  4. simple-api v.2.3.3 'common' of null
errorsimple apicommon of null
14 Beiträge 2 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • GlasfaserG Glasfaser
    @crunchip
    Kann ich bestätigen ... bin auch im latest ...
    Bei mir ist es sporalisch aufgetreten und jetzt nicht mehr .
    Habe noch nichts gefunden woher es kommen könnte
    2020-03-18 00:35:12.725 - info: simple-api.0 (8818) terminating http server on port 8087
    2020-03-18 00:35:12.730 - info: simple-api.0 (8818) terminating
    2020-03-18 00:35:12.731 - info: simple-api.0 (8818) Terminated (NO_ERROR): Without reason
    2020-03-18 00:35:13.301 - error: host.iobrokerv4 Caught by controller[0]: TypeError: Cannot read property 'common' of null
    2020-03-18 00:35:13.301 - error: host.iobrokerv4 Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
    2020-03-18 00:35:13.302 - error: host.iobrokerv4 Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2020-03-18 00:35:13.302 - error: host.iobrokerv4 Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2020-03-18 00:35:13.302 - error: host.iobrokerv4 Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-03-18 00:35:13.302 - info: host.iobrokerv4 instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
    2020-03-18 00:35:13.302 - info: host.iobrokerv4 Restart adapter system.adapter.simple-api.0 because enabled
    2020-03-18 00:35:43.371 - info: host.iobrokerv4 instance system.adapter.simple-api.0 started with pid 31153
    2020-03-18 00:35:45.029 - info: simple-api.0 (31153) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
    2020-03-18 00:35:45.076 - info: simple-api.0 (31153) simpleAPI server listening on port 8087
    2020-03-18 00:35:45.077 - info: simple-api.0 (31153) Allow states only when user is owner: false
    2020-03-18 00:35:45.081 - info: simple-api.0 (31153) http server listening on port 8087
    2020-03-18 00:36:13.104 - error: simple-api.0 (31153) uncaught exception: Cannot read property 'common' of null
    2020-03-18 00:36:13.105 - error: simple-api.0 (31153) TypeError: Cannot read property 'common' of null
    2020-03-18 00:36:13.106 - info: simple-api.0 (31153) terminating http server on port 8087
    2020-03-18 00:36:13.116 - info: simple-api.0 (31153) terminating
    2020-03-18 00:36:13.117 - info: simple-api.0 (31153) Terminated (NO_ERROR): Without reason
    2020-03-18 00:36:13.665 - error: host.iobrokerv4 Caught by controller[0]: TypeError: Cannot read property 'common' of null
    2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
    2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-03-18 00:36:13.667 - info: host.iobrokerv4 instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
    2020-03-18 00:36:13.667 - info: host.iobrokerv4 Restart adapter system.adapter.simple-api.0 because enabled
    2020-03-18 19:48:42.427 - error: simple-api.0 (2501) uncaught exception: Cannot read property 'common' of null
    2020-03-18 19:48:42.429 - error: simple-api.0 (2501) TypeError: Cannot read property 'common' of null
    2020-03-18 19:48:42.430 - info: simple-api.0 (2501) terminating http server on port 8087
    2020-03-18 19:48:42.515 - info: simple-api.0 (2501) terminating
    2020-03-18 19:48:42.516 - info: simple-api.0 (2501) Terminated (NO_ERROR): Without reason
    2020-03-18 19:48:43.086 - error: host.iobrokerv4 Caught by controller[0]: TypeError: Cannot read property 'common' of null
    2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
    2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    2020-03-18 19:48:43.087 - info: host.iobrokerv4 instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
    2020-03-18 19:48:43.087 - info: host.iobrokerv4 Restart adapter system.adapter.simple-api.0 because enabled
    2020-03-18 19:48:43.218 - info: sql.0 (17756) disabled logging of daswetter.0.NextHours.Location_1.Day_1.tempmax_value
    2020-03-18 19:49:13.171 - info: host.iobrokerv4 instance system.adapter.simple-api.0 started with pid 3946
    2020-03-18 19:49:14.766 - info: simple-api.0 (3946) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
    2020-03-18 19:49:14.809 - info: simple-api.0 (3946) simpleAPI server listening on port 8087
    2020-03-18 19:49:14.810 - info: simple-api.0 (3946) Allow states only when user is owner: false
    2020-03-18 19:49:14.814 - info: simple-api.0 (3946) http server listening on port 8087
    crunchipC Abwesend
    crunchipC Abwesend
    @Glasfaser bekomme die oben genannte Meldung auch, wenn IoBroker neu gestartet wurde
    desweiteren habe ich auch gelegentlich die Meldung
    web.0	2020-03-21 14:44:34.274	warn	(3060) Empty pattern!
    wenn ich im web Adapter socketio integriert auf socketio stelle, bekomme ich das Empty pattern! dann beim socketio Adapter
      GlasfaserG Offline
      GlasfaserG Offline
      @crunchip
      Die Meldung habe ich seit Tagen bemerkt und versucht es rauszufinden .
      Aber nur jetzt kommen Sie nicht mehr , habe auch nicht´s geändert 🤔
      Die Meldungen kamen aber nicht bei einem Neustart.
      Habe so meine Einstellungen ... aber wie gesagt alles Top ...
      Den Adapter ( Instanz) socket.io habe ich nicht an .
        @crunchip
        crunchipC Abwesend
        crunchipC Abwesend
        @Glasfaser bei mir ist eine Datenbank angegeben und alle Datenpunkte auflisten haken gesetzt, da man dadurch siehe hier auch Daten direkt holen kann.
          GlasfaserG Offline
          GlasfaserG Offline
          @crunchip
          Danke für den Tip ... schau ich mir an 👍
          • crunchipC Abwesend
            crunchipC Abwesend
            nachdem ich heute mal mein Tablet neugestartet habe, kamen wieder die Fehlermeldung in mehrfacher Ausführung,
            also gehe ich davon aus, ...wenn Gerät nicht erreichbar...,
            bleibt die Frage, warum häufig aber nicht immer, genau um 0:04Uhr,
            zumal in Vorgängerversionen eine solche Meldung nicht kam, wenn das Tablet neu gestartet/nicht erreichbar war,
            zumindest fiel es mir nicht bewusst auf
            auch die Fehlermeldungen ziehen sich von 15:38 - 16:04 kann also auch nicht allein am Neustart des Tablets liegen
            2020-03-25 15:38:51.385  - error: simple-api.0 (6321) uncaught exception: Cannot read property 'common' of null
            2020-03-25 15:38:51.387  - error: simple-api.0 (6321) TypeError: Cannot read property 'common' of null
            2020-03-25 15:38:51.389  - info: simple-api.0 (6321) terminating http server on port 8087
            2020-03-25 15:38:51.413  - info: simple-api.0 (6321) terminating
            2020-03-25 15:38:51.416  - info: simple-api.0 (6321) Terminated (NO_ERROR): Without reason
            2020-03-25 15:38:52.100  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 15:38:52.102  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 15:38:52.102  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 15:38:52.103  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 15:38:52.103  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 15:38:52.103  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:38:52.103  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 15:39:00.127  - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 15993
            2020-03-25 15:39:22.159  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 16017
            2020-03-25 15:39:25.254  - info: simple-api.0 (16017) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 15:39:25.329  - info: simple-api.0 (16017) simpleAPI server listening on port 8087
            2020-03-25 15:39:25.330  - info: simple-api.0 (16017) Allow states only when user is owner: false
            2020-03-25 15:39:25.337  - info: simple-api.0 (16017) http server listening on port 8087
            2020-03-25 15:39:34.492  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 379, >= Schwelle von 20
            2020-03-25 15:39:36.829  - error: simple-api.0 (16017) uncaught exception: Cannot read property 'common' of null
            2020-03-25 15:39:36.830  - error: simple-api.0 (16017) TypeError: Cannot read property 'common' of null
            2020-03-25 15:39:36.832  - info: simple-api.0 (16017) terminating http server on port 8087
            2020-03-25 15:39:37.835  - warn: simple-api.0 (16017) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2020-03-25 15:39:39.458  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 15:39:39.459  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 15:39:39.460  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 15:39:39.460  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 15:39:39.460  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 15:39:39.461  - error: host.IoBroker instance system.adapter.simple-api.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2020-03-25 15:39:39.462  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 15:40:00.103  - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 16202
            2020-03-25 15:40:00.551  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittel-RRS: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/bayern.rss eingelesen
            2020-03-25 15:40:00.573  - info: javascript.0 (1649) script.js.Visualisierung.Newsfeed_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
            2020-03-25 15:40:06.707  - error: daswetter.0 (15993) force terminate, objects still in list: 84
            2020-03-25 15:40:06.710  - warn: daswetter.0 (15993) Terminated (15): Without reason
            2020-03-25 15:40:07.249  - error: host.IoBroker instance system.adapter.daswetter.0 terminated with code 15 (15)
            2020-03-25 15:40:09.749  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 16357
            2020-03-25 15:40:13.706  - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:40:16.467  - info: simple-api.0 (16357) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 15:40:16.603  - info: simple-api.0 (16357) simpleAPI server listening on port 8087
            2020-03-25 15:40:16.604  - info: simple-api.0 (16357) Allow states only when user is owner: false
            2020-03-25 15:40:16.610  - info: simple-api.0 (16357) http server listening on port 8087
            2020-03-25 15:40:39.603  - error: simple-api.0 (16357) uncaught exception: Cannot read property 'common' of null
            2020-03-25 15:40:39.605  - error: simple-api.0 (16357) TypeError: Cannot read property 'common' of null
            2020-03-25 15:40:39.606  - info: simple-api.0 (16357) terminating http server on port 8087
            2020-03-25 15:40:40.481  - info: simple-api.0 (16357) terminating
            2020-03-25 15:40:40.483  - info: simple-api.0 (16357) Terminated (NO_ERROR): Without reason
            2020-03-25 15:40:40.560  - info: simple-api.0 (16357) terminating
            2020-03-25 15:40:40.878  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 378, >= Schwelle von 20
            2020-03-25 15:40:41.051  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 15:40:41.052  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 15:40:41.052  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 15:40:41.052  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 15:40:41.053  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 15:40:41.053  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:40:41.053  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 15:41:11.100  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 16688
            2020-03-25 15:41:14.158  - info: simple-api.0 (16688) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 15:41:14.277  - info: simple-api.0 (16688) simpleAPI server listening on port 8087
            2020-03-25 15:41:14.278  - info: simple-api.0 (16688) Allow states only when user is owner: false
            2020-03-25 15:41:14.284  - info: simple-api.0 (16688) http server listening on port 8087
            2020-03-25 15:41:39.560  - error: simple-api.0 (16688) uncaught exception: Cannot read property 'common' of null
            2020-03-25 15:41:39.561  - error: simple-api.0 (16688) TypeError: Cannot read property 'common' of null
            2020-03-25 15:41:39.563  - info: simple-api.0 (16688) terminating http server on port 8087
            2020-03-25 15:41:40.374  - info: simple-api.0 (16688) terminating
            2020-03-25 15:41:40.376  - info: simple-api.0 (16688) Terminated (NO_ERROR): Without reason
            2020-03-25 15:41:40.382  - info: simple-api.0 (16688) terminating
            2020-03-25 15:41:41.120  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 15:41:41.121  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 15:41:41.121  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 15:41:41.122  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 15:41:41.122  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 15:41:41.122  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:41:41.122  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 15:41:58.275  - info: coronavirus-statistics.0 (15208) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2020-03-25 15:41:58.818  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2020-03-25 15:42:11.077  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Esstisch: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 111, >= Schwelle von 20
            2020-03-25 15:42:11.181  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 17019
            2020-03-25 15:42:13.696  - info: simple-api.0 (17019) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 15:42:13.809  - info: simple-api.0 (17019) simpleAPI server listening on port 8087
            2020-03-25 15:42:13.810  - info: simple-api.0 (17019) Allow states only when user is owner: false
            2020-03-25 15:42:13.818  - info: simple-api.0 (17019) http server listening on port 8087
            2020-03-25 15:42:34.081  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Esstisch: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 143, >= Schwelle von 20
            2020-03-25 15:42:47.862  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Esstisch: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 144, >= Schwelle von 20
            2020-03-25 15:43:07.370  - info: iogo.0 (1615) device update received: {"alive":false,"batteryCharging":false,"batteryLevel":70,"name":"S10+","token":"f4Oce5GiBFM:APA91bHU9SFepK3mvxNHFO_dqfGUzIBv0AIpDnOzaMKPUlmzlJg8VwzLHYkKlypOkIwkwHVHfX9Gqn22FFs4286QcifPhj1tuWnj4GIf1HTyRZtFbrb_5CmgJ8xxE-C9OqLUrChq7l5c","ts":1585147384429}
            2020-03-25 15:43:07.590  - info: iogo.0 (1615) user Mario changed
            2020-03-25 15:45:00.061  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 started with pid 17840
            2020-03-25 15:45:05.300  - info: coronavirus-statistics.0 (17840) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
            2020-03-25 15:47:37.030  - info: coronavirus-statistics.0 (17840) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2020-03-25 15:47:37.551  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2020-03-25 15:47:45.329  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 364, >= Schwelle von 20
            2020-03-25 15:48:00.111  - info: host.IoBroker instance system.adapter.dwd.0 started with pid 18773
            2020-03-25 15:48:08.719  - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:50:00.108  - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 19556
            2020-03-25 15:50:00.527  - info: javascript.0 (1649) script.js.Visualisierung.Newsfeed_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
            2020-03-25 15:50:00.536  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittel-RRS: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/bayern.rss eingelesen
            2020-03-25 15:50:09.998  - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:51:22.850  - info: host.IoBroker stopInstance system.adapter.coronavirus-statistics.0 (force=false, process=false)
            2020-03-25 15:51:22.852  - info: host.IoBroker stopInstance canceled schedule system.adapter.coronavirus-statistics.0
            2020-03-25 15:51:25.358  - info: host.IoBroker instance scheduled system.adapter.coronavirus-statistics.0 */15 * * * *
            2020-03-25 15:51:25.408  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 started with pid 19896
            2020-03-25 15:51:30.352  - info: coronavirus-statistics.0 (19896) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
            2020-03-25 15:52:00.115  - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 20079
            2020-03-25 15:52:52.571  - info: host.IoBroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2020-03-25 15:54:04.236  - info: info.0 (1596) Popup news was read...
            2020-03-25 15:54:11.452  - info: coronavirus-statistics.0 (19896) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2020-03-25 15:54:11.995  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2020-03-25 15:58:24.393  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 364, >= Schwelle von 20
            2020-03-25 15:59:39.021  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 344, >= Schwelle von 20
            2020-03-25 16:00:00.060  - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 22591
            2020-03-25 16:00:00.785  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittel-RRS: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/bayern.rss eingelesen
            2020-03-25 16:00:00.798  - info: javascript.0 (1649) script.js.Visualisierung.Newsfeed_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
            2020-03-25 16:00:04.205  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 started with pid 22736
            2020-03-25 16:00:07.811  - warn: daswetter.0 (22591) no connection to objects DB
            2020-03-25 16:00:08.459  - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 22754
            2020-03-25 16:00:10.106  - warn: daswetter.0 (22591) no connection to states DB
            2020-03-25 16:00:10.086  - warn: coronavirus-statistics.0 (22736) no connection to states DB
            2020-03-25 16:00:12.569  - info: host.IoBroker instance system.adapter.dwd.0 started with pid 22792
            2020-03-25 16:00:13.810  - info: coronavirus-statistics.0 (22736) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
            2020-03-25 16:00:17.360  - info: host.IoBroker instance system.adapter.ical.0 started with pid 22816
            2020-03-25 16:00:21.224  - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:00:25.892  - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:00:34.573  - info: host.IoBroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:01:10.973  - error: simple-api.0 (17019) uncaught exception: Cannot read property 'common' of null
            2020-03-25 16:01:10.975  - error: simple-api.0 (17019) TypeError: Cannot read property 'common' of null
            2020-03-25 16:01:10.977  - info: simple-api.0 (17019) terminating http server on port 8087
            2020-03-25 16:01:11.662  - info: simple-api.0 (17019) terminating
            2020-03-25 16:01:11.663  - info: simple-api.0 (17019) Terminated (NO_ERROR): Without reason
            2020-03-25 16:01:11.667  - info: simple-api.0 (17019) terminating
            2020-03-25 16:01:12.248  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 16:01:12.249  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 16:01:12.250  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 16:01:12.250  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 16:01:12.250  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 16:01:12.250  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:01:12.251  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 16:01:13.333  - error: daswetter.0 (22591) force terminate, objects still in list: 314
            2020-03-25 16:01:13.338  - warn: daswetter.0 (22591) Terminated (15): Without reason
            2020-03-25 16:01:13.874  - error: host.IoBroker instance system.adapter.daswetter.0 terminated with code 15 (15)
            2020-03-25 16:01:42.304  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 23305
            2020-03-25 16:01:45.882  - info: simple-api.0 (23305) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 16:01:46.005  - info: simple-api.0 (23305) simpleAPI server listening on port 8087
            2020-03-25 16:01:46.007  - info: simple-api.0 (23305) Allow states only when user is owner: false
            2020-03-25 16:01:46.015  - info: simple-api.0 (23305) http server listening on port 8087
            2020-03-25 16:01:57.788  - error: simple-api.0 (23305) uncaught exception: Cannot read property 'common' of null
            2020-03-25 16:01:57.789  - error: simple-api.0 (23305) TypeError: Cannot read property 'common' of null
            2020-03-25 16:01:57.791  - info: simple-api.0 (23305) terminating http server on port 8087
            2020-03-25 16:01:57.808  - info: simple-api.0 (23305) terminating
            2020-03-25 16:01:57.810  - info: simple-api.0 (23305) Terminated (NO_ERROR): Without reason
            2020-03-25 16:01:58.382  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 16:01:58.383  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:01:58.383  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 16:02:11.022  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 335, >= Schwelle von 20
            2020-03-25 16:02:28.430  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 23644
            2020-03-25 16:02:32.062  - info: simple-api.0 (23644) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 16:02:32.143  - info: simple-api.0 (23644) simpleAPI server listening on port 8087
            2020-03-25 16:02:32.145  - info: simple-api.0 (23644) Allow states only when user is owner: false
            2020-03-25 16:02:32.151  - info: simple-api.0 (23644) http server listening on port 8087
            2020-03-25 16:03:01.254  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittelwarnung: Daten aktualisiert...
            2020-03-25 16:03:03.436  - error: simple-api.0 (23644) uncaught exception: Cannot read property 'common' of null
            2020-03-25 16:03:03.437  - error: simple-api.0 (23644) TypeError: Cannot read property 'common' of null
            2020-03-25 16:03:03.439  - info: simple-api.0 (23644) terminating http server on port 8087
            2020-03-25 16:03:03.569  - info: simple-api.0 (23644) terminating
            2020-03-25 16:03:03.577  - info: simple-api.0 (23644) Terminated (NO_ERROR): Without reason
            2020-03-25 16:03:04.163  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 16:03:04.164  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 16:03:04.165  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 16:03:04.165  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 16:03:04.165  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 16:03:04.165  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:03:04.165  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 16:03:12.191  - info: coronavirus-statistics.0 (22736) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2020-03-25 16:03:12.844  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2020-03-25 16:03:34.237  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 23974
            2020-03-25 16:03:37.002  - info: simple-api.0 (23974) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 16:03:37.093  - info: simple-api.0 (23974) simpleAPI server listening on port 8087
            2020-03-25 16:03:37.094  - info: simple-api.0 (23974) Allow states only when user is owner: false
            2020-03-25 16:03:37.100  - info: simple-api.0 (23974) http server listening on port 8087
            2020-03-25 16:04:06.373  - error: simple-api.0 (23974) uncaught exception: Cannot read property 'common' of null
            2020-03-25 16:04:06.384  - error: simple-api.0 (23974) TypeError: Cannot read property 'common' of null
            2020-03-25 16:04:06.386  - info: simple-api.0 (23974) terminating http server on port 8087
            2020-03-25 16:04:06.647  - info: simple-api.0 (23974) terminating
            2020-03-25 16:04:06.648  - info: simple-api.0 (23974) Terminated (NO_ERROR): Without reason
            2020-03-25 16:04:07.231  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
            2020-03-25 16:04:07.233  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
            2020-03-25 16:04:07.233  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            2020-03-25 16:04:07.233  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            2020-03-25 16:04:07.234  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
            2020-03-25 16:04:07.234  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
            2020-03-25 16:04:07.234  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
            2020-03-25 16:04:37.284  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 24305
            2020-03-25 16:04:40.791  - info: simple-api.0 (24305) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
            2020-03-25 16:04:40.869  - info: simple-api.0 (24305) simpleAPI server listening on port 8087
            2020-03-25 16:04:40.871  - info: simple-api.0 (24305) Allow states only when user is owner: false
            2020-03-25 16:04:40.876  - info: simple-api.0 (24305) http server listening on port 8087
              GlasfaserG Offline
              GlasfaserG Offline
              @crunchip sagte in simple-api v.2.3.3 'common' of null:
              Ich habe ja die Einstellungen (noch) nicht geändert , da ja zur Zeit alles läuft und keine Fehlermeldung mehr kommen ...
              Hast du es mal so getestet wie ich die Einstellungen habe , ob der Fehler dann noch kommt .
              Es sieht so aus als würde der simple-api Adapter immer zusammenbrechen ( zu viele Ereignisse)
                crunchipC Abwesend
                crunchipC Abwesend
                @Glasfaser du meinst den externen simple ausschalten und den internen im Web Adapter verwenden?
                kann ich mal testen
                  kann ich mal testen
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @crunchip
                  Jipp ... alle Einstellungen wie ich oben alle im Screenshot habe .
                  Simple und Web Adapter
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @Glasfaser also trotzdem den Simple-api Adapter an?
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @crunchip
                      Ja ..
                      ich habe nur die Adapter Simple-Api und Web an , den socketio Adapter habe ich aus.
                        @crunchip
                        Ja ..
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @Glasfaser dann hast ja den simple doppelt, extern und intigriert?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @crunchip
                          Die Einstellungen habe ich schon immer so .
