  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
  • cashC Offline
    cashC Offline
    cash
    #266
    Der Status vom Magnetkontakt wird nicht per Callback geliefert sondern nur per Web-Api. So ist zumindest meine Beobachtung.
    • JB_SullivanJ Offline
      JB_Sullivan
      #267
      Bitte schön
      nuki-extended.0	2020-03-05 21:55:09.193	info	(3816) Listening for Nuki events on port 51989.
      nuki-extended.0	2020-03-05 21:55:09.192	info	(3816) Polling Nuki Web API deactivated.
      nuki-extended.0	2020-03-05 21:55:09.175	debug	(3816) Callback (with URL http://xx.xxx.xx.xxx:51989/nuki-api-bridge) already attached to Nuki Bridge with name Bridge.
      nuki-extended.0	2020-03-05 21:55:09.155	debug	(3816) Retrieved current callbacks from Nuki Bridge with name Bridge.
      nuki-extended.0	2020-03-05 21:55:08.502	debug	(3816) system.adapter.admin.0: logging true
      javascript.0	2020-03-05 21:55:08.485	debug	(2192) system.adapter.admin.0: logging true
      nuki-extended.0	2020-03-05 21:55:07.853	info	(3816) starting. Version 2.2.2 in C:/iobroker/GLT/node_modules/iobroker.nuki-extended, node: v10.17.0
      nuki-extended.0	2020-03-05 21:55:07.737	debug	(3816) statesDB connected
      nuki-extended.0	2020-03-05 21:55:07.737	debug	(3816) States connected to redis: 127.0.0.1:9000
      nuki-extended.0	2020-03-05 21:55:07.730	debug	(3816) States create System PubSub Client
      nuki-extended.0	2020-03-05 21:55:07.728	debug	(3816) States create User PubSub Client
      nuki-extended.0	2020-03-05 21:55:07.723	debug	(3816) Redis States: Use Redis connection: 127.0.0.1:9000
      nuki-extended.0	2020-03-05 21:55:07.722	debug	(3816) objectDB connected
      nuki-extended.0	2020-03-05 21:55:07.718	debug	(3816) Objects connected to redis: 127.0.0.1:9001
      nuki-extended.0	2020-03-05 21:55:07.706	debug	(3816) Objects client initialize lua scripts
      nuki-extended.0	2020-03-05 21:55:07.705	debug	(3816) Objects create User PubSub Client
      nuki-extended.0	2020-03-05 21:55:07.705	debug	(3816) Objects create System PubSub Client
      nuki-extended.0	2020-03-05 21:55:07.702	debug	(3816) Objects client ready ... initialize now
      nuki-extended.0	2020-03-05 21:55:07.678	debug	(3816) Redis Objects: Use Redis connection: 127.0.0.1:9001
      • cashC cash
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        #268
        @JB_Sullivan sieht alles gut aus im Log. Also Änderungen am Schloss sollten zeitnah bei dir eingehen. Was steht denn im Log, wenn du das Schloss (nicht die Tür) ver- oder aufschließt?
        @cash sagte in Test Adapter Nuki-extended v2.0.x:
        Jo, das ist richtig.
        • ZefauZ Zefau
          JB_Sullivan
          #269
          @Zefau
          So, hier jetzt das LOG während eines normalen Schließvorgang.
          nuki-extended.0	2020-03-06 15:57:05.712	debug	(7852) Updating device smartlocks.XYZXYZXYZ with payload: {"smartlockId":XYZXYZXYZ,"accountId":XYZXYZXYZ,"authId":XYZXYZXYZ,"name":"XYZXYZXYZ","favorite":true,"config":{"name":"XYZXYZXYZ","latitude":XYZXYZXYZ
          nuki-extended.0	2020-03-06 15:57:05.711	debug	(7852) getWebApi(): [{"smartlockId":XYZXYZXYZ,"accountId":XYZXYZXYZ,"type":0,"authId":XYZXYZXYZ,"name":"XYZXYZXYZ","favorite":true,"config":{"name":"XYZXYZXYZ","latitude":XYZXYZXYZ,"longitude":XYZXYZXYZ,"a
          nuki-extended.0	2020-03-06 15:57:05.629	debug	(7852) Updating device smartlocks.XYZXYZXYZ with payload: {"nukiId":XYZXYZXYZ,"state":{"deviceType":0,"mode":2,"state":3,"batteryCritical":false,"timestamp":"2020-03-06T14:57:05+00:00","locked":3},"nuk
          nuki-extended.0	2020-03-06 15:57:05.628	debug	(7852) Received payload via callback: {"nukiId":XYZXYZXYZ,"state":{"deviceType":0,"mode":2,"state":3,"stateName":"unlocked","batteryCritical":false,"timestamp":"2020-03-06T14:57:05+00:00"}}
          nuki-extended.0	2020-03-06 15:56:52.396	debug	(7852) Updating device smartlocks.XYZXYZXYZ with payload: {"smartlockId":XYZXYZXYZ,"accountId":XYZXYZXYZ,"authId":XYZXYZXYZ,"name":"XYZXYZXYZ","favorite":true,"config":{"name":"XYZXYZXYZ","latitude":XYZXYZXYZ
          nuki-extended.0	2020-03-06 15:56:52.396	debug	(7852) getWebApi(): [{"smartlockId":XYZXYZXYZ,"accountId":XYZXYZXYZ,"type":0,"authId":XYZXYZXYZ,"name":"XYZXYZXYZ","favorite":true,"config":{"name":"XYZXYZXYZ","latitude":XYZXYZXYZ,"longitude":XYZXYZXYZ,"a
          nuki-extended.0	2020-03-06 15:56:52.276	debug	(7852) Updating device smartlocks.XYZXYZXYZ with payload: {"nukiId":XYZXYZXYZ,"state":{"deviceType":0,"mode":2,"state":3,"batteryCritical":false,"timestamp":"2020-03-06T14:56:52+00:00","locked":3},"nuk
          nuki-extended.0	2020-03-06 15:56:52.276	debug	(7852) Received payload via callback: {"nukiId":XYZXYZXYZ,"state":{"deviceType":0,"mode":2,"state":3,"stateName":"unlocked","batteryCritical":false,"timestamp":"2020-03-06T14:56:52+00:00"}}
          nuki-extended.0	2020-03-06 15:56:46.909	info	(7852) Successfully triggered action -UNLATCH- on Nuki Smartlock XYZXYZXYZ (via Bridge API).
          nuki-extended.0	2020-03-06 15:56:39.121	debug	(7852) State of nuki-extended.0.smartlocks.XYZXYZXYZ._ACTION.UNLATCH has changed {"val":0,"ack":true,"ts":1583506599116,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":158
          nuki-extended.0	2020-03-06 15:56:39.116	debug	(7852) Action applied on Bridge API.
          nuki-extended.0	2020-03-06 15:56:39.116	info	(7852) Trigger action -UNLATCH- on Nuki Smartlock XYZXYZXYZ (via Bridge API).
          nuki-extended.0	2020-03-06 15:56:39.115	debug	(7852) State of nuki-extended.0.smartlocks.XYZXYZXYZ._ACTION.UNLATCH has changed {"val":true,"ack":false,"ts":1583506599105,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":158350659
          • JB_SullivanJ JB_Sullivan
            @Zefau
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            #270
            @JB_Sullivan dann funktioniert der Adapter bei dir korrekt.
            Wie cash schon schrieb: Der Magnetkontakt wird leider nicht durch den Callback aktualisiert, sondern durch die Web API.
            • NewpicselN Offline
              NewpicselN Offline
              Newpicsel
              #271
              Moin zusammen,
              Ich habe nun folgendes Problem,
              wenn ich per Skript die Klingel abstellen möchte, stellt dieses den Wert der doorbellSupression auf 7, allerdings springt dieser nach sehr kurzer Zeit wieder um auf 0(Never).
              In der App ändert sich nichts, hier ist der Wert 3 eingestellt.
              Gleiches mit anderen werten und wenn ich diese manuell umstelle.
              Weiß jemand woran das liegen könnte?
              Gruß Peter
              cashC 1 Antwort Letzte Antwort
                JB_Sullivan
                schrieb am zuletzt editiert von JB_Sullivan
                #272
                OK - Danke erstmal für die Antwort.
                Eine Frage habe ich dann noch - der Aufruf der "NUKI-Kachel" aus ioB Admin - hast DU diese Seite erstellt, oder ist das etwas was das Schloss bzw. die Bridge als Webinterface integriert hat?
                Ich frage deshalb, weil die Aktualisierung stark hinter den realen Schließungen hinterher hinkt. Wie du auf dem Screenshot siehst, war die letzte Aktion um 00:12 Uhr. Seitdem sind im App Protokoll vier neue Aktionen hinzu gekommen, die aber (noch) nicht in der - ich nenne es mal Webinterface Liste - auftauchen.
                Vielleicht kannst du auch hier noch etwas zum Thema json Tabellen beitragen, denn die dort von mir genannten Beispiele beziehen sich vornehmlich auf Tabellen deiner Adapter (roomba & Nuki). In anderen Adaptern wie z.B. dem BackItUp und dem mihome-vaccum kommen diese json Tabellen quasi Mundgerecht im DP an.
                Ich weiß ich sollte bei GIT einen feature request aufmachen, aber irgendwie bekomme ich das nicht gebacken. Hier der Link zu dem Forums Beitrag den ich meine.
                https://forum.iobroker.net/topic/15965/wie-wird-das-widget-json-table-eingestellt-formatiert/31
                ..... und dann schiebe ich gleich noch eine Frage hinterher:
                Kann man bei den Stati evtl. noch einen Datenpunkt einbauen, der dort immer denjenigen User anzeigt der als letztes das Schloss geöffnet hat - meinetwegen auch als Nummer 1,2,3,4, und nicht als Namen?
                Dann konnte man diesen Datenpunkt über ein Skript z.B. für einen Alexa Begrüßungstext weiter verarbeiten - nur so eine Idee am Rand. Ich denke die User Identifikation über NUKI ist allemal besser als über Radar2, TR-64 und den neuen fb-checkpresence Adapter.
                Entweder man hat das Schoss mit seinem Smartphone oder mit einem FOB gekoppelt und diese entsprechend namentlich definiert. Für die "zuHause" Erkennung könnte man den NUKI Datenpunkt dann zusätzlich, in was für ein Skript auch immer, einbauen.
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  schrieb am zuletzt editiert von Zefau
                  #273
                  @JB_Sullivan sagte in Test Adapter Nuki-extended v2.0.x:
                  Ist von mir erstellt.
                  Zieht er sich aus dem Datenpunkt .logs .
                  Ich nutze kein vis, daher habe ich so eine "json Tabelle" nicht erstellt.
                  Hätte ich auch sehr gerne, wird aber leider nicht über den Callback mitgeliefert :(
                  • ZefauZ Zefau
                    JB_Sullivan
                    #274
                    @Zefau sagte in Test Adapter Nuki-extended v2.0.x:
                    Hast du bei NUKI deveolpers schonmal nachgefragt, ob die planen so etwas ggf. nachzurüsten, ober ob es vielleicht sogar schon Aussagen zu dem Thema gibt?
                    Wenn nicht würde ich dort mal eine Anfrage stellen, ob so ein Datenpunkt nicht machbar ist. Damit ich keinen Blödsinn dort schreibe, über was müsste der Datenpunkt "rein" kommen - web-API oder Bridge-Http API?
                      cashC Offline
                      cashC Offline
                      cash
                      #275
                      @JB_Sullivan Such doch dort im Forum mal. Da es gibt es nämlich schon eine Anforderung, die wenn ich mich nicht irre auch sehr viel Zuspruch hat. Und wenn Du auch noch abstimmst schadet es definitiv nicht
                      Hier die Anforderung:
                      https://developer.nuki.io/t/nuki-bridge-api-bell-ring-of-nuki-opener-as-trigger-for-callbacks/2557/13
                      • NewpicselN Newpicsel
                        Moin zusammen,
                        Gruß Peter
                        cashC Offline
                        cashC Offline
                        cash
                        #276
                        @Newpicsel Welche Version hast Du? Mit der aktuellen von github funktioniert es bei mir fast perfekt. Damit meine ich das ich alles per ioBroker ändern kann. Nur der Adapter bekommt die Änderungen die per App gemacht werden nicht mit. Deshalb ist es wichtig die Datenpunkte abzugleichen damit wenn Du z. B. Die Klingelunterdrückung aktivierst nicht aus versehen andere Sachen verstellst...
                        NewpicselN 1 Antwort Letzte Antwort
                        • cashC cash
                          NewpicselN Offline
                          NewpicselN Offline
                          Newpicsel
                          schrieb am zuletzt editiert von Newpicsel
                          #277
                          @cash ich hab die version 2.2.2 direkt über iob aktualisiert, GitHub hab ich grad gesehen wäre die 2.2.3 verfügbar! werde ich nachher mal testen.
                          Edit:
                          V 2.2.3 getestet, problem besteht weiterhin.
                          Zur sicherheit habe ich den kompletten nuki-extended ordner gelöscht und den adapter neu gestartet.
                          Habe mal andere einstellungen wie sounds getestet, hier gleiches problem, liegt also nicht nur an der klingelunterdrückung.
                          Ebenfalls steht der soundlevel bei mir auf -128, hier wird mir auch eine warnung im log ausgegeben:
                          StatusCodeError: 400 - {"detailMessage":"The supplied value '-128' for parameter 'soundLevel' is not valid","stackTrace":[],"suppressedExceptions":[]}
                          Dieser wert stellt sich auch automatisch wieder auf -128 wenn ich ihn änder.
                          Keine ahnung was ich übersehe, log ist sonst in ordnung würde ich sagen!
                          nuki-extended.0	2020-03-07 12:32:11.138	debug	(16308) Updating device smartlocks.wohnungstür with payload: {"smartlockId":487399285,"accountId":xxxxxxxx1,"authId":xxxxxx8,"name":"Haustür","favorite":false,"config":{"name":"Wohnungstür","latitude
                          nuki-extended.0	2020-03-07 12:32:11.108	debug	(16308) Updating device openers.eingangstür with payload: {"smartlockId":9075702938,"accountId":xxxxxxxx1,"authId":xxxxxx8,"name":"Opener","favorite":false,"config":{"name":"Opener","latitude":xx.404
                          nuki-extended.0	2020-03-07 12:32:11.106	debug	(16308) getWebApi(): [{"smartlockId":9075702938,"accountId":xxxxxxxx1,"type":2,"authId":xxxxxxx8,"name":"Opener","favorite":false,"config":{"name":"Opener","latitude":xx.404556,"longitude":xx.048951,"
                          nuki-extended.0	2020-03-07 12:32:06.047	debug	(16308) State of nuki-extended.0.openers.eingangstür.openerAdvancedConfig.soundLevel has changed {"val":-128,"ack":true,"ts":1583580725929,"q":0,"from":"system.adapter.nuki-extended.0","user":"system
                          nuki-extended.0	2020-03-07 12:32:05.950	debug	(16308) Updating device smartlocks.wohnungstür with payload: {"smartlockId":487399285,"accountId":xxxxxxxx1,"authId":xxxxxx8,"name":"Haustür","favorite":false,"config":{"name":"Wohnungstür","latitude
                          nuki-extended.0	2020-03-07 12:32:05.910	debug	(16308) Updating device openers.eingangstür with payload: {"smartlockId":9075702938,"accountId":xxxxxxxx1,"authId":xxxxxx8,"name":"Opener","favorite":false,"config":{"name":"Opener","latitude":53.404
                          nuki-extended.0	2020-03-07 12:32:05.909	debug	(16308) getWebApi(): [{"smartlockId":9075702938,"accountId":xxxxxxxx1,"type":2,"authId":xxxxxx8,"name":"Opener","favorite":false,"config":{"name":"Opener","latitude":xx.404556,"longitude":xx.048951,"
                          nuki-extended.0	2020-03-07 12:32:05.737	info	(16308) Listening for Nuki events on port 51989.
                          nuki-extended.0	2020-03-07 12:32:05.736	info	(16308) Polling Nuki Web API with a frequency of 5s.
                          nuki-extended.0	2020-03-07 12:32:05.707	debug	(16308) Callback (with URL http://xxx.xxx.xxx.62:51989/nuki-api-bridge) already attached to Nuki Bridge with name NukiBridge.
                          nuki-extended.0	2020-03-07 12:32:05.705	debug	(16308) Retrieved current callbacks from Nuki Bridge with name NukiBridge.
                          nuki-extended.0	2020-03-07 12:32:04.893	debug	(16308) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":487399285,"name":"Wohnungstür","firmwareVersion":"2.6.6","bridge":"1883159507","state":{"mode":2,"state":3,"batte
                          nuki-extended.0	2020-03-07 12:32:04.883	debug	(16308) Updating device openers.eingangstür with payload: {"deviceType":2,"nukiId":485768346,"name":"Eingangstür","firmwareVersion":"1.3.1","bridge":"1883159507","state":{"mode":2,"state":1,"batteryC
                          nuki-extended.0	2020-03-07 12:32:04.878	debug	(16308) getBridgeApi() [forcePlainToken: true]: [{"deviceType":2,"nukiId":485768346,"name":"Eingangstür","firmwareVersion":"1.3.1","lastKnownState":{"mode":2,"state":1,"stateName":"online","batteryCr
                          nuki-extended.0	2020-03-07 12:32:04.451	info	(16308) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
                          nuki-extended.0	2020-03-07 12:32:03.553	debug	(16308) statesDB connected
                          nuki-extended.0	2020-03-07 12:32:03.552	debug	(16308) States connected to redis: 127.0.0.1:9000
                          nuki-extended.0	2020-03-07 12:32:03.541	debug	(16308) States create System PubSub Client
                          nuki-extended.0	2020-03-07 12:32:03.538	debug	(16308) States create User PubSub Client
                          nuki-extended.0	2020-03-07 12:32:03.531	debug	(16308) Redis States: Use Redis connection: 127.0.0.1:9000
                          nuki-extended.0	2020-03-07 12:32:03.528	debug	(16308) objectDB connected
                          nuki-extended.0	2020-03-07 12:32:03.522	debug	(16308) Objects connected to redis: 127.0.0.1:9001
                          nuki-extended.0	2020-03-07 12:32:03.506	debug	(16308) Objects client initialize lua scripts
                          nuki-extended.0	2020-03-07 12:32:03.505	debug	(16308) Objects create User PubSub Client
                          nuki-extended.0	2020-03-07 12:32:03.504	debug	(16308) Objects create System PubSub Client
                          nuki-extended.0	2020-03-07 12:32:03.499	debug	(16308) Objects client ready ... initialize now
                          nuki-extended.0	2020-03-07 12:32:03.464	debug	(16308) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            JB_Sullivan
                            #278
                            Ich habe mal ein / zwei Frage zum Adapter.
                            • wer sortiert die Aktionen die am Schloss ausgeführt werden - das Schloss selber oder ioB Adapter?
                            Hintergrund der Frage ist die Sortierreihenfolge der Aktionen die offensichtlich falsch ist.
                            Hier sieht man sehr deutlich, das laut Liste die Tür geöffnet wurde, bevor überhaupt durch das Ipad der Befehl zum öffnen kam.
                            Korrekter Weise müsste es heißen
                            1.) Tür von Ipad geöffnet
                            2.) Tür manuell geöffnet
                            3.) Tür manuell geschlossen
                            So wäre die Reihenfolge korrekt.
                            Die nächste Frage betrifft die Datenpunkte:
                            Warum wird mir für Door state & closed - jeweils ein Wert angezeigt der nicht mit der App überein stimmt. Die Datenpunkte sind frisch aktualisiert und der Zeitstempel ist Deckungsgleich mit der Zeit am Handy - OK den Screenshot vom Handy habe ich später gemacht, aber es hat in der Zwischenzeit keine Aktion mehr statt gefunden.
                            Ich habe das NUKI 2.0 mit dem Tür Magneten - vielleicht sollte man bei den Datenpunkten deutlicher herausstellen, welche Aktionen vom Schloss und welche vom Tür Magneten kommen. Irgendwie habe ich da immer meine Schwierigkeiten, weil offensichtlich die Aktualisierung der DP sehr träge erfolgt.
                              ZefauZ Offline
                              ZefauZ Offline
                              Zefau
                              #279
                              Ist durch Nuki Web vorgegeben, siehe https://web.nuki.io/de/#/admin/logs
                              Dort sollte das Log identisch zum Adapter sein.
                              Liegt daran, dass der Wert von Nuki Web und nicht der Bridge kommt. Die Bridge (und damit der Callback) liefert den Wert nicht. Hier gibt es einen offiziellen Feature Request, siehe https://developer.nuki.io/t/create-callback-for-door-sensor-status-in-bridge-api/1360/4
                              • ZefauZ Zefau
                                JB_Sullivan
                                #280
                                Ah - OK, ja ist identisch - dann ist das aber von Seiten NUKI von der Logik her schon falsch.
                                  ZefauZ Offline
                                  ZefauZ Offline
                                  Zefau
                                  #281
                                  @JB_Sullivan dann am besten im Developer Forum einen Thread aufmachen.
                                  • ZefauZ Zefau
                                    JB_Sullivan
                                    #282
                                    @Zefau
                                    Habe ich gemacht und auch ziemlich schnell eine, naja sagen wir mal wenig befriedigende Antwort bekommen. Die NUKI Jungs scheinen eine eigene Logik zu verfolgen die für die breite Masse mitunter schwer nachzuvollziehen ist (das Gefühl habe ich wenn die anderen Beiträge dort so lese).
                                    Das ist denen aber weitest gehend egal - Hauptsache sie verfolgen IHR Entwicklungskonzept weiter.
                                    Hier die Antwort
                                    Befehle werden in das Protokoll geschrieben, wenn sie abgeschlossen sind und nicht, wenn sie gestartet werden. Das Öffnen der Tür (vom Türsensor) wurde registriert und abgeschlossen, bevor der Befehl "Tür öffnen" (vom iPad) abgeschlossen wurde, daher ist dies korrekt und kein Fehler.
                                      @Zefau
                                      Hier die Antwort
                                      cashC Offline
                                      cashC Offline
                                      cash
                                      #283
                                      @JB_Sullivan Ich finde die Antwort schon nachvollziehbar und sie sagt ja nun aus das das ipad einfach zu langsam ist :-)
                                      • cashC cash
                                        JB_Sullivan
                                        #284
                                        @cash
                                        Ich würde nicht sagen, das dass Ipad zu langsam ist, sondern die interne NUKI Kommunikation. Ist mit allen mobilen Endgeräten das gleiche - also nicht Eier-Kram spezifisch.
                                        Die Erkennung das ich vor der Tür stehe, wird ja durch die Bluetooth Feldstärke und Geofence bzw. WiFi Feldstärke bestimmt.
                                        Wird die Bedingung als positiv erkannt, wird die Tür geöffnet. Damit ist an dieser Stelle die Aufgabe des Ipad als Befehlsender erledigt.
                                        Dann öffne ich die Tür - Also Magnetkontakt AUF - erst jetzt, ist für das Schloss bzw. die Bridge der Befehl "Öffne Tür" beendet und es wird ein Log Eintrag erzeugt. Schließe ich nun die Tür hinter mir, kommt der zweite Log Eintrag.
                                        Da die Tür ja automatisch aufspringt, wird das unterbrechen des Magnetkontakt quasi ebenfalls eigenständig erkannt. Erst dann erfolgt der LOG Eintrag das die Tür Öffnung angefordert wurde.
                                        Entweder die Abhängigkeit ist miteinander verknüpft, oder die Rückmeldung NUKI -> Smartphone bzw. -> Bridge ist dermaßen Grotten langsam das es zu den unlogischen History einträgen kommt.
                                        Für mich als Endanwender ist die "Logik" dahinter schwer nachvollziehbar.
                                          @cash
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #285
                                          @JB_Sullivan ich vermute das ist technisch bedingt: Der Sensor funktioniert über Zigbee und ist in der Reaktion fast synchron. Das Öffnen der Tür funktioniert über den Callback und ist daher leicht zeitversetzt.
                                          Da die Aktionen fehlschlagen können, wird nur ein Erfolg protokolliert. Daher entsteht am Ende ein Bild, welches inkonsistent ist.
                                          Grundsätzlich gebe ich dir recht, dass es schwierig nachvollziehbar ist. Leider ist es nichts, was wir ändern können.
