRUE = "1";
                                  WiFiClient wifiClient;
                                  PubSubClient mqttClient(wifiClient);
                                  char MQTT_CLIENT_ID[15];
                                  void setup_mqtt() {
                                    mqttClient.setServer(MQTT_HOST, MQTT_PORT);
                                    byte mac[6];
                                    WiFi.macAddress(mac);
                                    sprintf(MQTT_CLIENT_ID, "ESP8266_%02X%02X%02X", mac[3], mac[4], mac[5]);
                                  void connect_mqtt(char* MQTT_TOPIC) {
                                    // Loop until we're reconnected
                                    while (!mqttClient.connected()) {
                                      Serial.print("Attempting MQTT connection...");
                                      // Attempt to connect
                                  #if defined(MQTT_ALIVE_TOPIC)
                                      byte mac[6];
                                      char aliveTopicId[7];
                                      sprintf(aliveTopicId, "%02X%02X%02X", mac[3], mac[4], mac[5]);
                                      char aliveTopic[255];
                                      sprintf(aliveTopic, MQTT_ALIVE_TOPIC, aliveTopicId);
                                      if (mqttClient.connect(MQTT_CLIENT_ID, MQTT_USERNAME, MQTT_PASSWORD, aliveTopic, 1, 1, MQTT_FALSE)) {
                                        Serial.println("connected with last will and testament enabled");
                                        mqttClient.publish(aliveTopic,MQTT_TRUE,1);
                                        Serial.print("Sent alive message to ");
                                        Serial.println(aliveTopic);
                                  #else
                                      if (mqttClient.connect(MQTT_CLIENT_ID, MQTT_USERNAME, MQTT_PASSWORD)) {
                                        Serial.println("connected");
                                  #endif
                                        if (MQTT_TOPIC && mqttClient.subscribe(MQTT_TOPIC,1)) {
                                          Serial.print("Subscribed to ");
                                          Serial.println(MQTT_TOPIC);
                                      } else {
                                        Serial.print("failed, rc=");
                                        Serial.print(mqttClient.state());
                                        Serial.println(" try again in 5 seconds");
                                        // Wait 5 seconds before retrying
                                        delay(5000);
                                        wdt_reset();
                                  volatile unsigned long lastTrigger;
                                  byte mac[6];
                                  char sensorId[7];
                                  char topicBuffer[255];
                                  char messageBuffer[255];
                                  byte bitPos=-1;
                                  byte messageNum=-1;
                                  // there are always sent 6 messages. For temperature/humidity, the message is repeatet 6 times. For wind, 2 messages are repeatet 3 times each
                                  int message1Bits[36];
                                  int message2Bits[36];
                                  bool verifyChecksum(int bits[]) {
                                    int checksum=0xf;
                                    for (int i=0;i<8;i++) {
                                      checksum-=bits[i*4]|bits[i*4+1]<<1|bits[i*4+2]<<2|bits[i*4+3]<<3;
                                    checksum&=0xf;
                                    int expectedChecksum=bits[32]|bits[33]<<1|bits[34]<<2|bits[35]<<3;
                                    return checksum==expectedChecksum;
                                  void decodeMessages() {
                                    if (!verifyChecksum(message1Bits)) {
                                      Serial.println("Checksum mismatch in message #1");
                                      return;
                                    Serial.println("---");
                                    for (int i=0;i<36;i++) {
                                      Serial.print(message1Bits[i]);
                                      Serial.print(" ");
                                    Serial.println();
                                      Serial.print(message2Bits[i]);
                                      Serial.print(" ");
                                    Serial.println();
                                    if (message1Bits[9]==1 && message1Bits[10]==1) { // wind data (2 messages)
                                      if (!verifyChecksum(message2Bits)) {
                                        return;
                                      float windSpeed=(message1Bits[24]    | message1Bits[25]<<1 | message1Bits[26]<<2 | message1Bits[27]<<3 |
                                                       message1Bits[28]<<4 | message1Bits[29]<<5 | message1Bits[30]<<6 | message1Bits[31]<<7)*0.2f;
                                      Serial.print("Average wind speed: ");
                                      Serial.print(windSpeed);
                                      Serial.println(" m/s");
                                      sprintf(topicBuffer, MQTT_DATA_TOPIC, sensorId, "wind_speed");
                                      String value = String(windSpeed,1);
                                      value.toCharArray(messageBuffer,255);
                                      mqttClient.publish(topicBuffer,(byte*)messageBuffer,strlen(messageBuffer));
                                      float windGust=(message2Bits[24]    | message2Bits[25]<<1 | message2Bits[26]<<2 | message2Bits[27]<<3 |
                                                      message2Bits[28]<<4 | message2Bits[29]<<5 | message2Bits[30]<<6 | message2Bits[31]<<7)*0.2f;
                                      Serial.print("Max wind speed: ");
                                      Serial.print(windGust);
                                      sprintf(topicBuffer, MQTT_DATA_TOPIC, sensorId, "wind_gust");
                                      value = String(windGust,1);
                                      int windDirection=(message2Bits[15]    | message2Bits[16]<<1 | message2Bits[17]<<2 | message2Bits[18]<<3 |
                                                         message2Bits[19]<<4 | message2Bits[20]<<5 | message2Bits[21]<<6 | message2Bits[22]<<7 |
                                                         message2Bits[23]<<8);
                                      Serial.print("Wind direction: ");
                                      Serial.print(windDirection);
                                      Serial.println(" °");
                                      sprintf(topicBuffer, MQTT_DATA_TOPIC, sensorId, "wind_direction");
                                      value = String(windDirection);
                                    } else {  // temperature/humidity in both messages
                                      int temperatureRaw=(message1Bits[12]    | message1Bits[13]<<1 | message1Bits[14]<<2 | message1Bits[15]<<3 |
                                                          message1Bits[16]<<4 | message1Bits[17]<<5 | message1Bits[18]<<6 | message1Bits[19]<<7 |
                                                          message1Bits[20]<<8 | message1Bits[21]<<9 | message1Bits[22]<<10| message1Bits[23]<<11);
                                      if (temperatureRaw& 0x800) temperatureRaw+=0xF000; // negative number, 12 to 16 bit
                                      float temperature=temperatureRaw*0.1f;
                                      Serial.print("Temperature: ");
                                      Serial.print(temperature);
                                      Serial.println(" °C");
                                      sprintf(topicBuffer, MQTT_DATA_TOPIC, sensorId, "temp");
                                      String value = String(temperature,1);
                                      int humidity=(message1Bits[24] | message1Bits[25]<<1 | message1Bits[26]<<2 | message1Bits[27]<<3 )+
                                                   (message1Bits[28] | message1Bits[29]<<1 | message1Bits[30]<<2 | message1Bits[31]<<3 )*10;
                                      Serial.print("Humidity: ");
                                      Serial.print(humidity);
                                      Serial.println(" %");
                                      sprintf(topicBuffer, MQTT_DATA_TOPIC, sensorId, "humi");
                                      value = String(humidity);
                                  void dataTrigger() {
                                    unsigned long now=micros();
                                    unsigned long duration=now-lastTrigger;
                                    lastTrigger=now;
                                    if (duration>30000) { // a news block of messages begins
                                      messageNum=0;
                                    if (duration>7000) { // ~9 ms = sync signal
                                      if (bitPos==36) { // we got a full message
                                        if (messageNum==0) { // 1st message completed
                                          messageNum=1;
                                        } else if (messageNum==1) { // 2nd message completed
                                          decodeMessages();
                                          messageNum=-1;
                                      bitPos=0; // Nachricht begonnen
                                      return;
                                    if (messageNum<0) return; // ignore repeated messages
                                    if (bitPos<0) return; // invalid message, ignored
                                      message1Bits[bitPos]=(duration>3300); // 2.2ms=LOW, 4.4ms = HIGH bits
                                    } else {
                                      message2Bits[bitPos]=(duration>3300); // 2.2ms=LOW, 4.4ms = HIGH bits
                                    bitPos++;
                                    if (bitPos>36) bitPos=-1; // message too long -> invalid
                                  void setup() {
                                    wdt_enable(WDTO_8S); // Watchdog muss alle 8 Sekunden resettet werden
                                    Serial.begin(115200);
                                    Serial.println("Initializing");
                                    sprintf(sensorId, "%02X%02X%02X", mac[3], mac[4], mac[5]);
                                    setup_wifi();
                                    wdt_reset(); // Watchdog resetten
                                    setup_mqtt();
                                    pinMode(PIN_ANEMOMETER,INPUT);
                                    attachInterrupt(digitalPinToInterrupt(PIN_ANEMOMETER), dataTrigger, FALLING);
                                    Serial.println("Starting");
                                  void loop() {
                                    connect_mqtt(0);
                                    mqttClient.loop();
                                  Beim Prüfen bekomme ich folgende Fehlerantwort; "common_wifi.h: No such file or Directory"
                                  Woran kann das liegen?
                                  Danke für deine Unterstützung!
                                  Meldb
                                  @claus1993 Hallo ich habe auch dein Skipt verwendet. Super danke erstmal das du es hier zu verfügung gestellt hat. Jetzt habe ich noch eine Frage weiter oben habt ihr über den Regensensor W174 geschrieben habt ihr das auch an dem Wemo mit dem Skript? Oder wie habt ihr das gemacht?
                                  C 1 Antwort Letzte Antwort
                                  • M Meldb
                                    claus1993
                                    @Meldb
                                    Jepp der läuft mit einem Wemos D1 Mini.
                                    • C claus1993
                                      @Meldb
                                      Meldb
                                      @claus1993 Hallo ich habe heute mein Sensor W132 bekommen ich bekomme immer den gleichen Temperatur u. Luftfeuchte Wert ist das bei dir auch so?
                                      • M Meldb
                                        claus1993
                                        @Meldb
                                        Habe den Sensor mal angeklemmt und sehe das sich nur die Werte für den Wind ändern. Bei Temperatur und Humity ist schon weit längeren unverändert und wird bei einem Update auch nicht kurz grün. Kann die leider nicht sagen woran das liegt. Vielleicht gibt es den ein oder anderen Experten der den Code lesen kann und dort einen Fehler findet.
                                        • H hugo1215
                                          @hugo1215
                                          Hallo @claus1993,
                                          @hugo1215 said in Windanzeige mit Ventus W132 & Wemos D1 Mini:
                                          @mwyraz
                                          Vielleicht könnte man den Punkt mit der Version 2.4.1 auf GitHub hinzufügen?
