  4. deconz funktioniert nach update nicht mehr
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
deconz
74 Beiträge 15 Kommentatoren 11.0k Aufrufe 14 Beobachtet
  • D dehein2
    Typ: js-controller
    Titel: JS controller
    OS: linux
    Verfügbar: 2.2.9
    Installiert: 2.2.8
    Ereignisse: ↦28 / ↦15
    Sieht also gut aus
    Jey CeeJ Offline
    Jey CeeJ Offline
    Jey Cee
    @dehein2 ok dann hilft nur Adapter löschen und neu installieren. Da wurde die Config des Adapters nicht neu geschrieben.
    Das scheint manchmal nicht zu klappen.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
      dehein2
      schrieb am zuletzt editiert von dehein2
      @Jey-Cee:
      Leider hat es nichts gebracht. Musste alle Einstellungen neu eingeben
      deconz.0	2020-03-09 22:50:22.270	debug	(1576) Code 200: Request succeded get group attributes 29013: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["1
      deconz.0	2020-03-09 22:50:22.263	debug	(1576) Code 200: Request succeded get group attributes 25738: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["1
      deconz.0	2020-03-09 22:50:22.253	debug	(1576) Code 200: Request succeded get group attributes 1721: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"
      deconz.0	2020-03-09 22:50:22.244	debug	(1576) Code 200: Request succeded get group attributes 1390: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["19
      deconz.0	2020-03-09 22:50:21.983	info	(1576) Code 404: Ressource not found get devices: []
      deconz.0	2020-03-09 22:50:21.980	debug	(1576) Code 200: Request succeded get all groups: {"1390":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["19"],
      deconz.0	2020-03-09 22:50:21.924	debug	(1576) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"2069ee2989febcb5fb37f35845d9baa8","manufacturername":"Phi
      deconz.0	2020-03-09 22:50:21.865	debug	(1576) Code 200: Request succeded get all lights: {"1":{"ctmax":454,"ctmin":250,"etag":"df9eddfa064381605844abb1057c1046","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb G
      deconz.0	2020-03-09 22:50:21.840	info	(1576) deConz Version: 2.5.71; API version: 1.16.0
      deconz.0	2020-03-09 22:50:21.838	debug	(1576) Code 200: Request succeded get config: {"UTC":"2020-03-09T21:50:21","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF0325F5","datastoreversion":"60","devic
      deconz.0	2020-03-09 22:50:21.726	info	(1576) starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.18.1
      deconz.0	2020-03-09 22:50:20.763	debug	(1576) statesDB connected
      deconz.0	2020-03-09 22:50:20.762	debug	(1576) States connected to redis: 127.0.0.1:9000
      deconz.0	2020-03-09 22:50:20.749	debug	(1576) States create System PubSub Client
      deconz.0	2020-03-09 22:50:20.747	debug	(1576) States create User PubSub Client
      deconz.0	2020-03-09 22:50:20.738	debug	(1576) Redis States: Use Redis connection: 127.0.0.1:9000
      deconz.0	2020-03-09 22:50:20.735	debug	(1576) objectDB connected
      deconz.0	2020-03-09 22:50:20.729	debug	(1576) Objects connected to redis: 127.0.0.1:9001
      deconz.0	2020-03-09 22:50:20.712	debug	(1576) Objects client initialize lua scripts
      deconz.0	2020-03-09 22:50:20.711	debug	(1576) Objects create User PubSub Client
      deconz.0	2020-03-09 22:50:20.710	debug	(1576) Objects create System PubSub Client
      deconz.0	2020-03-09 22:50:20.705	debug	(1576) Objects client ready ... initialize now
      deconz.0	2020-03-09 22:50:20.668	debug	(1576) Redis Objects: Use Redis connection: 127.0.0.1:9001
      Im Tab Geräte und Gruppen taucht auch alles auf
      • D dehein2
        @Jey-Cee:
        haselchenH Offline
        haselchenH Offline
        haselchen
        @dehein2
        Mein Rat und Empfehlung ist und bleibt Js Controller auf 2.2.9 updaten und Nodejs auf 10.19 aktualisieren.
        • H Offline
          hilde0407
          schrieb am zuletzt editiert von hilde0407
          Also, ich hatte heute das Problem auch. Ich hatte aber auch deconz (vm) aktualisiert. Bei der Aktualisierung von deconz wurde der Port, über den die Oberfläche erreichbar ist, ungefragt auf den Port 80 gelegt, da Du ebenfalls den Port manuell geändert haben könntest, könnte da das selbe Problem liegen! Versuche einfach mal die Weboberfläche zu erreichen und schau nach, ob die über den Port 80 erreichbar ist (oder ohne Port, da dies der übliche http Port ist! Wenn die Weboberfläche so erreichbar ist, musst Du in der VM die Config erneut anpassen, oder Du trägst im Adapter den Port 80 ein und lässt einen neuen App Key generieren!
          siggi85S 1 Antwort Letzte Antwort
          • H hilde0407
            siggi85S Offline
            siggi85S Offline
            siggi85
            Bei mir wurden die Einstellungen auch nicht übernommen. Ich musste gestern nach dem Update auch den Port und den API Key neu generieren lassen. Danach hat aber alles wieder einwandfrei funktioniert.
            Habe js 2.2.9 und nodejs auf 10.19, also alles aktuell.
              dehein2
              @haselchen Habe auf 2.2.9 aktualisiert .. leider ohne Erfolg
              Node js sieht wie folgt aus:
              pi@deheinIOBroker:~ $ node -v
              v10.18.1
              pi@deheinIOBroker:~ $ nodejs -v
              v10.18.1
              • D dehein2
                v10.18.1
                v10.18.1
                haselchenH Offline
                haselchenH Offline
                haselchen
                @dehein2
                10.19 wäre die nächste Version
                • X Offline
                  X Offline
                  Xyolyp
                  schrieb am zuletzt editiert von Xyolyp
                  Ich habe das gleiche Problem und habe
                  Nodejs 10.19.0
                  JS Controller 2.2.9
                  deconz 1.2.6
                  Auch einen neuen API Key generieren hat keine Abhilfe gebracht.
                  Lediglich mit einem Rollback auf die 1.1.2 und löschen und neu anlegen der Instanz ließ sich das Problem vorerst beheben.
                  Das ist leider nicht ganz das was ich mir vom Stable Repo vorstelle.
                    dehein2
                    bei mir leider ebenfalls kein erfolg. @Xyolyp: wie kann ich denn eine ältere Version installieren?
                    • Jey CeeJ Offline
                      Jey CeeJ Offline
                      Jey Cee
                      @Xyolyp oder @dehein2 bei wem von euch könnte ich mal drüber schauen per remote?
                      Ich konnte den Fehler bei mir nicht reproduzieren und es scheint als wäre es kein generelles Problem, die Version hat immerhin schon ~1000 Aktive installationen.
                      • D dehein2
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @dehein2
                        Ist denn das Problem , dass eure Instanz nicht grün wird mit den aktuellen Versionen, immer noch vorhanden?
                        Muss da @Jey-Cee zustimmen, ich habe da auch keine Probleme.
                        Liegt dann wohl an den individuellen Gegebenheiten des einzelnen Systems.
                          dehein2
                          @Jey-Cee: Ja bei mir gerne. Allerdings bin ich immer erst abends nach 21:00 wirklich am PC
                          @haselchen: ja genau - immernoch gelb
                          X 1 Antwort Letzte Antwort
                          • D dehein2
                            X Offline
                            X Offline
                            Xyolyp
                            @dehein2 Wenn du in der Adapterliste oben den Expertenmodus aktivierst kannst du neben dem Adapter rechts auf das Quadrat klicken und eine spezifische Version installieren.
                            • W Online
                              W Online
                              Wildbill
                              habe vorhin auch den deconz-Adapter von 1.1.2 (glaube ich) auf 1.2.6 upgedated, weil es im stable angeboten wurde. Adapter wurde anschliessend nicht mehr grün, keine Meldungen im Log, steuern ging. Habe dann gesehen, dass ich Deconz/Phoscon auf 2.05.74 updaten kann und habe das gemacht. Ergebnis unverändert. Habe dann testhable 1.1.2 zurück geholt aber auch der blieb geld. Steuern ging. Habe den Adapter anschließend komplett gelöscht, iobroker neu gebootet und anschließend den 1.2.6 installiert. Ergebnis: Er bleibt geld, ich kann von iobroker aus alles steuern, aber alles, was in Phoscon passiert (Lampen an durch BWM/Fernbedienung, Strom aus an) bekommt iobroker nicht mehr mit.
                              Hier das Log vom Start des Adapters, er läuft danach mit Status gelb und ohne Änderungen aus deconz mitzubekommen, kann aber alles steuern:
                              2020-03-11 19:04:13.349  - ^[[32minfo^[[39m: deconz.0 (2344) starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0
                              2020-03-11 19:04:27.810  - ^[[32minfo^[[39m: host.iobroker stopInstance system.adapter.deconz.0 (force=false, process=true)
                              2020-03-11 19:04:27.811  - ^[[32minfo^[[39m: host.iobroker stopInstance system.adapter.deconz.0 send kill signal
                              2020-03-11 19:04:27.816  - ^[[32minfo^[[39m: deconz.0 (2344) Got terminate signal TERMINATE_YOURSELF
                              2020-03-11 19:04:27.818  - ^[[32minfo^[[39m: deconz.0 (2344) terminating
                              2020-03-11 19:04:27.819  - ^[[32minfo^[[39m: deconz.0 (2344) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2020-03-11 19:04:28.335  - ^[[32minfo^[[39m: host.iobroker instance system.adapter.deconz.0 terminated with code 156 (156)
                              2020-03-11 19:04:30.320  - ^[[32minfo^[[39m: host.iobroker instance system.adapter.deconz.0 started with pid 2362
                              2020-03-11 19:04:32.503  - ^[[32minfo^[[39m: deconz.0 (2362) starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0
                              2020-03-11 19:04:32.582  - ^[[33mwarn^[[39m: deconz.0 (2362) No API Key found
                              Log auf debug brachte auch nicht mehr erhellendes, es kommen nur zusätzlich die ganzen Befehöe. wenn iobroker was ansteuert.
                              Wo kann ich noch ansetzen?
                              Gruss, Jürgen
                              • W Online
                                W Online
                                Wildbill
                                schrieb am zuletzt editiert von Wildbill
                                Kleines Update. Da meine Fernbedienungen auch nicht mehr gingen habe ich, Proxmox sei Dank, das Backup eingespielt, mit deconz-Adapter auf 1.1.2. Die VM gestartet und sofort war der deconz-Adapter grün (ohne neuen API-Key) hat alle states von deconz übernommen und bekommt Änderungen auch wieder mit. Deconz ist (und bleibt) auf 2.05.74, da es daran ja augenscheinlich nicht lag, da es mit der vorherigen Version und der 1.2.6 ja auch nicht lief.
                                Irgendwas ist zwischen 1.1.2 und 1.2.6 so dermaßen anders, dass der Adapter auch bei mir nicht mehr will.
                                Ich bleibe erstmal auf 1.1.2, auch wenn stable ja eigentlich stable sein sollte...
                                Gruss, Jürgen
                                • W Wildbill
                                  Gruss, Jürgen
                                  Jey CeeJ Offline
                                  Jey CeeJ Offline
                                  Jey Cee
                                  @Wildbill das Grundlegendes anders ist war der Sinn des Updates. Wie zum Beispiel die Anzeige ob verbunden oder nicht. Da es überhaupt nicht geprüft wurde und die Verbindung nur beim Starten aufgebaut wurde. Was dazu führt das eine Unterbrochene Verbindung gar nicht erkannt wurde.
                                  Wenn du beim Downgrade den Adapter nicht gelöscht hast war noch immer das Objekt für diese Verbindunganzeige da und deswegen war der Adapter Gelb.
                                  "No API Key found" ist eine relevante info, aber ich geh davon aus du hast den API Key in der Config eingetragen nachdem du das Log kopiert hast.
                                  Welche js- controller version hast du?
                                  • W Online
                                    W Online
                                    Wildbill
                                    @Jey-Cee
                                    JS-Controller ist 2.29, npm ist 6.8.0 und node/nodejs ist 10.19.0.
                                    Vor dem Log hatte ich den Deconz-Adapter komplett gelöscht, einmal unter Instanzen und einmal unter Adapter. Danach reboot und dann komplett neu installiert, natürlich inlusive neuem API-Key. Danach konnte ich vom iobroker aus alles in deconz steuern, aber von deconz kam nichts in iobroker an und der Adapter blieb gelb, aber keine weiteren Meldungen im Log, trotz Level Debug. Nur halt die Meldungen, wenn iobroker was an deconz raus schickt.
                                    Bin gerne morgen Abend bereit, einen neuen Versuch zu wagen, Proxmox macht es ja leicht. Dann allerdings möglichst mit genauen Anweisungen, was ich wann wo zu löschen bzw. zu installieren habe und gerne auch mit Neustarts dazwischen, falls nötig. Deconz möchte ich aber unverändert auf der neuen Version lassen. Da läuft parallel noch mehr und mit dem alten deconz-Adapter läuft es ja auch problemlos mit der 2.05.74.
                                    Gruss, Jürgen
                                    • W Wildbill
                                      @Jey-Cee
                                      Gruss, Jürgen
                                      Jey CeeJ Offline
                                      Jey CeeJ Offline
                                      Jey Cee
                                      @Wildbill bei @dehein2 ist das Problem jetzt weg. Bei ihm lief deConz in einem Container, läuft es bei dir auch in einem Conatiner und wie sieht das Port mapping deiner VM für den Websocket Port aus?
                                      Außerdem gab es ein Problem mit der Config, ioBroker hat gemeckert das er keine finden konnte. Sie war aber da, Adapter gelöscht und neu installiert dann lief es. Ich hab wirklich keine Erklärung dafür.
                                      • W Online
                                        W Online
                                        Wildbill
                                        @Jey-Cee
                                        Nein, Phoscon/Deconz läuft nativ direkt auf einem Raspberry, zusammen mit Pivccu. Da ich für Homematic das Aufsteck-Modul für den Raspi verwende läuft der eh und ich wollte die Lichtsteuerung abseits vom Proxmox-Server, damit diese auch noch das wichtigste steuern kann (Bewegungsmelder mit Lichtern), wenn Proxmox der die iobroker-vm mal down sind. Wie man sieht, kommt sowas ja doch mal vor... 😊 Also kein Portmapping, Deconz lauscht laut netstat auf den Ports 80, 443 und 1900. Und das nur auf der IPv4-Adresse. Daran hat sich durch das Update nichts geändert, das war mit der vorherigen Deconz-Version auch schon so.
                                        Es läuft deconz-gui, da der Raspi von früher her einen Desktop hatte und es ganz geschickt ist, mal eben direkt in der Deconz-Software rumzuspielen (z.B. Firmware updates) ohne sich vorab einen verrenken müssen, um die X-Ausgabe umzuleiten.
                                        Das Spielchen mit Adapter löschen und dann (nach reboot) neu installieren hatte ich ja gestern schon erfolglos versucht. Ich kann aber gerne einen neuen Versuch wagen, und auch vorher direkt im Filesystem alles löschen, was gelöscht sein sollte, wenn Du mir sagst, was alles vom deconz-Adapter ist und wo es liegt.
                                        Komischerweise zeigte das Log in iobroker aber auch auf Level debug keinerlei Meldungen, die auf eine gestörte Verbindung hinweisen.
                                        Ich habe echt keine Ahnung, wo ich jetzt selbst ansetzen könnte.
                                        Gruss, Jürgen
                                        • Jey CeeJ Jey Cee
                                          dehein2
                                          @Jey-Cee said in deconz funktioniert nach update nicht mehr:
                                          Danke ;)
