  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 563.0k Aufrufe 72 Beobachtet
  • StrathColeS Offline
    StrathColeS Offline
    StrathCole
    #486
    Okay, lag an was anderem. Habe einen Fix ins Git geladen.
    SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
      tp1de
      #487
      @StrathCole sagte in IOBroker Anbindung an einen Kostal Plenticore:
      Geht nicht - Adapter startet alle 30 Sekunden neu
      StrathColeS 1 Antwort Letzte Antwort
      • T tp1de
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #488
        @tom57 Mit derselben Meldung?
        • StrathColeS StrathCole
          tp1de
          #489
          Nein .....
          host.iob	2020-03-25 17:51:40.192	info	Restart adapter system.adapter.plenticore.0 because enabled
          host.iob	2020-03-25 17:51:40.191	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
          host.iob	2020-03-25 17:51:39.597	info	instance system.adapter.plenticore.0 started with pid 1909
          host.iob	2020-03-25 17:51:09.547	info	Restart adapter system.adapter.plenticore.0 because enabled
          host.iob	2020-03-25 17:51:09.546	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
          host.iob	2020-03-25 17:51:08.971	info	instance system.adapter.plenticore.0 started with pid 1862
          host.iob	2020-03-25 17:50:38.923	info	Restart adapter system.adapter.plenticore.0 because enabled
          host.iob	2020-03-25 17:50:38.922	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
          host.iob	2020-03-25 17:50:38.373	info	instance system.adapter.plenticore.0 started with pid 1847
          host.iob	2020-03-25 17:50:08.347	info	Restart adapter system.adapter.plenticore.0 because enabled
          host.iob	2020-03-25 17:50:08.347	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
          host.iob	2020-03-25 17:50:07.797	info	instance system.adapter.plenticore.0 started with pid 1831
          host.iob	2020-03-25 17:49:37.773	info	Restart adapter system.adapter.plenticore.0 because enabled
          host.iob	2020-03-25 17:49:37.773	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
          • T tp1de
            Nein .....
            StrathColeS Offline
            StrathColeS Offline
            StrathCole
            #490
            @tom57 Hast du ihn mal manuell komplett angehalten und neu gestartet?
              tp1de
              #491
              Nein hatte nur neu gestartet ....
              Jetzt habe ich Ihn angehalten ... etwas gewartet ... und neu gestartet.
              Jetzt habe ich keine Neustarts mehr.
              Wo ist der Unterschied mit Anhalten zum Neustarten ?
              StrathColeS DiginixD 2 Antworten Letzte Antwort
              • T tp1de
                StrathColeS Offline
                StrathColeS Offline
                StrathCole
                #492
                @tom57 sagte in IOBroker Anbindung an einen Kostal Plenticore:
                Das weiß ich nicht. Ich habe das aber auch manchmal bei Adaptern, die ich aktualisiere, dass ioBroker sie nicht korrekt neu startet und ich dann einmal manuell beenden muss.
                  tp1de
                  #493
                  Ok, wieder was gelernt 😊
                  • T tp1de
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #494
                    In einem solchen Fall läuft dann noch ein Zombiprozess.
                    Wenn du den Adapter stoppst und in der Kommandozeile:
                    ps auxww | grep plenticore
                    ausführst, siehst du ihn. Mit diesem Kommando kann man ihn killen:
                    sudo kill -9 $(pidof io.plenticore.0)
                    ..:: So long! Tom ::..
                      StrathColeS Offline
                      StrathCole
                      schrieb am zuletzt editiert von StrathCole
                      #495
                      Ich habe jetzt die aktuelle Version 2.1.0 ins Git und ins NPM repository geladen. Damit sollte sie morgen auch im "latest" von ioBroker auftauchen. Einzige Neuerung seit dem letzten Git-Upload ist das einstellbare minimum MinSoC.
                      Zudem habe ich die README auf den neuesten Stand gebracht und auch die Vorhersage etwas erläutert.
                      Nun habe ich auch noch eine deutsche Übersetzung der README eingepflegt.
                      • BostilB Offline
                        BostilB Offline
                        Bostil
                        #496
                        Jungs, ganz doof gefragt: Bekomme auch bald eine PV-Anlage mit einem Kostal Plenticore plus 8.5 - aber was wird noch benötigt, um die PV-Daten letztlich über iobroker auslesen zu lassen? Blicke hier noch nicht durch ....
                        Danke euch!
                        • BostilB Bostil
                          Danke euch!
                          StrathColeS Offline
                          StrathColeS Offline
                          StrathCole
                          #497
                          @Bostil Der Plenticore muss einfach im selben Netzwerk sein, sodass der ioBroker ihn erreichen kann. Sinnvoll wird es dann auch erst, wenn er mit einem SEM gekoppelt ist.
                          • BostilB Offline
                            BostilB Offline
                            Bostil
                            #498
                            Danke @StrathCole - hieße, der Plenticore bringt fast alles mit, um ihn im iobroker zumindest sichtbar zu machen. Der Plenticore wird einfach per LAN am Router angeschlossen, und ab da an ist es Konfigurationsarbeit? Danke dir.
                            • BostilB Bostil
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #499
                              @Bostil Im Grunde ist das richtig, ja.
                              BostilB 1 Antwort Letzte Antwort
                              • DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #500
                                @StrathCole Habe heute erst die Logzeile entdeckt:
                                Invalid minimum MinSoC value set. Valid values are from 5 to 100 and lower than maximum MinSoC. Resetting to default (5).
                                Und darauf hin in der Instanz versucht 5% als minMinSOC zu speichern. Wird aber immer mit einem Fehlerdialog quittiert, dass der Wert zw. 5 und 100 und kleiner maxMinSOC sein soll. maxMinSOC ist 20.
                                Erst ab minmin 40 und daher maxmin >40 lässt sich der Dialog speichern.
                                StrathColeS 2 Antworten Letzte Antwort
                                • DiginixD Diginix
                                  StrathColeS Offline
                                  StrathColeS Offline
                                  StrathCole
                                  #501
                                  @Diginix Komisch. Schau ich mir noch mal an.
                                  • DiginixD Diginix
                                    StrathColeS Offline
                                    StrathColeS Offline
                                    StrathCole
                                    #502
                                    @Diginix Danke für den Hinweis. Problem ist behoben.
                                      DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #503
                                      @StrathCole Funktioniert
                                        StrathColeS Offline
                                        StrathCole
                                        #504
                                        Gestern und heute hat die "intelligente" Batteriesteuerung zum ersten Mal richtig funktioniert. Allerdings ist sie selbst dann nicht optimal. Warum?
                                        Korrekterweise hat die Steuerung erst spät mit der Batterieladung begonnen (gegen 11 Uhr) und dann auch nur in einer geringen Leistung, sodass gerade keine Leistung der PV verloren ging. Nun kommt das große Aber. Die Batterie wurde in der Nacht bis auf das MinSoC entladen, also 5%. Nun hat die Steuerung aber selbst da morgens nichts in die Batterie gepackt (erwartet hätte ich eine Ladung auf mind. 8-10%, es wurde aber alles eingespeist). Das führte dazu, dass ich ein Verbrauchspeak hatte (10kW), das die PV-Leistung nicht decken konnte, aber die Batterie ebensowenig, weil sie ja schon auf MinSoC war. Ergo: 1kWh Netzbezug.
                                        Unter intelligent verstehe ich wirklich was anderes *seufz
                                        • DiginixD Offline
                                          DiginixD Offline
                                          Diginix
                                          #505
                                          Die Anlage bei mir gehört meinen Eltern und die meinten sie hätten keine 70% Deckelung, sondern lösen die Einspeisung über die Steuererklärung. Dann ist die intelligente Regelung für uns doch unwichtig oder? Im Netz lese ich dass es ohne Begrenzung keine Einspeisung gibt. Habe das aber noch nicht ganz durchblickt.
                                          Oder ist es genau diese Abflachung hier:
                                          Bisher dachte ich die 5500 Watt sind ohnehin mein Maximum, der WR heißt ja auch Plenticore 5.5. Im letzten Sommer wurden die 5500 W auch nie überschritten weil durch die höheren Temp. der Wirkungsgrad geringer war. Nur jetzt bei winterlichten Temp. und voller Sonne habe ich die 7000 W mal angekratzt.
                                          Viel mehr noch stört mich aktuell das nächtliche Nachladen aus dem Netz wenn die 5% SOC unterschritten werden.
                                          StrathColeS T 2 Antworten Letzte Antwort
