  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 563.0k Aufrufe 72 Beobachtet
  • StrathColeS StrathCole
    @tom57 Mit derselben Meldung?
    tp1de
    #489
    @StrathCole sagte in IOBroker Anbindung an einen Kostal Plenticore:
    Nein .....
    host.iob	2020-03-25 17:51:40.192	info	Restart adapter system.adapter.plenticore.0 because enabled
    host.iob	2020-03-25 17:51:40.191	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
    host.iob	2020-03-25 17:51:39.597	info	instance system.adapter.plenticore.0 started with pid 1909
    host.iob	2020-03-25 17:51:09.547	info	Restart adapter system.adapter.plenticore.0 because enabled
    host.iob	2020-03-25 17:51:09.546	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
    host.iob	2020-03-25 17:51:08.971	info	instance system.adapter.plenticore.0 started with pid 1862
    host.iob	2020-03-25 17:50:38.923	info	Restart adapter system.adapter.plenticore.0 because enabled
    host.iob	2020-03-25 17:50:38.922	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
    host.iob	2020-03-25 17:50:38.373	info	instance system.adapter.plenticore.0 started with pid 1847
    host.iob	2020-03-25 17:50:08.347	info	Restart adapter system.adapter.plenticore.0 because enabled
    host.iob	2020-03-25 17:50:08.347	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
    host.iob	2020-03-25 17:50:07.797	info	instance system.adapter.plenticore.0 started with pid 1831
    host.iob	2020-03-25 17:49:37.773	info	Restart adapter system.adapter.plenticore.0 because enabled
    host.iob	2020-03-25 17:49:37.773	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
    StrathColeS 1 Antwort Letzte Antwort
    • T tp1de
      Nein .....
      StrathColeS Offline
      StrathColeS Offline
      StrathCole
      #490
      @tom57 Hast du ihn mal manuell komplett angehalten und neu gestartet?
      SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
        tp1de
        #491
        Nein hatte nur neu gestartet ....
        Jetzt habe ich Ihn angehalten ... etwas gewartet ... und neu gestartet.
        Jetzt habe ich keine Neustarts mehr.
        Wo ist der Unterschied mit Anhalten zum Neustarten ?
        StrathColeS DiginixD 2 Antworten Letzte Antwort
        • T tp1de
          StrathColeS Offline
          StrathColeS Offline
          StrathCole
          #492
          @tom57 sagte in IOBroker Anbindung an einen Kostal Plenticore:
          Das weiß ich nicht. Ich habe das aber auch manchmal bei Adaptern, die ich aktualisiere, dass ioBroker sie nicht korrekt neu startet und ich dann einmal manuell beenden muss.
            tp1de
            #493
            Ok, wieder was gelernt 😊
            • T tp1de
              DiginixD Offline
              DiginixD Offline
              Diginix
              #494
              In einem solchen Fall läuft dann noch ein Zombiprozess.
              Wenn du den Adapter stoppst und in der Kommandozeile:
              ps auxww | grep plenticore
              ausführst, siehst du ihn. Mit diesem Kommando kann man ihn killen:
              sudo kill -9 $(pidof io.plenticore.0)
              ..:: So long! Tom ::..
              • StrathColeS Offline
                StrathColeS Offline
                StrathCole
                schrieb am zuletzt editiert von StrathCole
                #495
                Ich habe jetzt die aktuelle Version 2.1.0 ins Git und ins NPM repository geladen. Damit sollte sie morgen auch im "latest" von ioBroker auftauchen. Einzige Neuerung seit dem letzten Git-Upload ist das einstellbare minimum MinSoC.
                Zudem habe ich die README auf den neuesten Stand gebracht und auch die Vorhersage etwas erläutert.
                Nun habe ich auch noch eine deutsche Übersetzung der README eingepflegt.
                • BostilB Offline
                  BostilB Offline
                  Bostil
                  #496
                  Jungs, ganz doof gefragt: Bekomme auch bald eine PV-Anlage mit einem Kostal Plenticore plus 8.5 - aber was wird noch benötigt, um die PV-Daten letztlich über iobroker auslesen zu lassen? Blicke hier noch nicht durch ....
                  Danke euch!
                  • BostilB Bostil
                    Danke euch!
                    StrathColeS Offline
                    StrathColeS Offline
                    StrathCole
                    #497
                    @Bostil Der Plenticore muss einfach im selben Netzwerk sein, sodass der ioBroker ihn erreichen kann. Sinnvoll wird es dann auch erst, wenn er mit einem SEM gekoppelt ist.
                    • BostilB Offline
                      BostilB Offline
                      Bostil
                      #498
                      Danke @StrathCole - hieße, der Plenticore bringt fast alles mit, um ihn im iobroker zumindest sichtbar zu machen. Der Plenticore wird einfach per LAN am Router angeschlossen, und ab da an ist es Konfigurationsarbeit? Danke dir.
                      • BostilB Bostil
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        #499
                        @Bostil Im Grunde ist das richtig, ja.
                        BostilB 1 Antwort Letzte Antwort
                        • DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #500
                          @StrathCole Habe heute erst die Logzeile entdeckt:
                          Invalid minimum MinSoC value set. Valid values are from 5 to 100 and lower than maximum MinSoC. Resetting to default (5).
                          Und darauf hin in der Instanz versucht 5% als minMinSOC zu speichern. Wird aber immer mit einem Fehlerdialog quittiert, dass der Wert zw. 5 und 100 und kleiner maxMinSOC sein soll. maxMinSOC ist 20.
                          Erst ab minmin 40 und daher maxmin >40 lässt sich der Dialog speichern.
                          StrathColeS 2 Antworten Letzte Antwort
                          • DiginixD Diginix
                            StrathColeS Offline
                            StrathColeS Offline
                            StrathCole
                            #501
                            @Diginix Komisch. Schau ich mir noch mal an.
                            • DiginixD Diginix
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #502
                              @Diginix Danke für den Hinweis. Problem ist behoben.
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #503
                                @StrathCole Funktioniert
                                  StrathColeS Offline
                                  StrathCole
                                  #504
                                  Gestern und heute hat die "intelligente" Batteriesteuerung zum ersten Mal richtig funktioniert. Allerdings ist sie selbst dann nicht optimal. Warum?
                                  Korrekterweise hat die Steuerung erst spät mit der Batterieladung begonnen (gegen 11 Uhr) und dann auch nur in einer geringen Leistung, sodass gerade keine Leistung der PV verloren ging. Nun kommt das große Aber. Die Batterie wurde in der Nacht bis auf das MinSoC entladen, also 5%. Nun hat die Steuerung aber selbst da morgens nichts in die Batterie gepackt (erwartet hätte ich eine Ladung auf mind. 8-10%, es wurde aber alles eingespeist). Das führte dazu, dass ich ein Verbrauchspeak hatte (10kW), das die PV-Leistung nicht decken konnte, aber die Batterie ebensowenig, weil sie ja schon auf MinSoC war. Ergo: 1kWh Netzbezug.
                                  Unter intelligent verstehe ich wirklich was anderes *seufz
                                  • DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #505
                                    Die Anlage bei mir gehört meinen Eltern und die meinten sie hätten keine 70% Deckelung, sondern lösen die Einspeisung über die Steuererklärung. Dann ist die intelligente Regelung für uns doch unwichtig oder? Im Netz lese ich dass es ohne Begrenzung keine Einspeisung gibt. Habe das aber noch nicht ganz durchblickt.
                                    Oder ist es genau diese Abflachung hier:
                                    Bisher dachte ich die 5500 Watt sind ohnehin mein Maximum, der WR heißt ja auch Plenticore 5.5. Im letzten Sommer wurden die 5500 W auch nie überschritten weil durch die höheren Temp. der Wirkungsgrad geringer war. Nur jetzt bei winterlichten Temp. und voller Sonne habe ich die 7000 W mal angekratzt.
                                    Viel mehr noch stört mich aktuell das nächtliche Nachladen aus dem Netz wenn die 5% SOC unterschritten werden.
                                    StrathColeS T 2 Antworten Letzte Antwort
                                    • DiginixD Diginix
                                      StrathColeS Offline
                                      StrathColeS Offline
                                      StrathCole
                                      #506
                                      @Diginix sagte in IOBroker Anbindung an einen Kostal Plenticore:
                                      So gut kenne ich mich damit zwar nicht aus, aber meines Wissens nach gibt es eine gesetzliche Regelung, dass maximal 70% der maximalen Leistung der PV-Anlage (z. B. ca. 6.900W bei 9,9kWp) eingespeist werden dürfen. Da geht nichts über Steuererklärung etc., das ist gesetzlich so vorgegeben, damit das Netz im Mai/Juni nicht überlastet wird, wenn die Peaks kommen.
                                      Ich glaube, ein 5.5 kann technisch bis zu 25% mehr leisten. Aber genau weiß ich das nicht mehr. Es kommt ja auch auf die installierten kWp der Anlage auf dem Dach an.
                                      Die gezeigte Abflachung könnte genau diese Abriegelung sein, danach sieht es zumindest aus. Technisch scheint deine Anlage ja gut 7kWp zu können. Kannst du theoretisch testen, indem du bei erreichen des Peak-Zeitraums mal einfach für einige Minuten nen Verbraucher wie Wasserkocher, Herd oder Ofen anmachst. Das sollte sich dann als Spitze im Graph zeigen, wenn es an der Abriegelung liegt.
                                      Ja, es gibt ja jetzt die Einstellung für den min. MinSoC. Kannst ja auf 7 oder 8% stellen.
                                      • DiginixD Diginix
                                        tp1de
                                        #507
                                        Das ist so falsch:
                                        Zunächst einmal ist die Wirkleistungsbegrenzung keine bloße Empfehlung, sondern seit 2012 im Erneuerbare-Energien-Gesetz (EEG) festgeschrieben. Als Grund hierfür wird die Gewährleistung der Stromnetzstabilität angegeben.
                                        Es wird aktuell aber nur selten kontrolliert. Das wird sich aber in Zukunft ändern.
                                        D.h. der Anlagenbetrieber / Installateur hat sicherzustellen, dass maximal 70% der installierten kWp-Leistung in das Stromnetz eingespeist wird. Entweder durch Parametrisierung im Wechselrichter oder im KSEM.
                                        Alternativ kann diese Begrenzung entfallen, wenn durch die Stringausrichtung(en) die 70%-Grenze bauartbedingt eingehalten wird.
                                        So ist das bei mir: 4 kWP SO und 3,2 kWp nach NW - Summe 7.2 KWP. 70% sind 5,544 kWp. Ich habe einen Plenticore 5.5.
                                        Damit ist die 70% Grenze erfüllt.
                                          tp1de
                                          schrieb am zuletzt editiert von tp1de
                                          #508
                                          @Diginix
                                          So wie Deine Kurve aussieht sind 7kWp Module installiert und die Begrenzung erfolgt über das Lesitungslimit der Plenticore 5.5 nach ca. einer Stunde mit höherer Last. Die 70% Grenze erfüllst Du damit nicht, die Abregelung muss sofort erfolgen.
                                          Bedenke bitte dass der Betrieb des (zu kleinen) Wechselrichters über längere Zeit am Leistungslimit die Lebensdauer erheblich verkürzen soll. Kostal hat mir gegenüber von einer Halbierung der Lebensdauer gesprochen, als ich überlegt hatte die NW-Module (3kWP) nach SW-Ausrichtung zu verlegen.
