  4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    6.8k
248 Beiträge 26 Kommentatoren 72.0k Aufrufe 10 Beobachtet
  • J Offline
    james4711
    #157
    Hi Rene!
    Sorry .... ist sich gestern nicht mehr ausgegangen.
    Habe jetzt den Namen auf sbfspot.1 geändert.
    Ergebnis:
    Danach wieder auf sbfspot.0. Ergebnis:
    [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82. Please shift your use case over to Service Workers.
    VM14938 index.html:3469 Version vis-canvas-gauges: 0.1.5
    VM14940 index.html:4012 Version vis-history: 1.0.0
    info.js:9 Version Info-Adapter-Widget: 0.0.8
    index.html:5057 Version vis-jqui-mfd: 1.0.12
    justgage.js:115 Version justgage: 1.0.2
    index.html:9330 Version vis-map: 1.0.3
    index.html:10483 Metro version: "1.1.2"
    milight.js:135 Milight widget version: 0.0.3
    players.js:58 Version players: 0.1.0
    index.html:14341 Version vis-sbfspot: 2.4.0
    index.html:16742 Version vis-weather: 2.4.1
    conn.js:273 2020-03-25T08:01:22.278Z Connected => authenticate
    conn.js:293 2020-03-25T08:01:22.452Z Authenticated: true
    vis.js:3167 Create inner vis object sbfspot.0.304907836.EToday
    vis.js:3167 Create inner vis object sbfspot.0.304907836.history.last30Days
    index.html:14375 sbfspot history (w00037)
    index.html:14960 bind sbfspot.0.304907836.history.last30Days
    index.html:14600 ShowChart sbfspot (w00037)
    index.html:14606 need to wait... (w00037)
    index.html:14611 ShowChart sbfspot begin (w00037)
    index.html:14649 sel 2
    index.html:14815 barwidth = 43200000
    index.html:14514 CalcTicks4X: DayDiff 11 (1585047600000 1584097200000)
    jquery.flot.js:1349 +++
    jquery.flot.js:2452 major
    index.html:14406 legendformater label undefined
    index.html:14421 GridMarkings: DayDiff 11 (1585047600000 1584097200000)
    jquery.flot.js:1824 #1#1#
    jquery.flot.js:1861 major
    jquery.flot.js:1911 show 13.Mar on 0.5/-4.015625 Text is 23.328125 width and 8 high
    jquery.flot.js:1911 show 18.Mar on -21.5/-4.015625 Text is 23.328125 width and 8 high
    jquery.flot.js:1911 show 23.Mar on -42.5/-4.015625 Text is 23.328125 width and 8 high
    jquery.flot.js:1911 show 2.2 kWh on -1/-20.5 Text is 27.55078125 width and 8 high
    Letzte Zeile wiederholt sich dutzende male
    LG
    Rene_HMR 1 Antwort Letzte Antwort
    • J james4711
      Hi Rene!
      Ergebnis:
      LG
      Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      #158
      @james4711 sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
      Das ist okay. Hier einfach bei Tickgröße größere Werte eingeben, bis die Zeile nur noch 5 bis 10 mal kommt.
      Wenn sie dutzendende male kommt, versucht er die Skalierung auch so fein aufzubauen.
      und dann mal "Breite des Gitterrandes" verändern. Das hatte ich in der Vergangenheit schon mal, dass dieser Wert sich mal ändern muss...
      • J Offline
        james4711
        #159
        Danke für die Antwort ... habs jetzt mal geändert:
        Ergebnis im Log:
        VM1882 index.html:3469 Version vis-canvas-gauges: 0.1.5
        VM1883 index.html:4012 Version vis-history: 1.0.0
        conn.js:273 2020-03-28T18:03:46.546Z Connected => authenticate
        conn.js:293 2020-03-28T18:03:46.701Z Authenticated: true
        index.html:14514 CalcTicks4X: DayDiff 15 (1585393200000 1584097200000)
        index.html:14406 legendformater label ggggg
        index.html:14421 GridMarkings: DayDiff 15 (1585393200000 1584097200000)
        jquery.flot.js:1911 show 13.Mar on 0.5/-19.671875 Text is 34.9921875 width and 12 high
        jquery.flot.js:1911 show 18.Mar on -27.5/-19.671875 Text is 34.9921875 width and 12 high
        jquery.flot.js:1911 show 23.Mar on -55.5/-19.671875 Text is 34.9921875 width and 12 high
        jquery.flot.js:1911 show 4.0 kWh on -1/-33.5 Text is 41.326171875 width and 12 high
        jquery.flot.js:1911 show 6.0 kWh on -1/-30.5 Text is 41.326171875 width and 12 high
        jquery.flot.js:1911 show 8.0 kWh on -1/-27.5 Text is 41.326171875 width and 12 high
        jquery.flot.js:1911 show 10.0 kWh on -1/-24.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 12.0 kWh on -1/-21.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 14.0 kWh on -1/-18.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 16.0 kWh on -1/-15.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 18.0 kWh on -1/-12.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 20.0 kWh on -1/-10.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 22.0 kWh on -1/-7.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 24.0 kWh on -1/-4.5 Text is 47.326171875 width and 12 high
        jquery.flot.js:1911 show 26.0 kWh on -1/-1.5 Text is 47.326171875 width and 12 high
        Ergebnis am Schirm:
        Leider nix!
        • J Offline
          james4711
          #160
          Hat noch wer eine Idee was ich machen kann, damit die Anzeige funktioniert?
            Andersmacher
            #161
            @Rene_HM So, nachdem ich leider eine Pause einlegen mußte, habe ich mich der Thematik des bei mir "unsichtbaren Widgets" noch einmal gewidmet.
            Ich habe die Visualisierung ´mal via WR-ModBus-Auslesung, History- und flot-Adapter probiert. Damit erhalte ich problemlos Grafiken der Stromerzeugungswerte.
            Dann habe ich Deinen Adapter noch einmal komplett neu installiert. Wieder werden alle WR-Werte in der Rubrik "Objekte" unter sbfspot.0/Seriennummer/History angezeigt, aber Dein Widget (das natürlich via SBFspot.db und nicht via ModBus/History an die Daten kommt) will sich einfach nicht zeigen.
            Nachfolgend der aktuelle Browser-Log-Stand der Vis-Runtime:
            19:57:14.271 Laden fehlgeschlagen für das <script> mit der Quelle "http://Meine_IP-Adresse:8082/vis/widgets/sbfspot/flot/jquery.canvaswrapper.js". index.html:5493:1
            19:57:14.277 Version vis-sbfspot: 2.4.0 index.html:6179:25
            19:57:14.273
            TypeError: window.Flot is undefined
            jquery.flot.js:12:18
            19:57:14.273
            TypeError: $.plot is undefined
            jquery.flot.saturated.js:42:5
            19:57:14.274
            jquery.flot.browser.js:97:5
            19:57:14.274
            jquery.flot.drawSeries.js:662:25
            19:57:14.275
            jquery.flot.uiConstants.js:8:9
            19:57:14.275
            jquery.flot.time.js:26:23
            19:57:14.275
            jquery.flot.legend.js:431:5
            19:57:14.276
            jquery.flot.axislabels_V2.js:463:5
            19:57:14.669 Create inner vis object sbfspot.0.4711.history.last30Days vis.js:3167:29
            19:57:14.798 [1585850234799] Request 19 states. vis.js:2736:21
            19:57:14.985 sbfspot history (w00127) index.html:6213:25
            19:57:14.985 bind sbfspot.0.4711.history.last30Days index.html:6798:29
            19:57:14.986 ShowChart sbfspot (w00127) index.html:6438:29
            19:57:15.986 need to wait... (w00127) index.html:6444:37
            19:57:15.987 ShowChart sbfspot (w00127) index.html:6438:29
            19:57:15.987 ShowChart sbfspot begin (w00127) index.html:6449:29
            19:57:15.988 sel 2 index.html:6487:37
            19:57:15.989 barwidth = 43200000 index.html:6653:33
            19:57:15.991
            TypeError: $.plot is not a function
            Für mich sieht es so aus, als ob der Zugriff auf das Javaskript "jquery.canvaswrapper.js" ein/das Problem ist. Wo ich mir jetzt nicht sicher bin:
            Hat das grundsätzlich etwas mit dem Flot-Adapter zu tun (Ich habe Dein Widget jedoch in einem View, in dem ich nichts mit flot/History anzeigen lasse.) oder benutzt Du für Dein Widget auch irgend´was, daß mit flot zusammenhängt?
            Auf meinem Pi lautet der Pfad jedenfalls:
            /opt/iobroker/iobroker-data/files/vis/widgets/sbfspot/lib/js/flot/jquery.canvaswrapper.js
            und damit kann er es doch von
            auch gar nicht laden - oder?
            Ist das bei mir ein "ungewöhnlicher" Speicherort?
            Unter "/opt/iobroker/iobroker-data/files/vis/widgets/sbfspot/" das Verzeinis "flot" anzulegen und "jquery.canvaswrapper.js" da hinein zu kopieren, hat jedenfalls nichts gebracht, selbst dann nicht, wenn mann für "jquery.canvaswrapper.js" dort alle Berechtigungen erteilt.
            Weißt Du, bis wohin "http://Meine_IP-Adresse:8082/" tatsächlich vom root-Verzeichnis aus verweist? Dann würde ich es dort auch noch einmal hin kopieren.
            ioBroker auf Raspi4B 8GB Debian(12) 64Bit
            • Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              #162
              @Andersmacher , @james4711 nehmt mal bitte die 2.4.3 aus dem latest-Repo. Ich hatte noch zwei kleinere bug fixes nicht veröffentlicht:
              • im widget war der Pfad zu den flot/jquery-Dateien nicht korrekt
              • im adapter selbst war die Berechnung für die hitsory heute für sqlite noch falsch
                Beides ist behoben.
                Andersmacher
                #163
                @Rene_HM Kann man die 2.4.3 über die 2.4.0 installieren oder muß man 2.4.0 vorher deinstallieren?
                  Andersmacher
                  #164
                  @Rene_HM Edit: Ich sehe bei mir nur maximal eine 2.4.2 und keine 2.4.3!?!?
                    Andersmacher
                    #165
                    @Rene_HM So, 2.4.3 ist nun drauf. Ich habe die 2.4.0 vorher nicht deinstalliert. (Unter Adapter gibt es die 2.4.3 weiterhin nicht, aber unter Info/Updates tauchte sie plöztlich auf.).
                    In der Vis-Runtime sehe ich Dein Wifget weiterhin nicht.
                    Browser-Log Vis Runtime:
                    TypeError: vis.binds.sbfspot.history.update is not a functionindex.html:6824:55
                    init http://Meine-IP:8082/vis/index.html?PV-Anlage#Start
                    Im Vis-Editor sehe ich nun dort, wo die linke obere Ecke des Widgets sein sollte, einen winzigen Punkt. Geschätzt 2x2 Pixel.
                    Browser-Log Vis-Editor (nach Deiner Methode der Namensänderung erzeugt):
                    Beim ersten Mal:
                    21:52:08.855 Version vis-sbfspot: 2.4.3 edit.html:6200:25
                    21:52:09.402 2020-04-03T19:52:09.402Z Connected => authenticate conn.js:273:25
                    21:52:09.403 SyntaxError: JSON.parse: unexpected end of data at line 1 column 1 of the JSON data info.js:13:47
                    Ich hab´s dann noch einmal probiert:
                    22:33:02.089 ---------: w00127 - Start - sbfspot.0 - sbfspotinstance edit.html:6863:21
                    22:33:02.090 +++++++ sel_last30days 2 edit.html:6884:25
                    22:33:02.091 calc new oids with serial 4711 Instance sbfspot.0 last30Days edit.html:6910:25
                    22:33:02.110 sbfspot history (w00127) edit.html:6234:25
                    22:33:02.112 bind sbfspot.0.4711.history.last30Days edit.html:6835:29
                    22:33:02.113 ShowChart sbfspot (w00127) edit.html:6475:29
                    22:33:02.114 flot version 3.0.0 for sbfspot edit.html:6855:29
                    22:33:02.152 ---------: w00127 - Start - sbfspot.0 - sbfspotinstance edit.html:6863:21
                    22:33:02.153 +++++++ sel_last30days 2 edit.html:6884:25
                    22:33:02.153 calc new oids with serial 4711 Instance sbfspot.0 last30Days edit.html:6910:25
                    22:33:02.155 sbfspot history (w00127) edit.html:6234:25
                    22:33:02.156 bind sbfspot.0.4711.history.last30Days edit.html:6835:29
                    22:33:02.156 ShowChart sbfspot (w00127) edit.html:6475:29
                    22:33:02.156 flot version 3.0.0 for sbfspot edit.html:6855:29
                    22:33:02.182 "ne": {"en": "ne", "de": "ne", "ru": "ne"}, translate.js:20:17
                    22:33:02.183 "nw": {"en": "nw", "de": "nw", "ru": "nw"}, translate.js:20:17
                    22:33:02.183 "se": {"en": "se", "de": "se", "ru": "se"}, translate.js:20:17
                    22:33:02.183 "sw": {"en": "sw", "de": "sw", "ru": "sw"}, translate.js:20:17
                    22:33:02.294 "ne": {"en": "ne", "de": "ne", "ru": "ne"}, translate.js:20:17
                    22:33:02.294 "nw": {"en": "nw", "de": "nw", "ru": "nw"}, translate.js:20:17
                    22:33:02.294 "se": {"en": "se", "de": "se", "ru": "se"}, translate.js:20:17
                    22:33:02.295 "sw": {"en": "sw", "de": "sw", "ru": "sw"}, translate.js:20:17
                    22:33:03.115 need to wait... (w00127) edit.html:6481:37
                    22:33:03.116 ShowChart sbfspot (w00127) edit.html:6475:29
                    22:33:03.116 ShowChart sbfspot begin (w00127) edit.html:6486:29
                    22:33:03.116 sel 2 edit.html:6524:37
                    22:33:03.117 barwidth = 43200000 edit.html:6690:33
                    22:33:03.125 CalcTicks4X: DayDiff 18.958333333333332 (1585908000000 1584270000000) edit.html:6389:17
                    22:33:03.125 +++ jquery.flot.js:1349:29
                    22:33:03.128 xwhFormatter for 0 edit.html:6249:17
                    22:33:03.128 xwhFormatter for 3 edit.html:6249:17
                    22:33:03.129 +++ jquery.flot.js:1349:29
                    22:33:03.130 major 2 jquery.flot.js:2452:33
                    22:33:03.131 legendformater label undefined edit.html:6268:21
                    22:33:03.133 GridMarkings: DayDiff 18.958333333333332 (1585908000000 1584270000000) edit.html:6283:17
                    22:33:03.134 for more than days edit.html:6343:21
                    22:33:03.137 #1#1# jquery.flot.js:1824:21
                    22:33:03.138 major jquery.flot.js:1861:33
                    22:33:03.139 show 15.Mar on 0.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.139 show 20.Mar on -12.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.140 show 25.Mar on -24.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.140 show 30.Mar on -37.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.140 major jquery.flot.js:1861:33
                    22:33:03.141 show 0.0 Wh on -1/-19.5 Text is 23.549999237060547 width and 8 high jquery.flot.js:1911:41
                    22:33:03.162 need to wait... (w00127) edit.html:6481:37
                    22:33:03.163 ShowChart sbfspot (w00127) edit.html:6475:29
                    22:33:03.163 ShowChart sbfspot begin (w00127) edit.html:6486:29
                    22:33:03.163 sel 2 edit.html:6524:37
                    22:33:03.164 barwidth = 43200000 edit.html:6690:33
                    22:33:03.168 CalcTicks4X: DayDiff 18.958333333333332 (1585908000000 1584270000000) edit.html:6389:17
                    22:33:03.169 +++ jquery.flot.js:1349:29
                    22:33:03.171 xwhFormatter for 0 edit.html:6249:17
                    22:33:03.171 xwhFormatter for 3 edit.html:6249:17
                    22:33:03.171 +++ jquery.flot.js:1349:29
                    22:33:03.172 major 2 jquery.flot.js:2452:33
                    22:33:03.173 legendformater label undefined edit.html:6268:21
                    22:33:03.175 GridMarkings: DayDiff 18.958333333333332 (1585908000000 1584270000000) edit.html:6283:17
                    22:33:03.176 for more than days edit.html:6343:21
                    22:33:03.177 #1#1# jquery.flot.js:1824:21
                    22:33:03.178 major jquery.flot.js:1861:33
                    22:33:03.178 show 15.Mar on 0.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.179 show 20.Mar on -12.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.179 show 25.Mar on -24.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.179 show 30.Mar on -37.5/-4 Text is 23.33333396911621 width and 8 high jquery.flot.js:1911:41
                    22:33:03.180 major jquery.flot.js:1861:33
                    22:33:03.180 show 0.0 Wh on -1/-19.5 Text is 23.549999237060547 width and 8 high jquery.flot.js:1911:41
                    • A Andersmacher
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #166
                      @Andersmacher vielleicht war das Repo noch nicht aktualisiert?
                      • A Andersmacher
                        Beim ersten Mal:
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        schrieb am zuletzt editiert von Rene_HM
                        #167
                        @Andersmacher das log sieht eigentlich gut aus, die Pfade zu den Dateien stimmen jetzt. Wenn du im edit-Modus die sbfspot-Instanz löschst, bekommst du aber so etwas?
                        und mit Instanz gar nichts oder so etwas:
                        Kannst du mir die Einstellungen auf der rechten Seite nochmal zeigen?
                        Kannst du an allen Einstellungen auf der rechten Seite mal "wackeln", d.h. der Reihe nach alles mal ändern?
                        Mit welchem Browser arbeitest du?
                          Andersmacher
                          #168
                          @Rene_HM Mit gelöschter Instanz sehe ich im Editor auch dieses winzige schwarze Kästchen und direkt darunter steht "no instance for sbfspot specified".
                          Sowie man in das sbfspot-Instanz-Feld in den Eigenschaften des Widgets irgend etwas einträgt und sei es auch nur ein einziges Zeichen verschwindet der Schriftzug und nur das winzige schwarze Kästchen bleibt zu sehen.
                          Was noch ganz "lustig" ist:
                          Das sbfspot-Instanz-Feld und das Feld für die Seriennummer sind die einzigen beiden Felder (in allen Widgets, die ich bisher im Vis-Editor benutzt habe), bei dem man die Eingabe entweder blitzartig vornehmen muß oder nach jedem eingegebenen Zeichen kontrollieren muß, ob der Cursor noch im Feld steht und ihn meistens so etwa nach drei Zeichen wieder mit der Maus dort positionieren muß, weil er verschwunden ist und die weiteren Zeichen sonst verschluckt werden.
                          Hattest Du im Runtime-Log meines vorigen Posts gesehen?:
                          Das ist kein Problem?
                          "Wackeln an den Einstellungen" verändert nichts.
                          Normalerweise benutze ich noch immer FireFox 64Bit, weil ioBroker im IE bei mir gar nicht laufen will.
                          Aber Chrome verhält sich bezüglich Deines Widgets bei mir genauso wie FireFox.
                          • A Andersmacher
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #169
                            @Andersmacher wie groß ist dein widget?
                              Andersmacher
                              #170
                              OK, das war nach dem Update noch der entscheidende Hinweis. Offenbar sind beim Update auf 2.4.3 die Werte für Breite und Höhe wieder rausgeflogen und somit wurde es im Editor nur noch als dieses winzige Kästchen angezeigt und in der Runtime gar nicht. Nachdem ich die Größenangaben wieder eingesetzt habe, ist es nun in Editor und Runtime zum ersten Mal sichtbar.
                              Zeigt zwar noch immer nur Nullwerte bei heute und letzte 30 Tage an, aber das hängt ja wohl mit meinen bisher diskontinuierlichen DB-Einträgen zusammen, bzw. damit, daß mein Wechselrichter, wie weiter oben berichtet, leider keine Tageswerte ausgibt.
                              Da muß ich ohnehin noch entscheiden, ob dieser Adapter/dieses Widget für mich überhaupt einen sinnvollen Einsatz erlaubt.
                              Die Y-Achse kann nur dynamisch skalieren - oder?
                              Was mir noch aufgefallen ist:
                              Die Defaultwerte der Farbe für z.B. X-Achsenbeschriftung, ... stehen auf weiß. Für so Anfänger wie mich sieht das dann erst´mal so aus, als ob die Achse trotz Häckchen nicht angezeigt wird, jedenfalls solange man den Defaultwert für den Hintergrund (ebenfalls weiß) nicht ändert. Vielleicht kann man ja Vorder- und Hintergrund mit komplementären Defaultfarben belegen, damit man sofort alles sieht?
                              Auf alle Fälle Danke für die Unterstützung!
                              • A Andersmacher
                                Rene_HMR Offline
                                Rene_HMR Offline
                                Rene_HM
                                #171
                                @Andersmacher sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                                ich muss mal schauen, ob man mit den anderen Werten die History berechnen kann.
                                Habe dazu ein Ticket angelegt:
                                https://github.com/rg-engineering/ioBroker.sbfspot/issues/30
                                siehe dazu auch meine Nachricht im chat...
                                ja, die passt sich automatisch an...
                                ich habe zwar default-Farben vergeben, warum die dann nicht verwendet werden muss ich mir auch anschauen.
                                https://github.com/rg-engineering/ioBroker.sbfspot/issues/29
                                  Tottbeck
                                  schrieb am zuletzt editiert von Tottbeck
                                  #172
                                  Ich musste meinen Raspi3B nun auch nochmal neu aufsetzen mit dem Buster-Image.
                                  Schon wieder gibt's Sqlite3-Probleme.
                                  sbfspot.0	2020-04-09 15:00:04.085	error	(31172) exception catch after ready [Error: Cannot find module 'sqlite3']
                                  sbfspot.0	2020-04-09 15:00:04.029	info	(31172) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v10.19.0
                                  sbfspot.0	2020-04-09 15:00:02.928	debug	(31172) statesDB connected
                                  Das alte Ticket ist scheinbar noch nicht erledigt:
                                  https://github.com/mapbox/node-sqlite3/issues/1271
                                  Habe versucht manuell sqlite3 nachzuinstallieren wie im SQL-Adapter beschrieben
                                  pi@raspberrypi:~ $ node -v
                                  v10.19.0
                                  pi@raspberrypi:~ $ nodejs -v
                                  v10.19.0
                                  pi@raspberrypi:~ $ npm -v
                                  6.13.4
                                  pi@raspberrypi:~ $ cd /opt/iobroker
                                  pi@raspberrypi:/opt/iobroker $ iobroker stop sql
                                  Cannot find any instances of "sql"!
                                  pi@raspberrypi:/opt/iobroker $ npm install iobroker.sql --production
                                  npm WARN deprecated sprintf@0.1.5: The sprintf package is deprecated in favor of sprintf-js.
                                  npm WARN deprecated core-js@1.2.7: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                                  npm WARN deprecated json-parser@1.1.5: `json-parser` is deprecated. Please use `comment-json` instead
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/moment
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/moment-timezone
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-nan
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser
                                  npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sorted-array-functions
                                  npm ERR! code EACCES
                                  npm ERR! syscall access
                                  npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                  npm ERR! errno -13
                                  npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'
                                  npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node']
                                  npm ERR!   stack:
                                  npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node\'',
                                  npm ERR!   errno: -13,
                                  npm ERR!   code: 'EACCES',
                                  npm ERR!   syscall: 'access',
                                  npm ERR!   path:
                                  npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' }
                                  npm ERR!
                                  npm ERR! The operation was rejected by your operating system.
                                  npm ERR! It is likely you do not have the permissions to access this file as the current user
                                  npm ERR!
                                  npm ERR! If you believe this might be a permissions issue, please double-check the
                                  npm ERR! permissions of the file and its containing directories, or try running
                                  npm ERR! the command again as root/Administrator.
                                  npm ERR!     /home/pi/.npm/_logs/2020-04-09T14_00_08_273Z-debug.log
                                  Scheint also wieder an den Rechten zu scheitern, nur ändert diesmal leider auch das Fix-Script nichts 😞
                                  Gibt es einen workaround (alte sqlite3-Version, build from source ...)
                                  Ich weiß, das ist überhaupt kein Problem vom SBFspot. Aber ohne sqlite3 funktioniert der bei mir leider nicht. Danke
                                  • T Tottbeck
                                    v10.19.0
                                    v10.19.0
                                    6.13.4
                                    npm ERR! errno -13
                                    npm ERR!   stack:
                                    npm ERR!   path:
                                    npm ERR!
                                    npm ERR!
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #173
                                    @Tottbeck ja, das Ticket ist dort nicht erledigt und die Antworten sind auch nicht befriedigend.
                                    Ich kann damit nur raten:
                                    cd /opt/iobroker/node_modules/iobroker.sbfspot
                                    npm install
                                    Ich muss das oft drei vier mal hintereinander machen, aber irgendwann läuft es durch und baut von den Quellen...
                                    Auf jeden Fall vorher iobroker stoppen, damit Ressourcen auf dem System frei werden.
                                      Tottbeck
                                      #174
                                      Ich habe es jetzt x mal probiert, immer die gleiche Fehlermeldung. Dann auch mal als root im gleichem Ordner.
                                      Da gab es andere Fehlermeldungen, dann wieder als pi, auch mal das iobroker Fix-Script ausgeführt.
                                      Irgendwann konnte SBFspot die SQL-Datenbasis lesen, wirklich zielgerichtet ist diese Vorgehensweise ehrlich gesagt nicht.
                                      Aber gehen tut's jetzt zumindest. Danke
                                      • J Offline
                                        james4711
                                        #175
                                        So .. habs jetzt bei mir mal soweit zum laufen gebracht, dass etwas angezeigt wird (Problem lag in der Breite / Höhe ... war wohl auf 0. Danke für den Hinweis).
                                        Allerdings bekomme ich jetzt für heute z.B. so etwas:
                                        Sprich einmal Ausreißer ins Negative, und einmal start nach oben.
                                        Was kann der Grund dafür sein?
                                        Aus welchen Datenpunkten / Views / Tabellen werden die Graphen für den Tag generiert?
                                        Danke!
                                        • J james4711
                                          Danke!
                                          Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #176
                                          @james4711 Es wird einfach EToday aus der Datenbank ohne weitere Kalkulation verwendet und in eine Liste im Datenpunkt
                                          sbfspot.0.1234567890.history.today
                                          abgelegt.
                                          Die Liste sieht so ähnlich aus:
                                          [{"time":"06:30","value":0},{"time":"06:45","value":0},{"time":"07:00","value":5},{"time":"07:15","value":22},{"time":"07:30","value":47},{"time":"07:45","value":81},{"time":"08:00","value":126},{"time":"08:15","value":181},{"time":"08:30","value":251},{"time":"08:45","value":340},{"time":"09:00","value":443},{"time":"09:15","value":555},{"time":"09:30","value":676},{"time":"09:45","value":906},{"time":"10:00","value":1165},{"time":"10:15","value":1463},{"time":"10:30","value":1768},{"time":"10:45","value":2138},{"time":"11:00","value":2581},{"time":"11:15","value":2974},{"time":"11:30","value":3443},{"time":"11:45","value":3942},{"time":"12:00","value":4388},{"time":"12:15","value":4796},{"time":"12:30","value":5216},{"time":"12:45","value":5632},{"time":"13:00","value":6042},{"time":"13:15","value":6510},{"time":"13:30","value":7091},{"time":"13:45","value":7544},{"time":"14:00","value":7956},{"time":"14:15","value":8370},{"time":"14:30","value":8908},{"time":"14:45","value":9384},{"time":"15:00","value":9843},{"time":"15:15","value":10279},{"time":"15:30","value":10682},{"time":"15:45","value":11102},{"time":"16:00","value":11454},{"time":"16:15","value":11658},{"time":"16:30","value":11808},{"time":"16:45","value":11936},{"time":"17:00","value":12005}]
                                          Du siehst, die Werte steigen von 0Wh um 6:30Uhr auf 12005Wh um 17:00Uhr.
                                          Das ganze sieht grafisch dann so aus:
                                          Das Vis-Widget nimmt diese Liste und erstellt aus benachbarten Werten jeweils die Differenz. Wenn in deiner Liste im o.g. Datenpunkt die Werte irgendwann kleiner werden (z.Bsp. auf 0), dann hast du genau diesen Effekt..
