  4. [gelöst]iobroker auf FreeNAS (FreeBSD)
11 Beiträge 3 Kommentatoren 3.5k Aufrufe
    mrMuppet
    Nachdem ich den ccu.io auf meinem FreeNAS laufen habe, versuchte ich heute den Nachfolger ans Laufen zu bekommen.
    "npm install iobroker" produziert leider folgende Meldung
    > > iobroker@0.7.1 install /node_modules/iobroker
    > node lib/setup.js
    npm install iobroker.js-controller --production --prefix ""
    npm WARN deprecated graceful-fs@3.0.8: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible.
    npm ERR! FreeBSD 9.3-RELEASE-p31
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" ""
    npm ERR! node v5.9.0
    npm ERR! npm  v3.8.2
    npm ERR! Cannot read property 'target' of null
    npm ERR!
    npm ERR! If you need help, you may report this error at:
    npm ERR!     <https: github.com/npm/issues="">npm ERR! Please include the following file with any support request:
    npm ERR!     /node_modules/iobroker/npm-debug.log
    npm install iobroker.admin --production --prefix ""
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin" "--production" "--prefix" ""
    npm ERR! npm  v3.8.2
    npm ERR!
    Could not find "/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
    `-- iobroker@0.7.1
    npm WARN enoent ENOENT: no such file or directory, open '/package.json'
    npm WARN !invalid#1 No description
    npm WARN !invalid#1 No repository field.
    npm WARN !invalid#1 No README data
    npm WARN !invalid#1 No license field.</https:></https:>
    Was kann ich tun?
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • BluefoxB Offline
      BluefoxB Offline
      @mrMuppet:
      > node lib/setup.js
      npm ERR! npm  v3.8.2
      npm ERR!
      npm ERR! npm  v3.8.2
      npm ERR!
      `-- iobroker@0.7.1
      Was kann ich tun? `
      /node_modules/iobroker/npm-debug.log ??
      Da sollte am Ende ein Fehler stehen
        mrMuppet
        Hier ist meine http://pastebin.com/Xnjtcjut
        Wäre spitze wenn da mal einer drüber gucken könnte.
        Vielen Dank!
        • BluefoxB Offline
          BluefoxB Offline
          @mrMuppet:
          Vielen Dank! `
          Ich kann aus dem log nicht nachvollziehen, was schiff gelaufen ist.
          Ich sehe nur, dass ioBroker.admin kann nicht installiert werden.
          Es gibt noch die Möglichkeit das ganze einzeln zu installieren:
          mkdir /opt/iobroker
          sudo chmod 777 /opt/iobroker
          cd /opt/iobroker
          sudo npm install iobroker.js-controller
          sudo npm install iobroker.admin
          sudo chmod -R 777 /opt/iobroker
          cd /opt/iobroker/node_modules/iobroker.js-controller
          node iobroker setup first
          node iobroker start
          Danach sollte man autostart Problem lösen. Aber est ist danach. ;)
            mrMuppet
            @Bluefox:
            mkdir /opt/iobroker
            cd /opt/iobroker
            sudo chmod 777 /opt/iobroker/*.* -R
            node iobroker start
            Vielen Dank! Werde ich nachher mal ausprobieren!
            • N Offline
              N Offline
              nobody
              Hallo Bluefox,
              sollte die Installation denn mittlerweile mit node v5.9.0 ohne Fehler funktionieren? :?
                mrMuppet
                Super! Vielen Dank. Ich habe Node 012 benutzt und die Schritte von Bluefox. Und prompt läuft es! Vielen Dank! Sobald ich auch den Autostart hinbekommen habe werde ich auch ein HowTo für FreeNAS schreiben…
                  mrMuppet
                  Wo kann ich denn eigentlich die ioBroker kommandozeilenbefehle eingeben? Ich kann bei mir nur in "/opt/iobroker/node_modules/iobroker.js-controller" mit node den broker starten, aber zum beispiel der Upload-befehl klappen da nicht, weil er im falschen verzeichnis sucht.
                  Was kann ich tun?
                  • N Offline
                    N Offline
                    nobody
                    normalerweise legt die Installation des npm Pakets für iobroker eine Datei mit dem Namen iobroker im Verzeichnis /usr/bin an.
                    Diese Datei ist ausführbar und enthält die folgende Code-Zeile:
                    node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js $1 $2 $3 $4 $5
                    Das Verzeichnis /usr/bin liegt normalerweise im Pfad des Benutzer-Envrionments.
                    Prüfe mal, ob die Datei da und ausführbar ist und ob das Verzeichnis im Suchpfad ist.
                      mrMuppet
                      @nobody:
                      Prüfe mal, ob die Datei da und ausführbar ist und ob das Verzeichnis im Suchpfad ist. `
                      Die Datei ist leider nicht vorhanden, aber immerhin kann ich jetzt auch mal ein paar kommandorzeilen-parameter mit eingeben…
                      • N Offline
                        N Offline
                        nobody
                        Dann lege die Datei noch einfach mit nano an, kopiere die eine Zeile code rein und ändere die Rechte mit chmod auf ausführbar. Dann sollte es gehen.
                        Gesendet von meinem GT-N8000 mit Tapatalk
